Hi,
I recently got a great deal on a 2017 Passat but was informed it has some electrical issues. After scanning the vehicle, I’ve identified the codes, but I’m having trouble coding the ABS. I’d be grateful if someone could assist me with this.
Thank you so much in advance for your time and help!
PR CODE:
PR CODE:
VIN: 1VWAT7A38HC014104
Address 01: Engine (J623-CPRA) Labels:. 06K-907-425-V2.clb
Part No SW: 06K 906 071 BJ HW: 06K 907 425 C
Component: R4 1.8l TFS H13 4891
Revision: --H13--- CVN: 885AB9B6
Coding: 001A0092242400170000
Shop #: WSC 09003 957 00200
ASAM Dataset: EV_ECM18TFS02006K906071BJ 001010
ROD: EV_ECM18TFS020_VW41.rod
VCID: 74A4276BDFA01A36DF-8020
VINID: 0669D19074432184C004404010CFC7B63F
17178 - Databus
U1123 00 [00101111] - Received Error Message
Mileage: 117345 km
Date: 2058.14.21
Time: 00:24:59
Engine RPM: 0.00 /min
Coolant temperature: 66 °C
Intake air temperature: 44 °C
Voltage terminal 30: 11.738 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 BD HW: 09G 927 158
Component: AISIN AG6 G3 202 3121
CVN: CBD86859
Coding: 010200000C000000000000000000000000000000
ASAM Dataset: EV_TCMAQ250031 002009
ROD: EV_TCMAQ250031_002_VW25.rod
VCID: 76A01D63C9DC0826E1-8022
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
VCID: 75A21A6FDCDA033EE8-8020
Reset counter: 90
Date: 2058.14.21
Time: 00:22:07
Count: 3
Count: 12
Count: 20992
Count: 195
Count: 42496
Fault Status: 01100101
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:06
Count: 3
Count: 12
Count: 4096
Count: 212
Count: 42496
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:06
Count: 3
Count: 12
Count: 4096
Count: 279
Count: 42496
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:06
Count: 3
Count: 12
Count: 4096
Count: 270
Count: 42496
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:06
Count: 3
Count: 12
Count: 4096
Count: 291
Count: 42496
Part No SW: 561 907 044 BE HW: 561 907 044 BE
Component: Climatronic H08 0910
Revision: 00001K05
Coding: 0070019002
VCID: 5BF66CD7523EB54EFE-800E
Part No SW: 5K0 937 085 AE HW: 5K0 937 085 AE
Component: BCM PQ35 B+ 122 0184
Revision: BH122001
Coding: EF200E18942B0CD4088802010400044800F1000640801920E48062000C70
VCID: 76A01D63C1DC0826E1-8022
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 B HW: 7N0 907 572
Component: ACC Bosch PQx H03 0120
Serial number: 28061677090538 Dataset Number: V03935236LL 0001
Coding: 01001000FE0739
ASAM Dataset: EV_ACCBEGVW361 001005
ROD: EV_ACCBEGVW361.rod
VCID: 3522DA6F945A433E28-8060
7 Faults Found:
15360768 - Component Protection
U1101 00 [00001001] - Active
[FAULT_ATP_IKA_FAST_FAILED]
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:08
Control Module temperature: 26 °C
Voltage terminal 15: 11.7 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1070 - Databus
[FAULT_CIS_AXV_FAIL]
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:08
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:11
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:11
1540 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [00001001] - -
[FAULT_MISALIGNMENT_HORIZONTAL]
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:08
1792 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
[FAULT_WORKSHOP_ALIGNMENT_NOT_DONE]
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:08
1074 - Databus
[FAULT_CIS_YAW_FAIL]
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:08
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 008 0210
Serial number: 003RXM07KTW1 Dataset Number: 561003V____ 0012
Coding: 8CCCCC00000000005000001A020800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411.rod
VCID: 638654376A4E8D8EB6-8036
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005MS6U8
Coding: 303245
Subsystem 2 - Part No SW: ----------- HW: 480 002 106 16
Serial number: 357000000009D445AB1T
Subsystem 3 - Part No SW: ----------- HW: 480 002 106 16
Serial number: 3580000000019345AB1H
Subsystem 4 - Part No SW: ----------- HW: 480 020 107 16
Component: SideSensor_Dr 000 0148
Serial number: 3510001B9213E8D1D5CG
Subsystem 5 - Part No SW: ----------- HW: 480 020 107 16
Component: SideSensor_Pr 000 0148
Serial number: 3520001B7213E8D6C58F
Subsystem 6 - Part No SW: ----------- HW: 480 022 505 16
Component: FrontSensor_D 000 0189
Serial number: 3550001BB20E18B370EA
Subsystem 7 - Part No SW: ----------- HW: 480 020 306 16
Component: FrontSensor_P 000 0189
Serial number: 3560001B520E18B4450.
Part No SW: 1K5 953 521 CM HW: 5K0 953 569 BC
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20160622201396
Coding: 0882440008
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 7AB80953FDC46C4685-802E
Subsystem 1 - Part No SW: 6C0 959 442 G HW: 6C0 959 442 G Labels: 3C8-959-537.CLB
Serial number: 1701609025000932BE2B
Coding: 280000
Address 17: Instruments
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 10081603010226
Coding: 461020
VCID: 7BB60C57FAFE554E9E-802E
Component: IMMO H03 1104
Coding: 000002
Shop #: WSC 06050 062 00200
VCID: 6A9839138D64DCC675-803E
Part No SW: 561 959 701 B HW: 3C0 959 793 H
Component: TUER-SG FT 002 0637
Revision: 13100010 Serial number: 0010569424
Coding: 040495
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 1D7222CF0CAAFB7EC0-8048
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 C HW: 561 959 811 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 022 1472
Serial number: 14102746160813185823
B11EC 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:14
131584 - Motor for Rear Window Regulator
B11EE 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:14
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 311 3501
Revision: 00H22000
VCID: 393AD65F7042A75ECC-806C
Fault Status: 11100101
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:15
Battery Volts: 11.9 V
DD
Temperature: 19.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1682
Coding: 00000008
VCID: 6FAE2807BE8639EE22-803A
Subsystem 1 - Part No SW: 561 919 204 C HW: 561 919 204 C
Component: Analoguhr 002 0003
Part No SW: 561 959 702 B HW: 3C0 959 792 H
Component: TUER-SG BT 002 0637
Revision: 15100010 Serial number: 0010574759
Coding: 040494
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1E7025C301ACE066D9-804A
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 C HW: 561 959 812 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 022 1472
Serial number: 14202747160814234334
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:17
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:17
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 561 035 150 A HW: 561 035 150 A
Component: MU-E--US 055 7067
Serial number: 29061600012978 Dataset Number: V03935246TD 0001
Coding: 02140100BE00000041220001001000009F0000D40000010000
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 0B565C97A25E65CEAE-805E
[Anti-theft protection - component protection active (0xEA6300)]
Reset counter: 90
Mileage: 117345 km
Date: 2058.14.21
Time: 00:22:18
Voltage terminal 30: 11.8 V
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: E1200859
VCID: 71AA2E7FA8B22F1E34-8024
