2005.5 A4 B7 - ABS fault code - 00493 - ESP-Sensor Unit (G419) 001 - Upper Limit Exceeded
AudiNexus
C?ID=353164
Looking for help diagnosing ABS fault:
I looked at mb 005 under 03-ABS and noticed fluctuating activity on G202 (with the engine NOT running)
Is it normal to see activity on that sensor even with the engine not running?
I also attempted a Basic Setting on G419 (as it is available in the drop down) however it comes up saying not available. I did enter the security code 40168 which was successful.
Is that Basic setting really not available, or is there some order of events I'm not following?
Monday,13,January,2025,07:28:58:39111
VIN: WAUDG68E25A453163   License Plate:
Chassis Type: 8E (01 - My Car)
Scan: 01 02 03 08 09 15 16 17 36 45 46 55 56
VIN: WAUDG68E25A453163   Mileage: 260050km-161587miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 8E0 910 559 D    HW: 8E0 907 559 A
   Component: 3.2l V6 FSI         0050
   Revision: --H16---    Serial number:
   Coding: 01040106190F0120
   Shop #: WSC 06335 000 00000
   VCID: 2E050C9DCC1EC90AFD7-807A
   VINID: 9D19545C62150854441430460C13FE1612
   Part No SW: 8E1 910 156 B    HW: 09L 927 156
   Component: AG6 09L 3,2 FSI USA 0020
   Revision: --H01---    Serial number:        0084713
   Coding: 0000002
   VCID: 2615F4BDE4EE814A057-8072
   Part No SW: 8E0 910 517 C    HW: 8E0 614 517 BB
   Component: ESP8 quattro    H04 0180
   Coding: 0004532
   VCID: 270BF9B9E3E498423E1-8072
                    Fault Status: 01100001
                    Hex Value: 0x2400
                    Hex Value: 0x4006
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAD
                    Hex Value: 0x07FF
   Part No: 8E0 820 043 AL
   Component:   A4 Klimaautomat   2728
   Coding: 00000
   VCID: 6B83C5893A9C7C229A9-5184
   Part No: 8E0 907 279 J
   Component: int. Lastmodul  USA 0303
   Coding: 01023
   Shop #: WSC 65536
   VCID: 392F2FC100401EB2585-4B1E
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036N0004FY%
   Coding: 0032607
   VCID: 3C2136D50A622B9A433-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 02  0070
   Serial number: 6332DRB401114DA2F
   Coding: 00032607
   Subsystem 2 - Serial number: 6342DRB40135D32FQ
   Subsystem 3 - Serial number: 6352ARB4003E18C4O
   Subsystem 4 - Serial number: 6362ARB4003E125DL
   Subsystem 5 - Serial number: 63729RB4003D97F9$
   Subsystem 6 - Serial number: 63829RB4003E3FBC%
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 02041
   Shop #: WSC 06335
   VCID: 41DF472168904672105-4B1E
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8E0 920 981 N    HW: 8E0 920 981 N
   Component: KOMBI+WFS 4     H12 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0021261
   Shop #: WSC 05152 444 83926
   VCID: 38292AC53E4A07BAA7B-5184
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71BFD7E1188096F2A05-4B3C
   Part No: 8E0 959 433 BT
   Component: Komfortgerát T7B    3132
   Coding: 11836
   Shop #: WSC 06335
   VCID: 04518E353702935A7B3-4B1E
   Subsystem 1 - Part No: 8E1959801F
   Component: Tõrsteuer.FS BRM 0305
   Subsystem 2 - Part No: 8E1959802E
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0205
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Coding: 0000019
   Shop #: WSC 05152 444 64193
   Subsystem 1 - Part No: 8E0 941 329
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 8E0 941 329
   Component: AFS-Modul rechtsH05 0030
   Part No: 8E0 035 195 H
   Component: symphony II PM6    0410
   Coding: 01005
   Shop #: WSC 70656
   VCID: 2C010695FF22BB1AD33-508A
End----------(Elapsed Time: 01:32, VBatt start/end: 13.7V/13.8V)-----------
I think so. That sensor is quite sensitive and could pick up very small motions. How much fluctuation are you seeing? Put your laptop on the ground outside the car and remain outside the car yourself while looking at it.
It may be rejected due to the fault you have. Have you tried clearing faults in the ABS first?
FWIW, my guess is you need a new ESP sensor unit. They do fail.
AudiNexus
C?ID=353164
The fluctuation is a very rapid oscillation between -0.2 and -0.6 deg/sec. It did appear steady however when monitoring from the ground outside the car, but still throws the fault code.
When I clear the fault it just comes back within seconds. If that is why Basic Setting 069 remains unavailable then I will move on to replacing the sensor.
I cannot tell you that with certainty, but it strikes me as likely.
Dr Sheldon
Windsor UK
C?ID=334979
fluctuation is a very rapid oscillation between -0.2 and +0.4 deg/sec.
That is a fault if the car is stable and not rocking
WTF does "appear" mean ?? Is it steady or not ?
Graph it with VCDS and post please.
AudiNexus
C?ID=353164
I hear you. I hadn't taken the testing-time to be able to predict the exact results, I apologize and appreciate the help.
Just fyi, I edited my previous post - originally had values fluctuating from -0.2 to +0.6 but that was incorrect. Values are -0.2 to -0.6 (always < 0 )
There was no difference this time between being in the car or not.
Results:
Ignition on / engine off
Opened controller 03- ABS
Watched MB 005 - G202 fluctuates between -0.2 and -0.6 deg/sec for 1 minute ( I timed it) then holds at -0.14
Checked for fault - Fault is present
Cleared fault
Watched MB 005 - G202 steady at -0.14
Checked for fault - no fault present
Backed out 1 step ( controller still open) and checked fault again - still no fault present
Repeated previous step 5 times - no change
This condition holds (no fault, value at -0.14) for as long as I have the controller open
Entered security code - 40168
Attempted to access Basic Setting 069 - Not Available
Closed controller 03- ABS
Checked for fault - Fault is present ( closing and reopening the controller revives the fault)
Watched MB 005 - G202 now steady at 0.00
Cleared fault
Watched MB 005 - G202 still steady at 0.00
This condition holds (no fault, value at 0.00) for as long as I have the controller open
If I turn the ignition off and repeat, the test results begin from the top and are identical.
Results are also the same if performed with the engine running.
With the engine running it takes 1 minute, coincidentally, from when I turn it over before the dashboard ESP warning light comes on.
I have also pulled the ABS and ESP related fuses hoping to reset the G202 sensor but I'm not convinced either of those kills the power to the ESP unit. With the ESP fuse pulled MB 005 still shows activity on the G202 channel, and with the ABS fuse pulled I cannot open the 03 - ABS controller so MB 005 can't be checked.
Do I understand this correctly; the G202 sensor is falsely detecting the car spinning around its vertical axis, albeit slowly, for 60 seconds and then hits a predefined maximum of data input [ hence the 001 Upper Limit Exceeded ] before sending the fault and illuminating the warning light?
Dr Sheldon
Windsor UK
C?ID=334979
A fluctuation is a fluctuation - The numbers are academic !
AudiNexus
C?ID=353164
First 60 seconds after turning on the ignition. Scale -1 to +1:
AudiNexus
C?ID=353164
Replacing the ESP Sensor fixed the issue. No fault codes and no dashboard light.
Thanks for the help and suggestions.
The measuring block graph still shows activity on G202 at rest, but does not flatline after 60 seconds like before. Also the Basic Setting 069 is still not available so I'm thinking that must be normal for this car.
I'm content since everything is working, but if anyone feels like running this log on a known good car of around the same age I am curious if the G202 behaves the same.
AudiNexus
C?ID=353164
On second thought, now that the sensor is not causing fault codes, are there any other reasons the Basic Setting 069 would be blocked?
Are you doing this with Key On, Engine OFF? The latter is essential.
It must also be done with the car on a flat surface and the car must not be moved, rocked, or otherwise disturbed.
AudiNexus
C?ID=353164
Yes to all of the above, including with the laptop on the ground next to the car. It is accepting the security code and I am going directly to Basic Setting 069. I had noticed when going to Basic Settings that are not blocked the security code allows access to only 1 at a time, so I made sure I wasn't violating that restriction.
