- Dec 23, 2020
- 7
- 2
- Fort Myers, FL, USA
- C?ID=428597
As of the other day, I've noticed an error with my lane change assist. I've never had any issues with it and used it daily for several years. This is the passenger-side module with P/N 568B. Can this go out of adjustment on its own? The rear bumper hasn't been hit, no damage of any kind. I'm a bit confused how this needs to be calibrated. I looked at the current values and saw quite a variance.
Dynamic angle offset lane change assist 1 7.47°
Dynamic angle offset lane change assist 2 -4.32°
How does this happen all of a sudden? Can I calibrate this on my own, or am I doomed to deal with the dealer? The modules still appear to work unless I misunderstand this error.
729861 - Control Module for Lane-Change Assist
C1114 F0 [00001001] - Automatic Calibration Not Possible
Any help is greatly appreciated.
P.S.P0087 error was due to items unplugged when I was changing spark plugs.
Sunday,12,January,2025,18:41:52:23173
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WA1CGAFP1FA040474 License Plate:
Mileage: 171220km-106391mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
69 6C 6D 72 A9
VIN: WA1CGAFP1FA040474 Mileage: 171220km-106391miles
Address 01: Engine (J623-CTUD) Labels:. 06E-907-551-CGW.clb
Part No SW: 8R0 907 551 G HW: 4G0 907 551 A
Component: 3.0l V6 TFSIH07 0007
Revision: --H07--- CVN: 782EEB24
Coding: 2A2A0034053600060000
Shop #: WSC 59021 001 1048576
ASAM Dataset: EV_ECM30TFS0218R0907551G 001007
ROD: EV_ECM30TFS0218R0907551G.rod
VCID: 3C213F5196EE0FBA433-8068
VINID: 9D10535D15A0056440100107105308E593
6237 - Fuel Rail/System Pressure
P0087 00 [01100101] - Too Low
Mileage: 171223 km
Date: 2025.01.11
Time: 17:17:32
Engine RPM: 2986.00 /min
Normed load value: 43.9 %
Vehicle speed: 148 km/h
Coolant temperature: 93 ∞C
Intake air temperature: 27 ∞C
Voltage terminal 30: 13.913 V
Engine speed: actual: 2944 /min
MAF_ENVD: 501.12940 mg/stroke
Coolant temperature (unfiltered): 93.75 ∞C
FUEL_MASS_REQ_I_CTL_ENVD: 50.250000
FUP_ENVD: 61133.2965 hPa
FUP_EFP_ENVD: 5455.31 hPa
Readiness: 0010 0100
Part No SW: 8R0 927 158 AB HW: 0BK 927 156 AM
Component: 0BK 30TFSIUSA H18 1003
Revision: --H18--- CVN: A73896DF
VCID: 7DA7F255CD74C6B234D-8028
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AS HW: 8R0 907 379 AS
Component: ESP8 quattro H09 0020
Coding: 309D1801
VCID: 117FBEE5E16CD2D2C05-8044
Part No SW: 8K0 907 064 JP HW: 8K0 907 064 JP
Component: BCM2 2.0 H14 0650
Coding: 0D854040000000000000
Shop #: WSC 06335 000 00000
VCID: 074B90BD9F289C621E1-8052
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0214000154102015
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 AQ HW: 8K1 820 043 AQ
Revision: C1000000 Serial number: 01010920141697
Coding: 6601228000
Shop #: WSC 06342 000 00000
VCID: 77ABE07DEFC8ECE26E1-8022
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000885043301
Coding: 26008091863CAFE0010040C300003D0D0F9CE708A2090221000008004000030100000034000000
VCID: 78A9E341E2D6E39A67B-802C
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 140725 H12 0050
Serial number: 90243014140718111703
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 23111730
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001508140359
Component: USHL4.2 H30 0030
Serial number: 00000000095Z009969BF
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 9B580547000000000001
Part No SW: 8K0 959 655 R HW: 8K0 959 655 R
Component: AirbagVW-AU10 H51 0812
Serial number: 003NED12EDC9 Dataset Number: 8R0909602F 0002
Coding: 303634313432383132304A55304C38523053
ASAM Dataset: EV_AirbaECUVWAUDI010 003114
VCID: 4CC16F91C64EBF3AF33-8018
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R140000L6JD
Serial number: 6334MSME7E624C71Q
Serial number: 6344MSME7E622D54R
Serial number: 6352QSME49443D6CW
Serial number: 6362QSME19494868R
Serial number: 63732SME28494074.
Serial number: 63832SME2849174E6
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NI20014D
Coding: 000037
VCID: 48C95381D2B6531AD7B-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 C HW: 8R0 920 982 C
Component: KOMBIINSTR. H35 0564
Revision: 00400000 Serial number: R+A45LX8F
Coding: 8BBF22000301D705020000
Shop #: WSC 33609 002 104857
VCID: 3B233C4D936008824A9-806E
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z148110304
Coding: 80C103FF00
VCID: 4CC16F91C6CEBF3AF33-8018
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 2659164103
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000114744011
Coding: 00581B00000000000000
VCID: 42DD41A9F48A794A09F-8016
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0344291274 Dataset Number: 8R0909535F 0021
Coding: 010221
VCID: 3FDB485D87F814A2661-806A
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0344952990
Coding: 010221
Reset counter: 43
Mileage: 171215 km
Date: 2025.01.11
Time: 13:56:42
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000115574191
Coding: 011D13215E00440004
VCID: 4FFB789D37D88422961-801A
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H41 0510
Revision: 00001000 Serial number: 0028915745 Dataset Number: 8R0909852J 0022
Coding: 100000010000
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D75AB5E5244E722CD-8010
Revision: 00002001 Serial number: 0344628960
Coding: 01260E3A20FA70958430053200040000
Component: GTO BF H01 0080
Serial number: 00000000000000873959
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 43
Mileage: 171215 km
Date: 2025.01.11
Time: 13:57:07
02616 - Fuel Tank Cap; Unlock
Reset counter: 43
Mileage: 171215 km
Date: 2025.01.11
Time: 13:57:58
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000113969022
VCID: 4EC5659930D28D2A9D7-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 30000000258118
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2D39499CDA318A51F-806E
Part No SW: 4G0 035 082 H HW: 4G0 035 082
Component: Radio U SIRIU H60 0138
Revision: AB001007 Serial number: 156H/0E8056245
Coding: 020007020100000001
VCID: 2517FA3505E4AE720CD-8070
Part No SW: 8R1 035 746 K HW: 8R1 035 746 D
Component: H-BNT-NA H41 1040
Revision: -------- Serial number: 204I80E7676884
Coding: 1A0200060205A1EF5502AF5E00000403140000000000000000
VCID: 3FDB485D877814A2661-806A
Subsystem 1 - Part No: 8R0 060 884 GB
Component: NAR 2019 1901
Component: DU7 High H42 0104
Serial number: A130HO0E3117541
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Serial number: 00000001962139
Component: CD-Database 5950
03623 - Invalid Security/Release Code
Reset counter: 43
Mileage: 171215 km
Date: 2025.01.11
Time: 13:56:43
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000115232377
Coding: 010C13204000240004
VCID: 46D55DB9D8A2456A257-8012
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00000324132072
Coding: 0200000000000000
VCID: 36352D79A842D5EAB57-8062
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H09--- Serial number: 525PA8-J46A094
Coding: 1030010
VCID: 34311771B23EC7FA8B3-8060
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D2732558D7406B274D-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000115237184
Part No SW: 8R0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0001
Serial number: 140703200501
End----------(Elapsed Time: 02:17, VBatt start/end: 12.3V/12.3V)-----------
Sunday,12,January,2025,18:44:59:23173
69 6C 6D 72 A9
Readiness: 1110 1101
Coding: 309D1801
No Faults Found
Coding: 6601228000
Coding: 01DD13
Coding: 02005C
Coding: 000037
Coding: 80C103FF00
Coding: 010221
Coding: 010221
Reset counter: 44
Mileage: 171227 km
Date: 2025.01.12
Time: 18:42:07
Reset counter: 44
Mileage: 171227 km
Date: 2025.01.12
Time: 18:42:09
Hex Value: 0x0004
Hex Value: 0x000B
Count: 6
Coding: 1030010
End----------(Elapsed Time: 02:08, VBatt start/end: 12.2V/12.2V)-----------
