Can you increase idle RPM in Engine adaptation on a VW GTI MK7 with EA888 gen 3 engine?
Ziddywerks
Northern NJ USA
C?ID=208579
Best way would probably be to shim the relief valve in the oil pump. That should give it a good bump in pressure sometimes good enough for 1bar or more of additional pressure. This has been done in many race engines where oil pressure is needed.
   #23
geyungjen
Fremont, CA, USA
C?ID=606828
Yes, I have this on agenda when I have the time to remove the oil pump:
   #26
RGH0
Australia
C?ID=433612
At idle the relief valve will be fully closed so shimming the spring does nothing. This only increases the pressure at which the valve opens which only occurs at higher RPM. It is done on race engines to increase oil flow at high engine speeds for better bearing cooling
If you have excessive bearing wear then oil pressure measured will be lower especially when your engine oil is hot but it also could be due to oil pump wear or a failed / jamming relieve valve
A new oil pump or if you can source a high volume oil pump this may correct the low idle pressure issue.
Going to a 10W / 60 full synthetic group 4 and 5 base oil lubricant will also help. These are typical sold as competition oils as they are designed to run at high temperatures with less viscosity loss.
Long term it probably going to need an engine replacement or rebuild depending on the extent of the bearing damage
geyungjen
Fremont, CA, USA
C?ID=606828
"If you have excessive bearing wear then oil pressure measured will be lower especially when your engine oil is hot but it also could be due to oil pump wear or a failed / jamming relieve valve
Going to a 10W / 60 full synthetic group 4 and 5 base oil lubricant will also help. These are typical sold as competition oils as they are designed to run at high temperatures with less viscosity loss."
Good point. I will start with: (because that is easier to do)
   #30
geyungjen
Fremont, CA, USA
C?ID=606828
Hi RGH0,
Thanks for mentioning "10W / 60 full synthetic group 4 and 5 base oil lubricant", I Googled "Group 5" means "ester based", one of them is Motul 300V LE MANS 10W-60 Motor Oil, ester based.
I checked its viscosity at 100 degree is 23.6mm^2/s
Then I look at other Motul full synthetic 10w60 oils, all of them, viscosity at 100 degree are 23.6mm^2/s, those are cheaper, not ester based.
Does that data point "100 degree is 23.6mm^2/s" indicate all Motul 10W60 oils will have the same amount of viscosity loss at 100 degree C, (Group 5, ester based) or not?
Thanks again
   #31
davisev5225
C?ID=263265
My man, you're going way too deep into subjects that aren't likely to solve your issue. You have a low pressure indication not because you're using the wrong oil, but because you have either a mechanical or electronic issue in your engine.
Mechanical: oil pump bypass stuck open or pump is worn out
Electronic: oil pressure switch(es) aren't properly registering the actual pressure
Stick with the pump diagnosis, don't go off in the weeds trying to learn everything there is to know about high viscosity racing oils. There's actually other reasons not to use them anyway, such as insufficient flow through tiny oil passages in the heads. Pressure isn't everything, volumetric flow is actually more important in your engine's oiling system. Too high a viscosity in an engine that wasn't designed (or modified...) for it is actually a bad thing.
   #32
RGH0
Australia
C?ID=433612
The specification data is for new oil and all 60 spec oil will be similar when new. However the cheaper oils loose their hot viscosity much faster in use due to shearing of the polyethylene additives used to increase their hot viscosity.
As for issues with higher viscosity oil in the small oil passages, it is a much stated problem but little evidence to support it. If real this would only be a problem at low temperatures as all oils low temp viscosity are much higher than at normal operating temperatures. Small passages are much more likely to be fouled with sludge and varnish / gum from cheap oil deterioration.
In the end, as has been said, you have a mechanical or electrical problem. Higher viscosity oil may enable you to carry on for sometime but in the end you will need to solve the base problem
   #33
geyungjen
Fremont, CA, USA
C?ID=606828
Thanks for sharing the knowledge, much appreciated.
   #34
geyungjen
Fremont, CA, USA
C?ID=606828
Yes and no. Your ECU does have an Adaptation Channel for it:
IDE00259-ENG104054 -- Idle RPM correction - Idle Speed Offset
However, I'm near certain you won't be able to change it. It probably requires a Security Access code that not generic like it is on older TDIs and isn't known (at least to me).
Now, I have answers to my own questions:
1. Can you increase idle RPM in Engine adaptation on a VW GTI MK7 with EA888 gen 3 engine? Yes
2. "Unlike TDIs, most Gasoline engine controllers after (roughly) model year 2005 will not allow modifications to the idle speed.", it it true? This statement is not true with VW MK7 with EA888 Gen 3 (Gas engine, non TDI).
Here are steps what I have taken:
1. Pop up the hood.
2. Connect my standalone OBD2 scanner, start the car engine running (idle of course).
3. Using the standalone OBD2 scanner device to scan and clear engine module fault code if there is any.
4. Stop and then restart engine after clearing the fault, plug in VCDS connector.
5. Launch VCDS app, Application->Controller Channels Map, select Whole Vehicle, Output to Raw Hex, Check Adaptations option, Then click Go, wait until done. This is for restoring to previous state in case adaptation goes wrong.
6. Back out all the way to the main menu, click "Select"->01 Engine->Security Access, enter 27971, the code was accepted. Note, Before try 27971, I entered 20103, which was refused. Despite warning says "...allow only one access attempt... wait 10 minutes...", I did not wait 10 minutes, immediately enter 27971, which was accepted.
7. Then back to menu, select Adaptations->Idle Speed Adjustment, default is 0 RPM/min, I set to 50 RPM/min, then click do it. The new value 50 was accepted.
Exit VCDS app, re-enter VCDS to Adaptations, the stored value and new value shown are 50 /Min, the change appears to be persistent.
I did attempt to change from 50 to 100 following the same process, it will not change to 100, stay with 50, which indicates only allow delta increase of maximum 50 rpm/min from defaut delta idle rpm of 0 /min (stored value). The logic appears ignoring any RPM increase if stored value + new value > 50 / min, clicking do it will do nothing.
Thanks for all inputs, as a new bee with VCDS, I enjoy this forum discussion.
Given what you've found, I suspect most of those steps are superfluous.
- Clearing faults in 01-Engine is probably a good idea.
- Security Access with the relevant code, which in this case seems to be 27971.
- Change the Adaptation Channel within the allowable limits.
Those limits do vary from one engine/ECU to another. Back in the old MK3 VR6 days, the I believe the limit was +/- 40 RPM. I've heard that the Eurovan's 24V VR6 will accept much larger changes, but I've never tried that.
How about trying the abbreviated procedure and changing things by 10 RPM at a time? Drop to from 50 to 40 first to see if the procedure works. Then try 60, 70, and so on, to see where the actual limit for your particular engine/ECU actually is?
AINils
Germany (AIB)
C?ID=56975
Are you also to lower that value again after you fix your issue?
Won't try that on our cars as the engine is working fine with stock value ;-) But just out for interest
   #37
Dr Sheldon
Windsor UK
C?ID=334979
Ouch 🤕
   #38
I've never seen any indication on older cars that idle adjustments via Adaptation were irreversible.
geyungjen
Fremont, CA, USA
C?ID=606828
Did a few more experiments:
1. Reduce idle rpm delta from stored value of 50 /min to 40 /min, not successful:
Increase idle rpm delta from stored value of 50 /min to 60 /min, no error, but no change either, stay at 50 /min.
2. Attempt to activate Run In Oil Pressure, not successful with same error:
The error "Conditions not met" is about ECU throw error code NRC 22, following is good illustration about the possible cause, assuming the "Request" below is a long code:
It appears ECU does not accept long code to activate Engine Run in oil pressure adaptation that the client sent to the ECU, the server.
Need to mention, I did clear Engine fault prior to the experiment, so the ECU is not in critical state, as one of the conditions need to be met.
Run in oil pressure is set by the manufacturer, i.e., VW when the car just out of assembly line, or by dealer, when a new or rebuilt engine has been installed, for the so called breaking in period of first 1000KM, while Engine is operating only in high RPM mode, i.e., oil pressure regulation control valve N428 is always in closed state. So there has to be a valid long code request to activate Run in oil pressure.
It is also probable that Activating Run In Oil Pressure requires a security access code other than 27971, same might be true to reduce stored idle RPM value.
After increase the idle RPM, which is now about 750 /min:
So far, the maximum idle for my VW GTI MK7 is about 750 ~ 760 rotation /min.
geyungjen
Fremont, CA, USA
C?ID=606828
Hi RGH0,
I researched all the 10w60 oils and decided to use Liquimoly 10w60, good price at the well known ecommerce site:
The data point I was looking at is vicosity at 100 degree C, Liquimoly's data point appears to be one of the highest amongest different brands at 25,0 (German notation, in US, it is 25.0)
After I replaced the oil with Liquimoly 10w60 (6 Liter, the GTI needs to 6 quarts), I saw improvement in oil pressure when the car is hot:
Before, even with Mobile 5W50, it would have been 0.6 bar at around 210 F (98 C), while 0.9 bar at 210 F as shown with Liquimoly 10w60.
In fact, during road test, with 10w60 oil, the oil temperature went up to 235 degree F (112 degree C, I should have configured to show temperature on dashboard in C instead of F by default) and the oil pressure went to 0.7 bar (the lowest, but better than before, 0.4 bar with VW502 oil at 5w30 or 40, note, VW502 oil is designed for this car)
I looked at the reduced oil pressure switch (The Brown one), that I have replaced wishing it were the problem, it was not. It shows 0.55 bar to 0.85 bar threshold to activate and deactivate low oil pressure warning.
The specs of the oil pressure switch says that, if the oil pressure < 0.55 bar, a warning of low oil pressure will be triggered by the ECU and shown on the dashboard (with code P164D00), if there is such warning, the warning will dissapear from dashboard if later the oil pressure >= 0.85 bar.
The lowest oil pressure at 235 degree F was at 0.7 bar, above the threashold of 0.55 bar, hence there was no warning during the road test.
For now, the car is drivable, not for long distance though, do not have confidence. This is not a solution, at best it is a bandaid work around, I still plan to replace the oil pump later when I get a chance to do so. However, before attempting to replace the oil pump, not sure if the oil pump is the culprit, I may replace the stock plastic oil sump (pan) by aluminium one with cooling fins:
It holds 7 quarts of oil, and works like heatsinc to cool the oil, in an attempt to lower the oil temperature to maximum around 210 F or 100 degree C. Replacing oil sump is easier than replacing oil pump too. Let me know what do you think about aluminium oil sump with larger oil capacity that ensures oil pickup tube being fully submerged in the oil pan when the car turns and with cooling fins hoping to decrease oil temperature.
Thanks for your inputs.
