Can you increase idle RPM in Engine adaptation on a VW GTI MK7 with EA888 gen 3 engine?
geyungjen
Fremont, CA, USA
C?ID=606828
I have heard the following statement:
"Unlike TDIs, most Gasoline engine controllers after (roughly) model year 2005 will not allow modifications to the idle speed."
I have 2015 VW GTI SE Manual Transmission (MK7) with EA888 Gen 3 engine, engine code CNTA. It is a Gas engine, not TDI (diesel) engine. Does this means I can not change idle RPM by 50 per minute.
Is that statement true? Anyone has changed the idle RPM through engine module (01)->Adaptation on a recent model year Gas engine car? Thanks a lot.
Following is autoscan output:
Thursday,09,January,2025,11:36:40:39693
VIN: 3VW5T7AU7FM001611   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 5F 75 A9
VIN: 3VW5T7AU7FM001611   Mileage: 126417km-78551miles
Address 01: Engine (J623-CNTA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---    CVN: EAF4D4C7
   Coding: 091900122424000F1000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001005
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C06DBD0768287BAD33-8078
   VINID: 0E69C59074651D67400011810492F0F4C9
15197 - Intake Manifold Flap Position Sensor (Bank 1)
          P2014 00 [00100000] - Electrical Malfunction
                    Fault Frequency: 13
                    Mileage: 126417 km
                    Date: 2024.11.15
                    Time: 23:26:39
                    Engine RPM: 0.00 /min
                    Coolant temperature: 88 ∞C
                    Intake air temperature: 22 ∞C
                    Voltage terminal 30: 11.914 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 102 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 4400.0 kPa
Readiness: 0010 0101
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 50464000000163
   Coding: 01FA6BA13420096D007D020181C42980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44D69370FE126FFA3B3-8010
0297 - Steering angle sensor
          B1168 16 [00001000] - Voltage Too Low
                    Reset counter: 185
                    Mileage: 126394 km
                    Date: 2024.08.29
                    Time: 21:31:58
          C1146 02 [00001000] - Signal Failure
                    Reset counter: 185
                    Mileage: 126394 km
                    Date: 2024.08.29
                    Time: 21:32:43
   Revision: 00021000    Serial number: 0327221216 Dataset Number: V03935197ZB 0001
   Coding: 030C0C
   VCID: 3A2AED888CD6290A51F-806E
   Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   VCID: 3632F9B8B8CECD6AB57-8062
          B10CD 00 [00001000] - -
                    Fault Frequency: 14
                    Reset counter: 191
                    Mileage: 126411 km
                    Date: 2024.10.11
                    Time: 01:45:59
                    Voltage terminal 30: 11.0 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
   Component: BCM PQ37BOSCH 026 0097
   Revision: --------    Serial number: 86581902140054 Dataset Number: 5GM063v____
   Coding: 001108464041826969E44000001407201800000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 43D4906CFB1C68C2029-8016
   Component: WWS    140109  042 0581
   Serial number:         140320065008
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M01D30H06M26S20S8
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO2641420-
   Coding: 181801
15882 - Bulb for Right Brake Lamp / Turn Signal
          B1334 15 [00001000] - Open or Short to Plus
                    Reset counter: 173
                    Mileage: 126394 km
                    Date: 2024.08.25
                    Time: 01:29:49
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 13.6 V
                    Outside temperature: 22.0 ∞C
18186 - Bulb for Rear Left Side Marker Lamp
          B12BC 15 [00001001] - Open or Short to Plus
                    Reset counter: 145
                    Mileage: 126413 km
                    Date: 2024.10.24
                    Time: 02:37:13
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 13.8 V
                    Outside temperature: 15.5 ∞C
          B1806 F0 [00001000] - Safety Shut-Off due to Occupant Detection
                    Reset counter: 190
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:57:04
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
                    Outside temperature: 22.5 ∞C
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00BH6C Dataset Number: 5GM003V____ 0031
   VCID: 51F8AA2431608A52805-8004
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  005 0016
   Serial number: IBH0000J140000GI660U
   Coding: 303136
   Subsystem 2 - Part No SW: -----------    HW: 480 002 501 14
   Serial number: 35700000000C5A1DBE0
   Subsystem 3 - Part No SW: -----------    HW: 480 002 711 13
   Serial number: 358000000002C1605E0D
   Subsystem 4 - Part No SW: -----------    HW: 480 402 501 14
   Serial number: 3510002C712FAE23E3EM
   Subsystem 5 - Part No SW: -----------    HW: 480 402 501 14
   Serial number: 3520002AF12FAE2141CD
   Subsystem 6 - Part No SW: -----------    HW: 480 400 201 14
   Serial number: 3550002C712FAE355328
   Subsystem 7 - Part No SW: -----------    HW: 480 400 201 14
   Serial number: 3560002C712FAE31729D
   Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 09021404220563
   Coding: 0400
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 79A83284C950E212185-802C
   Part No SW: 5G6 920 970 C    HW: 5G6 920 970 C
   Component: KOMBI         316 2210
   Coding: 0BAD09122180CF0502086A00000000
   VCID: 303ECFA05AAAE35AEFB-8064
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2163
   Revision: --------    Serial number: 19021410000713 Dataset Number: 5GM067v____ 1609
   Coding: 0101000820085900EF000028080F00000001000000000000000000000000
   Shop #: WSC 00066 790 00199
   GVL: 01503C1000000600400C00008000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3E22E19890FE052A6D7-806A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27130002010210053502
   Coding: 28FFFF
   Revision: 00000000    Serial number: 14000035071002
   Coding: 5500000000000000
   VCID: 3436C3B0AEB2DF7A8B3-8060
   Serial number: 1902140605003C Dataset Number: V03935199GP 0004
   Coding: 003E13200000040000000000
   Shop #: WSC 51637 001 1048576
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 40DE9F60EA0A73DA1FB-8014
   Serial number: 00000000000001650900
   Coding: 011000
65604 - Door Warning Lamp
          B1326 01 [00001001] - Electrical Failure
                    Reset counter: 126
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:51:03
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Dataset Number: 5GM074V____ 0305
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3530FEB4A5C8C672BCD-8060
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H30 0042
   Serial number: VWZ8Z1DC400VYCX Dataset Number: 5GM050v____ 0009
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001005
   ROD: EV_AMPMst11CALPI.rod
   VCID: 639470EC5BDC08C2229-8036
0512 - Rear Right Treble Speaker
          B1068 13 [00001000] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                    Reset counter: 174
                    Mileage: 126394 km
                    Date: 2024.09.04
                    Time: 17:30:25
0517 - Rear Left Treble Speaker
          B1066 13 [00001010] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Fault Frequency: 38
                    Reset counter: 191
                    Mileage: 126336 km
                    Date: 2024.02.16
                    Time: 01:35:17
   Serial number: 280114060502K1 Dataset Number: V03935199GQ 0004
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3FDC9C9C97F40C22661-806A
   Serial number: 00000000000001259490
   Coding: 191000
                    Reset counter: 133
                    Mileage: 126392 km
                    Date: 2024.08.25
                    Time: 01:24:33
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     013 0645
   Serial number: V7B00902142405 Dataset Number: 5G0CV1v____ 0001
   Coding: 027300000000000021220002001800001F0203340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 649673F05ED20FFADB3-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS5000DM
                    Reset counter: 126
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:51:06
                    Voltage terminal 30: 13.7 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Dataset Number: 561098V____ 0403
   Shop #: WSC 00066 790 00145
   ROD: EV_OCULowMQB.rod
   VCID: 025A5568A486A1CA49F-8056
9457664 - Function limitation due to excessive temperature
          B1050 00 [00001000] - -
          [restriction due to temperature rise]
                    Reset counter: 0
2103041 - Control Module
          B1788 F0 [00001001] - Start Prohibition Deactivated
                    Fault Priority: 8
                    Reset counter: 151
   Component: SAS-GEN 2     H06 0013
   Serial number: 140127200336
   VCID: 6B8418CCB30C40829A9-803E
End----------(Elapsed Time: 01:23, VBatt start/end: 14.3V/14.4V)-----------
Ziddywerks
Northern NJ USA
C?ID=208579
Why do you want to increase the idle speed It will not resolve the fault you have.
geyungjen
Fremont, CA, USA
C?ID=606828
Thanks for the reply. By the way, I am not referring to the fault, which is intake manifold position sensor, which I can replace it and relearn it with VCDS.
The bigger issue I have is sporadic message low oil pressure during hot idle. I am not handy enough to do DIY engine diagnose and repair, nor is cost effective for a 2015 year car, better would trade it in for a new VW or Audi:)
I was seeking confirmation about the following statement:
Thanks again.
Ziddywerks
Northern NJ USA
C?ID=208579
It can be done via reflash of ecm, however I dont see this as a solution for low oil pressure. Why not check oil pressure switches for oil in connector? This is common occurence in these vehicles.
geyungjen
Fremont, CA, USA
C?ID=606828
For the low oil pressure, I started with easy attempts:
I have replaced the brown oil pressure sensor hoping it was bad, but not. Replace oil filter updated housing and adapter, hoping old oil filter adapter was the cause, but not.
Then I proceeded to more complex attempts:
I installed an oil gauge to monitor oil pressure on my GTI MK7:
I have already replaced N428, which is oil pressure control valve:
No difference, same low oil pressure on hot idle, during hot idle, oil pressure below 0.8 Bar, the minimum.
I have replaced VW oil filter with K&P Engineering High Performance Stainless Steel Oil Filter from ECS,
This filter has many times the flow rate than stock paper filter, less restrictive, reusable after clean, 10x more expensive:)
I have changed the oil from VW 502 to Mobile 5W50, gets better, but oil pressure is still around 0.8 bar during hot idle. Could trigger low oil pressure warning. May consider double down to 10W60 since I am in San Francisco area, warmer California cliemate. The higher the viscosity, the higher the oil pressure in general.
Final DIY attempt I have not yet started:
Plan to replace the oil pump with more stiffer relieve spring, which will result in higher oil pressure.
Since the car is out of warranty, none of these is right fix, thay are bandaid if any attempt makes the low oil pressure warning going away by having oil pressure >= 0.8 bar during hot idle. Right fix is to trade it in and buy a new one, not replace engine at 5 figure $$$, parts and labor with no guarantee this problem will not happen:). It is a fun car though.
But I still like to have the following statement confirmed:
Thanks again
Yes and no. Your ECU does have an Adaptation Channel for it:
IDE00259-ENG104054 -- Idle RPM correction - Idle Speed Offset
However, I'm near certain you won't be able to change it. It probably requires a Security Access code that not generic like it is on older TDIs and isn't known (at least to me).
geyungjen
Fremont, CA, USA
C?ID=606828
Thanks Uwe.
There is hope, Engine Module 01->Adaptation->Run in oil pressure to set it active.
Just in theory, if it works. Run in oil pressure is when the car is new, manufacture to set it in only high oil pressure mode, until 1000KM is reached. This means, ECU will tell oil pressure regualation valve N428 to be closed, until 1000KM is reached, so, during the 1000KM, N428 will lock only in high oil pressure mode even when RPM is below 2000 and engine temp >=80 degree celsus?
If this works, then set it every 1000KM iteratively in a forever loop, if the car lasts forever:)
Ziddywerks
Northern NJ USA
C?ID=208579
It sounds like you avoiding the problem or low oil pressure. Does this vehicle has 2 oil pressure switches? Have you checked the check valve inside the filter housing to make sure thats not your issue? As it will affect oil pressure at idle whether hot or cold.
geyungjen
Fremont, CA, USA
C?ID=606828
Thanks for the question.
"Have you checked the check valve inside the filter housing to make sure thats not your issue?"
Yes, I have replace oil filter adapter with updated housing and adapter, hoping old oil filter adapter was the cause, but not.
The oil pressure warning only shows when the car is in hot idle. No low pressure warning when the car is not hot, even at idle. This is confirmed by the oil pressure guage I installed, I had low oil pressure warning with the guage showed 0.6 bar in the past during hot idle, when oil is thinner, it flows quicker through engine parts and will not stick around, leaving engine parts less lubricated, the magic number for the oil pressure warning not to show up needs to be at least 0.8 bar, according to documentation (oil pressure range to be 0.8 bar to 4.0 bar when temp > 80 degree celcus)
There are 2 oil pressure switches (sensors), the blue one is for high oil pressure sensor, the brown one is for low oil pressure sensor. Both are in the down stream to the oil filter housing. I replaced the brown switch with genuine one from dealer parts dept, this is not the root cause. Having oil pressure < 0.8 bar when temp is > 80 degree and in idle is the sympton, which can only be correctly addressed by:
Drop the engine and replace the worn engine parts or replace the engine with a new or dealer rebuilt engine, this is a big ticket item/service which can only be performed by professional VW service, dealer or not:)
Relacing switches will not correct the problem in this car, in my humble opinion, I really wish it could.
We had an issue kinda like that on the 24V VR6 in our 2001 Eurovan about 10 years ago. It was due to FOD being lodged in the oild pressure relief (control?) valve at the pump, not letting the valve close the whole way. The FOD came from a defective intermediate sprocket in the timing chain section of the engine. We believe it was not properly heat-treated:
Amazingly, the low oil pressure at hot idle was the only thing that clued us in to the fact that there was a mechanical problem with the engine.
Have you dropped the oil pan on this engine yet?
geyungjen
Fremont, CA, USA
C?ID=606828
Hi Uwe,
"Have you dropped the oil pan on this engine yet?"
Yes, I havd dropped oil pan to clean the oil pan, oil pickup tube:
I have replaced the oil pressure relieve valve (or regulation valve) N428 with genuine new one from dealer parts.
I have not replaced sprocket which is inside the timing control cover that is beyond my level of skillset:)
I wasn't suggesting you should. I only mentioned it because that failure was the root cause of symptoms similar to yours, but of course in a completely different engine, and it was obvious that something mechanical had failed as soon as we dropped the pan and we found these bits laying in it:
geyungjen
Fremont, CA, USA
C?ID=606828
I have sent the oil sample to Blackstone lab, result came back state more metal particles in the oil sample:
I have cleaned the oil sump, oil pickup tube and found some metal shavings.
I bought the car new, and currently is at about 75K miles. Always have oil change at dealer once a year when the car reminds me for the oil change. Guess I should have the car oil changed every 6 month or 5000 miles instead of every 1 year or at 10000 miles.
I have taken the following steps to mitigate excessive metal shaving:
Replace the plastic oil sump oil drain plug with a magnetic drain plug:
Replace VW502 (5w30 or 40) oil with Mobile 5W50.
Seen a little improvement when it comes to oil pressure at hot idle, to about 0.7 bar, need to be at least 0.8 bar according to VW doc. I may push to 10w60.
My theory is this engine is worn, for sure, space between engine blocks is wider than should be, oil when hot will be thin as water, thus oil pressure is low when hot. Thicker oil will become thinner, higher viscosity oil will be better than lower viscosity, when it comes to running at operating temp.
If I can not increase idle rpm, (just need a little push to make oil pressure to 0.8 bar from 0.7 bar during hot), I may decide to do the following:
1. Engine (01)->adaptation->set Run in oil pressure to active to see if that works, if not,
2. Replace the oil pump, or make oil pump relieve spring stiffer, such as inserting a metal washing inside the spring compartment, to make the spring harder to compress, which in theory can have higher oil pressure.
3. Or replace the factory oil pump with the oil pump custome designed for worn EA888 Gen 3 engine to have higher oil pressure:
Quite expensive and it is in Germany, need to ship to me in California if I decide to buy from them.
If none of these work, time to trade in the car and get a new VW.
davisev5225
C?ID=263265
Drop the oil pump out and inspect it closely, especially its inlet and outlet valves and bypass valve (if equipped). If nothing major is found, clean and re-install; otherwise, replace.
geyungjen
Fremont, CA, USA
C?ID=606828
Thanks, will do that.
Ziddywerks
Northern NJ USA
C?ID=208579
Oil pressure at idle should be at least 1bar. Checking both oil switches for failure is a smart decision.
geyungjen
Fremont, CA, USA
C?ID=606828
while VW service doc says 0.85 bar at temp, I totally agree with you about needs to be at least 1 bar at idle. Since I have replaced the brown reduced oil pressure switch (F378), I will also replace the blue switch, which is below the brown switch.
Low oil pressure warning, to be exact is having error code P164D00, P164D is reduced oil pressure switch, the brown one, F378, 00 means malfunction, hence, P164D00 means reduced oil pressure switch malfunctioning".
Here is my understanding, correct me if I am wrong. When engine temp is >=80 degree C, RPM is at idle, ECU looks for the open/close status from F378, reduced oil pressure switch, the brown switch. The switch circuit should be open, as the lever is pushed by oil wich pressure needs to be 0.8 bar or greater; Any time when the oil pressure is below 0.8 bar, the lever closes, the circuit is closed, ECU receives the close signal, if the circuit is closed for a preset time period, like a few seconds (don't know how long), you will see on the dashboard P164D00 reduced oil pressure switch malfunctioning message, asking to turn off the engine.
Here is VW doc regarding disireable oil pressure range:
Low oil pressure will not show when pressure at 0.8 bar or better. The company in Germany selling modified oil pump for worn engine says oil pressure at temp needs to be at least 1.3 bar.
The problem I need to address is currently oil pressure at 0.7 bar when hot idle and with 5W50 oil. It needs to be constantly higher than 0.7 bar when in hot idle. This seeming simple problem is hard to crack unless serious professional works to be done on the engine blocks.
Dr Sheldon
Windsor UK
C?ID=334979
*Cable
