Resolved Replaced ABS Module 2010 VW Jetta
Resolved
Max910
Honolulu, HI, USA
C?ID=606887
Hi everyone,
Just received my VCDS and have completed an ABS module swap on my 2010 VW Jetta. Everything went really well due to all the research I've done on this forum (thanks for that!!). But I'm running into an issue with my latest scan. It's showing an issue on the engine and telling me to check my ABS module but the abs module is showing everything is good with no faults found. I'm sure I must have messed up the coding somehow when I flashed the new ABS but i'm really at a loss of what it could be. My scan is below, any help/ feedback would be appreciated. Thanks!!
Sunday,12,January,2025,15:23:40:15282
VIN: 3VWAX7AJ9AM109889   License Plate:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72 77
VIN: 3VWAX7AJ9AM109889   Mileage: 120510km-74881miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 AH    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H03---    Serial number:
   Coding: 0000075
   Shop #: WSC 05089 444 101369
   VCID: 74B603B662B8948A4B3-8020
   VINID: 0E69D1A0745A251741009208240A36FC5C
               U1017 - 000 -  - Intermittent
                    Mileage: 119489 km
                    Date: 2024.10.06.
                    Time: 20:40:48
                    Temperature: 33.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.319 V
   Part No SW: 09G 927 750 HG    HW: 09G 927 750 HG
   Component: AQ 250 6F           1631
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 7DA0269251F2D5C234D-8028
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 114B400C49220003881302EC92220041300000
   Shop #: WSC 00066 123 12345
   VCID: 78AE378672D0F0EA67B-802C
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00149
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75B03EB265428D827CD-8020
   Part No SW: 5K0 937 085 G    HW: 5K0 937 085 G
   Component: BCM PQ35 B++  111 0128
   Revision: BI111001
   Coding: 2D200B1A902F3EE480000085400000040100008651008D605C8020000000
   VCID: 372CF4BA3F4E3F92AE1-8062
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 06031  21  0512
   Coding: 009795
   Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
   Component: 04 AIRBAG VW8R  036 8900
   Revision: 06036000    Serial number: 003EVM02DAJS
   Coding: 0012340
   VCID: 6E8211DE0C94BE5ABD7-803A
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME4E402A7EQ
   Subsystem 3 - Serial number: 6342MSME4D1238429
   Subsystem 4 - Serial number: 6351HSME1F64641BF
   Subsystem 5 - Serial number: 6361HSME1F6400385
   Subsystem 6 - Serial number: 63727SME1F7F5F18R
   Subsystem 7 - Serial number: 63827SME2011510DR
   Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
   Component: J0527           053 0111
   Coding: 0001031
   VCID: 025A556E280CAA3A49F-8056
   Part No SW: 5M0 920 960 E    HW: 5M0 920 960 E
   Component: KOMBI         H14 0112
   Revision: X0014004    Serial number:
   Coding: 270700
   ASAM Dataset: EV_KombiUDSMM9RM10 A04102
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 3138CAA2D1AAE1A2E05-8064
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 210110F1000239
   Coding: ED807F07000602001002
   VCID: 698862C2357A5962E85-803C
01304 - Radio
                    Reset counter: 90
                    Mileage: 120516 km
                    Date: 2025.01.12.
                    Time: 18:30:10
   Part No SW: 5K0 953 234     HW: 5M0 920 960 E
   Component: IMMO          H14 0112
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
   VCID: 6A8A1DCE3CFC527AE1F-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0000491393
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide_VW32.rod
   VCID: 270C24FAEF6EAF123E1-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000004658478
   Coding: 000490
          B11EC 54 [00001000] - Missing Calibration / Basic Setting
                    Reset counter: 130
                    Mileage: 120516 km
                    Date: 2025.01.12.
                    Time: 18:30:05
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [00001001] - Electrical Failure
                    Reset counter: 91
                    Mileage: 120517 km
                    Date: 2025.01.12.
                    Time: 19:04:31
131584 - Motor for Rear Window Regulator
          B11EE 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 90
                    Mileage: 120516 km
                    Date: 2025.01.12.
                    Time: 19:00:07
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 3138CAA2DD2AE1A2E05-8064
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0000514694
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide_VW32.rod
   VCID: 280E27C6E270A06A37B-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000004680457
   Coding: 000490
                    Reset counter: 130
                    Mileage: 120516 km
                    Date: 2025.01.12.
                    Time: 18:30:05
Address 56: Radio
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Component: RDK           111 0821
   Coding: 018705
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000329387152
   Coding: 401100
   VCID: 2A0ADDCEFCFC927A21F-807E
03427 - Right Audio Channel
                    Reset counter: 90
                    Mileage: 120516 km
                    Date: 2025.01.12.
                    Time: 18:30:08
01304 - Radio
                    Reset counter: 90
                    Mileage: 120516 km
                    Date: 2025.01.12.
                    Time: 18:30:09
End----------(Elapsed Time: 01:09, VBatt start/end: 13.8V/13.9V)-----------
Have you tried just clearing the fault in the engine? It's flagged "Intermittent", meaning the fault condition that set the fault code did not exist, or could not be detected, at the time the scan was done. Moreover, based on "Readiness: 0000 0000", it does not seem like faults in the engine have been cleared recently.
[Select]
[01-Engine]
[Fault Codes]
[Clear Codes]
Max910
Honolulu, HI, USA
C?ID=606887
Uwe,
I could have sworn I did that, but I just went out to the car and tried it and everything cleared. Thanks so much for the advice/ help!!
Sunday,12,January,2025,18:00:23:15282
VIN: 3VWAX7AJ9AM109889   Mileage: 120520km-74887miles
   Coding: 0000075
Readiness: 1110 0101
   Coding: 0000840
   Revision: 00H30001
   Revision: 00009001
   Coding: 0000001002
   Revision: BI111001
   Coding: 009795
   Coding: 0012340
   Coding: 0001031
   Coding: 270700
01304 - Radio
                    Reset counter: 91
                    Mileage: 120520 km
                    Date: 2025.01.12.
                    Time: 03:57:16
   Coding: 0004B5
   Slave Driver:
   Coding: 000490
                    Reset counter: 91
                    Mileage: 120520 km
                    Date: 2025.01.12.
                    Time: 03:55:56
   Revision: 00H17000
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
Address 56: Radio
   Coding: 018705
   Coding: 401100
                    Reset counter: 90
                    Mileage: 120516 km
                    Date: 2025.01.12.
                    Time: 18:30:08
01304 - Radio
                    Reset counter: 90
                    Mileage: 120516 km
                    Date: 2025.01.12.
                    Time: 18:30:09
End----------(Elapsed Time: 01:09, VBatt start/end: 12.4V/12.4V)-----------
