2017 caddy highline fitting a MFSW.
DomPryor
England
C?ID=395971
Looking for help get a MK6 golf MFSW to work on a 2017 caddy highline. The van already has MF stalks 1k5.953.502T, with a 5k0.953.569.BB squib.
The new MFSW wheel number is 3C8.419091BEE74 with 3C8.959 538 G buttons.
The vans wiring looks to using a 12v and ground for the horn with the new wheel using Canbus to operate the horn wired to the buttons.
Try to read up looks like I need to change the squib to 5k0 953 549b to get the canbus to control the horn? Then change the settings with VCDS?
Will I have to change the stalks for ones with out the MFA controls or can I just turn these off?
Thanks in advance for any help
DomPryor
England
C?ID=395971
Tuesday,07,January,2025,19:30:34:26300
VCDS Version: 24.7.0.0 (x64)  HEX-V2 CB: 0.4643.4
VIN: WV1ZZZ2KZHX097992   License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZHX097992   Mileage: 263870km-163961miles
Address 01: Engine (J623-DFSD)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 GT    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 4648
   Revision: 8AH20---    CVN: BCEEEF18AF135584
   Coding: 0111001204250D090000
   Shop #: WSC 00384 210 00000
   ASAM Dataset: EV_ECM20TDI01104L906016GT 004004
   ROD: EV_ECM20TDI01104L906016GR_004.rod
   VCID: 015E7EED418F61C250D-8054
   VINID: 9E606AAAA09BA98A0024724908D0A99565
   Revision: 00000000    Serial number: 40087000000128
   Coding: 1479409B926BA485287E027F498425E3790000
   Shop #: WSC 35110 790 50316
   VCID: 3FDAB81577FBD732669-806A
   Part No SW: 1K8 907 426 AT    HW: 1K8 907 426 AT
   Component: AC Manuell    H21 0909
   Revision: 00001002
   Coding: 0010004003
   VCID: 05566AFD55A74DE26C5-8050
   Part No SW: 5K0 937 086 AA    HW: 5K0 937 086 AA
   Component: BCM PQ35 M+   122 0184
   Revision: BD122001
   Coding: 491A583E8025E16B08880082940001640351000842228260648087000041
   Shop #: WSC 35110 377 00142
   VCID: 73B224250BB34352521-8026
   Subsystem 1 - Part No: 2K2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 22121  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 221216 04  42  0106
   Coding: 0228DD
   Part No SW: 1K8 919 465 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0480
   Revision: --------    Serial number: 39261700401755
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14VW364GP00 001007
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   VCID: 372AD0355FCBEF72AE9-8062
   Part No SW: 2K5 959 655 B    HW: 2K5 959 655 B
   Component: VW10Airbag00K H08 0018
   Revision: --------    Serial number: 003V1002ES81 Dataset Number: 2KC003V__A_ 0765
   Coding: 00000000000000000000000000000000304B
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3B22CC0563E3CB124A1-806E
   Serial number: 3497ARB404P46P7SDGVJ
   Serial number: 3507ARB405D4738IQ9C0
   Part No SW: 1K5 953 521 CL    HW: 5K0 953 569 BB
   Revision: FF010042    Serial number: 20161222101032
   Coding: 4080160010
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 79AE160D295F390218D-802C
   Part No SW: 2K5 920 976 E    HW: 2K5 920 976 E
   Coding: 410A001200
   VCID: 3828D30952D5E00AA73-806C
   Part No SW: 7N0 907 530 BJ    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1682
   Revision:   H58       Serial number: 101216F1002323
   Coding: 357431
   VCID: 79AE160D29DF390218D-802C
   Component: IMMO          H03 1104
   VCID: 6A8C39415CF9829AE17-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2144
   Coding: 0131632
   VCID: 71BE2E2D7DAF7142A0D-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   VCID: 392ED60D655FF90258D-806C
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131632
   VCID: 72BC212178A94A5A597-8026
   Part No SW: 5C0 035 680 E    HW: 5C0 035 680 E
   Component: MU-S-ND-ER    H31 0359
   Serial number: VWZAZ2T5015194 Dataset Number: V03935249AS 0001
   Coding: 063307013C00000011111101008808001F0100C600200100CF
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 23121465FB5393D2621-8076
   Subsystem 1 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
   Component: Batt.regelung H58 1682
   Coding: 030F7873
   VCID: 71BE2E2D71AF7142A0D-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 75410603001701063396
End----(Elapsed Time: 01:10, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
DomPryor
England
C?ID=395971
The original wheel had a brown wire and a blue grey with a simple switch contact. Brown pin has continuity to be grounded and the pin for the blue/grey wire has plus 12v.
I the MFSW has a different wire colours with one core going to the horn contact but no brown wire. I cant make out the colours on my pictures, but one of the cores goes up to the steering wheel switch plug and then comes back down to the horn contact. So I took it the new wheels wiring is looking for a signal that isn't a dead short? so thought it might be the squib not being compatible as this is where the connections go back to, but the two looms used the same pins.
The cars not mine so can't quickly check anything.
siLc
Tallinn, Estonia
C?ID=330192
It might be easier to install the correct MFSW for this vehicle. This has the MQB-style wheel from factory. For example, 6C0419091BNE74.
