Audi A4 B9 2021adjust headlamp washers delay
AppleFarmer
Finland
C?ID=278914
Hello. I've crawled through Adaptations and Coding but can't seem to find anything that would let me adjust the delay time for the headlamp washers (English and German). Is it even possible to do this on my car? Please find attached the Auto scan data and admap of the 09 Central Electronics control module.
Thank you in advance for your help / contribution.
Auto scan
Chassis Type: F4-AU49 (80C)
Scan: 01 02 03 08 09 13 15 16 17 18 19 22 42 44 46 52 5F 69 6C 6D
          75 80 81 8B A5 BB BC D6 D7
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (evo4-DMSA)       Labels: None
   Part No SW: 8W0 907 115 R    HW: 06N 907 309 A
   Component: R4 2.0l TFSI  H80 0004
   Revision: J4H80000    CVN: 08979520
   Coding: 1265401B23760D0374002000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0118W0907115R 001007
   ROD: EV_ECM20TFS0118W0907115R.rod
   VCID: 48CE808FC23D7DAAD7B-801D
   VINID: 9D196AAAA58405D4401460061C5E099DD1
   Radiator shutter:
   Subsystem 1 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
   Component: V544KJS1  H13 0110
   Serial number: 20210216060103052034
   Part No SW: 8W2 927 155 FL    HW: 0HK 927 156 B
   Component: 2.0T 150kW EU H01 0001
   Revision: --H01---    Serial number: 0000003788 CVN: DA63675F
   ASAM Dataset: EV_TCMDL382021 002036
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 107E68EFFAEDF56ACFB-8045
   MTF pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 M
   Component: V553 MTFP  003 0582
   Serial number: 75290041210042001599
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 AJ    HW: 8W0 907 379 N
   Component: ESP9 Premium  H17 0870
   Dataset Number: 8W0909504AD 0001 CVN: 98D7539B
   Coding: 0CAA6C992CA70A9C519E4897228452A2F5B5D2303634508A12444A45AFAD4B
   Shop #: WSC 06324 790 00001
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 0D40719BEDDFD88224D-8059
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 AP    HW: 8W0 820 043 AP
   Component: Klima Zone 3  H60 0270
   Dataset Number: 8W0909862D  0025
   Coding: 2409401D5544400D02000100080000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 01585DABA1878CE2505-8055
   Subsystem 1 - Part No SW: 4M1 820 021 C    HW: 4M1 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000005976462
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu  H05 0010
   Serial number: A95D0E5700PAG0MUFU04
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W1 907 063 AG    HW: 8W1 907 063 G
   Component: BCM1 MLBevo   H10 0712
   Dataset Number: 8W1909514C  0015
   Coding: 07001940C13900DD050D010898BF80E9110B3108000000980101080020001C810A45023B0256050000000000000000000000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   ASAM Dataset: EV_BCM1BOSCHAU651 017002
   ROD: EV_BCM1BOSCHAU651_017.rod
   Subsystem 1 - Part No SW: 8W1 955 119 A    HW: 566 955 119
   Component: J400FRWISCH  051 0822
   Serial number: 887353F0402100601309
   Coding: 7DC727
   Component: G397_RLFSS  H06 0004
   Serial number: 20305574X81A955555B0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AN    HW: 4M0 941 531 AN
   Component: E1 - LDS  H07 0008
   Serial number: 09 11 2020  02504349
   Subsystem 4 - Part No SW: 8W0 857 511 F    HW: 8W0 857 511
   Serial number: GX1CE122122023810235
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AE    HW: 4K0 947 135 AE
   Component: Dachmodul  H42 0416
   Serial number: A00315031
   Coding: 0D0104
Address 13: Auto Dist. Reg (J428)       Labels:* Redir Fail!
   Part No SW: 8W0 907 561 G    HW: 8W0 907 561
   Component: LRR4          H12 0451
   Dataset Number: 8W0909863Q  0001
   Coding: 5572E7EA58FFEC0A949883E0
   ASAM Dataset: EV_ACCBOSCHAU49X 003024
   ROD: EV_ACCBOSCHAU49X_003_AU49.rod
   VCID: 42DA92A7E40157FA09F-8017
1538 - Sensor for Automatic Distance Control
          C110B F0 [00001000] - Limited Visibility
          [FAULT_SENSOR_BLIND]
                    Reset counter: 22
                    Mileage: 63923 km
                    Date: 2024.12.14
                    Time: 16:32:47
                    Control Module temperature: 20 ∞C
                    Voltage terminal 15: 14.7 V
                    Vehicle speed: 23.21 m/s
                    Longitudinal acceleration: 0.12 m/s≤
                    Adaptive distance regulation: status: ACC_StandBy
1396 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_NO_FREE_SIGHT]
                    Reset counter: 22
                    Mileage: 63926 km
                    Control Module temperature: 6 ∞C
                    Voltage terminal 15: 8.7 V
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.00 m/s≤
                    Adaptive distance regulation: status: ACC_Init
1542 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_BLIND]
                    Reset counter: 22
                    Mileage: 63909 km
                    Date: 2024.12.14
                    Time: 16:00:23
                    Voltage terminal 15: 14.8 V
                    Vehicle speed: 12.03 m/s
                    Longitudinal acceleration: 0.44 m/s≤
1397 - Sensor for Automatic Distance Control
          [FAULT_SYSTEM_NO_FREE_SIGHT]
                    Reset counter: 22
                    Mileage: 63926 km
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 P    HW: 8W0 959 655 P
   Component: Airbag10.44   H03 0122
   Serial number: 0034Y005BCA- Dataset Number: 8W0909602BB 0005
   Coding: AACCF0C00CA00000985400F3D04C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 56F25EF71889DB5A557-8003
   Subsystem 1 - Part No SW: -----------    HW: 442 060 902 21
   Serial number: 3577Y00C500BA794A11/
   Subsystem 2 - Part No SW: -----------    HW: 442 060 902 21
   Serial number: 3587Y00A700BA791041V
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 502 21
   Serial number: 35177002E640FE48C5EZ
   Subsystem 4 - Part No SW: -----------    HW: 442 0B1 102 21
   Serial number: 35277002264038FA4697
   Subsystem 5 - Part No SW: -----------    HW: 442 0C1 501 21
   Serial number: 35575009D0385AB182BK
   Subsystem 6 - Part No SW: -----------    HW: 442 0C1 501 21
   Serial number: 35675009F0385AB0429G
   Subsystem 7 - Part No SW: -----------    HW: 442 0C1 401 21
   Serial number: 2307500A50385AB333C4
   Subsystem 8 - Part No SW: -----------    HW: 442 552 601 21
   Component: PedPSensor_D2  3DE 0887
   Serial number: I0MFU00A7006DBC0B31U
   Subsystem 9 - Part No SW: -----------    HW: 442 552 601 21
   Component: PedPSensor_P2  3DE 0887
   Serial number: I0NFU00A7006DBC0B25Y
1060613 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Objektstatus]
                    Reset counter: 22
                    Mileage: 63910 km
                    Date: 2024.12.14
                    Time: 16:01:00
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 22
                    Mileage: 63910 km
                    Date: 2024.12.14
                    Time: 16:01:00
1060615 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_v_rel]
                    Reset counter: 22
                    Mileage: 63910 km
                    Date: 2024.12.14
                    Time: 16:01:00
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 22
                    Mileage: 63910 km
                    Date: 2024.12.14
                    Time: 16:01:00
   Part No SW: 4N0 907 129 LA    HW: 4N0 907 129 LA
   Component: Lenks.Modul   H03 0009
   VCID: 7BA42F43C36BE6320A9-802F
   Part No SW: 8W5 920 790 L    HW: 8W5 920 790 L
   Component: FBenRDW------ H10 0161
   Dataset Number: 8W1909525G  0019
   Coding: 8D842BC0EE8000080C80E3601000280008000800
   ASAM Dataset: EV_DashBoardAU65X 002025
   ROD: EV_DashBoardAU65X_002_AU49.rod
   VCID: 4BC4BF83D34B96B2FA9-801F
Address 18: Aux. Heat (J364)       Labels:| 4M0-265-105.clb
   Part No SW: 4M0 265 105 D    HW: 4M0 265 105 D
   Component: HSG           H12 0110
   Dataset Number: 8W0909858H  0023
   Coding: 0D0F01
   ASAM Dataset: EV_AuxilParkHeateEBEAU736 001019
   ROD: EV_AuxilParkHeateEBEAU736.rod
   VCID: 280E200F627D9DAA37B-807D
169986 - Fuel Level too Low
          P1250 00 [00001000] - -
                    Reset counter: 39
                    Mileage: 64353 km
                    Date: 2024.12.23
                    Time: 07:31:09
                    Coolant temperature of parking heater: 4 ∞C
                    Coolant temperature of auxiliary heater_Textual: numerical value: no text
                    Engine_coolant_temperature: 3.00 ∞C
                    Engine_coolant_temperature_Textual: numerical value: no text
                    Voltage terminal 30: 12.40 V
                    System condition: 0
                    Auxiliary heater operating status: OFF
                    Outside_Temperature_Additional_Heating: 0.50 ∞C
                    Engine_Speed: 0.00 /min
                    Fuel_Level_Input_Heater: 6 l
   Part No SW: 80C 907 468 C    HW: 80B 907 468 B
   Component: Gateway       H07 0602
   Serial number: 1RF03212217201 Dataset Number: 8W0909515Q  0033
   Coding: 0203000100200640298700000059001258380001100000000100008F02000000
   GVL: 01D03C0008000000C08CC8008006C80000080000004000000000000000006500
   ASAM Dataset: EV_Gatew31xAU65x 003220
   ROD: EV_Gatew31xAU65x_AU49.rod
   VCID: 303EC86F5AADD56AEFB-8065
   Subsystem 1 - Part No SW: 83A 951 523 K    HW: 83A 951 523 K
   Component: J453 MFL  H07 0004
   Serial number: 20210214233438 30172
   Subsystem 2 - Part No SW: 8W0 915 181 A    HW: 8W0 915 181 A
   Serial number: 8359486505
   Subsystem 3 - Part No SW: 4M8 419 508 A    HW: 4M8 419 508 A
   Component: J1158 KLR  H10 0010
   Serial number: 00000000000000109871
   Coding: FFFFFF
Address 22: AWD (J492)       Labels:| 0CJ-927-749.clb
   Part No SW: 8W0 927 755 C    HW: 0CJ 927 749 A
   Component: B9_DL3_N_SD1H02 0011
   Serial number: 20349B7990
   Coding: 110C0000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: 45D089BBF52F60C22CD-8011
   Part No SW: 8W0 959 593 N    HW: 8W0 959 593 N
   Component: TSG FS        011 0390
   Serial number: 0000433874770  Dataset Number: 8W0909872H  0037
   Coding: 00148B214000000000001000
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 55F059FB058FD0425CD-8001
   Part No SW: 8W0 909 144 J    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0411
   Dataset Number: 8W0909852R  0044
   Coding: 0D008380800080
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 44D694BFFE1559CA3B3-8011
   Part No SW: 8W1 907 064 BN    HW: 8W1 907 064 N
   Component: BCM2 MLBevo   044 0565
   Dataset Number: 8W0909501S  0016
   Coding: 01342100002000E06301A0000400C80213030000804706502F04000000040030001F0601001F31
   ASAM Dataset: EV_BCM2HellaAU736 018017
   ROD: EV_BCM2HellaAU736_018.rod
   VCID: 0A4A7A879CB1CFBA01F-805F
   left tail lamp 1:
   Subsystem 1 - Part No SW: 8W9 945 423     HW: 8W9 945 423
   Component: T1 LH ECE  H10 0510
   Serial number: HAX00206LD1X000020AE
   left tail lamp 2:
   Subsystem 2 - Part No SW: 8W9 945 429     HW: 8W9 945 429
   Component: T2 LH ECE  H10 0510
   Serial number: HAX0000IKS2X000020AY
   Right rear tail lamp 1:
   Subsystem 3 - Part No SW: 8W9 945 424     HW: 8W9 945 424
   Component: T1 RH ECE  H10 0510
   Serial number: HAX002011L1X000020AF
   Right rear tail lamp 2:
   Subsystem 4 - Part No SW: 8W9 945 430     HW: 8W9 945 430
   Component: T2 RH ECE  H10 0510
   Serial number: HAX000011P2X000020AX
   Part No SW: 8W0 959 392 N    HW: 8W0 959 392 J
   Component: TSG BFS       010 0390
   Serial number: 0000420404764  Dataset Number: 8W0909873H  0037
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 52FAA2E73461C77AB9F-8007
   Part No SW: 8W2 035 043 C    HW: 8W2 035 043
   Component: MU-TH-ND-EU   042 3385
   Serial number: GRO-63323.02.21 Dataset Number: 8W1909545H  0041
   Coding: 14920010804020000000000000000000000000000000000000
   ASAM Dataset: EV_MUTI 001010
   ROD: EV_MUTI_AU49.rod
   VCID: 3334C763ABBBEE72929-8067
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8W1 919 620 A    HW: 8W1 919 620
   Component: CenterDisplay  H42 0160
   Serial number: AUZ8Z9L2H01J9L
   Compact disc data bank:
   Component: Gracenote2     1006
   Volume Control 1:
   Subsystem 4 - Part No SW: 8W1 919 616 D    HW: 8W1 919 616 D
   Component: LSR-B9PA       H20 0103
   Serial number: ALJAL217122000030129
   Media socket:
   Subsystem 5 - Part No: 8W0 035 708 A
010 0007
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 8W1 907 383 C    HW: 8W1 907 383
   Component: Anhaenger     H10 0057
   Serial number: 000000000005699 Dataset Number: 8Y0909527B  0007
   Coding: 0100000202001100
   ASAM Dataset: EV_TrailFunctGener3Hella 001012
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 41D89DABE1074CE2105-8015
   Component: RVC Compact   H18 0250
   Dataset Number: 8W0909460D  0012
   Coding: 0294020103002005400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   Part No SW: 4M8 959 107     HW: 4M8 959 107
   Component: HDSG-Modul    H05 0330
   Revision: --------    Serial number: A2-C765-5000-7 Dataset Number: 8W0909541G
   Coding: 05C0
   ASAM Dataset: EV_DeckLidCONTIAU536 001001
   ROD: EV_DeckLidCONTIAU536_AU49.rod
   VCID: 78AE304FF25DCD2A67B-802D
   Part No SW: 4KE 035 282 A    HW: 4KE 035 282 B
   Component: CB_H_ECE      041 0236
   Serial number: A970B0MS209209 Dataset Number: 8W0909612F  0024
   Coding: 01E0E0F8C04080F6E0
   ASAM Dataset: EV_ConBoxHighAU49X 001004
   ROD: EV_ConBoxHighAU49X_AU49.rod
   VCID: 3928F54B89D71422585-806D
Address 80: Batt. reg. aux. accum. (A1)       Labels: 8W0-915-101.clb
   Part No SW: 8W0 915 101 A    HW: 8W0 915 101 A
   Component: MQ-BMS        H20 0127
   Serial number: 21000172806004
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: 3138CD6B51A7DC62E05-8065
   Part No SW: 8W1 713 041 N    HW: 8W1 713 041 K
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 21020565455891
   ROD: EV_GSMWaehlZFAU736_AU49.rod
   VCID: 3E22E65790F9331A6D7-806B
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 8W0 907 541 G    HW: 8W0 907 541
   Dataset Number: 8W0909885H  0002
   ASAM Dataset: EV_ACC2BOSCHAU49X 003024
   ROD: EV_ACC2BOSCHAU49X_003_AU49.rod
   VCID: 40DE98AFEA0D45EA1FB-8015
                    Reset counter: 22
                    Mileage: 63908 km
                    Date: 2024.12.14
                    Time: 15:59:14
                    Control Module temperature: 18 ∞C
                    Voltage terminal 15: 14.9 V
                    Vehicle speed: 15.79 m/s
                    Longitudinal acceleration: 0.01 m/s≤
                    Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
                    Reset counter: 22
                    Mileage: 63926 km
                    Control Module temperature: 7 ∞C
                    Voltage terminal 15: 9.5 V
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 G    HW: 8W0 907 217 F
   Component: BVS           H26 0070
   Dataset Number: 8W0909466H  0056
   Coding: 0404090200000403022000ADA50000FCA0F0C0200280
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002028
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
1123671 - Fog mode active
          C118E 00 [00001000] - -
                    Reset counter: 33
                    Mileage: 62884 km
                    Date: 2024.11.19
                    Time: 18:04:59
                    Control Module temperature: 25 ∞C
                    Voltage terminal 15: 15.10 V
1123986 - Dynamic Calibration
          C1106 F1 [00001000] - Function Restriction due to Limitation Exceeded
          [Online_calibration_safe-state_active]
                    Reset counter: 18
                    Mileage: 63808 km
                    Date: 2024.12.12
                    Time: 15:50:53
                    Control Module temperature: 17 ∞C
   Part No SW: 8W0 959 595 N    HW: 8W0 959 595 N
   Component: TSG HFS       010 0390
   Serial number: 0000434679095  Dataset Number: 8W0909897J  0038
   Coding: 000089210000000000001000
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 57EC53F31F83E2524E1-8003
   Component: TSG HBFS      010 0390
   Serial number: 0000434684689  Dataset Number: 8W0909896J  0038
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 4K0 941 591 BD    HW: 4K0 941 591 B
   Component: LMS_MLBevo    H11 0040
   Dataset Number: 8W0909471F  0013
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001015
   ROD: EV_LMSLeftHELLAAU58X.rod
   VCID: 72BA02679421A77A59F-8027
   Dataset Number: 8W0909472F  0013
   ASAM Dataset: EV_LMSRightHELLAAU58X 001015
End----(Elapsed Time: 01:51, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
09 Central Electronics admap
;SW:8W1-907-063-AG   HW:8W1-907-063-G ---  Cent. Elect.
;Component:BCM1 MLBevo   H10 0712, Coding:07001940C13900DD050D030898BF80E9110B3108000000980101080020001C810A45023B0256050000000000000000000000000000000000000000000000000000
;EV_BCM1BOSCHAU651,017002,EV_BCM1BOSCHAU651_017.rod
;Thursday,09,January,2025,12:22:22:59502
;VCDS Version: Release 24.7.1  Data version: 20240919 DS356.3
;VCID: 01585DABA1878CE2505-8055
IDE00001-MAS10842-Production mode-Deactivate exterior lighting,not active ,3
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10844-Production mode-Deactivate rear windshield wiper,not active ,3
IDE00001-MAS10847-Production mode-Deactivate windshield wipers,not active ,3
IDE00001-MAS10848-Production mode-Deactivate left-/right hand driving switch-over,not active ,3
IDE00001-MAS10849-Production mode-Switch parking assist to mute,not active ,3
IDE00001-MAS10850-Production mode-Deactivate massage function,not active ,3
IDE00001-MAS10871-Production mode-Deactivate AC compressor,not active ,3
IDE00001-MAS13264-Production mode-Activate headlamp cleaning system directly,not active ,3
IDE00001-MAS15400-Production mode-Continuation of basic settings without tester,not active ,3
IDE00001-MAS15622-Production mode-Cleaning of rearview camera: changed actuation time,not active ,3
IDE00001-MAS16746-Production mode-Deactivate air recirculation door,not active ,3
IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,Security access required,3
IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,Security access required,3
IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,Security access required,3
IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,Security access required,3
IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,Security access required,3
IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,Security access required,3
IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,Security access required,3
IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,Security access required,3
IDE00845-Wheel circumference,Conditions not correct or request sequence error,3
IDE01169-Audio lowering request,On ,1
IDE01476-Store air recirculation setting with terminal 15 OFF,According to country version ,1
IDE01482-After-run of parking heater or parking ventilation,activated ,1
IDE01485-Shut-off temperature for solar sunroof,-35 ∞C,1
IDE01493-Sensitivity of air quality sensor,Medium ,1
IDE01495-After-run time of auxiliary heater with air conditioner off,120 s,1
IDE01500-Reduction of window condensation with high humidity,Matching coding ,1
IDE01501-Air leak to footwell,automatic ,1
IDE01503-Running time of basic setting for compressor break-in,120 s,1
IDE01506-Tolerance range for flap end stops,0 ,1
IDE01536-Post heating of auxiliary heating,10 min,1
IDE01550-Service position,138.70 ,2
IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,installed ,1
IDE01996-SFT00041-Installation list: specified installations-Left light control,not installed ,1
IDE01996-SFT00057-Installation list: specified installations-Right light control,not installed ,1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,installed ,1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,installed ,1
IDE01996-SFT00216-Installation list: specified installations-Projection module in left matrix headlamp,not installed ,1
IDE01996-SFT00217-Installation list: specified installations-Projection module in right matrix headlamp,not installed ,1
IDE01996-SFT33232-Installation list: specified installations-Central control for digital matrix light,not installed ,1
IDE02328-Distance to curb,Conditions not correct or request sequence error,1
IDE02329-Allowance for vehicle fittings (width),Conditions not correct or request sequence error,1
IDE02333-Allowance for vehicle fittings (length),Conditions not correct or request sequence error,3
IDE03641-Presentation run dynamic AFS light,not active ,1
IDE03782-Switch-off speed for parking assist,10 ,1
IDE03783-Switch-on speed for parallel parking assist,Conditions not correct or request sequence error,1
IDE04034-Compass: magnetic field zone,Security access required,1
IDE04845-Deactivation of stop prevention by parking aid,Security access required,1
IDE04846-Deactivation of stop prevention by parallel parking assistance,Security access required,1
IDE05274-Acoustic warning for rear lid assistant,not active ,1
IDE05318-Retrofitted components installed,Default ,1
IDE05569-Compressor control in efficiency mode,Eco mode ,1
IDE05743-Reverse gear recognition debounce time,Security access required,1
IDE06546-Interior specified temperature for production routines,22 ∞C,1
IDE06593-Air recirculation for production routines,No effect ,1
IDE06769-Blower regulator for production routines,7 ,1
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,Security access required,1
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,Security access required,1
IDE07356-Position during interval mode,12.51 ,2
IDE08209-Speed of motors,Default ,1
IDE08373-Offset of fresh air blower speed,Default ,1
IDE08577-Garage door opener: use of GPS data,Security access required,1
IDE08578-Garage door opener: bi-directional communic.,Security access required,1
IDE08579-Garage door opener: drift adapt.,Security access required,1
IDE08580-Garage door opener: increasing transm. power,Security access required,1
IDE08583-Garage door opener: no. of channels,Security access required,1
IDE08584-MAS07165-Garage door opener: freq. selection-Frequency range A,Security access required,1
IDE08584-MAS07166-Garage door opener: freq. selection-Frequency range B,Security access required,1
IDE08584-MAS07167-Garage door opener: freq. selection-Frequency range C,Security access required,1
IDE08584-MAS07168-Garage door opener: freq. selection-Frequency range D,Security access required,1
IDE08584-MAS07169-Garage door opener: freq. selection-Frequency range E,Security access required,1
IDE08584-MAS07170-Garage door opener: freq. selection-Frequency range F,Security access required,1
IDE08584-MAS07171-Garage door opener: freq. selection-Frequency range G,Security access required,1
IDE08584-MAS07172-Garage door opener: freq. selection-Frequency range H,Security access required,1
IDE08584-MAS07173-Garage door opener: freq. selection-Frequency range I,Security access required,1
IDE08584-MAS07174-Garage door opener: freq. selection-Frequency range J,Security access required,1
IDE08584-MAS07175-Garage door opener: freq. selection-Frequency range K,Security access required,1
IDE08584-MAS09302-Garage door opener: freq. selection-Frequency range US-I,Security access required,1
IDE08584-MAS09303-Garage door opener: freq. selection-Frequency range US-II,Security access required,1
IDE08584-MAS09304-Garage door opener: freq. selection-Frequency range US-III,Security access required,1
IDE08584-MAS09305-Garage door opener: freq. selection-Frequency range US-IV,Security access required,1
IDE08584-MAS10461-Garage door opener: freq. selection-Frequency range AB,Security access required,1
IDE08585-Garage door opener: activation via remote key,Security access required,1
IDE08778-Garage door opener: surround. target area,Security access required,1
IDE09377-IDE00761-Multi contour seat driver's side-Run-on time,No Response From Subnet Component,1
IDE09377-IDE03006-Multi contour seat driver's side-Running time of massage function,No Response From Subnet Component,1
IDE09377-IDE03007-Multi contour seat driver's side-Component location,No Response From Subnet Component,1
IDE09377-IDE03099-Multi contour seat driver's side-Characteristics for manual seat adjustment,No Response From Subnet Component,1
IDE09377-IDE03100-Multi contour seat driver's side-Characteristics for seat adjustment using memory,No Response From Subnet Component,1
IDE09378-IDE00761-Multicontour seat passenger side-Run-on time,No Response From Subnet Component,1
IDE09378-IDE03006-Multicontour seat passenger side-Running time of massage function,No Response From Subnet Component,1
IDE09378-IDE03007-Multicontour seat passenger side-Component location,No Response From Subnet Component,1
IDE09378-IDE03099-Multicontour seat passenger side-Characteristics for manual seat adjustment,No Response From Subnet Component,1
IDE09378-IDE03100-Multicontour seat passenger side-Characteristics for seat adjustment using memory,No Response From Subnet Component,1
IDE09546-Multicontour seat on driver's side: reset compressor counter,No Response From Subnet Component,1
IDE09547-Multicontour seat on frt. pass. side: reset compressor counter,No Response From Subnet Component,1
IDE09548-Multicontour seat on driver's side: reset adaptation,No Response From Subnet Component,1
IDE09549-Multicontour seat on frt. pass. side: reset adaptation,No Response From Subnet Component,1
IDE10118-Fan speed reduction for telephony,Not available ,1
IDE10119-Blower reduction during voice control,Not available ,1
IDE10296-upper turn position,154.80 ,2
IDE10297-lower turn position,16.01 ,2
IDE10298-Alternating park position 1,7.31 ,2
IDE10299-Alternating park position 2,10.60 ,2
IDE10307-Presentation mode of multicolor ambient and contour lighting,not active ,1
IDE10308-Garage door opener: support door name,Security access required,1
IDE10321-MAS01364-Seat heater: micro adjust.-Stage 1,0 ∞C,3
IDE10321-MAS01365-Seat heater: micro adjust.-Stage 2,0 ∞C,3
IDE10321-MAS01366-Seat heater: micro adjust.-Stage 3,0 ∞C,3
IDE10322-MAS01364-Seat ventilation: micro adjust.-Stage 1,0 %,3
IDE10322-MAS01365-Seat ventilation: micro adjust.-Stage 2,0 %,3
IDE10322-MAS01366-Seat ventilation: micro adjust.-Stage 3,0 %,3
IDE10331-MAS02201-Roof electronics control module: temperature-related dim.-Temperature,65 ∞C,2
IDE10331-MAS10404-Roof electronics control module: temperature-related dim.-max. brightness,10 %,2
IDE10349-MAS10436-Garage door opener: Default/Fix kit mode-Default mode,No Response From Subnet Component,2
IDE10349-MAS10437-Garage door opener: Default/Fix kit mode-Fixkit mode: button 1,No Response From Subnet Component,2
IDE10349-MAS10438-Garage door opener: Default/Fix kit mode-Fixkit mode: button 2,No Response From Subnet Component,2
IDE10349-MAS10439-Garage door opener: Default/Fix kit mode-Fixkit mode: button 3,No Response From Subnet Component,2
IDE10350-Garage door opener: programming antenna,Security access required,2
IDE10362-MAS10458-Electrically adjustable steering column: adjustment speed-axial,No Response From Subnet Component,2
IDE10362-MAS10462-Electrically adjustable steering column: adjustment speed-vertical,No Response From Subnet Component,2
IDE10363-Electrically adjust. steering column: entry assist.,No Response From Subnet Component,2
IDE10364-Electrically adjust. steering column: soft stop,No Response From Subnet Component,2
IDE10661-Deactivation of start-stop function (climate control),not active ,1
IDE10729-Runtime measurement,on task level ,1
IDE10914-Seat occupancy-depending A/C,Matching coding ,1
IDE11217-Show parking space,not activated ,1
IDE11549-Automatic query of the identification data on LIN-Bus,activated: no backup ,1
IDE11613-MAS01364-Rear seat ventilation: micro adjustment-Stage 1,0 %,3
IDE11613-MAS01365-Rear seat ventilation: micro adjustment-Stage 2,0 %,3
IDE11613-MAS01366-Rear seat ventilation: micro adjustment-Stage 3,0 %,3
IDE11794-MAS13241-Fragrance diffuser system control module-Aroma 1,0 ,2
IDE11794-MAS13242-Fragrance diffuser system control module-Aroma 2,0 ,2
IDE11954-Automatic activation of parking distance control,active ,1
IDE12119-Garage door opener: frequency range of bi-directional communication,Security access required,1
IDE12120-Garage door opener: piloted parking,Security access required,1
IDE12121-Garage door opener: vehicle variant,Security access required,1
IDE12122-Garage door opener: continuous transmission mode for level measurement,Security access required,1
IDE12224-MAS14154-Rear parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12224-MAS14155-Rear parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12225-MAS14154-Front parking aid warning buzzer with open convertible top-Volume at Level 1,4 ,2
IDE12225-MAS14155-Front parking aid warning buzzer with open convertible top-Increment between the volume levels,20 ,2
IDE12291-A/C control and display heads: dimming,Dimming: no dimming when approaching ,1
IDE12359-Roof electronics control module 2: delay time: change of dimming value,No Response From Subnet Component,1
IDE12360-MAS02201-Roof electronics control module 2: temperature-related dim.-Temperature,No Response From Subnet Component,1
IDE12360-MAS10404-Roof electronics control module 2: temperature-related dim.-max. brightness,No Response From Subnet Component,1
IDE12361-Roof electronics control module 2: child-safety dependent,No Response From Subnet Component,1
IDE13059-Cleaning of rearview camera: actuation time in production mode,10000 ms,2
IDE13064-Wiper motor control module: dataset,00 00 06 0C 00 A0 00 7D 00 49 00 6A 05 6B 00 00 00 AA 04 06 02 C0 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 0E 14 19 00 00 00 00 0C 00 00 FC FD 00 00 F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B7 ED 41 5A ,90
IDE13354-Wiper motor control module: dataset 2,No Response From Subnet Component,90
IDE13355-Wiper motor control module: dataset 3,00 00 0F 00 6E 19 00 00 0A 04 64 96 C8 FA 6E 73 78 82 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 45 FF 6B E1 ,50
IDE13356-Wiper motor control module: dataset 4,00 00 38 57 31 39 35 35 31 31 39 41 20 35 36 36 39 35 35 31 31 39 20 20 30 35 31 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 07 9F B8 ,70
IDE13962-Upper soft distance,No Response From Subnet Component,70
IDE13963-Lower soft distance,No Response From Subnet Component,70
IDE13964-Soft distance retracted,No Response From Subnet Component,70
IDE13965-Soft distance extended,No Response From Subnet Component,70
IDE80001-Analysis 1,Security access required,70
IDE80002-Analysis 2,Security access required,70
IDE80003-Analysis 3,Security access required,70
IDE80251-MAS09644-Head area heater-Vent temperature,Security access required,70
IDE80251-MAS10293-Head area heater-Fan speed,Security access required,70
MAS01426-Rear parking aid buzzer: volume,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 6 ,1
MAS01428-Front parking aid buzzer: volume,Stage 4 ,1
MAS01429-Speaker frequency for front park assist,Stage 4 ,1
MAS12843-Maneuvering brake function,activated ,1
MAS15621-Restart information,activated ,1
ENG153768-AAU_CL_Adresse,Security access required,1
ENG133846-ENG98987-amature_ conditioning-Time,Security access required,1
ENG133846-ENG99033-amature_ conditioning-Voltage,Security access required,1
ENG125611-ENG125698-Blower_1_Backrest_Left-Counter_For_Blockage_Validation,Security access required,1
ENG125611-ENG125700-Blower_1_Backrest_Left-Critical_Temperature_Treshold,Security access required,1
ENG125611-ENG125697-Blower_1_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125611-ENG125699-Blower_1_Backrest_Left-Latency_For_Blockage_Validation,Security access required,1
ENG125611-ENG125701-Blower_1_Backrest_Left-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125611-ENG134731-Blower_1_Backrest_Left-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125611-ENG125695-Blower_1_Backrest_Left-Overvoltage_treshold,Security access required,1
ENG125611-ENG125696-Blower_1_Backrest_Left-Undervoltage_treshold,Security access required,1
ENG153775-ENG125698-Blower_1_Backrest_Left_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153775-ENG125700-Blower_1_Backrest_Left_fond-Critical_Temperature_Treshold,Security access required,1
ENG153775-ENG125697-Blower_1_Backrest_Left_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153775-ENG125699-Blower_1_Backrest_Left_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153775-ENG125701-Blower_1_Backrest_Left_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153775-ENG134731-Blower_1_Backrest_Left_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153775-ENG125695-Blower_1_Backrest_Left_fond-Overvoltage_treshold,Security access required,1
ENG153775-ENG125696-Blower_1_Backrest_Left_fond-Undervoltage_treshold,Security access required,1
ENG125612-ENG125698-Blower_1_Backrest_Right-Counter_For_Blockage_Validation,Security access required,1
ENG125612-ENG125700-Blower_1_Backrest_Right-Critical_Temperature_Treshold,Security access required,1
ENG125612-ENG125697-Blower_1_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125612-ENG125699-Blower_1_Backrest_Right-Latency_For_Blockage_Validation,Security access required,1
ENG125612-ENG125701-Blower_1_Backrest_Right-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125612-ENG134731-Blower_1_Backrest_Right-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125612-ENG125695-Blower_1_Backrest_Right-Overvoltage_treshold,Security access required,1
ENG125612-ENG125696-Blower_1_Backrest_Right-Undervoltage_treshold,Security access required,1
ENG153776-ENG125698-Blower_1_Backrest_Right_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153776-ENG125700-Blower_1_Backrest_Right_fond-Critical_Temperature_Treshold,Security access required,1
ENG153776-ENG125697-Blower_1_Backrest_Right_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153776-ENG125699-Blower_1_Backrest_Right_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153776-ENG125701-Blower_1_Backrest_Right_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153776-ENG134731-Blower_1_Backrest_Right_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153776-ENG125695-Blower_1_Backrest_Right_fond-Overvoltage_treshold,Security access required,1
ENG153776-ENG125696-Blower_1_Backrest_Right_fond-Undervoltage_treshold,Security access required,1
ENG125609-ENG125698-Blower_1_Cushion_Left-Counter_For_Blockage_Validation,Security access required,1
ENG125609-ENG125700-Blower_1_Cushion_Left-Critical_Temperature_Treshold,Security access required,1
ENG125609-ENG125697-Blower_1_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125609-ENG125699-Blower_1_Cushion_Left-Latency_For_Blockage_Validation,Security access required,1
ENG125609-ENG125701-Blower_1_Cushion_Left-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125609-ENG134731-Blower_1_Cushion_Left-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125609-ENG125695-Blower_1_Cushion_Left-Overvoltage_treshold,Security access required,1
ENG125609-ENG125696-Blower_1_Cushion_Left-Undervoltage_treshold,Security access required,1
ENG153777-ENG125698-Blower_1_Cushion_Left_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153777-ENG125700-Blower_1_Cushion_Left_fond-Critical_Temperature_Treshold,Security access required,1
ENG153777-ENG125697-Blower_1_Cushion_Left_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153777-ENG125699-Blower_1_Cushion_Left_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153777-ENG125701-Blower_1_Cushion_Left_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153777-ENG134731-Blower_1_Cushion_Left_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153777-ENG125695-Blower_1_Cushion_Left_fond-Overvoltage_treshold,Security access required,1
ENG153777-ENG125696-Blower_1_Cushion_Left_fond-Undervoltage_treshold,Security access required,1
ENG125610-ENG125698-Blower_1_Cushion_Right-Counter_For_Blockage_Validation,Security access required,1
ENG125610-ENG125700-Blower_1_Cushion_Right-Critical_Temperature_Treshold,Security access required,1
ENG125610-ENG125697-Blower_1_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125610-ENG125699-Blower_1_Cushion_Right-Latency_For_Blockage_Validation,Security access required,1
ENG125610-ENG125701-Blower_1_Cushion_Right-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125610-ENG134731-Blower_1_Cushion_Right-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125610-ENG125695-Blower_1_Cushion_Right-Overvoltage_treshold,Security access required,1
ENG125610-ENG125696-Blower_1_Cushion_Right-Undervoltage_treshold,Security access required,1
ENG153778-ENG125698-Blower_1_Cushion_Right_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153778-ENG125700-Blower_1_Cushion_Right_fond-Critical_Temperature_Treshold,Security access required,1
ENG153778-ENG125697-Blower_1_Cushion_Right_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153778-ENG125699-Blower_1_Cushion_Right_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153778-ENG125701-Blower_1_Cushion_Right_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153778-ENG134731-Blower_1_Cushion_Right_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153778-ENG125695-Blower_1_Cushion_Right_fond-Overvoltage_treshold,Security access required,1
ENG153778-ENG125696-Blower_1_Cushion_Right_fond-Undervoltage_treshold,Security access required,1
ENG125620-ENG125698-Blower_2_Backrest_Left-Counter_For_Blockage_Validation,Security access required,1
ENG125620-ENG125700-Blower_2_Backrest_Left-Critical_Temperature_Treshold,Security access required,1
ENG125620-ENG125697-Blower_2_Backrest_Left-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125620-ENG125699-Blower_2_Backrest_Left-Latency_For_Blockage_Validation,Security access required,1
ENG125620-ENG125701-Blower_2_Backrest_Left-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125620-ENG134731-Blower_2_Backrest_Left-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125620-ENG125695-Blower_2_Backrest_Left-Overvoltage_treshold,Security access required,1
ENG125620-ENG125696-Blower_2_Backrest_Left-Undervoltage_treshold,Security access required,1
ENG153779-ENG125698-Blower_2_Backrest_Left_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153779-ENG125700-Blower_2_Backrest_Left_fond-Critical_Temperature_Treshold,Security access required,1
ENG153779-ENG125697-Blower_2_Backrest_Left_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153779-ENG125699-Blower_2_Backrest_Left_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153779-ENG125701-Blower_2_Backrest_Left_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153779-ENG134731-Blower_2_Backrest_Left_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153779-ENG125695-Blower_2_Backrest_Left_fond-Overvoltage_treshold,Security access required,1
ENG153779-ENG125696-Blower_2_Backrest_Left_fond-Undervoltage_treshold,Security access required,1
ENG125619-ENG125698-Blower_2_Backrest_Right-Counter_For_Blockage_Validation,Security access required,1
ENG125619-ENG125700-Blower_2_Backrest_Right-Critical_Temperature_Treshold,Security access required,1
ENG125619-ENG125697-Blower_2_Backrest_Right-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125619-ENG125699-Blower_2_Backrest_Right-Latency_For_Blockage_Validation,Security access required,1
ENG125619-ENG125701-Blower_2_Backrest_Right-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125619-ENG134731-Blower_2_Backrest_Right-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125619-ENG125695-Blower_2_Backrest_Right-Overvoltage_treshold,Security access required,1
ENG125619-ENG125696-Blower_2_Backrest_Right-Undervoltage_treshold,Security access required,1
ENG153780-ENG125698-Blower_2_Backrest_Right_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153780-ENG125700-Blower_2_Backrest_Right_fond-Critical_Temperature_Treshold,Security access required,1
ENG153780-ENG125697-Blower_2_Backrest_Right_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153780-ENG125699-Blower_2_Backrest_Right_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153780-ENG125701-Blower_2_Backrest_Right_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153780-ENG134731-Blower_2_Backrest_Right_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153780-ENG125695-Blower_2_Backrest_Right_fond-Overvoltage_treshold,Security access required,1
ENG153780-ENG125696-Blower_2_Backrest_Right_fond-Undervoltage_treshold,Security access required,1
ENG125617-ENG125698-Blower_2_Cushion_Left-Counter_For_Blockage_Validation,Security access required,1
ENG125617-ENG125700-Blower_2_Cushion_Left-Critical_Temperature_Treshold,Security access required,1
ENG125617-ENG125697-Blower_2_Cushion_Left-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125617-ENG125699-Blower_2_Cushion_Left-Latency_For_Blockage_Validation,Security access required,1
ENG125617-ENG125701-Blower_2_Cushion_Left-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125617-ENG134731-Blower_2_Cushion_Left-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125617-ENG125695-Blower_2_Cushion_Left-Overvoltage_treshold,Security access required,1
ENG125617-ENG125696-Blower_2_Cushion_Left-Undervoltage_treshold,Security access required,1
ENG153781-ENG125698-Blower_2_Cushion_Left_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153781-ENG125700-Blower_2_Cushion_Left_fond-Critical_Temperature_Treshold,Security access required,1
ENG153781-ENG125697-Blower_2_Cushion_Left_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153781-ENG125699-Blower_2_Cushion_Left_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153781-ENG125701-Blower_2_Cushion_Left_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153781-ENG134731-Blower_2_Cushion_Left_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153781-ENG125695-Blower_2_Cushion_Left_fond-Overvoltage_treshold,Security access required,1
ENG153781-ENG125696-Blower_2_Cushion_Left_fond-Undervoltage_treshold,Security access required,1
ENG125618-ENG125698-Blower_2_Cushion_Right-Counter_For_Blockage_Validation,Security access required,1
ENG125618-ENG125700-Blower_2_Cushion_Right-Critical_Temperature_Treshold,Security access required,1
ENG125618-ENG125697-Blower_2_Cushion_Right-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG125618-ENG125699-Blower_2_Cushion_Right-Latency_For_Blockage_Validation,Security access required,1
ENG125618-ENG125701-Blower_2_Cushion_Right-Maximum_Blower_Rotation_Speed,Security access required,1
ENG125618-ENG134731-Blower_2_Cushion_Right-Minimum_Blower_Rotation_Speed,Security access required,1
ENG125618-ENG125695-Blower_2_Cushion_Right-Overvoltage_treshold,Security access required,1
ENG125618-ENG125696-Blower_2_Cushion_Right-Undervoltage_treshold,Security access required,1
ENG153782-ENG125698-Blower_2_Cushion_Right_fond-Counter_For_Blockage_Validation,Security access required,1
ENG153782-ENG125700-Blower_2_Cushion_Right_fond-Critical_Temperature_Treshold,Security access required,1
ENG153782-ENG125697-Blower_2_Cushion_Right_fond-Hysteresis_Treshold_For_Undervoltage,Security access required,1
ENG153782-ENG125699-Blower_2_Cushion_Right_fond-Latency_For_Blockage_Validation,Security access required,1
ENG153782-ENG125701-Blower_2_Cushion_Right_fond-Maximum_Blower_Rotation_Speed,Security access required,1
ENG153782-ENG134731-Blower_2_Cushion_Right_fond-Minimum_Blower_Rotation_Speed,Security access required,1
ENG153782-ENG125695-Blower_2_Cushion_Right_fond-Overvoltage_treshold,Security access required,1
ENG153782-ENG125696-Blower_2_Cushion_Right_fond-Undervoltage_treshold,Security access required,1
ENG128948-ENG128957-Compass_display_dimming_curve_manipulation-Point_0_Bus_Value,Security access required,1
ENG128948-ENG128958-Compass_display_dimming_curve_manipulation-Point_0_PWM_Value,Security access required,1
ENG128948-ENG128959-Compass_display_dimming_curve_manipulation-Point_1_Bus_Value,Security access required,1
ENG128948-ENG128960-Compass_display_dimming_curve_manipulation-Point_1_PWM_Value,Security access required,1
ENG128948-ENG128961-Compass_display_dimming_curve_manipulation-Point_2_Bus_Value,Security access required,1
ENG128948-ENG128962-Compass_display_dimming_curve_manipulation-Point_2_PWM_Value,Security access required,1
ENG128948-ENG128963-Compass_display_dimming_curve_manipulation-Point_3_Bus_Value,Security access required,1
ENG128948-ENG128964-Compass_display_dimming_curve_manipulation-Point_3_PWM_Value,Security access required,1
ENG128948-ENG128965-Compass_display_dimming_curve_manipulation-Point_4_Bus_Value,Security access required,1
ENG128948-ENG128966-Compass_display_dimming_curve_manipulation-Point_4_PWM_Value,Security access required,1
ENG128948-ENG128967-Compass_display_dimming_curve_manipulation-Point_5_Bus_Value,Security access required,1
ENG128948-ENG128968-Compass_display_dimming_curve_manipulation-Point_5_PWM_Value,Security access required,1
ENG128949-Compass_display_memory,Security access required,1
ENG133837-ENG134737-dim_ramp-dim_ambiente,Security access required,1
ENG133837-ENG134735-dim_ramp-dim_cockpit,Security access required,1
ENG133837-ENG134738-dim_ramp-dim_contact_switch,Security access required,1
ENG133837-ENG134736-dim_ramp-dim_fond,Security access required,1
ENG133837-ENG134741-dim_ramp-dim_in_light_0,Security access required,1
ENG133837-ENG134742-dim_ramp-dim_in_light_1,Security access required,1
ENG133837-ENG134739-dim_ramp-dim_read_light_0,Security access required,1
ENG133837-ENG134740-dim_ramp-dim_read_light_1,Security access required,1
ENG133837-ENG142175-dim_ramp-dim_touch_actuation,Security access required,1
ENG153807-ENG155029-dim_ramp_light_module_2-dim_contact_switch_light_module_2,Security access required,1
ENG153807-ENG155030-dim_ramp_light_module_2-dim_in_light_0_light_module_2,Security access required,1
ENG153807-ENG155031-dim_ramp_light_module_2-dim_in_light_1_light_module_2,Security access required,1
ENG153807-ENG155033-dim_ramp_light_module_2-dim_read_light_0_light_module_2,Security access required,1
ENG153807-ENG155034-dim_ramp_light_module_2-dim_read_light_1_light_module_2,Security access required,1
ENG153807-ENG155035-dim_ramp_light_module_2-dim_touch_activation_light_module_2,Security access required,1
ENG133840-ENG134747-dim_read_light-dim_read_light_back,Security access required,1
ENG133840-ENG134746-dim_read_light-dim_read_light_front,Security access required,1
ENG133841-ENG134749-dim_read_light_ring-dim_light_ring_back,Security access required,1
ENG133841-ENG134748-dim_read_light_ring-dim_light_ring_front,Security access required,1
ENG153808-dim_rear_button,Security access required,1
ENG133839-ENG134745-dim_value_in_light-dim_in_light_back,Security access required,1
ENG133839-ENG134744-dim_value_in_light-dim_in_light_front,Security access required,1
ENG153809-dim_value_light_module_2,Security access required,1
ENG133847-ENG134768-displacement_compensation-evls_defect,Security access required,1
ENG133847-ENG134761-displacement_compensation-evls_fault,Security access required,1
ENG133847-ENG134762-displacement_compensation-hall_axial_fault,Security access required,1
ENG133847-ENG134763-displacement_compensation-hall_vertical_fault,Security access required,1
ENG133847-ENG134764-displacement_compensation-motor_axial_fault,Security access required,1
ENG133847-ENG134765-displacement_compensation-motor_vertical_fault,Security access required,1
ENG133847-ENG134769-displacement_compensation-number_halls,Security access required,1
ENG133847-ENG134767-displacement_compensation-scaling_status_fault,Security access required,1
ENG133847-ENG134766-displacement_compensation-switch_fault,Security access required,1
ENG125597-ENG126865-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,Security access required,1
ENG125597-ENG126867-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,Security access required,1
ENG125597-ENG126866-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,Security access required,1
ENG125597-ENG126868-Driver_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,Security access required,1
ENG125597-ENG125690-Driver_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,Security access required,1
ENG125594-ENG125682-Driver_failure_detection_multi-contour_seat-s_GrobleckerkennungDauer,Security access required,1
ENG125594-ENG125680-Driver_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,Security access required,1
ENG125594-ENG125681-Driver_failure_detection_multi-contour_seat-s_Leckageerkennung,Security access required,1
ENG125594-ENG125678-Driver_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,Security access required,1
ENG125594-ENG125679-Driver_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,Security access required,1
ENG125588-ENG125667-Driver_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125666-Driver_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125668-Driver_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125588-ENG125673-Driver_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125672-Driver_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125674-Driver_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125588-ENG125670-Driver_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125669-Driver_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125671-Driver_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125588-ENG125676-Driver_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125675-Driver_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125677-Driver_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125588-ENG125664-Driver_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125588-ENG125663-Driver_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125588-ENG125665-Driver_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125667-Driver_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125666-Driver_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125668-Driver_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125673-Driver_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125672-Driver_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125674-Driver_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125670-Driver_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125669-Driver_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125671-Driver_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125676-Driver_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125675-Driver_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125677-Driver_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125589-ENG125664-Driver_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125589-ENG125663-Driver_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125589-ENG125665-Driver_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125667-Driver_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125666-Driver_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125668-Driver_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125673-Driver_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125672-Driver_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125674-Driver_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125670-Driver_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125669-Driver_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125671-Driver_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125676-Driver_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125675-Driver_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125677-Driver_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125590-ENG125664-Driver_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125590-ENG125663-Driver_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125590-ENG125665-Driver_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125667-Driver_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125666-Driver_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125668-Driver_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125673-Driver_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125672-Driver_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125674-Driver_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125670-Driver_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125669-Driver_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125671-Driver_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125676-Driver_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125675-Driver_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125677-Driver_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125591-ENG125664-Driver_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125591-ENG125663-Driver_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125591-ENG125665-Driver_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125667-Driver_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125666-Driver_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125668-Driver_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125673-Driver_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125672-Driver_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125674-Driver_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125670-Driver_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125669-Driver_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125671-Driver_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125676-Driver_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125675-Driver_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125677-Driver_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125592-ENG125664-Driver_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125592-ENG125663-Driver_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125592-ENG125665-Driver_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125667-Driver_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125666-Driver_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125668-Driver_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125673-Driver_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125672-Driver_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125674-Driver_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125670-Driver_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125669-Driver_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125671-Driver_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125676-Driver_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125675-Driver_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125677-Driver_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG125593-ENG125664-Driver_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG125593-ENG125663-Driver_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG125593-ENG125665-Driver_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125667-Driver_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125666-Driver_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125668-Driver_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125673-Driver_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125672-Driver_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125674-Driver_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125670-Driver_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125669-Driver_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125671-Driver_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125676-Driver_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125675-Driver_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125677-Driver_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG179017-ENG125664-Driver_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG179017-ENG125663-Driver_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG179017-ENG125665-Driver_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125667-Driver_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125666-Driver_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125668-Driver_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125673-Driver_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125672-Driver_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125674-Driver_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125670-Driver_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125669-Driver_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125671-Driver_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125676-Driver_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125675-Driver_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125677-Driver_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG179018-ENG125664-Driver_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG179018-ENG125663-Driver_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG179018-ENG125665-Driver_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125667-Driver_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125666-Driver_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125668-Driver_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125673-Driver_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125672-Driver_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125674-Driver_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125670-Driver_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125669-Driver_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125671-Driver_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125676-Driver_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125675-Driver_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125677-Driver_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,1
ENG179019-ENG125664-Driver_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,1
ENG179019-ENG125663-Driver_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,1
ENG179019-ENG125665-Driver_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,1
ENG133363-ENG133471-Driver_multi-contour_seat_Alfmeier_1-Offset_PB1_LM,Security access required,1
ENG133363-ENG133470-Driver_multi-contour_seat_Alfmeier_1-Offset_PB1_LO,Security access required,1
ENG133363-ENG133472-Driver_multi-contour_seat_Alfmeier_1-Offset_PB1_LU,Security access required,1
ENG133363-ENG133473-Driver_multi-contour_seat_Alfmeier_1-Offset_PB1_SH,Security access required,1
ENG133363-ENG133475-Driver_multi-contour_seat_Alfmeier_1-Offset_PB2_LM,Security access required,1
ENG133363-ENG133474-Driver_multi-contour_seat_Alfmeier_1-Offset_PB2_LO,Security access required,1
ENG133363-ENG133476-Driver_multi-contour_seat_Alfmeier_1-Offset_PB2_LU,Security access required,1
ENG133363-ENG133477-Driver_multi-contour_seat_Alfmeier_1-Offset_PB2_SH,Security access required,1
ENG133363-ENG133483-Driver_multi-contour_seat_Alfmeier_1-Offset_PV1_LM,Security access required,1
ENG133363-ENG133482-Driver_multi-contour_seat_Alfmeier_1-Offset_PV1_LO,Security access required,1
ENG133363-ENG133484-Driver_multi-contour_seat_Alfmeier_1-Offset_PV1_LU,Security access required,1
ENG133363-ENG133485-Driver_multi-contour_seat_Alfmeier_1-Offset_PV1_SH,Security access required,1
ENG133363-ENG133486-Driver_multi-contour_seat_Alfmeier_1-Offset_PV2_LO,Security access required,1
ENG133363-ENG133488-Driver_multi-contour_seat_Alfmeier_1-Offset_PV2_LU,Security access required,1
ENG133363-ENG133489-Driver_multi-contour_seat_Alfmeier_1-Offset_PV2_SH,Security access required,1
ENG133363-ENG134733-Driver_multi-contour_seat_Alfmeier_1-OffsetPP1 3,Security access required,1
ENG133363-ENG134734-Driver_multi-contour_seat_Alfmeier_1-OffsetPP2 4,Security access required,1
ENG133363-ENG133487-Driver_multi-contour_seat_Alfmeier_1-OffsetPV2_LMy,Security access required,1
ENG133363-ENG133478-Driver_multi-contour_seat_Alfmeier_1-OffsetT1,Security access required,1
ENG133363-ENG134732-Driver_multi-contour_seat_Alfmeier_1-OffsetT2 2,Security access required,1
ENG133363-ENG133490-Driver_multi-contour_seat_Alfmeier_1-p_function_feedback_timeout,Security access required,1
ENG133363-ENG133491-Driver_multi-contour_seat_Alfmeier_1-p_longpush_time,Security access required,1
ENG133363-ENG133497-Driver_multi-contour_seat_Alfmeier_1-p_stoesselSchaltschwelle_eins,Security access required,1
ENG133363-ENG133498-Driver_multi-contour_seat_Alfmeier_1-p_stoesselSchaltschwelle_zwei,Security access required,1
ENG133363-ENG133494-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_drei,Security access required,1
ENG133363-ENG133492-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_eins,Security access required,1
ENG133363-ENG133496-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_fuenf,Security access required,1
ENG133363-ENG133495-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_vier,Security access required,1
ENG133363-ENG133493-Driver_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_zwei,Security access required,1
ENG133363-ENG133458-Driver_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Befuellen,Security access required,1
ENG133363-ENG133460-Driver_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Druckmessung,Security access required,1
ENG133363-ENG133459-Driver_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Entlueften,Security access required,1
ENG133363-ENG133469-Driver_multi-contour_seat_Alfmeier_1-s_Faktor_Druck_Entlueftung_Seitenhalt,Security access required,1
ENG133363-ENG133464-Driver_multi-contour_seat_Alfmeier_1-s_IntervallUmgebungsbedingungen,Security access required,1
ENG133363-ENG133465-Driver_multi-contour_seat_Alfmeier_1-s_MaxIntervall,Security access required,1
ENG133363-ENG133461-Driver_multi-contour_seat_Alfmeier_1-s_Messdauer_Initialisierung,Security access required,1
ENG133363-ENG133462-Driver_multi-contour_seat_Alfmeier_1-s_Messdauer_Kurzzeitmessung,Security access required,1
ENG133363-ENG133463-Driver_multi-contour_seat_Alfmeier_1-s_Messdauer_Langzeitmessung,Security access required,1
ENG133363-ENG133468-Driver_multi-contour_seat_Alfmeier_1-s_Sitzvariante,Security access required,1
ENG133363-ENG133467-Driver_multi-contour_seat_Alfmeier_1-s_Timeout_Befuell_Linearbereich,Security access required,1
ENG133363-ENG133466-Driver_multi-contour_seat_Alfmeier_1-s_Timeout_Befuell_Startbereich,Security access required,1
ENG133363-ENG133457-Driver_multi-contour_seat_Alfmeier_1-s_Uebernahmedruck_P_u,Security access required,1
ENG133363-ENG133456-Driver_multi-contour_seat_Alfmeier_1-s_Uebernahmedruck_PUe_o,Security access required,1
ENG125596-ENG125687-Driver_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,Security access required,1
ENG125596-ENG125689-Driver_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,Security access required,1
ENG125596-ENG125685-Driver_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,Security access required,1
ENG125596-ENG125688-Driver_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,Security access required,1
ENG125596-ENG125686-Driver_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,Security access required,1
ENG125595-ENG125684-Driver_pressure_values_multi-contour_seat_driver-s_DruckschwelleNachlauf,Security access required,1
ENG125595-ENG126855-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_m,Security access required,1
ENG125595-ENG126854-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_o,Security access required,1
ENG125595-ENG126856-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_LRD_u,Security access required,1
ENG125595-ENG126857-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Sitzlehnenwangen,Security access required,1
ENG125595-ENG126863-Driver_pressure_values_multi-contour_seat_driver-s_Maximaldruck_Ueberlastschutz,Security access required,1
ENG125595-ENG126862-Driver_pressure_values_multi-contour_seat_driver-s_Maximaler_Differenzdruck_LRD_Vor_Zurueck,Security access required,1
ENG125595-ENG126859-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_m,Security access required,1
ENG125595-ENG126858-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_o,Security access required,1
ENG125595-ENG126860-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_LRD_u,Security access required,1
ENG125595-ENG126864-Driver_pressure_values_multi-contour_seat_driver-s_Minimaldruck_Massage,Security access required,1
ENG125595-ENG126861-Driver_pressure_values_multi-contour_seat_driver-s_MinimaldruckSitzlehnenwangen,Security access required,1
ENG125595-ENG125683-Driver_pressure_values_multi-contour_seat_driver-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,Security access required,1
ENG252014-ENG252049-Driver_seat_perso_1-Hoehe_Lordose_Perso,Security access required,1
ENG252014-ENG252081-Driver_seat_perso_1-Perso_Lehnenwangen,Security access required,1
ENG252014-ENG252087-Driver_seat_perso_1-Perso_letztes_Massageprogramm,Security access required,1
ENG252014-ENG252064-Driver_seat_perso_1-Perso_Massageintensitaet,Security access required,1
ENG252014-ENG252088-Driver_seat_perso_1-Weite_Lordose_Perso,Security access required,1
ENG252015-ENG252049-Driver_seat_perso_2-Hoehe_Lordose_Perso,Security access required,1
ENG252015-ENG252081-Driver_seat_perso_2-Perso_Lehnenwangen,Security access required,1
ENG252015-ENG252087-Driver_seat_perso_2-Perso_letztes_Massageprogramm,Security access required,1
ENG252015-ENG252064-Driver_seat_perso_2-Perso_Massageintensitaet,Security access required,1
ENG252015-ENG252088-Driver_seat_perso_2-Weite_Lordose_Perso,Security access required,1
ENG252016-ENG252049-Driver_seat_perso_3-Hoehe_Lordose_Perso,Security access required,1
ENG252016-ENG252081-Driver_seat_perso_3-Perso_Lehnenwangen,Security access required,1
ENG252016-ENG252087-Driver_seat_perso_3-Perso_letztes_Massageprogramm,Security access required,1
ENG252016-ENG252064-Driver_seat_perso_3-Perso_Massageintensitaet,Security access required,1
ENG252016-ENG252088-Driver_seat_perso_3-Weite_Lordose_Perso,Security access required,1
ENG252017-ENG252049-Driver_seat_perso_4-Hoehe_Lordose_Perso,Security access required,1
ENG252017-ENG252081-Driver_seat_perso_4-Perso_Lehnenwangen,Security access required,1
ENG252017-ENG252087-Driver_seat_perso_4-Perso_letztes_Massageprogramm,Security access required,1
ENG252017-ENG252064-Driver_seat_perso_4-Perso_Massageintensitaet,Security access required,1
ENG252017-ENG252088-Driver_seat_perso_4-Weite_Lordose_Perso,Security access required,1
ENG252018-ENG252049-Driver_seat_perso_5-Hoehe_Lordose_Perso,Security access required,1
ENG252018-ENG252081-Driver_seat_perso_5-Perso_Lehnenwangen,Security access required,1
ENG252018-ENG252087-Driver_seat_perso_5-Perso_letztes_Massageprogramm,Security access required,1
ENG252018-ENG252064-Driver_seat_perso_5-Perso_Massageintensitaet,Security access required,1
ENG252018-ENG252088-Driver_seat_perso_5-Weite_Lordose_Perso,Security access required,1
ENG252019-ENG252049-Driver_seat_perso_6-Hoehe_Lordose_Perso,Security access required,1
ENG252019-ENG252081-Driver_seat_perso_6-Perso_Lehnenwangen,Security access required,1
ENG252019-ENG252087-Driver_seat_perso_6-Perso_letztes_Massageprogramm,Security access required,1
ENG252019-ENG252064-Driver_seat_perso_6-Perso_Massageintensitaet,Security access required,1
ENG252019-ENG252088-Driver_seat_perso_6-Weite_Lordose_Perso,Security access required,1
ENG252020-ENG252049-Driver_seat_perso_7-Hoehe_Lordose_Perso,Security access required,1
ENG252020-ENG252081-Driver_seat_perso_7-Perso_Lehnenwangen,Security access required,1
ENG252020-ENG252087-Driver_seat_perso_7-Perso_letztes_Massageprogramm,Security access required,1
ENG252020-ENG252064-Driver_seat_perso_7-Perso_Massageintensitaet,Security access required,1
ENG252020-ENG252088-Driver_seat_perso_7-Weite_Lordose_Perso,Security access required,1
ENG128947-ENG128957-EC_indicator_dimming_curve_manipulation-Point_0_Bus_Value,Security access required,1
ENG128947-ENG128958-EC_indicator_dimming_curve_manipulation-Point_0_PWM_Value,Security access required,1
ENG128947-ENG128959-EC_indicator_dimming_curve_manipulation-Point_1_Bus_Value,Security access required,1
ENG128947-ENG128960-EC_indicator_dimming_curve_manipulation-Point_1_PWM_Value,Security access required,1
ENG128947-ENG128961-EC_indicator_dimming_curve_manipulation-Point_2_Bus_Value,Security access required,1
ENG128947-ENG128962-EC_indicator_dimming_curve_manipulation-Point_2_PWM_Value,Security access required,1
ENG128947-ENG128963-EC_indicator_dimming_curve_manipulation-Point_3_Bus_Value,Security access required,1
ENG128947-ENG128964-EC_indicator_dimming_curve_manipulation-Point_3_PWM_Value,Security access required,1
ENG128947-ENG128965-EC_indicator_dimming_curve_manipulation-Point_4_Bus_Value,Security access required,1
ENG128947-ENG128966-EC_indicator_dimming_curve_manipulation-Point_4_PWM_Value,Security access required,1
ENG128947-ENG128967-EC_indicator_dimming_curve_manipulation-Point_5_Bus_Value,Security access required,1
ENG128947-ENG128968-EC_indicator_dimming_curve_manipulation-Point_5_PWM_Value,Security access required,1
ENG133843-EC_interior_mirror_turn_down,Security access required,1
ENG131964-ENG133589-EntwID_activation-CapSense,Security access required,1
ENG131964-ENG133591-EntwID_activation-Clima-OBD,Security access required,1
ENG131964-ENG133588-EntwID_activation-Climate,Security access required,1
ENG131964-ENG98556-EntwID_activation-Display,Security access required,1
ENG131964-ENG133587-EntwID_activation-Flaps,Security access required,1
ENG131964-ENG133590-EntwID_activation-Massflow,Security access required,1
ENG131964-ENG116788-EntwID_activation-Potentiometer,Security access required,1
ENG131964-ENG98962-EntwID_activation-system,Security access required,1
ENG116833-Error Message,00 00 ,2
ENG264023-ENG264129-evls_pso_data_1-Axialposition,No Response From Subnet Component,2
ENG264023-ENG264281-evls_pso_data_1-Vertikalposition,No Response From Subnet Component,2
ENG264024-ENG264129-evls_pso_data_2-Axialposition,No Response From Subnet Component,2
ENG264024-ENG264281-evls_pso_data_2-Vertikalposition,No Response From Subnet Component,2
ENG264034-ENG264129-evls_pso_data_3-Axialposition,No Response From Subnet Component,2
ENG264034-ENG264281-evls_pso_data_3-Vertikalposition,No Response From Subnet Component,2
ENG264031-ENG264129-evls_pso_data_4-Axialposition,No Response From Subnet Component,2
ENG264031-ENG264281-evls_pso_data_4-Vertikalposition,No Response From Subnet Component,2
ENG264020-ENG264129-evls_pso_data_5-Axialposition,No Response From Subnet Component,2
ENG264020-ENG264281-evls_pso_data_5-Vertikalposition,No Response From Subnet Component,2
ENG264019-ENG264129-evls_pso_data_6-Axialposition,No Response From Subnet Component,2
ENG264019-ENG264281-evls_pso_data_6-Vertikalposition,No Response From Subnet Component,2
ENG264026-ENG264129-evls_pso_data_7-Axialposition,No Response From Subnet Component,2
ENG264026-ENG264281-evls_pso_data_7-Vertikalposition,No Response From Subnet Component,2
ENG133844-ENG134755-evls_ramp-break_ramp_axial,Security access required,2
ENG133844-ENG134756-evls_ramp-break_ramp_vertical,Security access required,2
ENG133844-ENG134753-evls_ramp-start_up_ramp_axail,Security access required,2
ENG133844-ENG134754-evls_ramp-start_up_ramp_vertical,Security access required,2
ENG133836-Fehlermaske 2,00 00 00 00 ,4
ENG117283-Frontwaschfunktion,10 ,2
ENG153887-ENG154466-LIN_CAN_mirrow-LIN_1,Security access required,2
ENG153887-ENG155269-LIN_CAN_mirrow-LIN_10,Security access required,2
ENG153887-ENG155270-LIN_CAN_mirrow-LIN_11,Security access required,2
ENG153887-ENG155271-LIN_CAN_mirrow-LIN_12,Security access required,2
ENG153887-ENG154480-LIN_CAN_mirrow-LIN_2,Security access required,2
ENG153887-ENG154481-LIN_CAN_mirrow-LIN_3,Security access required,2
ENG153887-ENG154482-LIN_CAN_mirrow-LIN_4,Security access required,2
ENG153887-ENG154483-LIN_CAN_mirrow-LIN_5,Security access required,2
ENG153887-ENG154484-LIN_CAN_mirrow-LIN_6,Security access required,2
ENG153887-ENG155272-LIN_CAN_mirrow-LIN_7,Security access required,2
ENG153887-ENG155273-LIN_CAN_mirrow-LIN_8,Security access required,2
ENG153887-ENG155274-LIN_CAN_mirrow-LIN_9,Security access required,2
ENG115646-Loeschen Fehlerspeicher,Security access required,2
ENG153894-Matrix_read_light,Security access required,2
ENG133365-ENG133451-Multikontursitz_BFS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,2
ENG133365-ENG133447-Multikontursitz_BFS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,2
ENG133365-ENG133453-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,2
ENG133365-ENG133452-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,2
ENG133365-ENG133454-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,2
ENG133365-ENG133455-Multikontursitz_BFS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,2
ENG133365-ENG133448-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,2
ENG133365-ENG133449-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,2
ENG133365-ENG133450-Multikontursitz_BFS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,2
ENG133365-ENG133446-Multikontursitz_BFS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,2
ENG133362-ENG133451-Multikontursitz_FS_Wildmoser-Differenzdruck_Toleranzband,No Response From Subnet Component,2
ENG133362-ENG133447-Multikontursitz_FS_Wildmoser-Leckage_Fehlerschwelle_Druck,No Response From Subnet Component,2
ENG133362-ENG133453-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_mitte,No Response From Subnet Component,2
ENG133362-ENG133452-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_oben,No Response From Subnet Component,2
ENG133362-ENG133454-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_LRD_unten,No Response From Subnet Component,2
ENG133362-ENG133455-Multikontursitz_FS_Wildmoser-Nachentlueftzeit_Seitenwangen,No Response From Subnet Component,2
ENG133362-ENG133448-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_1,No Response From Subnet Component,2
ENG133362-ENG133449-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_2,No Response From Subnet Component,2
ENG133362-ENG133450-Multikontursitz_FS_Wildmoser-Nachregelung_PWM_3,No Response From Subnet Component,2
ENG133362-ENG133446-Multikontursitz_FS_Wildmoser-Schwellwert_Temperaturkompensation,No Response From Subnet Component,2
ENG133838-off_timer_inside_light,Security access required,2
ENG153906-off_timer_inside_light_light_module_2,Security access required,2
ENG153907-ENG155443-p_Allgemeine_Parameter-p_Fkt_Motorstart_enable,Security access required,2
ENG153907-ENG155514-p_Allgemeine_Parameter-p_t_Motorstart_reenable,Security access required,2
ENG153907-ENG155533-p_Allgemeine_Parameter-p_v_hood,Security access required,2
ENG153908-ENG155420-p_Bereich-p_DWP_v_Bereich_1,Security access required,2
ENG153908-ENG155421-p_Bereich-p_DWP_v_Bereich_2,Security access required,2
ENG153908-ENG155422-p_Bereich-p_DWP_v_Bereich_3,Security access required,2
ENG153908-ENG155538-p_Bereich-p_vfzg_Hysterese,Security access required,2
ENG153909-ENG155408-p_FKT_DWP-p_DWP_Fkt_Boost,Security access required,2
ENG153909-ENG155409-p_FKT_DWP-p_DWP_Fkt_EM,Security access required,2
ENG153909-ENG155410-p_FKT_DWP-p_DWP_Fkt_first_Cycle,Security access required,2
ENG153909-ENG155411-p_FKT_DWP-p_DWP_Fkt_LHZ_AUS,Security access required,2
ENG153909-ENG155412-p_FKT_DWP-p_DWP_Fkt_U_Komp,Security access required,2
ENG153909-ENG155442-p_FKT_DWP-p_Fkt_Door_open_active,Security access required,2
ENG153909-ENG155444-p_FKT_DWP-p_Fkt_SAD_open_active,Security access required,2
ENG153909-ENG155445-p_FKT_DWP-p_Fkt_Water_Warning_active,Security access required,2
ENG153910-ENG155447-p_Fkt_HZG-p_HZG_Fkt_EM,Security access required,2
ENG153910-ENG155448-p_Fkt_HZG-p_HZG_Fkt_GefTemp,Security access required,2
ENG153911-ENG155397-p_FSP_Mask-p_010616_U11FD00,Security access required,2
ENG153911-ENG155398-p_FSP_Mask-p_010620_B1921F1,Security access required,2
ENG153911-ENG155399-p_FSP_Mask-p_010623_U11FC00,Security access required,2
ENG153911-ENG155400-p_FSP_Mask-p_010624_B192004,Security access required,2
ENG153911-ENG155401-p_FSP_Mask-p_1_010617_B192111,Security access required,2
ENG153911-ENG155402-p_FSP_Mask-p_1_010621_B192211,Security access required,2
ENG153911-ENG155403-p_FSP_Mask-p_10619_B1921F0,Security access required,2
ENG153911-ENG155404-p_FSP_Mask-p_2_010618_B192115,Security access required,2
ENG153911-ENG155405-p_FSP_Mask-p_2_010622_B192215,Security access required,2
ENG153912-ENG155497-p_HZG_Ansteuerung-p_PWM_Derating_Nachlauf_HZG_Off,Security access required,2
ENG153912-ENG155499-p_HZG_Ansteuerung-p_PWM_MAX_HZG,Security access required,2
ENG153912-ENG155502-p_HZG_Ansteuerung-p_PWM_MIN_HZG,Security access required,2
ENG153912-ENG155515-p_HZG_Ansteuerung-p_t_Nachlauf_HZG_Off,Security access required,2
ENG153912-ENG155519-p_HZG_Ansteuerung-p_T_WTC_PWM_0_HZG,Security access required,2
ENG153912-ENG155520-p_HZG_Ansteuerung-p_T_WTC_PWM_100_HZG,Security access required,2
ENG153913-ENG155512-p_Modus_DWP-p_T_Modus_DWP,Security access required,2
ENG153913-ENG155513-p_Modus_DWP-p_T_Modus_Hysterese_DWP,Security access required,2
ENG153914-ENG155407-p_Parameter_1-p_delta_Pos_Boost,Security access required,2
ENG153914-ENG155454-p_Parameter_1-p_LIN_Variant_ID,Security access required,2
ENG153914-ENG155462-p_Parameter_1-p_pos_DWP_Ansteuerung_disable_LHZ,Security access required,2
ENG153914-ENG155507-p_Parameter_1-p_t_Boost,Security access required,2
ENG153914-ENG155528-p_Parameter_1-p_v_crank,Security access required,2
ENG153914-ENG155532-p_Parameter_1-p_v_Faktor_Boost,Security access required,2
ENG153914-ENG155534-p_Parameter_1-p_v_klemme_15_AUS,Security access required,2
ENG153914-ENG155535-p_Parameter_1-p_v_klemme_X_AUS,Security access required,2
ENG153914-ENG155536-p_Parameter_1-p_v_WWS_timeout,Security access required,2
ENG153914-ENG155537-p_Parameter_1-p_Version_Parameter,Security access required,2
ENG153915-ENG155413-p_Parameter_2-p_DWP_Hood_enable,Security access required,2
ENG153915-ENG155416-p_Parameter_2-p_DWP_ReversierSperrzeit,Security access required,2
ENG153915-ENG155417-p_Parameter_2-p_DWP_Stop_Delay,Security access required,2
ENG153915-ENG155418-p_Parameter_2-p_DWP_Stop_Position,Security access required,2
ENG153915-ENG155419-p_Parameter_2-p_DWP_U_Komp_UBatRef,Security access required,2
ENG153915-ENG155440-p_Parameter_2-p_Faktor_EM_DWP,Security access required,2
ENG153915-ENG155441-p_Parameter_2-p_Faktor_EM_Hzg,Security access required,2
ENG153915-ENG155446-p_Parameter_2-p_HeizungPwmFrequenz,Security access required,2
ENG153915-ENG155449-p_Parameter_2-p_Hzg_GefTemp_Par_ske,Security access required,2
ENG153915-ENG155450-p_Parameter_2-p_Hzg_GefTemp_Par_u,Security access required,2
ENG153915-ENG155451-p_Parameter_2-p_Hzg_GefTemp_Par_v,Security access required,2
ENG153915-ENG155452-p_Parameter_2-p_Hzg_GefTemp_Par_w,Security access required,2
ENG153915-ENG155453-p_Parameter_2-p_LDF_MLB_active,Security access required,2
ENG153915-ENG155496-p_Parameter_2-p_PumpePwmFrequenz,Security access required,2
ENG153915-ENG155511-p_Parameter_2-p_t_min_Aussetzzeit_DWP,Security access required,2
ENG153916-ENG155406-p_Parameter_Diag_1-p_Debug_Mux_Control,Security access required,2
ENG153916-ENG155423-p_Parameter_Diag_1-p_DWP_WWS_Timeout,Security access required,2
ENG153916-ENG155505-p_Parameter_Diag_1-p_Reset_nach_Parametrierung,Security access required,2
ENG153916-ENG155506-p_Parameter_Diag_1-p_SG_BusKnockout_Tmr,Security access required,2
ENG153916-ENG155517-p_Parameter_Diag_1-p_t_STGL_DWP_aktiv,Security access required,2
ENG153916-ENG155518-p_Parameter_Diag_1-p_t_UKlemme30_Entprellung,Security access required,2
ENG153916-ENG155523-p_Parameter_Diag_1-p_u_DWP_Ueberspannung_Off,Security access required,2
ENG153916-ENG155524-p_Parameter_Diag_1-p_u_DWP_Ueberspannung_On,Security access required,2
ENG153916-ENG155525-p_Parameter_Diag_1-p_u_DWP_Unterspannung_Off,Security access required,2
ENG153916-ENG155526-p_Parameter_Diag_1-p_u_DWP_Unterspannung_On,Security access required,2
ENG153916-ENG155530-p_Parameter_Diag_1-p_v_DWP_Ueberspannung,Security access required,2
ENG153916-ENG155531-p_Parameter_Diag_1-p_v_DWP_Unterspannung,Security access required,2
ENG153917-ENG155425-p_Parameter_Diag_2-p_ED_Hzg_KS_n_max,Security access required,2
ENG153917-ENG155426-p_Parameter_Diag_2-p_ED_HZG_KS_Ubat_Offline,Security access required,2
ENG153917-ENG155427-p_Parameter_Diag_2-p_ED_HZG_OpenLoad_Offline,Security access required,2
ENG153917-ENG155428-p_Parameter_Diag_2-p_ED_HZG_R_Einzeldraht_Abriss,Security access required,2
ENG153917-ENG155429-p_Parameter_Diag_2-p_ED_Imax_HighSide_Hzg,Security access required,2
ENG153917-ENG155430-p_Parameter_Diag_2-p_ED_Imax_HighSide_WP,Security access required,2
ENG153917-ENG155431-p_Parameter_Diag_2-p_ED_Imax_HighSide_WP_u_Hzg,Security access required,2
ENG153917-ENG155432-p_Parameter_Diag_2-p_ED_WP_KS_GND_Offline,Security access required,2
ENG153917-ENG155433-p_Parameter_Diag_2-p_ED_WP_KS_n_max,Security access required,2
ENG153917-ENG155434-p_Parameter_Diag_2-p_ED_WP_KS_Ubat_Offline,Security access required,2
ENG153917-ENG155435-p_Parameter_Diag_2-p_ED_WP_LS_Block,Security access required,2
ENG153917-ENG155436-p_Parameter_Diag_2-p_ED_WP_LS_Kurzschluss,Security access required,2
ENG153917-ENG155437-p_Parameter_Diag_2-p_ED_WP_LS_Ueberlast,Security access required,2
ENG153917-ENG155438-p_Parameter_Diag_2-p_ED_WP_OpenLoad_Offline,Security access required,2
ENG153917-ENG155439-p_Parameter_Diag_2-p_EigenDiag_Aktiv,Security access required,2
ENG153917-ENG155503-p_Parameter_Diag_2-p_Reserve_1,Security access required,2
ENG153917-ENG155504-p_Parameter_Diag_2-p_Reserve_2,Security access required,2
ENG153917-ENG155508-p_Parameter_Diag_2-p_T_Derating,Security access required,2
ENG153917-ENG155516-p_Parameter_Diag_2-p_t_Quali_Tiefspannung,Security access required,2
ENG153917-ENG155521-p_Parameter_Diag_2-p_TreiberUebertemperatur_Freigabe,Security access required,2
ENG153917-ENG155522-p_Parameter_Diag_2-p_TreiberUebertemperatur_Sperre,Security access required,2
ENG153917-ENG155527-p_Parameter_Diag_2-p_u_Tiefspannung,Security access required,2
ENG153918-ENG155424-p_Parameter_MWP-p_dyn_waschen_aktiv,Security access required,2
ENG153918-ENG155455-p_Parameter_MWP-p_MWP_v_Bereich_1,Security access required,2
ENG153918-ENG155456-p_Parameter_MWP-p_MWP_v_Bereich_2,Security access required,2
ENG153918-ENG155457-p_Parameter_MWP-p_MWP_v_Bereich_3,Security access required,2
ENG153918-ENG155458-p_Parameter_MWP-p_MWP_v_Bereich_4,Security access required,2
ENG153918-ENG155459-p_Parameter_MWP-p_MWP_v_Bereich_5,Security access required,2
ENG153918-ENG155539-p_Parameter_MWP-p_waschen_Dach_PWM_1,Security access required,2
ENG153918-ENG155540-p_Parameter_MWP-p_waschen_Dach_PWM_2,Security access required,2
ENG153918-ENG155541-p_Parameter_MWP-p_waschen_Dach_PWM_3,Security access required,2
ENG153918-ENG155542-p_Parameter_MWP-p_waschen_Dach_PWM_4,Security access required,2
ENG153918-ENG155543-p_Parameter_MWP-p_waschen_Dach_PWM_5,Security access required,2
ENG153918-ENG155544-p_Parameter_MWP-p_waschen_Dach_PWM_6,Security access required,2
ENG153918-ENG155545-p_Parameter_MWP-p_waschen_Offset_Temp,Security access required,2
ENG153918-ENG155546-p_Parameter_MWP-p_waschen_PWM_V_1,Security access required,2
ENG153918-ENG155547-p_Parameter_MWP-p_waschen_PWM_V_2,Security access required,2
ENG153918-ENG155548-p_Parameter_MWP-p_waschen_PWM_V_3,Security access required,2
ENG153918-ENG155549-p_Parameter_MWP-p_waschen_PWM_V_4,Security access required,2
ENG153918-ENG155550-p_Parameter_MWP-p_waschen_PWM_V_5,Security access required,2
ENG153918-ENG155551-p_Parameter_MWP-p_waschen_PWM_V_6,Security access required,2
ENG153918-ENG155552-p_Parameter_MWP-p_waschen_rampenzeit,Security access required,2
ENG153918-ENG155553-p_Parameter_MWP-p_waschen_Temp_PWM_1,Security access required,2
ENG153918-ENG155554-p_Parameter_MWP-p_waschen_Temp_PWM_2,Security access required,2
ENG153918-ENG155555-p_Parameter_MWP-p_waschen_Temp_PWM_3,Security access required,2
ENG153918-ENG155556-p_Parameter_MWP-p_waschen_Temp_PWM_4,Security access required,2
ENG153918-ENG155557-p_Parameter_MWP-p_waschen_Temp_PWM_5,Security access required,2
ENG153918-ENG155558-p_Parameter_MWP-p_waschen_Temp_PWM_6,Security access required,2
ENG153918-ENG155559-p_Parameter_MWP-p_waschen_zeit_rampestart,Security access required,2
ENG153919-ENG155463-p_Profile_Curve-p_Profile_Angel_pos_1,Security access required,2
ENG153919-ENG155464-p_Profile_Curve-p_Profile_Angel_pos_10,Security access required,2
ENG153919-ENG155465-p_Profile_Curve-p_Profile_Angel_pos_11,Security access required,2
ENG153919-ENG155466-p_Profile_Curve-p_Profile_Angel_pos_12,Security access required,2
ENG153919-ENG155467-p_Profile_Curve-p_Profile_Angel_pos_13,Security access required,2
ENG153919-ENG155468-p_Profile_Curve-p_Profile_Angel_pos_14,Security access required,2
ENG153919-ENG155469-p_Profile_Curve-p_Profile_Angel_pos_15,Security access required,2
ENG153919-ENG155470-p_Profile_Curve-p_Profile_Angel_pos_16,Security access required,2
ENG153919-ENG155471-p_Profile_Curve-p_Profile_Angel_pos_2,Security access required,2
ENG153919-ENG155472-p_Profile_Curve-p_Profile_Angel_pos_3,Security access required,2
ENG153919-ENG155473-p_Profile_Curve-p_Profile_Angel_pos_4,Security access required,2
ENG153919-ENG155474-p_Profile_Curve-p_Profile_Angel_pos_5,Security access required,2
ENG153919-ENG155475-p_Profile_Curve-p_Profile_Angel_pos_6,Security access required,2
ENG153919-ENG155476-p_Profile_Curve-p_Profile_Angel_pos_7,Security access required,2
ENG153919-ENG155477-p_Profile_Curve-p_Profile_Angel_pos_8,Security access required,2
ENG153919-ENG155478-p_Profile_Curve-p_Profile_Angel_pos_9,Security access required,2
ENG153919-ENG155479-p_Profile_Curve-p_Profile_Curve_Index,Security access required,2
ENG153919-ENG155480-p_Profile_Curve-p_Profile_PWM_pos_1,Security access required,2
ENG153919-ENG155481-p_Profile_Curve-p_Profile_PWM_pos_10,Security access required,2
ENG153919-ENG155482-p_Profile_Curve-p_Profile_PWM_pos_11,Security access required,2
ENG153919-ENG155483-p_Profile_Curve-p_Profile_PWM_pos_12,Security access required,2
ENG153919-ENG155484-p_Profile_Curve-p_Profile_PWM_pos_13,Security access required,2
ENG153919-ENG155485-p_Profile_Curve-p_Profile_PWM_pos_14,Security access required,2
ENG153919-ENG155486-p_Profile_Curve-p_Profile_PWM_pos_15,Security access required,2
ENG153919-ENG155487-p_Profile_Curve-p_Profile_PWM_pos_16,Security access required,2
ENG153919-ENG155488-p_Profile_Curve-p_Profile_PWM_pos_2,Security access required,2
ENG153919-ENG155489-p_Profile_Curve-p_Profile_PWM_pos_3,Security access required,2
ENG153919-ENG155490-p_Profile_Curve-p_Profile_PWM_pos_4,Security access required,2
ENG153919-ENG155491-p_Profile_Curve-p_Profile_PWM_pos_5,Security access required,2
ENG153919-ENG155492-p_Profile_Curve-p_Profile_PWM_pos_6,Security access required,2
ENG153919-ENG155493-p_Profile_Curve-p_Profile_PWM_pos_7,Security access required,2
ENG153919-ENG155494-p_Profile_Curve-p_Profile_PWM_pos_8,Security access required,2
ENG153919-ENG155495-p_Profile_Curve-p_Profile_PWM_pos_9,Security access required,2
ENG153920-ENG155414-p_Pumpenansteuerung-p_DWP_PWM_Vorlauf_Sommer,Security access required,2
ENG153920-ENG155415-p_Pumpenansteuerung-p_DWP_PWM_Vorlauf_Winter,Security access required,2
ENG153920-ENG155460-p_Pumpenansteuerung-p_n_max_Waschzyklen,Security access required,2
ENG153920-ENG155461-p_Pumpenansteuerung-p_n_min_Waschzyklen,Security access required,2
ENG153920-ENG155498-p_Pumpenansteuerung-p_PWM_MAX_DWP,Security access required,2
ENG153920-ENG155501-p_Pumpenansteuerung-p_PWM_MIN_DWP,Security access required,2
ENG153920-ENG155509-p_Pumpenansteuerung-p_t_DWP_delay,Security access required,2
ENG153920-ENG155510-p_Pumpenansteuerung-p_t_max_Vorlauf,Security access required,2
ENG153920-ENG155529-p_Pumpenansteuerung-p_v_DWP_delay,Security access required,2
ENG153921-p_WaschWarnung,Security access required,2
ENG133842-ENG134750-pao_chamber-pao_chamber_1,Security access required,2
ENG133842-ENG134751-pao_chamber-pao_chamber_2,Security access required,2
ENG133842-ENG134752-pao_chamber-pao_chamber_3,Security access required,2
ENG125607-ENG126865-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manuelle_Befuellung_LRD,Security access required,2
ENG125607-ENG126867-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Manueller_Befuellung_Seitenwangen,Security access required,2
ENG125607-ENG126866-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_LRD,Security access required,2
ENG125607-ENG126868-Passenger_compressor_parameter_multi-contour_seat-s_Kompressorleistung_Memorisierte_Befuellung_Seitenwangen,Security access required,2
ENG125607-ENG125690-Passenger_compressor_parameter_multi-contour_seat-s_VerzoegerungszeitKompressoranlauf,Security access required,2
ENG125608-Passenger_detection_multi-contour_seat,Security access required,2
ENG125604-ENG125693-Passenger_failure_detection_multi-contour_seat-s_DauerFuerGrobleckerkennung,Security access required,2
ENG125604-ENG125680-Passenger_failure_detection_multi-contour_seat-s_LatenzzeitHaengenderTaster,Security access required,2
ENG125604-ENG125681-Passenger_failure_detection_multi-contour_seat-s_Leckageerkennung,Security access required,2
ENG125604-ENG125678-Passenger_failure_detection_multi-contour_seat-s_UeberspannungsSschwelle,Security access required,2
ENG125604-ENG125679-Passenger_failure_detection_multi-contour_seat-s_UnterspannungsSchwelle,Security access required,2
ENG125598-ENG125667-Passenger_massage_program_1_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125691-Passenger_massage_program_1_Intensity_1-EE_pMax_LO_MSG_Px_I,Security access required,2
ENG125598-ENG125668-Passenger_massage_program_1_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125598-ENG125673-Passenger_massage_program_1_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125672-Passenger_massage_program_1_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125598-ENG125674-Passenger_massage_program_1_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125598-ENG125670-Passenger_massage_program_1_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125669-Passenger_massage_program_1_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125598-ENG125671-Passenger_massage_program_1_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125598-ENG125676-Passenger_massage_program_1_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125675-Passenger_massage_program_1_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125598-ENG125677-Passenger_massage_program_1_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125598-ENG125664-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125598-ENG125663-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125598-ENG125665-Passenger_massage_program_1_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125667-Passenger_massage_program_1_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125666-Passenger_massage_program_1_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125668-Passenger_massage_program_1_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125673-Passenger_massage_program_1_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125672-Passenger_massage_program_1_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125674-Passenger_massage_program_1_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125670-Passenger_massage_program_1_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125669-Passenger_massage_program_1_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125671-Passenger_massage_program_1_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125676-Passenger_massage_program_1_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125675-Passenger_massage_program_1_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125677-Passenger_massage_program_1_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125599-ENG125664-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125599-ENG125663-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125599-ENG125665-Passenger_massage_program_1_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125667-Passenger_massage_program_1_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125600-ENG125666-Passenger_massage_program_1_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125668-Passenger_massage_program_1_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125673-Passenger_massage_program_1_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125600-ENG125672-Passenger_massage_program_1_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125674-Passenger_massage_program_1_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125670-Passenger_massage_program_1_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125600-ENG125669-Passenger_massage_program_1_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125671-Passenger_massage_program_1_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125676-Passenger_massage_program_1_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125600-ENG125675-Passenger_massage_program_1_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125677-Passenger_massage_program_1_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125600-ENG125692-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LM_MSG_Px_I,Security access required,2
ENG125600-ENG125663-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125600-ENG125665-Passenger_massage_program_1_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125667-Passenger_massage_program_2_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125666-Passenger_massage_program_2_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125668-Passenger_massage_program_2_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125673-Passenger_massage_program_2_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125672-Passenger_massage_program_2_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125674-Passenger_massage_program_2_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125670-Passenger_massage_program_2_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125669-Passenger_massage_program_2_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125671-Passenger_massage_program_2_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125676-Passenger_massage_program_2_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125675-Passenger_massage_program_2_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125677-Passenger_massage_program_2_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125601-ENG125664-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125601-ENG125663-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125601-ENG125665-Passenger_massage_program_2_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125667-Passenger_massage_program_2_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125666-Passenger_massage_program_2_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125668-Passenger_massage_program_2_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125673-Passenger_massage_program_2_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125672-Passenger_massage_program_2_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125674-Passenger_massage_program_2_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125670-Passenger_massage_program_2_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125669-Passenger_massage_program_2_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125671-Passenger_massage_program_2_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125676-Passenger_massage_program_2_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125675-Passenger_massage_program_2_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125677-Passenger_massage_program_2_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125602-ENG125664-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125602-ENG125663-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125602-ENG125665-Passenger_massage_program_2_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125667-Passenger_massage_program_2_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125666-Passenger_massage_program_2_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125668-Passenger_massage_program_2_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125673-Passenger_massage_program_2_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125672-Passenger_massage_program_2_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125674-Passenger_massage_program_2_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125670-Passenger_massage_program_2_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125669-Passenger_massage_program_2_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125671-Passenger_massage_program_2_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125676-Passenger_massage_program_2_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125675-Passenger_massage_program_2_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125677-Passenger_massage_program_2_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG125603-ENG125664-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG125603-ENG125663-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG125603-ENG125665-Passenger_massage_program_2_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125667-Passenger_massage_program_3_Intensity_1-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125666-Passenger_massage_program_3_Intensity_1-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125668-Passenger_massage_program_3_Intensity_1-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125673-Passenger_massage_program_3_Intensity_1-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125672-Passenger_massage_program_3_Intensity_1-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125674-Passenger_massage_program_3_Intensity_1-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125670-Passenger_massage_program_3_Intensity_1-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125669-Passenger_massage_program_3_Intensity_1-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125671-Passenger_massage_program_3_Intensity_1-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125676-Passenger_massage_program_3_Intensity_1-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125675-Passenger_massage_program_3_Intensity_1-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125677-Passenger_massage_program_3_Intensity_1-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG179044-ENG125664-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG179044-ENG125663-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG179044-ENG125665-Passenger_massage_program_3_Intensity_1-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125667-Passenger_massage_program_3_Intensity_2-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125666-Passenger_massage_program_3_Intensity_2-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125668-Passenger_massage_program_3_Intensity_2-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125673-Passenger_massage_program_3_Intensity_2-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125672-Passenger_massage_program_3_Intensity_2-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125674-Passenger_massage_program_3_Intensity_2-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125670-Passenger_massage_program_3_Intensity_2-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125669-Passenger_massage_program_3_Intensity_2-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125671-Passenger_massage_program_3_Intensity_2-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125676-Passenger_massage_program_3_Intensity_2-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125675-Passenger_massage_program_3_Intensity_2-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125677-Passenger_massage_program_3_Intensity_2-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG179045-ENG125664-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG179045-ENG125663-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG179045-ENG125665-Passenger_massage_program_3_Intensity_2-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125667-Passenger_massage_program_3_Intensity_3-EE_pMax_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125666-Passenger_massage_program_3_Intensity_3-EE_pMax_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125668-Passenger_massage_program_3_Intensity_3-EE_pMax_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125673-Passenger_massage_program_3_Intensity_3-EE_tEnt_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125672-Passenger_massage_program_3_Intensity_3-EE_tEnt_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125674-Passenger_massage_program_3_Intensity_3-EE_tEnt_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125670-Passenger_massage_program_3_Intensity_3-EE_tHalte_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125669-Passenger_massage_program_3_Intensity_3-EE_tHalte_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125671-Passenger_massage_program_3_Intensity_3-EE_tHalte_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125676-Passenger_massage_program_3_Intensity_3-EE_tWarte_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125675-Passenger_massage_program_3_Intensity_3-EE_tWarte_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125677-Passenger_massage_program_3_Intensity_3-EE_tWarte_LU_MSG_Px_Iy,Security access required,2
ENG179046-ENG125664-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LM_MSG_Px_Iy,Security access required,2
ENG179046-ENG125663-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LO_MSG_Px_Iy,Security access required,2
ENG179046-ENG125665-Passenger_massage_program_3_Intensity_3-EE_Upumpe_LU_MSG_Px_Iy,Security access required,2
ENG133366-ENG133471-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB1_LM,Security access required,2
ENG133366-ENG133472-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB1_LU,Security access required,2
ENG133366-ENG133473-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB1_SH,Security access required,2
ENG133366-ENG133475-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB2_LM,Security access required,2
ENG133366-ENG133474-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB2_LO,Security access required,2
ENG133366-ENG133476-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB2_LU,Security access required,2
ENG133366-ENG133477-Passenger_multi-contour_seat_Alfmeier_1-Offset_PB2_SH,Security access required,2
ENG133366-ENG133483-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV1_LM,Security access required,2
ENG133366-ENG133482-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV1_LO,Security access required,2
ENG133366-ENG133484-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV1_LU,Security access required,2
ENG133366-ENG133485-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV1_SH,Security access required,2
ENG133366-ENG133486-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV2_LO,Security access required,2
ENG133366-ENG133488-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV2_LU,Security access required,2
ENG133366-ENG133489-Passenger_multi-contour_seat_Alfmeier_1-Offset_PV2_SH,Security access required,2
ENG133366-ENG133534-Passenger_multi-contour_seat_Alfmeier_1-OffsetPB1_LO,Security access required,2
ENG133366-ENG134733-Passenger_multi-contour_seat_Alfmeier_1-OffsetPP1 3,Security access required,2
ENG133366-ENG134734-Passenger_multi-contour_seat_Alfmeier_1-OffsetPP2 4,Security access required,2
ENG133366-ENG133487-Passenger_multi-contour_seat_Alfmeier_1-OffsetPV2_LMy,Security access required,2
ENG133366-ENG133478-Passenger_multi-contour_seat_Alfmeier_1-OffsetT1,Security access required,2
ENG133366-ENG134732-Passenger_multi-contour_seat_Alfmeier_1-OffsetT2 2,Security access required,2
ENG133366-ENG133490-Passenger_multi-contour_seat_Alfmeier_1-p_function_feedback_timeout,Security access required,2
ENG133366-ENG133491-Passenger_multi-contour_seat_Alfmeier_1-p_longpush_time,Security access required,2
ENG133366-ENG133497-Passenger_multi-contour_seat_Alfmeier_1-p_stoesselSchaltschwelle_eins,Security access required,2
ENG133366-ENG133498-Passenger_multi-contour_seat_Alfmeier_1-p_stoesselSchaltschwelle_zwei,Security access required,2
ENG133366-ENG133494-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_drei,Security access required,2
ENG133366-ENG133492-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_eins,Security access required,2
ENG133366-ENG133496-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_fuenf,Security access required,2
ENG133366-ENG133495-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_vier,Security access required,2
ENG133366-ENG133493-Passenger_multi-contour_seat_Alfmeier_1-p_tasterSchaltschwelle_zwei,Security access required,2
ENG133366-ENG133458-Passenger_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Befuellen,Security access required,2
ENG133366-ENG133460-Passenger_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Druckmessung,Security access required,2
ENG133366-ENG133459-Passenger_multi-contour_seat_Alfmeier_1-s_Beruhigungszeit_Entlueften,Security access required,2
ENG133366-ENG133469-Passenger_multi-contour_seat_Alfmeier_1-s_Faktor_Druck_Entlueftung_Seitenhalt,Security access required,2
ENG133366-ENG133464-Passenger_multi-contour_seat_Alfmeier_1-s_IntervallUmgebungsbedingungen,Security access required,2
ENG133366-ENG133465-Passenger_multi-contour_seat_Alfmeier_1-s_MaxIntervall,Security access required,2
ENG133366-ENG133461-Passenger_multi-contour_seat_Alfmeier_1-s_Messdauer_Initialisierung,Security access required,2
ENG133366-ENG133462-Passenger_multi-contour_seat_Alfmeier_1-s_Messdauer_Kurzzeitmessung,Security access required,2
ENG133366-ENG133463-Passenger_multi-contour_seat_Alfmeier_1-s_Messdauer_Langzeitmessung,Security access required,2
ENG133366-ENG133468-Passenger_multi-contour_seat_Alfmeier_1-s_Sitzvariante,Security access required,2
ENG133366-ENG133467-Passenger_multi-contour_seat_Alfmeier_1-s_Timeout_Befuell_Linearbereich,Security access required,2
ENG133366-ENG133466-Passenger_multi-contour_seat_Alfmeier_1-s_Timeout_Befuell_Startbereich,Security access required,2
ENG133366-ENG133532-Passenger_multi-contour_seat_Alfmeier_1-s_Uebernahmedruck_PUe_u,Security access required,2
ENG133366-ENG133533-Passenger_multi-contour_seat_Alfmeier_1-s_UebernahmedruckP_u,Security access required,2
ENG125606-ENG125687-Passenger_pressure_correction_multi-contour_seat-s_AnzahlDruckmessungenIntervallerhoehung,Security access required,2
ENG125606-ENG125689-Passenger_pressure_correction_multi-contour_seat-s_AussendruckschwelleNachregelung,Security access required,2
ENG125606-ENG125685-Passenger_pressure_correction_multi-contour_seat-s_BasismessintervallNachregelung,Security access required,2
ENG125606-ENG125688-Passenger_pressure_correction_multi-contour_seat-s_BlasendruckschwelleNachregelung,Security access required,2
ENG125606-ENG125686-Passenger_pressure_correction_multi-contour_seat-s_ErhoehungsintervallNachregelung,Security access required,2
ENG125605-ENG126871-Passenger_pressure_values_multi-contour_seat-s_Druckschwelle_Nachlauf,Security access required,2
ENG125605-ENG126855-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_m,Security access required,2
ENG125605-ENG126854-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_o,Security access required,2
ENG125605-ENG126856-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_LRD_u,Security access required,2
ENG125605-ENG126857-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Sitzlehnenwangen,Security access required,2
ENG125605-ENG126863-Passenger_pressure_values_multi-contour_seat-s_Maximaldruck_Ueberlastschutz,Security access required,2
ENG125605-ENG126870-Passenger_pressure_values_multi-contour_seat-s_Maximaler_Differenzdruck_LRD_VorZurueck,Security access required,2
ENG125605-ENG126859-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_m,Security access required,2
ENG125605-ENG126858-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_o,Security access required,2
ENG125605-ENG126860-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_LRD_u,Security access required,2
ENG125605-ENG126864-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Massage,Security access required,2
ENG125605-ENG126869-Passenger_pressure_values_multi-contour_seat-s_Minimaldruck_Sitzlehnenwangen,Security access required,2
ENG125605-ENG125683-Passenger_pressure_values_multi-contour_seat-s_ZieldruckDerSitzlehnenwangenBeiPreCrash,Security access required,2
ENG133835-PLA_Dev_Msg,Security access required,2
ENG133834-ENG134724-PLA_New_Functions-StatusNewFunction1,Security access required,2
ENG133834-ENG134725-PLA_New_Functions-StatusNewFunction2 2,Security access required,2
ENG133834-ENG134726-PLA_New_Functions-StatusNewFunction3 3,Security access required,2
ENG133834-ENG134727-PLA_New_Functions-StatusNewFunction4 4,Security access required,2
ENG133834-ENG134728-PLA_New_Functions-StatusNewFunction5 5,Security access required,2
ENG133834-ENG134729-PLA_New_Functions-StatusNewFunction6 6,Security access required,2
ENG133834-ENG134730-PLA_New_Functions-StatusNewFunction7 7,Security access required,2
ENG133834-ENG134806-PLA_New_Functions-StatusNewFunction8 8,Security access required,2
ENG153928-PMS_CL_Adresse,Security access required,2
ENG118121-ENG100673-Rear_Lid_Assistance_Adaption-corner_boundary_offset,Security access required,2
ENG118121-ENG99594-Rear_Lid_Assistance_Adaption-monitored_area,Security access required,2
ENG118121-ENG98988-Rear_Lid_Assistance_Adaption-Timer,Security access required,2
ENG133845-ENG134759-regulator_parameter-ki_axial,Security access required,2
ENG133845-ENG134760-regulator_parameter-ki_vertical,Security access required,2
ENG133845-ENG134757-regulator_parameter-kp_axial,Security access required,2
ENG133845-ENG134758-regulator_parameter-kp_vertical,Security access required,2
ENG125614-Reset_Blower_1_Backrest_Left,Security access required,2
ENG153935-Reset_Blower_1_Backrest_Left_fond,Security access required,2
ENG125615-Reset_Blower_1_Backrest_Right,Security access required,2
ENG153936-Reset_Blower_1_Backrest_Right_fond,Security access required,2
ENG125613-Reset_Blower_1_Cushion_Left,Security access required,2
ENG153937-Reset_Blower_1_Cushion_Left_fond,Security access required,2
ENG125616-Reset_Blower_1_Cushion_Right,Security access required,2
ENG153938-Reset_Blower_1_Cushion_Right_fond,Security access required,2
ENG125623-Reset_Blower_2_Backrest_Left,Security access required,2
ENG153939-Reset_Blower_2_Backrest_Left_fond,Security access required,2
ENG125624-Reset_Blower_2_Backrest_Right,Security access required,2
ENG153940-Reset_Blower_2_Backrest_Right_fond,Security access required,2
ENG125621-Reset_Blower_2_Cushion_Left,Security access required,2
ENG153941-Reset_Blower_2_Cushion_Left_fond,Security access required,2
ENG125622-Reset_Blower_2_Cushion_Right,Security access required,2
ENG153942-Reset_Blower_2_Cushion_Right_fond,Security access required,2
ENG122927-RLS_close_glazing,Security access required,2
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,Security access required,2
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,Security access required,2
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,Security access required,2
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,Security access required,2
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,Security access required,2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,Security access required,2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,Security access required,2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,Security access required,2
ENG122929-RLS_LIN_Communication,Security access required,2
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,Security access required,2
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,Security access required,2
ENG122930-RLS_tunel_gateway_recognize,Security access required,2
ENG122935-RLS_Washer_Front,Security access required,2
ENG122926-RLS_wiper_position_parking,Security access required,2
ENG108935-Set_PLA_Activate_Brake_Function_Development,Security access required,2
ENG108937-Set_PLA_WPCA_Min_Change_Limit_Development,Security access required,2
ENG133832-sLWR_counter_left,0 ,4
ENG133833-sLWR_counter_right,0 ,4
ENG153972-SuFK_developement_massages,Security access required,4
ENG116832-ENG116697-Wischgeschwindigkeiten-Dauerwischen_Stufe 1 Zyklen_pro_ Minute,Security access required,4
ENG116832-ENG116698-Wischgeschwindigkeiten-Dauerwischen_Stufe 2 Zyklen_pro_Minute,Security access required,4
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,Security access required,4
Elapsed Time: 02:23
TTT
C?ID=547002
You have edited your Auto-Scan. You are also not verified. These are signs for using a clone. But since you've asked for a Verification, let's wait for that.
He's legit and now Verified. Moving this to Tweaks.
TTT
C?ID=547002
Maybe one of these?
AppleFarmer
Finland
C?ID=278914
Maybe one of these?
I had high hopes regarding these two before I posted here, but I couldn't even view any settings. There was a message (red font) in the stored values field but I can't remember what it said. I will check it when I get home in the evening and inform you. Thanks.
AppleFarmer
Finland
C?ID=278914
When I tried to read these two channels I got the following error (in stored values): No Response From Subnet Component
