Resolved Help - service inspection reset
Resolved
jenningsmark
C?ID=555169
I’m trying to reset my inspection service light and get the following message and it doesn’t reset.
Application error
This workshop identification:
WSC 03743 Importer 210 Equipment 65266 was rejected by the control module.
The command will probably fail.
Please change your values.
OK
jenningsmark
C?ID=555169
the car is a 2019 Audi a4 2.0tfsi 35
A bit of background ive previously changed the shop name/wsc and a few other codes because my old car wouldnt change the code for the injectors. I saw on some other forum to change those so I did that,
this is the first time i've tried using VAGCOM on this car other than an auto scan.
Monday,13,January,2025,18:13:31:50409
Dealer/Shop Name: JH Workshop
Workshop Code: 210 03743 065266
VIN: WAUZZZF47KA078071   License Plate: LP19URW
Mileage: 116175km-72187mi   Repair Order:
Chassis Type: F4-AU49 (8W5)
Scan: 01 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6C 80 A5 BB
          BC D6 D7
VIN: WAUZZZF47KA078071   Mileage: 116175km-72187miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DLVB)       Labels:. 06L-907-115-V1.clb
   Part No SW: 8W0 907 115 Q    HW: 06L 907 309 E
   Component: R4 2.0l TFSI  H31 0003
   Revision: 1HH31000    CVN: DF9CFDB6
   Coding: 0A1940130324050334082000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0118W0907115Q 001005
   ROD: EV_ECM20TFS0118W0907115Q.rod
   VCID: 47CB49EB1F21BAA2DE1-8012
   VINID: 9D196AAAA5841DB4401C80070433F096FE
17165 - Databus
          U1123 00 [00100000] - Received Error Message
2967 - Intake Manifold Flap Position Sensor (Bank 1)
          P2015 00 [01100000] - Implausible Signal
                    Mileage: 113694 km
                    Date: 2024.12.14
                    Time: 15:02:37
                    Engine RPM: 921.50 /min
                    Normed load value: 3.1 %
                    Vehicle speed: 21 km/h
                    Coolant temperature: 88 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 13.880 V
                    Unlearning counter according OBD: 32
                    Engine status: COENG_RUNNING
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 AF    HW: 8W0 907 379 J
   Component: ESP9 Plus     H16 0777
   Dataset Number: 8W0909504AA 0004 CVN: ECDA97F3
   Coding: 04AA08990CA90A9E119E4098007E5292F5D1D6201030508802004A49AF8B6B
   Shop #: WSC 06325 790 00001
   ROD: EV_ESP9BOSCHCMP_004_AU49.rod
   VCID: 094F8FD349B50CD2085-805C
415488 - TPMS Warning; Front Left Tire
          C1055 00 [00100000] - Flat
419328 - TPMS Warning; Front Right Tire
          C1057 00 [00100000] - Flat
419584 - TPMS Warning; Rear Left Tire
          C1059 00 [00100000] - Flat
419840 - TPMS Warning; Rear Right Tire
          C105B 00 [00100000] - Flat
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0251
   Dataset Number: 8W0909862D  0023
   Coding: 140900095544040D02000100080000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D15EE72E1791BA3B3-8010
   Subsystem 1 - Part No SW: 4M2 820 021 C    HW: 4M2 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000003477312
   Humidity sensor: exterior:
   Serial number: CA4011A900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
328180 - Motor for Rear Air Distribution
          B1093 31 [00001001] - No Signal
                    Reset counter: 179
                    Mileage: 97104 km
                    Date: 2024.02.02
                    Time: 16:30:57
                    Rear air distr.flap mot.:spec.val: 65535
                    System run time-Engine running time: 3 s
                    System run time-Terminal 15 on: 4 s
                    Rear air distribution flap motor: diagnosis-Last operating state: No routine started
                    Rear air distribution flap motor: diagnosis-Operating condition: No routine started
                    Voltage terminal 30: 14.11 V
                    Outside temperature: 16.50 °C
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0313
   Dataset Number: 8W0909514P  0057
   Coding: 07501143E17900CD051587141B8C80F9110B3108000000000000000020001A810A450122025605
   ASAM Dataset: EV_BCM1BOSCHAU736 019008
   ROD: EV_BCM1BOSCHAU736_019.rod
   VCID: 03539DFB6B995682429-8056
   Subsystem 1 - Part No SW: 8W2 955 119 A    HW: 567 955 119
   Component: J400FRWISCH  051 0822
   Serial number: 887253F0401902501423
   Coding: 7DC727
   Serial number: 22766295X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 24 01 2019  01834054
   Serial number: GX1CE118011923810630
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 B    HW: 4K0 947 135 B
   Component: Dachmodul  H42 0413
   Serial number: B01151330
   Coding: 0D0104
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2819000037948002
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0107
   Serial number: 003UP00S1258 Dataset Number: 8W0909602AL 0002
   Coding: AACCF0C00CA00000585400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006.rod
   VCID: 4CC176C7064759FAF33-8018
   Subsystem 1 - Part No SW: -----------    HW: 442 060 304 19
   Serial number: 3577Y00BB2D00853109X
   Subsystem 2 - Part No SW: -----------    HW: 442 060 304 19
   Serial number: 3587Y00C52D00851A05W
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 503 19
   Serial number: 3517700C7300D1B60291
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 503 19
   Serial number: 3527700C7300D1B4217%
   Subsystem 5 - Part No SW: -----------    HW: 442 0C1 803 19
   Serial number: 3557500B72FE87E2F33/
   Subsystem 6 - Part No SW: -----------    HW: 442 0C1 803 19
   Serial number: 3567500B72FE87E321C-
   Subsystem 7 - Part No SW: -----------    HW: 442 0C1 803 19
   Serial number: 2307500B72FE87E3F0D/
   Subsystem 8 - Part No SW: -----------    HW: 442 432 803 19
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00A12D4F36502EH
   Subsystem 9 - Part No SW: -----------    HW: 442 432 803 19
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00A12D4F364622B
   Part No SW: 4N0 907 129 S    HW: 4N0 907 129 S
   VCID: 41DF57F331058492105-8014
   Part No SW: 8W5 920 970 D    HW: 8W5 920 970 D
   Component: MMA4T19BENUK  H14 0612
   Revision: 0612v4.0    Serial number:    U4ICZ+14V
   Coding: 25A45090288006000120E9601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001032
   VCID: 43D35DFB2B199682029-8016
   Part No SW: 8W5 907 468 H    HW: 8W5 907 468 G
   Component: Gateway       H43 0145
   Revision: AS010003    Serial number: 038AS596219404 Dataset Number: 8W0909515L  0070
   Coding: 0201000100208640298700000059001248080007100000000175078E10000000
   GVL: 01503C0000000200408C00000002480000080000004000000000000000000000
   ASAM Dataset: EV_CGateCONTIAU491 003170
   VCID: 4EC57CCFF05B6BEA9D7-801A
   Subsystem 1 - Part No SW: 8W0 951 523 E    HW: 8W0 951 523 E
   Component: J453 MFL  H04 0004
   Serial number: 20190326071449 20638
   Subsystem 2 - Part No SW: 8W0 915 181 A    HW: 8W0 915 181 A
   Serial number: 8716860805
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   Dataset Number: 8W0909519B  0010
   VCID: 78A9FA17225F055A67B-802C
   Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
   Component: ELV-MLBevo    H05 0020
   Serial number: 19000071592003
   Coding: 0000000000000000
   ROD: EV_ELVMarqMQBA0_AU49.rod
   VCID: 34310E277EB7213A8B3-8060
   Dataset Number: 8W0909520B  0010
   Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
   Component: TSG FS        009 0130
   Serial number: 0000371030868  Dataset Number: 8W0909872G  0032
   Coding: 001F8A215001000000001002
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 4FFB61CBF75162E2961-801A
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Dataset Number: 8W0909852R  0042
   Coding: 09000380800000
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DD58FF34039F8A09F-8016
   Part No SW: 8W0 907 064 GB    HW: 8W0 907 064 DB
   Component: BCM2 MLBevo   025 0424
   Dataset Number: 8W0909501N  0057
   Coding: 012D00002FB000006309A0000400000211020010804306500F04000000040030001F0001000010
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016_AU49.rod
   VCID: 025D98FF74835F8A49F-8056
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY190701UAX
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000046943947
   Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
   Component: TSG BFS       009 0130
   Serial number: 0000361752488  Dataset Number: 8W0909873G  0032
   Coding: 001F8A215C01000000001000
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 K    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  050 0235
   Serial number:                Dataset Number: 8W0909545AF 0047
   Coding: 01940101FF0A000053111101000A00102F0001E601F00100CE
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 3E252C0F40FBFB6A6D7-806A
   Subsystem 1 - Part No SW: V03 959 802 LD    HW: -----------
   Component: ECE 2019  --- 0038
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8W2 919 604 A    HW: 8W2 919 604 A
   Component: AU49x_DU_STD  H41 0009
   Serial number: AUZ8Z9KHT0073B
   Subsystem 3 - Part No SW: 8W0 919 614 J    HW: 8W0 919 614 J
   Component: ControlUnit_B  H21 0134
   Serial number: APVAK119021900040089
   Component: RVC Compact   H15 0250
   Dataset Number: 8W0909460B  0010
   Coding: 0294010102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 33330D3B7BB92602929-8066
Address 80: Batt. reg. aux. accum. (A1)       Labels: 8W0-915-101.clb
   Part No SW: 8W0 915 101 A    HW: 8W0 915 101 A
   Component: MQ-BMS        H20 0127
   Serial number: 18000055769001
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: 313F073381A51412E05-8064
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 D    HW: 8W0 907 217 C
   Component: BVS           H18 0052
   Dataset Number: 8W0909466F  0037
   Coding: 0404090100000403024023A0A40000FC00F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_002_AU49.rod
   VCID: 3D272B034DFDE07274D-8068
   Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
   Component: TSG HFS       009 0130
   Serial number: 0000371053602  Dataset Number: 8W0909897G  0032
   Coding: 000F88200001000000001000
   ROD: EV_DCU2RearDriveMAXHCONT_VW37.rod
   VCID: 51FF67B3E1657412805-8004
   Component: TSG HBFS      009 0130
   Serial number: 0000371053531  Dataset Number: 8W0909896G  0032
   ROD: EV_DCU2RearPasseMAXHCONT_VW37.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   Dataset Number: 8W0909471C  0008
   VCID: 1675D4AF080BD32A957-8042
   Component: LED1R         H09 0003
   Dataset Number: 8W0909472C  0008
End----------(Elapsed Time: 01:55, VBatt start/end: 12.1V/12.2V)-----------
Silly question, did you have the hood ("bonnet") open when you tried to reset service reminders? If no, please try it with it open.
jenningsmark
C?ID=555169
It wasn’t a silly question as that sorted the problem. Thanks for the advice I didn’t realise it needed to be open when resetting service lights.
Much appreciated
