ESP Sensor (G419) location (B7/8E A4)
AudiNexus
C?ID=353164
Does anyone know where the ESP Sensor (G419) is located on a 2005 a4 quattro?
Sunday,12,January,2025,08:51:56:39111
VIN: WAUDG68E25A453163   License Plate:
Chassis Type: 8E (01 - My Car)
Scan: 01 02 03 08 09 15 16 17 36 45 46 55 56
VIN: WAUDG68E25A453163   Mileage: 259990km-161550miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 8E0 910 559 D    HW: 8E0 907 559 A
   Component: 3.2l V6 FSI         0050
   Revision: --H16---    Serial number:
   Coding: 01040106190F0120
   Shop #: WSC 06335 000 00000
   VCID: 2E050C9DCC1EC90AFD7-807A
   VINID: 9D19545C62150854441430460C13FE1612
Readiness: 0010 0101
   Part No SW: 8E1 910 156 B    HW: 09L 927 156
   Component: AG6 09L 3,2 FSI USA 0020
   Revision: --H01---    Serial number:        0084713
   Coding: 0000002
   VCID: 2615F4BDE4EE814A057-8072
   Part No SW: 8E0 910 517 C    HW: 8E0 614 517 BB
   Component: ESP8 quattro    H04 0180
   Coding: 0004532
   VCID: 270BF9B9E3E498423E1-8072
00493 - ESP-Sensor Unit (G419)
            001 - Upper Limit Exceeded
                    Fault Status: 01100001
                    Hex Value: 0x0000
                    Hex Value: 0x4002
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAE
                    Hex Value: 0x07FF
   Part No: 8E0 820 043 AL
   Component:   A4 Klimaautomat   2728
   Coding: 00000
   VCID: 6B83C5893A9C7C229A9-5184
   Part No: 8E0 907 279 J
   Component: int. Lastmodul  USA 0303
   Coding: 01023
   Shop #: WSC 65536
   VCID: 392F2FC100401EB2585-4B1E
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036N0004FY%
   Coding: 0032607
   VCID: 3C2136D50A622B9A433-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 02  0070
   Serial number: 6332DRB401114DA2F
   Coding: 00032607
   Subsystem 2 - Serial number: 6342DRB40135D32FQ
   Subsystem 3 - Serial number: 6352ARB4003E18C4O
   Subsystem 4 - Serial number: 6362ARB4003E125DL
   Subsystem 5 - Serial number: 63729RB4003D97F9$
   Subsystem 6 - Serial number: 63829RB4003E3FBC%
   Part No: 8E0 953 549 Q
   Component: Lenks ulenmodul     0601
   Coding: 02041
   Shop #: WSC 06335
   VCID: 41DF472168904672105-4B1E
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8E0 920 981 N    HW: 8E0 920 981 N
   Component: KOMBI+WFS 4     H12 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0021261
   Shop #: WSC 05152 444 83926
   VCID: 38292AC53E4A07BAA7B-5184
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71BFD7E1188096F2A05-4B3C
01447 - Sensor for Driver Seat; Height Adjust (G231)
            36-00 - Open Circuit
   Part No: 8E0 959 433 BT
   Component: Komfortger t T7B    3132
   Coding: 11836
   Shop #: WSC 06335
   VCID: 04518E353702935A7B3-4B1E
   Subsystem 1 - Part No: 8E1959801F
   Component: T rsteuer.FS BRM 0305
   Subsystem 2 - Part No: 8E1959802E
   Component: T rsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: T rsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: T rsteuer.HR BRM 0205
            62-10 - No or Incorrect Adjustment - Intermittent
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Coding: 0000019
   Shop #: WSC 05152 444 64193
   Subsystem 1 - Part No: 8E0 941 329
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 8E0 941 329
   Component: AFS-Modul rechtsH05 0030
   Part No: 8E0 035 195 H
   Component: symphony II PM6    0410
   Coding: 01005
   Shop #: WSC 70656
   VCID: 2C010695FF22BB1AD33-508A
End----------(Elapsed Time: 01:44, VBatt start/end: 14.0V/14.0V)-----------
AudiNexus
C?ID=353164
My research is leading me to consider that, at least for this car, the ESP sensor and Yaw rate sensor are actually the same unit which is mounted to the floor directly under the climate control head unit. Can anyone confirm this?
Jef
HQ
AudiNexus
C?ID=353164
Thanks. I have the Bentley manual, I will take a look.
Ziddywerks
Northern NJ USA
C?ID=208579
I believe it depends on the vehicle I have seen them mounted under the rear bench in some B6 vehicles.
AudiNexus
C?ID=353164
Thanks, I should have specified it's a 2005.5 B7. I've seen articles saying that too, about being under the rear bench, and others saying it's under the ashtray, and others under the radio. I will dig for it.
AudiNexus
C?ID=353164
2005 Audi A4 B7
ESP G419 Sensor location
Located directly under the climate control unit.
The sensor is not visible in the first image but the red arrow is indicating it is located forward of and below the climate control bracket.
AudiNexus
C?ID=353164
2005 Audi A4 B7
This image shows the sensor mounted to the floor, with the camera further into the dash.
AudiNexus
C?ID=353164
The center console needs to be removed in the 2005.5 A4 B7. The yellow arrow is pointing to the ESP sensor location. It also helps to have the shift lever all the way back.
The wiring harness is a nuisance. I wedged the handle of a screwdriver in from the lower left side to lift it up a bit. There's not a lot of play.
It's difficult to see in the image because the screwdriver handle is black so it's shown here outlined it in yellow.
AudiNexus
C?ID=353164
The cap nuts securing the sensor are 10 mm. I recommend using a long 10 mm flex-head ratcheting wrench for the least hassle, but a standard socket wrench will work with a lot of patience.
Also, the way the sensor sits, the wiring connector won't slide off (toward the shift lever) until you loosen the cap nuts and lift it a coupe of millimeters. The bracket it rests in gets in the way otherwise.
Jef
HQ
It is nice how the car is built around the G419... a theft protection design... one would practically have to steal the whole car to get one.
Once you do get more hands on and can test the wiring harness:
  • /2 (brown) is ground
  • /3 data to ABS /37
  • /4 data to ABS /24
  • /5 (black/brown) is power
Based past history from other customers, I suspect this will just be a bad G419, rarely come across wiring issues for no reason.
TCP
Australia
C?ID=92883
Hi,
(My first post to this forum :thumbs:)
Thank you so much for posting all this image and tips.
I've been watching your threads with great interest as I'm chasing the the same fault on my 2005 A4 B7
00493 - ESP-Sensor Unit (G419), 001 - Upper Limit Exceeded.
I've checked and monitored several things so far, my next step it to remove the interior, confirm the G419 part# and replace..... Looks like it will take a while :)
AudiNexus
C?ID=353164
Yes, it is fairly involved, but doable.
I used the Bentley Manual as the primary guide, plus a few YouTube videos when I got stuck. The parking brake handle and its plastic trim were the most annoying pieces to remove. The handle has a clip on the underside that is best released with a pic tool, and the plastic trim holds itself in place, but both require a bit of brute force and prying to remove.
Also, if your car has a cigarette lighter under the armrest, that is not mentioned in the manual, and there is zero play on the wiring underneath so you definitely want to remove it before attempting to lift out the center console.
Reactions: TCP
