ABS module failed-coding replacement (MK60EC1)
jono6974
Australia
C?ID=401581
My daughter has 2009 mk6 golf 1.4 TSI. It has developed an ABS issue.
There was no communication with the module.
It went to a mechanic who had a go and then suggested it goes to VW for further diagnosis.
This is where I stepped in .
So I scanned the car and had multiple issues. No communication with ABS module, mechatronic issues, evap valve, etc.
Anyway, I purchased another ABS unit from a breakers, have installed it, but am now stuck at the coding part:
Interesting that the gearbox was working once the new module was put in, but a day later is showing issues again.
I would like to get the ABS module working properly before looking into the mechatronic unit.
The original unit part number was: 1KO907379 AE, the unit I have installed has part number:1KO907379 BJ.
As you can see on the scan , there seems to be a lot going on.
Any help will be appreciated.
Sunday,12,January,2025,12:28:28:49636
VIN: WVWZZZ1KZ9W518244   License Plate: 1DCK 795
Mileage: 279910km-173928mi   Repair Order: N BOOST
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZ9W518244   Mileage: 279910km-173928miles
02-Auto Trans -- Status: Malfunction 1110
Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
   Part No SW: 03C 906 027 BA    HW: 03C 906 027 F
   Component: MED17.5.5       G   9660
   Revision: L1H08---    Serial number:
   Coding: 0000077
   Shop #: WSC 40951 002 1048576
   VCID: 619FA37D5D45B442305-8034
   VINID: 9E69EAAAA05BA899C5048084102C9C45CA
               U1017 - 000 -
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 21.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.065 V
049409 - No Communication with Transmission Control Module
               U0101 - 000 -
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:08:48
                    Temperature: 22.0°C
                    Temperature: 25.0°C
                    Voltage: 12.065 V
001092 - EVAP Purge Control Valve (N80)
               P0444 - 000 - Circuit Open
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:11:24
                    RPM: 460 /min
                    Load: 49.4 %
                    Temperature: 22.0°C
                    Temperature: 25.0°C
                    Voltage: 10.922 V
Readiness: 1110 0101
Address 02: Auto Trans
   Revision: 00H31001
   Shop #: WSC 00028 028 00001
   VCID: 7BA3F115D3E97E920A9-802E
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:12:36
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 195
                    Count: 51456
                    Count: 256
                    Fault Status: 01100101
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:12:37
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 279
                    Count: 51456
                    Count: 256
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:12:37
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 295
                    Count: 51456
                    Count: 256
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:12:37
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 270
                    Count: 51456
                    Count: 256
00150 - Plausibility Brake Booster System
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:12:37
                    Count: 7
                    Count: 14
                    Count: 29184
                    Count: 398
                    Count: 51456
                    Count: 256
   Part No SW: 5K0 907 044 AJ    HW: 5K0 907 044 AJ
   Component: Climatronic   130 0305
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 73B3D935FB3936D2529-8026
   Part No SW: 1K0 937 084     HW: 1K0 937 084
   Component: BCM PQ35  B   020 0358
   Revision: 00020000
   Coding: 40180A3A902518C044080080140000E441510088436D8960648000000000
   VCID: 6B83C155A389EE129A9-803E
   Component: Wischer 03030  21  0501
   Coding: 009795
   Component: RLS 090309 05  54  0402
   Coding: 0330AD
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:12:34
                    Voltage: 14.25 V
                        Term 50 Off
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    033 0604
   Serial number: 003C2D09HTDC   Dataset Number: v00300535K0 0001
   Coding: 00003134
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77ABED25EF415AF26E1-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 15760543ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 73780343ZZZZZZZZZZZZ
   Serial number: 12361872ZZZZZZZZZZZZ
   Serial number: 280F1854ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Component: J0527           055 0111
   Coding: 0001532
   VCID: 76B5E021E4CB23FA757-8022
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
00002 - Transmission Control Unit
   Part No SW: 5K0 920 870 B    HW: 5K0 920 870 B
   Component: KOMBI         H21 0030
   Coding: 170B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 2C0102496687292AD33-8078
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Steuergerät für Getriebe: keine Kommunikation]
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2025.01.12.
                    Time: 00:12:34
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 230209F1001098
   Coding: ED807F06000202000003
   VCID: 372B2D25A3419AF2AE1-8062
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.05.
                    Time: 00:12:36
   Component: IMMO          H21 0030
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2106
   Coding: 0008881
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 69     2501
   Revision: 00H15000
   VCID: 2C0102496A07292AD33-8078
   Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
   Component: Tuer-SG         008 2042
   Coding: 0000692
   VCID: 7AADF411D0D3479A11F-802E
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2I6076017
   Coding: 0500040004
   VCID: 6597B76D456DD862CCD-8030
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
   VCID: 7BA3F115DFE97E920A9-802E
End----------(Elapsed Time: 01:00, VBatt start/end: 14.3V/14.3V)-----------
You've had your VCDS for a number of years. Have you checked whether you have an scans from this car from before the old -AE ABS module expired? Check your Scans sub-folder. The coding from an -AE module just bolt right in to a -BJ with a bit if lubrication (the addition of a 00 byte at the end).
If not, please stand by. I'm confident some members here can build you a coding for it from scratch.
jono6974
Australia
C?ID=401581
Hello Uwe,
Yes, My VCDS has been used extensively on my own car.
I do have an old scan of this car.
Here is the old coding from the previous module:163B600D21230002680D06E8841D0080B100
So would i just add a 00 byte at the end and it should be good?
Once this is repaired, I can start looking at the transmission issue.
jono6974
Australia
C?ID=401581
Thank you for the help. I really appreciate it.
I have managed to get the coding put in and accepted.
I now have a longitudinal acceleration sensor adaptation fault.
I cant seem to get any joy with this, but I am guessing that I would need to drive the car for that.
I have lost communication with the transmission again, which I suspect is the mechatronic unit.
So, do I need to get the transmission working before I can finalise the brake system? If so I will tackle that first.
It seems as soon as I lose communication with the gearbox controller, a whole host of other issues crop up.
The transmission fault seems to be intermittent which is leading me to the circuitry in the mechatronic unit.
Thank you in advance
Tuesday,14,January,2025,18:40:26:49636
VIN: WVWZZZ1KZ9W518244   License Plate: 1DCK795
Mileage: 279910km-173928mi   Repair Order: jess dog car
   Coding: 0000077
                    Mileage: 279919 km
                    Date: 2019.06.07.
                    Time: 00:12:05
                    RPM: 886 /min
                    Load: 12.9 %
                    Temperature: 51.0°C
                    Temperature: 25.0°C
                    Voltage: 14.097 V
               U0101 - 000 -
                    Mileage: 279919 km
                    Date: 2019.06.07.
                    Time: 00:18:01
                    RPM: 699 /min
                    Load: 13.7 %
                    Temperature: 68.0°C
                    Temperature: 27.0°C
                    Voltage: 14.097 V
Readiness: 0110 0101
   Revision: 00H31001
   Coding: 163B600D21230002680D06E8841D0080B10000
                    Reset counter: 100
                    Mileage: 279919 km
                    Date: 2019.06.07.
                    Time: 00:25:49
                    Count: 16387
                    Count: 14
                    Count: 29184
                    Count: 212
                    Count: 50432
                    Count: 64768
                    Count: 53
                    Reset counter: 100
                    Mileage: 279919 km
                    Date: 2019.06.07.
                    Time: 00:25:49
                    Count: 16387
                    Count: 14
                    Count: 29184
                    Count: 8195
                    Count: 50432
                    Count: 64768
                    Count: 53
   Coding: 0000000000
   Revision: 00020000
   Coding: 009795
   Coding: 0330AD
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.07.
                    Time: 00:18:01
                    Voltage: 14.05 V
                        Term 50 Off
   Coding: 00003134
   Coding: 0001532
   Coding: 00000226
   Coding: 170B00
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2025.01.14.
                    Time: 00:18:00
                    Reset counter: 99
                    Mileage: 279919 km
                    Date: 2019.06.07.
                    Time: 00:18:02
   Coding: 0008881
   Revision: 00H15000
   Coding: 0000692
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:00, VBatt start/end: 14.1V/14.1V)-----------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
The lack of communication should definitely be fixed, and if you want you can do the basic settings first:
  • System voltage at least 12.0 V.
[Select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 006
[Go!]
Check field 4, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
[Security Access - 16]
Enter 40168, to enable the basic setting.
[Do it!]
[Basic Settings - 04]
Group 069
[Go!]
After a successful basic setting, field 2 should say "OK".
[Done, Go Back]
To make sure the basic setting was successful, check the sensor again.
Group 006
[Go!]
Check field 1, the value has to be between -1.5 and +1.5 m/s².
[Done, Go Back]
jono6974
Australia
C?ID=401581
[Select]
Group 006
[Go!]
[Done, Go Back]
[Do it!]
Group 069
[Go!]
[Done, Go Back]
Group 006
[Go!]
[Done, Go Back]
Thank you for the advice, this has remedied that issue. The value was sitting at -4.1m/s².
All issues now are pointing at the transmission control module ,except for a instrument message, which is in German, but this only appeared when the transmission module went into fault. I need to find some time between work and family to get stuck into that.
Thanks again for the quick and helpful responses.
jono6974
Australia
C?ID=401581
So, have been quiet as trying to remedy the other issues.
I had to replace the circuit board on the mechatronic unit. I found some broken wires on my unit, tried to solder them back on but still had no communication.
So bought one from a wrecker and it worked straight away.
The only fault now is number plate lights, the bulbs are fine, but I have no voltage at the plugs, so will do a bit of digging on this fault. A google search seems to highlight this as a fairly common issue.
Interesting, I did not need to code anything for the mechatronic. Now I need to give it a good test drive to ensure nothing else rears its head.
Thank you to all of you that helped and gave advise on these issues. The helpfulness is what makes a great forum.
Westbury, UK
Please post an updated Auto-Scan so we can see the details.
jono6974
Australia
C?ID=401581
Found the issue, was a broken wire behind the bumper.
Have everything working, but once in a while, I cant get reverse. If I turn the car off and back on it will go into reverse.
I am thinking that the mechatronic unit might need a new seal kit or replacement. Anyone else had experience with this?
