2007 2.0 TFSI Audi TT ESP Fault after ABS pump replace.
marslo
Tamworth, UK
C?ID=604595
Good morning Guys,
thank you for accepting me on the forum.
My original abs pump was temperamental, so i purchased a second hand ABS pump (with the same part number).
When my mechanic fitted the pump, he said he went through pump adaptation. All of the parameters has been adapted, except the one which is lateral sensor.
His diagnostic tool was coming up with following fault:
058F Lateral acceleration sensor
Basic setting not performed / wrong.
I have seen similar thread on this forum, however OP did not posted the solution to the issue.
the Donor pump was coming from 2006 TT 2000cc.
Does anyone of you had a similar issue, or solution to the problem ?
Thank you in advance.
Dr Sheldon
Windsor UK
C?ID=334979
There is ALWAYS a slution
Can you post a VCDS Autoscan Please ?
marslo
Tamworth, UK
C?ID=604595
Hi there. I don't have a VCDS scanner i am afraid. This adaptation has been made with Autel scanner.
Please find a picture below:
Dr Sheldon
Windsor UK
C?ID=334979
In that case I am not sure how much help I can offer - This is a forum for Legitimate VCDS owners.
And the Autel forum ?? Is there one ?
marslo
Tamworth, UK
C?ID=604595
Hi Guys, anyone here with the scanner located in Midlands UK ? Thanks
marslo
Tamworth, UK
C?ID=604595
Hi Guys, bought a cable - removed fault by getting G200 to basic settings. All working fine now.
I guess i joined the Ross Tech family for good now.
marslo
Tamworth, UK
C?ID=604595
Registered now as per youtube video :)
