Emission inspection 2002 A4 B6 1.8T
Larhal
South Yorkshire, UK
C?ID=295910
I had my MOT inspection last week and failed emissions.
The following results were logged:
Engine Speed 2500
CO 0.06 Pass
HC 6Ppm Pass
Lamda1.041 Fail (0.97-1.03)
Lamda Indicates that I am running Lean.
I have checked for leaks and found none, PCV working correctly. Very cold here now.
Any Help would be appreciated.
Monitered the followingat Idle:
   Address 01: Engine  (8E0 909 518 M)
13:48:44 Group 002: General
  760 /min  Engine Speed (G28)
  15.8 %  Engine Load
  2.04 ms  Injection Timing
  2.36 g/s  Mass Air Flow Sensor (G70)
13:48:44 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.016  Lambda Control Bank 1 (actual)
  1.000  Lambda Control Bank 1 (specified)
13:48:44 Group 032: Lambda Control (Mixture Adaptation)
  1.5 %  Adaptation (Idle) Bank 1 Sensor 1
  1.6 %  Adaptation (Partial) Bank 1 Sensor 1
Readiness Status: 0000 0000
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Secondary Air Injection: Passed
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Passed
Autoscan:
Saturday,11,January,2025,13:57:18:49418
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4658.4
Dealer/Shop Name: LarHal
VIN: WAUZZZ8E32A200477   License Plate:
Mileage: 251420km-156225mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E32A200477   Mileage: 251420km-156225miles
Address 01: Engine        Labels: 06B-906-018-AVJ.lbl
   Part No SW: 8E0 909 518 M    HW: 8E0 909 018
   Component: 1.8L R4/5VT      01 0001
   Coding: 0011501
   Shop #: WSC 00000 000 08192
   VCID: 3A2DCF2C6043897A51F-5160
   VINID: 9D196AAAA2150C24420001071CCE5BE79B
Address 03: ABS Brakes        Labels: None
   VCID: 55F77C90EC1D46025CD-51F2
No Faults Found
   Part No: 8E0 820 043
   Component:   A4 Klimaautomat   0712
   Coding: 00000
   Shop #: WSC 63351
   VCID: 5EE563BC992B855A0D7-5160
            41-10 - Blocked or No Voltage - Intermittent
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 C
   Component: int. Lastmodul  NDL 0203
   Coding: 00002
   Shop #: WSC 63351
   VCID: 323DE70CBD33713A99F-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655
   Component: Airbag 8.4E         4001
   Coding: 0010602
   Shop #: WSC 63351 000 00000
   VCID: 74B1211402A73F0A4B3-5160
   Part No: 8E0 953 549 F
   Component: Lenks ulenmodul     0308
   Coding: 00001
   Shop #: WSC 63351
   VCID: 3635DB1C515B6D1AB57-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.clb
   Part No: 8E0 920 950 G
   Component: KOMBI+WEGFAHRS. RB4 D26
   Coding: 00400
   Shop #: WSC 00260
   VCID: 2D07F470A40D2EC2C4D-5160
   WAUZZZ8E32A200477     AUZ6Z0A0309521
Address 46: Central Conv.        Labels:. 8E0-959-433-MIN.clb
   Part No: 8E0 959 433 AD
   Component: Komfortger t T85    0315
   Coding: 06848
   Shop #: WSC 63351
   VCID: 73B3220802A93832529-4B00
   Subsystem 1 - Part No: 8E2959802B
   Component: T rsteuer.FS BRM 0002
   Subsystem 2 - Part No: 8E2959801B
   Component: T rsteuer.BF BRM 0002
8 Faults Found:
01561 - Rear left door
            59-10 - Can't Unlock - Intermittent
            61-10 - Won't De-Safe - Intermittent
01562 - Rear right door
            61-00 - Won't De-Safe
00892 - Switch for Trunk Closing Cylinder (F248)
            27-00 - Implausible Signal
01559 - Drivers Door
01802 - Door Warning Lamp; Pass Side (W36)
            57-10 - Electric Circuit Failure - Intermittent
            62-10 - No or Incorrect Adjustment - Intermittent
   Part No: 8E0 035 186
   Component: concert II  GRO    0007
   Coding: 00001
   Shop #: WSC 63351
   VCID: 64915154B777AF8ADB3-4B1E
End----------(Elapsed Time: 05:50, VBatt start/end: 12.3V/12.2V)-----------
TTT
C?ID=547002
Dump some injector cleaner in the tank and go rounds.
Larhal
South Yorkshire, UK
C?ID=295910
Did that this morning and took a strong ride with several WOT. All the readings were taken after the run.
TTT
C?ID=547002
Wot is not needed, fuel will pass through injectors anyway. What are the fuel trims showing, try in obd mode? Long term and short term.
Could also be an Oxygen (Lambda) Sensor that's old and tired.
EuroX
Northern NJ USA
C?ID=208579
I don't understand why it failed. Spec vs actual is close and there is no codes. Fuel trims look to be in the norm up to 5% is normal.
I believe they do emissions inspections with an actual exhaust gas analyzer over there rather than depending on the what the car has to say via OBD.
RGH0
Australia
C?ID=433612
If its being done that way with a probe stuck up the exhaust then if you have a small exhaust joint leak or a small amount of air backflow due to the probe not being stuck in far enough or a loose joint on the probe to sensor being used then a false lean measurement is very possible and nothing to do with the car controls
EuroX
Northern NJ USA
C?ID=208579
I understand all that but why? if there is no CEL no codes, readiness is set and vehicle shows no signs of modifications why go to those lengths? Sounds like a money grab.
Larhal
South Yorkshire, UK
C?ID=295910
Sorry I am not that keen on some of the diagonistics..What is obd mode please? How can I observe, log this?
Larhal
South Yorkshire, UK
C?ID=295910
Well I know the ttester very well and he knows me also that I do all the work on my car myself. Could be an exhaust leak as I smell somerimes fumes in the car and have not been abke to find the leak. Goes for a retest tomorrow and I will advise him to insert the probe as far up the pipe as possible. I will report back after the test.
Thanks for all the input.
Dr Sheldon
Windsor UK
C?ID=334979
Here in the UK the emissions are tested at the tailpipe on Idle and Fast idle with an old school 4 Gas Analyser.
Nothing is done Diagnostically !! Although a MIL illuminated for any reason is a fail !!
That is the prescribed method of testing by the Ministry of Transport.
OH - If you have a Hybrid with a Petrol Engine (Prius for Example) then Emissions are NOT tested !!
  • Informative
RGH0
Australia
C?ID=433612
Whats the accuracy of their test system and how do they calibrate it. I doubt if its an old school 4 gas analyser it accurate to 0.01 Lamda even with top class calibration equipment
Larhal
South Yorkshire, UK
C?ID=295910
I did a long run today, 35 miles highway speeds. Retested and here are the results:
Sunday,12,January,2025,13:22:36:49418
Sunday,12,January,2025,13:23:40:49418
13:23:39 Group 002: General
  16.5 %  Engine Load
  2.31 g/s  Mass Air Flow Sensor (G70)
13:23:39 Group 031: Lambda Control (Lambda Sensor Voltages)
  1.000  Lambda Control Bank 1 (actual)
13:23:39 Group 032: Lambda Control (Mixture Adaptation)
  1.9 %  Adaptation (Idle) Bank 1 Sensor 1
  0.8 %  Adaptation (Partial) Bank 1 Sensor 1
All Looks good to me. Probably the probe wasent up far enough or there was a draft that went up one side of the exhust.
Dr Sheldon
Windsor UK
C?ID=334979
HaHA
They must be calibrated ONCE a year and then get abused for the other 364 days.
It sure is an old school thing. Once bought it can be used for testing for 15 + years.
It only needs to be accurate for CO, CO2, O2 & HC. Lambda is not a measurement, rather a calculation !
You can easily poke it into a good car on site and get a bad one to pass. Yes we are behind in some aspects.
Oh
A TPMS light is a failure but a Bulb Failure Light is not !!
Yep. Makes it easier for the inspection station to cheat, but more difficult for the car owner (via, for example, a tune/re-map that that ignores certain faults and reports all is well via OBD).
EuroX
Northern NJ USA
C?ID=208579
Yes and no, depends on knowledge. Yes most owners will no go down the rabbit hole to such lengths. However manipulating what result in a given map equal a pass result is not hard if you know where to look. Many tuners did this and probably still do this. Certain states are more strict than others.
Larhal
South Yorkshire, UK
C?ID=295910
Well it failed again. same issue Lambda inballance. Indicates it is running lean.
Options I have to resolving this?
Have looked for air leaks.
Any suggesstions,
Stii no MIL light on and no codes.
Have passed emissions for the last 10 years here.
Dr Sheldon
Windsor UK
C?ID=334979
Engine Warm - Fan kicked in and out - MVB for Upstream o2 voltage at Idle and 2000rpm.
Graph those and post here please.
