03 TT Headache
   #21
rsdubb
Las Vegas, NV, USA
C?ID=602949
Don’t put effort in that airbag for now. This is 2003 car, not 2025.
Copy that! I didnt know if that might be the module causing the communication issues. If that is for sure a non-issue, thats one thing I can cross off the list. Im digging into the wiring diagram for the power relal while battery is charging. It is in a storage unit costing me $185/mo. I need to get it out of there. I bring battery home to charge then take it back as there is no power available for a maintainer.
   #22
rsdubb
Las Vegas, NV, USA
C?ID=602949
I did not mention before that EPC light is on dash. I am really new to this discussing diagnostics in a forum. It looks like Ive turned this thread into a cluster diddle. Thank you everyone for your input!!! I am trying to get pertinent info into thread as I recall it. Thank you for your patience. The voltages I spoke of at fuse block locations 28,32,34 and 43. are only between 1-3 volts. voltage to fuel pump is the same. Fuse #28. I dont know if this is of any importance. Just seems to be off. fuel pump voltage I thought should be battery voltage at fuse 28.
   #23
rsdubb
Las Vegas, NV, USA
C?ID=602949
Wiring diagrams hurt my head lol! Does anyone want to buy an 03 TT Roadster ....cheap?
   #24
EuroX
Northern NJ USA
C?ID=208579
Are we sure multimeter is set to DC voltage? If the battery is fully charged you should have 12v on all those fuses with ignition on. Unless relays are not latching. Have you verified the strip fuses on the top of the battery are ok. This was a common issue on 1st gen audi tt's and mk4 vehicles from those years.That being said if you do indeed have 1-3volts instead of 12v I would say you have a wiring issue or corroded wire somewhere possibly with high resistance. Note fuse 28 is only powered if ecm latches both power supply relays IIRC.
   #25
rsdubb
Las Vegas, NV, USA
C?ID=602949
I am not getting that feeling that testing is done right. Testing is not parts swapping.
Where is the feed for the ecm relay coil coming from, point location, plug and terminal, where is the ground for the ecm relay coming from, point location, plug, terminal, as applicable.
Answering to the point could lead you to a faster fix.
There is a relay in engine compartment and another in footwell under dash. Both relay are working properly
Are we sure multimeter is set to DC voltage? If the battery is charged you should have 12v on all those fuses with ignition on. Unless relays are not latching. Have you verified the strip fuses on the top of the battery are ok. This was a common issue on 1st gen audi tt's and mk4 vehicles from those years.That being said if you do indeed have 1-3volts instead of 12v I would say you have a wiring issue or corroded wire somewhere possibly with high resistance. Note fuse 28 is only powered if ecm latches both power supply relays IIRC.
Yes, both relays are functioning properly. I am using an Autel PS100 power probe.Under the dash at micro central electrical panel, the blue wire is only energized w/2ish volts. It just so happens that post is what energizes the fuses I mentioned.
   #26
rsdubb
Las Vegas, NV, USA
C?ID=602949
All of the fuses at top of battery are intact as well
   #27
RGH0
Australia
C?ID=433612
The crash indicator is not a signficant problem for now as you say but it is an indicator of probably why there are so many problems. A crash and some poor repairs combined with years of wet storage and you have the type of issues seen. No easy fix but just need to work from wire to wire and module to module in a systemmatic way to eliminate the faults progressively. Start with the stuff that stops the car running
   #28
TTT
C?ID=547002
At this stage, we still cannot prove a relay ….
   #29
Dr Sheldon
Windsor UK
C?ID=334979
Then you will struggle to fix this !!
I am convinced you have not checked those relays !! further convinced you do not know how !!
Here you claim that you do !! I am not so sure !!
   #30
rsdubb
Las Vegas, NV, USA
C?ID=602949
Here is a fresh scan.
Sunday,12,January,2025,15:38:49:65378
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: TRUUT28N231019349   License Plate:
Mileage:    Repair Order: 01/12/2025
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
Address 01: Engine        Labels: 06A-906-032-BEA.clb
   Part No: 8N0 906 018 BB
   Component: 1.8L R4/5VT     G   0003
   Coding: 07710
   Shop #: WSC 01236
   VCID: 72B6A9A39DB0D7BA59F-513C
   TRUUT28N231019349     AUZ5Z0C2116115
18010 - Power Supply Terminal 30
            P1602 - 35-00 - Voltage too Low
17862 - Exhaust Gas Temp Sensor 1 (G235)
            P1454 - 35-10 - Short to Ground - Intermittent
17069 - ECM Power Relay Control Circuit
            P0685 - 35-10 - Open Circuit - Intermittent
17766 - Cylinder 2 Ignition Circuit
            P1358 - 35-10 - Open Circuit - Intermittent
16727 - Camshaft Position Sensor (G40)
            P0343 - 35-10 - Signal too High - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-A.lbl
   Part No: 8N0 907 379 H
   Component: ESP ALLRAD MK60     0101
   Coding: 0022544
   Shop #: WSC 01236 785 00200
   VCID: 41D4366FED963C22105-513C
65534 - Unknown Error Code
            015 - Cannot Be Tested at this Time - MIL ON
            003 - Mechanical Failure
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 28028BCB6BECED6A37B-2580
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
01273 - Fresh Air Blower (V2)
            17-10 - Control Difference - Intermittent
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 B
   Component: Airbag Front+Seite 6000
   Coding: 01103
   Shop #: WSC 01236
   VCID: 3FD030979E624AD2661-513C
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 980 E
   Component: KOMBI+WEGFAHRS. M73 D14
   Coding: 07244
   Shop #: WSC 26105
   VCID: 38225B8BBB4C7DEAA7B-4B00
00771 - Fuel Level Sensor (G)
00667 - Ambient Temperature Signal
01304 - Radio
            37-10 - Faulty - Intermittent
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
   VCID: 201293EB03DC152A7FB-4B00
            27-00 - Implausible Signal
            49-00 - No Communications
Address 35: Centr. Locks        Labels:. 8Nx-962-267.clb
   Part No: 8N7 962 267 F
   Component: Central Lock/Alarm  D09
   Coding: 15900
   Shop #: WSC 26105
   VCID: 43D83C67F28A2E32029-4F2E
01366 - Opened Due to Crash Signal
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
01616 - Signal Wire to Interior Monitor
            36-10 - Open Circuit - Intermittent
00955 - Key 1
            09-00 - Adaptation Limit Surpassed
01559 - Drivers Door
            58-00 - Can't Lock
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: 659CC2FF5C7E3002CCD-5184
   Part No: 4B0 035 186 H
   Component: concert II  NP2    0050
   Coding: 00202
   VCID: 251C82FF1CFEF0020CD-4E40
00857 - CD Changer Unit (R41)
End----------(Elapsed Time: 02:46, VBatt start/end: 12.3V/12.2V)-----------
TTT
C?ID=547002
What for? The ecm relay control circuit is still not right.
   #32
rsdubb
Las Vegas, NV, USA
C?ID=602949
Well isnt that special!!! I looked at fresh scan.decided to start disconecting modules that said no communication. I disconnect brake controller and it fired!! Woo hoo
   #33
rsdubb
Las Vegas, NV, USA
C?ID=602949
looks like I didnt have such a hard time after. And I do infact know how relays work. Maybe you are not seeing it quite right?
   #35
rsdubb
Las Vegas, NV, USA
C?ID=602949
Get yourself wiring diagrams and focus on ecm power relay. Learn from online videos what a relay does and how to test it and it’s associated wiring.
Thank you for your help sir!!! I appreciate you!!
   #36
TTT
C?ID=547002
I’m trying but still failing. My rule is to stick to one fault and possible that will lead to fixing all. I don’t think you’re out of the woods yet.
   #37
rsdubb
Las Vegas, NV, USA
C?ID=602949
So I cleared codes and scanned again. Here is what im left with. I have the air box out so MAF is not present among other things. I will need to sort out my brake controller issue but that is a massive portion of the haystack removed. Got alot to do but got alot done narrowing it down.
Sunday,12,January,2025,16:19:38:65378
Mileage:    Repair Order: post run
   Coding: 07710
   Shop #: WSC 01236
   VINID: 92296590221E0830400490C424D0E42CB1
18057 - Powertrain Data Bus
            P1649 - 35-00 - Missing Message from ABS Controller
   Coding: 00140
   Shop #: WSC 01236
   Coding: 01103
   Shop #: WSC 01236
   Coding: 07244
   Shop #: WSC 26105
   Coding: 15900
   Shop #: WSC 26105
            35-00 - -
            35-00 - -
            35-00 - -
00955 - Key 1
            58-00 - Can't Lock
   Coding: 00010
   Shop #: WSC 01236
   Coding: 00202
End----------(Elapsed Time: 02:52, VBatt start/end: 12.3V/12.3V)
rsdubb
Las Vegas, NV, USA
C?ID=602949
well a relay uses lower voltage to close a gate completing a circuit usually of a higher load. So if i put an ohm meter on the circuit that is being relayed and supply proper power to the slave circuit I will have continuity. Just a wild guess. You have a special way of communicating with people that is very condescending. Have a wonderful day
   #39
TTT
C?ID=547002
That ecm relay is not using a lower voltage. Just saying. It is true on hybrid and electric vehicles, but trust me, you ( I mean you) don’t get a chance to be messing with it, it is well burried.
   #40
rsdubb
Las Vegas, NV, USA
C?ID=602949
I did not look to see if the voltage going to 28,32,34 and 39 has gone up from the 2+volts it was showing before I removed ABS controller. I will check it tomorrow. I imagine it had to change and go up otherwise the fuel pump would not have primed properly to start the vehicle. Ill let you know after I check it out.
Ok I will go along with that. How about a lower amperage. Usually that is, not always. I agree. The slave circuit in this case uses running voltage. the ECM relay is buried deep? I already have the ECM out of its home in the firewall behind wiper arms. yes it was buried in there pretty good. That was my first thought. That the ECM was fried or corrupted. I will dig into the ABS module tomorrow and get that sorted. Did you happen to notice the new scan?
