Resolved VW Amarok V6 - ABS module tweaks
Resolved
   #21
Works for Caddy SA, T6, Amarok and Passat NMS with MK100 PQ
Maybe the Experts Here can Take it over to a lable File ?!
Thanks! We don't have enough official info to document that properly in VCDS but based on this I added a note with a link to this thread on the byte 15 area of the 7E0 tab here:
I did not realize that sheet could be edited. The owner of that spreadsheet may change my notes but this is the thread in our forum that the link can be found at:
   #22
sickpuppy
Norway
C?ID=180404
I'm a rookie regarding the deeper usage of VCDS, but I got curious about this lable file and if my reading and english isn't way off there is a guide I can follow to make these label files.
Would it be of any help if I did this procedure and submitted the files and a scan to the email mentioned in that guide?
If so I would gladly read the guide a couple more times to make sure I'm doing it right :)
   #23
Maps will not directly help with the coding chart and options for this 03-ABS system however they are extremely helpful in general. We made this sub-forum for those file types and when posted into a thread there they end up looking like post numbers 2 and 3 here:
Alternatively, you can run maps and send the resulting scan and files via e-mail to the Support account. Either way is fine but the community benefits the most when they are in forum.
Note, the HEX-USB+CAN interface will not generate UDS protocol Measuring Value function blockmaps. For that reason you will only have both types from the CAN controllers.
This automated process may take 20+ min so you either want a 12V battery charger connected or let the engine idle outside:
Key on -or- engine at idle​
[Applications]​
[Controller Channels Map]​
Whole Vehicle​
Function: Meas. Blocks and Adaptation​
Output: Pre-Label File​
[Start]​
At that point there will be a rather large collection of new files in the Logs folder. The Auto-Scan will backup to: C:\Ross-Tech\VCDS\Scans
