Suspension issue front - vw Touareg 7L
Jonathan1977
South Africa
C?ID=589658
Hello All
So on the way to work turning in I hear what sounded like a pipe shooting loose or something like that. When I got to the stop both my front wheels were on the bump stops.
I get the running gear fault. There shows 2 errors in the log. So I believe it could be the valve block? But Im only guessing. I need some expert advise please. Also where is the air system located on a 2005 Volkswagen Touareg 5.0L V10 TDI ?
Tuesday,07,January,2025,16:24:01:37818
VIN: WVGZZZ7LZ6D014293   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ6D014293   Mileage: 180460km-112132miles
   Part No SW: 070 906 016 AA    HW: 028 101 148 1
   Component: V10 5,0L EDCG000AGMª6189
   Coding: 0010575
   Shop #: WSC 31414 000 00000
   VCID: 4FFFA0127BC417D2961-5160
   VINID: 9E65EAAAA1DCA865000440890CEFF16FD9
18253 - Please check DTC Memory of Steering Electronics (J527)
            P1845 - 000 -
                    RPM: 651 /min
                    Torque: 150.1 Nm
                    Voltage: 13.53 V
                    Bin. Bits: 00001111
                    Bin. Bits: 00000000
                    Bin. Bits: 00001111
Readiness: 0 0 X X X
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No: 09D 927 750 BM
   Component: AL 750 6A           0592
   Coding: 0012328
   VCID: 7AA921C690C6627A11F-5160
01045 - Tiptronic Switch (F189)
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D23EADAC168954274D-5160
   Part No SW: 3D0 909 137     HW: 5WK 470 22
   Component: 05 Kessy            6700
   Revision: 67005514    Serial number: VWZ3Z0E3369500
   Coding: 0147688
   VCID: 64957FBE0242848ADB3-5160
00955 - Key 1
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77AF38F2A3D47F126E1-5160
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 L
   Component: CLIMAtronic 2+2     4018
   Subsystem 1 - Part No: 7L6 907 049 D
   Component: CLIMAtronic FOND    0400
00711 - Left Footwell Flap Positioning Motor (V108)
00445 - Loss of Refrigerant
                    Temperature: 99.0°C
                    RPM: 608 /min
                    Absolute Pres.: 6.0 bar
                    Load: 99.0 %
                    Temperature: 28.0°C
                    Temperature: 32.0°C
                    Load: 7.2 %
                    Temperature: 71.0°C
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3001
   Coding: 0111868
   VCID: 47CF883293B4CF92DE1-5160
   Part No: 3D0 909 601 E
   Component: 0B Airbag 8.4E+ H10 0951
   Coding: 0012354
   VCID: 251322BA49F83D820CD-5160
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000032
   VCID: 40DD932EB69AF8AA1FB-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 881 B
   Component: KOMBIINSTRUMENT RB8 3135
   Coding: 0007721
   Shop #: WSC 05147 996 88872
   VCID: 372FF8F2E354BF12AE1-5160
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 819 008 C
   Component: Standheizung E1MAC
   Coding: 0000030
   VCID: 3631F5F6E45E461AB57-5160
   Part No: 6N0 909 901
   Coding: 0000006
   Shop #: WSC 52110 004 104857
   VCID: 70BD03EEC6BA282AAFB-5160
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5FD0D28BE44752261-5160
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   Shop #: WSC 01657 996 62726
01400 - Suspension Level Control
02250 - Function Deactivation; Valve Duty Cycle
Address 46: Central Conv.        Labels: 7L0-959-933.clb
   Part No: 7L0 959 933 K
   Component: 34 HSG              4105
   Coding: 0000081
   VCID: 44D59F3EA282E48A3B3-4B14
   Subsystem 1 - Part No: 7L0 959 701 L
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 L
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
   Subsystem 5 - Part No: 7L0 907 719
   Subsystem 6 - Part No: 7L6 951 171
   Component: B  Innenraumsensor  0020
01830 - Bulbs for Fog-Lamps; Rear
            009 - Open or Short to Ground
Address 47: Sound System        Labels:
   VCID: 55F3527A5C086D025CD-5160
   Note: Excessive Comm Errors
Address 55: Headlight Range        Labels: 7L6-907-357.lbl
   Part No SW: 7L6 907 357     HW: 7L6 907 357
   Component: AFS-Steuergeraet    X016
   Revision:   H09       Serial number:
   Coding: 0000009
   Shop #: WSC 63354 003 1048576
   VCID: 78AD3BCEAECA706A67B-5160
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X017
   Coding: 00000034
   Subsystem 2 - Part No: 7L6 941 330
   Component: AFS-Lst.-Modul r    X018
   Coding: 00000034
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 L
   Component: Front Wiper         4027
   Coding: 0000855
   Shop #: WSC 31414 000 376832
   Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 010  1010
   Coding: 00208933
   Shop #: WSC 31414
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 392BFECAD540A962585-5160
00437 - Rear Right Inner Parking Aid Sensor (G335)
            014 - Defective
Address 77: Telephone        Labels: Redir Fail!
   Part No SW: 7L6 035 729 F    HW: 7L6 035 729 F
   Component: FSE_275x        H18 0020
   Revision: 00000001    Serial number: 00000000253650
   Coding: 0000211
02503 - Output Wire to Radio
                    Reset counter: 12
                    Time Indication: 15
End----(Elapsed Time: 09:23, VBatt start/end: 12.2V/11.9V. VIgn 11.9V)-----
Umh... so you head some "break".... have you looked at your airlines to see if they are intact and\or connected?
An air leak would be quite evident when the system fires up and it's just pumping into the atmosphere instead of raising the vehicle......
Jef
HQ
Jonathan1977
South Africa
C?ID=589658
I have raised the car to look for any loose connections, but I do not see any
Jonathan1977
South Africa
C?ID=589658
What i find quite funny is that both the front Shocks lost their air at the same time. In my opinion that means it is the solenoid block that is defective but I need to be certain as i cannot be throwing parts at this car. It can work out rather costly. Please if you can give comment out of experience, The jokes are funny but its not really when youre struggling with a problem.
Jef
HQ
Honestly, hands down the most common issue I see is leaking struts. They last 8-ish years on average. After that, weak or dead pumps is a thing we run into. Valve blocks are at the bottom of the list, we get feedback here and there, but it is an uncommon failure IMHO.
I came up with this goofy test plan years ago:
