Security access code pop up bubble not shown for Engine (Module 01) adaptation
geyungjen
Fremont, CA, USA
C?ID=606828
Dear All,
I am a new bee here. Just purchased a 3 VIN licenses VCDS USB connection this year. After install software and connect to my car, 2015 VW GTI SE Manual transmission (I bought it new in California USA, no changes have been done to the car).
Select Engine (Module 01), then select Security, place mouse cursor to the security code field, there is no pop up or bubble that should show a list of potential security code as I see someone demo on youtube. Where there is no pop up window to show codes to enter? Many Thanks.
Following are some photos about screens, links from my Google drive:
security
vin
Following is auto scan output:
Thursday,09,January,2025,11:36:40:39693
VIN: 3VW5T7AU7FM001611   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 47 52 5F 75 A9
VIN: 3VW5T7AU7FM001611   Mileage: 126417km-78551miles
Address 01: Engine (J623-CNTA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---    CVN: EAF4D4C7
   Coding: 091900122424000F1000
   Shop #: WSC 00066 790 00202
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001005
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C06DBD0768287BAD33-8078
   VINID: 0E69C59074651D67400011810492F0F4C9
15197 - Intake Manifold Flap Position Sensor (Bank 1)
          P2014 00 [00100000] - Electrical Malfunction
                    Fault Frequency: 13
                    Mileage: 126417 km
                    Date: 2024.11.15
                    Time: 23:26:39
                    Engine RPM: 0.00 /min
                    Coolant temperature: 88 ∞C
                    Intake air temperature: 22 ∞C
                    Voltage terminal 30: 11.914 V
                    Engine: operating status: ES
                    STATE_LS_SAE[1]: INI
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 102 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.978 V
                    FAC_TPS_1_SAE: 16.406250 %
                    FUP_H_SAE: 4400.0 kPa
Readiness: 0010 0101
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 50464000000163
   Coding: 01FA6BA13420096D007D020181C42980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44D69370FE126FFA3B3-8010
0297 - Steering angle sensor
          B1168 16 [00001000] - Voltage Too Low
                    Reset counter: 185
                    Mileage: 126394 km
                    Date: 2024.08.29
                    Time: 21:31:58
          C1146 02 [00001000] - Signal Failure
                    Reset counter: 185
                    Mileage: 126394 km
                    Date: 2024.08.29
                    Time: 21:32:43
   Revision: 00021000    Serial number: 0327221216 Dataset Number: V03935197ZB 0001
   Coding: 030C0C
   VCID: 3A2AED888CD6290A51F-806E
   Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   VCID: 3632F9B8B8CECD6AB57-8062
          B10CD 00 [00001000] - -
                    Fault Frequency: 14
                    Reset counter: 191
                    Mileage: 126411 km
                    Date: 2024.10.11
                    Time: 01:45:59
                    Voltage terminal 30: 11.0 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up lamp: OFF
   Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
   Component: BCM PQ37BOSCH 026 0097
   Revision: --------    Serial number: 86581902140054 Dataset Number: 5GM063v____
   Coding: 001108464041826969E44000001407201800000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 43D4906CFB1C68C2029-8016
   Component: WWS    140109  042 0581
   Serial number:         140320065008
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M01D30H06M26S20S8
   Coding: 00A8DD
   Sunroof control module:
   Subsystem 3 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO2641420-
   Coding: 181801
15882 - Bulb for Right Brake Lamp / Turn Signal
          B1334 15 [00001000] - Open or Short to Plus
                    Reset counter: 173
                    Mileage: 126394 km
                    Date: 2024.08.25
                    Time: 01:29:49
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): On
                    Status Bremslichtschalter (CAN): On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: Pin C14 Kessy Weckleitung
                    Voltage: 13.6 V
                    Outside temperature: 22.0 ∞C
18186 - Bulb for Rear Left Side Marker Lamp
          B12BC 15 [00001001] - Open or Short to Plus
                    Reset counter: 145
                    Mileage: 126413 km
                    Date: 2024.10.24
                    Time: 02:37:13
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 13.8 V
                    Outside temperature: 15.5 ∞C
          B1806 F0 [00001000] - Safety Shut-Off due to Occupant Detection
                    Reset counter: 190
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:57:04
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
                    Outside temperature: 22.5 ∞C
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00BH6C Dataset Number: 5GM003V____ 0031
   VCID: 51F8AA2431608A52805-8004
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  005 0016
   Serial number: IBH0000J140000GI660U
   Coding: 303136
   Subsystem 2 - Part No SW: -----------    HW: 480 002 501 14
   Serial number: 35700000000C5A1DBE0
   Subsystem 3 - Part No SW: -----------    HW: 480 002 711 13
   Serial number: 358000000002C1605E0D
   Subsystem 4 - Part No SW: -----------    HW: 480 402 501 14
   Serial number: 3510002C712FAE23E3EM
   Subsystem 5 - Part No SW: -----------    HW: 480 402 501 14
   Serial number: 3520002AF12FAE2141CD
   Subsystem 6 - Part No SW: -----------    HW: 480 400 201 14
   Serial number: 3550002C712FAE355328
   Subsystem 7 - Part No SW: -----------    HW: 480 400 201 14
   Serial number: 3560002C712FAE31729D
   Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 09021404220563
   Coding: 0400
   Shop #: WSC 40195 333 37120
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 79A83284C950E212185-802C
   Part No SW: 5G6 920 970 C    HW: 5G6 920 970 C
   Component: KOMBI         316 2210
   Coding: 0BAD09122180CF0502086A00000000
   VCID: 303ECFA05AAAE35AEFB-8064
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2163
   Revision: --------    Serial number: 19021410000713 Dataset Number: 5GM067v____ 1609
   Coding: 0101000820085900EF000028080F00000001000000000000000000000000
   Shop #: WSC 00066 790 00199
   GVL: 01503C1000000600400C00008000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3E22E19890FE052A6D7-806A
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27130002010210053502
   Coding: 28FFFF
   Revision: 00000000    Serial number: 14000035071002
   Coding: 5500000000000000
   VCID: 3436C3B0AEB2DF7A8B3-8060
   Serial number: 1902140605003C Dataset Number: V03935199GP 0004
   Coding: 003E13200000040000000000
   Shop #: WSC 51637 001 1048576
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 40DE9F60EA0A73DA1FB-8014
   Serial number: 00000000000001650900
   Coding: 011000
65604 - Door Warning Lamp
          B1326 01 [00001001] - Electrical Failure
                    Reset counter: 126
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:51:03
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Dataset Number: 5GM074V____ 0305
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3530FEB4A5C8C672BCD-8060
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H30 0042
   Serial number: VWZ8Z1DC400VYCX Dataset Number: 5GM050v____ 0009
   Coding: 22000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001005
   ROD: EV_AMPMst11CALPI.rod
   VCID: 639470EC5BDC08C2229-8036
0512 - Rear Right Treble Speaker
          B1068 13 [00001000] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                    Reset counter: 174
                    Mileage: 126394 km
                    Date: 2024.09.04
                    Time: 17:30:25
0517 - Rear Left Treble Speaker
          B1066 13 [00001010] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
                    Fault Frequency: 38
                    Reset counter: 191
                    Mileage: 126336 km
                    Date: 2024.02.16
                    Time: 01:35:17
   Serial number: 280114060502K1 Dataset Number: V03935199GQ 0004
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3FDC9C9C97F40C22661-806A
   Serial number: 00000000000001259490
   Coding: 191000
                    Reset counter: 133
                    Mileage: 126392 km
                    Date: 2024.08.25
                    Time: 01:24:33
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     013 0645
   Serial number: V7B00902142405 Dataset Number: 5G0CV1v____ 0001
   Coding: 027300000000000021220002001800001F0203340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 649673F05ED20FFADB3-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS5000DM
                    Reset counter: 126
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:51:06
                    Voltage terminal 30: 13.7 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Dataset Number: 561098V____ 0403
   Shop #: WSC 00066 790 00145
   ROD: EV_OCULowMQB.rod
   VCID: 025A5568A486A1CA49F-8056
9457664 - Function limitation due to excessive temperature
          B1050 00 [00001000] - -
          [restriction due to temperature rise]
                    Reset counter: 0
2103041 - Control Module
          B1788 F0 [00001001] - Start Prohibition Deactivated
                    Fault Priority: 8
                    Reset counter: 151
   Component: SAS-GEN 2     H06 0013
   Serial number: 140127200336
   VCID: 6B8418CCB30C40829A9-803E
End----------(Elapsed Time: 01:23, VBatt start/end: 14.3V/14.4V)-----------
What are you trying to accomplish with a Security Access code on this ECU?
geyungjen
Fremont, CA, USA
C?ID=606828
Hi Uwe,
Thanks for the reply.
I would like to increase idle RPM by 50 per minutes.
I see people do the same on Youtube and see there is pop up showing list of the security, but I do not see the pop up when I places mouse cursor in the security field, hence is my question. Did I miss something that needs to have the pop up showing up when connecting to a 2015 VW GTI? Thanks again.
On what car, with what engine?
I do not think there is one known for your GTI, or at least I'm not aware of one.
geyungjen
Fremont, CA, USA
C?ID=606828
Hi Uwe, Thanks for the reply and expert opinion.
My 2015 VW GTI SE manual transmission (Golf GTI MK7) has the following engine specs:
EA888 Gen 3
Engine code: CNTA
Following is an example youtube screen Engine (01)->Security Access on the Golf 7 with VCDS, the software has a pop up
I am refering to that pop up, and the VCDS version that I use the current, just installed days ago in 2025. I do not have that pop up on my screen. Following is mine:
Following is the software version I used:
                    Fault Frequency: 13
                    Mileage: 126417 km
                    Date: 2024.11.15
                    Time: 23:26:39
                    T_AST_SAE: 0 s
                    Reset counter: 185
                    Mileage: 126394 km
                    Date: 2024.08.29
                    Time: 21:31:58
                    Reset counter: 185
                    Mileage: 126394 km
                    Date: 2024.08.29
                    Time: 21:32:43
   Coding: 030C0C
   Revision: 00001K06
                    Fault Frequency: 14
                    Reset counter: 191
                    Mileage: 126411 km
                    Date: 2024.10.11
                    Time: 01:45:59
   Coding: 00A8DD
   Coding: 181801
                    Reset counter: 173
                    Mileage: 126394 km
                    Date: 2024.08.25
                    Time: 01:29:49
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 13.6 V
                    Reset counter: 145
                    Mileage: 126413 km
                    Date: 2024.10.24
                    Time: 02:37:13
                    CAN-Bus_aktiv: On
                    OFF: Not operated
                    Voltage: 13.8 V
                    Reset counter: 190
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:57:04
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.2 V
   Coding: 303136
   Coding: 0400
   Generator:
   Coding: 28FFFF
   Coding: 011000
                    Reset counter: 126
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:51:03
   Coding: 8102
                    Reset counter: 174
                    Mileage: 126394 km
                    Date: 2024.09.04
                    Time: 17:30:25
                    Fault Frequency: 38
                    Reset counter: 191
                    Mileage: 126336 km
                    Date: 2024.02.16
                    Time: 01:35:17
   Coding: 191000
                    Reset counter: 133
                    Mileage: 126392 km
                    Date: 2024.08.25
                    Time: 01:24:33
                    Reset counter: 126
                    Mileage: 126388 km
                    Date: 2024.08.14
                    Time: 21:51:06
                    Reset counter: 0
                    Fault Priority: 8
                    Reset counter: 151
NEtech
Denmark
C?ID=56995
The video is for an 1.6 diesel engine, so very different!
But you can try 20103, if that should give any access.
geyungjen
Fremont, CA, USA
C?ID=606828
Thanks, I will give it a try. Will report back status.
geyungjen
Fremont, CA, USA
C?ID=606828
Hi NEtech, 20103 was not accepted with my 2015 GTI SE (MK7), 27971 was accepted. Thanks.
marcop300
Dallas, TX, USA
C?ID=336206
are you saying increasing our idle up 50 RPM fixed the issues for the ;
Westbury, UK
I'm very sceptical that increasing idle speed will solve an electrical malfunction???
  • Agree
geyungjen
Fremont, CA, USA
C?ID=606828
Increasing idle RPM has nothing to do with P2014, which is a different issue.
