2018 Tiguan ABS coding
quartertech
C?ID=33971
Hi Guys,
I'm hoping someone could help me out with some ABS coding for this car. I could not communicate with the original module.
I purchased a used module from the junk yard. Here is a scan of the vehicle.
Thursday,09,January,2025,08:00:35:55305
VCDS Version: 24.7.1.0
Dealer/Shop Name: Advanced Auto and Diesel
VIN: 3VV1B7AX3JM071213   License Plate:
Chassis Type: AX-VW37 (3Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: 3VV1B7AX3JM071213   Mileage: 174824km-108630miles
Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 K    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H30 0004
   Revision: 1DH30000    CVN: BE3FCD76
   Coding: 012A00122424010F24000000000000000000000000000000
   Shop #: WSC 05638 005 1048576
   ASAM Dataset: EV_ECM20TFS0115NA907115K 001004
   ROD: EV_ECM20TFS0115NA907115K.rod
   VCID: 4688D37CF97FE4A6B1-8012
   VINID: 0E69814874680DA7401C10810C362B9A47
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [00101111] - -
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:13:29
                    Engine RPM: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 11.880 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
22372 - No Communication with ABS Brake Control Module
          U0121 00 [10101111] - -
                    Fault Frequency: 9
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:01
                    Coolant temperature: 16 °C
                    Intake air temperature: 1 °C
                    Voltage terminal 30: 11.600 V
                    Com st X Set1 Val1-Bits 0-7: 0
                    Com st X Set1 Val2-Bits 0-7: 0
                    Com st X Set1 Val3-Bits 0-7: 0
                    Com st X Set1 Val4-Bits 0-7: 0
                    Com st X Set1 Val5-Bits 0-7: 0
                    Com st X Set1 Val6-Bits 0-7: 0
                    Com st X Set1 Val7-Bits 0-7: 1
                    Com st X Set1 Val7-Bits 0-7: 0
7654 - Secondary Air Injection System: Bank 1
          P0491 00 [01100000] - Insufficient Flow
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:26:34
                    Engine RPM: 1113.50 /min
                    Normed load value: 45.5 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 14 °C
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 14.240 V
                    Engine status: COENG_RUNNING
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels: 09P-927-749-V1.clb
   Part No SW: 09G 927 158 DS    HW: 09G 927 158
   Component: AISIN AQ8     206 3699
   CVN: 709F86AC
   Coding: 0002000100000000000000000000000000000000
   Shop #: WSC 00066 790 00444
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 07161E78BEF53DAE8A-FFFE
7 Faults Found:
22646 - No Communications with Parking Brake Control Module
          U0128 00 [10101011] - -
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:02
                    Engine RPM: 0.0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -56 Nm
                    ATF temperature: -1 °C
                    Accelerator pedal position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
22635 - No Communication with ABS Brake Control Module
          U0121 00 [00101000] - -
                    Fault Frequency: 0
                    Reset counter: 0
22636 - No Communication with ABS Brake Control Module
22637 - No Communication with ABS Brake Control Module
22638 - No Communication with ABS Brake Control Module
22639 - No Communication with ABS Brake Control Module
26280 - No Communication with ABS Brake Control Module
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 50288000000614
   Coding: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 01383 790 50316
   VCID: 76E863BCC91F3426E1-8022
13 Faults Found:
0195 - Control module not coded
          U1013 00 [10001001] - -
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
          C1017 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
          C1079 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
0279 - Brake Pressure Sensor 1
          C107A 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
0295 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
0297 - Steering Angle Sensor
          B1168 F2 [10001001] - Not Initialized
                    Fault Frequency: 61
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
0398 - Control Module Incorrectly Coded
          U1014 00 [10001001] - -
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:06
8279 - Engine Control Module Incorrectly Coded
          P1612 00 [10001001] - -
                    Fault Frequency: 12
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
8280 - Engine Control Module Incorrectly Coded
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
8299 - Databus
                    Fault Frequency: 11
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
8306 - Databus
          U1122 00 [10001001] - Implausible Message
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:10
8308 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
                    Fault Frequency: 13
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [10001001] - Switches/Motors Detected
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:05
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-426.clb
   Part No SW: 5NN 907 426 B    HW: 5NN 907 426 B
   Component: AC Manuell el H34 4401
   Revision: 20K02000    Serial number: 00000D00062848 Dataset Number: 0000
   Coding: 00020004200110001000000000000006
   ASAM Dataset: EV_ACManuePrehVW37X 002022
   ROD: EV_ACManuePrehVW37X_002_VW37.rod
   VCID: 4FA6F658160525EE02-801A
459012 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:01
   Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 865804071900HV Dataset Number: V03935295SK 0001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0C1C2154A7935EF6A7-8058
   Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170920  034 0373
   Serial number: 17091521071140
533781 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:03
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 11.9 V
                    Outside temperature: 6.5 °C
554517 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:04
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.9 V
533525 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:04
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.9 V
533269 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:08
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.9 V
528917 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:03
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 11.9 V
   Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
   Component: AirbagVW21    004 0336
   Serial number: 003NUM06KXHP Dataset Number: V03935265ZU 0001
   Coding: 8CCCFC00000000005000001AC20800000065
   VCID: 050A147084F92FBEF8-8050
   Serial number: IBH000000000007TP9C%
   Coding: 303345
   Subsystem 2 - Part No SW: -----------    HW: 480 001 108 17
   Serial number: 357000000002C8DC862Z
   Subsystem 3 - Part No SW: -----------    HW: 480 001 108 17
   Serial number: 35800000000A322D172D
   Subsystem 4 - Part No SW: -----------    HW: 480 402 109 17
   Serial number: 3510001C3266F4B2D255
   Subsystem 5 - Part No SW: -----------    HW: 480 402 109 17
   Serial number: 3520001B7272BA95F67H
   Subsystem 6 - Part No SW: -----------    HW: 480 402 409 17
   Serial number: 3550001B1272BA95E404
   Subsystem 7 - Part No SW: -----------    HW: 480 402 409 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001B1272BA95A186
          B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
9482752 - Seat Occupied Recognition
          B10B2 00 [00001000] - Function Restriction due to Missing Message(s)
9681920 - ROD - Unknown Error Code
          - 00 [00000000]
0000 - ROD - Unknown Error Code
          - 00 [00000000]
          - 00 [00000000]
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 16081704220369
   Coding: 0410
   ROD: EV_SMLSKLOMQB_018_VW37.rod
   VCID: 02000F6C95D71886DD-8056
   Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
   Component: KOMBI         370 0310
   Coding: 0BB4090A2380CF0502082A001400000020000000
   Shop #: WSC 13581 003 1048576
   VCID: 3E78BB9CA1AFBC66F9-806A
16776967 - Databus
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:19
16776968 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:01
16776973 - Databus
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:19
16776993 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:01
   Part No SW: 3Q0 907 530 F    HW: 3Q0 907 530 B
   Component: GW MQB Mid    517 5304
   Serial number: 30091700842078 Dataset Number: V03935258SJ 0001
   Coding: 030100347F085900FA0000481C0F00010001070000000000000000000000
   Shop #: WSC 00066 790 00393
   GVL: 01503C0000000000400C00000000C80000000000000000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 32609FAC65F768060D-8066
   Generator:
   Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
   Serial number: 2431708390500706BH2B
   Coding: 280000
   Serial number: 4998765300
   Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
   Serial number: 7038728701574  Dataset Number: V03935269KM 0001
   Coding: 003003200000028000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 458AD470C479EFBEB8-8010
   Serial number: 00000000000007089839
   Coding: 011000
          B1487 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:23
   Revision: 00000000    Serial number: 0002088506 Dataset Number: V03935269NG 0001
   Coding: 01000010004000
   Shop #: WSC 00066 790 00231
   ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
   VCID: 4084C564DB5BCA968B-8014
9 Faults Found:
3158273 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:03
                    Write only channel
3158288 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:05
                    Write only channel
3161602 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:03
                    Write only channel
3161604 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:03
                    Write only channel
3161616 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:03
                    Write only channel
3161632 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:03
                    Write only channel
3161664 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:05
                    Write only channel
3161728 - Databus
                    Reset counter: 239
5262656 - Steering Angle Sensor
                    Fault Frequency: 11
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:25
                    Write only channel
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Serial number: 8038727301353  Dataset Number: V03935269KN 0001
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 448CC974CF43D6B6AF-8010
007 0002
   Serial number: 00000000000007097049
   Coding: 466F6E64204648534720505347
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      671 8395
   Serial number: 26081700020969 Dataset Number: V03935272CQ 0001
   Coding: 02230600BE00000041220001001000009F0000D40000010000
   Shop #: WSC 00066 790 00206
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 70E455A4AB7B1A163B-8024
6702 - Databus
                    Reset counter: 239
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:23:05
                    Voltage terminal 30: 11.9 V
                    Network diagnosis-Status: Enabled
          U1111 00 [00001001] - -
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:30
                    BAP-BAP_Function_ID: 00
7206 - Function Restricted due to Missing Message(s)
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.21
                    Time: 00:17:30
End-------------------------(Elapsed Time: 05:01)--------------------------
Thanks, Kevin
Jef
HQ
ST?ID=114886
Before we go digging into this, is this used ABS module the SAME part number as the original?
If the original ABS module wasn't part number 5Q0 614 517 CE, then... well... maybe this can work... maybe not.
Jef
HQ
.... and I'm going to say no, it was not a matching part number..... :banghead:
PL24 isn't pinning down what part number... but I do find the "CE" listing along with some PR-CODEs.
(before anyone comments, all ABS part numbers are grey'd out in PL24 at this time)
VL3: Extended and proactive pedestrian protection
VL5: Extended and crash-active and proactive pedestrian protection
Your VIN pulls up as VL0:
VL0: Pedestrian protection, standard
I'm not sure how this is going to pan out..... lets see what Dana or Seb have to say about this.
quartertech
C?ID=33971
The original module has part number 5Q0 614 517 CG on it.
Jef
HQ
OK, the "CG" looks legit in terms of PR codes as well as production dates.... I'm not going to say this can't work... but I suspect you should be looking for 5Q0 614 517 CG part number. I'll touch base with Dana and see what we can come up with for coding and follow up here once we have an answer to provide.
Jef
HQ
Here is what Dana and I come up with for ABS coding based on the correct part number, 5Q0 614 517 CG:
0BFA6BA454271B6DC5790201A2C649D0D62AD8A34045927000415058C2024200002764121A1C230A35351919323200
Use this coding with the currently installed 5Q0 614 517 CE at your own risk. It is possible this will all work out just fine, but we have no past experiences to offer any assurances of that. If the currently installed ABS module has issues, then our official response is going to be "get the correct ABS module".
Let us know the results.
quartertech
C?ID=33971
Thanks, I will let you know what happens. I will get approval from the customer before I do it. I may not get it back in here till Monday.
Kevin
quartertech
C?ID=33971
OK, I did it Sunday. I have to check on 2 problems, one is the parking brake and the other is the TPMS system. Here is a current scan,
Saturday,11,January,2025,09:29:34:55305
Readiness: 1110 1101
   CVN: 709F86AC
   VCID: 07161E78BEF53DAE8A-8052
   Coding: 0BFA6BA454271B6DC5790201A2C649D0D62AD8A34045927000415058C2024200002764121A1C230A35351919323200
16385 - TPMS Display
          C1146 F2 [10001001] - EEPROM Malfunction
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.24
                    Time: 22:51:27
32830 - Parking Brake Motors
          C10E1 29 [10001001] - Signal Implausible
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.24
                    Time: 22:46:20
65545 - Button(s) or Switch(es) in Operating Device
          B1312 07 [00001001] - Mechanical Failure
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.24
                    Time: 22:47:14
                    Voltage terminal 30: 13.3 V
                    Outside temperature: 16.5 °C
                    Pressing a button-Recirculating air: Not operated
                    Pressing a button-Rear window defogger: Not operated
                    Pressing a button-AC: Not operated
                    Pressing a button-Left heated seat: Not operated
                    Pressing a button-Right heated seat: Not operated
                    Pressing a button-OFF: Not operated
                    Pressing a button-Parking heater: Not operated
   Coding: 303345
   Coding: 0410
   Generator:
   Coding: 280000
   Coding: 011000
                    Reset counter: 199
                    Mileage: 174824 km
                    Date: 2024.04.24
                    Time: 22:48:39
   Coding: 091000
End-------------------------(Elapsed Time: 03:58)--------------------------
quartertech
C?ID=33971
Update, The Park brake started working when I pulled it out of the shop. I'm hoping that the TPMS light may go out when I go for a test drive.
I'm here by myself today (Sunday) and the fuel gage does not move even a 1/1000's of an inch so I'm afraid to leave the property with it and run out of gas
as I have nobody to recue me. My gas can that I keep here is empty also.
I believe the ABS module calculates tire pressure based on wheel speed correct? If so I may need to make sure the tires are aired up and drive it to establish a base line. If it don't, I'll check and see if this car has TPMS sensors and if they are "alive". I'll let you know hopefully tomorrow as I have other vehicles coming in tomorrow morning.
Kevin
I believe that is correct for the vehicle in question -- it's ABS-based "indirect" TPMs rather than "direct" TPMS from actual pressure sensors in the wheels.
quartertech
C?ID=33971
I reset the TPMS system and the TPMS light is out. It looks like that module worked out. I'll drive it some and post back with any trouble.
Thanks Jeff, You are the best,
Kevin
