change the cluster and ABS unit in MQB
rojas
Spain
C?ID=261996
Hi, I'm changing the cluster and the ABS unit, suffice to copy my coding in the new control units?
Part No 5F0920871A for 5F0920873A
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F for 5Q0907379AA 5Q0614517T
thank you
I doubt it. My guess is Component Protection will come into play here.
rojas
Spain
C?ID=261996
UWE thanks, always supporting :)
I count on the CP of cluster, I think the ABS unit does not have CP ... when once removed protection, it would be my coding valid?.
rojas: hello -sounds like a very interesting project!. I think that Uwe was referring to CP as a general matter of concern for your project, not that both ABS and the instrument cluster modules were included under VW's Component Protection constellation (love that descriptor!) - and yes, J104 is not included in the MQB constellation, but J285 is captured under CP
So when you say "I'm changing the cluster and the ABS unit, suffice to copy my coding in the new control units?", you are (of course) referring to both the coding string values and the adaptation channel settings.
The ABS unit SW:5Q0-907-379-AA that I have in my database has 45 adaptation channels. I don't have an admap for a 5F0-920-873A module, but the MQB instrument clusters that are in my database have about 220 adaptation channels. Just out of interest, I've been advised by a colleague in another forum that ABS security codes for the MQB series units are adaptation channel specific (at best, a single security code will only unlock a small number of adaption channels - but mostly it will apply to only one). Do you have access to the required suite of security codes for the ABS unit for your project? If so, I would welcome a copy please - ABS security codes for MQB units seem to be as scarce as rocking-horse-sh#t!
rojas
Spain
C?ID=261996
hello, thank you, I leave my adapmap:
	SW:5Q0-907-379-R   HW:5Q0-907-379-F ---  ABS Brakes
	Component:EMB8 EHCB     H31 0356, Coding:20EE629214210973007F060241C9240446289000608224F20061F0024009
	EV_Brake1UDSContiMK100ESP,033001,EV_Brake1UDSContiMK100ESP_SE37.rod
	Monday,07,December,2015,22:15:30:22717
	VCDS Version: Release 15.7.2 (x64)  Data version: 20151124
	VCID: 4BBB9CBDE29DAD66CE-801E
ABS in lower speed range,activated
Activating and deactivating all development messages,not active
Brake booster,4
Brake disk drying,Weak
Brake prefill,activated
Brake system vacuum pump,5
Braking torque boost for distance regulation,3
Counter steer support,Strong
Electronic Stability Program,not activated
Engine drag torque control,activated
Hill-start assistant,Early
Hill-start assistant	 increase threshold,3 %
Hydraulic brake assistant,normal
Hydraulic brake booster,8
No display,Medium
Offroad,0
Overboost in brake system,activated
Roller test bench mode,Manual activation	 possible
Roller test bench mode	 functional,not activated
Running manufacturer number,activated
(1)-Starting vibration reduction-,Strong
(2)-Starting vibration reduction-Torque limitation,Deactivated
Straight ahead brake stabilization,activated
Thresholds for brake performance,activated
Tire pressure monitoring display,2
Tire pressure monitoring display	 tire selection,2
Vehicle and trailer stabilization,not activated
XCP calibration protocol,not activated
Developer_Function_1,0
rojas
Spain
C?ID=261996
AND CLUSTER :
	SW:5F0-920-871-A   HW:5F0-920-871-A ---  Instruments
	Component:KOMBI         303 2210, Coding:07ED1280689C000800087E0E440000
	EV_DashBoardVDDMQBAB,008031,EV_DashBoardVDDMQBAB_SE37.rod
	Wednesday,18,November,2015,21:16:45:22717
	VCDS Version: Release 15.7.1 (x64)  Data version: 20150904
	VCID: 2773000D5EB5A9063C-8072
Cylinder shut-off,Display
Day,18 d
Day counter,564 d
Deactivate seat belt warning,No
Digital speedometer,Display
Display correction of consumption and operating range	 gas,100 %
Display correction of consumptions and operating range,100 %
Display depiction,Version 2
Distance,25949 km
Driving profile for range remaining LPG,8.0 l/100km
Driving profiled for range remaining,5.7 l/100km
Driving profiled for range remaining CNG,8.0 kg/100 km
ESI: distance driven from inspection,72 km
ESI: maximum value km-driving distance/inspection,30000 km
ESI: maximum value of time between inspections,730 d
ESI: minimum value km-driving distance/inspection,15000 km
ESI: minimum value of time between inspections,365 d
ESI: oil quality,good oil quality
ESI: Resetting ESI,no warning
ESI: soot entry,0 km
ESI: thermal load,0 km
ESI: time from inspection,2 d
FIX: Distance covered since last mileage-dependent inspection,25900 km
FIX: Max. distance until next mileage-related inspection,30000 km
FIX: Maximum time until next time-dependent inspection,730 d
FIX: Reset value for next mileage-dependent inspection,30000 km
FIX: Reset value for next mileage-dependent inspections,1095 d
FIX: Time since last time-dependent inspection,558 d
Hour,21 H
Ignition active message	 actuator,No display
Language version,Spanish
Lap counter,Display
(1)-MFA3-Reset-MFI button RESET / OK,Manual reset	 not possible
(2)-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
(3)-MFA3-Reset-Refuel detection gas,MFA3-Reset
(4)-MFA3-Reset-Nachtankerkennung Elektro,MFA3-Reset
Minute,16 min
Month,11 mon
No-voltage display,No display
(1)-Offset for tank calibration values-Offset sensor 1,-12.8 l
(2)-Offset for tank calibration values-Offset sensor 2,12.7 l
(3)-Offset for tank calibration values-Offset sensor 3,12.7 l
(4)-Offset for tank calibration values-Offset sensor 4,12.7 l
(5)-Offset for tank calibration values-Complete tank calibration,-12.8 l
Oil temperature display,On
Service notification in days,20 d
(1)-Service-key settings-p_write_delay_time,40 s
(2)-Service-key settings-p_write_delay_speed,20 km/h
(3)-Service-key settings-p_write_distance,20 km
(4)-Service-key settings-p_forcewrite_qual_time,10 s
(5)-Service-key settings-p_main_switch_keyless,On
(6)-Service-key settings-p_main_switch_Basic,On
(7)-Service-key settings-p_deactivate_SK_Function,On
SIA: maximum value of distance to service,15000 km
SIA: maximum value of time to service,365 d
Source for synchronization of time,internal clock
(1)-Speed warning-,not active
(2)-Speed warning-Unit,Kilometers per hour
(3)-Speed warning-Speed,120
Staging,No
Trip recorder,not installed
(1)-Units adjusted-Temperature,Degrees Celsius
(2)-Units adjusted-Distance,Kilometers
(3)-Units adjusted-Speed,Kilometers per hour
(4)-Units adjusted-Pressure,bar
(5)-Units adjusted-Volume,Liter
(6)-Units adjusted-Time,24h
(7)-Units adjusted-Date,dd_mm_yy
(8)-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
(9)-Units adjusted-Operating range consumption	 CNG (compressed natural gas),kg per 100 km
(10)-Units adjusted-Average consumption	 electric drive,kWh per 100 km
Vehicle Positioning System Interface Control Module,not installed
Year,2015 yr
(1)-Total operating range gas-State,active
(2)-Total operating range gas-selection_consumption_factor,consumption_factor_CAN
(3)-Total operating range gas-consumption_profile,consumption_profile_calculation
(4)-Total operating range gas-consumption_factor,0.000
BAP_Debug_Mode_Release,not_released
(1)-Configuration of Development CAN-Messages-Block 1,OFF
(2)-Configuration of Development CAN-Messages-Block 2,OFF
(3)-Configuration of Development CAN-Messages-Block 3,OFF
(4)-Configuration of Development CAN-Messages-Block 4,OFF
(5)-Configuration of Development CAN-Messages-Block 5,OFF
(6)-Configuration of Development CAN-Messages-Block 6,OFF
(7)-Configuration of Development CAN-Messages-Block 7,OFF
(8)-Configuration of Development CAN-Messages-Block 8,OFF
(9)-Configuration of Development CAN-Messages-Block 9,OFF
(10)-Configuration of Development CAN-Messages-Block 10,OFF
(11)-Configuration of Development CAN-Messages-Block 11,OFF
(12)-Configuration of Development CAN-Messages-Block 12,OFF
(13)-Configuration of Development CAN-Messages-Block 13,OFF
(14)-Configuration of Development CAN-Messages-Block 14,OFF
(15)-Configuration of Development CAN-Messages-Block 15,OFF
(16)-Configuration of Development CAN-Messages-Block 16,OFF
(17)-Configuration of Development CAN-Messages-Block 17,OFF
(18)-Configuration of Development CAN-Messages-Block 18,OFF
(19)-Configuration of Development CAN-Messages-Block 19,OFF
(20)-Configuration of Development CAN-Messages-Block 20,OFF
(21)-Configuration of Development CAN-Messages-Block 21,OFF
(22)-Configuration of Development CAN-Messages-Block 22,OFF
(23)-Configuration of Development CAN-Messages-Block 23,OFF
(24)-Configuration of Development CAN-Messages-Block 24,OFF
(25)-Configuration of Development CAN-Messages-Block 25,OFF
(26)-Configuration of Development CAN-Messages-Block 26,OFF
(27)-Configuration of Development CAN-Messages-Block 27,OFF
(28)-Configuration of Development CAN-Messages-Block 28,OFF
(29)-Configuration of Development CAN-Messages-Block 29,OFF
(30)-Configuration of Development CAN-Messages-Block 30,OFF
(31)-Configuration of Development CAN-Messages-Block 31,OFF
(32)-Configuration of Development CAN-Messages-Block 32,OFF
(33)-Configuration of Development CAN-Messages-Block 33,OFF
(34)-Configuration of Development CAN-Messages-Block 34,OFF
(35)-Configuration of Development CAN-Messages-Block 35,OFF
(36)-Configuration of Development CAN-Messages-Block 36,OFF
(37)-Configuration of Development CAN-Messages-Block 37,OFF
(38)-Configuration of Development CAN-Messages-Block 38,OFF
(39)-Configuration of Development CAN-Messages-Block 39,OFF
defuel_threshold,45 l
(1)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00
(2)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01
(3)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,0A
(4)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01
(5)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,64
(6)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,06
(7)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,96
(8)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,0A
(9)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,DC
(10)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,1E
(11)-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD
(12)-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,3C
(1)-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
(2)-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
(3)-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A
(4)-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
(5)-dimming_characteristic_curve_adjustment_clock_dial_day-X3,64
(6)-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
(7)-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
(8)-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05
(9)-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
(10)-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,30
(11)-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
(1)-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
(2)-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,05
(3)-dimming_characteristic_curve_adjustment_clock_dial_night-X2,06
(4)-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,05
(5)-dimming_characteristic_curve_adjustment_clock_dial_night-X3,64
(6)-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,36
(7)-dimming_characteristic_curve_adjustment_clock_dial_night-X4,96
(8)-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,44
(9)-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
(10)-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,59
(11)-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
(12)-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
(1)-dimming_characteristic_curve_adjustment_gauge-X1,00
(2)-dimming_characteristic_curve_adjustment_gauge-Y1,0F
(3)-dimming_characteristic_curve_adjustment_gauge-X2,0A
(4)-dimming_characteristic_curve_adjustment_gauge-Y2,0F
(5)-dimming_characteristic_curve_adjustment_gauge-X3,64
(6)-dimming_characteristic_curve_adjustment_gauge-Y3,50
(7)-dimming_characteristic_curve_adjustment_gauge-X4,96
(8)-dimming_characteristic_curve_adjustment_gauge-Y4,5F
(9)-dimming_characteristic_curve_adjustment_gauge-X5,DC
(10)-dimming_characteristic_curve_adjustment_gauge-Y5,64
(11)-dimming_characteristic_curve_adjustment_gauge-X6,FD
(12)-dimming_characteristic_curve_adjustment_gauge-Y6,64
(1)-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
(2)-dimming_characteristic_curve_adjustment_indicator_lights-Y1,0E
(3)-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
(4)-dimming_characteristic_curve_adjustment_indicator_lights-Y2,0E
(5)-dimming_characteristic_curve_adjustment_indicator_lights-X3,64
(6)-dimming_characteristic_curve_adjustment_indicator_lights-Y3,2D
(7)-dimming_characteristic_curve_adjustment_indicator_lights-X4,96
(8)-dimming_characteristic_curve_adjustment_indicator_lights-Y4,3E
(9)-dimming_characteristic_curve_adjustment_indicator_lights-X5,DC
(10)-dimming_characteristic_curve_adjustment_indicator_lights-Y5,57
(11)-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
(12)-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
(1)-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
(2)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
(3)-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
(4)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 2D
(5)-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
(6)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 7D
(7)-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
(8)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 C8
(9)-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
(10)-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
(1)-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
(2)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,02
(3)-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
(4)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,02
(5)-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,64
(6)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,13
(7)-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,96
(8)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,21
(9)-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
(10)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
(11)-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
(12)-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
Gas_functionality,not active
(1)-Illumination_algorithm-Scale_switching_algorithm,parking_light
(2)-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xt_bus
init_fuel_algorithm,No
(1)-outside_temperature-p_time_constant_pt1,40 s
(2)-outside_temperature-p_time_constant_slow_damping,2.0
(3)-outside_temperature-P_speed_threshold,20 km/h
(4)-outside_temperature-p_tendency_threshold,1.0 °C
(5)-outside_temperature-p_kmt_at_delta,25 °C
(6)-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
(7)-outside_temperature-p_storage_time_engine_off,180 min
(8)-outside_temperature-p_mileage_after_v_bigger_0,5.0 km
(9)-outside_temperature-p_ice_warning_exit_temperature,6 °C
(10)-outside_temperature-p_ice_warning_entry_temperature,4 °C
(11)-outside_temperature-p_tendency_damping,15 s
Picture_Upload_Download,not active
Service_Key_Clear_All_Counter,Yes
(1)-time_parameter_display-tDDWUP,0.00
(2)-time_parameter_display-tDD15_on,0.00
(3)-time_parameter_display-tDD15_off,0.60
(4)-time_parameter_display-hmi_t_Dreiter_ms,2.0
(5)-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s
(6)-time_parameter_display-hmi_t_UhrTimeout_ms,10 s
(7)-time_parameter_display-hmi_t_MenuTimeout_ms,255 s
(8)-time_parameter_display-hmi_t_TWSAnz_ms,3 s
(9)-time_parameter_display-hmi_t_NextWarning_ms,6 s
(10)-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s
(11)-time_parameter_display-hmi_t_P1Pause_ms,20 s
(12)-time_parameter_display-hmi_t_P2Pause_ms,900 s
(13)-time_parameter_display-hmi_t_Quit_ms,10 s
(14)-time_parameter_display-hmi_t_FondGurt,30 s
(15)-time_parameter_display-hmi_t_USZ,0.20 s
(16)-time_parameter_display-hmi_t_FTuerAUF,300 ms
(17)-time_parameter_display-rollierblockgroesse,3
	Monday,07,December,2015,22:16:18:22717
	VCID: 2773000D5EB5A9060A-8072
Day,7 d
Day counter,583 d
Distance,26870 km
Driving profiled for range remaining,5.6 l/100km
ESI: distance driven from inspection,993 km
ESI: soot entry,500 km
ESI: thermal load,1000 km
ESI: time from inspection,21 d
FIX: Distance covered since last mileage-dependent inspection,26800 km
FIX: Time since last time-dependent inspection,577 d
Hour,22 H
Lap counter,Display
Minute,16 min
Month,12 mon
Staging,No
Year,2015 yr
