2012 Jetta ABS module coding issue (MK60EC1)
Mwollman
Oregon, USA
C?ID=606414
Hey all first post here. Fairly new to VCDS other than using the older version on my B5 to code an ABS module. Anyways, my sister-in-law bought a 2012 Jetta and it was having some issues with the brakes. The dealer she bought it from supposedly replaced the ABS module on her car and afterwards all of her tcs and brake lights are flashing on the cluster. After running the codes I noticed that the control module wasn't coded. So far I have searched for the same hardware for her model and have tried all of the codes that I could find and continue to get coding rejected error 31. Thank you in advance for any help with this issue.
Here is the auto scan:
Wednesday,08,January,2025,18:17:18:28300
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
VIN: 3VWDP7AJ9CM349783   License Plate:
Chassis Type: AJ-VW36 (9M - VW Jetta IV (1998 > 2014))
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
VIN: 3VWDP7AJ9CM349783   Mileage: 231600km-143909miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 CJ    HW: 07K 907 309 B
   Component: 2,5l R5/4V      G01 1156
   Revision: T4H06---    Serial number:
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 78A29AF3CED5A30A67B-802C
   VINID: 0E69D480745A2537431091C80C39F0564F
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           2041
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 0052F2139605EBCA5FB-8054
   Revision: 00H31001
   VCID: 7DAC8BE7EDF7862234D-8028
03306 - Coding Not Valid
                    Reset counter: 107
                    Mileage: 231605 km
                    Date: 2063.14.31
                    Time: 17:27:23
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 4161
                    Count: 49408
                    Count: 256
                    Reset counter: 107
                    Date: 2063.14.31
                    Time: 17:40:29
                    Count: 3
                    Count: 12
                    Count: 20992
                    Count: 195
                    Count: 49920
                    Fault Status: 01100101
                    Reset counter: 107
                    Mileage: 231605 km
                    Date: 2063.14.31
                    Time: 17:24:19
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 279
                    Count: 49664
                    Count: 256
                    Reset counter: 107
                    Mileage: 231605 km
                    Date: 2063.14.31
                    Time: 17:24:19
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 295
                    Count: 49664
                    Count: 256
                    Reset counter: 107
                    Mileage: 231605 km
                    Date: 2063.14.31
                    Time: 17:24:19
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 270
                    Count: 49664
                    Count: 256
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000667245
   VCID: 6FB0A1AFBB9BE4B2B61-803A
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0251
   Revision: B2066001    Serial number: 04371302110278
   Coding: 7B994B9A08AB0B0008382000240884C500C2502E60000000300000000000
   VCID: 2F3061AF771BA4B2F61-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H09 0007
   Serial number:     WRH00033M97
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0675074
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3464
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM02NY00   Dataset Number: 160003v____ 0154
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 343A6EC39EBD876A8B3-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100008TU50+
   Coding: 303241
   Serial number: 3572MSME1F751165ZZZY
   Serial number: 3582MSME5A2C0342ZZZW
   Serial number: 3516KSME6B0E6414ZZZZ
   Serial number: 3526KSME2B176414ZZZQ
   Serial number: 3556LSME1A0C1714ZZZU
   Serial number: 3566LSME5F441B14ZZZ/
   Part No SW: 5C6 920 951 B    HW: 5C6 920 951 B
   Component: KOMBI         H04 0604
   Coding: 270201
   Shop #: WSC 00066 000 00123
   VCID: 2A0670BB4C79C19A21F-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0251
   Revision: B2066001
   Coding: 102200
   VCID: 70B2A2D3AAA5FB4AAFB-8024
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3221079
   Coding: 01000400020006
   VCID: 6398DD9F6B5350D2229-8036
                    Reset counter: 20
                    Mileage: 230994 km
                    Date: 2019.06.01.
                    Time: 07:22:06
End----------(Elapsed Time: 04:34, VBatt start/end: 13.6V/13.5V)-----------
EuroX
Northern NJ USA
C?ID=208579
Is the BL a suitable replacement for the BJ? if so I cant provide correct coding for a small fee if your in a rush. You will still need to perform basic setting afterwards.
Mwollman
Oregon, USA
C?ID=606414
I'm not familiar with this platform so that I'm not sure of. Starting to think the dealer installed the wrong module which is why I'm having issues with coding. Is the BJ the proper module for this car?
I'm guessing this was not a VW dealer?
-BL is newer than -BJ and both are H31, so I'd speculate it will work.
Mwollman
Oregon, USA
C?ID=606414
It was not a VW dealer. The dealer she got it from said that it needed to be brought to a VW dealer to be coded and that they were going to take care of it but haven't done so and it's been about a month.
I think EuroX means "I can provide correct coding........"
Boki Ar
Arandjelovac, Serbia
C?ID=57300
You can try: 114B600C49260003881206EC921C0041B70800
Or contact @EuroX, please.
Mwollman
Oregon, USA
C?ID=606414
Correct i can provide correct coding if needed.
Yes that would be great. Haven't yet tried the code Boki provided. I spent about an hour and a half scrolling through different threads trying different codes without any luck so far.
That's completely unproductive. MK60EC1 codings are VIN-specific and a coding from another car will never work in yours.
Mwollman
Oregon, USA
C?ID=606414
Lol well that's good to know... the only other time I did this I had the original coding from the original module and it was as simple as copying and pasting.
EuroX
Northern NJ USA
C?ID=208579
Keep us posted If you've made progress. Thanks
Boki Ar
C?ID=57300
@Mwollman, try 114B600C49260003881206EC921C0041B70800 or 114B400C49260003881202EC921C0041B00800
it will be accepted, and then it can be corrected as desired. Test then pay @EuroX for more accurate.
You will see the difference in some bytes.
Mwollman
Oregon, USA
C?ID=606414
Thanks all for the help. Been sick the last few days so I haven't gotten a chance to get over to the car and input the new code. Will be sure to update once it's done.
Mwollman
Oregon, USA
C?ID=606414
Coding was accepted.
All basic settings are giving me an error not available
Mwollman
Oregon, USA
C?ID=606414
The coding also resets to 0's after turning off car and starting it back up.
Mwollman
Oregon, USA
C?ID=606414
After doing more research it appear I wasn't following proper directions:facepalm: will be trying again doing it right lol.
Mwollman
Oregon, USA
C?ID=606414
Yep, I was missing the security access step lol. Everything seems to be good to go. Thank you all for the help.
