Used ecm coding 2015 sportwagen mqb tdi
Dillenher1
Cleveland, OH, USA
HUC-2H
Hello all, I installed a used ecm and need the correct path(module,login) to take to code the immobilizer to work with my car 2015 golf sportwagen tdi
Tuesday,07,January,2025,14:37:24:60137VIN: 3VWCA7AU9FM501766 License Plate: Mileage: 198628km-123421mi Repair Order: Chassis Type: AU-VW37 (5Q0)Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75VIN: 3VWCA7AU9FM501766 Mileage: 198628km-123421miles01-Engine -- Status: Malfunction 001002-Auto Trans -- Status: OK 000003-ABS Brakes -- Status: Malfunction 001005-Acc/Start Auth. -- Status: OK 000008-Auto HVAC -- Status: OK 000009-Cent. Elect. -- Status: OK 000015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: Malfunction 001019-CAN Gateway -- Status: OK 00002B-Steer. Col. Lock -- Status: OK 000042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: Malfunction 001052-Door Elect, Pass. -- Status: OK 00005F-Information Electr. -- Status: Malfunction 001075-Telematics -- Status: OK 0000-------------------------------------------------------------------------------VCDSSelf-Diagnosis LogTuesday,07,January,2025,14:37:24:60137Page 2VIN: 3VWCA7AU9FM501766 License Plate: Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb Part No SW: 04L 906 021 D HW: 04L 907 309 Component: R4 2.0l TDI H23 9283 Revision: 85H23--- CVN: 23243BB738D3FF82 Coding: 011D0012032410081000 Shop #: WSC 38600 001 1048576 ASAM Dataset: EV_ECM20TDI01104L906021D 004017 ROD: EV_ECM20TDI01104L906021D_004.rod VCID: 26122FF05869A3AA057-8072 VINID: 0E69D34474652567450011C61802C70C372 Faults Found:17158 - Databus U1123 00 [00100111] - Received Error Message Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Mileage: 198628 km Date: 2024.10.24 Time: 20:21:27 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 2 °C Intake air temperature: 2 °C Ambient air pressure: 970 mbar Voltage terminal 30: 11.960 V Unlearning counter according OBD: 40 Drivetrain coordinator: ACC fault status-Bits 0-7: 0 Drivetrain coordinator: ACC fault status-Bits 0-7: 0 Drivetrain coordinator: brake fault status-Bits 0-7: 4 Drivetrain coordinator: brake function status-Bits 0-7: 0 Drivetrain coordinator: brake function status-Bits 0-7: 0 Acceleration: 0.000 m/s²7150 - Implausible Data Received from Steering Angle Sensor Module (G85) U0428 00 [00100111] - - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 6 Fault Frequency: 1 Mileage: 198628 km Date: 2024.10.24 Time: 20:21:28 Engine RPM: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 2 °C Intake air temperature: 2 °CVCDSSelf-Diagnosis LogTuesday,07,January,2025,14:37:24:60137Page 3VIN: 3VWCA7AU9FM501766 License Plate: Ambient air pressure: 970 mbar Voltage terminal 30: 11.960 V Unlearning counter according OBD: 40 CAN status - engine control module-Bits 0-7: 0 Cruise Control System (CCS): status-Bits 0-7: 0Readiness: 0 0 0 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ Component: DQ250-6F MQB H53 4512 Revision: 05853104 Serial number: TFK01501120125 CVN: 0000FB0A Coding: 0014 Shop #: WSC 00066 790 00201 ASAM Dataset: EV_TCMDQ250021 001001 ROD: EV_TCMDQ250021.rod VCID: 231436E42B5B5682629-8076No fault code found. -------------------------------------------------------------------------------VCDSSelf-Diagnosis LogTuesday,07,January,2025,14:37:24:60137Page 4VIN: 3VWCA7AU9FM501766 License Plate: Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C Component: ESC H32 0385 Revision: 00000000 Serial number: 50075000000447 Coding: 04FA6AA12420096D007E020681C92520562490004081A4B200630050C002 Shop #: WSC 01383 790 50316 ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033 ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod VCID: 47CC8274FF235AA2DE1-80123 Faults Found:0297 - Steering angle sensor B1168 16 [10001001] - Voltage Too Low MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 90 Date: 2024.10.24 Time: 20:21:2716412 - Display for Tire Pressure Monitoring C1146 02 [10001001] - Signal Failure MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 90 Mileage: 198628 km Date: 2024.10.24 Time: 20:21:3916413 - Display for Tire Pressure Monitoring C1146 02 [10001001] - Signal Failure MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Priority: 2 Fault Frequency: 1 Reset counter: 90 Mileage: 198628 km Date: 2024.10.24 Time: 20:21:39------------------------------------------------------------------------------
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Like was mentioned above it us not possible to program this Ecu with VCDS.
I can help you with this, check your messages.
Most Vw dealer will not program used Ecu is USA for liability reasons.
2kaa52
Ceska Republica, Praha
C?ID=319193
When replacing a BCM, the immobilizer is not the only thing that needs to be done; in order to get it fully functional, the component protection also needs to be matched.
Dillenher1
Cleveland, OH, USA
HUC-2H
I thought that was only with kessy and the infotainment system
