2015 VW TDI Golf Sportwagon Manual Regen & DPF Readings
super
C?ID=172515
2015 VW TDI I'm looking to check DPF reading & possible regen but when I go to basic setting 4 & only see Service regeneration of particle filter not regen while standing? but click on Service & put in security code & nothing happens, plus I don't see meas blocks & coding ll -11 highlighted so I can't open them up?
Wednesday,08,January,2025,16:00:47:26981
VCDS Version: 24.7.1.0 (x64)
VIN: 3VWFA7AU5FM520893   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWFA7AU5FM520893   Mileage: 33091km-20561miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 C    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9282
   Revision: 85H23---    CVN: 4ACF405238D3FF82
   Coding: 01190012032410081000
   Shop #: WSC 02645 444 00000
   ASAM Dataset: EV_ECM20TDI01104L906021C 004014
   ROD: EV_ECM20TDI01104L906021C_004.rod
   VCID: 25413ADB248863BE98-8070
   VINID: 0E69D64474651567450802090C20932EE2
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 51545000000055
   Coding: 04FA6AA12422096C007F020981C62520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 479D9053FEC491AE4A-8012
   Revision: 00021000    Serial number: 0367371971 Dataset Number: V03935208L0003
   Coding: 030C0C
   VCID: 3A7BF9A7BD36FC46C5-806E
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01    Dataset Number: 0000
   Coding: 02020104202100000000000000000000
   VCID: 05015A5B844843BEF8-8050
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Revision: --------    Serial number: 86581905151951 Dataset Number: 5GM063v____ 0050
   Coding: 000108424041804169E44000000403001800000000000000000000000000
   Shop #: WSC 00066 790 00221
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4999966BE8D067DE5C-801C
   Component: WWS    150419  043 0581
   Serial number:         150619065053
   Serial number: 003GCR01TNF/ Dataset Number: 5GM003V____ 0044
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J15000309LZ0A
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 001 105 15
   Serial number: 3570000000032C9DF31U
   Subsystem 3 - Part No SW: -----------    HW: 480 000 605 15
   Serial number: 358000000003EC89141P
   Subsystem 4 - Part No SW: -----------    HW: 480 402 204 15
   Serial number: 3510002C11A87863614Z
   Subsystem 5 - Part No SW: -----------    HW: 480 402 804 15
   Serial number: 35200029D1A87873A28C
   Subsystem 6 - Part No SW: -----------    HW: 480 401 804 15
   Serial number: 3550002AF19EFF55D11X
   Subsystem 7 - Part No SW: -----------    HW: 480 401 804 15
   Serial number: 3560002AF19EFF5132CW
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150508500022
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0407475F8F727AB6EF-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA412122180CF0502086A001000000000000000
   VCID: 65C17ADB6408A3BE58-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 15051510000304 Dataset Number: 5G0067v____ 2011
   Coding: 0901000800087300EF000008080F00000001050000000000000000000000
   Shop #: WSC 00066 790 07030
   GVL: 01503C0000000600400C00008000480000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 71E91E8BA0C07F1E34-8024
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150001076830065216
   Coding: 30FFFF
   Inverter for electrical outlet:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0057955
   Revision: 00000000    Serial number: 15000110083005
   Coding: 5500000000000000
   VCID: 3467D79F9F520A361F-8060
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 01061506050CGQ Dataset Number: V03935206HY 0006
   Coding: 003013200000040000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 3E73F5B7A11ED066F9-806A
   Serial number: 00000000000001363050
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Dataset Number: 5GM074V____ 0515
   Coding: 0102
   VCID: 43858443CAFCBD8E96-8016
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 020615060502JC Dataset Number: V03935206HZ 0006
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 3D71F2BBAC18CB7EE0-8068
   Serial number: 00000000000001320248
   Coding: 091000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0655
   Serial number: V7B02004150685 Dataset Number: 5G0CV1v____ 0001
   Coding: 02730200FF00000021220001001800001F0100140100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64C767DF6F32DAB64F-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9RS501XF4
                    Reset counter: 197
                    Mileage: 33091 km
                    Date: 2025.01.08
                    Time: 16:51:29
                    Voltage terminal 30: 14.6 V
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Component: OCULowMQBUS   007 0564
   Dataset Number: 561098V____ 0409
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00322
   ROD: EV_OCULowMQB.rod
End-------------------------(Elapsed Time: 03:43)--------------------------
Dr Sheldon
Windsor UK
C?ID=334979
Nothing there to suggest a regen is required or indeed recommended !!
Are you actively looking to break your car ?
If anything, drive it as a DPF should be driven !! ie some highway driving regularly.
super
C?ID=172515
Ha no, but I want to check reading & know how to anyway
Nothing wrong with learning how & to use your diagnostic equipment
Dr Sheldon
Windsor UK
C?ID=334979
Then go do it on someone else's car. Leave yours alone !
Dr Sheldon
Windsor UK
C?ID=334979
Completely agree !! The go for it
I am just advising against it - Especially DPF related stuff !!
Perhaps the ECU will not allow a regen when it is not required !! What will be your next stunt ?
super
C?ID=172515
Like I said my post I can’t even get that far, how come measuring blocks and coding is not highlighted for me to get into then?
I’d rather screw up my car then then a customers car
Derek
UK (ilexa)
C?ID=56983
Have you posted the wrong autoscan?
That one doesn't come from 2015 Golf
Best regards
Derek
Something is fishy here.... the title would suggest a NAR vehicle, but the engine does not.... the VIN doesn't match the title of the post either....
super
C?ID=172515
Best regards
Derek
Ha Yes!
Sorry wrong autoscan
So I'm trying to learn 2 things here:
How to check my soot & ash levels
How to perform a Regen
   Coding: 030C0C
   Coding: 303138
   Coding: 0400
   Generator:
   Coding: 30FFFF
   Coding: 011000
   Coding: 0102
   Coding: 091000
                    Reset counter: 197
                    Mileage: 33091 km
                    Date: 2025.01.08
                    Time: 16:51:29
Learn how to code wrap first ;)
Then, go under engine controller and advanced measuring values and scroll\search for the IDEs that interest you to select.
Here's an example from a different vehicle as a generic idea.
                Address 01: Engine  (4G0 907 401 N)
14:22:05
  IDE00432   Particle filter: time since last regeneration 77719 s
  IDE00433   Particle filter: oil ash volume 0.04 l
  IDE00434   Particle filter: soot mass calculated 26.58 g
  IDE00435   Particle filter: soot mass measured 5.92 g
  IDE00436   Particle filter: kilometers since last regeneration 882477 m
  IDE01922   Vehicle distance driven 141876 km
  IDE03386   Long-term adaptation of reduction agent dosage 0.98
  IDE05857   DPF statistics: current measured charging rate 0.0310 g/km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 343 km
  IDE07197   Average reducing agent since lest filling 0.80 l/1000 km
Lastly, see wiki
Diesel Particle Filter Emergency Regeneration
Derek
UK (ilexa)
C?ID=56983
OK, that's a better scan :)
It looks like there are two DPF regen procedures available, but I'm absolutely not recommending you try them unless there's a good reason to
Just a reminder to never click a basic setting or adaptation unless you know exactly why you are doing it, exactly what will happen, and that there's a good reason to do it.
Some basic settings can start procedures that take time and effort to work through, and sometimes you may need special equipment to complete them or you may even make a change that cannot be reversed and you may end up needing a new module or a trip to the dealer!
As the post above says, check your advanced measured values for the DPF related values and see what the levels are
If you do ever need to do a manual regen it looks like there's an adaptation for while driving and also a basic setting that may run stationary (though I can't be sure without more data), but if the car is driven as a DPF equipped car needs to be you probably wont ever need to do them unless there's a fault
This engine controller is the later type which used advanced measured values instead of the old measuring blocks and also does not use coding11. If you are following instructions that mention using those it's for an earlier car and not right for this one
Best regards
Derek
super
C?ID=172515
Best regards
Derek
So I can check my soot & ash levels under Adv. Meas. Values then? I did enter the security codes tried both but didn't work so can't seem to find mt ash & soot levels?
I'm pretty sure it doesn't allow to click on it, it's not highlighted
Derek
UK (ilexa)
C?ID=56983
You don't need SA codes to look at live data
I recommend you spend some time with the user manual section of the website before you do too much more as you don't want to start a procedure on the car by accident
Have a look a the advanced measuring values and try typing "particulate" (no quotes) into the search box on that screen, or type the IDE numbers from the post a bit further up as your car will probably have similar ones and that should show you all you need
Best regards
Derek
super
C?ID=172515
Best regards
Derek
Ok I'll try
Thank You Derek!
Derek
UK (ilexa)
C?ID=56983
You're very welcome.
If you have any questions let us know
all the best
Derek
Your ECU should have the following measuring values:
IDE00434 -- Particle filter: soot mass calculated (g)
IDE00435 -- Particle filter: soot mass measured (g)
IDE00433 -- Particle filter: oil ash volume (l)
IDE06059 -- Particulate filter: oil ash mass (g)
IDE06060 -- Particulate filter ash load limit (g)
I agree with others here. Do not initiate a forced regen just for the heck of it. The only reason that should ever be needed is if the car doesn't regen on its own, generally due to some sensor failure, or if it is consistently driven in a manner unbecoming of a modern diesel where it never where it never has a chance to finish a regen on its own.
super
C?ID=172515
14:22:05
Lastly, see wiki
SaGVAGeSoot,
I’ve been playing around it to see my readings
Ok, so let's see what you're seeing.
