Unable to update HEX-NET ROD and ASAM data
andreag0
Italy
C?ID=251081
I update firmware with success but every time when I check the update
using java utility with pc I got "update rod data needed".
I do the update, I check again and I heve the save message then I
switch off the HEX-NET, I connect egain, I check the update and again
the message "update rod data needed".
If I do "autoscan" using android app then during scan I am getting
update ASAM data every time even if I agree for update!
It seams that something is going wrong with rod and asam update.
Someone know how to fix?
Thank you.
Santos
What version of the Java utility are you running?
What OS ?
andreag0
Italy
C?ID=251081
Java utility: HexNetConfigV2.007.jar
OS: MS Windows 8.1 Pro
andreag0
Italy
C?ID=251081
There is the same problem using android app during autoscan.
When the dialog "No ASAM data etc..." then I confirm the update but nothing huppen,
I mean there is no download from cloud server.
Santos
Can you post an autoscan from the car? Without knowing the module part number, we cannot check the server for the Asam file.
andreag0
Italy
C?ID=251081
Sunday,01,November,2015,11:51:42:18535
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWZZZAUZFP617747   License Plate:
Mileage: 17512km-10881mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFP617747   Mileage: 17512km-10881miles
Address 01: Engine (2D2D2-CXXB)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 056     HW: 04L 907 445 B
   Component: R4 1.6l TDI   H06 8983
   Revision: 22004001
   Coding: 01114032434405092000
   Shop #: WSC 00028 028 00074
   ASAM Dataset: EV_ECM16TDI03004L906056 002009
   ROD: EV_ECM16TDI03004L906056_VW37.rod
   VCID: EA9888CC0D370E6E63-80BE
Readiness: N/A
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 60845000004741
   Coding: 04FA62A124210973077E060441CA2520462490E06082A4F31440F078C009
   Shop #: WSC 00028 028 00066
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: C8DC124473FB1C7E55-809C
   Part No SW: 5G0 907 044 BC    HW: 5G0 907 044 BC
   Revision: 00001K08
   Coding: 02020104202100011005000000101000
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: E99AF7C0083105766A-80BC
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 086 AC    HW: 5Q0 937 086 AC
   Revision: --------    Serial number: 86581103151512
   Coding: 00000862C24102FB4FE44000000407281000000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   VCID: FBB6BD8872AD87E688-80AE
   Slave 1:
   Component: WWS    150309  043 0551
   Serial number:         150316142457
   Slave 2:
   Component: RLHS  037 0059
   Serial number: S4Y14M12D23H10M10S49
   Coding: 96A8DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391506504945
   Coding: 0071051001
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: BD3273902C3949D6F6-80E8
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 E    HW: 5Q0 907 567 E
   Component: ACC3          H06 0381
   Serial number: 03021276110039
   Coding: 00000300FE0309
   ASAM Dataset: EV_ACCBoschMQB 001019
   ROD: EV_ACCBoschMQB_VW37.rod
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R0H92F8
   Shop #: WSC 00028 028 00061
   VCID: C1CA0F6050C12D3692-8094
   Subsystem 1 - Part No SW: -----------    HW: 480 002 003 15
   Serial number: 35767000000F5224931Q
   Subsystem 2 - Part No SW: -----------    HW: 480 002 303 15
   Serial number: 358670000005C68C831+
   Subsystem 3 - Part No SW: -----------    HW: 480 402 003 15
   Serial number: 3516502991A14CA1939E
   Subsystem 4 - Part No SW: -----------    HW: 480 402 003 15
   Serial number: 3526502B919DB893011D
   Subsystem 5 - Part No SW: -----------    HW: 480 402 003 15
   Serial number: 3556502BD19EFD24A0C1
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150325500260
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: BA38788C3D177EEED3-80EE
   Part No SW: 5G1 920 741     HW: 5G1 920 741
   Component: KOMBI         204 4270
   Coding: 07A512002780000800883A001400000000000000
   VCID: E484E6F4EF13581E59-80B0
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   131 1204
   Revision: --------    Serial number: 0003733880
   Coding: 030100040F087300FF000258080F00010001050000000000000000000000
   Shop #: WSC 50352 001 104857
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear.rod
   VCID: F2A890AC25E7C6AEDB-80A6
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001000670125201
   Coding: 2C0000
   Serial number: 6051995803
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593 A
   Component: TSG FS        H12 0006
   Serial number: 18101200010718
   Coding: 003B0320D000040000001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: BFCE099826355BC6E4-80EA
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000008397834
   Coding: 110000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 8102
   Shop #: WSC 39823 001 1048576
   ROD: EV_SteerAssisMQB.rod
   VCID: C3C605684ADD3F2680-8096
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000112431293
   Coding: 003B0120DE00040000801000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000008328184
   Coding: 090000
   Part No SW: 5G0 035 819 A    HW: 5G0 035 819 A
   Component: MU-S--ER      041 0421
   Serial number: V1C02603153215
   Coding: 02730200FF00000011110001000800001F0100840100010001
   ROD: EV_MUStd4CPASE_SK37.rod
   VCID: A71EB1F8DEA5F306BC-80F2
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605     HW: 5G0 919 605
   Component: ABT_Std_Radio  H60 0030
   Serial number: VWZ8Z9RS2081L4
End-------------------------(Elapsed Time: 01:51)--------------------------
Gizmo
S.E.Kent UK
C?ID=49193
Thank you.
I am getting exactly the same issues as above apart from I am using HEX-NET on an iPad
#hndoc:?docid=000013DB&xt=hnh:E74F21D4D694445A389C922AA5306652400C4BDAA76F46B5B8D2C07CE7BEDE64VCDS Mobile 0.4231.0.4
VIN: TMBBJ9NP9G7029918
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 3C 42 44 52 55
     5F 6C 6D A5
Address 01: Engine  (DFCA2 J623)    Labels: 04-01.lbl
    Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
    Component: R4 2,0L EDC   H23 1195
    Revision: B4H23---
    Coding: 011D0032036501083000
    Shop #: WSC 33361 790 00063
    ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
    ROD: N/A
    VCID: 7BB964EF62E4E8BFF6C1CB-802E
    No ASAM data for: "EV_ECM20TDI01104L906026FN"
No fault codes found.
Address 02: Auto Trans  (J743)    Labels: 0D-02.lbl
    Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
    Component: DQ250-6F MQB  H53 4803
    Revision: 06253104
    ROD: N/A
    VCID: 1771585F7E8C2CDF72F987-8042
    No ASAM data for: "EV_TCMDQ250021"
Address 03: ABS Brakes  (J104)    Labels: None
    Revision: 00000000
    Coding: 1D07929C34220B750780060141CB49B8492CD0E0608292F53861F0F8C2A90000000000000000000000000000000000000000000000000000000000000000000000
    ROD: N/A
    VCID: 7AB761EB6DDED1B7EDD7C6-802F
    No ASAM data for: "EV_Brake1UDSContiMK100IPB"
Address 05: Acc/Start Auth.  (J518)    Labels: None
    Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
    Component: VWKESSYMQB    036 0710
    Revision: 00036000
    Coding: 030C0C0703
    ROD: N/A
    VCID: 3A37A1EB2D5E11B7AD5706-806F
    No ASAM data for: "EV_KessyHellaMQBAB"
    Subsystem 1 -
1077250 - ROD - Unknown faultcode
Address 08: Auto HVAC  (E87)    Labels: None
    Part No SW: 3V0 907 044 AN    HW: 3V0 907 044 AN
    Component: AC Automat    H32 3601
    Revision: 20K04000
    Coding: 11110104000400011005100100101102
    ASAM Dataset: EV_ACClimaPrehVW37X 002009
    ROD: N/A
    VCID: 804393038B020B67231304-80D5
    No ASAM data for: "EV_ACClimaPrehVW37X"
000515 - ROD - Unknown faultcode
Address 09: Cent. Elect.  (J519)    Labels: 5Q-09.lbl
    Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
    Coding: 0F019E66C2C72AFB17844086B118172C0800000000000000000000000000
    ROD: N/A
    VCID: 89558E27B8384A2F744D61-80DC
    No ASAM data for: "EV_BCMMQB"
    Subsystem 1 -     Part No SW: 3V2-955-119
    Component: ]�
    Subsystem 2 -
    Subsystem 3 -
    Subsystem 4 -
    Subsystem 5 -     Component: ]Ý
    Subsystem 6 -
    Subsystem 7 -
Address 10: Park/Steer Assist  (J791)    Labels: None
    Part No SW: 5QA 919 298    HW: 5Q0 919 298 C
    Component: PLA 3.0 12K
    Coding: 0371167851
    ASAM Dataset: EV_EPHVA2CAU3700000 009017
    ROD: N/A
    VCID: 0D5D3A374C50D60FD89515-8058
    No ASAM data for: "EV_EPHVA2CAU3700000"
Address 13: Auto Dist. Reg  (J428)    Labels: None
    Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
    Coding: 320067C355FFC428949C804D
    ROD: N/A
    VCID: 342B8FD30F3AE7C7771BB8-8061
    No ASAM data for: "EV_ACCBOSCHVW48X"
000110 - ROD - Unknown faultcode
Address 14: Susp. Elect.  (J250)    Labels: 5Q0-907-376.clb
    Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
    Component: DAEMPFUNGS-SG H17 0120
    Shop #: WSC 00000 000
    ROD: N/A
    VCID: 3731B8DF1E4C0CDF5239E7-8062
    No ASAM data for: "EV_DRCONTITEMIC"
    Part No SW: 5Q0 959 655 AE    HW: 5Q0 959 655 AE
    Component: AirbagVW21    005 0130
    Coding: 98FCC0C0000000005C5400CF00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
    ROD: N/A
    VCID: 83499C0F9A14107F3E3123-80D6
    No ASAM data for: "EV_AirbaVW20SMEVW37X"
    Subsystem 1 -     Part No SW: 4M0-980-945-A
    Component: €
    Subsystem 2 -     Component: €
    Subsystem 3 -     Component: ---
    Subsystem 4 -     Component: ---
    Subsystem 5 -     Component: ---
    Subsystem 6 -     Component: ---
Address 16: Steering wheel  (J524)    Labels: None
    Part No SW: 3Q0 953 521 BA    HW: 5Q0 953 569 A
    Component: Lenks.Modul   075 0195
    Revision: FF033033
    Coding: 6010
    ROD: N/A
    VCID: 70A343C33BA29BE7537354-8025
    No ASAM data for: "EV_SMLSVALEOMQB"
Address 17: Instruments  (J285)    Labels: None
    Part No SW: 3V0 920 911    HW: 3V0 920 911
    Component: KOMBI         305 6422
    Coding: 27A5011A7F80A600018B6A0B5001000000000000
    Shop #: WSC 73430 031 00063
    ROD: N/A
    VCID: EFA1C0BFA69C041FCA49CF-80BA
    No ASAM data for: "EV_DashBoardVDDMQBAB"
Address 19: CAN Gateway  (J533)    Labels: None
    Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
    Component: GW MQB High   212 2227
    Revision: --------
    Coding: 030100044F087300EB00025E9C0F00010001070000000000000000000000
    Shop #: WSC 73430 790 00063
    ROD: N/A
    VCID: 75AD72D744C0BECF80858D-8020
    No ASAM data for: "EV_GatewConti"
    Subsystem 1 -
    Subsystem 2 -
    Subsystem 3 -
Address 2B: Steer. Col. Lock  (J764)    Labels: None
    Part No SW: 3Q0 905 861    HW: 3Q0 905 861
    Coding: 0800000000000000
    ROD: N/A
    VCID: F1A5C6C7B0A812EFDC7DD9-80A4
    No ASAM data for: "EV_ELVMarquMQBB"
Address 36: Seat Mem. Drvr  (J810)    Labels: None
    Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
    Component: Sitzmemory    H06 0009
    Coding: 001400000000010001A080808080000000008181000000D4
    ASAM Dataset: EV_SeatMemorDriveSide 001015
    ROD: N/A
    VCID: 3B39A4EF226428BFB6410B-806E
    No ASAM data for: "EV_SeatMemorDriveSide"
Address 3C: Lane Change  (J1086)    Labels: None
    Component: HRE_Master    H11 0071
    Coding: 02011203
    ROD: N/A
    VCID: 3C3BA7F3276A2F87BF4B10-8069
    No ASAM data for: "EV_HREntryHella"
Address 42: Door Elect, Driver  (J386)    Labels: 5Q-42.lbl
    Coding: 001D0820DE01048000001100
    ROD: N/A
    VCID: 43C9DC0F5A94507FFEB163-8016
    No ASAM data for: "EV_DCUDriveSideEWMAXKLO"
    Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
    Component: EPS_MQB_ZFLS  125 1063
    Coding: 9303
    VCID: 44CBDF135F9A5747C7BB68-8011
Address 52: Door Elect, Pass.  (J387)    Labels: 5Q-52.lbl
    Coding: 001D0220DE01048000001100
    ROD: N/A
    VCID: 42C7D90B458E5977F5875E-8017
    No ASAM data for: "EV_DCUPasseSideEWMAXKLO"
Address 55: Xenon Range  (J745)    Labels: 7P6-907-357.clb
    Revision: --------
    Coding: 06D602007F010000
    ROD: N/A
    VCID: 40C3D3034B824B67E39344-8015
    No ASAM data for: "EV_HeadlRegulVWAFSMQB"
    Subsystem 1 -     Part No SW: 4H0-941-329
    Component: ³
    Part No SW: 3V0 035 020 A    HW: 3V0 035 020
    Component: MU-H-ND-EU    H42 0318
    Coding: 038401010000000011111202008808002F0003E601200100DE
    ROD: N/A
    VCID: 240B7F93BFDA7747E77B08-8071
    No ASAM data for: "EV_MUHig4CGen2HBAS"
    Subsystem 1 -
    Subsystem 2 -
    Subsystem 3 -
    Subsystem 4 -
    Subsystem 5 -
    Subsystem 6 -
    Subsystem 7 -
    Subsystem 8 -
    Subsystem 9 -
    Subsystem 10 -
    Subsystem 11 -
    Subsystem 12 -
    Subsystem 13 -
    Subsystem 14 -
Address 6C: Back-up Cam.  (J772)    Labels: None
    Part No SW: 5Q0 980 556    HW: 5Q0 980 556
    Component: RVC Compact   H07 0100
    Coding: 04840101A600201F000040
    ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
    ROD: N/A
    VCID: F7B1F8DFDECC4CDF12B927-80A2
    No ASAM data for: "EV_CamSysRVRVCPANAMQBAB"
Address 6D: Trunk Elect.  (J605)    Labels: None
    Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
    Component: HDSG-Modul    H12 0250
    Revision: --------
    Coding: 1008
    ASAM Dataset: EV_DeckLidCONTIAU736 001011
    ROD: N/A
    No ASAM data for: "EV_DeckLidCONTIAU736"
Address A5: Frt Sens. Drv. Assist  (R242)    Labels: None
    Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
    Component: MQB_B_MFK     H04 0024
    Coding: 020408010000040100062346C040A00088000E100040
    ROD: N/A
    VCID: 3833BBE3135203A75B23EC-806D
    No ASAM data for: "EV_MFKBoschMQBB"
Java 8 Update 66
OS X El Capitan (version 10.11.1)
Also on Wndows 7 (same Java 8 Update 66)
This is on a brand new (4 miles) UK Škoda Superb L&K
