Ignition Key SECURITY CHIP (Pill) removal/replacement - 2005 Touareg
2005 Touareg
C?ID=366307
From the ignition key, Has anyone removed the Security Chip glued to the printed circuit board and placed it on another Original FOB printed circuit board to create a fictional ignition key. Attached find a picture of the printed circuit board (PCB) from a disassembled original FOB. I believe the long narrow chip furthest to the left, on the narrowest part of the PCB board is the security chip.
Dr Sheldon
Windsor UK
C?ID=334979
It is called cloning and yes !
As per our phone conversation we believe the transponder should look something like this:
2005 Touareg
C?ID=366307
Here is an image of the opened key case.
2005 Touareg
C?ID=366307
Soot,
That's why I'm here, the dealer can't get me a new key, the Cassie is not manufactured anymore. Do you have anything constructive to add?
Nope... carry on :thumbs:
Dr Sheldon
Windsor UK
C?ID=334979
Soot,
An auto locksmith can get you a new key - Easy !
2005 Touareg
C?ID=366307
2005 Touareg
C?ID=366307
Sheldon, this problem started at a locksmiths garage. If I could buy a brand new key from him I would. In fact the dealer that I contacted did not think he could source the key.
2005 Touareg
C?ID=366307
Dana, here is the image of the other PC board from the other key that VCDS validates as Adaptable. As you can see, the components are identical, and therefore it looks no different than the other PCB. Both these keys are genuine Volkswagen keys. Neither of them appears to have been tampered with.
Dr Sheldon
Windsor UK
C?ID=334979
Change Locksmith !!
You clearly have a shit one there !!
2005 Touareg
C?ID=366307
I thought of that, can you suggest somebody that you know that is good with working with these cars?
2005 Touareg
C?ID=366307
Thanks for the reply. The chip that I am pointing to doesn't appear to be soldered (no legs) to the PCB, but rather glued. Would they pick up supply coil be attached this way?
If it is the multi-leg chip that you suggested, that's beyond my capability to remove.
