My cars steering rack failed and came up with the dreaded STOP do not drive.
Its was removed and sent off to be repaired
Upon opening it, it was discovered it was full of water.
Rack was repaired and tested and refixed
Nothing else was moved on the vehicle whilst the rack was removed
I'm struggling to find where it reprogramme the end stops and calibrate the steering angle sensor
I've attached the VCDS log and would appreciate any guidance or help
Saturday,07,December,2024,10:59:17:26910
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WAUZZZ8RXFA064177 License Plate: E13ADA
Mileage: 116080km-72128mi Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 6D 72
A9 C0
VIN: WAUZZZ8RXFA064177 Mileage: 116080km-72128miles
C0-Act. for Ext. Noise -- Status: Malfunction 0010
Address 01: Engine (J623-CGQB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 589 HW: 4G0 907 589
Component: 3.0BTD EDC17 H25 0004
Revision: 57H25--- CVN: 3354AAC7
Coding: 2A2A4032252603020000
Shop #: WSC 65535 000 00000
ASAM Dataset: EV_ECM30BTD0118K5907589 001007
ROD: EV_ECM30BTD011_AU48.rod
VCID: 7EA5029AA071E41A2D7-802A
VINID: 9D196AAAA222A164401840471CF5ED62F6
11 Faults Found:
4327 - Function Restriction due to Faults in Other Modules
U1113 00 [00100000] - -
4881 - EGR Valve (N18)
P1440 00 [01100000] - Open Circuit
18735 - Steering Effort Control Module
U0130 00 [00100000] - No Communications
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [00100000] - -
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [00100000] - -
4713 - No Communication with ABS Brake Control Module
U0121 00 [00100000] - -
[Lost Communication WithAnti-Lock Brake System (ABS) Control Module]
4714 - Steering Column Control Module
U0212 00 [00100000] - No Communications
4715 - No Communication with Instrument Cluster
U0155 00 [00100000] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
4716 - No Communications with Parking Brake Control Module
U0128 00 [00100000] - -
Part No SW: 8R0 927 158 AE HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1006
Revision: --H19--- CVN: AA86CC8E
VCID: 00597C62DA8592EA5FB-8054
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AP HW: 8R0 907 379 AP
Component: ESP8 quattro H09 0020
Coding: 241DCC01
Shop #: WSC 06335 000 00000
VCID: 0E45525A9051F49ADD7-805A
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 92
Mileage: 116069 km
Date: 2024.12.06
Time: 18:25:21
Hex Value: 0x0840
Hex Value: 0x4016
Hex Value: 0x120C
Hex Value: 0xC0B9
Hex Value: 0x0000
Part No SW: 8K0 907 064 KG HW: 8K0 907 064 KG
Component: BCM2 2.0 H15 0711
Coding: 01B54040000000000000
VCID: 7F5BFF9EA7FBED12261-802A
Subsystem 1 - Part No SW: 8K0 959 754 BM HW: 8K0 959 754 BM
Serial number: 0814000146520018
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3214000124703015
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01201020141334
Coding: 3625028080
VCID: 78A9148282D5DA2A67B-802C
Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH
Component: BCM1 1.0 H16 0103
Revision: 08016001 Serial number: 00000927476101
Coding: 260000108034AFE0018140C300001D0D0F9DC70827090201000008004400030100000024000000
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 140917 H12 0050
Serial number: 90243015140906021046
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 23347077
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001510146334
Serial number: 2A09C357000000000001
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H48 0610
Serial number: 003JPDC1SJ2- Dataset Number: 8R0909602E 0010
Coding: 30473431313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48C9A442B2356AAAD7B-801C
Serial number: 6334MSME4A1B702EM
Serial number: 6344MSME496B711ER
Serial number: 6352QSME75471A66N
Serial number: 6362QSME624B3652H
Serial number: 63732SME74524D70+
Serial number: 63832SME59465052-
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862NJM0014E
Coding: 000037
VCID: 48C9A442B2B56AAAD7B-801C
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 950 T HW: 8R0 920 950 T
Component: KOMBIINSTR. H35 0564
Revision: 00400000 Serial number: ZDL380HAF
Coding: 33A7220003012600010000
VCID: 47CBA77EBFAB65D2DE1-8012
Part No SW: 8R0 907 468 N HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0060
Revision: 1Y080030 Serial number: 3041Y14A07030B
Coding: 80CD07FF00
VCID: 4ACD9E4AACB998BAC1F-801E
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 6487714403
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 14288002551021200181
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000122234851
Coding: 011D02215C01440004
VCID: 4FFB8F5E57DBBD92961-801A
Part No SW: 8R0 909 144 J HW: 8R0 909 144 B
Component: RCEPS H41 0509
Revision: 00001000 Serial number: 0006067087 Dataset Number: 8R0909852H 0021
Coding: 100000010001
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_RCEPSAU48X 008016
ROD: EV_RCEPSAU48X_008.rod
VCID: 3FDBBF9EE7FB2D12661-806A
7341600 - Position Sensor for Motor
C10AD 29 [00001000] - Signal Implausible
[Unplausible Werte vom Resolver (Warnung)]
Reset counter: 132
Mileage: 115928 km
Date: 2024.12.05
Time: 07:03:56
Write only channel
7341570 - Position Sensor for Motor
C10AD 29 [10001001] - Signal Implausible
[Unplausible Werte vom Resolver (beherrschbarer Fehler)]
Mileage: 116068 km
Date: 2024.12.06
Time: 18:24:18
Write only channel
Revision: 00002001 Serial number: 0349540935
Coding: 013B0622A0B930808720053680040047
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000122741726
Coding: 011D02215E01440004
VCID: 4EC5925A50D1B49A9D7-801A
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 00000001561895
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2DCE8AFCD9083A51F-806E
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109JD0E7978339
Coding: 010103020100000001
VCID: 280904C212F58AAA37B-807C
Part No SW: 8R2 035 666 G HW: 8R2 035 666 C
Component: H-BN-EU H47 0809
Revision: -------- Serial number: 206J60E7579247
Coding: 1A0101060205A1ED05808B5E00000403E40000020000000000
VCID: 3D27C596ED773F0274D-8068
Subsystem 1 - Part No: 8R0 060 884 BT
Component: EUR 2014 1903
Subsystem 2 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Serial number: 00000002017407
Subsystem 3 - Part No: 8R0 060 961 G
Component: CD-Database 5950
00658 - Control Head
Fault Frequency: 13
Reset counter: 132
Mileage: 115923 km
Date: 2024.11.24
Time: 13:24:46
Voltage: 12.10 V
02259 - Information Display and Control Head (Front) (J685)
Reset counter: 89
Mileage: 115923 km
Date: 2024.11.24
Time: 13:21:58
Voltage: 11.60 V
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000122411300
Coding: 010C02204001240004
VCID: 46D5AA7AB8A17CDA257-8012
Address 6D: Trunk Elect. (J605) Labels: 8K9-827-851.clb
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000122205433
Part No SW: 8R0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0007
Serial number: 140916202406
VCID: 79AF1186B95FC322185-802C
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 8R0 907 160 HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H09 0002
Serial number: 140920202313
ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
ROD: EV_ActuaForExterNoiseUDS.rod
VCID: 71BF29A6E12F8B62A05-8024
0006 - Actuator 1 for Engine Noise Simulation
C113C 13 [00001000] - Open Circuit
Fault Frequency: 15
Mileage: 115985 km
Date: 2024.12.05
Time: 13:08:16
End----(Elapsed Time: 01:55, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
Monday,23,December,2024,09:20:29:26910
A9 C0
44-Steering Assist -- Status: Malfunction 1010
12 Faults Found:
U1113 00 [00100111] - -
Mileage: 116088 km
Date: 2024.12.23
Time: 08:56:52
Engine RPM: 0.00 /min
Coolant temperature: 21 C
Intake air temperature: 6 C
Voltage terminal 30: 11.920 V
ACC specified acceleration: 0.000 m/s
ACC control module: received status-Bits 0-7: 6
Active brake system error status-Bits 0-7: 48
Status of ACC/CCS acceleration interface-Bits 0-7: 0
Acceleration: 0.000 m/s
Engine status: COENG_READY
Mileage: 116088 km
Date: 2024.12.23
Time: 08:56:52
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 44
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
Mileage: 116088 km
Date: 2024.12.23
Time: 08:56:52
U0428 00 [00100111] - -
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:26
Coolant temperature: 23 C
Voltage terminal 30: 12.060 V
CAN TimeOut meter - battery manager-Bits 0-7: 0
Cruise Control System (CCS): status-Bits 0-7: 236
CAN TimeOut meter - gateway-Bits 0-7: 0
CAN TimeOut meter - steering angle-Bits 0-7: 0
CAN TimeOut meter - parking brake-Bits 0-7: 0
CAN TimeOut meter - transmission-Bits 0-7: 0
Coding: 241DCC01
Fault Status: 00101101
Reset counter: 132
Mileage: 116088 km
Date: 2024.12.07
Time: 10:59:02
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x000C
Hex Value: 0xC094
Hex Value: 0x0000
Reset counter: 132
Mileage: 116088 km
Date: 2024.12.07
Time: 11:00:34
Hex Value: 0x00C0
Hex Value: 0x07A2
Hex Value: 0x0015
Hex Value: 0x1087
Hex Value: 0x0000
Reset counter: 132
Mileage: 116088 km
Date: 2024.12.23
Time: 08:56:53
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x002F
Hex Value: 0x3697
Hex Value: 0x0000
Reset counter: 132
Mileage: 116088 km
Date: 2024.12.23
Time: 08:56:53
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x002F
Hex Value: 0x3697
Hex Value: 0x0000
Coding: 3625028080
Coding: 01DD13
Coding: 02005C
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:31
Coding: 000037
Fault Status: 00100011
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:26
(no units): 32.0
Text: 2087FFFF3000310000
(no units): 65025.0
(no units): 49.0
Text: 13890000FFDFFFDFFF
Inj. On Time: 0.00 ms
Raw, Index/Key Err.: 255 223 255
Raw, Index/Key Err.: 223 255 049
014 - Defective
Fault Status: 01101110
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:30
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:58
(no units): 32.0
(no units): 65025.0
(no units): 49.0
Coding: 80CD07FF00
Reset counter: 132
Mileage: 116088 km
Date: 2024.12.10
Time: 20:43:33
Bin. Bits: 00000
Voltage: 12.00 V
Count: 7
Bin. Bits: 00000
Time: 0.40 s
8 Faults Found:
5242881 - Regulation Limit Exceeded
C10F2 F0 [00001000] - Unknown Error Elaboration
[Detektierung "yellow error" durch Lenkfunktions- berwachung-Software]
Reset counter: 132
Mileage: 116088 km
Date: 2024.12.23
Time: 08:57:35
Write only channel
4207936 - Steering Angle Value
C10C9 29 [00001000] - Signal Implausible
[Unzul ssige Differenz zwischen internen Lenkwinkel und dem vom Bussystem (Gleichlauf- berwachung)]
Reset counter: 132
Mileage: 116088 km
Date: 2024.12.23
Time: 08:57:35
Write only channel
4215044 - Function Restriction due to Faults in Other Modules
U1113 00 [00001001] - -
[Fehlerwert "Lenkradwinkel"]
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:26
Write only channel
4205828 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:30
Write only channel
4208000 - Steering Angle Sensor
B1168 F1 [00001000] - Synchronization Failed
Write only channel
5258753 - Steering End Stops Not Learned
C10AC F0 [10001001] - Unknown Error Elaboration
[Lenkungsendanschl ge nicht angelernt]
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:30
Write only channel
18689 - Terminal 30
U140A 00 [00001000] - Open Circuit
[Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
Reset counter: 132
Write only channel
3158560 - Combination / Chassis CAN Bus (SAE Bus D)
U0056 00 [00001000] - Performance
[CAN Global Timeout]
Write only channel
Fault Frequency: 26
Reset counter: 132
Mileage: 115923 km
Date: 2024.11.24
Time: 13:24:46
Voltage: 12.10 V
Reset counter: 89
Mileage: 115923 km
Date: 2024.11.24
Time: 13:21:58
Voltage: 11.60 V
Fault Frequency: 27
Mileage: 115985 km
Date: 2024.12.05
Time: 13:08:16
End----(Elapsed Time: 01:56, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
Tuesday,07,January,2025,13:16:05:26910
A9 C0
Mileage: 116088 km
Date: 2025.01.07
Time: 13:11:32
Engine RPM: 819.00 /min
Normed load value: 24.7 %
Coolant temperature: 31 C
Intake air temperature: 7 C
Voltage terminal 30: 14.340 V
Mileage: 116088 km
Date: 2025.01.07
Time: 13:11:32
Mileage: 116088 km
Date: 2025.01.07
Time: 13:11:32
Engine RPM: 818.50 /min
Voltage terminal 30: 14.360 V
Coding: 241DCC01
Fault Frequency: 8
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 09:20:27
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x002F
Hex Value: 0x2397
Hex Value: 0x0000
Coding: 3625028080
Coding: 01DD13
Coding: 02005C
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:31
Coding: 000037
Mileage: 116088 km
Date: 2024.12.23
Time: 14:00:25
(no units): 32.0
(no units): 65025.0
(no units): 49.0
014 - Defective
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:30
Mileage: 116088 km
Date: 2024.12.23
Time: 14:00:39
(no units): 32.0
(no units): 65025.0
(no units): 49.0
01426 - Controls in Steering Wheel (E221)
Coding: 80CD07FF00
Reset counter: 92
Mileage: 116088 km
Date: 2025.01.07
Time: 13:12:26
Write only channel
Reset counter: 92
Mileage: 116088 km
Date: 2025.01.07
Time: 13:12:26
Write only channel
Reset counter: 92
Mileage: 116088 km
Date: 2025.01.07
Time: 13:12:26
Write only channel
Fault Frequency: 41
Reset counter: 132
Mileage: 115923 km
Date: 2024.11.24
Time: 13:24:46
Voltage: 12.10 V
Reset counter: 89
Mileage: 115923 km
Date: 2024.11.24
Time: 13:21:58
Voltage: 11.60 V
C113C 13 [00001001] - Open Circuit
Fault Frequency: 16
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 09:45:46
End----------(Elapsed Time: 01:55, VBatt start/end: 14.5V/14.5V)-----------
Tuesday,07,January,2025,13:21:35:26910
A9 C0
Mileage: 116088 km
Date: 2025.01.07
Time: 13:11:32
Mileage: 116088 km
Date: 2025.01.07
Time: 13:11:32
Mileage: 116088 km
Date: 2025.01.07
Time: 13:11:32
Coding: 241DCC01
Fault Frequency: 8
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 09:20:27
Hex Value: 0x0000
Hex Value: 0x07A2
Hex Value: 0x002F
Hex Value: 0x2397
Hex Value: 0x0000
Coding: 3625028080
Coding: 01DD13
Coding: 02005C
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:31
Coding: 000037
014 - Defective
Reset counter: 92
Mileage: 116088 km
Date: 2024.12.23
Time: 08:58:30
Coding: 80CD07FF00
Reset counter: 92
Mileage: 116088 km
Date: 2025.01.07
Time: 13:12:26
Write only channel
Reset counter: 92
Mileage: 116088 km
Date: 2025.01.07
Time: 13:12:26
Write only channel
Reset counter: 92
Mileage: 116088 km
Date: 2025.01.07
Time: 13:12:26
Write only channel
Reset counter: 92
Mileage: 116088 km
Date: 2025.01.07
Time: 13:15:32
Voltage: 14.60 V
Reset counter: 92
Mileage: 116088 km
Date: 2025.01.07
Time: 13:15:59
End----------(Elapsed Time: 01:53, VBatt start/end: 14.4V/14.5V)-----------
