2012EosExecutive
My issue,
I got new fog lights and was getting an error on the gage cluster every time I started the car saying the fog lights were bad. After you turned them on and off the message disappeared. I saw on another forum that you can turn off "cold diagnostics" to stop the message. I of course busted out my obdEleven and changed the longcode in the central electrics to match what I saw on the post but the post was using VCDS and the number of bytes didn't match. I figured if it didn't work I could just change it back. No go. Now my door locks don't work at all (key fob, interior button, and when I use the key it mechanically operates but no power lock actuation). The car doesn't recognize the key is in the car and the only way to get the ignition to turn on is to hold the key to the start push button. The windows barely work (I gotta keep hitting the switch and I only get 1/4 inch movement every 5th time) the battery is flickering on the gage cluster and the car will try to start but is also in an intermittent status. (It turns over and stops repeatedly as long as I push the start button). Also, the gage cluster doesn't have a constant signal that the door is open (as evidenced by the gage cluster screen driver door flickering open and shut). This is also weird because the hood is indicating normally. Finally, I noticed the tail lights are flickering while ignition is on. This all happened because I changed the long code in central electrics and now when I fire up obdEleven it can see the module on the main screen and it shows green in the list of modules but as soon as I click on the central electrics module to go to the screen to change the longcode back it says "control unit not responding. Check ignition and try again". Can I revert the longcode back With VCDS?!
Things I've tried:
Unplug battery and short positive and negative battery leads for 10 min.
Attached a jump box to the battery (even though is says battery is 12.4V in obdEleven)
Cleared Cache in APP
Tried with a different phone
Copied the logs that say no errors with the central electrics module and even shows the longcode with the improper modification
Searched a bunch on forums and almost bought a VCP to reflash the central electrics. (Might have to go this route in the end)
Any help is seriously appreciated!
Also weird is obdeleven says no errors found.
Bad code:
6F000A3F8A232A64808802C174008DC44855FF0665200DB0E48C60008040
Good old code:
6F000A3F8A232A64808802C174008DC44855610665200DB0E48C60008040
Log from obdeleven:
Things I've tried:
Bad code:
Good old code:
Log from obdeleven:
OBDeleven data log
Date: 2025-01-04 16:39
VIN: WVWFW7AH4CV010043
Car: Volkswagen Eos
Year: 2012
Body type: Coupe convertible
Engine: CBFA
Mileage: 70970 KM
01 Engine
System description: MED17.5.2 03
Software number: 06J906027CH
Software version: 1440
Hardware number: 06J907309B
Long coding: 041C01081C070160
Trouble codes:
No trouble codes found
02 Transmission
System description: GSG DSG AG6 511
Software number: 02E300057B
Software version: 2730
Hardware number: 02E927770AL
Hardware version: F11
Serial number: 00001107112356
Trouble codes:
03 Brakes
System description: ESP MK60EC1
Software number: 1K0907379BJ
Software version: 0121
Hardware number: 1K0907379BJ
Hardware version: H31
Long coding: 514B600A492300FA8A0B06E8921C0041310000
Trouble codes:
04 Steering Angle Sensor
Trouble codes:
05 Keyless System
System description: VWKESSYPQ35GP
Software number: 5K0959434A
Software version: 0802
Hardware number: 5K0959434A
Hardware version: 085
Serial number: 0150203323
ODX name: EV_KESSY_PQ35GP
ODX version: A01018
Long coding: 030C0C
Trouble codes:
08 Air Conditioning
System description: Climatronic
Software number: 1K8907044AT
Software version: 0202
Hardware number: 1K8907044AT
Hardware version: H05
ODX name: EV_Climatronic
ODX version: A01010
Long coding: 0810019002
Trouble codes:
09 Central Electrics
System description: BCM PQ35 H+
Software number: 5K0937087Q
Software version: 0148
Hardware number: 5K0937087Q
Hardware version: 111
Long coding: 6F000A3F8A232A64808802C174008DC44855FF0665200DB0E48C60008040
Trouble codes:
10 Parking Assistance
System description: PARKHILFE 4K
Software number: 1Q0919475A
Software version: 0006
Hardware number: 1Q0919475
Hardware version: H02
Serial number: 32901119400767
ODX name: EV_EPHVA14VW4650000
ODX version: 001003
Long coding: 304101
Trouble codes:
15 Airbag
System description: 20 Airbag VW8C
Software number: 1Q0959655B
Software version: 0210
Hardware number: 1Q0959655B
Serial number: 003G2000SUYR
Coding: 0012848
Trouble codes:
16 Steering Column
System description: LENKS.MODUL
Software number: 5K0953569AL
Software version: 0180
Hardware number: 5K0953569AL
Hardware version: 016
Serial number: 20230306200617
ODX name: EV_SMLSNGVOLWS
ODX version: A01004
Long coding: 100A140000
Trouble codes:
17 Dashboard
System description: KOMBI
Software number: 1Q0920985F
Software version: 0407
Hardware number: 1Q0920985F
Hardware version: H03
ODX name: EV_Kombi_UDS_VDD_RM09
ODX version: A04114
Long coding: 271F01
Trouble codes:
19 Gateway
System description: J533 Gateway
Software number: 7N0907530BC
Software version: 1663
Hardware number: 7N0907530AN
Hardware version: H56
Serial number: 31123500F10066
Long coding: 355000
Trouble codes:
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Hardware number: 5K0953234
ODX name: EV_Immo_UDS_VDD_RM09
ODX version: A03009
Long coding: 000007
Trouble codes:
26 Roof Control
System description: Verdecksteuergeraet
Software number: 1Q0959255F
Software version: 0854
Hardware number: 1Q0959255F
Hardware version: 000
Serial number: 111960305
Coding: 0655366
Trouble codes:
2B Steering Column Lock
System description: ELV-PQ35
Software number: 5K0905861A
Software version: 0230
Hardware number: 5K0905861A
Hardware version: H20
Serial number: 11000168397003
ODX name: EV_ELVMarquMPVW36X
ODX version: A01001
Long coding: 4900000000000000
Trouble codes:
42 Driver Door
System description: Tuer-SG 009
Software number: 1Q0959701H
Software version: 2151
Hardware number: 1Q0959701H
Coding: 0021687
Trouble codes:
44 Steering Assistance
System description: EPS_ZFLS Kl. 70
Software number: 1K0909144M
Software version: 3201
Trouble codes:
46 Comfort System
Trouble codes:
47 Sound System
System description: DSP 10 Kanal
Software number: 1Q0035456F
Software version: 0010
Hardware number: 1Q0035456F
Serial number: 75809000218801
Trouble codes:
52 Passenger Door
Software number: 1Q0959702H
Hardware number: 1Q0959702H
Coding: 0021942
Trouble codes:
55 Headlight Regulation
System description: AFS-Steuergeraet
Software number: 5M0907357D
Software version: 0149
Hardware number: 5M0907357D
Coding: 1774803
Trouble codes:
5F Multimedia
System description: MU-S-NS-US
Software number: 5C0035684D
Software version: 0478
Hardware number: 5C0035684
Hardware version: H21
Serial number: VWZAZ2R0336691
ODX name: EV_MUStd4CTSAT
ODX version: 001022
Long coding: 02620002AA00000051220005001D0C001F0100D400300300C6
Trouble codes:
62 Rear Left Door
System description: Tuer-SG 004
Software number: 1Q0959811B
Software version: 0605
Hardware number: 1Q0959811B
Coding: 0000144
Trouble codes:
63 Entry Assistance Left
System description: J572 EASYENTRY FS
Software number: 1Q0959790A
Software version: 0603
Hardware number: 1Q0959790A
Hardware version: 560
Serial number: 5DS008646-01--
Coding: 0000002
Trouble codes:
65 Tire Pressure
System description: RDK
Software version: 0821
Long coding: 018705
Trouble codes:
72 Rear Right Door
Software number: 1Q0959812B
Hardware number: 1Q0959812B
Coding: 0000144
Trouble codes:
73 Entry Assistance Right
System description: J573 EASYENTRY BFS
Hardware version: 563
Coding: 0000002
Trouble codes:
