DPF differential pressure issue
Olof
Sweden
C?ID=415203
I have an Audi A6 3.0 TDI with several error codes that I now are working on.
Initially I had error codes for the glow plug 1 and 4. After replacing all 6 plugs these codes disappeared.
After this I made a forced dpf regeneration. The cycle started and the temperatures in the exhaust temp sensors reached 550 Celsius degrees except the exhaust temp sensor 2 that was on 222.0 degrees the full sequence. After 1 hour the process was still running and I closed the process manually (The engine was running on idle the last 20 minutes.) The IDE00427 Particle filter difference pressure at idle went from around 14 hPa to 4 hPa and I was happy. After a full scan, surprisingly, the particle filter issue was still present.
I noticed that there are two different diff pressure readings. In my case:
IDE00427 Particle filter. difference pressure actual reading 4 hPA
ENG106384 Particul.filter diff.pressure
actual reading 9 hPA this is obviously the value that the full scan is catching.
What is the difference between these two diff pressure?
Can I get rid of the difference between them?
Is there a better suggestion how to handle this issue?
Saturday,04,January,2025,16:25:47:63392
VIN: WAUZZZ4G9CN160651   License Plate:
Mileage: 378348km-235094mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 28 3B 3C 42 44 46 47
          52 53 55 56 5F 62 69 6C 72 85 8B 8E 8F 90
VIN: WAUZZZ4G9CN160651   Mileage: 378348km-235094miles
18-Aux. Heat -- Status: Cannot be reached 0100
Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 997 401     HW: 4G0 907 401
   Component: 3.0TDI EDC17  H37 0005
   Revision: 53H37---    CVN: 51CC9A94
   Coding: 1225401A057601020000
   Shop #: WSC 56479 004 1048576
   ASAM Dataset: EV_ECM30TDI0114G0997401 001005
   ROD: EV_ECM30TDI0114G0997401.rod
   VCID: 698FB9CEA9F69842E85-803C
   VINID: 9D196AAAA1172537811801850480D0640E
5585 - Particulate Filter (Bank 1)
          P242F 00 [00100111] - Restricted/Clogged
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 16:06:44
                    Engine RPM: 818.50 /min
                    Normed load value: 18.4 %
                    Coolant temperature: 68 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 14.540 V
                    Crankshaft speed (RPM): 818.5 /min
                    Vehicle speed: 0.00 km/h
                    Exhaust gas jet volume in particle filter: 57.5 m³/h
                    Particul.filter diff.pressure: 9 hPa
                    Particle filter: oil ash volume: 0.43 l
                    Exh t Adap T Oxi Cat Ds: 129.1 °C
                    P Flt Ld fac Ash Cor: 0.6061
4862 - No Communications with Aux. Heater Control Module
          U0166 00 [00100111] - -
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 16:06:45
                    Engine RPM: 819.50 /min
                    Voltage terminal 30: 14.560 V
                    Cruise Control System (CCS): status-Bits 0-7: 52
                    selected gear-Bits 0-7: 0
   Part No SW: 4G1 927 156 B    HW: 0B5 927 156 F
   Component: 0B5 30 TDIRdW H10 0006
   Revision: --H10---    Serial number: 0000000058 CVN: 0000014B
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMDL501 A02206
   ROD: EV_TCMDL501.rod
   VCID: 2C0100DA66844D6AD33-8078
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 27A68701E465E180FB00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 38292C8AA2DCF1CAA7B-806C
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0333
   Coding: 01A93006000000000000
   VCID: 76B5E2B2E8C847BA757-8022
   Serial number: 2312000058292010
   Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
   Component: KLIMA 4 ZONEN H12 0064
   Serial number: 30031200041378
   Coding: 3612007824
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 270BFFF67F626E323E1-8072
0237 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Steuergerät für Zusatzheizung: kein Signal / Kommunikation]
                    Reset counter: 104
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 15:53:30
                    Voltage terminal 30: 14.69 V
                    Outside temperature: 2.0 °C
                    Engine RPM: 778 /min
   Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
   Component: BCM1 2.0      H12 0111
   Revision: 20012002    Serial number: 00000001268370
   Coding: 2600E01040349FE28181008320001D0CCF9CE70826090101000008602100
   VCID: 75B7E5BEF5CE4CA27CD-8020
   Component: WWS57X 120223  H35 0080
   Serial number:         120317134152
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 20116530
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
   Component: E1 - LDS  H07 0044
   Serial number: 30 03 2012  00000822
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 08288026000000000001
   Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0060
   Revision: 11001001    Serial number: 55901207904061
   Coding: 292B08
   ASAM Dataset: EV_EPHVA18AU57X0000 004005
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 40D9446AFA0CB90A1FB-8014
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Serial number: 00000000000000 Dataset Number: 4G0909863B  0025
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2809FCCA727C614A37B-807C
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG007VH18 Dataset Number: 4G0909602G  0013
   Coding: 30323436313330303433554A304C34473053
   VCID: 363522B2A8C807BAB57-8062
   Serial number: 3575HRB405V173JOCGP7
   Serial number: 3585HRB40631872O4GAW
   Serial number: 3515JRB40144UHL8AQ4S
   Serial number: 3525JRB40164UHL8G91H
   Serial number: 3554VRB405R18AICP16V
   Serial number: 3564VRB405R18AIC8OOD
   Revision: --------    Serial number: 90372LCS000MA
   Coding: 0000DD
   VCID: 372B2FB6AF42FEB2AE1-8062
   Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
   Component: E221 - MFL  H08 0009
   Serial number: 22 12 2011  C0060689
   Part No SW: 4G8 920 931 R    HW: 4G8 920 931 R
   Component: TDieRdwAcc    H79 0416
   Revision: 28460177    Serial number: 658260312596034
   Coding: 138611000F110008010000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K_AU57.rod
   VCID: 3D273D9E8DFED4E274D-8068
Address 18: Aux. Heat
   Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000461480 Dataset Number: 4G0909515F  0058
   Coding: 00CD077D00
   GVL: FDADF844FEE6600D4000
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 70B9D4AA8A2C698AAFB-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790566906
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 090112000000000001E6
5409 - No Communications with Aux. Heater Control Module
          U0166 00 [00001001] - -
                    Reset counter: 104
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 15:53:30
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.6 V
                    Control Module temperature: 36 °C
                    System status: Terminal 15 on
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0064
   Serial number: 05041200040114
   Coding: 01
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 2F3B17D657923672F61-807A
0140 - Function Restricted due to Missing Message(s)
                    Reset counter: 104
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 15:53:30
                    Voltage terminal 30: 14.75 V
                    Engine RPM: 779 /min
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0009
   Revision: --------    Serial number: EJ1BPA4204EMHE0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 2D070DDE5D9E4462C4D-8078
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0010102
   VCID: 303914AA462C298AEFB-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F31.03.1200H020003CF25227ÿ
   Subsystem 4 - Serial number: F25227ÿ
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F16205000628002080013
   VCID: 41DF416EF186B002105-8014
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0020455961 Dataset Number: 4G0909852H  0027
   Coding: 101001010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1EA244A01B9A99F-8066
   Revision: 00002001    Serial number: 0174293630
   Coding: 013A062020B90480832009842C0104000000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00001020658
01403 - Glass-Break Sensors; Rear
                    Reset counter: 104
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 15:53:27
   Revision: CJ007001    Serial number: 00000000042333
   Coding: 030000
   VCID: 1D67DD1E2DBEB4E254D-8048
   Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
   Component: TSG BF        H05 0212
   Coding: 011F16205000628002080002
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000305507 Dataset Number: 4G0909522A  0001
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D06C26C70535A21F-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120404-0002-034
   Coding: 1122A6101002A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G1 035 053 E    HW: 4G1 035 053
   Component: Radio U Basic H41 0093
   Revision: AB001007    Serial number: 227C80C7558699
   Coding: 010003010000000001
   VCID: 211FE1EE11C69002705-8074
   Part No SW: 4G0 035 666 H    HW: 4G0 035 666 H
   Component: H-BN-EU       H49 0526
   Revision: --------    Serial number: 189CP0C7500103
   Coding: 050100010003EBEF3D10EB3E00000003E00001020000000000
   VCID: 2D070DDE5D1E4462C4D-8078
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC94019SG
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LD30005N
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
   Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
   Component: TSG HL        H04 0212
   Coding: 010F14204000628002080002
   VCID: 44D1487AEE94A52A3B3-8010
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Revision: 5G001001    Serial number: 00000174175365
   Coding: 0109080000000000
   VCID: 71BFD1AE81A66082A05-8024
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J23G3FR
   Coding: 1090005
   VCID: 2615F2F274E8773A057-8072
   Component: TSG HR        H04 0212
01482 - Motors for Central Locking
            006 - Short to Plus
                    Fault Status: 01100110
                    Reset counter: 104
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 15:53:28
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 104
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 15:53:28
02131 - Child Safety Lock Motor
                    Reset counter: 104
                    Mileage: 378348 km
                    Date: 2025.01.04
                    Time: 15:53:28
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G0909547C  0028
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F2F27868773A057-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 7F04010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000052703127 Dataset Number: 4G0909548C  0026
   Coding: 04C0B81C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Dataset Number: 4G0909614B  0004
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F11AE41A62082E05-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   Dataset Number: 4G0909615B  0004
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
End----------(Elapsed Time: 02:28, VBatt start/end: 13.3V/14.5V)-----------
Good question. Unfortunately, VAG doesn't share such details.
NEtech
Denmark
C?ID=56995
Probably offset.
ENG106384 = IDE00427 +/- IDE00428
Please post Controller Channel Map from the engine, warm in idle.
[Applications]
[Controller Channel Map]
- Controller Address = 01
- Login or security code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
File is placed in C:\Ross-Tech\VCDS\Logs
There cold be problem with exhaust temp sensor, log all sensors with VCDS from cold engine and drive, look at graph.
Exhaust/intake, diff.senor leaking somewhere.
Check if the Sensor 2 is installed, look at it with VCDS and then disconnect sensor.
