2014 GTI with bad abs module.
edognight
SC, USA
C?ID=606696
Hey there. I need some help with a 2014 GTI. It had some crazy symptoms, and I think I narrowed it down to a bad abs module. I backed up the coding
11 4B 60 0C 49 22 00 FB 88 0E 06 E6 92 21 00 41 B7 08 00
then I ordered a new abs module on eBay and I was careful to order one with a very similar model number. 1 K0 614 517 DT L6+ was stock to the car...
new one is 1KO 907 379 BL according to vcds readout.
eBay said 2013-15 VW Passat. (in my defense, the one I ordered was almost the same number as I had, but they did not send me the one that was pictured...)
the part fits, is on the car and works fine, but still flashing warning lights of every sort....
I try to code it in and get various error messages. error 12 sub function not reported blah blah blah...
It also wants a different number of digits from above, so I tried adding 00 on the end of the code...right now, the code is all zeroes, and won't accept anything I try.
I hope this isn't too specific, I am new to VW's...thanks
edognight
SC, USA
C?ID=606696
I am going to attempt to post my auto scan here:
Wednesday,01,January,2025,13:55:46:47516
VIN: WVWHD7AJXEW001328   License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHD7AJXEW001328   Mileage: 190230km-118203miles
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine (CBF)       Labels:. 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
   Revision: E3H26---    Serial number:
   Coding: 040301081C070160
   VCID: 78AE37BD1ED8D20A67B-802C
   VINID: 9E69D850745AA159C00010C220CD0EA255
               U1017 - 007 -  - Intermittent
                    Fault Status: 00100111
                    Mileage: 185287 km
                    Date: 2019.03.18.
                    Time: 05:38:53
                    RPM: 1752 /min
                    Load: 56.8 %
                    Speed: 45.0 km/h
                    Temperature: 84.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 950.0 mbar
                    Voltage: 13.843 V
009576 - Sensor for Ozone Reducing Radiator Identification
               P2568 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 185303 km
                    Date: 2019.03.18.
                    Time: 19:41:27
                    RPM: 2112 /min
                    Load: 11.0 %
                    Speed: 85.0 km/h
                    Temperature: 66.0°C
                    Temperature: 21.0°C
                    Voltage: 14.097 V
001169 - Secondary Air Injection System: Bank 1
               P0491 - 000 - Insufficient Flow - MIL ON
                    Fault Frequency: 17
                    Mileage: 186253 km
                    Date: 2019.04.03.
                    Time: 04:52:51
                    RPM: 1324 /min
                    Load: 42.3 %
                    Speed: 10.0 km/h
                    Temperature: 30.0°C
                    Temperature: 30.0°C
                    Voltage: 13.970 V
049441 - No Communication with ABS Brake Control Module
               U0121 - 000 -  - Intermittent
                    Mileage: 190230 km
                    Date: 2019.05.25.
                    Time: 01:42:13
                    Temperature: 9.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 11.303 V
   Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 3513
   Revision: 05652104    Serial number: 00001307240271
   VCID: 270C24C183E68DF23E1-8072
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Mileage: 190230 km
                    Date: 2019.05.25.
                    Time: 01:42:14
   Revision: 00H31001
   Coding: 114B600C492200FB880E06E692210041B70800
   Shop #: WSC 12345 123 61029
   VCID: 7DA026A93DFAF72234D-8028
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                    Fault Status: 00100011
                    Fault Frequency: 34
                    Reset counter: 130
                    Mileage: 189807 km
                    Date: 2019.05.25.
                    Time: 04:12:01
                    Count: 4608
                    Count: 37
                    Count: 49920
                    Count: 1024
                    Reset counter: 132
                    Mileage: 190224 km
                    Date: 2019.05.25.
                    Time: 00:04:43
                    Count: 16387
                    Count: 12
                    Count: 28672
                    Count: 210
                    Count: 43264
                    Count: 65280
                    Count: 58314
                    Reset counter: 125
                    Mileage: 189818 km
                    Date: 2019.05.25.
                    Time: 08:50:19
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 16390
                    Count: 51456
                    Count: 1
   Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
   Component: AC Manuell    H20 0505
   Revision: 00001019
   Coding: 0010002002
   VCID: 7BA428B1236EF9120A9-802E
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Bremsensteuergerät - kein Signal/Kommunikation]
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2025.01.01.
                    Time: 01:42:13
   Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
   Component: BCM PQ35  M   111 0709
   Revision: AC111709
   Coding: 6F180A1A90272AC4008800C17000054448010386434D8D60648020200040
   VCID: 41D89A59018253C2105-8014
   Subsystem 1 - Part No: 5K1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 09071  26  0512
   Coding: 009795
00984 - Left Tail Light (M4)
                    Fault Status: 00101010
                    Reset counter: 144
                    Mileage: 189538 km
                    Date: 2019.05.25.
                    Time: 06:24:51
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
02391 - Terminal 30 Reference
                    Fault Status: 00101011
                    Reset counter: 155
                    Mileage: 189807 km
                    Date: 2019.05.25.
                    Time: 03:17:17
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.25.
                    Time: 01:42:14
                    Voltage: 11.35 V
                        Term 50 On
   Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
   Component: AirbagVW10G   014 0726
   Serial number: 003L4R02BK35   Dataset Number: 5K0003v__B_ 0080
   Coding: 00004737
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3C26EBAD66E03E2A433-8068
   Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
   Component: BF-Gewichtss.  006 0001
   Serial number: ---0000R--00008G8600
   Serial number: 3572MSME1409337CZZZW
   Serial number: 3582MSME642D1578ZZZ/
   Serial number: 3512QSME720C2D5FZZZ4
   Serial number: 3522QSME760C311EZZZ-
   Serial number: 35527SME444F732FZZZU
   Serial number: 35627SME2C496D2FZZZ/
12656896 - No Communication with ABS Brake Control Module
          U0121 00 [00001000] - -
          [Lost Communication With Vehicle Dynamics Control Module]
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2025.01.01.
                    Time: 01:42:13
   Component: Lenks.Modul   008 0090
   Revision: --------    Serial number:  90422ME50001B Dataset Number: 5K0953507AH D005
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76B23985184CA47A757-8022
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Serial number: 0089224
   Coding: 830000
   Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
   Component: KOMBI         H05 0705
   Coding: 270F01
   VCID: 372CF4815FC61D72AE1-8062
12656896 - Function Restricted due to Missing Message(s)
          [Steuergerät für Bremse: keine Kommunikation]
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2025.01.01.
                    Time: 01:42:13
   Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
   Component: J533  Gateway H52 1634
   Revision:   H52       Serial number: 020713F2000219
   Coding: 350002
   VCID: 74B6038D0EB0B66A4B3-8020
                    Fault Status: 00110100
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.25.
                    Time: 01:42:15
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         002 0002
   Revision: 00002000    Serial number: 1225223RP57507
   Coding: 0000002
   VCID: 7EA221A53CFCEC3A2D7-802A
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.25.
                    Time: 01:42:18
   Component: IMMO          H05 0705
   VCID: 6A8A1DF55CF4709AE1F-803E
   Revision: A1001003    Serial number: 7665107926
   Coding: 010100
   VCID: 2B04D8F1930EA992DA9-807E
03138 - Input AUX IN
                    Fault Status: 00101001
                    Reset counter: 173
   Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
   Component: Tuer-SG         009 2105
   Coding: 0001204
   VCID: 372CF48153461D72AE1-8062
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 74     3501
   Revision: 00H22000
   VCID: 3928F2B965520B02585-806C
                    Fault Status: 00101101
                    Fault Frequency: 255
                    Reset counter: 173
                    Mileage: 190226 km
                    Date: 2019.05.25.
                    Time: 01:16:08
                    Voltage: 14.38 V
                        DU
                    Temperature: 14.0°C
                    RPM: 1619 /min
                    Speed: 31.0 km/h
                    Speed: 31.0 km/h
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.25.
                    Time: 01:42:13
                    Voltage: 11.38 V
                        DD
                    Temperature: 16.0°C
   Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
   Coding: 0001204
   VCID: 382EF7BD5E58120AA7B-806C
   Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
   Component: LOW NAR SDARS H03 0005
   Revision: -----07S    Serial number: VWZ4Z6N3590103
   Coding: 01000400040005
   VCID: 25102EC9F5EA9FE20CD-8070
                    Reset counter: 240
                    Mileage: 185287 km
                    Date: 2019.03.18.
                    Time: 05:38:30
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 3530FE89494AEF62BCD-8060
   Coding: 0001168
   VCID: 3632F985544CE47AB57-8062
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007665081620 Dataset Number: 7P6035730K  0001
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2AEDB56CD4001A51F-806E
End----(Elapsed Time: 01:12, VBatt start/end: 11.3V/11.3V. VIgn 11.2V)-----
Boki Ar
Arandjelovac, Serbia
C?ID=57300
According to Auto Scan coding: 114B600C492200FB880E06E692210041B70800 looks good.
edognight
SC, USA
C?ID=606696
Is the problem the replacement part is wrong number/generation? If I have to find another one and replace it, it's not the end of the world, but this car has been down ove a month, this is getting impossible...
-BL doesn't seem too far off for a MY 2014 car. What was the original one?
Boki Ar
C?ID=57300
A photo of the old module would be welcome, you can see everything there, like in the example:
edognight
SC, USA
C?ID=606696
1 K0 614 517 DT L6+ was the original to the car. the old one is lying on the garage floor. I will get the pic/ info today or tomorrow, thanks for the help.
Boki Ar
C?ID=57300
That would be best, we are interested in the part number 1K0 907 379 XX.
edognight
SC, USA
C?ID=606696
I don't know how to post a photo
Edit: this was originally incorrect...BL is the original to the car, on the garage floor, and a bad part...
TT1
1KO 907 379 BL
10.0961-0364.3
10.0619-3955.1
And then 1 K0 614 517 DT L6+ is the used eBay part I installed...soory for confusion....
edognight
SC, USA
C?ID=606696
ps, I am open to paying someone for help, and or buying an ABS model that will work, this car has been down for too long, and I am new to VW's and I can't believe how incredibly complicated it is! This site is by far the best and only resource.
edognight
SC, USA
C?ID=606696
One more thing! I misstated on post 7 and 1 above, I am very sorry to confuse everybody, I originally mixed them up...the original abs module in my garage, the bad one, stock to the car is
TT1
1KO 907 379 BL
10.0961-0364.3
10.0619-3955.1
From a 2014 gti.
and the long coding was: 11 4B 60 0C 49 22 00 FB 88 0E 06 E6 92 21 00 41 B7 08 00
The replacement part, which I bought off eBay,
1 K0 614 517 DT L6+
which was supposed to be from a '13 to '15 Passat which fit fine and does work, but still getting lots of flashing lights.
If you are in a hurry, @EuroX I believe will help you sort this out..... for a fee. You will have to PM him and ask about the details.
Otherwise, be patient as more (free) replies will come.
stock to the car is
TT1
1KO 907 379 BL
Since you're replacing a -BL module with another -BL module, you should be able to just copy and paste the existing coding that you have:
And then run Basic Settings:
Of course this assumes that the replacement module, as well as everything else related to the ABS, is in good working order.
edognight
SC, USA
C?ID=606696
Ok, thanks, I see why I was confused. I was confusing the number on the black cylinders, that you can see when the control module is in place, with the number on the back of the control module, like was pictured above...I guess one is the pump number and the other is the control module itself, sorry for the confusion...
Boki Ar
C?ID=57300
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL Component: ESP MK60EC1 H31 0152 Revision: 00H31001 Coding: 114B600C492200FB880E06E692210041B70800
Try this coding, seems fine.
edognight
SC, USA
C?ID=606696
*the problem stated briefly: I replaced a BL abs module with a BM module and the car wont accept the coding. First it says wrong number of digits, then I pad it with 00 at the end to make it the right number of digits, and I get another error message .
*Longer explanation: Ok, I had a chance to check over things, and it would be easiest to just start over. I apologize for messing things up...I confused the numbers on the pump (on the black cylinder) itself and the control box...I also assumed eBay sent the abs control module they pictured and they did not...
2014 GTI with a bad abs module. many codes, it was kicking on when it shouldn't even at 5 mph, for seemingly no reason. I removed 1K0 907 379 BL from the car, and it's coding was:
I then ordered a used part on eBay and installed it: 1KO 907 379 BM is what comes up as the hardware number when I scan it. (some of the confusion came when they did not send the part that they pictured on the auction which I wrote down, but it was a BL) I was warned to keep the initial coding but It hasn't worked...And here is the current auto scan...with the eBay part installed...
Tuesday,07,January,2025,16:46:12:47516
VIN: WVWHD7AJXEW001328   Mileage: 190310km-118253miles
10 Faults Found:
                    Mileage: 185287 km
                    Date: 2019.03.24.
                    Time: 05:38:53
                    RPM: 1752 /min
                    Load: 56.8 %
                    Speed: 45.0 km/h
                    Temperature: 84.0°C
                    Temperature: 42.0°C
                    Voltage: 13.843 V
                    Mileage: 185303 km
                    Date: 2019.03.24.
                    Time: 19:41:27
                    RPM: 2112 /min
                    Load: 11.0 %
                    Speed: 85.0 km/h
                    Temperature: 66.0°C
                    Temperature: 21.0°C
                    Voltage: 14.097 V
                    Fault Frequency: 17
                    Mileage: 186253 km
                    Date: 2019.04.09.
                    Time: 04:52:51
                    RPM: 1324 /min
                    Load: 42.3 %
                    Speed: 10.0 km/h
                    Temperature: 30.0°C
                    Temperature: 30.0°C
                    Voltage: 13.970 V
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 01:42:13
                    Temperature: 9.0°C
                    Temperature: 17.0°C
                    Voltage: 11.303 V
               U1017 - 000 -  - Intermittent
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:06:41
                    Temperature: 9.0°C
                    Temperature: 18.0°C
                    Voltage: 11.176 V
               U1017 - 015 -  - Intermittent
                    Fault Status: 00101111
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:06:41
                    Temperature: 9.0°C
                    Temperature: 18.0°C
                    Voltage: 11.176 V
050197 - Implausible Data Received from ABS Control Module
               U0415 - 004 -  - Intermittent
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:07:45
                    Speed: 255.0 km/h
                    Temperature: 9.0°C
                    Temperature: 18.0°C
                    Voltage: 11.176 V
               P0300 - 000 -  - Intermittent
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 05:31:14
                    RPM: 1049 /min
                    Load: 66.2 %
                    Speed: 3.0 km/h
                    Temperature: 9.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected - Intermittent
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 05:31:53
                    RPM: 1126 /min
                    Load: 23.5 %
                    Temperature: 22.0°C
                    Temperature: 9.0°C
                    Voltage: 14.351 V
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected - Intermittent
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 05:31:53
                    RPM: 1126 /min
                    Load: 23.5 %
                    Temperature: 22.0°C
                    Temperature: 9.0°C
                    Voltage: 14.351 V
                    Reset counter: 35
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 01:42:14
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 0000000000000000000000000000000000000000
   Shop #: WSC 09003 957 00200
   VCID: 7EA221A530FCEC3A2D7-802A
10 Faults Found:
                    Fault Status: 00101100
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:07:45
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 88
                    Count: 40704
                    Count: 65280
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:07:45
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 72
                    Count: 40704
                    Count: 65280
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:07:45
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 56
                    Count: 40704
                    Count: 65280
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:07:45
                    Count: 7
                    Count: 12
                    Count: 12288
                    Count: 40
                    Count: 40704
                    Count: 65280
                    Fault Frequency: 14
                    Reset counter: 137
                    Date: 2043.04.00
                    Time: 16:01:40
                    Count: 8381
                    Count: 256
                    Count: 37
                    Count: 40
                    Count: 54403
                    Count: 256
                    Reset counter: 131
                    Mileage: 66051 km
                    Date: 2001.12.04
                    Time: 00:36:14
                    Count: 1541
                    Count: 80
                    Count: 44288
                    Count: 195
                    Count: 256
                    Count: 22528
                    Count: 64
                    Count: 44289
                    Fault Status: 01100101
                    Reset counter: 131
                    Mileage: 190217 km
                    Date: 2019.05.31.
                    Time: 03:43:07
                    Count: 2
                    Count: 28672
                    Count: 212
                    Count: 44032
                    Count: 767
                    Reset counter: 131
                    Mileage: 190217 km
                    Date: 2019.05.31.
                    Time: 03:43:07
                    Count: 2
                    Count: 28672
                    Count: 279
                    Count: 44032
                    Count: 767
                    Reset counter: 131
                    Mileage: 190217 km
                    Date: 2019.05.31.
                    Time: 03:43:07
                    Count: 2
                    Count: 28672
                    Count: 295
                    Count: 44032
                    Count: 767
                    Reset counter: 131
                    Mileage: 190217 km
                    Date: 2019.05.31.
                    Time: 03:43:07
                    Count: 2
                    Count: 28672
                    Count: 270
                    Count: 44032
                    Count: 767
   Revision: 00001019
   Coding: 0010002002
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2025.01.07.
                    Time: 01:42:13
13701904 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001000] - -
          [Bremsensteuergerät - bitte Fehlerspeicher auslesen]
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2025.01.07.
                    Time: 02:07:49
   Revision: AC111709
   Coding: 009795
                    Reset counter: 144
                    Mileage: 189538 km
                    Date: 2019.05.31.
                    Time: 06:24:51
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
                    Reset counter: 155
                    Mileage: 189807 km
                    Date: 2019.05.31.
                    Time: 03:17:17
                        Term 15 Off
                    Voltage: 12.65 V
                        Term 50 Off
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 01:42:14
                    Voltage: 11.35 V
                        Term 50 On
   Coding: 00004737
12850432 - Implausible Data Received from ABS Control Module
          U0415 00 [00001000] - -
          [Communication with Vehicle Dynamics Control Module Implausible]
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2025.01.07.
                    Time: 02:07:44
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2025.01.07.
                    Time: 01:42:13
   Coding: 189A140000
   Coding: 830000
   Coding: 270F01
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2025.01.07.
                    Time: 01:42:13
   Coding: 350002
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 01:42:15
   Coding: 0000002
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 01:42:18
   Coding: 010100
                    Reset counter: 173
   Coding: 0001204
   Revision: 00H22000
                    Reset counter: 178
                    Mileage: 190304 km
                    Date: 2019.05.31.
                    Time: 04:48:25
                    Voltage: 14.38 V
                        DU
                    Temperature: 14.0°C
                    RPM: 1606 /min
                    Speed: 37.0 km/h
                    Speed: 37.0 km/h
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:06:42
                    Voltage: 11.25 V
                        DD
                    Temperature: 18.0°C
                    Reset counter: 173
                    Mileage: 190230 km
                    Date: 2019.05.31.
                    Time: 02:07:45
                    Voltage: 11.25 V
                        DU
                    Temperature: 18.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Coding: 0001204
                    Reset counter: 240
                    Mileage: 185287 km
                    Date: 2019.03.24.
                    Time: 05:38:30
   Coding: 0001168
   Coding: 0001168
End----------(Elapsed Time: 01:21, VBatt start/end: 12.1V/12.2V)-----------
Boki Ar
C?ID=57300
1K0 907 379 BM: 114B600C492200FB880E06E692210041A1080022
edognight
SC, USA
C?ID=606696
Coding accepted! Two of the most beautiful words I have heard in a long time. Thanks so much for all the help...
edognight
SC, USA
C?ID=606696
Is there more to do? or will the 57 flashing lights go away?
Boki Ar
C?ID=57300
Post new, fresh, Auto Scan, so we can see what to do now.
