ABS long coding lost (2015 Polo ESP9.0i)
Danedmunds
London, UK
hi all happy new year. so we have brought a 2015 polo someone by passed immob some how after messing up key so few things didnt work we have decided to change ecu bcm cluster and barrel. desperate to get long coding for abs as we have zeros once done we can move on to what issues we have after.
Thursday,02,January,2025,15:33:26:12174
VCDS Version: 24.7.1.0 (x64)
VIN: WVWZZZ6RZFY275793   License Plate: DA15
Mileage: 22294km-13852mi   Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY275793   Mileage: 22294km-13852miles
Address 01: Engine (J623-CHYA)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057     HW: 04C 907 309 J
   Component: R3 1.0l MPI   H23 8408
   Revision: 31H23000    CVN: 6B416539
   Coding: 01110052020401080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10MPI01104C906057 001015
   ROD: EV_ECM10MPI01104C906057_VW26.rod
   VCID: 62CDD76875603F86BD-8036
   VINID: 9E69EAAAA1A2A96A421C51C90C4FD32AB3
          U0428 00 [00100111] - -
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:37
                    Engine RPM: 0.00 /min
                    Coolant temperature: 76 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 11.991 V
                    selected gear-Bits 0-7: 0
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [00100111] - -
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:37
                    Mass flow through throttle valve: 0.0 kg/h
                    Engine operating condition: Idle
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0003
   Serial number: 08504585141022 Dataset Number: 6C0012V____ 0121
   Coding: 0000000000000000000000000000000000000000000000000000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
   ROD: EV_Brake1ESP90iBOSCHPQ26_VW26.rod
   VCID: 3363622C9A1AE60E06-8066
0943 - ABS/ESP Control Module
          U10C5 00 [10001001] - No or Incorrect Basic Setting
                    Reset counter: 215
                    Mileage: 22292 km
                    Date: 2018.12.17
                    Time: 00:01:15
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [10001001] - -
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
0887 - Control Module
          C104A F0 [00011000] - Incorrect VIN
                    Reset counter: 0
                    Mileage: 22292 km
                    Date: 2018.12.17
                    Time: 00:01:15
0883 - Control module not coded
          U1013 00 [00011000] - -
                    Reset counter: 2
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6C0 820 045     HW: 6C0 820 045
   Component: AC Manuell    H02 0105
   Serial number:  1409291B-0592 Dataset Number: 6C0032v____ 0009
   Coding: 200000001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 5CB1E99057040976F7-8008
459015 - Databus
          U1121 00 [00001100] - Missing Message
                    Reset counter: 4
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:41
          B10CD 00 [00001101] - -
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:19:22
                    Voltage terminal 30: 11.8 V
                    CAN input signal(s) status-Transport mode: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
                    CAN input signal(s) status-Back-up lamp: OFF
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 B    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H07 0065
   Serial number: 001098066043 Dataset Number: 6C0063V____ 0222
   Coding: 03000840421300530B244080B10703880000580257010000000000000000
   ASAM Dataset: EV_BCMA0 004008
   ROD: EV_MQBA0.rod
   VCID: 2F6B6E5C7632C2EE62-807A
   Driver door control module:
   Subsystem 1 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU020101442931127
   Coding: 1400A0
   Front passenger door control module:
   Subsystem 2 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU020111443241293
   Coding: 0400A0
8458 - Bulb for Right DRL
          B121E 15 [00001001] - Open or Short to Plus
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:38
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Stoerschutzzaehler: 0
                    Voltage: 12.1 V
                    Outside temperature: 4.5 °C
134667 - Voltage Supply for Terminal 30 of Exterior Mirror Heating
          B1900 13 [00001001] - Open Circuit
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
                    OFF: operated
                    Voltage: 12.1 V
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [00001001] - -
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
                    OFF: operated
                    Voltage: 12.1 V
267012 - No Communications with Anti-Theft Siren / Alarm Horn
          U10F3 00 [00001001] - -
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
                    OFF: operated
                    Voltage: 12.1 V
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
   Component: VW20Airbag011 001 0330
   Revision: --------    Serial number: 003LM005ULEU Dataset Number: 6C0003V____ 0215
   Coding: 88C0C000000000005C000000008800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 316F68246006D41E74-8064
   Subsystem 1 - Part No SW: -----------    HW: 410 821 806 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H009D1564992B07R
   Subsystem 2 - Part No SW: -----------    HW: 410 821 806 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H000A28358E4C1BU
   Subsystem 3 - Part No SW: -----------    HW: 442 151 810 14
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A009F179F752439Q
   Subsystem 4 - Part No SW: -----------    HW: 442 151 810 14
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00C91735273201-
          B13BC F2 [10001001] - No function
                    Mileage: 22293 km
                    Date: 2018.12.17
                    Time: 16:34:52
          U1101 00 [10001001] - Active
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
Address 17: Instruments (J285)       Labels:| 6C0-920-KOM-V1.clb-SRI3
   Part No SW: 6C0 920 940 A    HW: 6C0 920 940 A
   Component: KOMBI         211 0290
   Coding: 272401002180260001082A001000000000000000
   Shop #: WSC 09550 758 180955
   VCID: 224D976835E07F86FD-8076
16776973 - Databus
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H07 0065
   Revision: --------    Serial number: 001098066043 Dataset Number: 6C0067v____ 0039
   Coding: 030100047F0A640071000000000000010001010000000000000000000000
   GVL: 01403C0000000000400000000000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 001001
   ROD: EV_GatewA0Lear_001_VW26.rod
   VCID: 65C7CC74644E48BE58-8030
   Subsystem 1 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 51288H11272821932290
197169 - Controls in Steering Wheel
          U108E 00 [00001001] - No Communications
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:37
                    Terminal 30 power supply: 12.2 V
                    Terminal 15: On
          U1101 00 [00001001] - Active
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:37
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3211
   Serial number: CEBM0099 Dataset Number: 6C0074V____ 0224
   Coding: 0007
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
1094656 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
   Part No SW: 6C0 035 869 A    HW: 6C0 035 869 A
   Component: MU-E--ER      820 6220
   Serial number: 13091400010106 Dataset Number: 5G0CV1v____ 0001
   Coding: 02620000BE00000041111201000000001F0000860000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001017
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 295F804448D6ACDEBC-807C
                    Reset counter: 219
                    Mileage: 22294 km
                    Date: 2018.12.31
                    Time: 01:17:36
                    Voltage terminal 30: 12.1 V
End-------------------------(Elapsed Time: 02:07)--------------------------
Westbury, UK
You also have Component Protection active on 3 modules - Airbags, CAN Gateway and Infotainment.
What's the back story to this Polo?
Danedmunds
London, UK
Pretty much above mate. Brought from a customer who had someone change the key but some how override immobiliser as opened key up no chip in key. Was going to order a key from TPS but customer also told me the person who done the key may have also used a secondhand ignition barrel so where key would be cut to chassis would have been no good. So all we have done is changed ecu kit autologic will log in and sort c.p but need to have abs long coding to sort steering angle ect
Is WVWZZZ6RZFY275793 the actual, physical VIN of the car?
Before anyone makes themselves and you crazy, check that the VIN in 17-Instruments matches.
Danedmunds
London, UK
Uwe brilliant point sorry still stuck in holiday mode lol.
WVWZZZ6RZFU057871
iichel
Netherlands, Operation Market Garden
C?ID=284912
Try this to fix your multiple collision braking error
23DD2485492A33C5091B10720054C42492CC90080005CB080800
