2016 GTI ACC Retrofit issues
   #21
mmhubbard
Illinois, USA
C?ID=404494
I have made the updates to add the lane departure back in and it has cleaned up some of the errors. I am not yet worried about the code on the windshield wiper/washer switch, but concerned with the engine and 5F codes. Unless they are related in some way. I am not sure where to look next. The only remaining error on the dash is the EPC light.
Here is the latest scan:
VIN: 3VW447AU8GM007430   License Plate:
Mileage: 51081km-31740mi   Repair Order: d2
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 2B 32 42 44 47 52 55 5F 75
          A5 A9
VIN: 3VW447AU8GM007430   Mileage: 51081km-31740miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 766D2359
   Coding: 091D00124424002F1000
   Shop #: WSC 33076 003 104857
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F3B16F88798F4C2F61-807A
   VINID: 0E69C410746521774000710300BB87D739
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [10100111] - -
                    Mileage: 51081 km
                    Date: 2025.02.12
                    Time: 18:58:24
                    Engine RPM: 0.00 /min
                    Coolant temperature: 6  C
                    Intake air temperature: 7  C
                    Voltage terminal 30: 12.187 V
                    ACC variants (coding): CCS
                    CCS Switch: CCS operating unit
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    ACC variants: ACC
                    Engine: operating status: ES
Readiness: 1110 1101
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01505270109 CVN: 0000EE8B
   Shop #: WSC 00066 790 00202
   ROD: EV_TCMDQ250021.rod
   VCID: 1C61D134E62E7F5AA33-8048
   Revision: 00000000    Serial number: 62805000001299
   Coding: 01FA6BA154200973007B020341C36880D62A9000408216B6004350D1C009
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AADF7AC0C5AE16A11F-802E
   Revision: 00021000    Serial number: 0370694598 Dataset Number: V03935197ZB 0001
   Coding: 030C0C
   Shop #: WSC 01383 790 50316
   VCID: 3A2D37AC4CDA216A51F-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000101004012111402
   VCID: 42DD4F4C240A69AA09F-8016
   Air quality sensor:
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86580306152031 Dataset Number: 5GM063v____ 0059
   Coding: 00111B464041A27969E44000001407281800000000000000000000000000
   Shop #: WSC 00070 123 12345
   ROD: EV_BCMBOSCH_015.rod
   Component: WWS    150430  043 0581
   Serial number:         150716102540
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M07D07H01M57S57S8
   Coding: 028877
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694814510102150651
   Coding: 181803
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 31051541350039 Dataset Number: V03935209LD 0002
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 372B2E987FC83C02AE1-8062
   Serial number: 003GCR0255K4 Dataset Number: 5GM003V____ 0046
   VCID: 47CB5E580F284C82DE1-8012
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J1500034LPA05
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 35700000000115647411
   Subsystem 3 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 3580000000010B547416
   Subsystem 4 - Part No SW: -----------    HW: 480 402 005 15
   Serial number: 3510002B11A2DCD2B269
   Subsystem 5 - Part No SW: -----------    HW: 480 401 805 15
   Serial number: 3520002B11B0CB34A25/
   Subsystem 6 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3550002B71B41485529/
   Subsystem 7 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3560002B71B4148141B.
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150603400078
   Coding: 0610
   Shop #: WSC 12345 123 61029
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045189547E9EA79A7B3-8050
          B1149 13 [00001001] - Open Circuit
                    Reset counter: 239
                    Mileage: 51081 km
                    Date: 2025.02.12
                    Time: 18:58:21
                    Ubat 30 Voltage: 12.30 V
                    Ignition State: On
                    Terminal 15: 11.50 V
                    A/D #1: 97.65 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3196
   Coding: 0BAD111B7984CF0502087A021000000000000000
   VCID: 2A0D07ECBC7A91EA21F-807E
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 17061510002481 Dataset Number: 5G0067V____ 2215
   Coding: 0101003830085800FB00022B9C0F00000001050000000000000000000000
   GVL: 01503C5000000600408C10008000CC0000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E49025448E127CD-8020
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160000291600106062
   Coding: 29FFFF
   Revision: 00000000    Serial number: 15000147802002
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07027
   VCID: 343119946EBED71A8B3-8060
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00031.03.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 150615060506C1 Dataset Number: V03935214VB 0007
   Coding: 003F1320DC00040000000001
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 43D34A483B1060A2029-8016
   Serial number: 00000000000001537970
   Coding: 011000
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Dataset Number: 5GM074V____ 0418
   Coding: 9102
   Shop #: WSC 00046 000 00000
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA007UTT Dataset Number: 5GM050v____ 0212
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6D87CCF04D1446D284D-8038
   Serial number: 180615060507AA Dataset Number: V03935214VC 0007
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   Serial number: 00000000000001495359
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 021203010B000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D945442A067BBA1FB-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0241
   Serial number: VWZAZ2R0232869 Dataset Number: 5G0CV1v____ 0001
   Coding: 027300020000000051220002001808001F0203F401200105C6
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 71BFD080512CA232A05-8024
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU301J11
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 239
                    Mileage: 51081 km
                    Date: 2025.02.12
                    Time: 18:58:24
                    Voltage terminal 30: 12.1 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 239
                    Mileage: 51081 km
                    Date: 2025.02.12
                    Time: 18:58:24
   Component: OCULowMQBUS   007 0564
   Dataset Number: 561098V____ 0409
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0060
   Serial number: 10000016023    Dataset Number: 5G0HL1V____ 0049
   Coding: 0101010101020306000301000000000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C2131B446EE1F5A433-8068
   Component: SAS-GEN 2     H06 0014
   Serial number: 150523202386
   VCID: 6B83C2E8730048E29A9-803E
End----------(Elapsed Time: 01:47, VBatt start/end: 12.2V/12.2V)-----------
downtime
Finland
C?ID=280813
                    Reset counter: 239
                    Mileage: 51081 km
                    Date: 2025.02.12
                    Time: 18:58:24
                    Reset counter: 239
                    Mileage: 51081 km
                    Date: 2025.02.12
                    Time: 18:58:24
5F adaptations, in menu and bap groups. Put Charisma to not activated as you don't seem to have drive mode selection, and do the same for brake assist. Set the menu item and bap control channels to not activated.
For engine, what if you put the cruise control coding to no cruise control, does it clear the error?
And can you post adaptation map from gateway 19 module?
   #23
mmhubbard
Illinois, USA
C?ID=404494
                    Reset counter: 239
                    Mileage: 51081 km
                    Date: 2025.02.12
                    Time: 18:58:24
                    Reset counter: 239
                    Mileage: 51081 km
                    Date: 2025.02.12
                    Time: 18:58:24
I removed the Charisma adaptations from 5F and it removed one of the errors. I could not find a 5f adaptation setting for brake assist. I did see a brake function and a brake setting, but wasn't sure if that is the one you are referring to. I do have a button for drive mode, that did I do not believe was working prior to the change.
I removed cruise control from the engine coding and the engine error did go away, but obviously that leaves me with no cruise control.
Here is an updated scan after the updates:
Mileage: 51091km-31746mi   Repair Order: e3
          A5 A9
VIN: 3VW447AU8GM007430   Mileage: 51091km-31746miles
   Coding: 091D00124404002F1000
   Coding: 030C0C
   Revision: 00001K01
   Air quality sensor:
   Coding: 028877
   Coding: 181803
   Coding: 303131
   Coding: 0610
                    Reset counter: 241
                    Mileage: 51091 km
                    Date: 2025.02.14
                    Time: 14:13:27
                    Ubat 30 Voltage: 12.10 V
                    Ignition State: On
                    Terminal 15: 11.30 V
                    A/D #1: 97.65 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
   Generator:
   Coding: 29FFFF
   Coding: 0001
   Coding: 011000
   Coding: 9102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
                    Reset counter: 241
                    Mileage: 51091 km
                    Date: 2025.02.14
                    Time: 14:13:31
                    Voltage terminal 30: 12.0 V
End----------(Elapsed Time: 01:46, VBatt start/end: 12.1V/12.1V)-----------
Here is the admap for 19:
;SW:5Q0-907-530-AF HW:5Q0-907-530-M --- CAN Gateway
;Component:GW MQB High 212 2223Coding:0101003830085800FB00022B9C0F00000001050000000000000000000000
;EV_GatewConti013020EV_GatewConti_013.rod
;Friday
14​
February
2025​
13:39:30:23435
;VCDS Version: Release 24.7.1 (x64) Data version: 20240919 DS356.3
;VCID: 75B7E49025448E127CD-8020
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keysDeactivating
3​
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperationDeactivating
3​
IDE00002-Transport modenot active
1​
IDE00820-MAS01172-Activating and deactivating all development messages-Development messagesnot active
1​
IDE00820-ENG98891-Activating and deactivating all development messages-Reserved
0​
1​
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation12.1 V
2​
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering12.1 V
2​
IDE01211-Static current measuring modenot activated
1​
IDE01457-Energy management deactivation stageMode not active
1​
IDE01459-Energy management heat output control statusMode not active
1​
IDE01844-Increase idle speed requestMode not active
1​
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time--
3​
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activationMode not active
3​
IDE01860-Generator specified voltage value variable10.6 V
1​
IDE01996-SFT00001-Installation list: specified installations-Engine Electronicscoded
32​
IDE01996-SFT00002-Installation list: specified installations-Transmission Electronicscoded
32​
IDE01996-SFT00003-Installation list: specified installations-Brake electronicscoded
32​
IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's sideNot coded
32​
IDE01996-SFT00008-Installation list: specified installations-Climate Control Modulecoded
32​
IDE01996-SFT00009-Installation list: specified installations-Electronic central electriccoded
32​
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air HeaterNot coded
32​
IDE01996-SFT00014-Installation list: specified installations-Media Player 1Not coded
32​
IDE01996-SFT00019-Installation list: specified installations-Distance RegulationNot coded
32​
IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronicscoded
32​
IDE01996-SFT00021-Installation list: specified installations-Airbagcoded
32​
IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systemscoded
32​
IDE01996-SFT00023-Installation list: specified installations-Instrument clustercoded
32​
IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heatingNot coded
32​
IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface
1​
32​
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position DetectionNot coded
32​
IDE01996-SFT00032-Installation list: specified installations-High beam assistantNot coded
32​
IDE01996-SFT00033-Installation list: specified installations-Battery management 2Not coded
32​
IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronicsNot coded
32​
IDE01996-SFT00035-Installation list: specified installations-Brake BoostNot coded
32​
IDE01996-SFT00038-Installation list: specified installations-Convertible top operationNot coded
32​
IDE01996-SFT00043-Installation list: specified installations-Steering column lockcoded
32​
IDE01996-SFT00048-Installation list: specified installations-Special Function 2Not coded
32​
IDE01996-SFT00050-Installation list: specified installations-Differential lock electronicscoded
32​
IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver sideNot coded
32​
IDE01996-SFT00060-Installation list: specified installations-Lane change assistanceNot coded
32​
IDE01996-SFT00061-Installation list: specified installations-Special FunctionNot coded
32​
IDE01996-SFT00064-Installation list: specified installations-A/C compressorNot coded
32​
IDE01996-SFT00066-Installation list: specified installations-Driver's door electronicscoded
32​
IDE01996-SFT00068-Installation list: specified installations-Power steeringcoded
32​
IDE01996-SFT00071-Installation list: specified installations-Sound SystemNot coded
32​
IDE01996-SFT00075-Installation list: specified installations-Multi-function moduleNot coded
32​
32​
IDE01996-SFT00081-Installation list: specified installations-Electric driveNot coded
32​
IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronicscoded
32​
IDE01996-SFT00085-Installation list: specified installations-Headlamp range controlcoded
32​
IDE01996-SFT00086-Installation list: specified installations-RadioNot coded
32​
IDE01996-SFT00087-Installation list: specified installations-TV TunerNot coded
32​
IDE01996-SFT00095-Installation list: specified installations-Information electronics 1coded
32​
IDE01996-SFT00096-Installation list: specified installations-Trip recorderNot coded
32​
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS)Not coded
32​
IDE01996-SFT00105-Installation list: specified installations-Trailer FunctionNot coded
32​
IDE01996-SFT00108-Installation list: specified installations-Rear view camera systemNot coded
32​
IDE01996-SFT00109-Installation list: specified installations-Rear lid electronicsNot coded
32​
IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unitcoded
32​
IDE01996-SFT00118-Installation list: specified installations-Parking aidNot coded
32​
IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1Not coded
32​
IDE01996-SFT00130-Installation list: specified installations-Head-Up-DisplayNot coded
32​
IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery ManagementNot coded
32​
IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systemscoded
32​
IDE01996-SFT00166-Installation list: specified installations-Microphone control moduleNot coded
32​
IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuatorcoded
32​
IDE01996-SFT00183-Installation list: specified installations-Interface for access/start systemcoded
32​
IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronicsNot coded
32​
IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronicsNot coded
32​
IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging managementNot coded
32​
IDE01996-SFT00190-Installation list: specified installations-Left rear sliding doorNot coded
32​
IDE01996-SFT00191-Installation list: specified installations-Right rear sliding doorNot coded
32​
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior NoiseNot coded
32​
IDE01996-SFT00197-Installation list: specified installations-Thermal managementNot coded
32​
IDE01996-SFT00198-Installation list: specified installations-High-voltage battery chargerNot coded
32​
IDE01996-SFT00202-Installation list: specified installations-Sunroof control moduleNot coded
32​
IDE01996-SFT00204-Installation list: specified installations-Starter generatorNot coded
32​
IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2Not coded
32​
IDE01996-ENG118226-Installation list: specified installations-Node_0x01Not coded
32​
IDE01996-ENG118227-Installation list: specified installations-Node_0x02Not coded
32​
IDE01996-ENG118228-Installation list: specified installations-Node_0x03Not coded
32​
IDE01996-ENG118229-Installation list: specified installations-Node_0x04Not coded
32​
IDE01996-ENG118230-Installation list: specified installations-Node_0x05Not coded
32​
IDE01996-ENG118231-Installation list: specified installations-Node_0x06Not coded
32​
IDE01996-ENG118232-Installation list: specified installations-Node_0x07Not coded
32​
IDE01996-ENG118233-Installation list: specified installations-Node_0x08Not coded
32​
IDE01996-ENG118235-Installation list: specified installations-Node_0x0DNot coded
32​
IDE01996-ENG118236-Installation list: specified installations-Node_0x11Not coded
32​
IDE01996-ENG118237-Installation list: specified installations-Node_0x16Not coded
32​
IDE01996-ENG118238-Installation list: specified installations-Node_0x17Not coded
32​
IDE01996-ENG118239-Installation list: specified installations-Node_0x1ANot coded
32​
IDE01996-ENG118241-Installation list: specified installations-Node_0x1DNot coded
32​
IDE01996-ENG118242-Installation list: specified installations-Node_0x1FNot coded
32​
IDE01996-ENG118243-Installation list: specified installations-Node_0x20Not coded
32​
IDE01996-ENG118244-Installation list: specified installations-Node_0x21Not coded
32​
IDE01996-ENG118245-Installation list: specified installations-Node_0x22Not coded
32​
IDE01996-ENG118246-Installation list: specified installations-Node_0x24Not coded
32​
IDE01996-ENG118247-Installation list: specified installations-Node_0x25Not coded
32​
IDE01996-ENG118248-Installation list: specified installations-Node_0x26Not coded
32​
IDE01996-ENG118249-Installation list: specified installations-Node_0x27Not coded
32​
IDE01996-ENG118250-Installation list: specified installations-Node_0x28Not coded
32​
IDE01996-ENG118251-Installation list: specified installations-Node_0x29Not coded
32​
IDE01996-ENG118252-Installation list: specified installations-Node_0x2ANot coded
32​
IDE01996-ENG118253-Installation list: specified installations-Node_0x2ENot coded
32​
IDE01996-ENG118254-Installation list: specified installations-Node_0x2FNot coded
32​
IDE01996-ENG118255-Installation list: specified installations-Node_0x35Not coded
32​
IDE01996-ENG118256-Installation list: specified installations-Node_0x36Not coded
32​
IDE01996-ENG118257-Installation list: specified installations-Node_0x37Not coded
32​
IDE01996-ENG118258-Installation list: specified installations-Node_0x38Not coded
32​
IDE01996-ENG118259-Installation list: specified installations-Node_0x39Not coded
32​
IDE01996-ENG118260-Installation list: specified installations-Node_0x3ANot coded
32​
IDE01996-ENG118261-Installation list: specified installations-Node_0x3CNot coded
32​
IDE01996-ENG118262-Installation list: specified installations-Node_0x3DNot coded
32​
IDE01996-ENG118263-Installation list: specified installations-Node_0x40Not coded
32​
IDE01996-ENG118264-Installation list: specified installations-Node_0x41Not coded
32​
IDE01996-ENG118265-Installation list: specified installations-Node_0x43Not coded
32​
IDE01996-ENG118266-Installation list: specified installations-Node_0x45Not coded
32​
IDE01996-ENG118267-Installation list: specified installations-Node_0x48Not coded
32​
IDE01996-ENG118268-Installation list: specified installations-Node_0x49Not coded
32​
IDE01996-ENG118269-Installation list: specified installations-Node_0x51Not coded
32​
IDE01996-ENG118270-Installation list: specified installations-Node_0x52Not coded
32​
IDE01996-ENG118271-Installation list: specified installations-Node_0x53Not coded
32​
IDE01996-ENG118272-Installation list: specified installations-Node_0x55Not coded
32​
IDE01996-ENG118273-Installation list: specified installations-Node_0x56Not coded
32​
IDE01996-ENG118274-Installation list: specified installations-Node_0x58Not coded
32​
IDE01996-ENG118275-Installation list: specified installations-Node_0x59Not coded
32​
IDE01996-ENG118276-Installation list: specified installations-Node_0x5ANot coded
32​
IDE01996-ENG118277-Installation list: specified installations-Node_0x5BNot coded
32​
IDE01996-ENG118278-Installation list: specified installations-Node_0x5CNot coded
32​
IDE01996-ENG118279-Installation list: specified installations-Node_0x5DNot coded
32​
IDE01996-ENG118280-Installation list: specified installations-Node_0x5ENot coded
32​
IDE01996-ENG118281-Installation list: specified installations-Node_0x5FNot coded
32​
IDE01996-ENG118282-Installation list: specified installations-Node_0x60Not coded
32​
IDE01996-ENG118283-Installation list: specified installations-Node_0x61Not coded
32​
IDE01996-ENG118284-Installation list: specified installations-Node_0x62Not coded
32​
IDE01996-ENG118285-Installation list: specified installations-Node_0x66Not coded
32​
IDE01996-ENG118286-Installation list: specified installations-Node_0x68Not coded
32​
IDE01996-ENG118287-Installation list: specified installations-Node_0x6BNot coded
32​
IDE01996-ENG118288-Installation list: specified installations-Node_0x6CNot coded
32​
IDE01996-ENG118289-Installation list: specified installations-Node_0x6ENot coded
32​
IDE01996-ENG118290-Installation list: specified installations-Node_0x74Not coded
32​
IDE01996-ENG118291-Installation list: specified installations-Node_0x75Not coded
32​
IDE01996-ENG118292-Installation list: specified installations-Node_0x78Not coded
32​
IDE01996-ENG118293-Installation list: specified installations-Node_0x79Not coded
32​
IDE01996-ENG118294-Installation list: specified installations-Node_0x7ANot coded
32​
IDE01996-ENG118295-Installation list: specified installations-Node_0x7DNot coded
32​
IDE01996-ENG118296-Installation list: specified installations-Node_0x7ENot coded
32​
IDE01996-ENG118297-Installation list: specified installations-Node_0x7FNot coded
32​
IDE01996-ENG118298-Installation list: specified installations-Node_0x80Not coded
32​
IDE01996-ENG118299-Installation list: specified installations-Node_0x81Not coded
32​
IDE01996-ENG118300-Installation list: specified installations-Node_0x82Not coded
32​
IDE01996-ENG118301-Installation list: specified installations-Node_0x83Not coded
32​
IDE01996-ENG118303-Installation list: specified installations-Node_0x86Not coded
32​
IDE01996-ENG118304-Installation list: specified installations-Node_0x87Not coded
32​
IDE01996-ENG118305-Installation list: specified installations-Node_0x88Not coded
32​
IDE01996-ENG118306-Installation list: specified installations-Node_0x89Not coded
32​
IDE01996-ENG118307-Installation list: specified installations-Node_0x8BNot coded
32​
IDE01996-ENG118308-Installation list: specified installations-Node_0x8CNot coded
32​
IDE01996-ENG118309-Installation list: specified installations-Node_0x8DNot coded
32​
IDE01996-ENG118310-Installation list: specified installations-Node_0x8ENot coded
32​
IDE01996-ENG118311-Installation list: specified installations-Node_0x8FNot coded
32​
IDE01996-ENG118312-Installation list: specified installations-Node_0x90Not coded
32​
IDE01996-ENG118313-Installation list: specified installations-Node_0x91Not coded
32​
IDE01996-ENG118314-Installation list: specified installations-Node_0x92Not coded
32​
IDE01996-ENG118315-Installation list: specified installations-Node_0x93Not coded
32​
IDE01996-ENG118316-Installation list: specified installations-Node_0x94Not coded
32​
IDE01996-ENG118317-Installation list: specified installations-Node_0x95Not coded
32​
IDE01996-ENG118318-Installation list: specified installations-Node_0x96Not coded
32​
IDE01996-ENG118319-Installation list: specified installations-Node_0x97Not coded
32​
IDE01996-ENG118320-Installation list: specified installations-Node_0x98Not coded
32​
IDE01996-ENG118321-Installation list: specified installations-Node_0x99Not coded
32​
IDE01996-ENG118322-Installation list: specified installations-Node_0x9ANot coded
32​
IDE01996-ENG118323-Installation list: specified installations-Node_0x9BNot coded
32​
IDE01996-ENG118325-Installation list: specified installations-Node_0x9DNot coded
32​
IDE01996-ENG118326-Installation list: specified installations-Node_0x9ENot coded
32​
IDE01996-ENG118327-Installation list: specified installations-Node_0x9FNot coded
32​
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0Not coded
32​
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1Not coded
32​
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2Not coded
32​
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3Not coded
32​
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5Not coded
32​
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6Not coded
32​
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7Not coded
32​
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8Not coded
32​
IDE01996-ENG118338-Installation list: specified installations-Node_0xAANot coded
32​
IDE01996-ENG118339-Installation list: specified installations-Node_0xABNot coded
32​
IDE01996-ENG118340-Installation list: specified installations-Node_0xACNot coded
32​
IDE01996-ENG118341-Installation list: specified installations-Node_0xADNot coded
32​
IDE01996-ENG118343-Installation list: specified installations-Node_0xAFNot coded
32​
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0Not coded
32​
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1Not coded
32​
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2Not coded
32​
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3Not coded
32​
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4Not coded
32​
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5Not coded
32​
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6Not coded
32​
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7Not coded
32​
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8Not coded
32​
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9Not coded
32​
IDE01996-ENG118354-Installation list: specified installations-Node_0xBANot coded
32​
IDE01996-ENG118355-Installation list: specified installations-Node_0xBBNot coded
32​
IDE01996-ENG118356-Installation list: specified installations-Node_0xBCNot coded
32​
IDE01996-ENG118357-Installation list: specified installations-Node_0xBDNot coded
32​
IDE01996-ENG118358-Installation list: specified installations-Node_0xBENot coded
32​
IDE01996-ENG118359-Installation list: specified installations-Node_0xBFNot coded
32​
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0Not coded
32​
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1Not coded
32​
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2Not coded
32​
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3Not coded
32​
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4Not coded
32​
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5Not coded
32​
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6Not coded
32​
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7Not coded
32​
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8Not coded
32​
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9Not coded
32​
IDE01996-ENG118370-Installation list: specified installations-Node_0xCANot coded
32​
IDE01996-ENG118371-Installation list: specified installations-Node_0xCBNot coded
32​
IDE01996-ENG118372-Installation list: specified installations-Node_0xCCNot coded
32​
IDE01996-ENG118373-Installation list: specified installations-Node_0xCDNot coded
32​
IDE01996-ENG118374-Installation list: specified installations-Node_0xCENot coded
32​
IDE01996-ENG118375-Installation list: specified installations-Node_0xCFNot coded
32​
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0Not coded
32​
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1Not coded
32​
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2Not coded
32​
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3Not coded
32​
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4Not coded
32​
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5Not coded
32​
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6Not coded
32​
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7Not coded
32​
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8Not coded
32​
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9Not coded
32​
IDE01996-ENG118386-Installation list: specified installations-Node_0xDANot coded
32​
IDE01996-ENG118387-Installation list: specified installations-Node_0xDBNot coded
32​
IDE01996-ENG118388-Installation list: specified installations-Node_0xDCNot coded
32​
IDE01996-ENG118389-Installation list: specified installations-Node_0xDDNot coded
32​
IDE01996-ENG118390-Installation list: specified installations-Node_0xDENot coded
32​
IDE01996-ENG118391-Installation list: specified installations-Node_0xDFNot coded
32​
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0Not coded
32​
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1Not coded
32​
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2Not coded
32​
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3Not coded
32​
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4Not coded
32​
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5Not coded
32​
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6Not coded
32​
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7Not coded
32​
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8Not coded
32​
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9Not coded
32​
IDE01996-ENG118402-Installation list: specified installations-Node_0xEANot coded
32​
IDE01996-ENG118403-Installation list: specified installations-Node_0xEBNot coded
32​
IDE01996-ENG118404-Installation list: specified installations-Node_0xECNot coded
32​
IDE01996-ENG118405-Installation list: specified installations-Node_0xEDNot coded
32​
IDE01996-ENG118406-Installation list: specified installations-Node_0xEENot coded
32​
IDE01996-ENG118407-Installation list: specified installations-Node_0xEFNot coded
32​
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0Not coded
32​
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1Not coded
32​
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2Not coded
32​
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3Not coded
32​
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4Not coded
32​
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5Not coded
32​
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6Not coded
32​
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7Not coded
32​
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8Not coded
32​
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9Not coded
32​
IDE01996-ENG118418-Installation list: specified installations-Node_0xFANot coded
32​
IDE01996-ENG118419-Installation list: specified installations-Node_0xFBNot coded
32​
IDE01996-ENG118420-Installation list: specified installations-Node_0xFCNot coded
32​
IDE01996-ENG118421-Installation list: specified installations-Node_0xFDNot coded
32​
IDE01996-ENG118422-Installation list: specified installations-Node_0xFENot coded
32​
IDE01996-ENG118423-Installation list: specified installations-Node_0xFFNot coded
32​
IDE02200-Component protection showroom modenot active
1​
IDE02332-Deactivate production mode
0​
3​
IDE03256-MAS06105-Battery adaptation-Rated battery capacity60 Ah
15​
IDE03256-MAS06106-Battery adaptation-Battery technologyBinary - AGM
15​
IDE03256-MAS06107-Battery adaptation-Battery manufacturerJCB
15​
IDE03256-MAS06108-Battery adaptation-Battery Serial Number
1111111112​
15​
IDE03903-Production process data 100 00
2​
IDE04159-Deactivation of start/stop functionMode not active
1​
IDE04186-Battery terminal recognitionconnected
1​
IDE04330-Transfer of release code for a SWaP function00
1​
IDE04331-Selection of release codes for a SWaP functionFF FF FF FF
4​
IDE06425-MAS06026-Dynamometer mode: functional-Activation stagesnot activated
1​
IDE06425-MAS06277-Dynamometer mode: functional-Malfunction statesNo malfunction
1​
IDE06530-Distance left for deactivation of static current measuring mode
2​
1​
IDE06541-Distance left for deactivation of transport mode
50​
1​
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroofactivated
4​
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPMactivated
4​
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine startactivated
4​
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch)activated
4​
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-systemactivated
4​
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-systemactivated
4​
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroofactivated
4​
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position Dnot activated
4​
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstillactivated
4​
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button)activated
4​
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstillactivated
4​
IDE06753-MAS06289-Efficiency program display-Comfort use A/Cactivated
4​
IDE06753-MAS06290-Efficiency program display-Comfort use parking heateractivated
4​
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heateractivated
4​
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heateractivated
4​
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilationactivated
4​
IDE06753-MAS06294-Efficiency program display-Comfort use rear heateractivated
4​
IDE06753-MAS06295-Efficiency program display-Comfort use fog lightactivated
4​
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog lightnot activated
4​
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emissionactivated
4​
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heateractivated
4​
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heateractivated
4​
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heateractivated
4​
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heaternot activated
4​
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilationactivated
4​
IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selectionECO tips independent of driver profile selection
4​
IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumptionactivated
4​
IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependencyUntil temperature threshold: with after-run: with switch
4​
IDE07838-Counter for inconsistent states
0​
2​
IDE08348-Start/stop start voltage limit7.6 V
1​
IDE08624-MKE Check boxactivated
1​
IDE10735-Number requests autonomous recharging
3​
1​
IDE10736-Cyclization limitation request battery service
0​
1​
IDE10748-MAS11262-Range gain-Range gain AC systemactivated
3​
IDE10748-MAS11263-Range gain-Range gain auxiliary heateractivated
3​
IDE10748-MAS11264-Range gain-Range gain window defoggeractivated
3​
IDE10748-MAS11265-Range gain-Range gain seat heater frontactivated
3​
IDE10748-MAS11266-Range gain-Range gain front set ventilationactivated
3​
IDE10748-MAS11267-Range gain-Range gain rear heateractivated
3​
IDE10748-MAS11268-Range gain-Range gain fog lightactivated
3​
IDE10748-MAS11269-Range gain-Range gain rear fog lightactivated
3​
IDE10748-MAS11270-Range gain-Range gain windshield heatingactivated
3​
IDE10748-MAS11271-Range gain-Range gain steering wheel heateractivated
3​
IDE10748-MAS11272-Range gain-Range gain mirror heateractivated
3​
IDE10748-MAS11273-Range gain-Range gain rear seat heaternot activated
3​
IDE10748-MAS11274-Range gain-Range gain rear seat heateractivated
3​
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC systemnot activated
3​
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC systemactivated
3​
IDE10748-MAS11277-Range gain-PTC(low voltage) consumptionnot activated
3​
IDE10748-MAS11278-Range gain-PTC(low voltage) range gainactivated
3​
IDE10748-MAS11279-Range gain-List at engine still standactivated
3​
IDE10748-MAS12689-Range gain-Catalogue range displayactivated
3​
IDE10748-MAS12690-Range gain-Loading condition catalogue range displayactivated
3​
IDE10748-MAS13161-Range gain-List display absolute values ??with weightingactivated
3​
IDE10748-MAS19099-Range gain-Convenience consumption socketactivated
3​
IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumptionactivated
3​
IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heatingactivated
3​
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence
100%​
10​
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold
100​
10​
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In0 ms
10​
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start0 ms
10​
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out0 ms
10​
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start0 ms
10​
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay0 ms
10​
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence0 ms
10​
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightnessactive
3​
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequencyactive
3​
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbolactive
3​
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Resetactive
12​
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation
100​
12​
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation60000 ms
12​
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation10000 ms
12​
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption3000 ms
12​
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption0 ms
12​
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation180000 ms
12​
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation1500 ms
12​
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation800 ms
12​
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption2500 ms
12​
ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reportsMode not active
4​
ENG137060-ENG113873-EM_energy_management_warning_displays-GeneratormeldungenMode not active
4​
ENG137060-ENG118686-EM_energy_management_warning_displays-MMI VorwarnungenMode not active
4​
ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC)Mode not active
4​
ENG137075-EM_heating_power_quota_adjustment1000 W
1​
ENG137061-EM_nominal_voltage_limitation_low_beams12.1 V
1​
ENG137064-EM_requirement_cyclic_time_voltage_measurement0 s
1​
ENG137063-EM_requirement_reduction_air_blowersMode not active
1​
ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature-50.0 °C
2​
ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature-50.0 °C
2​
ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronicsactivated
32​
ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronicsactivated
32​
ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronicsnot activated
32​
ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's sideactivated
32​
ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Moduleactivated
32​
ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electricactivated
32​
ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heateractivated
32​
ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1activated
32​
ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulationactivated
32​
ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronicsactivated
32​
ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbagnot activated
32​
ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systemsactivated
32​
ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument clusteractivated
32​
ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heatingactivated
32​
ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interfaceactivated
32​
ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detectionactivated
32​
ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistantactivated
32​
ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2activated
32​
ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronicsactivated
32​
ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boostactivated
32​
ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operationactivated
32​
ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lockactivated
32​
ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2activated
32​
ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronicsactivated
32​
ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver sideactivated
32​
ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistanceactivated
32​
ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Functionactivated
32​
ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressoractivated
32​
ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronicsactivated
32​
ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steeringactivated
32​
ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound Systemactivated
32​
ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function moduleactivated
32​
32​
ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric driveactivated
32​
ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronicsactivated
32​
ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range controlactivated
32​
ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radioactivated
32​
ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuneractivated
32​
ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1activated
32​
ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorderactivated
32​
ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS)activated
32​
ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Functionactivated
32​
ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera systemactivated
32​
ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronicsactivated
32​
ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unitactivated
32​
ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aidactivated
32​
ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1activated
32​
ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Displayactivated
32​
ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Managementactivated
32​
ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systemsactivated
32​
ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control moduleactivated
32​
ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuatoractivated
32​
ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start systemactivated
32​
ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronicsactivated
32​
ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronicsactivated
32​
ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging managementactivated
32​
ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding dooractivated
32​
ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding dooractivated
32​
ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noiseactivated
32​
ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal managementactivated
32​
ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery chargeractivated
32​
ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control moduleactivated
32​
ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generatoractivated
32​
ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2activated
32​
ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00activated
32​
ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01activated
32​
ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02activated
32​
ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03activated
32​
ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04activated
32​
ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05activated
32​
ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06activated
32​
ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07activated
32​
ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08activated
32​
ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0Dactivated
32​
ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11activated
32​
ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16activated
32​
ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17activated
32​
ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1Aactivated
32​
ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1Dactivated
32​
ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1Factivated
32​
ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20activated
32​
ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21activated
32​
ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22activated
32​
ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24activated
32​
ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25activated
32​
ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26activated
32​
ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27activated
32​
ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28activated
32​
ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29activated
32​
ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2Aactivated
32​
ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2Eactivated
32​
ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2Factivated
32​
ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35activated
32​
ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36activated
32​
ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37activated
32​
ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38activated
32​
ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39activated
32​
ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3Aactivated
32​
ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3Cactivated
32​
ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3Dactivated
32​
ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40activated
32​
ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41activated
32​
ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43activated
32​
ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45activated
32​
ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48activated
32​
ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49activated
32​
ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51activated
32​
ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52activated
32​
ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53activated
32​
ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55activated
32​
ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56activated
32​
ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58activated
32​
ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59activated
32​
ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5Aactivated
32​
ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5Bactivated
32​
ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5Cactivated
32​
ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5Dactivated
32​
ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5Eactivated
32​
ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5Factivated
32​
ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60activated
32​
ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61activated
32​
ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62activated
32​
ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66activated
32​
ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68activated
32​
ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6Bactivated
32​
ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6Cactivated
32​
ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6Eactivated
32​
ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74activated
32​
ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75activated
32​
ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78activated
32​
ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79activated
32​
ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7Aactivated
32​
ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7Dactivated
32​
ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7Eactivated
32​
ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7Factivated
32​
ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80activated
32​
ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81activated
32​
ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82activated
32​
ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83activated
32​
ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86activated
32​
ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87activated
32​
ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88activated
32​
ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89activated
32​
ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8Bactivated
32​
ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8Cactivated
32​
ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8Dactivated
32​
ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8Eactivated
32​
ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8Factivated
32​
ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90activated
32​
ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91activated
32​
ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92activated
32​
ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93activated
32​
ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94activated
32​
ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95activated
32​
ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96activated
32​
ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97activated
32​
ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98activated
32​
ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99activated
32​
ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9Aactivated
32​
ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9Bactivated
32​
ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9Dactivated
32​
ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9Eactivated
32​
ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9Factivated
32​
ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0activated
32​
ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1activated
32​
ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2activated
32​
ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3activated
32​
ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5activated
32​
ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6activated
32​
ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7activated
32​
ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8activated
32​
ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAAactivated
32​
ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xABactivated
32​
ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xACactivated
32​
ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xADactivated
32​
ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAFactivated
32​
ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0activated
32​
ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1activated
32​
ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2activated
32​
ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3activated
32​
ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4activated
32​
ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5activated
32​
ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6activated
32​
ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7activated
32​
ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8activated
32​
ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9activated
32​
ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBAactivated
32​
ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBBactivated
32​
ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBCactivated
32​
ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBDactivated
32​
ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBEactivated
32​
ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBFactivated
32​
ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0activated
32​
ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1activated
32​
ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2activated
32​
ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3activated
32​
ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4activated
32​
ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5activated
32​
ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6activated
32​
ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7activated
32​
ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8activated
32​
ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9activated
32​
ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCAactivated
32​
ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCBactivated
32​
ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCCactivated
32​
ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCDactivated
32​
ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCEactivated
32​
ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCFactivated
32​
ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0activated
32​
ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1activated
32​
ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2activated
32​
ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3activated
32​
ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4activated
32​
ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5activated
32​
ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6activated
32​
ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7activated
32​
ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8activated
32​
ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9activated
32​
ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDAactivated
32​
ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDBactivated
32​
ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDCactivated
32​
ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDDactivated
32​
ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDEactivated
32​
ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDFactivated
32​
ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0activated
32​
ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1activated
32​
ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2activated
32​
ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3activated
32​
ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4activated
32​
ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5activated
32​
ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6activated
32​
ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7activated
32​
ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8activated
32​
ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9activated
32​
ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEAactivated
32​
ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEBactivated
32​
ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xECactivated
32​
ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEDactivated
32​
ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEEactivated
32​
ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEFactivated
32​
ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0activated
32​
ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1activated
32​
ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2activated
32​
ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3activated
32​
ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4activated
32​
ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5activated
32​
ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6activated
32​
ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7activated
32​
ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8activated
32​
ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9activated
32​
ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFAactivated
32​
ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFBactivated
32​
ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFCactivated
32​
ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFDactivated
32​
ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFEactivated
32​
ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFFactivated
32​
ENG137059-ENG118464-GW_mirror_mode-mirror_mode_busPowertrain data bus
2​
ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typnot active
2​
ENG137065-GW_routing_000 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137066-GW_routing_100 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137067-GW_routing_200 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137068-GW_routing_300 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137069-GW_routing_400 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137070-GW_routing_500 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137071-GW_routing_600 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137072-GW_routing_700 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137073-GW_routing_800 00 00 00 00 00 00 00 00 00 00 00
12​
ENG137074-GW_routing_900 00 00 00 00 00 00 00 00 00 00 00
12​
ENG118779-IDE02583-Multi_function_steering_wheel_control_module Coding Value-Steering wheel Tiptronic switchinstalled
3​
ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-VariantCCS
3​
ENG118779-MAS09758-Multi_function_steering_wheel_control_module Coding Value-Temperature sensornot installed
3​
ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1active
3​
ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2not active
3​
ENG118774-ENG98345-WakeUpMonitor_Activation-Activationactivated
1​
ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activatenot activated
1​
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events
100​
5​
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events12 s
5​
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay0 s
5​
Elapsed Time: 00:28
Thanks!
   #24
downtime
Finland
C?ID=280813
Hmm.. that is not very good that removing CCS clears the error. That gives the assumption that car never had cruise either.
Can you post adamap from 5F. I can tell you then what to disable to remove the error.
   #25
mmhubbard
Illinois, USA
C?ID=404494
Thanks.
I will get the admap for 5F captured.
I know the car originally had standard cruise, but I don't know what all the previous owner might have done, or what the dealer did when they started making changes when they didn't realize it had been modified.
   #26
mmhubbard
Illinois, USA
C?ID=404494
Here is the 5F admap:
;SW:3Q0-035-876 HW:3Q0-035-876 --- Information Electr.
;Component:MU-S-NS-US H25 0241Coding:027300020000000051220002001808001F0203F401200105C6
;EV_MUStd4CTSAT001022EV_MUStd4CTSAT_VW37.rod
;Friday
14​
February
2025​
16:46:11:23435
;VCID: 71BFD080512CA232A05-8024
IDE00001-Production mode00 00 00
3​
IDE00346-Summertime-automaticmanual
1​
IDE00758-Base volume of telephone
50%​
1​
IDE00759-Base volume of speech output
50%​
1​
IDE00760-Microphone sensitivity0 dB
1​
IDE00769-Call number 1 for info callFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE00770-Number 1 for roadside assistanceFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_MessagesOFF
1​
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_MessagesOFF
1​
IDE00845-Wheel circumference0 mm
2​
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control moduleNo
3​
IDE01996-MAS00839-Installation list: specified installations-TV TunerNo
3​
IDE01996-MAS00844-Installation list: specified installations-RadioNo
3​
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control ModuleYes
3​
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1Yes
3​
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2No
3​
IDE01996-MAS04300-Installation list: specified installations-DVD changerNo
3​
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control moduleNo
3​
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control headNo
3​
IDE01996-ENG154341-Installation list: specified installations-Reserved_8No
3​
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1No
3​
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2No
3​
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1No
3​
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2No
3​
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1No
3​
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2No
3​
IDE02121-CD eject buttonEnabled
1​
IDE02122-Developer modeactivated
1​
IDE02330-Call number 2 for info callFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE02331-Number 2 for roadside assistanceFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
0​
3​
IDE02476-MAS03001-Electrical test of speakers-Modeautomatic
49​
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency19000 Hz
49​
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume
36​
49​
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency19000 Hz
49​
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume
36​
49​
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency19000 Hz
49​
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume
36​
49​
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency19000 Hz
49​
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume
36​
49​
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency19000 Hz
49​
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume
36​
49​
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency19000 Hz
49​
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume
36​
49​
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency19000 Hz
49​
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume
36​
49​
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency19000 Hz
49​
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume
36​
49​
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency19000 Hz
49​
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume
36​
49​
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency19000 Hz
49​
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume
36​
49​
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency19000 Hz
49​
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume
36​
49​
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency19000 Hz
49​
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume
36​
49​
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency19000 Hz
49​
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume
36​
49​
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency19000 Hz
49​
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume
36​
49​
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency19000 Hz
49​
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume
36​
49​
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency19000 Hz
49​
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume
36​
49​
IDE02502-Confirmation of installation change05 EC
2​
IDE02607-Wheel pulse
0​
2​
IDE02699-Number 1 for roadside assistanceFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE02701-Number 1 (roaming) for roadside assistanceFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE03902-Automatic ring break diagnosticNo automatic start
1​
4​
IDE04521-Sporadic ring break detectionoptical
1​
IDE04522-Awakening ability on optical databusOFF
1​
IDE04550-Bluetooth: Sniff modeOFF
1​
IDE05111-Fee-based traffic information (TMC)
1537​
2​
IDE05113-Infotainment Recorderactivated
1​
IDE06425-Dynamometer mode: functionalnot activated
1​
IDE08814-IDE04033-Navigation receiver GNSS configuration-CompassOFF
1​
IDE08814-MAS01570-Navigation receiver GNSS configuration-DefaultOn
1​
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPSOFF
1​
IDE08814-MAS07828-Navigation receiver GNSS configuration-GalileoOFF
1​
IDE08814-MAS07829-Navigation receiver GNSS configuration-GlonassOFF
1​
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1OFF
1​
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2OFF
1​
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner
-128​
40​
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio
5​
40​
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)
-128​
40​
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)
-128​
40​
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)
-128​
40​
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB
-128​
40​
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP
-128​
40​
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay
-128​
40​
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter
-128​
40​
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN
-128​
40​
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray
-128​
40​
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice
-128​
40​
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA
-128​
40​
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud
-128​
40​
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD
-128​
40​
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI
-128​
40​
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP
-128​
40​
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP
-128​
40​
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink
-128​
40​
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP
-128​
40​
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB
-3​
40​
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice
-128​
40​
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM
-128​
40​
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep
-128​
40​
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging
-128​
40​
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen
-128​
40​
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning
-128​
40​
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav
-128​
40​
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS
-128​
40​
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online
-128​
40​
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal
-128​
40​
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI
-128​
40​
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN
-128​
40​
IDE10480-MAS10741-Interface for external media: activation-Connection 1activated
4​
IDE10480-MAS10742-Interface for external media: activation-Connection 2not activated
4​
IDE10480-MAS10743-Interface for external media: activation-Connection 3not activated
4​
IDE10480-MAS10744-Interface for external media: activation-Connection 4not activated
4​
IDE10604-Menu entries for mobile online servicesnot activated
1​
IDE11122-Country identification: country of sale HMIUS
2​
IDE11502-ENG127601-Locked menu contents-FB_CAR_0non_blocked
21​
IDE11502-ENG127602-Locked menu contents-FB_CAR_1non_blocked
21​
IDE11502-ENG127611-Locked menu contents-FB_CAR_10non_blocked
21​
IDE11502-ENG127612-Locked menu contents-FB_CAR_11non_blocked
21​
IDE11502-ENG127613-Locked menu contents-FB_CAR_12non_blocked
21​
IDE11502-ENG127614-Locked menu contents-FB_CAR_13non_blocked
21​
IDE11502-ENG127615-Locked menu contents-FB_CAR_14non_blocked
21​
IDE11502-ENG127616-Locked menu contents-FB_CAR_15non_blocked
21​
IDE11502-ENG127617-Locked menu contents-FB_CAR_16non_blocked
21​
IDE11502-ENG127618-Locked menu contents-FB_CAR_17non_blocked
21​
IDE11502-ENG127619-Locked menu contents-FB_CAR_18non_blocked
21​
IDE11502-ENG127620-Locked menu contents-FB_CAR_19non_blocked
21​
IDE11502-ENG127603-Locked menu contents-FB_CAR_2non_blocked
21​
IDE11502-ENG127621-Locked menu contents-FB_CAR_20non_blocked
21​
IDE11502-ENG127622-Locked menu contents-FB_CAR_21non_blocked
21​
IDE11502-ENG127623-Locked menu contents-FB_CAR_22non_blocked
21​
IDE11502-ENG127624-Locked menu contents-FB_CAR_23non_blocked
21​
IDE11502-ENG127604-Locked menu contents-FB_CAR_3non_blocked
21​
IDE11502-ENG127605-Locked menu contents-FB_CAR_4non_blocked
21​
IDE11502-ENG127606-Locked menu contents-FB_CAR_5non_blocked
21​
IDE11502-ENG127607-Locked menu contents-FB_CAR_6non_blocked
21​
IDE11502-ENG127608-Locked menu contents-FB_CAR_7non_blocked
21​
IDE11502-ENG127609-Locked menu contents-FB_CAR_8non_blocked
21​
IDE11502-ENG127610-Locked menu contents-FB_CAR_9non_blocked
21​
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0non_blocked
21​
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1non_blocked
21​
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10non_blocked
21​
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11non_blocked
21​
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12non_blocked
21​
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13non_blocked
21​
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14non_blocked
21​
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15non_blocked
21​
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16non_blocked
21​
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17non_blocked
21​
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18non_blocked
21​
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19non_blocked
21​
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2non_blocked
21​
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20non_blocked
21​
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21non_blocked
21​
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22non_blocked
21​
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23non_blocked
21​
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3non_blocked
21​
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4non_blocked
21​
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5non_blocked
21​
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6non_blocked
21​
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7non_blocked
21​
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8non_blocked
21​
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9non_blocked
21​
IDE11502-ENG127625-Locked menu contents-FB_MISC_0non_blocked
21​
IDE11502-ENG127626-Locked menu contents-FB_MISC_1non_blocked
21​
IDE11502-ENG127635-Locked menu contents-FB_MISC_10non_blocked
21​
IDE11502-ENG127636-Locked menu contents-FB_MISC_11non_blocked
21​
IDE11502-ENG127637-Locked menu contents-FB_MISC_12non_blocked
21​
IDE11502-ENG127638-Locked menu contents-FB_MISC_13non_blocked
21​
IDE11502-ENG127639-Locked menu contents-FB_MISC_14non_blocked
21​
IDE11502-ENG127640-Locked menu contents-FB_MISC_15non_blocked
21​
IDE11502-ENG127641-Locked menu contents-FB_MISC_16non_blocked
21​
IDE11502-ENG127642-Locked menu contents-FB_MISC_17non_blocked
21​
IDE11502-ENG127643-Locked menu contents-FB_MISC_18non_blocked
21​
IDE11502-ENG127644-Locked menu contents-FB_MISC_19non_blocked
21​
IDE11502-ENG127627-Locked menu contents-FB_MISC_2non_blocked
21​
IDE11502-ENG127645-Locked menu contents-FB_MISC_20non_blocked
21​
IDE11502-ENG127646-Locked menu contents-FB_MISC_21non_blocked
21​
IDE11502-ENG127647-Locked menu contents-FB_MISC_22non_blocked
21​
IDE11502-ENG127648-Locked menu contents-FB_MISC_23non_blocked
21​
IDE11502-ENG127649-Locked menu contents-FB_MISC_24non_blocked
21​
IDE11502-ENG127650-Locked menu contents-FB_MISC_25non_blocked
21​
IDE11502-ENG127651-Locked menu contents-FB_MISC_26non_blocked
21​
IDE11502-ENG127652-Locked menu contents-FB_MISC_27non_blocked
21​
IDE11502-ENG127653-Locked menu contents-FB_MISC_28non_blocked
21​
IDE11502-ENG127654-Locked menu contents-FB_MISC_29non_blocked
21​
IDE11502-ENG127628-Locked menu contents-FB_MISC_3non_blocked
21​
IDE11502-ENG127655-Locked menu contents-FB_MISC_30non_blocked
21​
IDE11502-ENG127656-Locked menu contents-FB_MISC_31non_blocked
21​
IDE11502-ENG127657-Locked menu contents-FB_MISC_32non_blocked
21​
IDE11502-ENG127658-Locked menu contents-FB_MISC_33non_blocked
21​
IDE11502-ENG127659-Locked menu contents-FB_MISC_34non_blocked
21​
IDE11502-ENG127660-Locked menu contents-FB_MISC_35non_blocked
21​
IDE11502-ENG127661-Locked menu contents-FB_MISC_36non_blocked
21​
IDE11502-ENG127662-Locked menu contents-FB_MISC_37non_blocked
21​
IDE11502-ENG127663-Locked menu contents-FB_MISC_38non_blocked
21​
IDE11502-ENG127664-Locked menu contents-FB_MISC_39non_blocked
21​
IDE11502-ENG127629-Locked menu contents-FB_MISC_4non_blocked
21​
IDE11502-ENG127665-Locked menu contents-FB_MISC_40non_blocked
21​
IDE11502-ENG127666-Locked menu contents-FB_MISC_41non_blocked
21​
IDE11502-ENG127667-Locked menu contents-FB_MISC_42non_blocked
21​
IDE11502-ENG127668-Locked menu contents-FB_MISC_43non_blocked
21​
IDE11502-ENG127669-Locked menu contents-FB_MISC_44non_blocked
21​
IDE11502-ENG127670-Locked menu contents-FB_MISC_45non_blocked
21​
IDE11502-ENG127671-Locked menu contents-FB_MISC_46non_blocked
21​
IDE11502-ENG127672-Locked menu contents-FB_MISC_47non_blocked
21​
IDE11502-ENG127630-Locked menu contents-FB_MISC_5non_blocked
21​
IDE11502-ENG127631-Locked menu contents-FB_MISC_6non_blocked
21​
IDE11502-ENG127632-Locked menu contents-FB_MISC_7non_blocked
21​
IDE11502-ENG127633-Locked menu contents-FB_MISC_8non_blocked
21​
IDE11502-ENG127634-Locked menu contents-FB_MISC_9non_blocked
21​
IDE11502-ENG127561-Locked menu contents-FB_NAV_0non_blocked
21​
IDE11502-ENG127562-Locked menu contents-FB_NAV_1non_blocked
21​
IDE11502-ENG127571-Locked menu contents-FB_NAV_10non_blocked
21​
IDE11502-ENG127572-Locked menu contents-FB_NAV_11non_blocked
21​
IDE11502-ENG127573-Locked menu contents-FB_NAV_12non_blocked
21​
IDE11502-ENG127574-Locked menu contents-FB_NAV_13non_blocked
21​
IDE11502-ENG127575-Locked menu contents-FB_NAV_14non_blocked
21​
IDE11502-ENG127576-Locked menu contents-FB_NAV_15non_blocked
21​
IDE11502-ENG127577-Locked menu contents-FB_NAV_16non_blocked
21​
IDE11502-ENG127578-Locked menu contents-FB_NAV_17non_blocked
21​
IDE11502-ENG127579-Locked menu contents-FB_NAV_18non_blocked
21​
IDE11502-ENG127580-Locked menu contents-FB_NAV_19non_blocked
21​
IDE11502-ENG127563-Locked menu contents-FB_NAV_2non_blocked
21​
IDE11502-ENG127581-Locked menu contents-FB_NAV_20non_blocked
21​
IDE11502-ENG127582-Locked menu contents-FB_NAV_21non_blocked
21​
IDE11502-ENG127583-Locked menu contents-FB_NAV_22non_blocked
21​
IDE11502-ENG127584-Locked menu contents-FB_NAV_23non_blocked
21​
IDE11502-ENG127585-Locked menu contents-FB_NAV_24non_blocked
21​
IDE11502-ENG127586-Locked menu contents-FB_NAV_25non_blocked
21​
IDE11502-ENG127587-Locked menu contents-FB_NAV_26non_blocked
21​
IDE11502-ENG127588-Locked menu contents-FB_NAV_27non_blocked
21​
IDE11502-ENG127589-Locked menu contents-FB_NAV_28non_blocked
21​
IDE11502-ENG127590-Locked menu contents-FB_NAV_29non_blocked
21​
IDE11502-ENG127564-Locked menu contents-FB_NAV_3non_blocked
21​
IDE11502-ENG127591-Locked menu contents-FB_NAV_30non_blocked
21​
IDE11502-ENG127592-Locked menu contents-FB_NAV_31non_blocked
21​
IDE11502-ENG127593-Locked menu contents-FB_NAV_32non_blocked
21​
IDE11502-ENG127594-Locked menu contents-FB_NAV_33non_blocked
21​
IDE11502-ENG127595-Locked menu contents-FB_NAV_34non_blocked
21​
IDE11502-ENG127596-Locked menu contents-FB_NAV_35non_blocked
21​
IDE11502-ENG127597-Locked menu contents-FB_NAV_36non_blocked
21​
IDE11502-ENG127598-Locked menu contents-FB_NAV_37non_blocked
21​
IDE11502-ENG127599-Locked menu contents-FB_NAV_38non_blocked
21​
IDE11502-ENG127600-Locked menu contents-FB_NAV_39non_blocked
21​
IDE11502-ENG127565-Locked menu contents-FB_NAV_4non_blocked
21​
IDE11502-ENG127566-Locked menu contents-FB_NAV_5non_blocked
21​
IDE11502-ENG127567-Locked menu contents-FB_NAV_6non_blocked
21​
IDE11502-ENG127568-Locked menu contents-FB_NAV_7non_blocked
21​
IDE11502-ENG127569-Locked menu contents-FB_NAV_8non_blocked
21​
IDE11502-ENG127570-Locked menu contents-FB_NAV_9non_blocked
21​
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0non_blocked
21​
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1non_blocked
21​
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10non_blocked
21​
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11non_blocked
21​
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12non_blocked
21​
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13non_blocked
21​
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14non_blocked
21​
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15non_blocked
21​
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2non_blocked
21​
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3non_blocked
21​
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4non_blocked
21​
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5non_blocked
21​
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6non_blocked
21​
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7non_blocked
21​
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8non_blocked
21​
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9non_blocked
21​
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0non_blocked
21​
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1non_blocked
21​
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10non_blocked
21​
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11non_blocked
21​
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12non_blocked
21​
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13non_blocked
21​
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14non_blocked
21​
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15non_blocked
21​
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2non_blocked
21​
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3non_blocked
21​
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4non_blocked
21​
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5non_blocked
21​
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6non_blocked
21​
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7non_blocked
21​
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8non_blocked
21​
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9non_blocked
21​
IDE11503-Satellite radio tuner: pre-activated subscription07
1​
MAS00951-BluetoothOn
1​
MAS02809-MAS02870-Check tone frequency-High note frequency range4000 Hz
6​
MAS02809-MAS02871-Check tone frequency-Medium note frequency range1000 Hz
6​
MAS02809-MAS02872-Check tone frequency-Low note frequency range100 Hz
6​
MAS03782-WLANOn
1​
ENG117917-BAP_Debug_Mode_Releasenot_released
1​
ENG104140-Bluetooth_Phonebook_Access_ProfilePBAP
1​
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatizationnot activated
60​
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimernot activated
60​
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_offnot activated
60​
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_highnot activated
60​
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstillnot activated
60​
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilationnot activated
60​
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimernot activated
60​
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_offnot activated
60​
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_highnot activated
60​
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstillnot activated
60​
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistentnot activated
60​
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimernot activated
60​
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_offnot activated
60​
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_highnot activated
60​
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstillnot activated
60​
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACCnot activated
60​
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimernot activated
60​
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_offnot activated
60​
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_highnot activated
60​
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstillnot activated
60​
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_keynot activated
60​
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimernot activated
60​
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_offnot activated
60​
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_highnot activated
60​
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstillnot activated
60​
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adbluenot activated
60​
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimernot activated
60​
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_offnot activated
60​
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_highnot activated
60​
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstillnot activated
60​
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_dampernot activated
60​
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimernot activated
60​
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_offnot activated
60​
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_highnot activated
60​
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstillnot activated
60​
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illuminationactivated
60​
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimernot activated
60​
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_offnot activated
60​
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_highactivated
60​
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstillnot activated
60​
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slopenot activated
60​
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimernot activated
60​
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_offnot activated
60​
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_highnot activated
60​
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstillnot activated
60​
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identificationnot activated
60​
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimernot activated
60​
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_offnot activated
60​
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_highnot activated
60​
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstillnot activated
60​
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heatingnot activated
60​
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimernot activated
60​
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_offnot activated
60​
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_highnot activated
60​
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstillnot activated
60​
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awvnot activated
60​
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimernot activated
60​
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_offnot activated
60​
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_highnot activated
60​
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstillnot activated
60​
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_managementnot activated
60​
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimernot activated
60​
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_offnot activated
60​
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_highnot activated
60​
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstillnot activated
60​
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmEactivated
60​
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimernot activated
60​
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_offnot activated
60​
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_highactivated
60​
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstillnot activated
60​
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computeractivated
60​
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimernot activated
60​
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_offnot activated
60​
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_highactivated
60​
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstillnot activated
60​
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Functionactivated
60​
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimernot activated
60​
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_offnot activated
60​
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_highactivated
60​
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstillnot activated
60​
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirroractivated
60​
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimernot activated
60​
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_offnot activated
60​
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_highactivated
60​
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstillnot activated
60​
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_lockingactivated
60​
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimernot activated
60​
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_offnot activated
60​
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_highactivated
60​
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstillnot activated
60​
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_masteractivated
60​
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimernot activated
60​
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_offnot activated
60​
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_highactivated
60​
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstillnot activated
60​
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charismanot activated
60​
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimernot activated
60​
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_offnot activated
60​
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_highactivated
60​
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstillnot activated
60​
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configurationactivated
60​
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimernot activated
60​
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_offnot activated
60​
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_highactivated
60​
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstillnot activated
60​
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clockactivated
60​
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimernot activated
60​
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_offnot activated
60​
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_highactivated
60​
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstillnot activated
60​
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compassactivated
60​
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimernot activated
60​
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_offnot activated
60​
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_highactivated
60​
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstillnot activated
60​
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assistnot activated
60​
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimernot activated
60​
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_offnot activated
60​
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_highnot activated
60​
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstillnot activated
60​
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configurationnot activated
60​
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimernot activated
60​
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_offnot activated
60​
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_highnot activated
60​
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstillnot activated
60​
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_schoolactivated
60​
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimernot activated
60​
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_offnot activated
60​
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_highactivated
60​
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstillnot activated
60​
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecallactivated
60​
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimernot activated
60​
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_offnot activated
60​
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_highactivated
60​
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstillnot activated
60​
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assistnot activated
60​
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimernot activated
60​
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_offnot activated
60​
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_highnot activated
60​
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstillnot activated
60​
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENIactivated
60​
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimernot activated
60​
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_offnot activated
60​
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_highactivated
60​
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstillnot activated
60​
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illuminationactivated
60​
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimernot activated
60​
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_offnot activated
60​
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_highactivated
60​
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstillnot activated
60​
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_displaynot activated
60​
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimernot activated
60​
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_offnot activated
60​
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_highnot activated
60​
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstillnot activated
60​
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybridnot activated
60​
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimernot activated
60​
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_offnot activated
60​
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_highnot activated
60​
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstillnot activated
60​
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistantnot activated
60​
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimernot activated
60​
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_offnot activated
60​
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_highnot activated
60​
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstillnot activated
60​
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warningactivated
60​
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimernot activated
60​
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_offnot activated
60​
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_highactivated
60​
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstillnot activated
60​
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jockernot activated
60​
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimernot activated
60​
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_offnot activated
60​
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_highnot activated
60​
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstillnot activated
60​
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_visionnot activated
60​
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimernot activated
60​
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_offnot activated
60​
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_highnot activated
60​
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstillnot activated
60​
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_levelnot activated
60​
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimernot activated
60​
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_offnot activated
60​
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_highnot activated
60​
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstillnot activated
60​
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdcnot activated
60​
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimernot activated
60​
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_offnot activated
60​
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_highnot activated
60​
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstillnot activated
60​
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assistnot activated
60​
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimernot activated
60​
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_offnot activated
60​
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_highactivated
60​
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstillnot activated
60​
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdkactivated
60​
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimernot activated
60​
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_offnot activated
60​
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_highactivated
60​
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstillnot activated
60​
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainmentnot activated
60​
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimernot activated
60​
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_offnot activated
60​
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_highnot activated
60​
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstillnot activated
60​
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_loadnot activated
60​
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimernot activated
60​
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_offnot activated
60​
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_highnot activated
60​
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstillnot activated
60​
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identificationactivated
60​
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimernot activated
60​
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_offnot activated
60​
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_highactivated
60​
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstillnot activated
60​
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configurationnot activated
60​
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimernot activated
60​
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_offnot activated
60​
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_highnot activated
60​
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstillnot activated
60​
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumaticnot activated
60​
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimernot activated
60​
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_offnot activated
60​
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_highnot activated
60​
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstillnot activated
60​
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_siaactivated
60​
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimernot activated
60​
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_offnot activated
60​
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_highactivated
60​
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstillnot activated
60​
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_viewnot activated
60​
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimernot activated
60​
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_offnot activated
60​
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_highnot activated
60​
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstillnot activated
60​
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functionsnot activated
60​
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimernot activated
60​
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_offnot activated
60​
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_highnot activated
60​
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstillnot activated
60​
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoilernot activated
60​
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimernot activated
60​
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_offnot activated
60​
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_highnot activated
60​
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstillnot activated
60​
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMInot activated
60​
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimernot activated
60​
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_offnot activated
60​
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_highnot activated
60​
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstillnot activated
60​
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasonsnot activated
60​
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimernot activated
60​
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_offnot activated
60​
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_highnot activated
60​
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstillnot activated
60​
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistantnot activated
60​
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimernot activated
60​
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_offnot activated
60​
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_highnot activated
60​
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstillnot activated
60​
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tunernot activated
60​
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimernot activated
60​
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_offnot activated
60​
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_highnot activated
60​
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstillnot activated
60​
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdonot activated
60​
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimernot activated
60​
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_offnot activated
60​
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_highnot activated
60​
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstillnot activated
60​
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_ratingactivated
60​
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimernot activated
60​
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_offnot activated
60​
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_highactivated
60​
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstillnot activated
60​
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vinactivated
60​
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimernot activated
60​
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_offnot activated
60​
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_highactivated
60​
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstillnot activated
60​
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognitionnot activated
60​
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimernot activated
60​
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_offnot activated
60​
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_highnot activated
60​
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstillnot activated
60​
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windowsactivated
60​
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimernot activated
60​
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_offnot activated
60​
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_highactivated
60​
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstillnot activated
60​
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiperactivated
60​
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimernot activated
60​
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_offnot activated
60​
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_highactivated
60​
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstillnot activated
60​
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrolnot activated
60​
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimernot activated
60​
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_offnot activated
60​
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_highnot activated
60​
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstillnot activated
60​
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05not activated
64​
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_busExtended data bus
64​
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06not activated
64​
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_busSuspension data bus
64​
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2Dnot activated
64​
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_busnot activated
64​
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24not activated
64​
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_busnot activated
64​
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03not activated
64​
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_busComfort data bus
64​
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1Bactivated
64​
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_busTerminal 15
64​
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25not activated
64​
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_busPowertrain data bus
64​
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23activated
64​
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_busInfotainment data bus
64​
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26activated
64​
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_busSuspension data bus
64​
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0Dactivated
64​
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_busComfort data bus
64​
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17not activated
64​
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_busInfotainment data bus
64​
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16not activated
64​
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_busComfort data bus
64​
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01activated
64​
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_busComfort data bus
64​
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02not activated
64​
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_busComfort data bus
64​
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11activated
64​
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_busComfort data bus
64​
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15activated
64​
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_busInfotainment data bus
64​
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10not activated
64​
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_busComfort data bus
64​
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33activated
64​
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_busComfort data bus
64​
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3CComfort data bus
64​
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3Cnot activated
64​
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37activated
64​
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_busComfort data bus
64​
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38not activated
64​
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_busComfort data bus
64​
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09activated
64​
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_busComfort data bus
64​
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04not activated
64​
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_busComfort data bus
64​
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1Dnot activated
64​
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_busPowertrain data bus
64​
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08activated
64​
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_busComfort data bus
64​
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19activated
64​
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_busExtended data bus
64​
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0Factivated
64​
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_busComfort data bus
64​
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34not activated
64​
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34Infotainment data bus
64​
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0Eactivated
64​
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_busComfort data bus
64​
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18not activated
64​
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_busnot activated
64​
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0Anot activated
64​
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_busTerminal 15
64​
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20not activated
64​
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_busComfort data bus
64​
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3Anot activated
64​
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3AExtended data bus
64​
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39not activated
64​
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39Infotainment data bus
64​
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2Enot activated
64​
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_busComfort data bus
64​
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1Fnot activated
64​
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_busPowertrain data bus
64​
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3Bnot activated
64​
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3BComfort data bus
64​
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3Fnot activated
64​
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3FComfort data bus
64​
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3Enot activated
64​
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3EComfort data bus
64​
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12activated
64​
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_busComfort data bus
64​
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1Enot activated
64​
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_busnot activated
64​
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35not activated
64​
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35Comfort data bus
64​
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27not activated
64​
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_busInfotainment data bus
64​
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1Anot activated
64​
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_busExtended data bus
64​
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07activated
64​
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_busSuspension data bus
64​
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21activated
64​
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_busExtended data bus
64​
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36not activated
64​
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36Comfort data bus
64​
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2Cnot activated
64​
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_busComfort data bus
64​
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14not activated
64​
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_busTerminal 15
64​
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13activated
64​
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_busComfort data bus
64​
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0Bnot activated
64​
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_busInfotainment data bus
64​
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22not activated
64​
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_busInfotainment data bus
64​
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0Cactivated
64​
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_busComfort data bus
64​
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_keyNot available
8​
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_busComfort data bus
8​
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_schoolavailable.
8​
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_busInfotainment data bus
8​
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFLavailable.
8​
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_busInfotainment data bus
8​
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_levelNot available
8​
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_busPowertrain data bus
8​
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_loweringNot available
8​
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_busSuspension data bus
8​
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-ReservedNot available
8​
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1Comfort data bus
8​
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2Comfort data bus
8​
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3Not available
8​
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VINavailable.
8​
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_busComfort data bus
8​
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1
0​
6​
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2
50​
6​
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3
100​
6​
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1
0​
6​
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2
50​
6​
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3
100​
6​
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1
0​
6​
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2
50​
6​
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3
100​
6​
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1
0​
6​
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2
50​
6​
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3
100​
6​
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1
0​
12​
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2
10​
12​
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3
100​
12​
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4
150​
12​
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5
220​
12​
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6
253​
12​
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1
1%​
12​
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2
1%​
12​
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3
8%​
12​
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4
20%​
12​
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5
60%​
12​
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6
100%​
12​
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE
40​
ENG117809-p_damping_Display5 ms
1​
ENG117808-p_HMI_Display
13%​
1​
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset
0​
2​
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset
0​
2​
ENG117910-Set_Remote_Test_Channel_ScanningConditions not correct or request sequence error
2​
ENG117908-Shift_Remote_Test_Frequency_AMConditions not correct or request sequence error
2​
ENG117907-Shift_Remote_Test_Frequency_FMConditions not correct or request sequence error
2​
ENG117906-Shift_Remote_Test_VolumeConditions not correct or request sequence error
2​
ENG117919-Startup_Screen_Sticker_HMI00 01
2​
ENG109862-ENG117847-Vehicle_configuration-advanced_range_displayOFF
30​
ENG109862-ENG249824-Vehicle_configuration-AliBoxOFF
30​
ENG109862-ENG142146-Vehicle_configuration-allow_message_editingOFF
30​
ENG109862-ENG130249-Vehicle_configuration-Apple_DIOOn
30​
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_WirelessOFF
30​
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_LifeOFF
30​
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_iosOFF
30​
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_WirelessOFF
30​
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_WirelessOFF
30​
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epblocked
30​
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant
0​
30​
ENG109862-ENG263540-Vehicle_configuration-correction_e_mileage
0​
30​
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_callOn
30​
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_supportOFF
30​
ENG109862-ENG185778-Vehicle_configuration-FoDSWaP
30​
ENG109862-ENG130248-Vehicle_configuration-Google_GALOn
30​
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_WirelessOFF
30​
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverartsOFF
30​
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_otherOFF
30​
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverartsOFF
30​
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_otherOFF
30​
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_datanot activated
30​
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_ExtenderDeactivated
30​
ENG109862-ENG261211-Vehicle_configuration-internet_over_WLAN_default_settingOFF
30​
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1not installed
30​
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2not installed
30​
ENG109862-ENG127492-Vehicle_configuration-LGIOFF
30​
ENG109862-ENG130246-Vehicle_configuration-LTE_modulactivated
30​
ENG109862-ENG142142-Vehicle_configuration-map_email_supportOFF
30​
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_supportOFF
30​
ENG109862-ENG142141-Vehicle_configuration-map_sms_supportOFF
30​
ENG109862-ENG142152-Vehicle_configuration-Map_Style
0​
30​
ENG109862-ENG152537-Vehicle_configuration-media_controlnot activated
30​
ENG109862-ENG138662-Vehicle_configuration-Mirror_linkOFF
30​
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_CodeMIB_EU
30​
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_PreferenceRGB565
30​
ENG109862-ENG117843-Vehicle_configuration-my_audiOFF
30​
ENG109862-ENG117845-Vehicle_configuration-online_dictationOFF
30​
ENG109862-ENG127495-Vehicle_configuration-online_mediaOFF
30​
ENG109862-ENG117840-Vehicle_configuration-online_navigationOFF
30​
ENG109862-ENG117837-Vehicle_configuration-online_POIOFF
30​
ENG109862-ENG117838-Vehicle_configuration-online_POI_voiceOFF
30​
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_servicesOFF
30​
ENG109862-ENG152553-Vehicle_configuration-online_radioDeactivated
30​
ENG109862-ENG117841-Vehicle_configuration-online_street_viewOFF
30​
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unitOFF
30​
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold00
30​
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis00
30​
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy
0​
30​
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_modeData & language service active
30​
ENG109862-ENG117844-Vehicle_configuration-picture_naviOn
30​
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parkingnot activated
30​
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_usenot activated
30​
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest
0​
30​
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgiOFF
30​
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzoOFF
30​
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_VersionPSD_1.5
30​
ENG109862-ENG117846-Vehicle_configuration-remote_HMIOFF
30​
ENG109862-ENG138661-Vehicle_configuration-RSE_software_componentactivated
30​
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_opennot activated
30​
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_thresholdnot activated
30​
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafenot activated
30​
ENG109862-ENG126143-Vehicle_configuration-RVC_video_inputFBAS
30​
ENG109862-ENG152556-Vehicle_configuration-scon_telephonynot activated
30​
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivationno restriction
30​
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flagno_region
30​
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switchnot activated
30​
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switchnot installed
30​
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_supportOFF
30​
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmiactivated
30​
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode
0​
30​
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_holdOFF
30​
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_callingOn
30​
ENG109862-ENG130247-Vehicle_configuration-Support_second_phoneOn
30​
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_locationOFF
30​
ENG109862-ENG126994-Vehicle_configuration-TPEG_availabilityOFF
30​
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_drivinglocked
30​
ENG109862-ENG137647-Vehicle_configuration-UOTAOFF
30​
ENG109862-ENG167532-Vehicle_configuration-UOTA_2OFF
30​
ENG109862-ENG117852-Vehicle_configuration-UPnPOFF
30​
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_soundnot activated
30​
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_soundnot activated
30​
ENG109862-ENG152558-Vehicle_configuration-voice_over_ltenot activated
30​
ENG109862-ENG117836-Vehicle_configuration-VZAProOFF
30​
ENG109862-ENG127494-Vehicle_configuration-VZOOFF
30​
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMIOFF
30​
ENG109862-ENG117842-Vehicle_configuration-WIFI_HotspotOFF
30​
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switchnot activated
30​
Elapsed Time: 00:41
   #27
downtime
Finland
C?ID=280813
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimernot activated60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_offnot activated60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_highactivated60
Put all these to not activated
   #28
mmhubbard
Illinois, USA
C?ID=404494
Thanks. I set all those to not activated and still had the error, so I also set this one to not activated, but it didn't make any difference either.
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function\activated60
Here is the scan after the changes:
VIN: 3VW447AU8GM007430   License Plate:
Mileage: 51102km-31753mi   Repair Order: new1
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 2B 32 42 44 47 52 55 5F 75
          A5 A9
VIN: 3VW447AU8GM007430   Mileage: 51102km-31753miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 766D2359
   Coding: 091D00124404002F1000
   Shop #: WSC 33076 003 104857
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F3B16F88798F4C2F61-807A
   VINID: 0E69C410746521774000710300BB87D739
Readiness: 1110 1101
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01505270109 CVN: 0000EE8B
   Shop #: WSC 00066 790 00202
   ROD: EV_TCMDQ250021.rod
   VCID: 1C61D134E62E7F5AA33-8048
   Revision: 00000000    Serial number: 62805000001299
   Coding: 01FA6BA154200973007B020341C36880D62A9000408216B6004350D1C009
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AADF7AC0C5AE16A11F-802E
   Revision: 00021000    Serial number: 0370694598 Dataset Number: V03935197ZB 0001
   Coding: 030C0C
   Shop #: WSC 01383 790 50316
   VCID: 3A2D37AC4CDA216A51F-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000101004012111402
   VCID: 42DD4F4C240A69AA09F-8016
   Air quality sensor:
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86580306152031 Dataset Number: 5GM063v____ 0059
   Coding: 00111B464041A27969E44000001407281800000000000000000000000000
   Shop #: WSC 00070 123 12345
   ROD: EV_BCMBOSCH_015.rod
   Component: WWS    150430  043 0581
   Serial number:         150716102540
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M07D07H01M57S57S8
   Coding: 028877
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694814510102150651
   Coding: 181803
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 31051541350039 Dataset Number: V03935209LD 0002
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 372B2E987FC83C02AE1-8062
   Serial number: 003GCR0255K4 Dataset Number: 5GM003V____ 0046
   VCID: 47CB5E580F284C82DE1-8012
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J1500034LPA05
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 35700000000115647411
   Subsystem 3 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 3580000000010B547416
   Subsystem 4 - Part No SW: -----------    HW: 480 402 005 15
   Serial number: 3510002B11A2DCD2B269
   Subsystem 5 - Part No SW: -----------    HW: 480 401 805 15
   Serial number: 3520002B11B0CB34A25/
   Subsystem 6 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3550002B71B41485529/
   Subsystem 7 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3560002B71B4148141B.
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150603400078
   Coding: 0610
   Shop #: WSC 12345 123 61029
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045189547E9EA79A7B3-8050
          B1149 13 [00001001] - Open Circuit
                    Reset counter: 243
                    Mileage: 51102 km
                    Date: 2025.02.15
                    Time: 10:51:19
                    Ubat 30 Voltage: 12.20 V
                    Ignition State: On
                    Terminal 15: 11.40 V
                    A/D #1: 97.65 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3196
   Coding: 0BAD111B7984CF0502087A021000000000000000
   VCID: 2A0D07ECBC7A91EA21F-807E
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 17061510002481 Dataset Number: 5G0067V____ 2215
   Coding: 0101003830085800FB00022B9C0F00000001050000000000000000000000
   GVL: 01503C5000000600408C10008000CC0000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E49025448E127CD-8020
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160000291600106062
   Coding: 29FFFF
   Revision: 00000000    Serial number: 15000147802002
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07027
   VCID: 343119946EBED71A8B3-8060
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00031.03.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 150615060506C1 Dataset Number: V03935214VB 0007
   Coding: 003F1320DC00040000000001
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 43D34A483B1060A2029-8016
   Serial number: 00000000000001537970
   Coding: 011000
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Dataset Number: 5GM074V____ 0418
   Coding: 9102
   Shop #: WSC 00046 000 00000
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA007UTT Dataset Number: 5GM050v____ 0212
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6D87CCF04D1446D284D-8038
   Serial number: 180615060507AA Dataset Number: V03935214VC 0007
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   Serial number: 00000000000001495359
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 021203010B000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D945442A067BBA1FB-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0241
   Serial number: VWZAZ2R0232869 Dataset Number: 5G0CV1v____ 0001
   Coding: 027300020000000051220002001808001F0203F401200105C6
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 71BFD080512CA232A05-8024
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU301J11
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 243
                    Mileage: 51102 km
                    Date: 2025.02.15
                    Time: 10:51:23
                    Voltage terminal 30: 12.0 V
                    BAP-BAP_Function_ID: 02
   Component: OCULowMQBUS   007 0564
   Dataset Number: 561098V____ 0409
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0060
   Serial number: 10000016023    Dataset Number: 5G0HL1V____ 0049
   Coding: 0101010101020306000301000000000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C2131B446EE1F5A433-8068
   Component: SAS-GEN 2     H06 0014
   Serial number: 150523202386
   VCID: 6B83C2E8730048E29A9-803E
End----------(Elapsed Time: 01:47, VBatt start/end: 12.2V/12.1V)-----------
Here is the admap for 5F:
;SW:3Q0-035-876 HW:3Q0-035-876 --- Information Electr.
;Component:MU-S-NS-US H25 0241Coding:027300020000000051220002001808001F0203F401200105C6
;EV_MUStd4CTSAT001022EV_MUStd4CTSAT_VW37.rod
;Saturday
15​
February
2025​
11:08:08:23435
;VCDS Version: Release 24.7.1 (x64) Data version: 20240919 DS356.3
;VCID: 71BFD080512CA232A05-8024
IDE00001-Production mode00 00 00
3​
IDE00346-Summertime-automaticmanual
1​
IDE00758-Base volume of telephone
50%​
1​
IDE00759-Base volume of speech output
50%​
1​
IDE00760-Microphone sensitivity0 dB
1​
IDE00769-Call number 1 for info callFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE00770-Number 1 for roadside assistanceFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_MessagesOFF
1​
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_MessagesOFF
1​
IDE00845-Wheel circumference0 mm
2​
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control moduleNo
3​
IDE01996-MAS00839-Installation list: specified installations-TV TunerNo
3​
IDE01996-MAS00844-Installation list: specified installations-RadioNo
3​
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control ModuleYes
3​
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1Yes
3​
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2No
3​
IDE01996-MAS04300-Installation list: specified installations-DVD changerNo
3​
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control moduleNo
3​
IDE01996-SFT271943-Installation list: specified installations-Multimedia system control headNo
3​
IDE01996-ENG154341-Installation list: specified installations-Reserved_8No
3​
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1No
3​
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2No
3​
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1No
3​
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2No
3​
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1No
3​
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2No
3​
IDE02121-CD eject buttonEnabled
1​
IDE02122-Developer modeactivated
1​
IDE02330-Call number 2 for info callFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE02331-Number 2 for roadside assistanceFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE02332-Deactivate production mode
0​
3​
IDE02476-MAS03001-Electrical test of speakers-Modeautomatic
49​
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency19000 Hz
49​
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume
36​
49​
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency19000 Hz
49​
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume
36​
49​
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency19000 Hz
49​
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume
36​
49​
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency19000 Hz
49​
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume
36​
49​
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency19000 Hz
49​
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume
36​
49​
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency19000 Hz
49​
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume
36​
49​
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency19000 Hz
49​
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume
36​
49​
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency19000 Hz
49​
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume
36​
49​
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency19000 Hz
49​
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume
36​
49​
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency19000 Hz
49​
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume
36​
49​
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency19000 Hz
49​
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume
36​
49​
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency19000 Hz
49​
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume
36​
49​
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency19000 Hz
49​
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume
36​
49​
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency19000 Hz
49​
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume
36​
49​
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency19000 Hz
49​
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume
36​
49​
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency19000 Hz
49​
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume
36​
49​
IDE02502-Confirmation of installation change05 EC
2​
IDE02607-Wheel pulse
0​
2​
IDE02699-Number 1 for roadside assistanceFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE02701-Number 1 (roaming) for roadside assistanceFF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
23​
IDE03902-Automatic ring break diagnosticNo automatic start
1​
IDE04331-Selection of release codes for a SWaP functionFF FF FF FF
4​
IDE04521-Sporadic ring break detectionoptical
1​
IDE04522-Awakening ability on optical databusOFF
1​
IDE04550-Bluetooth: Sniff modeOFF
1​
IDE05111-Fee-based traffic information (TMC)
1537​
2​
IDE05113-Infotainment Recorderactivated
1​
IDE06425-Dynamometer mode: functionalnot activated
1​
IDE08814-IDE04033-Navigation receiver GNSS configuration-CompassOFF
1​
IDE08814-MAS01570-Navigation receiver GNSS configuration-DefaultOn
1​
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPSOFF
1​
IDE08814-MAS07828-Navigation receiver GNSS configuration-GalileoOFF
1​
IDE08814-MAS07829-Navigation receiver GNSS configuration-GlonassOFF
1​
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1OFF
1​
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2OFF
1​
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner
-128​
40​
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio
5​
40​
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)
-128​
40​
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)
-128​
40​
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)
-128​
40​
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB
-128​
40​
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP
-128​
40​
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay
-128​
40​
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter
-128​
40​
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN
-128​
40​
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray
-128​
40​
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice
-128​
40​
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA
-128​
40​
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud
-128​
40​
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD
-128​
40​
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI
-128​
40​
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP
-128​
40​
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP
-128​
40​
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink
-128​
40​
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP
-128​
40​
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB
-3​
40​
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice
-128​
40​
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM
-128​
40​
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep
-128​
40​
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging
-128​
40​
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen
-128​
40​
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning
-128​
40​
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav
-128​
40​
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS
-128​
40​
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online
-128​
40​
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal
-128​
40​
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI
-128​
40​
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN
-128​
40​
IDE10480-MAS10741-Interface for external media: activation-Connection 1activated
4​
IDE10480-MAS10742-Interface for external media: activation-Connection 2not activated
4​
IDE10480-MAS10743-Interface for external media: activation-Connection 3not activated
4​
IDE10480-MAS10744-Interface for external media: activation-Connection 4not activated
4​
IDE10604-Menu entries for mobile online servicesnot activated
1​
IDE11122-Country identification: country of sale HMIUS
2​
IDE11502-ENG127601-Locked menu contents-FB_CAR_0non_blocked
21​
IDE11502-ENG127602-Locked menu contents-FB_CAR_1non_blocked
21​
IDE11502-ENG127611-Locked menu contents-FB_CAR_10non_blocked
21​
IDE11502-ENG127612-Locked menu contents-FB_CAR_11non_blocked
21​
IDE11502-ENG127613-Locked menu contents-FB_CAR_12non_blocked
21​
IDE11502-ENG127614-Locked menu contents-FB_CAR_13non_blocked
21​
IDE11502-ENG127615-Locked menu contents-FB_CAR_14non_blocked
21​
IDE11502-ENG127616-Locked menu contents-FB_CAR_15non_blocked
21​
IDE11502-ENG127617-Locked menu contents-FB_CAR_16non_blocked
21​
IDE11502-ENG127618-Locked menu contents-FB_CAR_17non_blocked
21​
IDE11502-ENG127619-Locked menu contents-FB_CAR_18non_blocked
21​
IDE11502-ENG127620-Locked menu contents-FB_CAR_19non_blocked
21​
IDE11502-ENG127603-Locked menu contents-FB_CAR_2non_blocked
21​
IDE11502-ENG127621-Locked menu contents-FB_CAR_20non_blocked
21​
IDE11502-ENG127622-Locked menu contents-FB_CAR_21non_blocked
21​
IDE11502-ENG127623-Locked menu contents-FB_CAR_22non_blocked
21​
IDE11502-ENG127624-Locked menu contents-FB_CAR_23non_blocked
21​
IDE11502-ENG127604-Locked menu contents-FB_CAR_3non_blocked
21​
IDE11502-ENG127605-Locked menu contents-FB_CAR_4non_blocked
21​
IDE11502-ENG127606-Locked menu contents-FB_CAR_5non_blocked
21​
IDE11502-ENG127607-Locked menu contents-FB_CAR_6non_blocked
21​
IDE11502-ENG127608-Locked menu contents-FB_CAR_7non_blocked
21​
IDE11502-ENG127609-Locked menu contents-FB_CAR_8non_blocked
21​
IDE11502-ENG127610-Locked menu contents-FB_CAR_9non_blocked
21​
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0non_blocked
21​
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1non_blocked
21​
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10non_blocked
21​
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11non_blocked
21​
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12non_blocked
21​
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13non_blocked
21​
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14non_blocked
21​
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15non_blocked
21​
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16non_blocked
21​
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17non_blocked
21​
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18non_blocked
21​
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19non_blocked
21​
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2non_blocked
21​
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20non_blocked
21​
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21non_blocked
21​
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22non_blocked
21​
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23non_blocked
21​
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3non_blocked
21​
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4non_blocked
21​
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5non_blocked
21​
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6non_blocked
21​
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7non_blocked
21​
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8non_blocked
21​
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9non_blocked
21​
IDE11502-ENG127625-Locked menu contents-FB_MISC_0non_blocked
21​
IDE11502-ENG127626-Locked menu contents-FB_MISC_1non_blocked
21​
IDE11502-ENG127635-Locked menu contents-FB_MISC_10non_blocked
21​
IDE11502-ENG127636-Locked menu contents-FB_MISC_11non_blocked
21​
IDE11502-ENG127637-Locked menu contents-FB_MISC_12non_blocked
21​
IDE11502-ENG127638-Locked menu contents-FB_MISC_13non_blocked
21​
IDE11502-ENG127639-Locked menu contents-FB_MISC_14non_blocked
21​
IDE11502-ENG127640-Locked menu contents-FB_MISC_15non_blocked
21​
IDE11502-ENG127641-Locked menu contents-FB_MISC_16non_blocked
21​
IDE11502-ENG127642-Locked menu contents-FB_MISC_17non_blocked
21​
IDE11502-ENG127643-Locked menu contents-FB_MISC_18non_blocked
21​
IDE11502-ENG127644-Locked menu contents-FB_MISC_19non_blocked
21​
IDE11502-ENG127627-Locked menu contents-FB_MISC_2non_blocked
21​
IDE11502-ENG127645-Locked menu contents-FB_MISC_20non_blocked
21​
IDE11502-ENG127646-Locked menu contents-FB_MISC_21non_blocked
21​
IDE11502-ENG127647-Locked menu contents-FB_MISC_22non_blocked
21​
IDE11502-ENG127648-Locked menu contents-FB_MISC_23non_blocked
21​
IDE11502-ENG127649-Locked menu contents-FB_MISC_24non_blocked
21​
IDE11502-ENG127650-Locked menu contents-FB_MISC_25non_blocked
21​
IDE11502-ENG127651-Locked menu contents-FB_MISC_26non_blocked
21​
IDE11502-ENG127652-Locked menu contents-FB_MISC_27non_blocked
21​
IDE11502-ENG127653-Locked menu contents-FB_MISC_28non_blocked
21​
IDE11502-ENG127654-Locked menu contents-FB_MISC_29non_blocked
21​
IDE11502-ENG127628-Locked menu contents-FB_MISC_3non_blocked
21​
IDE11502-ENG127655-Locked menu contents-FB_MISC_30non_blocked
21​
IDE11502-ENG127656-Locked menu contents-FB_MISC_31non_blocked
21​
IDE11502-ENG127657-Locked menu contents-FB_MISC_32non_blocked
21​
IDE11502-ENG127658-Locked menu contents-FB_MISC_33non_blocked
21​
IDE11502-ENG127659-Locked menu contents-FB_MISC_34non_blocked
21​
IDE11502-ENG127660-Locked menu contents-FB_MISC_35non_blocked
21​
IDE11502-ENG127661-Locked menu contents-FB_MISC_36non_blocked
21​
IDE11502-ENG127662-Locked menu contents-FB_MISC_37non_blocked
21​
IDE11502-ENG127663-Locked menu contents-FB_MISC_38non_blocked
21​
IDE11502-ENG127664-Locked menu contents-FB_MISC_39non_blocked
21​
IDE11502-ENG127629-Locked menu contents-FB_MISC_4non_blocked
21​
IDE11502-ENG127665-Locked menu contents-FB_MISC_40non_blocked
21​
IDE11502-ENG127666-Locked menu contents-FB_MISC_41non_blocked
21​
IDE11502-ENG127667-Locked menu contents-FB_MISC_42non_blocked
21​
IDE11502-ENG127668-Locked menu contents-FB_MISC_43non_blocked
21​
IDE11502-ENG127669-Locked menu contents-FB_MISC_44non_blocked
21​
IDE11502-ENG127670-Locked menu contents-FB_MISC_45non_blocked
21​
IDE11502-ENG127671-Locked menu contents-FB_MISC_46non_blocked
21​
IDE11502-ENG127672-Locked menu contents-FB_MISC_47non_blocked
21​
IDE11502-ENG127630-Locked menu contents-FB_MISC_5non_blocked
21​
IDE11502-ENG127631-Locked menu contents-FB_MISC_6non_blocked
21​
IDE11502-ENG127632-Locked menu contents-FB_MISC_7non_blocked
21​
IDE11502-ENG127633-Locked menu contents-FB_MISC_8non_blocked
21​
IDE11502-ENG127634-Locked menu contents-FB_MISC_9non_blocked
21​
IDE11502-ENG127561-Locked menu contents-FB_NAV_0non_blocked
21​
IDE11502-ENG127562-Locked menu contents-FB_NAV_1non_blocked
21​
IDE11502-ENG127571-Locked menu contents-FB_NAV_10non_blocked
21​
IDE11502-ENG127572-Locked menu contents-FB_NAV_11non_blocked
21​
IDE11502-ENG127573-Locked menu contents-FB_NAV_12non_blocked
21​
IDE11502-ENG127574-Locked menu contents-FB_NAV_13non_blocked
21​
IDE11502-ENG127575-Locked menu contents-FB_NAV_14non_blocked
21​
IDE11502-ENG127576-Locked menu contents-FB_NAV_15non_blocked
21​
IDE11502-ENG127577-Locked menu contents-FB_NAV_16non_blocked
21​
IDE11502-ENG127578-Locked menu contents-FB_NAV_17non_blocked
21​
IDE11502-ENG127579-Locked menu contents-FB_NAV_18non_blocked
21​
IDE11502-ENG127580-Locked menu contents-FB_NAV_19non_blocked
21​
IDE11502-ENG127563-Locked menu contents-FB_NAV_2non_blocked
21​
IDE11502-ENG127581-Locked menu contents-FB_NAV_20non_blocked
21​
IDE11502-ENG127582-Locked menu contents-FB_NAV_21non_blocked
21​
IDE11502-ENG127583-Locked menu contents-FB_NAV_22non_blocked
21​
IDE11502-ENG127584-Locked menu contents-FB_NAV_23non_blocked
21​
IDE11502-ENG127585-Locked menu contents-FB_NAV_24non_blocked
21​
IDE11502-ENG127586-Locked menu contents-FB_NAV_25non_blocked
21​
IDE11502-ENG127587-Locked menu contents-FB_NAV_26non_blocked
21​
IDE11502-ENG127588-Locked menu contents-FB_NAV_27non_blocked
21​
IDE11502-ENG127589-Locked menu contents-FB_NAV_28non_blocked
21​
IDE11502-ENG127590-Locked menu contents-FB_NAV_29non_blocked
21​
IDE11502-ENG127564-Locked menu contents-FB_NAV_3non_blocked
21​
IDE11502-ENG127591-Locked menu contents-FB_NAV_30non_blocked
21​
IDE11502-ENG127592-Locked menu contents-FB_NAV_31non_blocked
21​
IDE11502-ENG127593-Locked menu contents-FB_NAV_32non_blocked
21​
IDE11502-ENG127594-Locked menu contents-FB_NAV_33non_blocked
21​
IDE11502-ENG127595-Locked menu contents-FB_NAV_34non_blocked
21​
IDE11502-ENG127596-Locked menu contents-FB_NAV_35non_blocked
21​
IDE11502-ENG127597-Locked menu contents-FB_NAV_36non_blocked
21​
IDE11502-ENG127598-Locked menu contents-FB_NAV_37non_blocked
21​
IDE11502-ENG127599-Locked menu contents-FB_NAV_38non_blocked
21​
IDE11502-ENG127600-Locked menu contents-FB_NAV_39non_blocked
21​
IDE11502-ENG127565-Locked menu contents-FB_NAV_4non_blocked
21​
IDE11502-ENG127566-Locked menu contents-FB_NAV_5non_blocked
21​
IDE11502-ENG127567-Locked menu contents-FB_NAV_6non_blocked
21​
IDE11502-ENG127568-Locked menu contents-FB_NAV_7non_blocked
21​
IDE11502-ENG127569-Locked menu contents-FB_NAV_8non_blocked
21​
IDE11502-ENG127570-Locked menu contents-FB_NAV_9non_blocked
21​
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0non_blocked
21​
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1non_blocked
21​
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10non_blocked
21​
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11non_blocked
21​
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12non_blocked
21​
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13non_blocked
21​
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14non_blocked
21​
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15non_blocked
21​
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2non_blocked
21​
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3non_blocked
21​
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4non_blocked
21​
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5non_blocked
21​
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6non_blocked
21​
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7non_blocked
21​
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8non_blocked
21​
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9non_blocked
21​
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0non_blocked
21​
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1non_blocked
21​
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10non_blocked
21​
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11non_blocked
21​
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12non_blocked
21​
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13non_blocked
21​
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14non_blocked
21​
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15non_blocked
21​
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2non_blocked
21​
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3non_blocked
21​
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4non_blocked
21​
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5non_blocked
21​
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6non_blocked
21​
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7non_blocked
21​
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8non_blocked
21​
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9non_blocked
21​
IDE11503-Satellite radio tuner: pre-activated subscription07
1​
MAS00951-BluetoothOn
1​
MAS02809-MAS02870-Check tone frequency-High note frequency range4000 Hz
6​
MAS02809-MAS02871-Check tone frequency-Medium note frequency range1000 Hz
6​
MAS02809-MAS02872-Check tone frequency-Low note frequency range100 Hz
6​
MAS03782-WLANOn
1​
ENG117917-BAP_Debug_Mode_Releasenot_released
1​
ENG104140-Bluetooth_Phonebook_Access_ProfilePBAP
1​
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatizationnot activated
60​
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimernot activated
60​
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_offnot activated
60​
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_highnot activated
60​
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstillnot activated
60​
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilationnot activated
60​
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimernot activated
60​
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_offnot activated
60​
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_highnot activated
60​
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstillnot activated
60​
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistentnot activated
60​
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimernot activated
60​
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_offnot activated
60​
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_highnot activated
60​
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstillnot activated
60​
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACCnot activated
60​
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimernot activated
60​
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_offnot activated
60​
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_highnot activated
60​
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstillnot activated
60​
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_keynot activated
60​
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimernot activated
60​
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_offnot activated
60​
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_highnot activated
60​
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstillnot activated
60​
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adbluenot activated
60​
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimernot activated
60​
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_offnot activated
60​
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_highnot activated
60​
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstillnot activated
60​
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_dampernot activated
60​
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimernot activated
60​
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_offnot activated
60​
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_highnot activated
60​
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstillnot activated
60​
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illuminationactivated
60​
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimernot activated
60​
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_offnot activated
60​
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_highactivated
60​
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstillnot activated
60​
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slopenot activated
60​
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimernot activated
60​
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_offnot activated
60​
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_highnot activated
60​
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstillnot activated
60​
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identificationnot activated
60​
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimernot activated
60​
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_offnot activated
60​
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_highnot activated
60​
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstillnot activated
60​
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heatingnot activated
60​
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimernot activated
60​
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_offnot activated
60​
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_highnot activated
60​
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstillnot activated
60​
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awvnot activated
60​
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimernot activated
60​
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_offnot activated
60​
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_highnot activated
60​
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstillnot activated
60​
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_managementnot activated
60​
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimernot activated
60​
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_offnot activated
60​
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_highnot activated
60​
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstillnot activated
60​
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmEactivated
60​
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimernot activated
60​
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_offnot activated
60​
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_highactivated
60​
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstillnot activated
60​
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computeractivated
60​
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimernot activated
60​
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_offnot activated
60​
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_highactivated
60​
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstillnot activated
60​
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Functionnot activated
60​
60​
60​
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_highnot activated
60​
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstillnot activated
60​
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirroractivated
60​
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimernot activated
60​
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_offnot activated
60​
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_highactivated
60​
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstillnot activated
60​
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_lockingactivated
60​
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimernot activated
60​
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_offnot activated
60​
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_highactivated
60​
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstillnot activated
60​
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_masteractivated
60​
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimernot activated
60​
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_offnot activated
60​
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_highactivated
60​
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstillnot activated
60​
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charismanot activated
60​
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimernot activated
60​
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_offnot activated
60​
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_highactivated
60​
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstillnot activated
60​
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configurationactivated
60​
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimernot activated
60​
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_offnot activated
60​
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_highactivated
60​
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstillnot activated
60​
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clockactivated
60​
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimernot activated
60​
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_offnot activated
60​
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_highactivated
60​
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstillnot activated
60​
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compassactivated
60​
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimernot activated
60​
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_offnot activated
60​
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_highactivated
60​
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstillnot activated
60​
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assistnot activated
60​
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimernot activated
60​
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_offnot activated
60​
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_highnot activated
60​
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstillnot activated
60​
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configurationnot activated
60​
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimernot activated
60​
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_offnot activated
60​
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_highnot activated
60​
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstillnot activated
60​
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_schoolactivated
60​
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimernot activated
60​
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_offnot activated
60​
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_highactivated
60​
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstillnot activated
60​
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecallactivated
60​
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimernot activated
60​
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_offnot activated
60​
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_highactivated
60​
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstillnot activated
60​
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assistnot activated
60​
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimernot activated
60​
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_offnot activated
60​
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_highnot activated
60​
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstillnot activated
60​
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENIactivated
60​
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimernot activated
60​
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_offnot activated
60​
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_highactivated
60​
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstillnot activated
60​
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illuminationactivated
60​
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimernot activated
60​
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_offnot activated
60​
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_highactivated
60​
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstillnot activated
60​
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_displaynot activated
60​
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimernot activated
60​
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_offnot activated
60​
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_highnot activated
60​
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstillnot activated
60​
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybridnot activated
60​
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimernot activated
60​
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_offnot activated
60​
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_highnot activated
60​
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstillnot activated
60​
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistantnot activated
60​
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimernot activated
60​
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_offnot activated
60​
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_highnot activated
60​
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstillnot activated
60​
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warningactivated
60​
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimernot activated
60​
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_offnot activated
60​
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_highactivated
60​
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstillnot activated
60​
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jockernot activated
60​
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimernot activated
60​
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_offnot activated
60​
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_highnot activated
60​
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstillnot activated
60​
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_visionnot activated
60​
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimernot activated
60​
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_offnot activated
60​
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_highnot activated
60​
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstillnot activated
60​
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_levelnot activated
60​
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimernot activated
60​
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_offnot activated
60​
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_highnot activated
60​
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstillnot activated
60​
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdcnot activated
60​
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimernot activated
60​
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_offnot activated
60​
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_highnot activated
60​
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstillnot activated
60​
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assistnot activated
60​
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimernot activated
60​
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_offnot activated
60​
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_highactivated
60​
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstillnot activated
60​
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdkactivated
60​
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimernot activated
60​
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_offnot activated
60​
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_highactivated
60​
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstillnot activated
60​
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainmentnot activated
60​
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimernot activated
60​
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_offnot activated
60​
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_highnot activated
60​
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstillnot activated
60​
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_loadnot activated
60​
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimernot activated
60​
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_offnot activated
60​
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_highnot activated
60​
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstillnot activated
60​
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identificationactivated
60​
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimernot activated
60​
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_offnot activated
60​
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_highactivated
60​
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstillnot activated
60​
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configurationnot activated
60​
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimernot activated
60​
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_offnot activated
60​
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_highnot activated
60​
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstillnot activated
60​
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumaticnot activated
60​
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimernot activated
60​
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_offnot activated
60​
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_highnot activated
60​
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstillnot activated
60​
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_siaactivated
60​
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimernot activated
60​
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_offnot activated
60​
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_highactivated
60​
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstillnot activated
60​
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_viewnot activated
60​
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimernot activated
60​
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_offnot activated
60​
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_highnot activated
60​
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstillnot activated
60​
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functionsnot activated
60​
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimernot activated
60​
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_offnot activated
60​
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_highnot activated
60​
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstillnot activated
60​
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoilernot activated
60​
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimernot activated
60​
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_offnot activated
60​
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_highnot activated
60​
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstillnot activated
60​
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMInot activated
60​
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimernot activated
60​
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_offnot activated
60​
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_highnot activated
60​
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstillnot activated
60​
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasonsnot activated
60​
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimernot activated
60​
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_offnot activated
60​
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_highnot activated
60​
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstillnot activated
60​
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistantnot activated
60​
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimernot activated
60​
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_offnot activated
60​
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_highnot activated
60​
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstillnot activated
60​
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tunernot activated
60​
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimernot activated
60​
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_offnot activated
60​
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_highnot activated
60​
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstillnot activated
60​
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdonot activated
60​
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimernot activated
60​
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_offnot activated
60​
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_highnot activated
60​
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstillnot activated
60​
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_ratingactivated
60​
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimernot activated
60​
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_offnot activated
60​
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_highactivated
60​
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstillnot activated
60​
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vinactivated
60​
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimernot activated
60​
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_offnot activated
60​
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_highactivated
60​
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstillnot activated
60​
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognitionnot activated
60​
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimernot activated
60​
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_offnot activated
60​
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_highnot activated
60​
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstillnot activated
60​
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windowsactivated
60​
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimernot activated
60​
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_offnot activated
60​
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_highactivated
60​
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstillnot activated
60​
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiperactivated
60​
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimernot activated
60​
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_offnot activated
60​
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_highactivated
60​
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstillnot activated
60​
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrolnot activated
60​
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimernot activated
60​
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_offnot activated
60​
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_highnot activated
60​
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstillnot activated
60​
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05not activated
64​
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_busExtended data bus
64​
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06not activated
64​
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_busSuspension data bus
64​
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2Dnot activated
64​
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_busnot activated
64​
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24not activated
64​
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_busnot activated
64​
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03not activated
64​
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_busComfort data bus
64​
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1Bactivated
64​
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_busTerminal 15
64​
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25not activated
64​
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_busPowertrain data bus
64​
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23activated
64​
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_busInfotainment data bus
64​
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26not activated
64​
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_busSuspension data bus
64​
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0Dactivated
64​
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_busComfort data bus
64​
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17not activated
64​
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_busInfotainment data bus
64​
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16not activated
64​
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_busComfort data bus
64​
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01activated
64​
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_busComfort data bus
64​
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02not activated
64​
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_busComfort data bus
64​
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11activated
64​
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_busComfort data bus
64​
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15activated
64​
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_busInfotainment data bus
64​
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10not activated
64​
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_busComfort data bus
64​
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33activated
64​
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_busComfort data bus
64​
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3CComfort data bus
64​
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3Cnot activated
64​
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37activated
64​
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_busComfort data bus
64​
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38not activated
64​
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_busComfort data bus
64​
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09activated
64​
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_busComfort data bus
64​
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04not activated
64​
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_busComfort data bus
64​
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1Dnot activated
64​
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_busPowertrain data bus
64​
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08activated
64​
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_busComfort data bus
64​
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19activated
64​
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_busExtended data bus
64​
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0Factivated
64​
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_busComfort data bus
64​
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34not activated
64​
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34Infotainment data bus
64​
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0Eactivated
64​
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_busComfort data bus
64​
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18not activated
64​
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_busnot activated
64​
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0Anot activated
64​
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_busTerminal 15
64​
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20not activated
64​
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_busComfort data bus
64​
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3Anot activated
64​
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3AExtended data bus
64​
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39not activated
64​
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39Infotainment data bus
64​
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2Enot activated
64​
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_busComfort data bus
64​
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1Fnot activated
64​
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_busPowertrain data bus
64​
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3Bnot activated
64​
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3BComfort data bus
64​
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3Fnot activated
64​
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3FComfort data bus
64​
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3Enot activated
64​
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3EComfort data bus
64​
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12activated
64​
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_busComfort data bus
64​
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1Enot activated
64​
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_busnot activated
64​
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35not activated
64​
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35Comfort data bus
64​
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27not activated
64​
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_busInfotainment data bus
64​
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1Anot activated
64​
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_busExtended data bus
64​
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07activated
64​
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_busSuspension data bus
64​
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21activated
64​
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_busExtended data bus
64​
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36not activated
64​
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36Comfort data bus
64​
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2Cnot activated
64​
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_busComfort data bus
64​
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14not activated
64​
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_busTerminal 15
64​
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13activated
64​
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_busComfort data bus
64​
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0Bnot activated
64​
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_busInfotainment data bus
64​
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22not activated
64​
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_busInfotainment data bus
64​
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0Cactivated
64​
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_busComfort data bus
64​
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_keyNot available
8​
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_busComfort data bus
8​
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_schoolavailable.
8​
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_busInfotainment data bus
8​
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFLavailable.
8​
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_busInfotainment data bus
8​
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_levelNot available
8​
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_busPowertrain data bus
8​
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_loweringNot available
8​
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_busSuspension data bus
8​
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-ReservedNot available
8​
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1Comfort data bus
8​
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2Comfort data bus
8​
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3Not available
8​
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VINavailable.
8​
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_busComfort data bus
8​
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1
0​
6​
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2
50​
6​
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3
100​
6​
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1
0​
6​
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2
50​
6​
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3
100​
6​
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1
0​
6​
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2
50​
6​
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3
100​
6​
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1
0​
6​
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2
50​
6​
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3
100​
6​
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1
0​
12​
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2
10​
12​
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3
100​
12​
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4
150​
12​
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5
220​
12​
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6
253​
12​
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1
1%​
12​
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2
1%​
12​
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3
8%​
12​
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4
20%​
12​
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5
60%​
12​
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6
100%​
12​
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE
40​
ENG117809-p_damping_Display5 ms
1​
ENG117808-p_HMI_Display
13%​
1​
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset
0​
2​
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset
0​
2​
ENG117910-Set_Remote_Test_Channel_ScanningConditions not correct or request sequence error
2​
ENG117908-Shift_Remote_Test_Frequency_AMConditions not correct or request sequence error
2​
ENG117907-Shift_Remote_Test_Frequency_FMConditions not correct or request sequence error
2​
ENG117906-Shift_Remote_Test_VolumeConditions not correct or request sequence error
2​
ENG117919-Startup_Screen_Sticker_HMI00 01
2​
ENG109862-ENG117847-Vehicle_configuration-advanced_range_displayOFF
30​
ENG109862-ENG249824-Vehicle_configuration-AliBoxOFF
30​
ENG109862-ENG142146-Vehicle_configuration-allow_message_editingOFF
30​
ENG109862-ENG130249-Vehicle_configuration-Apple_DIOOn
30​
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_WirelessOFF
30​
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_LifeOFF
30​
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_iosOFF
30​
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_WirelessOFF
30​
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_WirelessOFF
30​
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epblocked
30​
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant
0​
30​
ENG109862-ENG263540-Vehicle_configuration-correction_e_mileage
0​
30​
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_callOn
30​
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_supportOFF
30​
ENG109862-ENG185778-Vehicle_configuration-FoDSWaP
30​
ENG109862-ENG130248-Vehicle_configuration-Google_GALOn
30​
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_WirelessOFF
30​
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverartsOFF
30​
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_otherOFF
30​
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverartsOFF
30​
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_otherOFF
30​
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_datanot activated
30​
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_ExtenderDeactivated
30​
ENG109862-ENG261211-Vehicle_configuration-internet_over_WLAN_default_settingOFF
30​
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1not installed
30​
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2not installed
30​
ENG109862-ENG127492-Vehicle_configuration-LGIOFF
30​
ENG109862-ENG130246-Vehicle_configuration-LTE_modulactivated
30​
ENG109862-ENG142142-Vehicle_configuration-map_email_supportOFF
30​
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_supportOFF
30​
ENG109862-ENG142141-Vehicle_configuration-map_sms_supportOFF
30​
ENG109862-ENG142152-Vehicle_configuration-Map_Style
0​
30​
ENG109862-ENG152537-Vehicle_configuration-media_controlnot activated
30​
ENG109862-ENG138662-Vehicle_configuration-Mirror_linkOFF
30​
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_CodeMIB_EU
30​
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_PreferenceRGB565
30​
ENG109862-ENG117843-Vehicle_configuration-my_audiOFF
30​
ENG109862-ENG117845-Vehicle_configuration-online_dictationOFF
30​
ENG109862-ENG127495-Vehicle_configuration-online_mediaOFF
30​
ENG109862-ENG117840-Vehicle_configuration-online_navigationOFF
30​
ENG109862-ENG117837-Vehicle_configuration-online_POIOFF
30​
ENG109862-ENG117838-Vehicle_configuration-online_POI_voiceOFF
30​
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_servicesOFF
30​
ENG109862-ENG152553-Vehicle_configuration-online_radioDeactivated
30​
ENG109862-ENG117841-Vehicle_configuration-online_street_viewOFF
30​
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unitOFF
30​
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold00
30​
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis00
30​
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy
0​
30​
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_modeData & language service active
30​
ENG109862-ENG117844-Vehicle_configuration-picture_naviOn
30​
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parkingnot activated
30​
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_usenot activated
30​
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest
0​
30​
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgiOFF
30​
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzoOFF
30​
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_VersionPSD_1.5
30​
ENG109862-ENG117846-Vehicle_configuration-remote_HMIOFF
30​
ENG109862-ENG138661-Vehicle_configuration-RSE_software_componentactivated
30​
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_opennot activated
30​
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_thresholdnot activated
30​
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafenot activated
30​
ENG109862-ENG126143-Vehicle_configuration-RVC_video_inputFBAS
30​
ENG109862-ENG152556-Vehicle_configuration-scon_telephonynot activated
30​
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivationno restriction
30​
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flagno_region
30​
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switchnot activated
30​
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switchnot installed
30​
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_supportOFF
30​
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmiactivated
30​
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode
0​
30​
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_holdOFF
30​
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_callingOn
30​
ENG109862-ENG130247-Vehicle_configuration-Support_second_phoneOn
30​
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_locationOFF
30​
ENG109862-ENG126994-Vehicle_configuration-TPEG_availabilityOFF
30​
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_drivinglocked
30​
ENG109862-ENG137647-Vehicle_configuration-UOTAOFF
30​
ENG109862-ENG167532-Vehicle_configuration-UOTA_2OFF
30​
ENG109862-ENG117852-Vehicle_configuration-UPnPOFF
30​
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_soundnot activated
30​
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_soundnot activated
30​
ENG109862-ENG152558-Vehicle_configuration-voice_over_ltenot activated
30​
ENG109862-ENG117836-Vehicle_configuration-VZAProOFF
30​
ENG109862-ENG127494-Vehicle_configuration-VZOOFF
30​
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMIOFF
30​
ENG109862-ENG117842-Vehicle_configuration-WIFI_HotspotOFF
30​
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switchnot activated
30​
Elapsed Time: 00:37
   #29
downtime
Finland
C?ID=280813
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school    activated
60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer    not activated
60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off    not activated
60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high    activated
60
Set these to not activated as well
   #30
mmhubbard
Illinois, USA
C?ID=404494
60
60
60
60
I set those all to not activated, but it didn't change the remaining error message.
   #31
downtime
Finland
C?ID=280813
This one to not activated
   #32
mmhubbard
Illinois, USA
C?ID=404494
Thank You! That removed the last of the 5F errors. I need to go back and figure out why the cruise control won't work, but at least the other errors are all cleared up.
   #33
downtime
Finland
C?ID=280813
Check the measurement channel for swap keys from gateway. Does it show all are valid? And what are the swaps in?
   #34
mmhubbard
Illinois, USA
C?ID=404494
I am not sure I know how to read this (or if I got the right data), but it appears some are invalid.
Here is what captured:
VIN: 3VW447AU8GM007430   License Plate:
Mileage:    Repair Order: swap
                Address 19: CAN Gateway  (5Q0 907 530 AF)
14:08:26
  IDE04329-ENG118721   Status of all SWaP functions-SWaP_function_state array |ID number,Release code for a SWaP function,Cancellation,Individualization characteristic,Preconditions met,Configuration,Functions,Authentication|10 00 03 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 01 00,available.,No,invalid,Condition met,OK,present,valid|10 00 11 00,available.,No,invalid,Condition met,OK,present,valid|10 00 12 00,available.,No,invalid,Condition met,OK,present,valid|10 00 13 00,available.,No,invalid,Condition met,OK,present,valid|10 00 14 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 15 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 16 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 17 00,available.,No,invalid,Condition met,OK,present,valid|10 00 18 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 19 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 1A 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 1B 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|00 00 00 00,Not available,Yes,invalid,Condition not met,not OK,not installed,invalid|00 00 00 00,Not available,Yes,invalid,Condition not met,not OK,not installed,invalid|
  IDE04332   Release code for a SWaP function 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D
  IDE04334   Public key for SWaP function 99 19 70 20 DD A9 1D 14 0A BB A4 90 B5 ED 09 97 32 66 86 77 B6 FC 36 C9 0F 44 99 7F 58 BF 1C 99 82 8C DD 35 B4 F5 BB 76 4F 28 2E 4A 4B AA 98 44 D5 65 19 9D 70 BD 6E 67 C7 B2 D6 C9 37 77 57 DD CE 12 D4 A1 15 32 59 88 5E 5C 05 4B C4 B9 D5 8F 18 83 0E BA 93 C1 43 56 0F A4 B6 B9 3C 79 66 8F D7 5B 33 70 34 84 1E 8E D7 AE CD B8 E6 0E 29 FC D5 60 B3 F6 EC FD E2 D3 2B 1A 7D 78 41 88 78 F9 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
  ENG118782-ENG118460   Gateway app. software identification-software_version_SWaP 0620
