2016 GTI ACC Retrofit issues
mmhubbard
Illinois, USA
C?ID=404494
Hi all,
I have a 2016 GTI Autobahn edition that came with performance pack but not the driver assist.
The car was modified to have ACC by the previous owner (I did not know that when I purchased the car). The ACC was not working and indicated it needed calibrated, and to make a long story short, neither I nor my dealer new of the modification and the dealer completely messed up the programming of the ABS module.
Once I understood that the previous owners' retrofit did everything except the swap of the ABS module, I located a used 3Q0-907-379-AB module and completed the swap.
I have mostly fixed the coding errors and am still troubleshooting the system. The car runs and drives fine at the moment, without cruise control working, but I have a warning when I start the car that the "Trans. in emerg. mode. You can continue driving", and the below scan shows that the Transmission cannot communicate with the parking brake module. I am guessing that the car that the ABS module came out of had an electronic brake and I cannot figure out how to fix that. There are still other errors, so it is possible that fixing the other ACC related errors will fix it, but I would like to at least get the transmission error resolved before tackling the others if possible.
Any help would be appreciated.
Is my assumption correct that it is looking for an EPB that does not exist? Is there a code or an adaptation in the ABS module so that the transmission does not think there is an EPB? Can share more details on what I have tried in the coding if needed. Thanks.
VIN: 3VW447AU8GM007430   License Plate:
Mileage: 50855km-31599mi   Repair Order: update bytes post clrea
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 2B 32 42 44 47 52 55 5F
          75 A5 A9
VIN: 3VW447AU8GM007430   Mileage: 50855km-31599miles
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: 766D2359
   Coding: 091D00124464002F1000
   Shop #: WSC 33076 003 104857
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001002
   ROD: EV_ECM20TFS0205G0906259D.rod
   VCID: 2F3B16F88798F4C2F61-807A
   VINID: 0E69C410746521774000710300BB87D739
22008 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [00100111] - -
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:05
                    Engine RPM: 0.00 /min
                    Coolant temperature: 27  C
                    Intake air temperature: 15  C
                    Voltage terminal 30: 10.585 V
                    Engine: operating status: ES
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 13.0  C
                    Time since engine start: 0.0 s
                    T_ES: 6 min
                    Cruise control switch actuation-Main switch: Not operated
                    Cruise control switch actuation-Set: Not operated
                    Cruise control switch actuation-Resume: Not operated
                    Cruise control switch actuation-Accelerate: Not operated
                    Cruise control switch actuation-DELAY: Not operated
                    Cruise control switch actuation-Cancel: Not operated
                    Cruise control switch actuation-Main switch hardware: Not operated
                    Cruise control switch actuation-Limit button: Not operated
                    Cruise control switch actuation-Main switch CAN: Not operated
                    Cruise control switch actuation-Large increment: Not operated
                    STATE_ERR_ABC_PRED: 18
Readiness: 1110 1101
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H53 4902
   Revision: 06253104    Serial number: TFK01505270109 CVN: 0000EE8B
   Shop #: WSC 00066 790 00202
   ROD: EV_TCMDQ250021.rod
   VCID: 1C61D134E62E7F5AA33-8048
21221 - No Communications with Parking Brake Control Module
          U0128 00 [00001011] - -
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:05
   Revision: 00000000    Serial number: 62805000001299
   Coding: 01FA6BA154200973007B020341C36880D62A9000408216B6164350D3C009
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AADF7AC0C5AE16A11F-802E
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Reset counter: 213
                    Date: 2025.01.01
                    Time: 13:06:04
8260 - Databus
          [FCAN: Pla_01 message is not received]
                    Reset counter: 213
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:10
   Revision: 00021000    Serial number: 0370694598 Dataset Number: V03935197ZB 0001
   Coding: 030C0C
   Shop #: WSC 01383 790 50316
   VCID: 3A2D37AC4CDA216A51F-806E
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 00020014200100000101004012111402
   VCID: 42DD4F4C240A69AA09F-8016
   Air quality sensor:
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86580306152031 Dataset Number: 5GM063v____ 0059
   Coding: 00111B464041A27969E44000001407281800000000000000000000000000
   Shop #: WSC 00070 123 12345
   ROD: EV_BCMBOSCH_015.rod
   Component: WWS    150430  043 0581
   Serial number:         150716102540
   Subsystem 2 - Part No SW: 5Q0 955 559     HW: 5Q0 955 559   Labels: 5Q0-955-547.CLB
   Component: RLS  024 0042
   Serial number: Y14M07D07H01M57S57S8
   Coding: 028877
   Sunroof control module:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03694814510102150651
   Coding: 181803
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H04 0303
   Serial number: 09051477030676 Dataset Number: 5g0114v____ 1020
   Coding: 001C1600FE033B
   Shop #: WSC 00046 123 12345
   VCID: 38292DA472D6337AA7B-806C
1037 - Databus
          [FAULT_CIS_QDCACC_FAIL]
                    Reset counter: 213
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:02
                    Control Module temperature: 30  C
                    Voltage terminal 15: 10.5 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s
1807 - No Enable Identifications Active
          B2032 00 [00001001] - -
          [FAULT_SWAP_NO_FSID_ACTIVE]
                    Reset counter: 213
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:02
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [00001000] - -
          [FAULT_VMON_VZ_LOW]
                    Reset counter: 253
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:44
                    Voltage terminal 15: 8.7 V
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 31051541350039 Dataset Number: V03935209LD 0002
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 372B2E987FC83C02AE1-8062
   Serial number: 003GCR0255K4 Dataset Number: 5GM003V____ 0046
   VCID: 47CB5E580F284C82DE1-8012
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH0000J1500034LPA05
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 35700000000115647411
   Subsystem 3 - Part No SW: -----------    HW: 480 000 206 15
   Serial number: 3580000000010B547416
   Subsystem 4 - Part No SW: -----------    HW: 480 402 005 15
   Serial number: 3510002B11A2DCD2B269
   Subsystem 5 - Part No SW: -----------    HW: 480 401 805 15
   Serial number: 3520002B11B0CB34A25/
   Subsystem 6 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3550002B71B41485529/
   Subsystem 7 - Part No SW: -----------    HW: 480 400 206 15
   Serial number: 3560002B71B4148141B.
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150603400078
   Coding: 0E10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 045189547E9EA79A7B3-8050
          B1149 13 [00001001] - Open Circuit
                    Reset counter: 213
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:03
                    Ubat 30 Voltage: 10.70 V
                    Ignition State: On
                    Terminal 15: 9.90 V
                    A/D #1: 97.65 %
                    A/D #2: 65.88 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         408 3196
   Coding: 0BAD111B7D84CF0502887A031000000000000000
   VCID: 2A0D07ECBC7A91EA21F-807E
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2223
   Revision: --------    Serial number: 17061510002481 Dataset Number: 5G0067V____ 2215
   Coding: 0101003830085800FB00023B9C0F00000001050000000000000000000000
   GVL: 01503C5000000600408C90008000CC0000000000000000000000000000000000
   ROD: EV_GatewConti_013.rod
   VCID: 75B7E49025448E127CD-8020
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150000655820035153
   Coding: 2DFFFF
   Revision: 00000000    Serial number: 15000147802002
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07027
   VCID: 343119946EBED71A8B3-8060
Address 32: Differential Locks (J492)       Labels:| 0CQ-907-554-V2.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00031.03.15 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 150615060506C1 Dataset Number: V03935214VB 0007
   Coding: 003F1320DC00040000000001
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 43D34A483B1060A2029-8016
   Serial number: 00000000000001537970
   Coding: 011000
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Dataset Number: 5GM074V____ 0418
   Coding: 9102
   Shop #: WSC 00046 000 00000
   Component: MIB2_lite_amp H20 0110
   Revision: 00000001    Serial number: VWZ8Z1FBA007UTT Dataset Number: 5GM050v____ 0212
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI_VW37.rod
   VCID: 6D87CCF04D1446D284D-8038
   Serial number: 180615060507AA Dataset Number: V03935214VC 0007
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   Serial number: 00000000000001495359
   Coding: 091000
   Revision: --------    Serial number: -------------- Dataset Number: V03935205NP 0021
   Coding: 021203010B000400
   ROD: EV_HeadlRegulVWAFS_VW37.rod
   VCID: 40D945442A067BBA1FB-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 876     HW: 3Q0 035 876
   Component: MU-S-NS-US    H25 0241
   Serial number: VWZAZ2R0232869 Dataset Number: 5G0CV1v____ 0001
   Coding: 027300020000000051220002001808001F0203F401200105C6
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 71BFD080512CA232A05-8024
   Component: ABT_High  H62 0031
   Serial number: VWZ8Z9RU301J11
   Subsystem 2 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
7173 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 213
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:06
                    Voltage terminal 30: 10.5 V
                    BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 213
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:06
   Component: OCULowMQBUS   007 0564
   Dataset Number: 561098V____ 0409
   Shop #: WSC 00066 790 00323
   ROD: EV_OCULowMQB.rod
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0060
   Serial number: 10000016023    Dataset Number: 5G0HL1V____ 0049
   Coding: 0101010101020306000301010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3C2131B446EE1F5A433-8068
1114112 - Databus
          [SWA_01_TO_FAILURE]
                    Reset counter: 213
                    Mileage: 50855 km
                    Date: 2025.01.01
                    Time: 13:06:03
                    Control Module temperature: 39  C
                    Outside temperature: 8.5  C
                    Vehicle speed: 0.00 km/h
                    Terminal 15 on: 361.3 s
   Component: SAS-GEN 2     H06 0014
   Serial number: 150523202386
   VCID: 6B83C2E8730048E29A9-803E
End----(Elapsed Time: 01:51, VBatt start/end: 11.3V/10.9V. VIgn 11.0V)-----
golfi_vend
Tartu, Estonia
C?ID=195131
Please get full blockmap from 13.
mmhubbard
Illinois, USA
C?ID=404494
Blockmap from 13:
;SW:5Q0-907-572-D   HW:5Q0-907-572-D ---  Auto Dist. Reg
;Component:ACC Bosch MQB H04 0303, Coding:001C1600FE033B
;EV_ACCMRRBoschVW372,001015,EV_ACCMRRBoschVW372_VW26.rod
;Thursday,02,January,2025,11:40:08:23435
;VCDS Version: Release 24.7.1 (x64)  Data version: 20240919 DS356.3
;VCID: 38292DA472D6337AA7B-806C
Group,Description,Actual
IDE00002,Transport mode,OFF,
IDE00018,Voltage terminal 15,11.9, V
IDE00102,Control Module temperature,12, °C
IDE01784,Misalignment angle,-0.47, °
IDE01785,Vertical angle deviation,0.289000, °
IDE01786,Horizontal angle deviation,0.119000, °
IDE01787,Radar status,OFF,
IDE01788,Heated lens control signal,0.00, %
IDE02290-MAS01466,Adjustment screw 1-Direction of rotation,none,
IDE02290-MAS02559,Adjustment screw 1-Rotations,0.00,
IDE02291-MAS01466,Adjustment screw 2-Direction of rotation,none,
IDE02291-MAS02559,Adjustment screw 2-Rotations,0.00,
IDE02523,Adjustment angle - fast algorithms,-0.47, °
IDE03203,Alignment instructions,Set mirror in posit 1 and start measurement,
IDE04329-ENG125077,Status of all SWaP functions-begin array,|ID number,Release code for a SWaP function,Cancellation,Individualization characteristic,Preconditions met,Configuration,Functions,Authentication|10 00 31 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 32 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 33 00,available.,No,invalid,Condition met,OK,present,valid|10 00 34 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 36 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 37 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|10 00 38 00,Not available,Yes,invalid,Condition not met,OK,present,invalid|,
IDE04332,Release code for a SWaP function,2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,
IDE04334-MAS02643,Public key for SWaP function-Key,86 6D 6F D1 B1 45 75 4F 11 7E 6C C7 CC E7 56 45 BF E9 86 D7 1B FE 18 3B 1B EC 4B 4C 2B 0F 03 98 34 9A 4E 27 CD 09 85 4D 50 8E 6A C1 F5 66 79 0F 1F 9C 97 23 A1 19 1C 9A 9D 83 C2 F1 FB FC 6E A3 C0 81 80 34 1E B3 C1 05 9A EF 0D C1 CA 08 45 92 8E AF 81 9F A0 8A 28 B7 47 CF FF CB 30 7E C0 17 6A 76 88 28 16 55 38 02 83 54 B5 DA E0 82 39 BC 41 C7 35 FA 88 97 52 24 54 5D B9 79 5D 95 82 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03,
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,00,
IDE04805-MAS01448,Driving profile selection-Target value,00,
IDE04805-MAS05058,Driving profile selection-Compatibility,Yes,
IDE05814,Individualization characteristic,6D 29 76 DB A6,
IDE07584,Counter for internal faults,0,
IDE09906,Vertical deadjustment,1.342, °
ENG119268-MAS01632,Status ACC System-Status,ACC_irreversible error,
Elapsed Time: 00:07
admap:
;Thursday,02,January,2025,11:40:16:23435
IDE00056-History data 1,On ,1
IDE00820-Activating and deactivating all development messages,OFF ,1
IDE00899-Option for presetting of time gap,OFF ,1
IDE01795-Heated lens,On ,1
IDE02332-Deactivate production mode,Deactivating ,3
IDE07570-Multiple assignment of buttons in multi-function steering wheel,OFF ,1
IDE07977-Plausibilization of activation of emergency brake function,On ,1
IDE07978-Avoidance for impermissible passing process,OFF ,1
IDE09536-Detect. of vertical deadjustment,On ,1
Elapsed Time: 00:04
downtime
Finland
C?ID=280813
ABS coding not correct
downtime
Finland
C?ID=280813
This ABS coding should fix the ABS errors :
01FA6BA154200973007B020341C36880D62A9000408216B6004350D1C009
The problem is that your ACC is retrofitted. And if I'm not mistaken by the part number it is an older MRR1 radar. It says in DTCs No enable identifications active. Means no SWAP is active and the radar is not working. You can hack it, but not with VCDS.
I disabled PLA and ACC from your ABS coding so at least the car is mostly driveable now.
mmhubbard
Illinois, USA
C?ID=404494
Thanks. that cleared up some of the errors. I do still however have the error related to the transmission not being able to connect to the Parking Brake Module. Am I correct that it is an adaptation on the ABS module to look for an Electronic Parking brake that is not present on North American GTIs?
New Scan:
Mileage: 50863km-31604mi   Repair Order: post reset and start
          75 A5 A9
VIN: 3VW447AU8GM007430   Mileage: 50863km-31604miles
                    Mileage: 50863 km
                    Date: 2025.01.04
                    Time: 15:37:53
                    Coolant temperature: 7  C
                    Intake air temperature: 8  C
                    Voltage terminal 30: 11.679 V
                    ECU_STATE: ENG_STOP
                    Engine oil temperature: 6.0  C
                    T_ES: 1609 min
Readiness: 1110 0101
                    Mileage: 50863 km
                    Date: 2025.01.04
                    Time: 15:37:54
   Coding: 01FA6BA154200973007B020341C36880D62A9000408216B6004350D1C009
   Coding: 030C0C
   Revision: 00001K01
   Air quality sensor:
   Coding: 028877
   Coding: 181803
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 214
                    Mileage: 50863 km
                    Date: 2025.01.04
                    Time: 15:37:51
                    Control Module temperature: 13  C
                    Voltage terminal 15: 11.6 V
                    Reset counter: 214
                    Mileage: 50863 km
                    Date: 2025.01.04
                    Time: 15:37:51
   Coding: 303131
   Coding: 0E10
                    Reset counter: 214
                    Mileage: 50863 km
                    Date: 2025.01.04
                    Time: 15:37:51
                    Ubat 30 Voltage: 11.80 V
                    Ignition State: On
                    Terminal 15: 11.00 V
                    A/D #1: 97.65 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
   Generator:
   Coding: 2DFFFF
   Coding: 0001
   Coding: 011000
   Coding: 9102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
                    Reset counter: 214
                    Mileage: 50863 km
                    Date: 2025.01.04
                    Time: 15:37:54
                    Voltage terminal 30: 11.6 V
                    Reset counter: 214
                    Mileage: 50863 km
                    Date: 2025.01.04
                    Time: 15:37:54
1114112 - Databus
          [SWA_01_TO_FAILURE]
                    Reset counter: 214
                    Mileage: 50863 km
                    Date: 2025.01.04
                    Time: 15:37:52
                    Control Module temperature: 18  C
                    Outside temperature: 6.0  C
                    Terminal 15 on: 246.1 s
admap for ABS:
;SW:3Q0-907-379-AB   HW:3Q0-907-379-G ---  ABS Brakes
;Component:ESC           H42 0723, Coding:01FA6BA154200973007B020341C36880D62A9000408216B6004350D1C009
;EV_Brake1UDSContiMK100IPB,034036,EV_Brake1UDSContiMK100IPB_034_VW37.rod
;Saturday,04,January,2025,15:42:25:23435
;VCID: 7AADF7AC0C5AE16A11F-802E
IDE00252-Brake system vacuum pump,5 ,1
IDE00820-Activating and deactivating all development messages,0 ,1
IDE01763-Dimming,activated ,1
IDE03493-Driver's door status,activated ,1
IDE03659-Roller test bench mode,Manual activation: possible ,1
IDE04456-Brake disk drying,Medium ,1
IDE04508-Hydraulic brake booster,8 ,1
IDE04643-Overboost in brake system,activated ,1
IDE04645-IDE05287-Electromechanical parking brake-Automatic application,activated ,2
IDE04645-MAS05667-Electromechanical parking brake-Driver presence recognition via brake pedal,not activated ,2
IDE04765-Counter steer support,Strong ,1
IDE04774-Vehicle and trailer stabilization,activated ,1
IDE04871-Dynamic starting assist,normal ,1
IDE04939-Tire Pressure Monitoring System (TPMS),2 ,1
IDE04944-Brake pedal evaluation,activated ,1
IDE04949-Engine drag torque control,activated ,1
IDE04951-Brake Boost,4 ,1
IDE04952-Braking torque boost for distance regulation,3 ,1
IDE05055-Hydraulic brake assistant,normal ,1
IDE05057-Brake prefill,activated ,1
IDE05161-Straight ahead brake stabilization,activated ,1
IDE05263-AUTO HOLD functionality,not activated ,1
IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
IDE05286-Expanded electronic differential lock,Standard ,1
IDE05337-Starting vibration reduction-,Strong ,1
IDE05337-MAS02653-Starting vibration reduction-Limited torque,Deactivated ,1
IDE05711-Automatic application during engine stalling,activated ,1
IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
IDE06139-AUTO HOLD slippage recognition,activated ,1
IDE06505-Electromechanical parking brake: delay level,6 ,1
IDE07006-Tire pressure monitoring display: tire selection,2 ,1
IDE07565-ABS in lower speed range,activated ,1
IDE07848-Thresholds for brake performance,activated ,1
MAS00122-Electronic Stability Program,not activated ,1
MAS00970-Running manufacturer number,activated ,1
MAS01180-AUTO HOLD functional status,Last setting ,1
MAS01299-Offroad,0 ,1
MAS02080-XCP calibration protocol,not activated ,1
MAS02138-Hill-start assistant,normal ,1
MAS02666-Seat belt buckle scan,activated ,1
MAS07300-Monitoring infotainment control unit,Security access required,1
MAS08145-Hill-start assistant: increase threshold,3 %,1
MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
MAS11606-Electromechanical parking brake: emergency braking,Security access required,3
ENG118148-Developer_Function_1,0 ,1
ENG122612-Developer_Function_100,Security access required,1
ENG122613-Developer_Function_101,Security access required,1
ENG122614-Developer_Function_102,Security access required,1
ENG122615-Developer_Function_103,Security access required,1
ENG122616-Developer_Function_104,Security access required,1
ENG122617-Developer_Function_105,Security access required,1
ENG122618-Developer_Function_108,Security access required,1
ENG125054-Developer_Function_110,Security access required,1
ENG130301-Developer_Function_121,not activated ,1
ENG118149-Developer_Function_2,Security access required,1
ENG118200-Developer_Function_3,Security access required,1
ENG118201-Developer_Function_4,Security access required,1
ENG127702-Developer_Function_5,Security access required,1
ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
ENG122844-ENG99557-dimming_characteristic_1-X2,50 ,12
ENG122844-ENG102140-dimming_characteristic_1-X3,220 ,12
ENG122844-ENG102936-dimming_characteristic_1-X4,6 ,12
ENG122844-ENG103548-dimming_characteristic_1-X5,8 ,12
ENG122844-ENG113992-dimming_characteristic_1-X6,80 ,12
ENG122844-ENG99777-dimming_characteristic_1-Y1,10 ,12
ENG122844-ENG100480-dimming_characteristic_1-Y2,100 ,12
ENG122844-ENG100773-dimming_characteristic_1-Y3,253 ,12
ENG122844-ENG100631-dimming_characteristic_1-Y4,6 ,12
ENG122844-ENG102174-dimming_characteristic_1-Y5,12 ,12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
ENG122845-ENG99557-dimming_characteristic_2-X2,50 ,12
ENG122845-ENG102140-dimming_characteristic_2-X3,220 ,12
ENG122845-ENG102936-dimming_characteristic_2-X4,6 ,12
ENG122845-ENG103548-dimming_characteristic_2-X5,8 ,12
ENG122845-ENG113992-dimming_characteristic_2-X6,80 ,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,10 ,12
ENG122845-ENG100480-dimming_characteristic_2-Y2,100 ,12
ENG122845-ENG100773-dimming_characteristic_2-Y3,253 ,12
ENG122845-ENG100631-dimming_characteristic_2-Y4,6 ,12
ENG122845-ENG102174-dimming_characteristic_2-Y5,12 ,12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
ENG118202-fill_and_bleed_information,Security access required,12
Elapsed Time: 00:16
2kaa52
Ceska Republica, Praha
C?ID=319193
To get your ACC working you need to Install correct Swap Codes .
If this is done, Most Errors are gone.
Try to find someone in your area maybe.
If you Stuck with it, you can contact me.
downtime
Finland
C?ID=280813
@mmhubbard the transmission error could be a ghost issue. Go to 02 transmission module, basic settings and choose reset installation list basic setting.
Ignition off and lock the doors and let the car sleep. This clears any ”residue” stuff from the can bus
In abs module there was no EPB coding present so that’s fine
mmhubbard
Illinois, USA
C?ID=404494
That did clear the transmission error. Thank you so much!
mmhubbard
Illinois, USA
C?ID=404494
Does anyone have any contact or aware of any options to help install correct Swap Codes that is located in the US, Central Illinois area?
Also, I am researching doing this myself, and have OBD11 available, but have not been able to locate the correct FEC key for ACC for my car. Does anyone know what the correct key is?
Thanks.
downtime
Finland
C?ID=280813
First things first, do you know if the ACC has ever worked on the previous owner? You cannot just input the FEC to the radar if the radar was not in the car from factory. If it's from factory, you can do it online via dealer or via someone with proper GEKO access and suitable dongle.
If it's not from factory then your options are quite slim. Easiest would be to swap the radar for 3QF and let someone who knows what they are doing, do their magic and this way enable the radar on your car.
OBD11 is not enough for this work in any case
mmhubbard
Illinois, USA
C?ID=404494
Thanks. I do not believe the radar was on the car from the factory, and the previous owner appears to have done everything for the retrofit except changing out the ABS unit, so I know it was never fully working. I do not know if he had the radar working on its own at any point.
If I remove the settings from the other modules related to ACC, would I be able to go back to having basic cruise control working? I assume I would need to go back to the original cruise control buttons on the steering wheel, as well.
darkchina811
ITALY
C?ID=333184
yes for regular CCS you'd need to replace buttons on the steering wheel, and change the relevant adaptation in the Gateway.
mmhubbard
Illinois, USA
C?ID=404494
The saga continues. I have gone ahead with disconnecting the radar unit and making all the settings go back to regular CCS, including replacing the steering wheel buttons. I have cleaned up most the coding errors, but few remain that I cannot seem to find the source of. Any help on where to look next would be appreciated.
Here is the latest scan after updates. I can also post blockmap and adpmap if needed.
Mileage: 51054km-31723mi   Repair Order: postupdate
Scan: 01 02 03 05 08 09 14 15 16 17 19 2B 32 42 44 47 52 55 5F 75
          A5 A9
VIN: 3VW447AU8GM007430   Mileage: 51054km-31723miles
   Coding: 091D00124424002F1000
17169 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [10100111] - -
                    Mileage: 51054 km
                    Date: 2025.02.08
                    Time: 14:25:58
                    Coolant temperature: 90  C
                    Voltage terminal 30: 12.207 V
                    ACC variants (coding): CCS
                    CCS Switch: CCS operating unit
                    ACC variants: ACC
          P1734 00 [00000010] - -
   Coding: 030C0C
   Revision: 00001K01
   Air quality sensor:
   Coding: 028877
   Coding: 181803
   Coding: 303131
   Coding: 0E10
   Shop #: WSC 12345 123 61029
                    Reset counter: 237
                    Mileage: 51054 km
                    Date: 2025.02.08
                    Time: 14:25:54
                    Ubat 30 Voltage: 12.30 V
                    Ignition State: On
                    Terminal 15: 11.50 V
                    A/D #1: 97.65 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
   Coding: 0BAD111B7984CF0502087A021000000000000000
   Coding: 0101003830085800FB00022B9C0F00000001050000000000000000000000
   GVL: 01503C5000000600408C10008000CC0000000000000000000000000000000000
   Generator:
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160000291600106062
   Coding: 29FFFF
   Coding: 0001
   Coding: 011000
   Coding: 9102
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
                    Reset counter: 237
                    Mileage: 51054 km
                    Date: 2025.02.08
                    Time: 14:25:57
                    Voltage terminal 30: 12.1 V
7195 - Function Restricted due to Missing Message(s)
          [Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 237
                    Mileage: 51054 km
                    Date: 2025.02.08
                    Time: 14:25:57
   Coding: 0101010101020306000301010000000100
1114112 - Databus
          [SWA_01_TO_FAILURE]
                    Reset counter: 237
                    Mileage: 51054 km
                    Date: 2025.02.08
                    Time: 14:25:55
                    Control Module temperature: 45  C
                    Outside temperature: 1.5  C
                    Voltage terminal 15: 12.2 V
                    Terminal 15 on: 291.1 s
End----------(Elapsed Time: 01:47, VBatt start/end: 12.2V/12.2V)-----------
downtime
Finland
C?ID=280813
In A5, you have lane assist or bsd coded. Remove that coding and you’ll get rid of it.
In engine, did you change the cruise coding to cruise control instead of ACC?
The windshield/wiper error, wiring? Check that.
mmhubbard
Illinois, USA
C?ID=404494
Thanks.
I went ahead and disabled the lane assist, although I thought that was dependent on the camera and not the radar, so should have been able to be on. I don't really care about that feature, so I went ahead and removed the config for it. I did change the cruise coding in the engine to be cruise control instead of ACC. I am not real worried about the windshield/wiper error at the moment.
Some errors have cleaned up, but I am getting a new error in the 44 steering assist module, and some different faults in the 5F information Electr. module. Thoughts on what I am missing?
Mileage: 51070km-31733mi   Repair Order: latest
          A5 A9
VIN: 3VW447AU8GM007430   Mileage: 51070km-31733miles
                    Mileage: 51070 km
                    Date: 2025.02.09
                    Time: 14:11:28
                    Coolant temperature: 46  C
                    Intake air temperature: 30  C
                    Voltage terminal 30: 11.933 V
                    ACC variants: ACC
   Coding: 030C0C
   Revision: 00001K01
   Air quality sensor:
   Coding: 028877
   Coding: 181803
   Coding: 303131
   Coding: 0E10
                    Reset counter: 239
                    Mileage: 51070 km
                    Date: 2025.02.09
                    Time: 14:11:25
                    Ubat 30 Voltage: 12.10 V
                    Ignition State: On
                    Terminal 15: 11.30 V
                    A/D #1: 97.65 %
                    A/D #2: 65.49 %
                    A/D #3: 0.00 %
   Coding: 0BAD111B3984CF0502087A001000000000000000
   Generator:
   Coding: 29FFFF
   Coding: 0001
   Coding: 011000
   Coding: 9102
21760 - Databus
          [HCA_01 Botschaft - CAN-Timeout]
                    Reset counter: 239
                    Mileage: 51070 km
                    Date: 2025.02.09
                    Time: 14:11:29
                    Motor status: 00
                    Supply voltage: 11.75 V
                    Temperature: 22.0  C
                    KFC: 55
                    KFA: 00 00
                    Freeze frame conditions: 5F
                    uioUdNotFilt_xdu16: 11.84 V
                    uAdSensI_SwitchedKl30_xdu16: 11.84 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Coding: 091000
   Coding: 2E0000
   Coding: 2E0000
                    Reset counter: 239
                    Mileage: 51070 km
                    Date: 2025.02.09
                    Time: 14:11:29
                    Voltage terminal 30: 11.8 V
7193 - Function Restricted due to Missing Message(s)
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 239
                    Mileage: 51070 km
                    Date: 2025.02.09
                    Time: 14:11:29
                    Reset counter: 239
                    Mileage: 51070 km
                    Date: 2025.02.09
                    Time: 14:11:29
   Coding: 0001010101020306000300000000000100
End----------(Elapsed Time: 01:48, VBatt start/end: 12.1V/12.0V)-----------
downtime
Finland
C?ID=280813
You are now mixing things. Camera based system is lane DEPARTURE assist and lane ASSIST is blind spot monitoring. So now you have disabled LDW which is lane departure warning. That you can enable because it's fully relying on the camera. The HCA error you have on steering assist is because of that.
So enable HCA or heading control assist on the A5 back but make sure you don't have BSD or LANE ASSIST enabled on it.
Did you modify the ABS coding as well when you removed ACC? Probably that's your issue now. You still have in ABS ACC coded. To disable ACC from ABS in byte 24 make sure bits from 1 - 4 are all 0. And remember, bit counting starts from 0. And they count from right to left. Right being the LSB or least significant bit or in more common terms bit number 0.
mmhubbard
Illinois, USA
C?ID=404494
Thanks for the details, I didn't realize they were 2 settings. I will work to add them back and see where that gets me.
Also, my coding for the ABS is 01FA6BA154200973007B020341C36880D62A9000408216B6004350D1C009, so byte 24 is 00 unless I am doing something wrong, so I think it should already have ABS disabled.
