- Mar 3, 2019
- 99
- 27
- New Zealand
- C?ID=197081
Hi Team, (Updated)
Trying to make this a definitive coding guide as there's only partial information out there.
I've retrofitted the following to my 2017 Golf Variant R-Line:
PLA2.0 (used module, wire harness, buttons, sensors from 17 Golf hatchback)
Dynaudio system (used harness, speakers, amplifier)
DCC (new china harness, sensors, used shocks)
Only the PLA is connected and powered right now as I'll deal with them one by one.
Park pilot does not display on screen, park pilot error appears on instruments when button pushed.
Coding changes I've made so far:
01 Engine
Byte 3 - Bit 5 ticked
03 ABS
Byte 27 - changed to B9 (same as my other car with PLA)
17 Instruments
Byte 5 - Bit 4 ticked
19 Can gateway - ticked 10 in install list.
3C Lane change
Byte 0 - PLA installed
A5 Front sens
Byte 12 - bit 6 ticked.
Many thanks and a happy new year!
01 Engine
03 ABS
17 Instruments
3C Lane change
A5 Front sens
Tuesday,31,December,2024,18:16:00:54382
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
VIN: WVWZZZAUZJP525286 License Plate:
Mileage: 29880km-18566mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 29 2B 39 3C 42 44 4B 52
57 5F A5 D6 D7
VIN: WVWZZZAUZJP525286 Mileage: 29880km-18566miles
Address 01: Engine (J623-CHPA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 CG HW: 04E 907 309 A
Component: R4 1.4l TFS H13 9191
Revision: WAH13--- CVN: DD863503
Coding: 01250032236405083000
Shop #: WSC 00028 028 00081
ASAM Dataset: EV_ECM14TFS01104E906016CG 002007
ROD: EV_ECM14TFS01104E906016CG.rod
VCID: 698FB82439F4A4A2E8D-803C
VINID: 9E69EAAAA465A9A80508508818580ED3D3
17158 - Databus
U1123 00 [00100111] - Received Error Message
Mileage: 29880 km
Date: 2024.12.31
Time: 18:01:49
Engine RPM: 0.00 /min
Coolant temperature: 25 °C
Intake air temperature: 25 °C
Voltage terminal 30: 11.473 V
Acceleration: 0.000 m/s²
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
Drivetrain coordinator: brake fault status-Bits 0-7: 5
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 041 B HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1006
Revision: 00005026 Serial number: CU501707195164 CVN: 1265A98F
Shop #: WSC 00028 028 00066
ROD: EV_TCMDQ200021.rod
VCID: 343119502EB6294A8BB-8060
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 62157000000420
Coding: 04FA8AA1242221714779060880C92920512484E260019473182250B9C2A2430000000012121212B835351919323200
VCID: 77ABEE5C7F4002526E9-8022
8216 - Databus
[FCAN: Fahrwerk_01 message is not received]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:11
8331 - Databus
U1121 00 [10001001] - Missing Message
[FCAN: Quersperre_03 message is not received]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:14
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0450665403 Dataset Number: V03935252RF 0001
Coding: 032C0C
VCID: 3C21317006E6E10A43B-8068
Part No SW: 5G0 907 044 CE HW: 5G0 907 044 CE
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0212000410010001110500001010102A
VCID: 6C81C1303606B18A93B-8038
Air quality sensor:
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865825071701T1 Dataset Number: V03935265FF 0001
ROD: EV_BCMBOSCH_018.rod
VCID: 0B43A2AC13C816B23A1-805E
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 170713 042 0551
Serial number: 170801074435
Component: RLHS 042 0105
Serial number: S4Y17M08D14H14M13S27
Coding: 31E8DD
Humidity sensor: interior:
65802 - Rear Left Ride-Height Sensor
C1036 15 [00001001] - Open or Short to Plus
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:09
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 11.6 V
Outside temperature: 25.0 °C
65800 - Rear Left Ride-Height Sensor
C1036 29 [00001001] - Signal Implausible
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.6 V
65806 - Rear Left Ride-Height Sensor
C1036 04 [00001001] - Internal System Fault
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
CAN-Bus_aktiv: On
OFF: operated
Voltage: 11.6 V
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617126 Dataset Number: V03935256VM 0001
Coding: 0371167851
ASAM Dataset: EV_EPHVA2CAU3700000 009037
VCID: 50F975C0BA6E756A8F3-8004
13637426 - Databus
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:11
13688835 - Databus
[Steuergerät für Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 18:01:48
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Dataset Number: V03935259QS 0001
Coding: 330007C159FFC728949C810580400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E253B7810FAF31A6DF-806A
2172 - Databus
[FAULT_BRAKINGLIGHT_FAIL]
Reset counter: 25
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
Control Module temperature: 40 °C
Voltage terminal 15: 11.4 V
0803 - Databus
[FAULT_BV1_FEHLER]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
0928 - Databus
[FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
Part No SW: 5Q0 959 655 BK HW: 5Q0 959 655 BK
Component: AirbagVW21 005 0336
Serial number: 003VXR360NKH Dataset Number: V03935259SL 0001
Coding: 98FCC0C0000000005C5400CF008800000065
Shop #: WSC 00028 028 00057
VCID: 0A4DA7A81CB20FBA017-805E
Left seat belt tensioner:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E07081741575
Coding: 333135
Right seat belt tensioner:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E08081751304
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 808 17
Serial number: 357000000002553C652C
Subsystem 4 - Part No SW: ----------- HW: 480 000 808 17
Serial number: 35800000000217945629
Subsystem 5 - Part No SW: ----------- HW: 480 400 308 17
Serial number: 3510001C7269FFA3083E
Subsystem 6 - Part No SW: ----------- HW: 480 400 308 17
Serial number: 35200019D26441E3531X
Subsystem 7 - Part No SW: ----------- HW: 480 400 408 17
Serial number: 3550001A12711E34B41U
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170804200093
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 73B3DA4C6B386E72521-8026
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 407 3193
Coding: 27E459186F98000E02886B0B5400000080000000
VCID: 2A0D0728FC726FBA217-807E
U1014 00 [00001001] - -
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 18:02:55
16776980 - Databus
[PLA_Status_01 keine Kommunikation]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 18:02:55
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 28071710520751 Dataset Number: V03935266ZJ 0001
Coding: 030100047F085700FB00025E1C0F00010001070000000000000000000000
GVL: 01563C000000060040CC80000000C80000000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 33331A4C2BB82E72921-8066
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170001573480107295
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 0585834704
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
VCID: 47CB5E9C4F20B2D2DE9-8012
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000206322009
Coding: 5D00000000000000
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0449804213 Dataset Number: V03935258DF 0001
Coding: 02011203
Shop #: WSC 02345 003 104857
ROD: EV_HREntryHella_VW37.rod
VCID: 3D273C741DFCE802745-8068
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0449744698
Coding: 020112
267520 - invalid data record
B2005 00 [00001001] - -
[Control Unit - Invailed dataset]
Reset counter: 240
267776 - Data Set Implausible
B2012 00 [00001000] - -
[Control Unit - Implausible dataset]
Reset counter: 25
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 011 0032
Serial number: 0000270320359 Dataset Number: V03935257PY 0001
Coding: 003B1320D001028000001000
ROD: EV_DCUDriveSideEWMAXKLO.rod
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000006656783
Coding: 0D0000
B1487 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:09
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Dataset Number: V03935259RW 0001
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A2D37680CD2DF3A517-806E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 31071710800456 Dataset Number: V03935259VB 0001
Coding: 000000050100194E01204F01020000000000000000000000000000000000
VCID: 72BDDF481422677A597-8026
13705999 - Databus
U1123 00 [10001001] - Received Error Message
[Kamera_FDD_Funktionsstatus_Fehler received error status]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:09
13705991 - Databus
[FA_Hoehenwert_HL_01 received error value]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:09
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 011 0032
Serial number: 0000266495183 Dataset Number: V03935267WU 0001
Coding: 003B1120DE01028000801000
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 46D55398482AABDA25F-8012
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000006734884
Coding: 050000
Address 57: TV Tuner (R78) Labels:| 8V0-919-DTV-V1.clb
Part No SW: 8V0 919 129 F HW: 8V0 919 129 D
Component: JP-DTV H12 2110
Coding: 02041C0000000100000002
ASAM Dataset: EV_TVMELC 001039
ROD: EV_TVMELC_VW37.rod
VCID: 43D34A8C7B189EF2021-8016
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 050 A HW: 5NA 035 050
Component: MU-H-N-JP 053 0829
Serial number: K5F AW7U80O4MI Dataset Number: V03935262VW 0001
Coding: 027312060000000051110001001038001F0106F601200400FE
ASAM Dataset: EV_MUHig4CGen2AW7 001081
ROD: EV_MUHig4CGen2AW7_VW37.rod
VCID: 323D1F48D4A2277A997-8066
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT2060393
Subsystem 2 - Part No SW: V03 959 803 EG HW: -----------
Component: JPN 2017 --- 7720
Compact disc data bank:
Component: Gracenote2 --- 2014
2570 - Control Module for Smart Card Reader
B128F 31 [00001001] - No Signal
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:13
Voltage terminal 30: 11.7 V
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 27071712K11732 Dataset Number: V03935265PP 0001
Coding: 0003070200000501000223548150A90084000E300040
0646 - Control Module Incorrectly Coded
[Variant_coding_failure]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
Control Module temperature: 43 °C
Vehicle speed: 0.00 km/h
System run time: 502.4 s
Voltage terminal 15: 11.5 V
mid: 00 29
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 240
Mileage: 29880 km
Date: 2024.12.31
Time: 17:57:10
System run time: 502.8 s
mid: 02 E0
Status of camera: System malfunction
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F286409D4D42258D-806C
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----(Elapsed Time: 02:10, VBatt start/end: 11.7V/11.6V. VIgn 11.6V)-----
