Maps 2025 ID.Buzz (NAR)
Maps
Jef
HQ
Monday,30,December,2024,11:51:59:18177
VCDS Version: 24.12.0.1 (x64)  HEX-V2 CB: 0.4658.5
Data version: 20241120 DS361.3
VIN: WVGAWVEB7SH010695   License Plate:
Chassis Type: EB-VNE4 (1EE)
Scan: 01 03 05 06 08 09 10 13 15 16 17 19 23 2B 36 3C 42 44 51 52
          5F 6C 6D 75 8C A5 BE BF C0 C6 D6 D7 DE 8116 8123 8124 8125 8128 C002 C003
VIN: WVGAWVEB7SH010695   Mileage: 464km-288miles
51-Electric Drive -- Status: Malfunction 0010
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
8116-Snd enhanct 2 -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623----B)       Labels: None
   Part No SW: 0EA 906 014 GG    HW: 0EA 907 425 K
   Component: E-Vehicle     H80 3875
   Dataset Number: V03935424SD 0001 CVN: 31279148
   Coding: 4102000350042C0236000800000000000000000000000000
   ASAM Dataset: EV_VCU00XXX0200EA906014GG 003002
   ROD: EV_VCU00XXX020_VNE4.rod
   VCID: 78AE321B22573BDA4B2-802C-R SFD
   VINID: 9E65D19E65521E360004018914CA47BDE8
   Radiator shutter:
   Subsystem 1 - Part No SW: 1EA 965 501 B    HW: 1EA 965 501 B
   Component: V711           023 0008
   Serial number: 20240911060604065629
23085 - Implausible Data Received from Battery Energy Control Module 2
          U0413 00 [00100000] - -
          [Control module 2 for battery energy management implausible signal]
                    Mileage: 464 km
                    Date: 2024.12.28
                    Time: 20:28:45
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 12.929 V
                    LF_MVB_PDU_INTC_DIAG_1: 0
                    LF_MVB_PDU_INTC_DIAG_15: 0
                    LF_MVB_PDU_INTC_DIAG_16: 256
                    LF_MVB_BUS_INTC_DIAG: 0
19854 - Steering Column Control Module
          U0212 00 [00100100] - No Communications
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:47:10
                    Voltage terminal 30: 14.882 V
                    LF_MVB_PDU_INTC_DIAG_8: 1
                    LF_MVB_PDU_INTC_DIAG_9: 0
                    LF_MVB_PDU_INTC_DIAG_10: 0
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_18: 0
                    LF_MVB_PDU_INTC_DIAG_19: 0
                    LF_MVB_BUS_INTC_DIAG: 256
37944 - DC-DC Converter 1 for Electric Drive
          U0599 00 [00100000] - Implausible Signal
                    Mileage: 395 km
                    Date: 2024.12.23
                    Time: 15:15:04
                    Voltage terminal 30: 13.125 V
                    LF_MVB_PDU_INTC_DIAG_2: 0
                    LF_MVB_PDU_INTC_DIAG_8: 0
                    LF_MVB_PDU_INTC_DIAG_22: 4096
                    LF_MVB_PDU_INTC_DIAG_23: 0
                    LF_MVB_PDU_INTC_DIAG_24: 0
43491 - Communication Authentication
          U3035 00 [00100000] - Invalid Signal
          [Communication Authentication Signal Invalid Data]
                    Mileage: 458 km
                    Date: 2024.12.28
                    Time: 16:38:36
                    Voltage terminal 30: 13.007 V
                    Driver intention torque: 0.0 Nm
                    PV: 0.00 %
                    LV_IGK: 00000000
                    Outside temperature: 13.5 °C
                    Driving position: P
                    Brake light switch status-actuated__activated: Not operated
                    Brake light switch status-Ident_32: 0
                    Hybrid batt charge cond act val standardized: 52.50 %
   Part No SW: 1EA 907 379 BQ    HW: 1EA 614 517 M
   Component: ESC-ZF_EBC470 H18 0754
   Serial number: 0000000         Dataset Number: V03935447PA 0001 CVN: CEBFB6
   Coding: 481044A8004159024217990000B79840250070614000
   ASAM Dataset: EV_BrakeZFESCMEBUNECE 001035
   ROD: EV_BrakeZFESCMEBUNECE_001_VWE3.rod
   VCID: 0D4073CF3DD52E72084-8058-R SFD
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 N    HW: 5WA 959 436 N
   Component: Kessy IOBOX   122 0757
   Serial number: --------------- Dataset Number: V03935385FF 0001
   ASAM Dataset: EV_Kessy37w 005030
   ROD: EV_Kessy37w_005_VW38.rod
   VCID: 5F9C7987A7B9ECE22A8-800A-R
   Part No SW: 1N3 959 760 H    HW: 1N3 959 760 H
   Component: MEM-BFS       011 0571
   Serial number: 2490901KA02543 Dataset Number: V03935362VW 0001
   Coding: 0118B24000012A008803010121010000000000000000000000000000211000
   Shop #: WSC 00000 790 00551
   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
   ROD: EV_SCMPasseSideCONTIAU736_VW42.rod
   VCID: 3E22E40340F3C5EA41E-806A-R
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 1N3 907 007 D    HW: 1N3 907 007 C
   Component: Climatronic   H01 0247
   Serial number: 221082411054150 Dataset Number: V03935439QZ 0001
   Coding: 013022007010120051102110111001102000102100201171000010000000
   ASAM Dataset: EV_ACClimaBHBE3ADV 002051
   ROD: EV_ACClimaBHBE3ADV_VW42.rod
   VCID: 2D00D34F9D954E72E84-8078-R SFD
   Interior temperature sensor:
   Subsystem 1 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00001190824234842501
   Air quality sensor:
   Subsystem 2 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000010000530822
   Subsystem 3 - Part No SW: 3G0 963 345 C    HW: 3G0 963 345 C
   Component: SysNameFanLin  016 0103
   Serial number: ESEYSKC0067046
   Subsystem 4 - Part No SW: 3G0 963 345 D    HW: 3G0 963 345 D
   Serial number: ESEYSKD0122018
   Subsystem 5 - Part No SW: 3G0 963 345 C    HW: 3G0 963 345 C
   Serial number: ESEYSKC0080449
   Subsystem 6 - Part No SW: 3G0 963 345 D    HW: 3G0 963 345 D
   Serial number: ESEYSKD0097976
   A/C compressor sub:
   Subsystem 7 - Part No SW: 1N3 816 797 C    HW: 1N3 816 797 B
   Component: J842 EKK       H71 1411
   Serial number: 02200001564702
   Auxiliary Heater Control Module/PTC 2:
   Subsystem 8 - Part No SW: 1EA 963 581 E    HW: 1EA 963 581 E
   Component: 0123456789012  020 0172
   Serial number: T745647BB24277000212
   Subsystem 9 - Part No SW: 1EA 820 021 B    HW: 1EA 820 021 B
   Component: J126 J126      001 0001
   Serial number: 00000000000000000618
   Expansion valve 1 for refrigerant:
   Subsystem 10 - Part No SW: 1EA 816 590 B    HW: 1EA 816 590 B
   Component: N636 EV1_KaMi  H05 0002
   Serial number: 1422878
   Subsystem 11 - Part No SW: 4M0 959 603 J    HW: 4M0 959 603 J
   Component: G395 pT-Sens1  H20 0020
   Subsystem 12 - Part No SW: 7T0 907 049 A    HW: 7T0 907 049 A
   Component: E265 KPH GB    H02 0220
   Serial number: G08S16.07.2400972632
   Control module for heating element 1:
   Subsystem 13 - Part No SW: 1T3 959 772 A    HW: 1T3 959 772 A
   Component: LHR            H02 0107
   Serial number: 0074
   A/C control head right rear:
   Subsystem 14 - Part No SW: 7T0 907 049 A    HW: 7T0 907 049 A
   Serial number: G08S10.07.2400971004
   Auxiliary Heater Control Module/PTC 3:
   Subsystem 15 - Part No SW: 1N3 963 581     HW: 1N3 963 581
   Component: IDBUZZPTC      H04 0007
   Serial number: PR653007050724035901
523522 - Airbag Control Module
          C12D1 F3 [00100000] - Received Malfunction Value
          [Airbag control module Received malfunction value 2]
                    Mileage: 75 km
                    Date: 2024.12.13
                    Time: 21:13:39
1180188 - Unknown Error Code
          B182C F8 [00100000] - Unknown Error Elaboration
          [second_HV heater control module Malfunction 9]
                    Reset counter: 39
                    Mileage: 19 km
                    Date: 2024.12.13
                    Time: 15:29:58
                    Voltage terminal 30: 14.90 V
                    Outside temperature: 3.50 °C
                    Engine running time: 77 s
                    Terminal 15 on: 77 s
                    Specified value: left: 75 %
                    Specified value: right: 75 %
                    Center target value: 0 %
                    Requirement: active
                    Number of heat zones: 2 zones
                    Heating system used: Basic system
                    Current: actual value: 1.50 A
                    High voltage supply voltage: 332 V
                    Supply voltage: OK
                    HV heater: status: Overheat protection
                    Vehicle high voltage system: OK
                    Timeout: OK
                    Response error: OK
                    Supply voltage: actual value: 16.50 V
                    Heater electronics and circuit board temperature (PCB): 3
                    Heating circuit 4 status: OK
                    Heating circuit 3 status: OK
                    Heating circuit 2 status: Power reduction due to excessive temperature
                    Heating circuit 1 status: Temperature shut-off
                    Internal error (other): OK
                    Circuit board temperature: shut-off value: OK
                    Total current over long period of time too high: OK
                    Current flow with heating circuit not activated: OK
                    HV heater shut-off condition: none
   Part No SW: 1EE 937 089 C    HW: 1EE 937 089 A
   Component: SAM_H+        H08 0555
   Serial number: 01102420800759- Dataset Number: V03935441QK 0001
   ASAM Dataset: EV_SAMVW31x 006001
   ROD: EV_SAMVW31x_006_VNE4.rod
   VCID: 42DA90F3340BA10A256-8016-R SFD
   Subsystem 1 - Part No SW: 1T3 955 119     HW: 1T3 955 119
   Component: FWISCHER_MYJT  003 0017
   Serial number: 909453F0302420401594
   Wiper motor control unit 2:
   Subsystem 2 - Part No SW: 1T3 955 120     HW: 1T3 955 120
   Component: FWISCHER_SL02  003 0017
   Serial number: 909353F0302418200722
   Subsystem 3 - Part No SW: 89A 955 555 C    HW: 89A 955 555 C
   Component: G397_RLFSS     004 0008
   Serial number: TTZ53523082400032563
   Subsystem 4 - Part No SW: 10A 941 193 N    HW: 10A 941 193 N
   Component: LiSi           H04 0515
   Serial number: RRB71503092400027273
   Subsystem 5 - Part No SW: 1T3 953 235 A    HW: 1T3 953 235 A
   Component: DiETa          H11 0029
   Serial number: LZH 8BS00221911XXXXX
   Subsystem 6 - Part No SW: 7T0 959 569     HW: 7T0 959 569
   Component: DACHKONSOLE    101 0104
   Serial number: 000000092661XGP01349
   Valve block 1 in front seat driver side:
   Subsystem 7 - Part No SW: 14A 881 643 A    HW: 14A 881 643 A
   Component: J873 MKS_FSv   H02 0353
   Serial number: 7009362241C243400779
   Valve block 1 in front seat passenger side:
   Subsystem 8 - Part No SW: 14A 881 643 A    HW: 14A 881 643 A
   Component: J872 MKS_BFSv  H02 0353
   Serial number: 7009362241C243203488
   Subsystem 9 - Part No SW: 2Q0 959 407     HW: 2Q0 959 163
   Component: FOND_FHSG_DRV  001 0007
   Serial number: 03020140811605240734
   Subsystem 10 - Part No SW: 2Q0 959 408     HW: 2Q0 959 164
   Component: FOND_FHSG_PSG  001 0007
   Serial number: 03020110390305242252
1074806 - Databus
          U1123 00 [00100000] - Received Error Message
          [ICAS1_Gateway Datenbus empfangener Fehlerwert]
                    Reset counter: 1
                    Mileage: 19 km
                    Date: 2024.12.13
                    Time: 14:10:36
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    Status drive readiness: not ready to drive
                    Status of brake lamp switch: discrete: OFF
                    Brake lamp switch via CAN: status: OFF
                    Operating condition: Normal mode
                    Voltage: 12.4 V
                    Outside temperature: 1.0 °C
                    Light switch position: automatic
15401216 - Secure Onboard Communication
          U14FE 00 [01100000] - Signature Verification Failed
          [Sichere on-board Kommunikation: Signaturüberprüfung fehlgeschlagen]
                    Reset counter: 12
                    Mileage: 126 km
                    Date: 2024.12.14
                    Time: 12:27:49
                    Voltage: 12.3 V
                    Outside temperature: 0.5 °C
8667507 - Databus
          U1121 00 [00101100] - Missing Message
          [BMS_07 Datenbus fehlende Botschaft]
                    Fault Frequency: 110
                    Mileage: 18 km
                    Date: 2024.12.11
                    Time: 14:37:23
                    Voltage: 12.6 V
8667442 - Unknown Error Code
          B1CEF 86 [00101000] - Signal Invalid
          [Ladeklappenkontaktschalter Signal unplausibel]
                    Fault Frequency: 97
                    Mileage: 17 km
                    Date: 2024.12.10
                    Time: 22:41:30
                    Voltage: 12.5 V
                    Outside temperature: 21.0 °C
589829 - Window Regulator; Rear Driver Side
          B131F 54 [00101000] - Missing Calibration / Basic Setting
          [Driver side rear window regulator motor No basic setting]
                    Fault Frequency: 38
                    Mileage: 13 km
                    Date: 2024.12.10
                    Time: 18:13:06
                    Operating condition: Idle condition
                    Voltage: 0.0 V
                    Outside temperature: -50.0 °C
590341 - Window Regulator; Front Passenger Side
          B1320 54 [00101000] - Missing Calibration / Basic Setting
          [Passenger side rear window regulator motor No basic setting]
                    Fault Frequency: 38
                    Mileage: 13 km
                    Date: 2024.12.10
                    Time: 18:13:06
                    Terminal 15 status: On
                    Voltage: 14.5 V
                    Outside temperature: 20.0 °C
   Part No SW: 1EE 919 300 B    HW: 1EE 919 300
   Component: RPA12K        H01 0630
   Serial number: 000018062494560 Dataset Number: V03935447DQ 0001
   Coding: 0230026041
   ASAM Dataset: EV_EPHBO3CVW4130000 001014
   ROD: EV_EPHBO3CVW4130000_VWE4.rod
   VCID: 3334C5377BB11882BE0-8066-R
   Part No SW: 1EA 907 567 B    HW: 1EA 907 819
   Component: ARS512VW13    H05 0232
   Dataset Number: V03935436WW 0001
   Coding: 06230AE24071C04412574000008040052F4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 004013
   ROD: EV_FRONTRADARCONTIVW310_004_VWE3.rod
   VCID: 3B24ED1753E1D0C2660-806E-R SFD
209054 - Databus
          [FAULT_BV_BLINDNESS_ERROR]
2092 - Databus
          U1122 00 [00101110] - Implausible Message
          [FAULT_QDISACC_FAIL]
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:47:01
2068 - Databus
          U1123 00 [10101110] - Received Error Message
          [FAULT_TSK_IRREV_ERROR]
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:47:10
1076 - Databus
          U1121 00 [00101110] - Missing Message
          [FAULT_TIMEOUT_GRA_ACC_01]
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:53
Address 15: Airbags (J234)       Labels:* 3WA-959-655.clb
   Part No SW: 3WA 959 655 AA    HW: 3WA 959 655 AA
   Component: Airbag VW50   006 0151
   Revision: --------    Serial number: 003C0T5CHFWPK+ Dataset Number: V03935445XP 0001
   Coding: 8CCC0C0000FCC0000000002000000000A15450008100A200830036F8102B0065
   ASAM Dataset: EV_AirbaVW50TS6VW49X 001001
   ROD: EV_AirbaVW50TS6VW49X_VWE3.rod
   VCID: 147666AB1EFFFFBAC7A-8040-R SFD
   Component: BF-Gewichtss.  H17 0022
   Serial number: IBH0000D24000N7BWW0+
   Subsystem 2 - Part No SW: -----------    HW: 654 000 807 24
   Component: SideSensor_Df  010 0887
   Serial number: 3570000F55814FC6883J
   Subsystem 3 - Part No SW: -----------    HW: 654 002 007 24
   Component: SideSensor_Pf  010 0887
   Serial number: 3580000755893EA38327
   Subsystem 4 - Part No SW: -----------    HW: 654 001 811 23
   Component: SideSensor_Dr  020 0148
   Serial number: 351005074C7CEC58A93V
   Subsystem 5 - Part No SW: -----------    HW: 654 000 610 23
   Component: SideSensor_Pr  020 0148
   Serial number: 352005072C7CEC54CA6W
   Subsystem 6 - Part No SW: -----------    HW: 654 002 307 24
   Component: FrontSensor_D  030 010A
   Serial number: 35500509CC74C40D848P
   Subsystem 7 - Part No SW: -----------    HW: 654 002 307 24
   Component: FrontSensor_P  030 010A
   Serial number: 3560050A8C74C188439J
   Rear end impact crash sensor:
   Subsystem 8 - Part No SW: -----------    HW: 654 002 207 24
   Component: RearSensor_C_  030 010A
   Serial number: 3530050A8C74C189252A
   Crash sensor for side airbag: B-pillar: driver side:
   Subsystem 9 - Part No SW: -----------    HW: 654 001 911 23
   Component: Side_Sens_B_D  020 0108
   Serial number: I0P005068C87D3854474
   Crash sensor for side airbag: B-pillar: passenger side:
   Subsystem 10 - Part No SW: -----------    HW: 654 001 911 23
   Component: Side_Sens_B_P  020 0108
   Serial number: I0Q005076C74C457A521
   Seat occupancy detection 1:
   Subsystem 11 - Part No SW: 2K7 959 760 D    HW: 2K7 959 760 D
   Component: wSBR F-SG      037 0200
   Serial number:         94DC4E15AC12
Address 16: Steering wheel (J527)       Labels: 1EE-953-507.clb
   Part No SW: 1EE 953 507 CH    HW: 1EE 953 507 CH
   Component: GSMMEB        005 0067
   Serial number: 000000220824477
   ASAM Dataset: EV_SMLSKLOGEN2 009005
   ROD: EV_SMLSKLOGEN2.rod
   VCID: 035455F76B9168026E0-8056-R SFD
Address 17: Instruments (J1254)       Labels:| 10A-920-320.clb
   Part No SW: 10A 920 320 D    HW: 10A 920 320 D
   Component: FAHRERDISPLAY 031 0650
   Serial number: 4F1XB150-H95753 Dataset Number: V03935392XE 0001
   Coding: 267001
   ASAM Dataset: EV_DashBoardLGMEB 002032
   ROD: EV_DashBoardLGMEB_002_VWE3.rod
   VCID: 16721CA30803EDAAB9E-8042-R SFD
Address 19: CAN Gateway (J533)       Labels: 1EE-937-012.clb
   Part No SW: 1EE 937 012 A    HW: 1EE 937 012
   Component: ICAS1 Host-SG 031 0254
   Serial number: SMERBG120924006 Dataset Number: V03935446DK 0001
   GVL: 2D0008001E0850FC8062904248180050C400200000000000000200000000C057
   ASAM Dataset: EV_GatewICAS1MEBUNECE 001004
   ROD: EV_GatewICAS1MEBUNECE_VNE4.rod
   VCID: 323AC03384AB118AB56-8066 SFD
   Subsystem 1 - Part No SW: 1N3 915 181 A    HW: 1N3 915 181 A
   Component: J367-BDMConti  H05 1076
   Serial number: 7856800100240808015E
   Inverter for electrical outlet:
   Subsystem 2 - Part No SW: 5H0 907 155 A    HW: 5H0 907 155 A
   Component: Inverter       H05 0050
   Serial number: 5ZJSHFT0805240000672
   Subsystem 3 - Part No SW: 3G0 959 542 B    HW: 3G0 959 542 B
   Component: J IEEHOD1ZONE  251 0303
   Serial number: 00000000230201282907
   left tail lamp 1:
   Subsystem 4 - Part No SW: 1T3 945 207 F    HW: 1T3 945 207 F
   Component: SHLli1         040 5222
   Serial number: L0000202409210427457
   left tail lamp 2:
   Subsystem 5 - Part No SW: 1T3 945 307 F    HW: 1T3 945 307 F
   Component: SHLli2         071 5222
   Serial number: L0000202408290240443
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 1T3 945 208 F    HW: 1T3 945 208 F
   Component: SHLre1         040 5222
   Serial number: R0000202409210454157
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 1T3 945 307 F    HW: 1T3 945 307 F
   Component: SHLre2         071 5222
   Serial number: R0000202408290240456
8491266 - Secure Onboard Communication
          U14FE 00 [00101100] - Signature Verification Failed
          [SOK_signature_verification_failed]
                    Fault Frequency: 154
                    Mileage: 13 km
                    Date: 2024.12.10
                    Time: 19:14:06
8491267 - Secure Onboard Communication
          U14FF 00 [00100000] - Signature Generation Failed
          [SOK_signature_creation_failed]
                    Reset counter: 30
                    Mileage: 60 km
                    Date: 2024.12.13
                    Time: 20:35:40
8516869 - External Charging Infrastructure
          P1DCB 00 [01100100] - Not Ready for Charging Socket 1
          [HVLM_unknown_cp_communication_a]
                    Reset counter: 29
                    Mileage: 17 km
                    Date: 2024.12.10
                    Time: 22:46:59
8516873 - Unknown Error Code
          B1CA2 F1 [01101100] - Unknown Error Elaboration
          [HVLM_control_flap_lock_locking_a]
                    Reset counter: 32
                    Mileage: 18 km
                    Date: 2024.12.11
                    Time: 15:23:07
8830976 - Unknown Error Code
          U1A2F 00 [00100000] - -
          [Data_bus_mdk_single_wire_mode]
                    Mileage: 395 km
                    Date: 2024.12.25
                    Time: 20:51:29
   Part No SW: 1N3 909 059 AA    HW: 1N3 909 059
   Component: EBB-ZF-Gen1   H47 0853
   Serial number: 0000000         Dataset Number: V03935435CY 0001
   Coding: A0404080600028
   ASAM Dataset: EV_BrakeBoostZFMEBUNECE 001034
   ROD: EV_BrakeBoostZFMEBUNECE.rod
   VCID: 74B6062B3E3F5FBA67A-8020-R SFD
Address 2B: Steer. Col. Lock (J764)       Labels:. 3WA-905-861.clb
   Part No SW: 3WA 905 861     HW: 3WA 905 861
   Component: ELV-MQB_UNECE H05 0063
   Serial number: 24000226973004 Dataset Number: V03935384XW 0001
   Coding: 8880000000000000
   Shop #: WSC 00000 790 00077
   ASAM Dataset: EV_ELVMarqUNECE 003006
   ROD: EV_ELVMarqUNECE.rod
   VCID: 084E42DB52B74B5A3B2-805C-R SFD
   Component: MEM-FS        011 0571
   Serial number: 2490901KA01958 Dataset Number: V03935362VP 0001
   Coding: 0118BA4000013A008803010121010000000000000000000000000000215000
   ROD: EV_SCMDriveSideCONTIAU736_VW42.rod
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 14520053629613  Dataset Number: V03935416KP 0001
   Coding: 5A954750
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
   VCID: 3FDC990747F9CCE24A8-806A-R
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 14520054427148
   Part No SW: 1EA 959 593 F    HW: 1EA 959 593 F
   Component: TSG FS        009 0563
   Serial number: 0000536220247  Dataset Number: V03935421ZA 0001
   Coding: 0035DB20D200028044000020
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001004
   ROD: EV_DCU3DriveSideMAXHCONT_VWE3.rod
   VCID: 45D08BEF25259632004-8010-R
   Door operating panel: driver side:
   Subsystem 1 - Part No SW: 11A 959 862 C    HW: 11A 959 862 C
   Component: EX36 TBF_FS    H23 0116
   Serial number: 0248-24.08.24-------
   Part No SW: 1N3 907 144 Q    HW: 1N3 907 144 L
   Component: BASGEN1MQB37  131 7341
   Serial number: 01719785 Dataset Number: V03935435WK 0001
   Coding: 00000000000002010000020101000100000001000101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 017078
   ROD: EV_SteerAssisBASGEN1MQB37_017_VW27.rod
   VCID: 3C26EE0B56EFD7FA6FA-8068-R SFD
Address 51: Electric Drive (J841)       Labels: 0ET-907-INV-V1.clb
   Part No SW: 0ET 907 121 G    HW: 0ET 907 121 G
   Component: MEB INV6.0    H10 7260
   Dataset Number: V03935396ZE 0001
   ASAM Dataset: EV_DMCM21000110ET907121G 001001
   ROD: EV_DMCM21000110ET907121G.rod
   VCID: 44D696EB2E1FAF3A17A-8010-R SFD
41631 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 [00100000] - -
          [Lost Communication With Vehicle Dynamics Control Module]
41657 - Implausible Data Received from Engine Control Module
          U0401 00 [00101000] - -
          [Invalid Data Received From ECM/PCM "A"]
                    Reset counter: 37
                    Mileage: 119 km
                    Date: 2024.12.14
                    Time: 12:10:38
41665 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [00101000] - -
          [Lost Communication with ECM/PCM]
                    Mileage: 18 km
                    Date: 2024.12.11
                    Time: 16:41:40
43408 - Unknown Error Code
          U192A 00 [00101000] - -
          [Online Remote UpdateNo signal]
                    Fault Frequency: 209
                    Mileage: 13 km
                    Date: 2024.12.10
                    Time: 18:25:57
   Part No SW: 1EA 959 592 F    HW: 1EA 959 592 F
   Component: TSG BFS       009 0563
   Serial number: 0000537095500  Dataset Number: V03935435GJ 0001
   Coding: 00355320DE00028040800020
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001004
   ROD: EV_DCU3PasseSideMAXHCONT_VWE3.rod
   Part No SW: 10C 035 842 A    HW: 10C 035 842
   Component: IC3GSF--US    H09 3626
   Dataset Number: V03935418SE 0001
   Coding: 64101030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 002001
   ROD: EV_MUICASSAFEPart_002_VNE4.rod
   VCID: 1B640D97F321B0C2860-804E-R SFD
   Subsystem 1 - Part No SW: 1T3 919 605 M    HW: 1T3 919 605 D
   Component: ABT-E3_13      H43 4045
   Serial number: CKS00728072411552330
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 1EA 980 556 L    HW: 5WA 980 556 C
   Component: RV eCompact   H52 0574
   Serial number: FCLK20140824010 Dataset Number: V03935441LY 0001
   Coding: 0603460027140000
   ASAM Dataset: EV_CamSysRVCeCFicosUNECE 003008
   ROD: EV_CamSysRVCeCFicosUNECE.rod
   Part No SW: 4KE 959 107 B    HW: 4KE 959 107 B
   Component: HDSG-Modul    H08 0342
   Revision: --------    Serial number: A2-C765-4922-2 Dataset Number: V03935420NU 0001
   Coding: 6208
   ASAM Dataset: EV_DeckLidCONTIAU536 001006
   ROD: EV_DeckLidCONTIAU536_001_VWE3.rod
   Part No SW: 14A 035 285 A    HW: 14A 035 285
   Component: OCU4MEB_UNECE H11 0554
   Serial number: 0000000406VISM2 Dataset Number: V03935436CE 0001
   Coding: 06020700010000000000010013000000101112111012000010
   ASAM Dataset: EV_OCUGen4UNECE 001050
   ROD: EV_OCUGen4UNECE_VWE3.rod
   VCID: 1E620483E033A5EA61E-804A-R SFD
0082 - Databus
          U1121 00 [00100110] - Missing Message
          [Ethernet Databus missing message - Gateway]
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:57
                    Voltage terminal 30: 14.6 V
          U1400 00 [00100000] - -
          [Functional restrictiondue to insufficient voltage]
                    Reset counter: 30
                    Mileage: 12 km
                    Date: 2000.01.01
                    Time: 00:00:35
                    Voltage terminal 30: 5.5 V
1375744 - Secure Onboard Communication
                    Fault Frequency: 21
                    Mileage: 19 km
                    Date: 2024.12.11
                    Time: 19:24:16
1375488 - Secure Onboard Communication
          U14FD 00 [00100000] - Time Server not Available
          [SOK_timeserver_not_available]
                    Reset counter: 10
1586 - invalid data record
          B2005 00 [01100000] - -
          [Ecu_dataset download_invalid_data_record_audio]
                    Reset counter: 36
                    Voltage terminal 30: 12.7 V
Address 8C: HV Battery (J840)       Labels: 0Z1-915-184.clb
   Part No SW: 0Z1 915 184 AE    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 010 1141
   Serial number: 000000040924020 Dataset Number: V03935430CT 0001 CVN: 7AA92BF600000000976986D0453CFE57453CFE57453CFE57
   ASAM Dataset: EV_BMCeVWBSMEB 003018
   ROD: EV_BMCeVWBSMEB_003_VWE3.rod
   VCID: 7DA0230F0D751EF2184-8028-R
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 BL    HW: 0Z1 915 140 BC
   Component: SX6  X74  CMC  005 1140
   Serial number: 00000001092403010289
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000012092401060461
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000012092401070514
   Cell module control module 13:
   Subsystem 4 - Part No SW: 0Z1 915 140 M    HW: 0Z1 915 140 D
   Serial number: 00000012092401070442
   Coolant heating:
   Subsystem 5 - Part No SW: 1EE 963 231     HW: 1EE 963 231
   Component: J848 HV-PTC    H04 0026
   Serial number: 1EE96323124257002734
   Part No SW: 1EA 980 653 E    HW: 1EA 980 653 A
   Component: MEB MFK 4.1   H08 5556
   Dataset Number: V03935445AY 0001
   Coding: 010A302E1F4500F83724301C4000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001080
   ROD: EV_MFK41ValeoMEB_VWE3.rod
1124497 - Databus
          U1123 00 [00101110] - Received Error Message
          [ACC_18_ACC_Status_ACC_irreversibel_ERROR]
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:47:11
1124496 - Databus
          [ACC_18_ACC_Status_ACC_reversibel_ERROR]
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:53
1126421 - Databus
          [FAS_Anzeigen_01_KBI_Anzeigefehler_LDW_Anzeigefehler_ERROR]
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:58
1126434 - Unknown Error Code
          C110A F7 [00101000] - Unknown Error Elaboration
          [Temporary_blindness_of_lane_detection]
                    Reset counter: 24
                    Mileage: 120 km
                    Date: 2024.12.14
                    Time: 12:12:48
                    Blindness_cause_light_functions: Glare
                    Blindness_cause_traffic_sign_control: none
                    Blindness_cause_error_memory: Glare
                    Blindness_cause_pedestrian_detection: Glare
                    Blindness_cause_lane_detection: frozen_windshield
                    Blindness_cause_object_detection: Glare
                    Blindness_cause_road_free_detection: Glare
                    Blindness_cause_windscreen_heater_request: none
                    Blindness_detection_visibility_range: Blindness_detection_no_visibility
1126487 - Databus
          U1123 00 [00101000] - Received Error Message
          [Airbag_02_AB_Gurtschloss_Reihe3_FA_ERROR]
                    Mileage: 75 km
                    Date: 2024.12.13
                    Time: 21:13:39
1126489 - Databus
          [Airbag_02_AB_Gurtschloss_Reihe3_BF_ERROR]
                    Reset counter: 33
                    Mileage: 245 km
                    Date: 2024.12.15
                    Time: 17:37:49
Address BE: Slid. Door Rear Left (J926)       Labels:| 1N3-959-244.clb
   Part No SW: 1N3 959 244 B    HW: 1N3 959 244 B
   Component: Slidingdoor_d H04 0028
   Serial number: 97092947 Dataset Number: V03935426PK 1510
   Coding: D600
   ASAM Dataset: EV_SlideDoorDriveHufIDBuz 002110
   ROD: EV_SlideDoorDriveHufIDBuz_002.rod
   VCID: 3530FB2F75C506B2904-8060-R
37460 - Control Module for Sliding Door
          B1307 54 [00100000] - Missing Calibration / Basic Setting
          [Door_window_not_normalized]
32793 - Unknown Error Code
          B1BAC 19 [01100000] - Current Too High
          [Arrester_over_current]
32785 - Unknown Error Code
          B1BAC 11 [01100000] - Short to Ground
          [Arrester_short_circuit_to_ground]
Address BF: Slid. Door Rear Right (J927)       Labels:| 1N3-959-244.clb
   Component: Slidingdoor_p H04 0028
   Serial number: 97093505 Dataset Number: V03935426PL 1510
   Coding: D600
   ASAM Dataset: EV_SlideDoorPasseHufIDBuz 002110
   ROD: EV_SlideDoorPasseHufIDBuz_002.rod
Address C0: Act. for Ext. Noise (J943)       Labels: 1EA-035-335.clb
   Part No SW: 1T3 035 335 A    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0006
   Serial number: JTK072300824953
   ASAM Dataset: EV_ESounHarmaMEBUNECE 001006
   ROD: EV_ESounHarmaMEBUNECE_VWE3.rod
   VCID: 2C06DE4BA68F477AFFA-8078-R
   Part No SW: 1EK 915 692 J    HW: 1EK 915 692 H
   Component: OCDC Gen4+    H03 2207
   Revision: 00H03000
   Coding: 308010
   ASAM Dataset: EV_OCDCXPHASERB8MEBB 002001
   ROD: EV_OCDCXPHASERB8MEBB_002_VWE3.rod
   VCID: 4BC4BDD703416042D60-801E-R SFD
151554 - Unknown Error Code
          P1EE7 00 [01100000] - -
          [PLC_firmware_download_error]
                    Reset counter: 25
                    Mileage: 17 km
                    Date: 2024.12.10
                    Time: 22:46:35
   Part No SW: 992 941 572 AG    HW: 992 941 572 A
   Component: LED1L         H17 9104
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 002003
   ROD: EV_LLPGen3LKEBODPO68X_002_VW27.rod
   VCID: 688E625B72F7AB5ADB2-803C-R
131329 - Databus
          U1201 00 [00101000] - No Communications
          [can data bus - no communication]
                    Reset counter: 39
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:47:10
131332 - Databus
          U1121 00 [00101000] - Missing Message
          [can message LED_Soll_Fkt2 missing]
                    Reset counter: 39
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:53
131347 - Databus
          [CAN message ESP_21 missing]
                    Reset counter: 39
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:53
131353 - Databus
          [CAN message Klemmen_Status_01 missing]
                    Reset counter: 39
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:53
   Component: LED1R         H17 9104
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 002003
   ROD: EV_LLPGen3RKEBODPO68X_002_VW27.rod
131329 - Databus
                    Reset counter: 39
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:47:10
131332 - Databus
                    Reset counter: 39
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:53
131347 - Databus
                    Reset counter: 39
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:53
131353 - Databus
                    Reset counter: 39
                    Mileage: 464 km
                    Date: 2024.12.30
                    Time: 16:46:53
Address DE: Charger 1 for mobile dev (J0000)       Labels:* None
   Part No SW: 3P0 035 502 B    HW: 3P0 035 502
   Component: COUPLING BOX  004 0170
   Serial number: 324000000000038 Dataset Number: V03935426MT 0001
   Coding: 400080
   ASAM Dataset: EV_DualCouplBoxSK336 001006
   ROD: EV_DualCouplBoxSK336.rod
   VCID: 2416366BCE5F8F3A37A-8070-R SFD
Address 8116: Snd enhanct 2 (J943)       Labels: None
   Part No SW: 1T3 035 335 B    HW: 1EA 035 335
   Component: E_SOUND_SG    H06 0007
   Serial number: JTK072160824953
   ASAM Dataset: EV_ESoun2HarmaMEBUNECE 001003
   ROD: EV_ESoun2HarmaMEBUNECE.rod
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: V04-007-XXX-SWC4.clb
   Part No: V04 007 003 LE
   Component: ICAS1 Sys_Ada 0254
   Dataset Number: V03935439BB 0001
   ASAM Dataset: EV_AppServ1Sys1ICAS1UNECE 001002
   ROD: EV_AppServ1Sys1ICAS1UNECE.rod
   VCID: 75B03B2F354546B2504-8020-R SFD
Address 8124: App server 1 system 2 Java (SWC5)       Labels: V04-007-XXX-SWC5.clb
   Part No: V04 007 003 LF
   Component: ICAS1 Sys_Jav 0254
   Dataset Number: V03935439BA 0001
   ASAM Dataset: EV_AppServ1Sys2ICAS1UNECE 001002
   ROD: EV_AppServ1Sys2ICAS1UNECE_VWE3.rod
   VCID: 76B23C2328434DAA59E-8022-R SFD
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:| V04-007-XXX-SWC6.clb
   Part No: V04 007 003 RH
   Component: IC3GIVI-S--US 3626
   Dataset Number: V03935442BN 0001
   ASAM Dataset: EV_MUICASIVIPart 003001
   ROD: EV_MUICASIVIPart_003_VWE3.rod
   VCID: 7EA22403007305EA01E-802A-R SFD
Address 8128: Light line display (J145)       Labels: 1T3-919-451.clb
   Part No SW: 1T3 919 451 G    HW: 1T3 919 451 G
   Component: ID_Light_GA   033 0074
   ASAM Dataset: EV_SmartLight1MEBGA 001014
   ROD: EV_SmartLight1MEBGA.rod
Address C002: SW Cluster Embedded (SWC2)       Labels: V04-007-XXX-SWC2.clb
   Part No: V04 007 003 LG
   Component: ICAS1 SWCL_Em 0254
   Dataset Number: V03935439BG 0001
   ASAM Dataset: EV_SWCLEmbed1ICAS1UNECE 001002
   ROD: EV_SWCLEmbed1ICAS1UNECE_VWE3.rod
   VCID: 77AC31272F4934A2428-8022-R SFD
13706049 - Databus
          [WLA_Blindheit received error value]
0268 - Unknown Error Code
          U1775 00 [00100110] - -
          [R7_Illegal_memory_access]
                    Date: 2024.12.30
8516625 - Expanded Charging Functions
          U15E9 00 [01101100] - Charging Plan Programming Error
                    Mileage: 458 km
                    Date: 2024.12.28
                    Time: 14:51:58
Address C003: SW Cluster Housekeeping (SWC3)       Labels: V04-007-XXX-SWC3.clb
   Part No: V04 007 003 LH
   Component: ICAS1 SWCL_HK 0254
   ASAM Dataset: EV_SWCLHouse1ICAS1UNECE 001002
   ROD: EV_SWCLHouse1ICAS1UNECE.rod
End----------(Elapsed Time: 02:31, VBatt start/end: 14.6V/14.8V)-----------
Jef
HQ
Seems to be some paste formatting issue on the forum.... maps are 80meters wide. But paste into notepad++ and it looks normal. 2 different computers, same issue.
Trying smaller chunks
blockmap-01-0EA-906-014-GG_WVGAWVEB7SH010695-20241230-1124.CSV
;SW:0EA-906-014-GG   HW:0EA-907-425-K ---  Engine
;Component:E-Vehicle     H80 3875, Coding:4102000350042C0236000800000000000000000000000000
;EV_VCU00XXX0200EA906014GG,003002,EV_VCU00XXX020_VNE4.rod
;Monday,30,December,2024,11:24:33:18177
;VCDS Version: Beta 24.12.0 (x64)  Data version: 20241120 DS361.3
;VCID: 78AE321B22573BDA4B2-802C-R SFD
Group,Description,Actual
IDE00011,Vehicle Identification Number (VIN),||WVGAWVEB7SH010695|,
IDE00019,Voltage terminal 30,14.882, V
IDE00086,Accelerator pedal position,14.5, %
IDE00089,Driving position,P,
IDE00097,OBD - requirements for which this vehicle is designed,None,
IDE00102,Control Module temperature,33.0, °C
IDE00150,Pressure in brake servo unit,0.000, bar
IDE00252,Brake system vacuum pump,Pump off,
IDE00380,Coolant fan 1: activation,9.77, %
IDE00392,Accelerator pedal: sensor voltage 1,0.720, V
IDE00393,Accelerator pedal: sensor voltage 2,0.360, V
IDE00451,Currently running routine,Unknown (0),
IDE00541,Acceleration,0.000, m/s²
IDE00601,Monitoring status since erasing DTC memory,,
IDE00973,Outside temperature,12.0, °C
IDE01021,Current of H-V / hybrid battery,-5.9, A
IDE01714,Status reverse gear,not selected,
IDE01922,Vehicle distance driven,464, km
IDE02656,System condition of parking brake,closed,
IDE02832,Coolant circulation pump: activation,65.36, %
IDE03767,Engine status,Stop,
IDE04885,Hybrid batt charge cond act val standardized,62.00, %
IDE04913,Current speed of electric motor,0.0, /min
IDE05679-MAS19394,Accelerator monitoring level-Accelerator pedal position status,Not operated,
IDE06703-IDE12714,Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration,No,
IDE06703-MAS14977,Drivetrain coordinator: ACC fault status-ACC active: although TSK passive,No,
IDE06703-MAS14978,Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set,No,
IDE06703-MAS14979,Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously,No,
IDE06703-MAS14980,Drivetrain coordinator: ACC fault status-ACC active: although limiter active,No,
IDE06703-MAS14981,Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking,No,
IDE06703-MAS14982,Drivetrain coordinator: ACC fault status-ACC sends undefined signals,No,
IDE06703-MAS14983,Drivetrain coordinator: ACC fault status-ACC active although main switch off,No,
IDE06703-MAS14984,Drivetrain coordinator: ACC fault status-ACC is active despite driver braking,No,
IDE06703-MAS14985,Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling,No,
IDE06704-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE06704-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE06704-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE06704-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE06704-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE06704-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE06704-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE06704-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE06705-MAS05179,Drivetrain coordinator: brake function status-ABS intervention,No,
IDE06705-MAS05180,Drivetrain coordinator: brake function status-ESP intervention,No,
IDE06705-MAS05181,Drivetrain coordinator: brake function status-EDL intervention,No,
IDE06705-MAS05186,Drivetrain coordinator: brake function status-ASR intervention,No,
IDE06705-MAS05187,Drivetrain coordinator: brake function status-MSR intervention,No,
IDE06705-MAS05192,Drivetrain coordinator: brake function status-Driver braking,Yes,
IDE06705-MAS05195,Drivetrain coordinator: brake function status-HDC active,No,
IDE06705-MAS15001,Drivetrain coordinator: brake function status-ESP invokes TSK braking,No,
IDE06705-MAS15002,Drivetrain coordinator: brake function status-EPB active,No,
IDE06705-MAS15003,Drivetrain coordinator: brake function status-ASP intervention,No,
IDE06705-MAS15004,Drivetrain coordinator: brake function status-ADS intervention,No,
IDE06705-MAS15006,Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt,No,
IDE06705-MAS15007,Drivetrain coordinator: brake function status-ESP sampled passive (ESP off),No,
IDE06705-MAS15008,Drivetrain coordinator: brake function status-ASR sampled passive (ASR off),No,
IDE06705-MAS15009,Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest,Yes,
IDE06705-MAS15010,Drivetrain coordinator: brake function status-ACC stopping distance control active,No,
IDE06706,ACC variants,ACC with Stop & Go,
IDE06707,CCS Switch,ACC operating unit,
IDE06709,ACC variants (coding),ACC with braking until standstill / Stop & Go,
IDE07543,Vehicle speed,0.00, km/h
IDE07575,Driver intention torque,0.0, Nm
IDE07598-MAS00320,Cruise control switch actuation-Main switch,operated,
IDE07598-MAS00325,Cruise control switch actuation-Set,Not operated,
IDE07598-MAS00326,Cruise control switch actuation-Resume,Not operated,
IDE07598-MAS01632,Cruise control switch actuation-Status,OK,
IDE07598-MAS02309,Cruise control switch actuation-Accelerate,Not operated,
IDE07598-MAS02310,Cruise control switch actuation-DELAY,Not operated,
IDE07598-MAS05172,Cruise control switch actuation-Cancel,Not operated,
IDE07598-MAS05806,Cruise control switch actuation-Main switch hardware,operated,
IDE07598-MAS05807,Cruise control switch actuation-Coding,plausible,
IDE07598-MAS05809,Cruise control switch actuation-Limit function,not selected,
IDE07598-MAS05812,Cruise control switch actuation-Limit button,Not operated,
IDE07598-MAS05813,Cruise control switch actuation-Main switch CAN,operated,
IDE07598-MAS05842,Cruise control switch actuation-Large increment,Not operated,
IDE07598-MAS05843,Cruise control switch actuation-Control component verified,Yes,
IDE07605,Cruise control system: temporary deactivation,No switch-off,
IDE07608,Standard test of current section,0,
IDE07904-ENG118117,Brake test switch status-actuated__activated,operated,
IDE07904-ENG114825,Brake test switch status-Ident_32,1,
IDE07905-ENG118117,Brake light switch status-actuated__activated,operated,
IDE07905-ENG114825,Brake light switch status-Ident_32,1,
IDE08998-MAS05117,Driver info-Driver,not installed,
IDE09098,E-machine electrical power,275.296, kW
IDE09099,E-machine mechanical power,231.712, kW
IDE09116,Power electronics: traction network voltage,399.3, V
IDE10300,OBD Driving Cycle detected,active,
IDE10710-ENG125936,Exhaust warning light: triggering contr. module-Blinking_MIL_due_to_misfire_is_causing_catalyst_damage,No,
IDE10710-ENG130107,Exhaust warning light: triggering contr. module-MIL Request from Transmission Control Module,No,
IDE10710-ENG355207,Exhaust warning light: triggering contr. module-MIL_Request_from_BCCM,No,
IDE10710-ENG353763,Exhaust warning light: triggering contr. module-MIL_Request_from_DCDC,No,
IDE10710-ENG125937,Exhaust warning light: triggering contr. module-MIL_request_register_ident,0,
IDE10710-ENG420335,Exhaust warning light: triggering contr. module-MIL-Request from Battery Diagnostic Control Module,No,
IDE10710-ENG130102,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module,No,
IDE10710-ENG137566,Exhaust warning light: triggering contr. module-MIL-Request from Battery Energy Control Module 48V,No,
IDE10710-ENG130110,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module,No,
IDE10710-ENG130100,Exhaust warning light: triggering contr. module-MIL-Request from Brake System Control Module 2,No,
IDE10710-ENG130103,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module,No,
IDE10710-ENG130109,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 2,No,
IDE10710-ENG137567,Exhaust warning light: triggering contr. module-MIL-Request from Drive Motor Control Module 48V,No,
IDE10710-ENG130105,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module,No,
IDE10710-ENG130106,Exhaust warning light: triggering contr. module-MIL-Request from Engine Control Module 2,No,
IDE10710-ENG130111,Exhaust warning light: triggering contr. module-MIL-Request from HVAC Control Module,No,
IDE10710-ENG130108,Exhaust warning light: triggering contr. module-MIL-Request from Transmission Control Module 2,No,
IDE11663-IDE06673,H-V energy management mode-Initialization status,not active,
IDE11663-IDE12475,H-V energy management mode-Input status,OK,
IDE11663-MAS01458,H-V energy management mode-Operating condition,not active,
IDE13301-MAS06606,Drivetrain coordinator: brake fault status-Brake under pressure too low,No,
IDE13301-MAS14986,Drivetrain coordinator: brake fault status-Deceleration sensor not available,No,
IDE13301-MAS14987,Drivetrain coordinator: brake fault status-Deceleration sensor malfunction,No,
IDE13301-MAS14988,Drivetrain coordinator: brake fault status-ESP system error,No,
IDE13301-MAS14989,Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque,No,
IDE13301-MAS14990,Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error,No,
IDE13301-MAS14991,Drivetrain coordinator: brake fault status-TSK/ESP handshake error,No,
IDE13301-MAS14992,Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction,No,
IDE13301-MAS14993,Drivetrain coordinator: brake fault status-Brake light implausible,No,
IDE13301-MAS16114,Drivetrain coordinator: brake fault status-Deceleration management error,No,
IDE13301-MAS16115,Drivetrain coordinator: brake fault status-Deceleration management: restricted performance,No,
IDE13301-MAS16116,Drivetrain coordinator: brake fault status-Deceleration management not available,No,
IDE13336-MAS04795,Drive train coordinator reversible switch off conditions-main switch off,No,
IDE13336-MAS05192,Drive train coordinator reversible switch off conditions-Driver braking,Yes,
IDE13336-MAS05823,Drive train coordinator reversible switch off conditions-Speed signal error during initialization,No,
IDE13336-MAS05824,Drive train coordinator reversible switch off conditions-Emer. engine operation,No,
IDE13336-MAS05836,Drive train coordinator reversible switch off conditions-Acceleration monitoring error,No,
IDE13336-MAS05901,Drive train coordinator reversible switch off conditions-Trans. emerg. operation,No,
IDE13336-MAS12585,Drive train coordinator reversible switch off conditions-Speed threshold for reversible ACC shut-off,No,
IDE13336-MAS12586,Drive train coordinator reversible switch off conditions-Speed threshold for ending the brake torque shut-off ramp,No,
IDE13336-MAS12588,Drive train coordinator reversible switch off conditions-Speed cut-off active,No,
IDE13336-MAS12590,Drive train coordinator reversible switch off conditions-Reversible brake system error,No,
IDE13336-MAS12591,Drive train coordinator reversible switch off conditions-Engine off or drive is not ready,Yes,
IDE13336-MAS15049,Drive train coordinator reversible switch off conditions-Drive train open or no gear selected,No,
IDE13336-MAS16227,Drive train coordinator reversible switch off conditions-Stopping distance reduction 3 interventions,No,
IDE13336-MAS16228,Drive train coordinator reversible switch off conditions-Tracking system interface shutdown,No,
IDE13336-MAS16230,Drive train coordinator reversible switch off conditions-ESP safety-related message condition,No,
IDE13336-MAS16231,Drive train coordinator reversible switch off conditions-ACC switch off because of driver braking,No,
IDE13336-MAS16232,Drive train coordinator reversible switch off conditions-PCC sensor: reversible error,No,
IDE13336-MAS16235,Drive train coordinator reversible switch off conditions-Intelligent parking assistant reversible error,No,
IDE13336-MAS16246,Drive train coordinator reversible switch off conditions-ACC breaking only possible because of CAN bus,No,
IDE13336-MAS16247,Drive train coordinator reversible switch off conditions-Diagnostics fadeout due to identified malfunction,No,
IDE13336-MAS16248,Drive train coordinator reversible switch off conditions-Safety computer detects crash,No,
IDE13336-MAS16249,Drive train coordinator reversible switch off conditions-Electrical parking brake: braking,No,
IDE13336-MAS16253,Drive train coordinator reversible switch off conditions-GRA breaking intervention: switch off due to brake disc temperature,No,
IDE13336-MAS16254,Drive train coordinator reversible switch off conditions-Hill descent assistant active,No,
IDE13336-MAS16255,Drive train coordinator reversible switch off conditions-Locking by trailer shunting assistant,No,
IDE13336-MAS16256,Drive train coordinator reversible switch off conditions-Blocking by parking assistant,No,
IDE13337-MAS05814,Drive train coordinator irreversible switch off conditions-CAN communication error,No,
IDE13337-MAS05815,Drive train coordinator irreversible switch off conditions-CAN signal error,No,
IDE13337-MAS05818,Drive train coordinator irreversible switch off conditions-Transmission coding not plausible,No,
IDE13337-MAS05820,Drive train coordinator irreversible switch off conditions-ACC error,No,
IDE13337-MAS05821,Drive train coordinator irreversible switch off conditions-Braking intervention too weak,No,
IDE13337-MAS05824,Drive train coordinator irreversible switch off conditions-Emer. engine operation,No,
IDE13337-MAS05825,Drive train coordinator irreversible switch off conditions-Engine control module fault,No,
IDE13337-MAS05829,Drive train coordinator irreversible switch off conditions-Brake light fault,No,
IDE13337-MAS05830,Drive train coordinator irreversible switch off conditions-CCS deactivated due to fault in control component,No,
IDE13337-MAS05831,Drive train coordinator irreversible switch off conditions-ACC deactivated due to fault in control component,No,
IDE13337-MAS05832,Drive train coordinator irreversible switch off conditions-Coding error,No,
IDE13337-MAS05833,Drive train coordinator irreversible switch off conditions-ESC error,No,
IDE13337-MAS05835,Drive train coordinator irreversible switch off conditions-Clutch pedal fault,No,
IDE13337-MAS05836,Drive train coordinator irreversible switch off conditions-Acceleration monitoring error,No,
IDE13337-MAS15052,Drive train coordinator irreversible switch off conditions-Brake light actuation malfunction,No,
IDE13337-MAS16257,Drive train coordinator irreversible switch off conditions-Brake pedal implausible,No,
IDE13337-MAS16258,Drive train coordinator irreversible switch off conditions-Transport mode active,No,
IDE13337-MAS16259,Drive train coordinator irreversible switch off conditions-GRA looking due to software as product,No,
IDE13337-MAS16260,Drive train coordinator irreversible switch off conditions-Emergency assistant: actual acceleration error,No,
IDE13337-MAS16262,Drive train coordinator irreversible switch off conditions-Vehicle speed determination: substitute value,No,
IDE13337-MAS16263,Drive train coordinator irreversible switch off conditions-Intelligent parking assistant irreversible error,No,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVGAWVEB7SH010695,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,8,
IDE13845,Production mode status,not active,
IDE14051,Parking lock actuator: actual position as a percentage,0, %
IDE14052,Parking lock actuator: actual position,Initialization,
IDE14054,Parking lock actuator: current,0.0, A
IDE14055,Parking lock actuator: supply voltage,5, V
IDE14056,Parking lock actuator: temperature,-40, °C
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 D8,
IDE14492-MAS28619,Secure Onboard Communication: verification failed-currently failed,not failed,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3D 5C A0 C2 C8 30 45,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,9,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0A,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE15328,Status of electrical system converter: high-voltage system maintenance connector,Terminal 30c not interrupted,
IDE15329,Status of high-voltage battery management system maintenance plug,Terminal 30c not interrupted,
IDE15573,High-voltage contactors: error status,no contactor was detected as worn,
IDE15578,High-voltage de-energization: electrical system converter status,High-voltage components not de-energized,
IDE15596,High-voltage charging plug: status,no plug detected,
IDE15597,Detection status: open high-voltage wire on chargers,no open high-voltage wire detected,
IDE15781,VW Trustcenter Project ID,1044,
IDE16005,Drive train coordinator: acceleration request target value,0.13, m/s²
IDE16006-MAS00086,Drive train coordinator current status-active,No,
IDE16006-MAS00087,Drive train coordinator current status-passive,Yes,
IDE16006-MAS00342,Drive train coordinator current status-Initialization,not active,
IDE16006-MAS00519,Drive train coordinator current status-Condition violated,not active,
IDE16006-MAS04795,Drive train coordinator current status-main switch off,not active,
IDE16006-MAS21866,Drive train coordinator current status-Braking on shutdown Assistant system,not active,
IDE16006-MAS21867,Drive train coordinator current status-Assistant system shutdown: reversible,No,
IDE16006-MAS21868,Drive train coordinator current status-irreversible off,No,
IDE16007-MAS01102,Drive train coordinator: Acceleration Requester Status-Cruise control system,No,
IDE16007-MAS05189,Drive train coordinator: Acceleration Requester Status-Speed limiter active,No,
IDE16007-MAS09193,Drive train coordinator: Acceleration Requester Status-PLA,No,
IDE16007-MAS09331,Drive train coordinator: Acceleration Requester Status-no function,Yes,
IDE16007-MAS12321,Drive train coordinator: Acceleration Requester Status-Trailer positioning assistant,No,
IDE16007-MAS12422,Drive train coordinator: Acceleration Requester Status-intelligent parking assistant,No,
IDE16007-MAS14343,Drive train coordinator: Acceleration Requester Status-Predictive efficiency assistant,No,
IDE16007-MAS18082,Drive train coordinator: Acceleration Requester Status-Emergency assistant,No,
IDE16008-MAS03758,Drive Train Coordinator: Embassies Status-Not assigned,no error in message,
IDE16008-MAS22018,Drive Train Coordinator: Embassies Status-Error in ESP message,no error in message,
IDE16008-MAS22019,Drive Train Coordinator: Embassies Status-Error in ESP message (preliminary),no error in message,
IDE16008-MAS22020,Drive Train Coordinator: Embassies Status-Error in message electric parking brake (EPB),no error in message,
IDE16008-MAS22021,Drive Train Coordinator: Embassies Status-Error in ACC message,no error in message,
IDE16008-MAS22022,Drive Train Coordinator: Embassies Status-Error in ACC message (preliminary),no error in message,
IDE16008-MAS22023,Drive Train Coordinator: Embassies Status-Error in message control unit (SMLS),no error in message,
IDE16008-MAS22024,Drive Train Coordinator: Embassies Status-Error in message control panel (SMLS) (preliminary),no error in message,
IDE16008-MAS22025,Drive Train Coordinator: Embassies Status-Error in message transmission,no error in message,
IDE16008-MAS22026,Drive Train Coordinator: Embassies Status-Error in message Instrument cluster,no error in message,
IDE16008-MAS22027,Drive Train Coordinator: Embassies Status-Error in message rear light,no error in message,
IDE16008-MAS22028,Drive Train Coordinator: Embassies Status-Error in message trailer,no error in message,
IDE16008-MAS22029,Drive Train Coordinator: Embassies Status-Error in message airbag,no error in message,
IDE16008-MAS22030,Drive Train Coordinator: Embassies Status-Error in message Satellite Tracking System (STS),no error in message,
IDE16008-MAS22031,Drive Train Coordinator: Embassies Status-Error in message steering (LWI/SCU),no error in message,
IDE16008-MAS22032,Drive Train Coordinator: Embassies Status-Error in message gateway,no error in message,
IDE16008-MAS22033,Drive Train Coordinator: Embassies Status-Error in message all wheel drive,no error in message,
IDE16008-MAS22034,Drive Train Coordinator: Embassies Status-Error in message chassis,no error in message,
IDE16008-MAS22035,Drive Train Coordinator: Embassies Status-Error in message Trailer Shunting Assistant (TSA),no error in message,
IDE16008-MAS22036,Drive Train Coordinator: Embassies Status-Error in Message Parking Steering Assistant (PLA),no error in message,
IDE16008-MAS22037,Drive Train Coordinator: Embassies Status-Error in message Intelligent Park Assistant (IPA),no error in message,
IDE16008-MAS22038,Drive Train Coordinator: Embassies Status-Error in message Emergency Assist (EA),no error in message,
IDE16008-MAS22039,Drive Train Coordinator: Embassies Status-Error in message maximum speed for spoiler,no error in message,
IDE16008-MAS22040,Drive Train Coordinator: Embassies Status-Error in message traffic congestion pilot,no error in message,
IDE16008-MAS22041,Drive Train Coordinator: Embassies Status-Error in message predictive fuel consumption display,no error in message,
IDE16008-MAS22042,Drive Train Coordinator: Embassies Status-Error in message specific function control unit (KFG),no error in message,
IDE16008-MAS22044,Drive Train Coordinator: Embassies Status-Error in message from active chassis (EML),no error in message,
IDE16009-MAS05087,Drivetrain coordinator: proximity control type-ACC,installed,
IDE16009-MAS05088,Drivetrain coordinator: proximity control type-ACC with braking until at standstill,installed,
IDE16009-MAS05089,Drivetrain coordinator: proximity control type-ACC with Stop & Go,not installed,
IDE16009-MAS05205,Drivetrain coordinator: proximity control type-Basic ACC (without braking until at standstill),installed,
IDE16010-MAS00320,Driver assistance systems: control panel actuations-Main switch,not engaged,
IDE16010-MAS00325,Driver assistance systems: control panel actuations-Set,Not operated,
IDE16010-MAS00326,Driver assistance systems: control panel actuations-Resume,Not operated,
IDE16010-MAS02321,Driver assistance systems: control panel actuations-Cancel,On,
IDE16010-MAS05168,Driver assistance systems: control panel actuations-Control malfunction,No,
IDE16010-MAS05846,Driver assistance systems: control panel actuations-up,Not operated,
IDE16010-MAS07156,Driver assistance systems: control panel actuations-down,Not operated,
IDE16010-MAS10720,Driver assistance systems: control panel actuations-Speed limiter,not active,
IDE16010-MAS21855,Driver assistance systems: control panel actuations-CCS type control panel b0,Yes,
IDE16010-MAS21856,Driver assistance systems: control panel actuations-CCS type control panel b1,Yes,
IDE16010-MAS21857,Driver assistance systems: control panel actuations-CCS type control panel b2,No,
IDE16010-MAS21858,Driver assistance systems: control panel actuations-CCS limiter button available,not installed,
IDE16010-MAS21859,Driver assistance systems: control panel actuations-Tap in stage 2,Not operated,
IDE16010-MAS21860,Driver assistance systems: control panel actuations-Adjustment time gap down,Not operated,
IDE16010-MAS21861,Driver assistance systems: control panel actuations-Adjustment time gap up,Not operated,
IDE16010-MAS21862,Driver assistance systems: control panel actuations-Main switch type,engaged,
IDE16011-MAS05168,Drive train coordinator: blocking reasons of CCS and limiter-Control malfunction,No malfunction,
IDE16011-MAS14948,Drive train coordinator: blocking reasons of CCS and limiter-Irreversible brake malfunction relevant for limiter,No malfunction,
IDE16011-MAS21900,Drive train coordinator: blocking reasons of CCS and limiter-Implausible behavior of the display,No malfunction,
IDE16011-MAS21901,Drive train coordinator: blocking reasons of CCS and limiter-Blocking request CCS and limiter,No malfunction,
IDE16011-MAS21902,Drive train coordinator: blocking reasons of CCS and limiter-Vehicle speed or ESP message errors,No malfunction,
IDE16011-MAS21903,Drive train coordinator: blocking reasons of CCS and limiter-Monitoring function error,No malfunction,
IDE16011-MAS21904,Drive train coordinator: blocking reasons of CCS and limiter-Control panel messages,No malfunction,
IDE16024-MAS15052,Drive train coordinator: blocking reasons-Brake light actuation malfunction,No,
IDE16024-MAS16258,Drive train coordinator: blocking reasons-Transport mode active,No,
IDE16024-MAS21932,Drive train coordinator: blocking reasons-Error message of the brake system,No,
IDE16024-MAS21933,Drive train coordinator: blocking reasons-Variant error ACC type,No,
IDE16024-MAS21934,Drive train coordinator: blocking reasons-Intelligent Park Assistant error message,No,
IDE16024-MAS21935,Drive train coordinator: blocking reasons-Control panel error ACC and CCS,No,
IDE16024-MAS21936,Drive train coordinator: blocking reasons-Control panel error CCS,No,
IDE16024-MAS21937,Drive train coordinator: blocking reasons-Defective brake light,No,
IDE16024-MAS21938,Drive train coordinator: blocking reasons-Driver's wish no longer discernible,No,
IDE16024-MAS21939,Drive train coordinator: blocking reasons-Engine emergency run: power limitation,No,
IDE16024-MAS21940,Drive train coordinator: blocking reasons-Speed signal substitute value,No,
IDE16024-MAS21941,Drive train coordinator: blocking reasons-Error of the Emergency Assist Target acceleration,No,
IDE16024-MAS21942,Drive train coordinator: blocking reasons-Monitoring of control deviation Brakes,No,
IDE16024-MAS21943,Drive train coordinator: blocking reasons-Implausible coding of the gearbox variant,No,
IDE16024-MAS21944,Drive train coordinator: blocking reasons-CCS lock condition software as product,No,
IDE16024-MAS21945,Drive train coordinator: blocking reasons-ACC system error,No,
IDE16024-MAS21946,Drive train coordinator: blocking reasons-Error Monitoring Actual acceleration / control deviation,No,
IDE16024-MAS21947,Drive train coordinator: blocking reasons-Error clutch switch,No,
IDE16024-MAS21948,Drive train coordinator: blocking reasons-Plausibility error brake pedal,No,
IDE16024-MAS21949,Drive train coordinator: blocking reasons-Substitute values for relevant input signals,No,
IDE16024-MAS21950,Drive train coordinator: blocking reasons-Error relevant CAN messages,No,
IDE16076,Front axle: minimum mechanical power,0.0, kW
IDE16077,Front axle: maximum mechanical power,0.0, kW
IDE16078,Rear axle: maximum mechanical power,231.7, kW
IDE16079,Rear axle: minimum mechanical performance,-162.8, kW
IDE16080,All wheel drive: electric front axle drive nominal torque,0, Nm
IDE16081,All-wheel drive: electric rear axle drive Nominal torque,0.250004, Nm
IDE16082,All wheel drive: longitudinal torque controller system status,3, no unit
IDE16083,All wheel drive: torque limitation front axle,0, Nm
IDE16084,All wheel drive: torque limitation rear axle,5100, Nm
IDE16085,All wheel drive: electric front axle drive actual torque,0, Nm
IDE16086,All-wheel drive: electric rear axle drive actual torque,0, Nm
IDE16087,All-wheel drive: differential torque target value,0, Nm
IDE16088,All wheel drive: electric front axle drive operating mode,15, no unit
IDE16089,All-wheel drive: electric rear axle drive Operating mode,8, no unit
IDE16090,All-wheel drive: electronic torque control Error status,0, no unit
IDE16091,All-wheel drive: electronic torque control System status,3, no unit
IDE16092,All wheel drive: safety function intervention status,0, no unit
IDE16093,All-wheel drive: longitudinal function System status,3, no unit
IDE16094,All wheel drive: error value,0, no unit
IDE16095,All-wheel drive: error status of signals,0, no unit
IDE16096,All-wheel drive: error status ESP,0, no unit
IDE16097,All-wheel drive: validity of input signals,1, no unit
IDE16098,All wheel drive: vehicle speed is zero,1, no unit
IDE16099,All-wheel drive: vehicle speed between 0 and 20 m/s,0, no unit
IDE16100,All wheel drive: vehicle speed is negative,0, no unit
IDE16101,All wheel drive: vehicle speed greater than 20 m/s,0, no unit
IDE16102,All-wheel drive: nominal torque is negative,0, no unit
IDE16103,All wheel drive: nominal torque is greater than 1000 Nm,0, no unit
IDE16104,All wheel drive: nominal torque is greater than 100 Nm,0, no unit
IDE16105,All-wheel drive: nominal torque is zero,1, no unit
IDE16106,All-wheel drive: rear axle Maximum torque below limit value,0, no unit
IDE16107,All-wheel drive: rear axle Maximum torque is invalid,0, no unit
IDE16108,All wheel drive: front axle maximum torque below limit value,1, no unit
IDE16109,All-wheel drive: front axle Maximum torque is invalid,1, no unit
IDE16110,All wheel drive: yaw rate is invalid,0, no unit
IDE16111,All-wheel drive: steering wheel angle is invalid,0, no unit
IDE16112,All-wheel drive: steering wheel angle,2.4, °
IDE16130,Acceleration: signal,0.000, m/s²
IDE16164,High voltage coordinator: DC charging status,Deactivated,
IDE16189-MAS22194,High-voltage coordinator: high-voltage stabilization operating status-High-voltage stabilization: initialization phase,not active,
IDE16189-MAS22195,High-voltage coordinator: high-voltage stabilization operating status-High-voltage stabilization,active,
IDE16190,High-voltage auxiliary users: total current,3.38, A
IDE60001,Environmental condition 1,0, no unit
IDE60002,Environmental condition 2,0, no unit
IDE60003,Environmental condition 3,0, no unit
IDE60004,Environmental condition 4,0, no unit
IDE60005,Environmental condition 5,0, no unit
IDE60006,Environmental condition 6,0, no unit
IDE60007,Environmental condition 7,0, no unit
IDE60008,Environmental condition 8,0, no unit
IDE60009,Environmental condition 9,0, no unit
IDE60010,Environmental condition 10,0, no unit
IDE60011,Environmental condition 11,0, no unit
IDE60012,Environmental condition 12,0, no unit
IDE60013,Environmental condition 13,0, no unit
IDE60014,Environmental condition 14,0, no unit
IDE60015,Environmental condition 15,0, no unit
IDE60016,Environmental condition 16,0, no unit
IDE60017,Environmental condition 17,0, no unit
IDE60018,Environmental condition 18,0, no unit
IDE60019,Environmental condition 19,0, no unit
IDE60020,Environmental condition 20,0, no unit
IDE60021,Environmental condition 21,0, no unit
IDE60022,Environmental condition 22,0, no unit
IDE60023,Environmental condition 23,0, no unit
IDE60024,Environmental condition 24,0, no unit
IDE60025,Environmental condition 25,0, no unit
IDE60026,Environmental condition 26,0, no unit
IDE60027,Environmental condition 27,0, no unit
IDE60028,Environmental condition 28,0, no unit
IDE60029,Environmental condition 29,0, no unit
IDE60030,Environmental condition 30,0, no unit
IDE60031,Environmental condition 31,0, no unit
IDE60032,Environmental condition 32,0, no unit
IDE60033,Environmental condition 33,0, no unit
IDE60034,Environmental condition 34,0, no unit
IDE60035,Environmental condition 35,0, no unit
IDE80258,Immobilizer status,Authentication successful,
MAS00370,Vehicle speed,0.00, km/h
MAS13362,Calculated coolant temperature DCDC converter,10.5, °C
MAS17268,Functions which can be activated: connection error counter,00 00,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,2,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS17521,Unlockable functions: activation status,|ID number,Release code for a SWaP function,Cancellation,Individualization characteristic,Preconditions met,Configuration,Functions,Authentication|10 07 17 00,available.,No,invalid,Condition not met,OK,available.,Condition met|10 07 04 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS20471,High-voltage battery de-energization status,High-voltage components not de-energized,
MAS20481,Detection status of open high-voltage wire on battery heater,no open high-voltage wire on battery heater detected,
MAS20513,De-energization status of entire high-voltage system,Initialization/function not active,
MAS20515,Charger de-energization status,High-voltage components not de-energized,
MAS20517,High-voltage interlock status,High-voltage interlock closed,
MAS20518,Electric machine 2: de-energization status,Initialization/no diagnostic results,
MAS20519,Electric machine: de-energization status,High-voltage components not de-energized,
MAS20529,Detection status of open high-voltage wire - e-machine 2,Detection initialization for open high-voltage wire: e-machine 2,
MAS20530,Detection status of open high-voltage wire - e-machine,no open high-voltage wire detected - e-machine,
MAS20600,High-voltage system: emergency shut-off status,no high-voltage system emergency shut-off,
MAS20607,High-voltage battery heater: installation status,High-voltage heater installed,
MAS20614,High-voltage system: warning light,no warning lamp,
MAS20620,Overall status of function high-voltage shut-off in crash,No crash recognized,
MAS20625,Overall status of high-voltage interlock (pilot line),Pilot line OK,
MAS20629,High-voltage system: detection status of open high-voltage wire,no open high-voltage wire detected,
MAS20635,Detection status: open high-voltage wire on the A/C compressor,no open high-voltage wire detected,
MAS20636,High-voltage network 1 status,High-voltage off,
MAS20637,Detection status: open high-voltage wire on electrical system converter,no open high-voltage wire detected,
MAS20639,Insulation resistance in high-voltage network 1,Insulation resistance measurement active,
MAS20647,Detection status: open high-voltage wire on A/C system heater,no open high-voltage wire detected,
MAS20662,Insulation resistance measurement locked by charging function,Insulation resistance measurement locked,
MAS20664,Insulation resistance measurement locked by diagnostic tester,Insulation resistance measurement unlocked,
MAS20667,E-machine 2 installation status,not installed,
MAS20776,Adaptation of radiator blind result,2059.95, °
MAS20777,Activation of radiator blind result,1.96078, %
MAS20778,Radiator blind: actual position,1.96078, %
MAS20779,Adaptation of radiator blind status,Function was successfully ended,
MAS20786,Electrical system converter: installation status,Electrical system converter installed,
MAS21928-MAS00320,Drive train coordinator: longitudinal dynamics control: functionalities-Main switch,engaged,
MAS21928-MAS21929,Drive train coordinator: longitudinal dynamics control: functionalities-CCS/LIM switch available,No,
MAS21928-MAS21930,Drive train coordinator: longitudinal dynamics control: functionalities-Combi indicates setting value for speed limiter,Yes,
MAS21928-MAS21931,Drive train coordinator: longitudinal dynamics control: functionalities-Combi indicates setting value for CCS,Yes,
MAS22005-MAS01632,High-voltage Coordinator: operating status High-voltage stabilization-Status,no request,
MAS22083,Electric machine 2: de-energization status: masked,High voltage component voltage free,
MAS22084,Voltage-free status of the entire high-voltage system: masked,High voltage component not voltage free,
MAS22146,High voltage coordinator: low voltage DC charging status,active,
MAS22160,High-voltage auxiliary consumer: maximum permissible power,2.68800, kW
MAS22161,High-voltage auxiliary consumer: current power,1.5, kW
MAS22162,High voltage coordinator: active discharge status,not active,
MAS23372-MAS23383,Cancellation status of version coding: short-Number of rejected activation IDs,0, no unit
MAS23372-MAS23385,Cancellation status of version coding: short-Cluster index (FoD),0, no unit
MAS23372-MAS23386,Cancellation status of version coding: short-Row coding combination condition,0, no unit
MAS23372-MAS23387,Cancellation status of version coding: short-Rejection by coding cell number,0, no unit
MAS23372-MAS23388,Cancellation status of version coding: short-Delivery status: reset by immobilizer,Release,
MAS23372-MAS23389,Cancellation status of version coding: short-No code word received in D-Flash,Release,
MAS23372-MAS23390,Cancellation status of version coding: short-Rejection due to missing FoD release,Release,
MAS23372-MAS23391,Cancellation status of version coding: short-Rejection due to invalid coding combinations,Release,
MAS23372-MAS23392,Cancellation status of version coding: short-Rejection due to data status approval,Release,
MAS23374-MAS23383,Cancellation status of version coding: long-Number of rejected activation IDs,0, no unit
MAS23374-MAS23385,Cancellation status of version coding: long-Cluster index (FoD),0, no unit
MAS23374-MAS23386,Cancellation status of version coding: long-Row coding combination condition,0, no unit
MAS23374-MAS23387,Cancellation status of version coding: long-Rejection by coding cell number,0, no unit
MAS23374-MAS23388,Cancellation status of version coding: long-Delivery status: reset by immobilizer,Release,
MAS23374-MAS23389,Cancellation status of version coding: long-No code word received in D-Flash,Release,
MAS23374-MAS23390,Cancellation status of version coding: long-Rejection due to missing FoD release,Release,
MAS23374-MAS23391,Cancellation status of version coding: long-Rejection due to invalid coding combinations,Release,
MAS23374-MAS23392,Cancellation status of version coding: long-Rejection due to data status approval,Release,
MAS23374-MAS23393,Cancellation status of version coding: long-Activation ID 1,0, no unit
MAS23374-MAS23394,Cancellation status of version coding: long-Activation ID 2,0, no unit
MAS23374-MAS23395,Cancellation status of version coding: long-Activation ID 3,0, no unit
MAS23374-MAS23396,Cancellation status of version coding: long-Activation ID 4,0, no unit
MAS23374-MAS23397,Cancellation status of version coding: long-Activation ID 5,0, no unit
MAS27212,Drive cooling: coolant temperature,10.50, °
MAS27213,Drive cooling: target volume flow of inverter drive 1,3.0, l/min
MAS27214,Drive cooling: target volume flow of inverter drive 2,0.0, l/min
MAS27215,Drive cooling: actual volume flow of drive 2,25.5, l/min
MAS27216,Drive cooling: actual volume flow of drive 1,3.0, l/min
MAS27217,Drive cooling: target volume flow of electric drive motor 1,3.0, l/min
MAS27218,Drive cooling: target volume flow of electric drive motor 2,0.0, l/min
MAS27219,Drive cooling: target volume flow of heat pump,0.00, l/min
MAS27220,Drive cooling: radiator fan request for brake cooling,0, %
MAS27221,Drive cooling: target volume flow of battery charger/vehicle electrical system converter,1.0, l/min
MAS27222,Drive cooling: radiator fan request for air conditioning,0, %
MAS27234,Differential pressure of battery charger/vehicle electrical system converter cooling system: actual value,1.5, kPa
MAS27235,Drive cooling: target volume flow of battery charger,0.0, l/min
MAS27236,Drive cooling: radiator fan request,0, %
ENG138673,Bypasstool_a2l_name,SE1780,
ENG138672,Bypasstool_manipulation_bit,not active,
ENG101413,Calibration Identifications,||0EA014GG3875EzJ6|,
ENG99697,Calibration Verification Numbers,||31 27 91 48|,
ENG249134,CUR_CHA_MAX_DYN_2,0.0, A
ENG249135,CUR_DCHA_MAX_DYN_2,0.0, A
ENG100131,ECU_STATE,ENG_STOP,
ENG100152,ECUNAME,|ECU,ECUNAME|PCM,PowertrainCtrl|,
ENG103644,FRF_IMMO_SNAPSHOT_BYTE1,0,
ENG102892,FRF_IMMO_SNAPSHOT_BYTE2,0,
ENG100521,FRF_IMMO_SNAPSHOT_BYTE3,0,
ENG101852,FRF_IMMO_SNAPSHOT_BYTE4,0,
ENG99312,FRF_IMMO_SNAPSHOT_BYTE5,0,
ENG103956,FRF_IMMO_SNAPSHOT_BYTE6,0,
ENG138674,LF_MVB_BUS_INTC_DIAG,0,
ENG138675,LF_MVB_PDU_INTC_DIAG_1,0,
ENG138676,LF_MVB_PDU_INTC_DIAG_10,0,
ENG168842,LF_MVB_PDU_INTC_DIAG_11,0,
ENG168843,LF_MVB_PDU_INTC_DIAG_12,0,
ENG138677,LF_MVB_PDU_INTC_DIAG_13,0,
ENG138679,LF_MVB_PDU_INTC_DIAG_15,0,
ENG138680,LF_MVB_PDU_INTC_DIAG_16,0,
ENG138681,LF_MVB_PDU_INTC_DIAG_17,0,
ENG138682,LF_MVB_PDU_INTC_DIAG_18,0,
ENG168844,LF_MVB_PDU_INTC_DIAG_19,0,
ENG138683,LF_MVB_PDU_INTC_DIAG_2,0,
ENG168845,LF_MVB_PDU_INTC_DIAG_20,0,
ENG168846,LF_MVB_PDU_INTC_DIAG_22,0,
ENG168847,LF_MVB_PDU_INTC_DIAG_23,0,
ENG168848,LF_MVB_PDU_INTC_DIAG_24,0,
ENG168849,LF_MVB_PDU_INTC_DIAG_25,0,
ENG168850,LF_MVB_PDU_INTC_DIAG_26,0,
ENG168851,LF_MVB_PDU_INTC_DIAG_27,0,
ENG138684,LF_MVB_PDU_INTC_DIAG_3,0,
ENG138685,LF_MVB_PDU_INTC_DIAG_4,0,
ENG138686,LF_MVB_PDU_INTC_DIAG_5,0,
ENG138687,LF_MVB_PDU_INTC_DIAG_6,0,
ENG138689,LF_MVB_PDU_INTC_DIAG_8,0,
ENG138690,LF_MVB_PDU_INTC_DIAG_9,0,
ENG112471,LV_IGK,00000001 ,
ENG249159,N_EM_3,0.0, /min
ENG249160,N_EM_6,16383.5, /min
ENG128797,PV,0.00, %
ENG249203,STATE_REQ_ENG_HVS,0,
ENG112494,T_AST_SAE,17, s
ENG128802,T_IGK,376.92, s
ENG249209,TQ_EM_1,0.00000, Nm
ENG249210,TQ_EM_2,0.00000, Nm
ENG249211,TQ_EM_3,0.00000, Nm
ENG252424,Vehicle Operation Data - Distance/Fuel Used,|Total Distance Traveled (Recent),Total Distance Traveled (Lifetime),Total Fuel Consumed (Recent),Total Fuel Consumed (Lifetime)|450.8,464.4,42949671.99,42949671.99|, l
ENG249216,VS_DIR_CUS,0.00, km/h
Elapsed Time: 00:27
blockmap-03-1EA-907-379-BQ_WVGAWVEB7SH010695-20241230-1125.CSV
;SW:1EA-907-379-BQ   HW:1EA-614-517-M ---  ABS Brakes
;Component:ESC-ZF_EBC470 H18 0754, Coding:481044A8004159024217990000B79840250070614000
;EV_BrakeZFESCMEBUNECE,001035,EV_BrakeZFESCMEBUNECE_001_VWE3.rod
;Monday,30,December,2024,11:25:08:18177
;VCID: 0D4073CF3DD52E72084-8058-R SFD
IDE00019,Voltage terminal 30,14.94, V
IDE00021,Engine RPM,0.00, /min
IDE00025,Coolant temperature,-1, °C
IDE00085,Normed load value,24.71, %
IDE00086,Accelerator pedal position,14.12, %
IDE00602-ENG161054,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_continous_diagnostics,00000100 ,
IDE00602-ENG161055,Monitoring status in current driving cycle-Diagnostic_approval_and_Readiness_code_non_continous_diagnostics,00000000 ,
IDE00602-ENG161141,Monitoring status in current driving cycle-Readiness_Code,00000000 ,
IDE02270-IDE02713,CAN input signal(s) status-Brake lamp switch,operated,
IDE02270-IDE05726,CAN input signal(s) status-Dimmer terminal 58xd,0,
IDE02270-MAS02357,CAN input signal(s) status-Vehicle identification,WVGAWVEB7SH010695,
IDE02270-MAS15790,CAN input signal(s) status-Setting for clear error memory,locked,
IDE02271-IDE02070,CAN output signal(s) status-Wake-up cause,Bus communication,
IDE04082-MAS00580,Instrument cluster text output-Electromechanical parking brake text 1,0,
IDE04082-MAS03359,Instrument cluster text output-Text,0,
IDE06422-ENG103176,IUMPR_1-General Denominator,0,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,0,
IDE06422-ENG100120,IUMPR_1-Milage,0,
IDE06422-ENG101622,IUMPR_1-Record Number,0,
IDE06423-ENG101817,IUMPR_2-Denominator,0,
IDE06423-ENG103772,IUMPR_2-DFCC Value,0,
IDE06423-ENG99150,IUMPR_2-Numerator,0,
IDE06423-ENG101622,IUMPR_2-Record Number,1,
IDE06424-ENG101817,IUMPR_3-Denominator,0,
IDE06424-ENG103772,IUMPR_3-DFCC Value,0,
IDE06424-ENG99150,IUMPR_3-Numerator,0,
IDE06424-ENG101622,IUMPR_3-Record Number,0,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE14227-IDE02955,modular vehicle dynamic controller-System status,available.,
IDE14227-MAS18086,modular vehicle dynamic controller-Dynamic Chassis Control function status,mFDR_active_DCC_not_configured,
IDE14227-ENG370765,modular vehicle dynamic controller-mFDR Offset DCC HL,Initialization,
IDE14227-ENG370766,modular vehicle dynamic controller-mFDR Offset DCC HR,Initialization,
IDE14227-ENG370767,modular vehicle dynamic controller-mFDR Offset DCC VL,Initialization,
IDE14227-ENG370768,modular vehicle dynamic controller-mFDR Offset DCC VR,Initialization,
IDE14227-ENG370769,modular vehicle dynamic controller-mFDR_Active_DCC,Init,
IDE14227-ENG370771,modular vehicle dynamic controller-mFDR_FPA_value_actual,4,
IDE14227-ENG370772,modular vehicle dynamic controller-mFDR_FPA_value_nominal,4,
IDE14227-ENG370773,modular vehicle dynamic controller-mFDR_target_delta_moment_brake_torque_front_axle,0.00, Nm
IDE14227-ENG370774,modular vehicle dynamic controller-mFDR_target_delta_moment_brake_torque_rear_axle,0.00, Nm
IDE14227-ENG370855,modular vehicle dynamic controller-System_state_FPA,available.,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3D 5C A0 C2 C8 31 AF,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,4,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0E,
IDE14623,Commutation test status,not active,
MAS26780-MAS26781,Distance safety-Total of average distance pulses from rear wheels,00 01 0B 19 EE,
ENG99697-ENG110852,Calibration Verification Numbers-Calibration Verification Number,3C CE BF B6,
ENG100152,ECUNAME,BSCM-BrakeSystem----,
ENG264447-ENG135743,Entwicklermesswert_11-Left_Brake_Full_Clamping_Force,0,
ENG264447-ENG135741,Entwicklermesswert_11-Right_Brake_Full_Clamping_Force,0,
ENG264448,Entwicklermesswert_12,ÿV",
ENG370243-MAS00106,valve_calibration-Year,2003,
ENG370243-MAS00107,valve_calibration-Month,0,
ENG370243-MAS00108,valve_calibration-Day,7,
ENG370243-MAS00109,valve_calibration-Hours,17,
ENG370243-MAS00110,valve_calibration-Minutes,0,
ENG370243-MAS00111,valve_calibration-Seconds,58,
ENG370243-ENG370529,valve_calibration-absiso_fl,2562.49, mA
ENG370243-ENG370530,valve_calibration-absiso_fr,6874.98, mA
ENG370243-ENG370531,valve_calibration-absiso_rl,10437.2, mA
ENG370243-ENG370532,valve_calibration-absiso_rr,14062.2, mA
ENG370243-ENG370560,valve_calibration-calibration_ign_count,58880,
ENG370243-ENG370561,valve_calibration-calibration_mileage,3892314112, km
ENG370243-ENG98502,valve_calibration-Data,41,
ENG370243-ENG370857,valve_calibration-tc_iso_circuit_1,14062.2, mA
ENG370243-ENG370858,valve_calibration-tc_iso_circuit_2,1999.99, mA
Elapsed Time: 00:14
blockmap-05-5WA-959-436-N_WVGAWVEB7SH010695-20241230-1125.CSV
;SW:5WA-959-436-N   HW:5WA-959-436-N ---  Acc/Start Auth.
;Component:Kessy IOBOX   122 0757, Coding:
;EV_Kessy37w,005030,EV_Kessy37w_005_VW38.rod
;Monday,30,December,2024,11:25:40:18177
;VCID: 5F9C7987A7B9ECE22A8-800A-R
IDE00019,Voltage terminal 30,14.885, V
IDE02413,Door handle touch sensor: last operation,Driver door,
IDE02414-MAS00080,Driver exterior door handle touch sensor-Coding information,coded,
IDE02414-MAS02176,Driver exterior door handle touch sensor-Approach to the inside,not active,
IDE02414-MAS02177,Driver exterior door handle touch sensor-Actuation to the inside,not active,
IDE02414-MAS02178,Driver exterior door handle touch sensor-Approach to the outside,not active,
IDE02414-MAS02179,Driver exterior door handle touch sensor-Actuation to the outside,not active,
IDE02414-MAS02451,Driver exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02415-MAS00080,Front passenger exterior door handle touch sensor-Coding information,coded,
IDE02415-MAS02176,Front passenger exterior door handle touch sensor-Approach to the inside,not active,
IDE02415-MAS02177,Front passenger exterior door handle touch sensor-Actuation to the inside,not active,
IDE02415-MAS02178,Front passenger exterior door handle touch sensor-Approach to the outside,not active,
IDE02415-MAS02179,Front passenger exterior door handle touch sensor-Actuation to the outside,not active,
IDE02415-MAS02451,Front passenger exterior door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02416-MAS00080,Left rear outside door handle touch sensor-Coding information,Not coded,
IDE02416-MAS02176,Left rear outside door handle touch sensor-Approach to the inside,not active,
IDE02416-MAS02177,Left rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02416-MAS02178,Left rear outside door handle touch sensor-Approach to the outside,not active,
IDE02416-MAS02179,Left rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02416-MAS02451,Left rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02417-MAS00080,Right rear outside door handle touch sensor-Coding information,Not coded,
IDE02417-MAS02176,Right rear outside door handle touch sensor-Approach to the inside,not active,
IDE02417-MAS02177,Right rear outside door handle touch sensor-Actuation to the inside,not active,
IDE02417-MAS02178,Right rear outside door handle touch sensor-Approach to the outside,not active,
IDE02417-MAS02179,Right rear outside door handle touch sensor-Actuation to the outside,not active,
IDE02417-MAS02451,Right rear outside door handle touch sensor-Pulling actuation: outside door handle,not active,
IDE02418,Proximity sensor driver door: number of triggers,555,
IDE02419,Proximity sensor frt.pass. door: number of triggers,265,
IDE02420,Proximity sensor left rear door: number of triggers,0,
IDE02421,Proximity sensor right rear door: number of triggers,0,
IDE02422-MAS01482,Driver door handle: version information-Hardware version,33,
IDE02422-MAS01483,Driver door handle: version information-Software version,49,
IDE02422-MAS04065,Driver door handle: version information-EEPROM,36,
IDE02422,Driver door handle: version information,2F 00 0C 72 B0,
IDE02423-MAS01482,ass. door handle: version information-Hardware version,33,
IDE02423-MAS01483,ass. door handle: version information-Software version,49,
IDE02423-MAS04065,ass. door handle: version information-EEPROM,36,
IDE02423,ass. door handle: version information,2F 00 0C 73 F2,
IDE02424-MAS01482,Left rear door handle: version information-Hardware version,0,
IDE02424-MAS01483,Left rear door handle: version information-Software version,0,
IDE02424-MAS04065,Left rear door handle: version information-EEPROM,0,
IDE02424,Left rear door handle: version information,00 00 00 00 00,
IDE02425-MAS01482,Right rear door handle: version information-Hardware version,0,
IDE02425-MAS01483,Right rear door handle: version information-Software version,0,
IDE02425-MAS04065,Right rear door handle: version information-EEPROM,0,
IDE02425,Right rear door handle: version information,00 00 00 00 00,
IDE02466,Play protection activation counter driver door,not active,
IDE02466,Play protection activation counter driver door,0,
IDE02467,Play protection activation counter frt.pass. door,not active,
IDE02467,Play protection activation counter frt.pass. door,0,
IDE02468,Play protection activation counter left rear door,not active,
IDE02468,Play protection activation counter left rear door,0,
IDE02469,Play protection activation counter right rear door,0,
IDE02469,Play protection activation counter right rear door,not active,
IDE02482,72h-Signaling counter driver door,0,
IDE02483,72-hour signaling counter frt.pass. door,0,
IDE02486,Data logger triggering,not initialized,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,14.8, V
IDE07359,Dimming of starter button lighting,10000,
IDE14837-MAS19401,Outer door handle switch: status-Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19402,Outer door handle switch: status-Front Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19403,Outer door handle switch: status-Rear Passenger Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19404,Outer door handle switch: status-Rear Driver Side Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19612,Outer door handle switch: status-Rear Exterior Door Handle Switch: status,Not operated,
IDE14837-MAS19613,Outer door handle switch: status-Tank Exterior Door Handle Switch: status,Not operated,
IDE14924-MAS00218,Status of release conditions Passive Entry-Driver door,not enabled,
IDE14924-MAS00219,Status of release conditions Passive Entry-Front Passenger Door,not enabled,
IDE14924-MAS00220,Status of release conditions Passive Entry-Left rear door,not enabled,
IDE14924-MAS00221,Status of release conditions Passive Entry-Right rear door,not enabled,
IDE14924-MAS19581,Status of release conditions Passive Entry-Rear,not enabled,
IDE14924-MAS19611,Status of release conditions Passive Entry-Tank,not enabled,
IDE14925-MAS00218,Status of release conditions Passive Exit-Driver door,Enabled,
IDE14925-MAS00219,Status of release conditions Passive Exit-Front Passenger Door,Enabled,
IDE14925-MAS00220,Status of release conditions Passive Exit-Left rear door,not enabled,
IDE14925-MAS00221,Status of release conditions Passive Exit-Right rear door,not enabled,
IDE14925-MAS19581,Status of release conditions Passive Exit-Rear,not enabled,
IDE14925-MAS19611,Status of release conditions Passive Exit-Tank,not enabled,
IDE14926,Status of release conditions for key search,Key search: release activated,
IDE14927-MAS19605,History of range limiter for automatic functions-Reduction level,|Level_of_reduction,Year,Month,Day,Hours,Minutes,Seconds|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|0,2127,15,31,31,63,63|,
IDE14928-MAS00080,Sensor for control section-Coding information,Not coded,
IDE14928-MAS02176,Sensor for control section-Approach to the inside,not active,
IDE14928-MAS02177,Sensor for control section-Actuation to the inside,not active,
IDE14928-MAS02178,Sensor for control section-Approach to the outside,not active,
IDE14928-MAS02179,Sensor for control section-Actuation to the outside,not active,
IDE14928-MAS02451,Sensor for control section-Pulling actuation: outside door handle,not active,
IDE14929-MAS00080,Sensor for fuel filler flap control section-Coding information,Not coded,
IDE14929-MAS02176,Sensor for fuel filler flap control section-Approach to the inside,not active,
IDE14929-MAS02177,Sensor for fuel filler flap control section-Actuation to the inside,not active,
IDE14929-MAS02178,Sensor for fuel filler flap control section-Approach to the outside,not active,
IDE14929-MAS02179,Sensor for fuel filler flap control section-Actuation to the outside,not active,
IDE14929-MAS02451,Sensor for fuel filler flap control section-Pulling actuation: outside door handle,not active,
IDE14930,Sensor fuel filler flap control section: number of triggers,0,
IDE14931,Sensor control section trunk: number of triggers,0,
IDE14932,Fuel filler flap control section: play protection,0,
IDE14932,Fuel filler flap control section: play protection,not active,
IDE14933,Trunk control section: play protection counter,not active,
IDE14933,Trunk control section: play protection counter,0,
IDE14934-MAS01482,Trunk control section: version information-Hardware version,0,
IDE14934-MAS01483,Trunk control section: version information-Software version,0,
IDE14934-MAS04065,Trunk control section: version information-EEPROM,0,
IDE14934,Trunk control section: version information,00 00 00 00 00,
IDE14935-MAS01482,Fuel filler cap control section: version information-Hardware version,0,
IDE14935-MAS01483,Fuel filler cap control section: version information-Software version,0,
IDE14935-MAS04065,Fuel filler cap control section: version information-EEPROM,0,
IDE14935,Fuel filler cap control section: version information,00 00 00 00 00,
ENG129040-ENG129151,History_of_last _reset_reason-Last_1_reset_reason,Power_On_Reset,
ENG129040-ENG129152,History_of_last _reset_reason-Last_2_reset_reason,Software_Request_Flashbootloader,
ENG129040-ENG129153,History_of_last _reset_reason-Last_3_reset_reason,Power_On_Reset,
ENG129040-ENG129154,History_of_last _reset_reason-Last_4_reset_reason,Power_On_Reset,
ENG129040-ENG129155,History_of_last _reset_reason-Last_5_reset_reason,Power_On_Reset,
ENG129040-ENG129156,History_of_last _reset_reason-Last_6_reset_reason,Power_On_Reset,
ENG129040-ENG129157,History_of_last _reset_reason-Last_7_reset_reason,Power_On_Reset,
ENG129040-ENG129158,History_of_last _reset_reason-Last_8_reset_reason,Power_On_Reset,
ENG129040-ENG129159,History_of_last _reset_reason-Last_9_reset_reason,Power_On_Reset,
ENG129040-ENG124545,History_of_last _reset_reason-Last_reset_reason,Power_On_Reset,
ENG254757-MAS00106,Lf_antenna_eight_detune_counter-Year,2000,
ENG254757-MAS00107,Lf_antenna_eight_detune_counter-Month,0,
ENG254757-MAS00108,Lf_antenna_eight_detune_counter-Day,0,
ENG254757-MAS00109,Lf_antenna_eight_detune_counter-Hours,0,
ENG254757-MAS00110,Lf_antenna_eight_detune_counter-Minutes,0,
ENG254757-MAS00111,Lf_antenna_eight_detune_counter-Seconds,0,
ENG254757-ENG255615,Lf_antenna_eight_detune_counter-Detune_counter,0,
ENG254758-MAS00106,Lf_antenna_five_detune_counter-Year,2000,
ENG254758-MAS00107,Lf_antenna_five_detune_counter-Month,0,
ENG254758-MAS00108,Lf_antenna_five_detune_counter-Day,0,
ENG254758-MAS00109,Lf_antenna_five_detune_counter-Hours,0,
ENG254758-MAS00110,Lf_antenna_five_detune_counter-Minutes,0,
ENG254758-MAS00111,Lf_antenna_five_detune_counter-Seconds,0,
ENG254758-ENG255615,Lf_antenna_five_detune_counter-Detune_counter,0,
ENG254759-MAS00106,Lf_antenna_four_detune_counter-Year,2000,
ENG254759-MAS00107,Lf_antenna_four_detune_counter-Month,0,
ENG254759-MAS00108,Lf_antenna_four_detune_counter-Day,0,
ENG254759-MAS00109,Lf_antenna_four_detune_counter-Hours,0,
ENG254759-MAS00110,Lf_antenna_four_detune_counter-Minutes,0,
ENG254759-MAS00111,Lf_antenna_four_detune_counter-Seconds,0,
ENG254759-ENG255615,Lf_antenna_four_detune_counter-Detune_counter,0,
ENG254760-MAS00106,Lf_antenna_one_detune_counter-Year,2000,
ENG254760-MAS00107,Lf_antenna_one_detune_counter-Month,0,
ENG254760-MAS00108,Lf_antenna_one_detune_counter-Day,0,
ENG254760-MAS00109,Lf_antenna_one_detune_counter-Hours,0,
ENG254760-MAS00110,Lf_antenna_one_detune_counter-Minutes,0,
ENG254760-MAS00111,Lf_antenna_one_detune_counter-Seconds,0,
ENG254760-ENG255615,Lf_antenna_one_detune_counter-Detune_counter,0,
ENG254761-MAS00106,Lf_antenna_seven_detune_counter-Year,2000,
ENG254761-MAS00107,Lf_antenna_seven_detune_counter-Month,0,
ENG254761-MAS00108,Lf_antenna_seven_detune_counter-Day,0,
ENG254761-MAS00109,Lf_antenna_seven_detune_counter-Hours,0,
ENG254761-MAS00110,Lf_antenna_seven_detune_counter-Minutes,0,
ENG254761-MAS00111,Lf_antenna_seven_detune_counter-Seconds,0,
ENG254761-ENG255615,Lf_antenna_seven_detune_counter-Detune_counter,0,
ENG254762-MAS00106,Lf_antenna_six_detune_counter-Year,2000,
ENG254762-MAS00107,Lf_antenna_six_detune_counter-Month,0,
ENG254762-MAS00108,Lf_antenna_six_detune_counter-Day,0,
ENG254762-MAS00109,Lf_antenna_six_detune_counter-Hours,0,
ENG254762-MAS00110,Lf_antenna_six_detune_counter-Minutes,0,
ENG254762-MAS00111,Lf_antenna_six_detune_counter-Seconds,0,
ENG254762-ENG255615,Lf_antenna_six_detune_counter-Detune_counter,0,
ENG254763-MAS00106,Lf_antenna_three_detune_counter-Year,2000,
ENG254763-MAS00107,Lf_antenna_three_detune_counter-Month,0,
ENG254763-MAS00108,Lf_antenna_three_detune_counter-Day,0,
ENG254763-MAS00109,Lf_antenna_three_detune_counter-Hours,0,
ENG254763-MAS00110,Lf_antenna_three_detune_counter-Minutes,0,
ENG254763-MAS00111,Lf_antenna_three_detune_counter-Seconds,0,
ENG254763-ENG255615,Lf_antenna_three_detune_counter-Detune_counter,0,
ENG254764-MAS00106,Lf_antenna_two_detune_counter-Year,2000,
ENG254764-MAS00107,Lf_antenna_two_detune_counter-Month,0,
ENG254764-MAS00108,Lf_antenna_two_detune_counter-Day,0,
ENG254764-MAS00109,Lf_antenna_two_detune_counter-Hours,0,
ENG254764-MAS00110,Lf_antenna_two_detune_counter-Minutes,0,
ENG254764-MAS00111,Lf_antenna_two_detune_counter-Seconds,0,
ENG254764-ENG255615,Lf_antenna_two_detune_counter-Detune_counter,0,
ENG254789-MAS00106,Over_temperature_counter_lf_driver-Year,2000,
ENG254789-MAS00107,Over_temperature_counter_lf_driver-Month,0,
ENG254789-MAS00108,Over_temperature_counter_lf_driver-Day,0,
ENG254789-MAS00109,Over_temperature_counter_lf_driver-Hours,0,
ENG254789-MAS00110,Over_temperature_counter_lf_driver-Minutes,0,
ENG254789-MAS00111,Over_temperature_counter_lf_driver-Seconds,0,
ENG254789-MAS27962,Over_temperature_counter_lf_driver-Excessive temperature counter for Kessy OK box,0, counts
ENG108452,Reset_counter,12,
ENG108925-ENG103300,Service_Key_Data_Current_Page-Service_Data,00 0C 00 00 00 00 00 01 01 01 FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF,
ENG108926-ENG103300,Service_Key_Data_Previous_Page-Service_Data,00 0C 00 00 00 00 00 01 01 01 FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF 00 FF FF FF FF FF,
ENG119884-ENG119837,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_0,0, d
ENG119884-ENG119867,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_1,1, d
ENG119884-ENG119868,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_2,31, d
ENG119884-ENG119866,Service_Key_Mileage_Date-Date_Day_Secure_Total_Distance_Block_3,31, d
ENG119884-ENG119870,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_0,0,
ENG119884-ENG119836,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_1,8,
ENG119884-ENG119850,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_2,15,
ENG119884-ENG119851,Service_Key_Mileage_Date-Date_Month_Secure_Total_Distance_Block_3,7,
ENG119884-ENG119869,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_0,2000,
ENG119884-ENG119835,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_1,2000,
ENG119884-ENG119845,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_2,2127,
ENG119884-ENG119846,Service_Key_Mileage_Date-Date_Year_Secure_Total_Distance_Block_3,2000,
ENG119884-ENG119834,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_0,3072, km
ENG119884-ENG119839,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_1,1, km
ENG119884-ENG119840,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_2,16776960, km
ENG119884-ENG119841,Service_Key_Mileage_Date-Secure_Total_Distance_Km_Block_3,16777215, km
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG161255,Service_Key_Pointer-Write_Pointer_Adr_160,Write_Pointer_Adr,
ENG108929-ENG161256,Service_Key_Pointer-Write_Pointer_Adr_184,Write_Pointer_Adr,
ENG108929-ENG161257,Service_Key_Pointer-Write_Pointer_Adr_208,Write_Pointer_Adr,
ENG254855,WUP_measurement_historie,|Learned wake pattern,Mileage|73695432,0|0,0|2006232112,16777215|, km
Elapsed Time: 00:07
blockmap-06-1N3-959-760-H_WVGAWVEB7SH010695-20241230-1125.CSV
;SW:1N3-959-760-H   HW:1N3-959-760-H ---  Seat Mem. Pass
;Component:MEM-BFS       011 0571, Coding:0118B24000012A008803010121010000000000000000000000000000211000
;EV_SCMPasseSideCONTIAU736,006013,EV_SCMPasseSideCONTIAU736_VW42.rod
;Monday,30,December,2024,11:25:59:18177
;VCDS Version: Beta 24.12.0 (x64)  Data version: 20241120 DS361.3
;VCID: 3E22E40340F3C5EA41E-806A-R
Group,Description,Actual
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.80, V
IDE00102,Control Module temperature,29,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,34038,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32455,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32782,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,22,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,26,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1583,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33269,
IDE06511-MAS01391,Seat height adjustment-Block 2,32768,
IDE06511-MAS02282,Seat height adjustment-Position,33080,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,21,
IDE06511-MAS04160,Seat height adjustment-Load change,23,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,501,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,33105,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32554,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,33023,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,69,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,291,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,551,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33037,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32769,
IDE06683-MAS02282,Seat inclination adjustment-Position,33017,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,24,
IDE06683-MAS04160,Seat inclination adjustment-Load change,28,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,268,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,0,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,0,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,0,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,0,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,0,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,0,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,0,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08988-MAS01390,Head restraint adjustment-Block 1,0,
IDE08988-MAS01391,Head restraint adjustment-Block 2,0,
IDE08988-MAS02282,Head restraint adjustment-Position,0,
IDE08988-MAS02955,Head restraint adjustment-Engine temperature,0, °C
IDE08988-MAS03129,Head restraint adjustment-Reset counter,0,
IDE08988-MAS04160,Head restraint adjustment-Load change,0,
IDE08988-MAS04337,Head restraint adjustment-Engine current,0, A
IDE08988-MAS05370,Head restraint adjustment-Direction of movement,Not operated,
IDE08988-MAS05563,Head restraint adjustment-Norming,not normed,
IDE08988-MAS05719,Head restraint adjustment-Maximum travel,0,
IDE08988-MAS12838,Head restraint adjustment-Standardization flag,never normed,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Paddle,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG139951-IDE06510,Account_1-Adjustment for backrest angle,0,
ENG139951-IDE06511,Account_1-Seat height adjustment,0,
ENG139951-IDE06512,Account_1-Adjustment for seat forward/back position,0,
ENG139951-IDE06683,Account_1-Seat inclination adjustment,0,
ENG139951-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG139951-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG139951-IDE08989,Account_1-Seat depth adjustment,0,
ENG139951-IDE08990,Account_1-Backrest top adjustment,0,
ENG139951-IDE08991,Account_1-Belt height adjustment,0,
ENG139951-IDE11024,Account_1-Headrest height adjustment,0,
ENG139952-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG139952-IDE06511,Account_2-Seat height adjustment,0,
ENG139952-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG139952-IDE06683,Account_2-Seat inclination adjustment,0,
ENG139952-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG139952-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG139952-IDE08989,Account_2-Seat depth adjustment,0,
ENG139952-IDE08990,Account_2-Backrest top adjustment,0,
ENG139952-IDE08991,Account_2-Belt height adjustment,0,
ENG139952-IDE11024,Account_2-Headrest height adjustment,0,
ENG139953-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG139953-IDE06511,Account_3-Seat height adjustment,0,
ENG139953-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG139953-IDE06683,Account_3-Seat inclination adjustment,0,
ENG139953-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG139953-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG139953-IDE08989,Account_3-Seat depth adjustment,0,
ENG139953-IDE08990,Account_3-Backrest top adjustment,0,
ENG139953-IDE08991,Account_3-Belt height adjustment,0,
ENG139953-IDE11024,Account_3-Headrest height adjustment,0,
ENG139954-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG139954-IDE06511,Account_4-Seat height adjustment,0,
ENG139954-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG139954-IDE06683,Account_4-Seat inclination adjustment,0,
ENG139954-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG139954-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG139954-IDE08989,Account_4-Seat depth adjustment,0,
ENG139954-IDE08990,Account_4-Backrest top adjustment,0,
ENG139954-IDE08991,Account_4-Belt height adjustment,0,
ENG139954-IDE11024,Account_4-Headrest height adjustment,0,
ENG139955-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG139955-IDE06511,Account_5-Seat height adjustment,0,
ENG139955-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG139955-IDE06683,Account_5-Seat inclination adjustment,0,
ENG139955-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG139955-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG139955-IDE08989,Account_5-Seat depth adjustment,0,
ENG139955-IDE08990,Account_5-Backrest top adjustment,0,
ENG139955-IDE08991,Account_5-Belt height adjustment,0,
ENG139955-IDE11024,Account_5-Headrest height adjustment,0,
ENG139956-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG139956-IDE06511,Account_6-Seat height adjustment,0,
ENG139956-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG139956-IDE06683,Account_6-Seat inclination adjustment,0,
ENG139956-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG139956-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG139956-IDE08989,Account_6-Seat depth adjustment,0,
ENG139956-IDE08990,Account_6-Backrest top adjustment,0,
ENG139956-IDE08991,Account_6-Belt height adjustment,0,
ENG139956-IDE11024,Account_6-Headrest height adjustment,0,
ENG139957-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG139957-IDE06511,Account_7-Seat height adjustment,0,
ENG139957-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG139957-IDE06683,Account_7-Seat inclination adjustment,0,
ENG139957-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG139957-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG139957-IDE08989,Account_7-Seat depth adjustment,0,
ENG139957-IDE08990,Account_7-Backrest top adjustment,0,
ENG139957-IDE08991,Account_7-Belt height adjustment,0,
ENG139957-IDE11024,Account_7-Headrest height adjustment,0,
ENG139950-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG139950-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG139950-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG139950-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG139950-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG139950-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG139950-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG139950-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG139950-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG139950-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG139950-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG139950-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG139950-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG139950-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG139950-ENG140668,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG139950-ENG140669,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG139950-ENG140667,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG136330-ENG136340,Cause of de-normalization-Axis_1,Normierroutine,
ENG136330-ENG136349,Cause of de-normalization-Axis_10,Achse decodiert,
ENG136330-ENG136341,Cause of de-normalization-Axis_2,Normierroutine,
ENG136330-ENG136342,Cause of de-normalization-Axis_3,Normierroutine,
ENG136330-ENG136343,Cause of de-normalization-Axis_4,Normierroutine,
ENG136330-ENG136344,Cause of de-normalization-Axis_5,Achse decodiert,
ENG136330-ENG136345,Cause of de-normalization-Axis_6,Achse decodiert,
ENG136330-ENG136346,Cause of de-normalization-Axis_7,Achse decodiert,
ENG136330-ENG136347,Cause of de-normalization-Axis_8,Achse decodiert,
ENG136330-ENG136348,Cause of de-normalization-Axis_9,Achse decodiert,
ENG136325-ENG101098,crash_precrash-Crash,not active,
ENG136325-ENG131963,crash_precrash-Precrash,not active,
ENG247801-ENG248126,info_developer-ax_da,80 FF 7F 2A 81 51 00 07 80 0E 7E C7 84 F6 00 07 81 38 80 00 81 F5 00 07 80 F9 80 01 81 0D 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG247801-ENG248078,info_developer-gl_lo,31 4E 33 39 35 39 37 36 30 48 20 00 00 00 00 00 54 30 37 35 00 00 00 00 32 35 33 39 00 00 00 00 53 43 42 55 5A 5A 50 45 4F 50 4C 45 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG247947,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0F 00 04 03 00 00 03 00 04 04 00 00 00 00,
ENG247801-ENG248107,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG248040,info_developer-so_deb,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG136350-ENG136426,key_memory_activated-mmi_key_memory_activated,not active,
ENG157282-ENG161450,Maximum travel-Axis_1_current,551,
ENG157282-ENG161451,Maximum travel-Axis_1_last,0,
ENG157282-ENG161452,Maximum travel-Axis_10_current,65535,
ENG157282-ENG161453,Maximum travel-Axis_10_last,0,
ENG157282-ENG161454,Maximum travel-Axis_2_current,1583,
ENG157282-ENG161455,Maximum travel-Axis_2_last,0,
ENG157282-ENG161456,Maximum travel-Axis_3_current,501,
ENG157282-ENG161457,Maximum travel-Axis_3_last,0,
ENG157282-ENG161458,Maximum travel-Axis_4_current,268,
ENG157282-ENG161459,Maximum travel-Axis_4_last,0,
ENG157282-ENG161460,Maximum travel-Axis_5_current,65535,
ENG157282-ENG161461,Maximum travel-Axis_5_last,0,
ENG157282-ENG161462,Maximum travel-Axis_6_current,65535,
ENG157282-ENG161463,Maximum travel-Axis_6_last,0,
ENG157282-ENG161464,Maximum travel-Axis_7_current,65535,
ENG157282-ENG161465,Maximum travel-Axis_7_last,0,
ENG157282-ENG161466,Maximum travel-Axis_8_current,65535,
ENG157282-ENG161467,Maximum travel-Axis_8_last,0,
ENG157282-ENG161468,Maximum travel-Axis_9_current,65535,
ENG157282-ENG161469,Maximum travel-Axis_9_last,0,
ENG136323-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG136323-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG136323-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG136323-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG136323-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG136323-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG136323-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG136323-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG136324-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG136324-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG136324-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG136324-ENG140350,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG136324-ENG136335,Memory_ID_CAN_2-Hardware_onoff,active,
ENG136324-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG136324-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG136324-ENG248058,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG158048-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG158048-ENG161471,missing_pre_conditions-backrest_locked,active,
ENG158048-ENG161472,missing_pre_conditions-backrest_unlocked,active,
ENG158048-ENG161506,missing_pre_conditions-button_pressed,not active,
ENG158048-ENG161716,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG158048-ENG163288,missing_pre_conditions-other_adjustment_already_active,not active,
ENG158048-ENG98864,missing_pre_conditions-Reserved,0,
ENG158048-ENG310748,missing_pre_conditions-reserviert_01,0,
ENG158048-ENG163523,missing_pre_conditions-reset_problem,not active,
ENG158048-ENG163733,missing_pre_conditions-speed_above_5kmh,not active,
ENG158048-ENG159469,missing_pre_conditions-Voltage_supply,not active,
ENG158102-ENG161674,personalization_last_function-cause_of_termination,0,
ENG158102,personalization_last_function,none,
ENG158102-ENG99298,personalization_last_function-State,none,
ENG136328-ENG136337,pwm_generator-pwm_generator_group_1_overload,not active,
ENG136328-ENG136338,pwm_generator-pwm_generator_group_2_overload,not active,
ENG136326-ENG99389,Resets-Resetcounter,15,
ENG136329-ENG136339,sbc-sbc_overload,not active,
ENG136351-ENG136438,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG136351-ENG136434,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG136351-ENG136441,Seat_Actual_Positions-Current_Position_kks,32768,
ENG136351-ENG136437,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG136351-ENG136431,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG136351-ENG136436,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG136351-ENG136435,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG136351-ENG136433,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG136351-ENG136428,Seat_Actual_Positions-Current_Position_lnv,32782,
ENG136351-ENG136439,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG136351-ENG136440,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG136351-ENG136429,Seat_Actual_Positions-Current_Position_shv,33080,
ENG136351-ENG136427,Seat_Actual_Positions-Current_Position_slv,33023,
ENG136351-ENG136430,Seat_Actual_Positions-Current_Position_snv,33017,
ENG136351-ENG136432,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG136421,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG136422,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG136423,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG136424,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG136425,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,not active,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,No_signal,
ENG123053-ENG136417,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG136412,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG136418,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG136415,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG136420,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG136419,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG136416,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG136413,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG136414,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG136411,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG158188-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG158188-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG158188-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG158188-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG158188-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG158188-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG158188-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG158188-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG158188-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG158188-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG158189-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG158189-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG158189-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG158189-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG158189-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG158189-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG158189-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG158189-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG158189-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG158189-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG158190-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG158190-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG158190-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG158190-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG158190-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG158190-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG158190-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG158190-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG158190-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG158190-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG136327-ENG116986,Source_Last_Reset-Low_Voltage,active,
ENG136327-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG136327-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG136327-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG136327-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG136327-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:23
Jef
HQ
blockmap-08-1N3-907-007-D_WVGAWVEB7SH010695-20241230-1126.CSV
;SW:1N3-907-007-D   HW:1N3-907-007-C ---  Auto HVAC
;Component:Climatronic   H01 0247, Coding:013022007010120051102110111001102000102100201171000010000000
;EV_ACClimaBHBE3ADV,002051,EV_ACClimaBHBE3ADV_VW42.rod
;Monday,30,December,2024,11:26:49:18177
;VCID: 2D00D34F9D954E72E84-8078-R SFD
IDE00019,Voltage terminal 30,14.60, V
IDE00198,Refrigerant pressure,4.40, bar
IDE00767,No. of unscheduled ECU resets,0,
IDE00965,Compressor shut-off condition,AC button off,
IDE00968,Compressor speed,0.0, /min
IDE00969,Compressor load,0.0, Nm
IDE00970,Coolant fan activation: actual value,4.00, %
IDE00971,Coolant fan activation: specified value,0.0, %
IDE00973,Outside temperature,12.50, °C
IDE00974,Outside air temperature internally calculated,12.00, °C
IDE00976,Left front vent temperature,26.50, °C
IDE00977,Right front vent temperature,28.50, °C
IDE00979,Left footwell vent temperature,33.00, °C
IDE00980,Right footwell vent temperature,29.00, °C
IDE00982,Temperature downstream of evaporator,10.00, °C
IDE00983,Inside temperature,17.80, °C
IDE00984,Sun intensity left,460.00, W/m²
IDE00985,Sun intensity right,40.00, W/m²
IDE00992,Recirculation flap specified value,Unknown (4),
IDE00994,Actual value for fresh air/recirculation air flow flap,66.0, %
IDE00994,Actual value for fresh air/recirculation air flow flap,624,
IDE00995,Fresh air/recirculating air/back pressure door specified value,623,
IDE00996,Fresh air stop for fresh air/recirculation air flow flap,158,
IDE00997,Recirculated air stop for fresh air/recirc air flow flap,863,
IDE00998,Left temperature flap - actual value,73.0, %
IDE00998,Left temperature flap - actual value,649,
IDE00999,Temperature door left - Specified value,648,
IDE01040,Left Temperature Control Door - cold stop,190,
IDE01041,Left temperature flap: warm stop,818,
IDE01042,Right temperature flap: actual value,817,
IDE01042,Right temperature flap: actual value,98.5, %
IDE01043,Temperature door right - Specified value,816,
IDE01044,Right temperature flap: cold stop,185,
IDE01045,Right temperature flap: warm stop,826,
IDE01054,Defroster flap: actual value,438,
IDE01054,Defroster flap: actual value,38.5, %
IDE01055,Defrost door - Specified value,438,
IDE01056,Defroster flap: stop open,190,
IDE01057,Defroster flap: stop closed,828,
IDE01061,Rear air distribution flap: actual value,31.0, %
IDE01061,Rear air distribution flap: actual value,403,
IDE01062,Rear air distribution flap: specified value,403,
IDE01063,Status of recirculation air,Fresh air,
IDE01065,Rear vent temperature,30.00, °C
IDE01068,Rear blower voltage: actual value,3.70, V
IDE01076,Time since ignition off,0, min
IDE01092,Rear air distribution flap: vent stop,219,
IDE01093,Rear air distribution flap: footwell stop,806,
IDE01227,Blower current,0.00, A
IDE01229,Blower current of rear fresh air blower,18.75, A
IDE01232,Supply voltage for external components,5.00, V
IDE01419,Compressor shut-off condition: last,Compressor activation: malfunction in activation path,
IDE01420,Compressor shut-off requirement: penultimate,Compressor activation: malfunction in activation path,
IDE01421,Compressor shut-off requirement: antepenultimate,Compressor activation: malfunction in activation path,
IDE01433,Air quality status,Slightly dirty air: stage 1,
IDE01448,Actual value of heated front window,not coded/not installed,
IDE01464,Rear window defogger,OFF,
IDE01540-MAS06913,Left front heated seat-Backrest heating: activation,255, %
IDE01540-MAS06914,Left front heated seat-Seat cushion heating: activation,0, %
IDE01540-MAS07048,Left front heated seat-Target temperature backrest,6503.00, °C
IDE01540-MAS07049,Left front heated seat-Target temperature seat cushion,6502.90, °C
IDE01540-MAS07050,Left front heated seat-Actual temperature backrest,6503.00, °C
IDE01540-MAS07051,Left front heated seat-Actual temperature seat cushion,12.80, °C
IDE01540-MAS07052,Left front heated seat-Setting,OFF,
IDE01540-MAS07071,Left front heated seat-Temperature sensor for seat cushion: resistance value,655.35, kOhm
IDE01540-MAS07072,Left front heated seat-Temperature sensor for backrest: resistance value,655.35, kOhm
IDE01540-MAS07921,Left front heated seat-Balance setting,Neutral,
IDE01540-MAS07929,Left front heated seat-Power quota setting by energy management,99.00, %
IDE01540-MAS07945,Left front heated seat-Spec temp: backrest with active overheating function,6503.00, °C
IDE01540-MAS07946,Left front heated seat-Spec temp: seat cushion with active overheating function,6503.00, °C
IDE01540-MAS07947,Left front heated seat-Backrest heater: status,not coded/not installed,
IDE01540-MAS07950,Left front heated seat-Seat cushion heater: status,not active,
IDE01540-MAS07951,Left front heated seat-Automatic down-shift,not active,
IDE01540-MAS07968,Left front heated seat-Temp sensor offset in chassis ground,55.54, V
IDE01540-MAS12630,Left front heated seat-Backrest heater: current draw (effective value),25.50, A
IDE01540-MAS12631,Left front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01541-MAS06913,Right front heated seat-Backrest heating: activation,255, %
IDE01541-MAS06914,Right front heated seat-Seat cushion heating: activation,0, %
IDE01541-MAS07048,Right front heated seat-Target temperature backrest,6503.00, °C
IDE01541-MAS07049,Right front heated seat-Target temperature seat cushion,6502.90, °C
IDE01541-MAS07050,Right front heated seat-Actual temperature backrest,6503.00, °C
IDE01541-MAS07051,Right front heated seat-Actual temperature seat cushion,12.20, °C
IDE01541-MAS07052,Right front heated seat-Setting,OFF,
IDE01541-MAS07071,Right front heated seat-Temperature sensor for seat cushion: resistance value,655.35, kOhm
IDE01541-MAS07072,Right front heated seat-Temperature sensor for backrest: resistance value,655.35, kOhm
IDE01541-MAS07921,Right front heated seat-Balance setting,Neutral,
IDE01541-MAS07929,Right front heated seat-Power quota setting by energy management,99.00, %
IDE01541-MAS07945,Right front heated seat-Spec temp: backrest with active overheating function,6503.00, °C
IDE01541-MAS07946,Right front heated seat-Spec temp: seat cushion with active overheating function,6503.00, °C
IDE01541-MAS07947,Right front heated seat-Backrest heater: status,not coded/not installed,
IDE01541-MAS07950,Right front heated seat-Seat cushion heater: status,not active,
IDE01541-MAS07951,Right front heated seat-Automatic down-shift,not coded/not installed,
IDE01541-MAS07968,Right front heated seat-Temp sensor offset in chassis ground,55.54, V
IDE01541-MAS12630,Right front heated seat-Backrest heater: current draw (effective value),25.50, A
IDE01541-MAS12631,Right front heated seat-Seat cushion: current draw (effective value),0.00, A
IDE01622,Fresh air blower: speed,1220, /min
IDE01694-MAS01767,Left rear heated seat-Left rear seat heater stage,0,
IDE01694-MAS01768,Left rear heated seat-Left rear seat heater specified temperature,0.0, °C
IDE01694-MAS01769,Left rear heated seat-Left rear seat heater actual temperature,0.0, °C
IDE01694-MAS01770,Left rear heated seat-Left rear seat heater current,0.00, A
IDE01695-MAS01771,Right rear heated seat-Right rear seat heater stage,0,
IDE01695-MAS01772,Right rear heated seat-Right rear seat heater specified temperature,0.0, °C
IDE01695-MAS01773,Right rear heated seat-Right rear seat heater actual temperature,0.0, °C
IDE01695-MAS01774,Right rear heated seat-Right rear seat heater current,0.00, A
IDE01708-MAS01632,Rear refrigerant shut-off valve-Status,closed,
IDE02270-IDE01268,CAN input signal(s) status-Windshield wiper,OFF,
IDE02270-IDE01457,CAN input signal(s) status-Energy management deactivation stage,Deactivation stage 0,
IDE02270-MAS01281,CAN input signal(s) status-Back-up lamp,OFF,
IDE02270-MAS01283,CAN input signal(s) status-Actual value of windshield heater,OFF,
IDE02744-IDE15944,Steering wheel heating-Energy management approval,Release,
IDE02744-IDE15945,Steering wheel heating-Heater parameter set,n/a,
IDE02744-MAS01632,Steering wheel heating-Status,switched off,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,Stage 3,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,operated,
IDE02744-MAS09022,Steering wheel heating-PWM value,0, %
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,21, °C
IDE03488,Driving time remaining for basic setting of compressor run in,0, s
IDE03538-MAS01632,Ionizer: diagnosis-Status,No malfunction,
IDE03538-MAS02830,Ionizer: diagnosis-Ionizer button,not coded/not installed,
IDE03538-MAS02831,Ionizer: diagnosis-Ionizer check light,not coded/not installed,
IDE03538-MAS13074,Ionizer: diagnosis-Error validity status,not coded/not installed,
IDE04312-IDE04095,System run time-Engine running time,255, s
IDE04312-MAS00084,System run time-Terminal 15 on,255, s
IDE04805-IDE02955,Driving profile selection-System status,available.,
IDE04805-MAS01447,Driving profile selection-Act.val.,2,
IDE04805-MAS01448,Driving profile selection-Target value,2,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05533,Heater for nozzles,OFF,
IDE05738-ENG124653,Subssystem diagnosis classes-DC0_systems,Yes,
IDE05738-ENG124652,Subssystem diagnosis classes-DC1_systems,Yes,
IDE05738-ENG124651,Subssystem diagnosis classes-DC2/DC2F_systems,Yes,
IDE05738-ENG124650,Subssystem diagnosis classes-DC3_systems,No,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,22.30, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,22.50, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,50.50, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,11.40, °C
IDE06163-MAS04628,Humidity sensor: exterior-Air temperature,62.10, °C
IDE06163-MAS04629,Humidity sensor: exterior-Sensor temperature,164.50, °C
IDE06163-MAS04630,Humidity sensor: exterior-Relative humidity,126.50, %
IDE06163-MAS04647,Humidity sensor: exterior-Dew point,62.10, °C
IDE06201,Blower reduction,Unknown (0),
IDE06545,Blower voltage for production routines,6.00, V
IDE06546,Interior specified temperature for production routines,22, °C
IDE06547,Air distribution for production routines,Air distribution top and footwell,
IDE06593,Air recirculation for production routines,Fresh air,
IDE06976,Right front air distribution flap motor: actual value,127.50,
IDE06976,Right front air distribution flap motor: actual value,65535,
IDE06977,Right front air distribution flap motor: spec. value,778,
IDE06979,Left front air distribution flap motor: actual value,42.00,
IDE06979,Left front air distribution flap motor: actual value,452,
IDE06980,Left front air distribution flap motor: spec. value,448,
IDE07133,Fresh air blower motor: temperature,16.00, °C
IDE07968,Air distribution flap motor: actual value,14528,
IDE07969,Air distribution flap motor: specified value,14528,
IDE07970,Air distribution flap motor: dynamic,14528,
IDE08372,Fresh air blower: target speed,1220, /min
IDE08442-MAS01580,Wiper storage and spray nozzle heater-Activation,OFF,
IDE08442-MAS07000,Wiper storage and spray nozzle heater-Switch-on current,0,
IDE08442-MAS12621,Wiper storage and spray nozzle heater-Current draw (effective value),0,
IDE08774-MAS01453,Fresh air blower: error status-Blocking detection,not active,
IDE08774-MAS01478,Fresh air blower: error status-insufficient voltage,not active,
IDE08774-MAS01479,Fresh air blower: error status-Excessive voltage,not active,
IDE08774-MAS01480,Fresh air blower: error status-excessive temperature,not active,
IDE08774-MAS01575,Fresh air blower: error status-Internal malfunction,not active,
IDE08774-MAS01807,Fresh air blower: error status-Short circuit,not active,
IDE08774-MAS07627,Fresh air blower: error status-Over current string,not active,
IDE08774-MAS07628,Fresh air blower: error status-Over current phase,not active,
IDE08774-MAS07629,Fresh air blower: error status-Error current offset,not active,
IDE08774-MAS07630,Fresh air blower: error status-error temperature sensor,not active,
IDE08774-MAS07631,Fresh air blower: error status-Error bridge driver,not active,
IDE08774-MAS07632,Fresh air blower: error status-Excess temp. bridge driver,not active,
IDE08961-MAS01554,Installation info: seat heater-Left heated seat,Parallel activation of backrest and seat cushion,
IDE08961-MAS01556,Installation info: seat heater-Right heated seat,Parallel activation of backrest and seat cushion,
IDE09168-MAS01632,Shut-off valve 1 for refrigerant-Status,Open,
IDE09203,HV heater shut-off condition,none,
IDE10300,OBD Driving Cycle detected,active,
IDE10942-MAS00788,Expansion valve 1 for refrigerant-LIN node- address,Shut-off valve 1 for refrigerant,
IDE10942-MAS01447,Expansion valve 1 for refrigerant-Act.val.,0, %
IDE10942-MAS01448,Expansion valve 1 for refrigerant-Target value,0, %
IDE10942-MAS02201,Expansion valve 1 for refrigerant-Temperature,28, °C
IDE10942-MAS10469,Expansion valve 1 for refrigerant-Raw value,65534,
IDE10943-MAS00788,Expansion valve 2 for refrigerant-LIN node- address,not coded/not installed,
IDE10943-MAS01447,Expansion valve 2 for refrigerant-Act.val.,65533, %
IDE10943-MAS01448,Expansion valve 2 for refrigerant-Target value,65533, %
IDE10943-MAS02201,Expansion valve 2 for refrigerant-Temperature,203, °C
IDE10943-MAS10469,Expansion valve 2 for refrigerant-Raw value,65533,
IDE10944-MAS00788,Expansion valve 3 for refrigerant-LIN node- address,not coded/not installed,
IDE10944-MAS01447,Expansion valve 3 for refrigerant-Act.val.,65533, %
IDE10944-MAS01448,Expansion valve 3 for refrigerant-Target value,65533, %
IDE10944-MAS02201,Expansion valve 3 for refrigerant-Temperature,203, °C
IDE10944-MAS10469,Expansion valve 3 for refrigerant-Raw value,65533,
IDE10945-MAS00788,Shut-off valve 1 for refrigerant-LIN node- address,not coded/not installed,
IDE10945-MAS01447,Shut-off valve 1 for refrigerant-Act.val.,65533, %
IDE10945-MAS01448,Shut-off valve 1 for refrigerant-Target value,65533, %
IDE10945-MAS02201,Shut-off valve 1 for refrigerant-Temperature,203, °C
IDE10945-MAS10469,Shut-off valve 1 for refrigerant-Raw value,65533,
IDE10946-MAS00788,Shut-off valve 2 for refrigerant-LIN node- address,not coded/not installed,
IDE10946-MAS01447,Shut-off valve 2 for refrigerant-Act.val.,65533, %
IDE10946-MAS01448,Shut-off valve 2 for refrigerant-Target value,65533, %
IDE10946-MAS02201,Shut-off valve 2 for refrigerant-Temperature,203, °C
IDE10946-MAS10469,Shut-off valve 2 for refrigerant-Raw value,65533,
IDE10947-MAS00788,Shut-off valve 3 for refrigerant-LIN node- address,not coded/not installed,
IDE10947-MAS01447,Shut-off valve 3 for refrigerant-Act.val.,65533, %
IDE10947-MAS01448,Shut-off valve 3 for refrigerant-Target value,65533, %
IDE10947-MAS02201,Shut-off valve 3 for refrigerant-Temperature,203, °C
IDE10947-MAS10469,Shut-off valve 3 for refrigerant-Raw value,65533,
IDE10948-MAS00788,Shut-off valve 4 for refrigerant-LIN node- address,not coded/not installed,
IDE10948-MAS01447,Shut-off valve 4 for refrigerant-Act.val.,65533, %
IDE10948-MAS01448,Shut-off valve 4 for refrigerant-Target value,65533, %
IDE10948-MAS02201,Shut-off valve 4 for refrigerant-Temperature,203, °C
IDE10948-MAS10469,Shut-off valve 4 for refrigerant-Raw value,65533,
IDE10949-MAS00788,Shut-off valve 5 for refrigerant-LIN node- address,not coded/not installed,
IDE10949-MAS01447,Shut-off valve 5 for refrigerant-Act.val.,65533, %
IDE10949-MAS01448,Shut-off valve 5 for refrigerant-Target value,65533, %
IDE10949-MAS02201,Shut-off valve 5 for refrigerant-Temperature,203, °C
IDE10949-MAS10469,Shut-off valve 5 for refrigerant-Raw value,65533,
IDE10951-IDE00198,A/C pressure/temperature sensor 1-Refrigerant pressure,4.5672, bar
IDE10951-MAS00073,A/C pressure/temperature sensor 1-Communication,OK,
IDE10951-MAS02832,A/C pressure/temperature sensor 1-Malfunction status,OK,
IDE10951-MAS07055,A/C pressure/temperature sensor 1-Response error,OK,
IDE10951-MAS09641,A/C pressure/temperature sensor 1-Inside temperature,17.60, °C
IDE10951-MAS10764,A/C pressure/temperature sensor 1-Test Result,Tested in current operating cycle,
IDE10951-MAS11295,A/C pressure/temperature sensor 1-Refrigerant temperature,11.60, °C
IDE10976-MAS02201,Coolant expansion valve 1: internal status-Temperature,28, °C
IDE10976-MAS02282,Coolant expansion valve 1: internal status-Position,0,
IDE10977-MAS02201,Coolant expansion valve 2: internal status-Temperature,129, °C
IDE10977-MAS02282,Coolant expansion valve 2: internal status-Position,65010,
IDE10978-MAS02201,Coolant expansion valve 3: internal status-Temperature,129, °C
IDE10978-MAS02282,Coolant expansion valve 3: internal status-Position,65010,
IDE10979-MAS02201,Coolant shut-off valve 1: internal status-Temperature,129, °C
IDE10979-MAS02282,Coolant shut-off valve 1: internal status-Position,65010,
IDE10980-MAS02201,Coolant shut-off valve 2: internal status-Temperature,129, °C
IDE10980-MAS02282,Coolant shut-off valve 2: internal status-Position,65010,
IDE10981-MAS02201,Coolant shut-off valve 3: internal status-Temperature,129, °C
IDE10981-MAS02282,Coolant shut-off valve 3: internal status-Position,65010,
IDE10982-MAS02201,Coolant shut-off valve 4: internal status-Temperature,129, °C
IDE10982-MAS02282,Coolant shut-off valve 4: internal status-Position,65010,
IDE10983-MAS02201,Coolant shut-off valve 5: internal status-Temperature,129, °C
IDE10983-MAS02282,Coolant shut-off valve 5: internal status-Position,65010,
IDE11430,Rear blower reduction,Unknown (0),
IDE11431,Rear blower status,active,
IDE11432,Temp. dwn. strm. of rear evaporator,6513.50, °C
IDE11455-MAS11114,Range consumption forecast-Time to transition from dynamic to steady-state operation,4, min
IDE11455-MAS11115,Range consumption forecast-Change in the prediction initiated by customer action,2,
IDE11455-MAS11116,Range consumption forecast-Dynamic power for heating/cooling,160.00, W
IDE11455-MAS11117,Range consumption forecast-Steady-state power for heating/cooling,610.00, W
IDE11455-MAS11118,Range consumption forecast-Consumption for heating and cooling of the components,0, Ws
IDE11455-MAS11119,Range consumption forecast-Overflow-bit component consumption,no overflow,
IDE11455-MAS11120,Range consumption forecast-Consumption for heating and cooling of the interior,7865, Ws
IDE11455-MAS13274,Range consumption forecast-Overflow-bit interior consumption,Overflow,
IDE11698-MAS09216,Instrument panel temperature sensor-Sun intensity,0.00, W/m²
IDE11698-MAS13115,Instrument panel temperature sensor-Sunlight sensor: voltage,655.35, V
IDE11698-MAS13116,Instrument panel temperature sensor-Temperature sensor 1: temperature,18.000, °C
IDE11698-MAS13117,Instrument panel temperature sensor-Temperature sensor 1: resistance value,655.35, kOhm
IDE11698-MAS13118,Instrument panel temperature sensor-Temperature sensor 2: temperature,4045.938, °C
IDE11698-MAS13119,Instrument panel temperature sensor-Temperature sensor 2: resistance value,655.35, kOhm
IDE11698-MAS13179,Instrument panel temperature sensor-Temperature sensor 3: temperature,4045.938, °C
IDE11698-MAS13180,Instrument panel temperature sensor-Temperature sensor 3: resistance value,655.35, kOhm
IDE11790,Carbon dioxide content in the interior,Malfunction,
IDE11791,Particulate matter content in air,65010, µg/m³
IDE11836,Query of the supported PIDs (0x01 - 0x20),135790593,
IDE11837,Query of the supported PIDs (0x21 - 0x40),1,
IDE11838,Query of the supported PIDs (0x41 - 0x60),0,
IDE11839,Query of the supported InfoTypes (0x01 - 0x20),0,
IDE12499-IDE08704,A/C compressor initial running in: start prevention-Load management,not active,
IDE12499-MAS01250,A/C compressor initial running in: start prevention-Malfunction on fresh air blower,not active,
IDE12499-MAS01493,A/C compressor initial running in: start prevention-Engine running,Yes,
IDE12499-MAS10030,A/C compressor initial running in: start prevention-Adapt. of run-in time: compressor initial operation: written,Yes,
IDE12499-MAS14625,A/C compressor initial running in: start prevention-High-voltage vehicle electrical system,not active,
IDE12499-MAS14626,A/C compressor initial running in: start prevention-High-voltage current limitations,not active,
IDE12499-MAS14891,A/C compressor initial running in: start prevention-Flaps not calibrated,not active,
IDE12500-IDE08704,A/C compressor initial running in: interruption conditions-Load management,not active,
IDE12500-MAS01250,A/C compressor initial running in: interruption conditions-Malfunction on fresh air blower,not active,
IDE12500-MAS01254,A/C compressor initial running in: interruption conditions-AC button off,not active,
IDE12500-MAS01256,A/C compressor initial running in: interruption conditions-Outside air temperature too low,not active,
IDE12500-MAS01261,A/C compressor initial running in: interruption conditions-Evaporator temperature ice-up danger,not active,
IDE12500-MAS01263,A/C compressor initial running in: interruption conditions-Compressor activation: malfunction in activation path,not active,
IDE12500-MAS01264,A/C compressor initial running in: interruption conditions-Malfunction at refrigerant pressure sensor,not active,
IDE12500-MAS01265,A/C compressor initial running in: interruption conditions-Speed shut-off,not active,
IDE12500-MAS01504,A/C compressor initial running in: interruption conditions-Supply voltage too high,not active,
IDE12500-MAS01508,A/C compressor initial running in: interruption conditions-High pressure event,not active,
IDE12500-MAS01509,A/C compressor initial running in: interruption conditions-Low pressure event,not active,
IDE12500-MAS14625,A/C compressor initial running in: interruption conditions-High-voltage vehicle electrical system,not active,
IDE12500-MAS14626,A/C compressor initial running in: interruption conditions-High-voltage current limitations,not active,
IDE12500-MAS14892,A/C compressor initial running in: interruption conditions-Pressure test not successful,not active,
IDE12500-MAS14893,A/C compressor initial running in: interruption conditions-Fault on the evaporator temperature sensor,not active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVGAWVEB7SH010695,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,3,
IDE13845,Production mode status,not active,
IDE14095,Wiper park position heater,not coded/not installed,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant (challenge response only),
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,2,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 28,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14804-MAS19258,A/C Compressor compatibility monitor-Activated numbers of error screen in climate control module,31,
IDE14804-MAS19259,A/C Compressor compatibility monitor-Number of A/C Compressor error display from last routine,31,
IDE14804-MAS19260,A/C Compressor compatibility monitor-Number of error display for A/C Compressor: actual value,31,
IDE14804-MAS19261,A/C Compressor compatibility monitor-Activated error display in climate control module: status,Qualified,
IDE14804-MAS19262,A/C Compressor compatibility monitor-Number of disrupted standard comparisons,0,
IDE15120-IDE01233,A/C Compressor EKK4 system monitor-Compressor motor current,0.00, A
IDE15120-IDE05237,A/C Compressor EKK4 system monitor-A/C compressor power consumption: actual value,0, W
IDE15120-IDE05241,A/C Compressor EKK4 system monitor-A/C compressor release status,not transmitted,
IDE15120-IDE06336,A/C Compressor EKK4 system monitor-A/C compressor: target speed,0, /min
IDE15120-IDE06337,A/C Compressor EKK4 system monitor-A/C compressor: actual speed,0, /min
IDE15120-MAS04770,A/C Compressor EKK4 system monitor-A/C compressor: function status,Air conditioner compressor off,
IDE15120-MAS05974,A/C Compressor EKK4 system monitor-A/C compressor error indicator,not active,
IDE15120-MAS05976,A/C Compressor EKK4 system monitor-A/C compressor: inverter temperature,13.00, °C
IDE15120-MAS05978,A/C Compressor EKK4 system monitor-High voltage supply voltage,396, V
IDE15120-MAS12658,A/C Compressor EKK4 system monitor-HV release,transmitted,
IDE16374-ENG378374,Seat Heating status: 2nd row passenger side-ClimateModes,Not available,
IDE16375-ENG378374,Seat Heating status: 3rd row passenger side-ClimateModes,Not available,
IDE16376-ENG378374,Seat Heating status: 2nd row driver side-ClimateModes,installed,
IDE16377-ENG378374,Seat Heating status: 3rd row driver side-ClimateModes,Not available,
IDE16609-MAS00073,A/C pressure/temperature sensor 1  R744-Communication,Unknown (210),
IDE16609-MAS01441,A/C pressure/temperature sensor 1  R744-Refrigerant pressure,320.10,
IDE16609-MAS02832,A/C pressure/temperature sensor 1  R744-Malfunction status,Unknown (210),
IDE16609-MAS07055,A/C pressure/temperature sensor 1  R744-Response error,Unknown (210),
IDE16609-MAS09641,A/C pressure/temperature sensor 1  R744-Inside temperature,3201.00, °C
IDE16609-MAS10764,A/C pressure/temperature sensor 1  R744-Test Result,Unknown (210),
IDE16609-MAS11295,A/C pressure/temperature sensor 1  R744-Refrigerant temperature,3201.00, °C
IDE16797,Pre-ventilation: total elapsed time of the function,16777215, s
IDE16798,Pre-ventilation: number of functions performed,65535,
IDE16799,Pre-ventilation: remaining time,65535,
IDE17034-MAS00073,A/C pressure/temperature sensor 2  R744-Communication,Unknown (210),
IDE17034-MAS01441,A/C pressure/temperature sensor 2  R744-Refrigerant pressure,320.10, bar
IDE17034-MAS02832,A/C pressure/temperature sensor 2  R744-Malfunction status,Unknown (210),
IDE17034-MAS07055,A/C pressure/temperature sensor 2  R744-Response error,Unknown (210),
IDE17034-MAS09641,A/C pressure/temperature sensor 2  R744-Inside temperature,3201.00, °C
IDE17034-MAS10764,A/C pressure/temperature sensor 2  R744-Test Result,Unknown (210),
IDE17034-MAS11295,A/C pressure/temperature sensor 2  R744-Refrigerant temperature,3201.00, °C
IDE17035-MAS00073,A/C pressure/temperature sensor 3  R744-Communication,Unknown (210),
IDE17035-MAS01441,A/C pressure/temperature sensor 3  R744-Refrigerant pressure,320.10, bar
IDE17035-MAS02832,A/C pressure/temperature sensor 3  R744-Malfunction status,Unknown (210),
IDE17035-MAS07055,A/C pressure/temperature sensor 3  R744-Response error,Unknown (210),
IDE17035-MAS09641,A/C pressure/temperature sensor 3  R744-Inside temperature,3201.00, °C
IDE17035-MAS10764,A/C pressure/temperature sensor 3  R744-Test Result,Unknown (210),
IDE17035-MAS11295,A/C pressure/temperature sensor 3  R744-Refrigerant temperature,3201.00, °C
IDE17036-MAS00073,A/C pressure/temperature sensor 4  R744-Communication,Unknown (210),
IDE17036-MAS01441,A/C pressure/temperature sensor 4  R744-Refrigerant pressure,320.10, bar
IDE17036-MAS02832,A/C pressure/temperature sensor 4  R744-Malfunction status,Unknown (210),
IDE17036-MAS07055,A/C pressure/temperature sensor 4  R744-Response error,Unknown (210),
IDE17036-MAS09641,A/C pressure/temperature sensor 4  R744-Inside temperature,3201.00, °C
IDE17036-MAS10764,A/C pressure/temperature sensor 4  R744-Test Result,Unknown (210),
IDE17036-MAS11295,A/C pressure/temperature sensor 4  R744-Refrigerant temperature,3201.00, °C
IDE17037-MAS00073,A/C pressure/temperature sensor 5  R744-Communication,Unknown (210),
IDE17037-MAS01441,A/C pressure/temperature sensor 5  R744-Refrigerant pressure,320.10, bar
IDE17037-MAS02832,A/C pressure/temperature sensor 5  R744-Malfunction status,Unknown (210),
IDE17037-MAS07055,A/C pressure/temperature sensor 5  R744-Response error,Unknown (210),
IDE17037-MAS09641,A/C pressure/temperature sensor 5  R744-Inside temperature,3201.00, °C
IDE17037-MAS10764,A/C pressure/temperature sensor 5  R744-Test Result,Unknown (210),
IDE17037-MAS11295,A/C pressure/temperature sensor 5  R744-Refrigerant temperature,3201.00, °C
IDE17038-MAS00073,A/C pressure/temperature sensor 6  R744-Communication,OK,
IDE17038-MAS01441,A/C pressure/temperature sensor 6  R744-Refrigerant pressure,320.10,
IDE17038-MAS02832,A/C pressure/temperature sensor 6  R744-Malfunction status,OK,
IDE17038-MAS07055,A/C pressure/temperature sensor 6  R744-Response error,OK,
IDE17038-MAS09641,A/C pressure/temperature sensor 6  R744-Inside temperature,-40.00, °C
IDE17038-MAS10764,A/C pressure/temperature sensor 6  R744-Test Result,Tested in current operating cycle,
IDE17038-MAS11295,A/C pressure/temperature sensor 6  R744-Refrigerant temperature,3201.00, °C
IDE18268-IDE18264,Humidity/temperature sensor for seat: left front-Seat cushion humidity,255, %
IDE18268-IDE18265,Humidity/temperature sensor for seat: left front-Seat cushion temperature,127.50, °C
IDE18268-IDE18266,Humidity/temperature sensor for seat: left front-Backrest humidity,255, %
IDE18268-IDE18267,Humidity/temperature sensor for seat: left front-Temperature seat backrest,77.00, °C
IDE18269-IDE18264,Humidity/temperature sensor for seat: right front-Seat cushion humidity,255, %
IDE18269-IDE18265,Humidity/temperature sensor for seat: right front-Seat cushion temperature,127.50, °C
IDE18269-IDE18266,Humidity/temperature sensor for seat: right front-Backrest humidity,255, %
IDE18269-IDE18267,Humidity/temperature sensor for seat: right front-Temperature seat backrest,127.50, °C
IDE18270-IDE18264,Humidity/temperature sensor for seat: left rear-Seat cushion humidity,255, %
IDE18270-IDE18265,Humidity/temperature sensor for seat: left rear-Seat cushion temperature,127.50, °C
IDE18270-IDE18266,Humidity/temperature sensor for seat: left rear-Backrest humidity,255, %
IDE18270-IDE18267,Humidity/temperature sensor for seat: left rear-Temperature seat backrest,127.50, °C
IDE18271-IDE18264,Humidity/temperature sensor for seat: right rear-Seat cushion humidity,255, %
IDE18271-IDE18265,Humidity/temperature sensor for seat: right rear-Seat cushion temperature,127.50, °C
IDE18271-IDE18266,Humidity/temperature sensor for seat: right rear-Backrest humidity,255, %
IDE18271-IDE18267,Humidity/temperature sensor for seat: right rear-Temperature seat backrest,127.50, °C
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,30,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,27,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,15,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,10,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,464, km
MAS11297-MAS01379,Standstilll A/C: customer setting-Operating time,2, min
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 05 03 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,5,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20376-MAS01634,High-voltage air heater status: internal-Supply voltage,OK,
MAS20376-MAS02246,High-voltage air heater status: internal-Timeout,OK,
MAS20376-MAS03746,High-voltage air heater status: internal-Current: actual value,1.25, A
MAS20376-MAS05978,High-voltage air heater status: internal-High voltage supply voltage,406, V
MAS20376-MAS07055,High-voltage air heater status: internal-Response error,OK,
MAS20376-MAS09468,High-voltage air heater status: internal-Vehicle high voltage system,OK,
MAS20376-MAS09469,High-voltage air heater status: internal-HV heater: status,OK,
MAS20376-MAS10074,High-voltage air heater status: internal-Supply voltage: actual value,16.40, V
MAS20376-MAS21216,High-voltage air heater status: internal-Heater electronics and circuit board temperature (PCB),35, °C
MAS20376-MAS21217,High-voltage air heater status: internal-Heating circuit 1 status,OK,
MAS20376-MAS21218,High-voltage air heater status: internal-Heating circuit 2 status,OK,
MAS20376-MAS21219,High-voltage air heater status: internal-Heating circuit 3 status,OK,
MAS20376-MAS21221,High-voltage air heater status: internal-Heating circuit 4 status,OK,
MAS20376-MAS21222,High-voltage air heater status: internal-Current flow with heating circuit not activated,OK,
MAS20376-MAS21223,High-voltage air heater status: internal-Total current over long period of time too high,OK,
MAS20376-MAS21224,High-voltage air heater status: internal-Circuit board temperature: shut-off value,OK,
MAS20376-MAS21225,High-voltage air heater status: internal-Internal error (other),OK,
MAS20377-MAS08432,High-voltage air heater status: global-Requirement,active,
MAS20377-MAS21209,High-voltage air heater status: global-Specified value: left,10, %
MAS20377-MAS21210,High-voltage air heater status: global-Specified value: right,7, %
MAS20377-MAS21211,High-voltage air heater status: global-Center target value,0, %
MAS20377-MAS21212,High-voltage air heater status: global-Number of heat zones,2 zones,
MAS20377-MAS21213,High-voltage air heater status: global-Heating system used,Basic system,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS20802,Front right air distribution door- defrost end stop,99,
MAS20809,Front left air distribution door - defrost end stop,97,
MAS20817,Front right air distribution door - Mann end stop,928,
MAS20818,Front left air distribution door - Mann end stop,933,
MAS23045-MAS01634,High-voltage air heater 2 status: internal-Supply voltage,OK,
MAS23045-MAS02246,High-voltage air heater 2 status: internal-Timeout,OK,
MAS23045-MAS03746,High-voltage air heater 2 status: internal-Current: actual value,1.00, A
MAS23045-MAS05978,High-voltage air heater 2 status: internal-High voltage supply voltage,396, V
MAS23045-MAS07055,High-voltage air heater 2 status: internal-Response error,OK,
MAS23045-MAS09468,High-voltage air heater 2 status: internal-Vehicle high voltage system,OK,
MAS23045-MAS09469,High-voltage air heater 2 status: internal-HV heater: status,OK,
MAS23045-MAS10074,High-voltage air heater 2 status: internal-Supply voltage: actual value,16.40, V
MAS23045-MAS21216,High-voltage air heater 2 status: internal-Heater electronics and circuit board temperature (PCB),24,
MAS23045-MAS21217,High-voltage air heater 2 status: internal-Heating circuit 1 status,OK,
MAS23045-MAS21218,High-voltage air heater 2 status: internal-Heating circuit 2 status,OK,
MAS23045-MAS21219,High-voltage air heater 2 status: internal-Heating circuit 3 status,OK,
MAS23045-MAS21221,High-voltage air heater 2 status: internal-Heating circuit 4 status,OK,
MAS23045-MAS21222,High-voltage air heater 2 status: internal-Current flow with heating circuit not activated,OK,
MAS23045-MAS21223,High-voltage air heater 2 status: internal-Total current over long period of time too high,OK,
MAS23045-MAS21224,High-voltage air heater 2 status: internal-Circuit board temperature: shut-off value,OK,
MAS23045-MAS21225,High-voltage air heater 2 status: internal-Internal error (other),OK,
MAS23052-MAS08432,High-voltage air heater 2 status: global-Requirement,active,
MAS23052-MAS21209,High-voltage air heater 2 status: global-Specified value: left,9, %
MAS23052-MAS21210,High-voltage air heater 2 status: global-Specified value: right,9, %
MAS23052-MAS21211,High-voltage air heater 2 status: global-Center target value,0, %
MAS23052-MAS21212,High-voltage air heater 2 status: global-Number of heat zones,2 zones,
MAS23052-MAS21213,High-voltage air heater 2 status: global-Heating system used,Basic system,
MAS23053,Carbon dioxide concentration in the rear vehicle interior,Malfunction,
MAS24099-MAS02201,Coolant expansion valve 4: internal status-Temperature,129.00, °C
MAS24099-MAS02282,Coolant expansion valve 4: internal status-Position,65010,
SFT272229-MAS00788,Expansion valve 4 for refrigerant-LIN node- address,not coded/not installed,
SFT272229-MAS01447,Expansion valve 4 for refrigerant-Act.val.,65533, %
SFT272229-MAS01448,Expansion valve 4 for refrigerant-Target value,65533, %
SFT272229-MAS02201,Expansion valve 4 for refrigerant-Temperature,203, °C
SFT272229-MAS10469,Expansion valve 4 for refrigerant-Raw value,65533,
ENG181012,FoD_slave_state,2,
ENG254718-IDE04332,Function_On_Demand_Unlock_ID_Status_Dev-Release code for a SWaP function,available.,
ENG254718-IDE05814,Function_On_Demand_Unlock_ID_Status_Dev-Individualization characteristic,invalid,
ENG254718-IDE06260,Function_On_Demand_Unlock_ID_Status_Dev-ID number,268763904,
ENG254718-MAS01340,Function_On_Demand_Unlock_ID_Status_Dev-Functions,available.,
ENG254718-MAS01903,Function_On_Demand_Unlock_ID_Status_Dev-Configuration,OK,
ENG254718-MAS02934,Function_On_Demand_Unlock_ID_Status_Dev-Preconditions met,Condition not met,
ENG254718-MAS05616,Function_On_Demand_Unlock_ID_Status_Dev-Cancellation,not_canceled,
ENG254718-MAS05617,Function_On_Demand_Unlock_ID_Status_Dev-Authentication,Condition met,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,5,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
Elapsed Time: 00:34
blockmap-09-1EE-937-089-C_WVGAWVEB7SH010695-20241230-1127.CSV
;SW:1EE-937-089-C   HW:1EE-937-089-A ---  Cent. Elect.
;Component:SAM_H+        H08 0555, Coding:
;EV_SAMVW31x,006001,EV_SAMVW31x_006_VNE4.rod
;Monday,30,December,2024,11:27:54:18177
;VCDS Version: Beta 24.12.0 (x64)  Data version: 20241120 DS361.3
;VCID: 42DA90F3340BA10A256-8016-R SFD
Group,Description,Actual
IDE00001,Production mode,not active,
IDE00324-MAS20322,Programming preconditions-Number of programming requirements,4,
IDE00324,Programming preconditions,|Programming Precondition|Vehicle speed is not zero|Supply voltage too low|Sub data bus system in diagnosis|Active function not ended|,
IDE00356-IDE00355,Cruise Control System (CCS): switch position-Cruise Control System (CCS): status,not coded/not installed,
IDE00356-MAS00125,Cruise Control System (CCS): switch position-Cruise control system,not coded/not installed,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,not coded/not installed,
IDE00356-MAS00320,Cruise Control System (CCS): switch position-Main switch,not coded/not installed,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,not coded/not installed,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,not coded/not installed,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,not coded/not installed,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,NOT-DEFINED,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,not coded/not installed,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,not coded/not installed,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,not coded/not installed,
IDE00973,Outside temperature,12.5, °C
IDE01164-MAS10094,Parking aid button-Rear outside door handle sensor: frt. pass. side,not coded/not installed,
IDE02260-IDE00773,Supply voltage for door control module: rear: left-Terminal 15 status via CAN,active,
IDE02260-IDE01715,Supply voltage for door control module: rear: left-Status terminal S,active,
IDE02260-IDE05835,Supply voltage for door control module: rear: left-Supply voltage for central locking,14.80, V
IDE02261-IDE00773,Supply voltage for door control module: rear: frt.pass. side-Terminal 15 status via CAN,active,
IDE02261-IDE01715,Supply voltage for door control module: rear: frt.pass. side-Status terminal S,active,
IDE02261-IDE05835,Supply voltage for door control module: rear: frt.pass. side-Supply voltage for central locking,14.80, V
IDE02266,Passenger side rear power window button,Not operated,
IDE02711-IDE05228,Rear wiper-Operating hour counter,00 00 00 00 0E 00 00 00 48 45 52 5F 4D 59 4A 54 01 6E 46 57 49 53 43 48 45 52 5F 53 4C 30 32 00,
IDE02711-MAS01632,Rear wiper-Status,not active,
IDE02711-MAS20299,Rear wiper-Wiper level: steering column switch module,switched off,
IDE02711-MAS20300,Rear wiper-Actual wiper level,not active,
IDE02744-MAS01632,Steering wheel heating-Status,not coded/not installed,
IDE02744-MAS02311,Steering wheel heating-Steering wheel heating button,not coded/not installed,
IDE02744-MAS09758,Steering wheel heating-Temperature sensor,205, °C
IDE02857-IDE03111,Activation current-Interior lighting,0, mA
IDE02857-IDE06012,Activation current-Background lighting,0, mA
IDE02857-MAS01288,Activation current-Horn,No malfunction,
IDE02857-ENG128458,Activation current-DWA_Einfachhorn,Measuring value not available,
IDE04347-IDE00020,Expanded freeze frame conditions-Terminal 15 status,On,
IDE04347-IDE01716,Expanded freeze frame conditions-Terminal 50 status,OFF,
IDE04347-IDE05742,Expanded freeze frame conditions-Light switch position,automatic,
IDE04347-MAS01458,Expanded freeze frame conditions-Operating condition,Normal mode,
IDE04347-MAS01957,Expanded freeze frame conditions-Outside temperature,12.5, °C
IDE04347-MAS04121,Expanded freeze frame conditions-Voltage,14.8, V
IDE04347-MAS15304,Expanded freeze frame conditions-Status drive readiness,Drive readiness,
IDE04347-MAS19766,Expanded freeze frame conditions-Status of brake lamp switch: discrete,On,
IDE04347-MAS19768,Expanded freeze frame conditions-Brake lamp switch via CAN: status,On,
IDE04639,Last wake-up cause,Terminal 15 ignition switch signal 1,
IDE05045-IDE05183,Front wiper module-Malfunction left,No malfunction,
IDE05045-IDE05184,Front wiper module-Malfunction right,No malfunction,
IDE05045-MAS01364,Front wiper module-Stage 1,not active,
IDE05045-MAS01365,Front wiper module-Stage 2,not active,
IDE05045-MAS03638,Front wiper module-Wipe speed,0 revolutions per minute,
IDE05045-MAS05057,Front wiper module-Number of wiper cycles,1400,
IDE05045-MAS05878,Front wiper module-Stage,not coded/not installed,
IDE05719-IDE05534,Window washer system-Headlamp washer system,not coded/not installed,
IDE05719-MAS02341,Window washer system-Rear window washer system,not active,
IDE05834-MAS00212,Driver info-Insufficient washer fluid,not active,
IDE05836-MAS03637,Rain recognition sensor-Rain quantity,0,
IDE05838-MAS02248,Light recognition sensor-Signal state,active,
IDE05838-MAS02475,Light recognition sensor-Brightness infrared,14000, lx
IDE05838-MAS02851,Light recognition sensor-Brightness,4626, lx
IDE05838-MAS04809,Light recognition sensor-Darkness,OFF,
IDE05838-MAS04810,Light recognition sensor-Request for light activation,OFF,
IDE06091-IDE01440,Humidity sensor: interior-Front windshield temperature,22.8, °C
IDE06091-MAS04629,Humidity sensor: interior-Sensor temperature,23.0, °C
IDE06091-MAS04630,Humidity sensor: interior-Relative humidity,48.5, %
IDE06091-MAS04647,Humidity sensor: interior-Dew point,11.2, °C
IDE06208-MAS01453,Rear window regulator status: driver side-Blocking detection,not active,
IDE06208-MAS02039,Rear window regulator status: driver side-Force limitation,not active,
IDE06208-MAS02097,Rear window regulator status: driver side-Window position,0.00, %
IDE06208-MAS02098,Rear window regulator status: driver side-Window regulator standardized,Yes,
IDE06208-MAS03548,Rear window regulator status: driver side-Motor current,0, A
IDE06208-MAS04642,Rear window regulator status: driver side-Before upper stop,not active,
IDE06208-MAS05370,Rear window regulator status: driver side-Direction of movement,Position top,
IDE06209-MAS01453,Rear window regulator status: frt.pass. side-Blocking detection,not active,
IDE06209-MAS02039,Rear window regulator status: frt.pass. side-Force limitation,not active,
IDE06209-MAS02097,Rear window regulator status: frt.pass. side-Window position,0.00, %
IDE06209-MAS02098,Rear window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06209-MAS03548,Rear window regulator status: frt.pass. side-Motor current,0, A
IDE06209-MAS04642,Rear window regulator status: frt.pass. side-Before upper stop,not active,
IDE06209-MAS05370,Rear window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06621,Driver side rear power window button,Not operated,
IDE06931-MAS01159,Ident. of rear window regulator programming: driver side-Version number,5716,
IDE06932-MAS01159,Ident. of rear window regulator programming: frt.pass. side-Version number,5716,
IDE06935,Rear window regulator relay: driver side,Open,
IDE06936,Rear window regulator relay: frt.pass. side,Open,
IDE06939-MAS02545,Rear window regulator reversing position: driver side-Last,127.50, %
IDE06939-MAS02546,Rear window regulator reversing position: driver side-Second to last,127.50, %
IDE06939-MAS02547,Rear window regulator reversing position: driver side-Third to last,127.50, %
IDE06939-MAS02548,Rear window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06939-MAS05380,Rear window regulator reversing position: driver side-fifth to last,127.50, %
IDE06940,Rear window regulator child lock: driver side,active,
IDE06941,Rear window regulator child lock: frt.pass. side,active,
IDE07407-IDE03114,Enable driver-side rear window regulator-Comfort function,No,
IDE07407-MAS02447,Enable driver-side rear window regulator-Release,Yes,
IDE07408-IDE03114,Enable frt.pass.-side rear window regulator-Comfort function,No,
IDE07408-MAS02447,Enable frt.pass.-side rear window regulator-Release,Yes,
IDE07411-MAS01632,Excess.temp.disconnect: rear window regulator: driver side-Status,not active,
IDE07411-MAS02955,Excess.temp.disconnect: rear window regulator: driver side-Engine temperature,22, °C
IDE07412-MAS01632,Excess.temp.disconnect for rear window regulator: frt.pass.side-Status,not active,
IDE07412-MAS02955,Excess.temp.disconnect for rear window regulator: frt.pass.side-Engine temperature,24, °C
IDE07415,Comfort function for rear window regulator: driver side,not active,
IDE07416,Comfort function for rear window regulator: frt.pass. side,not active,
IDE07417-MAS02545,Rear window regulator reversing position: frt.pass. side-Last,7.50, %
IDE07417-MAS02546,Rear window regulator reversing position: frt.pass. side-Second to last,127.50, %
IDE07417-MAS02547,Rear window regulator reversing position: frt.pass. side-Third to last,127.50, %
IDE07417-MAS02548,Rear window regulator reversing position: frt.pass. side-Fourth to last,127.50, %
IDE07417-MAS05380,Rear window regulator reversing position: frt.pass. side-fifth to last,127.50, %
IDE08185,Counter for play protection of central locking,not active,
IDE08211-MAS03129,History data control module reset-Reset counter,11,
IDE08211,History data control module reset,|last cause of reset,Year,Month,Day,Hours,Minutes|Analysis 1,2000,1,1,0,0|Analysis 1,2000,1,1,0,0|Analysis 1,2000,1,1,0,0|Analysis 1,2000,1,1,0,0|Analysis 1,2000,1,1,0,0|Analysis 1,2000,1,1,0,0|uC_fes_SelfTestCompleted,2000,1,1,0,3|Analysis 1,2000,1,1,0,0|Analysis 1,2000,1,1,0,0|Analysis 1,2000,1,1,0,0|Analysis 1,255,2255,2255,2255,2255|,
IDE08949-MAS07867,Operating current: light driver-Conn. pin 0,not coded/not installed,
IDE08949-MAS07868,Operating current: light driver-Conn. pin 1,not coded/not installed,
IDE08949-MAS07869,Operating current: light driver-Conn. pin 2,not coded/not installed,
IDE08949-MAS07870,Operating current: light driver-Conn. pin 3,not coded/not installed,
IDE08949-MAS07871,Operating current: light driver-Conn. pin 4,not coded/not installed,
IDE08949-MAS07872,Operating current: light driver-Conn. pin 5,not coded/not installed,
IDE08949-MAS07873,Operating current: light driver-Conn. pin 6,not coded/not installed,
IDE08949-MAS07874,Operating current: light driver-Conn. pin 7,not coded/not installed,
IDE08949-MAS07875,Operating current: light driver-Conn. pin 8,not coded/not installed,
IDE08949-MAS07876,Operating current: light driver-Conn. pin 9,not coded/not installed,
IDE08949-MAS07877,Operating current: light driver-Conn. pin 10,not coded/not installed,
IDE08949-MAS07878,Operating current: light driver-Conn. pin 11,not coded/not installed,
IDE08949-MAS07879,Operating current: light driver-Conn. pin 12,not coded/not installed,
IDE08949-MAS07880,Operating current: light driver-Conn. pin 13,not coded/not installed,
IDE08949-MAS07881,Operating current: light driver-Conn. pin 14,not coded/not installed,
IDE08949-MAS07882,Operating current: light driver-Conn. pin 15,not coded/not installed,
IDE08949-MAS07883,Operating current: light driver-Conn. pin 16,not coded/not installed,
IDE08949-MAS07884,Operating current: light driver-Conn. pin 17,not coded/not installed,
IDE08949-MAS07886,Operating current: light driver-Conn. pin 19,15, mA
IDE08949-MAS07887,Operating current: light driver-Conn. pin 20,135, mA
IDE08949-MAS07888,Operating current: light driver-Conn. pin 21,145, mA
IDE08949-MAS07889,Operating current: light driver-Conn. pin 22,225, mA
IDE08949-MAS07890,Operating current: light driver-Conn. pin 23,15, mA
IDE08949-MAS07891,Operating current: light driver-Conn. pin 24,0, mA
IDE08949-MAS07892,Operating current: light driver-Conn. pin 25,0, mA
IDE08949-MAS07894,Operating current: light driver-Conn. pin 27,not coded/not installed,
IDE08949-MAS07895,Operating current: light driver-Conn. pin 28,15, mA
IDE08949-MAS07897,Operating current: light driver-Conn. pin 30,0, mA
IDE08949-MAS07898,Operating current: light driver-Conn. pin 31,4, mA
IDE08949-MAS07899,Operating current: light driver-Conn. pin 32,4, mA
IDE08949-MAS07900,Operating current: light driver-Conn. pin 33,4, mA
IDE08949-MAS07901,Operating current: light driver-Conn. pin 34,4, mA
IDE08949-MAS20146,Operating current: light driver-Conn. pin 35,not coded/not installed,
IDE08949-MAS20147,Operating current: light driver-Conn. pin 36,not coded/not installed,
IDE08949-MAS20148,Operating current: light driver-Conn. pin 37,not coded/not installed,
IDE08949-MAS20149,Operating current: light driver-Conn. pin 38,not coded/not installed,
IDE08949-MAS20150,Operating current: light driver-Conn. pin 39,not coded/not installed,
IDE08949-MAS20151,Operating current: light driver-Conn. pin 40,30, mA
IDE08949-MAS20152,Operating current: light driver-Conn. pin 41,22, mA
IDE08949-MAS21233,Operating current: light driver-Conn. pin 42,not coded/not installed,
IDE08949-MAS21234,Operating current: light driver-Conn. pin 43,not coded/not installed,
IDE08949-MAS21235,Operating current: light driver-Conn. pin 45,0, mA
IDE08949-MAS21236,Operating current: light driver-Conn. pin 44,70, mA
IDE10300,OBD Driving Cycle detected,not active,
IDE10345-IDE00673,Roof electronics control module: button-Information Service Button -E450-,Not operated,
IDE10345-MAS08884,Roof electronics control module: button-Sunroof button,Not operated,
IDE10345-MAS08932,Roof electronics control module: button-Sunroof shade button,Not operated,
IDE10345-MAS10417,Roof electronics control module: button-Door contact switching button,Not operated,
IDE10345-MAS10426,Roof electronics control module: button-Roadside Assistance Button,Not operated,
IDE11350-MAS12597,Sunlight photo sensor-Sun intensity left,50, W/m²
IDE11350-MAS12598,Sunlight photo sensor-Sun intensity right,25, W/m²
IDE11551-MAS03619,Status of identification data query on LIN-Bus-complete,Yes,
IDE11551-MAS11095,Status of identification data query on LIN-Bus-Cause,Terminal 15 on,
IDE11551-MAS12667,Status of identification data query on LIN-Bus-Specified installation of sub-bus users,10,
IDE11551-MAS12668,Status of identification data query on LIN-Bus-Actual installation of sub-bus users,11,
IDE11551-ENG303032,Status of identification data query on LIN-Bus-complete_config_hash,Yes,
IDE11551-ENG303033,Status of identification data query on LIN-Bus-complete_programming_hash,Yes,
IDE11551-ENG303064,Status of identification data query on LIN-Bus-slave_hash_valid,Yes,
IDE12940-IDE01268,Lever functions of the steering column electronics-Windshield wiper,not coded/not installed,
IDE12940-IDE02335,Lever functions of the steering column electronics-Signal light switch position,not coded/not installed,
IDE12940-IDE02711,Lever functions of the steering column electronics-Rear wiper,not coded/not installed,
IDE12940-MAS00232,Lever functions of the steering column electronics-MFI button UP,not coded/not installed,
IDE12940-MAS00233,Lever functions of the steering column electronics-MFI button DOWN,not coded/not installed,
IDE12940-MAS00234,Lever functions of the steering column electronics-MFI button RESET / OK,not coded/not installed,
IDE12940-MAS00242,Lever functions of the steering column electronics-Driver assistance systems button,not coded/not installed,
IDE12940-MAS00243,Lever functions of the steering column electronics-Buttons for driver assistance systems: status,not coded/not installed,
IDE12940-MAS01288,Lever functions of the steering column electronics-Horn,not coded/not installed,
IDE12940-MAS02338,Lever functions of the steering column electronics-Windshield wiper: intermittent stage,not coded/not installed,
IDE12940-MAS02339,Lever functions of the steering column electronics-Windshield washer system,not coded/not installed,
IDE12940-MAS02341,Lever functions of the steering column electronics-Rear window washer system,not coded/not installed,
IDE12940,Lever functions of the steering column electronics,not coded/not installed,
IDE13750-IDE02572,Input signals: control of terminal-Starter button: status,not active,
IDE13750-IDE13954,Input signals: control of terminal-Starter button: status redundant,not active,
IDE13751-IDE00020,Output signals: control of terminal-Terminal 15 status,active,
IDE13751-ENG256402,Output signals: control of terminal-Status_Terminal_Startwunsch_BCM,not active,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-ENG256401,Key position replication: input signals-Status_terminal_15_SOK,OFF,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE14238-MAS02282,Wiper arm position-Position,0.0, °
IDE14238-MAS19580,Wiper arm position-Alternating park position,Alternating park position 1,
IDE14328-MAS19447,Back flash safety version of software blocks-Versioning,01,
IDE14328,Back flash safety version of software blocks,|Rear flash protection: minimal version,Rear flash protection: current version|0002,0002|0002,0002|,|0001,0001|,|,|,|,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Invalid status,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,05 30 32 30 30 30 32 30,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Invalid status,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,7,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 32,
IDE14958-SFT00002,Recognized actual fitting list: adapt-Transmission Electronics,not detected,
IDE14958-SFT00005,Recognized actual fitting list: adapt-Access/start authorization,not detected,
IDE14958-SFT00006,Recognized actual fitting list: adapt-Seat adjustment: passenger's side,not detected,
IDE14958-SFT00008,Recognized actual fitting list: adapt-Climate Control Module,detected,
IDE14958-SFT00023,Recognized actual fitting list: adapt-Instrument cluster,not detected,
IDE14958-SFT00025,Recognized actual fitting list: adapt-Data Bus OBD Interface,detected,
IDE14958-SFT00038,Recognized actual fitting list: adapt-Convertible top operation,not detected,
IDE14958-SFT00043,Recognized actual fitting list: adapt-Steering column lock,not detected,
IDE14958-SFT00054,Recognized actual fitting list: adapt-Seat adjustment: driver side,not detected,
IDE14958-SFT00061,Recognized actual fitting list: adapt-Special Function,not detected,
IDE14958-SFT00096,Recognized actual fitting list: adapt-Trip recorder,not detected,
IDE14958-SFT00105,Recognized actual fitting list: adapt-Trailer Function,not detected,
IDE14958-SFT00106,Recognized actual fitting list: adapt-Automatic door: rear driver side,detected,
IDE14958-SFT00109,Recognized actual fitting list: adapt-Rear lid electronics,not detected,
IDE14958-SFT00122,Recognized actual fitting list: adapt-Automatic door: rear passenger side,detected,
IDE14958-SFT00165,Recognized actual fitting list: adapt-Front sensor for drivers assistant systems,not detected,
IDE14958-SFT00202,Recognized actual fitting list: adapt-Sunroof control module,not detected,
IDE14958-SFT00214,Recognized actual fitting list: adapt-Light Control Left 2,not detected,
IDE14958-SFT00215,Recognized actual fitting list: adapt-Light Control Right 2,not detected,
IDE14958-SFT33031,Recognized actual fitting list: adapt-Antenna module,not detected,
IDE14958-SFT33054,Recognized actual fitting list: adapt-Burglary Protection Control Module FL,not detected,
IDE14958-SFT33055,Recognized actual fitting list: adapt-Burglary Protection Control Module FR,not detected,
IDE14958-SFT33056,Recognized actual fitting list: adapt-Burglary Protection Control Module RL,not detected,
IDE14958-SFT33057,Recognized actual fitting list: adapt-Burglary Protection Control Module RR,not detected,
IDE14958-SFT33058,Recognized actual fitting list: adapt-Burglary Protection Control Module interior,not detected,
IDE14958-SFT271890,Recognized actual fitting list: adapt-Driver door control module,not detected,
IDE14958-SFT271891,Recognized actual fitting list: adapt-Front passenger door control module,not detected,
IDE14958-SFT271948,Recognized actual fitting list: adapt-Rear Driver Side Door Control Module,not detected,
IDE14958-SFT271949,Recognized actual fitting list: adapt-Rear Passenger Door Control Module,not detected,
IDE14958-SFT272107,Recognized actual fitting list: adapt-Antenna for short-range communication,not detected,
IDE14958-SFT272139,Recognized actual fitting list: adapt-Antenna 2 for short-range communication,not detected,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 00,
IDE14993,Software composition list identification data,|Software Composition ID,System designation,Supplier ID,VW/Audi part number,Primary version number,Secondary version number,Patch version number|00 00 00 00 00 00 00 00,,Unknown (0),,,,|,
IDE15364-MAS20454,Historical memory: coolant defect display-Frequency counter: absolute,11,
IDE15364,Historical memory: coolant defect display,|Frequency Counter,Odometer reading,Year,Month,Day,Hour,Minute|0,0,2000,0,0,0,0|0,0,2000,0,0,0,0|0,0,2000,0,0,0,0|0,0,2000,0,0,0,0|0,0,2000,0,0,0,0|, min
IDE15417-MAS06904,Predictive brake pad wear indicator-Brake lining wear warning,not active,
IDE15417-MAS20562,Predictive brake pad wear indicator-Relative kilometer status,0, km
IDE15417-MAS20563,Predictive brake pad wear indicator-Remaining kilometers until warning light turns on,0, km
IDE15417-MAS20564,Predictive brake pad wear indicator-Kilometers since wear sensor was disconnected,0, km
IDE15417,Predictive brake pad wear indicator,not installed,
IDE17551-ENG298469,Rear driver's side sliding door status: second block-Sliding_Door_Inside_actuate_Button,Not operated,
IDE17551-ENG249501,Rear driver's side sliding door status: second block-Sliding_Door_Inside_Close_Release_Button,Not operated,
IDE17552-ENG298469,Rear passenger's side sliding door status: second block-Sliding_Door_Inside_actuate_Button,Not operated,
IDE17552-ENG249501,Rear passenger's side sliding door status: second block-Sliding_Door_Inside_Close_Release_Button,Not operated,
MAS00043-IDE00019,Terminal 30 power supply-Voltage terminal 30,14.85, V
MAS00043-IDE05835,Terminal 30 power supply-Supply voltage for central locking,14.85, V
MAS00043-IDE05967,Terminal 30 power supply-Voltage terminal 30 left,14.85, V
MAS00043-IDE05968,Terminal 30 power supply-Voltage terminal 30 right,14.85, V
MAS00043-IDE08734,Terminal 30 power supply-Supply voltage for anti-theft alarm system,5.00, V
MAS00464-MAS00110,Standard - ambient data 1-Minutes,28,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,17,
MAS12666-SFT271873,SubSystemNodeAddress of sub bus participant-Wiper motor control module,0x0001,
MAS12666-SFT271874,SubSystemNodeAddress of sub bus participant-Rain/Light Recognition Sensor,0x0002,
MAS12666-SFT271875,SubSystemNodeAddress of sub bus participant-Light switch,0x0003,
MAS12666-SFT271876,SubSystemNodeAddress of sub bus participant-Garage door opener control module,0x0004,
MAS12666-SFT271894,SubSystemNodeAddress of sub bus participant-Anti-theft alarm system sensor,0x0016,
MAS12666-SFT271896,SubSystemNodeAddress of sub bus participant-Alarm horn,0x0018,
MAS12666-SFT271909,SubSystemNodeAddress of sub bus participant-left tail lamp 1,0x0025,
MAS12666-SFT271910,SubSystemNodeAddress of sub bus participant-Roof electronics control module,0x0026,
MAS12666-SFT271947,SubSystemNodeAddress of sub bus participant-Humidity sensor: interior,0x004B,
MAS12666-SFT271948,SubSystemNodeAddress of sub bus participant-Rear Driver Side Door Control Module,0x004C,
MAS12666-SFT271949,SubSystemNodeAddress of sub bus participant-Rear Passenger Door Control Module,0x004D,
MAS12666-SFT271950,SubSystemNodeAddress of sub bus participant-Rear lid opener control module,0x004E,
MAS12666-SFT271966,SubSystemNodeAddress of sub bus participant-Left head area heater,0x005E,
MAS12666-SFT271967,SubSystemNodeAddress of sub bus participant-Right head area heater,0x005F,
MAS12666-SFT272009,SubSystemNodeAddress of sub bus participant-Steering Column Switch,0x0089,
MAS12666-SFT272014,SubSystemNodeAddress of sub bus participant-Control head for driving and comfort functions,0x008E,
MAS12666-SFT272057,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat driver side,0x00B9,
MAS12666-SFT272061,SubSystemNodeAddress of sub bus participant-Valve block 1 in front seat passenger side,0x00BD,
MAS12666-SFT272065,SubSystemNodeAddress of sub bus participant-Blower 1 for left front backrest,0x00C1,
MAS12666-SFT272067,SubSystemNodeAddress of sub bus participant-Blower 1 for left front seat cushion,0x00C3,
MAS12666-SFT272069,SubSystemNodeAddress of sub bus participant-Blower 1 for right front backrest,0x00C5,
MAS12666-SFT272071,SubSystemNodeAddress of sub bus participant-Blower 1 for right front seat cushion,0x00C7,
MAS12666-SFT272107,SubSystemNodeAddress of sub bus participant-Antenna for short-range communication,0x00EB,
MAS12666-SFT272121,SubSystemNodeAddress of sub bus participant-Control unit 2 for driving and convenience functions,0x00F9,
MAS12666-SFT272139,SubSystemNodeAddress of sub bus participant-Antenna 2 for short-range communication,0x010B,
MAS12666-SFT272142,SubSystemNodeAddress of sub bus participant-left tail lamp 2,0x010E,
MAS12666-SFT272143,SubSystemNodeAddress of sub bus participant-Right rear tail lamp 1,0x010F,
MAS12666-SFT272144,SubSystemNodeAddress of sub bus participant-Right rear tail lamp 2,0x0110,
MAS12666-SFT272221,SubSystemNodeAddress of sub bus participant-Radio receiver for remote start,0x015D,
MAS12666-SFT272238,SubSystemNodeAddress of sub bus participant-Wiper motor control unit 2,0x016E,
MAS12666-SFT272272,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear driver side,0x0190,
MAS12666-SFT272286,SubSystemNodeAddress of sub bus participant-Virtual pedal door opening: rear passenger side,0x019E,
MAS12667-SFT271873,Specified installation of sub-bus users-Wiper motor control module,available.,
MAS12667-SFT271874,Specified installation of sub-bus users-Rain/Light Recognition Sensor,available.,
MAS12667-SFT271875,Specified installation of sub-bus users-Light switch,available.,
MAS12667-SFT271876,Specified installation of sub-bus users-Garage door opener control module,Not available,
MAS12667-SFT271894,Specified installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12667-SFT271896,Specified installation of sub-bus users-Alarm horn,Not available,
MAS12667-SFT271909,Specified installation of sub-bus users-left tail lamp 1,Not available,
MAS12667-SFT271910,Specified installation of sub-bus users-Roof electronics control module,available.,
MAS12667-SFT271947,Specified installation of sub-bus users-Humidity sensor: interior,Not available,
MAS12667-SFT271948,Specified installation of sub-bus users-Rear Driver Side Door Control Module,available.,
MAS12667-SFT271949,Specified installation of sub-bus users-Rear Passenger Door Control Module,available.,
MAS12667-SFT271950,Specified installation of sub-bus users-Rear lid opener control module,Not available,
MAS12667-SFT271966,Specified installation of sub-bus users-Left head area heater,Not available,
MAS12667-SFT271967,Specified installation of sub-bus users-Right head area heater,Not available,
MAS12667-SFT272009,Specified installation of sub-bus users-Steering Column Switch,Not available,
MAS12667-SFT272014,Specified installation of sub-bus users-Control head for driving and comfort functions,available.,
MAS12667-SFT272057,Specified installation of sub-bus users-Valve block 1 in front seat driver side,available.,
MAS12667-SFT272061,Specified installation of sub-bus users-Valve block 1 in front seat passenger side,available.,
MAS12667-SFT272065,Specified installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12667-SFT272067,Specified installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12667-SFT272069,Specified installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12667-SFT272071,Specified installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12667-SFT272107,Specified installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12667-SFT272121,Specified installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12667-SFT272139,Specified installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12667-SFT272142,Specified installation of sub-bus users-left tail lamp 2,Not available,
MAS12667-SFT272143,Specified installation of sub-bus users-Right rear tail lamp 1,Not available,
MAS12667-SFT272144,Specified installation of sub-bus users-Right rear tail lamp 2,Not available,
MAS12667-SFT272221,Specified installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12667-SFT272238,Specified installation of sub-bus users-Wiper motor control unit 2,available.,
MAS12667-SFT272272,Specified installation of sub-bus users-Virtual pedal door opening: rear driver side,Not available,
MAS12667-SFT272286,Specified installation of sub-bus users-Virtual pedal door opening: rear passenger side,Not available,
MAS12668-SFT271873,Actual installation of sub-bus users-Wiper motor control module,available.,
MAS12668-SFT271874,Actual installation of sub-bus users-Rain/Light Recognition Sensor,available.,
MAS12668-SFT271875,Actual installation of sub-bus users-Light switch,available.,
MAS12668-SFT271876,Actual installation of sub-bus users-Garage door opener control module,Not available,
MAS12668-SFT271894,Actual installation of sub-bus users-Anti-theft alarm system sensor,Not available,
MAS12668-SFT271896,Actual installation of sub-bus users-Alarm horn,Not available,
MAS12668-SFT271909,Actual installation of sub-bus users-left tail lamp 1,Not available,
MAS12668-SFT271910,Actual installation of sub-bus users-Roof electronics control module,available.,
MAS12668-SFT271947,Actual installation of sub-bus users-Humidity sensor: interior,available.,
MAS12668-SFT271948,Actual installation of sub-bus users-Rear Driver Side Door Control Module,available.,
MAS12668-SFT271949,Actual installation of sub-bus users-Rear Passenger Door Control Module,available.,
MAS12668-SFT271950,Actual installation of sub-bus users-Rear lid opener control module,Not available,
MAS12668-SFT271966,Actual installation of sub-bus users-Left head area heater,Not available,
MAS12668-SFT271967,Actual installation of sub-bus users-Right head area heater,Not available,
MAS12668-SFT272009,Actual installation of sub-bus users-Steering Column Switch,Not available,
MAS12668-SFT272014,Actual installation of sub-bus users-Control head for driving and comfort functions,available.,
MAS12668-SFT272057,Actual installation of sub-bus users-Valve block 1 in front seat driver side,available.,
MAS12668-SFT272061,Actual installation of sub-bus users-Valve block 1 in front seat passenger side,available.,
MAS12668-SFT272065,Actual installation of sub-bus users-Blower 1 for left front backrest,Not available,
MAS12668-SFT272067,Actual installation of sub-bus users-Blower 1 for left front seat cushion,Not available,
MAS12668-SFT272069,Actual installation of sub-bus users-Blower 1 for right front backrest,Not available,
MAS12668-SFT272071,Actual installation of sub-bus users-Blower 1 for right front seat cushion,Not available,
MAS12668-SFT272107,Actual installation of sub-bus users-Antenna for short-range communication,Not available,
MAS12668-SFT272121,Actual installation of sub-bus users-Control unit 2 for driving and convenience functions,Not available,
MAS12668-SFT272139,Actual installation of sub-bus users-Antenna 2 for short-range communication,Not available,
MAS12668-SFT272142,Actual installation of sub-bus users-left tail lamp 2,Not available,
MAS12668-SFT272143,Actual installation of sub-bus users-Right rear tail lamp 1,Not available,
MAS12668-SFT272144,Actual installation of sub-bus users-Right rear tail lamp 2,Not available,
MAS12668-SFT272221,Actual installation of sub-bus users-Radio receiver for remote start,Not available,
MAS12668-SFT272238,Actual installation of sub-bus users-Wiper motor control unit 2,available.,
MAS12668-SFT272272,Actual installation of sub-bus users-Virtual pedal door opening: rear driver side,Not available,
MAS12668-SFT272286,Actual installation of sub-bus users-Virtual pedal door opening: rear passenger side,Not available,
MAS12669-SFT271873,Bus identification of sub-bus users-Wiper motor control module,Local data bus,
MAS12669-SFT271874,Bus identification of sub-bus users-Rain/Light Recognition Sensor,Local data bus,
MAS12669-SFT271875,Bus identification of sub-bus users-Light switch,Local data bus 11,
MAS12669-SFT271876,Bus identification of sub-bus users-Garage door opener control module,Local data bus 4,
MAS12669-SFT271894,Bus identification of sub-bus users-Anti-theft alarm system sensor,Local data bus 3,
MAS12669-SFT271896,Bus identification of sub-bus users-Alarm horn,Local data bus 2,
MAS12669-SFT271909,Bus identification of sub-bus users-left tail lamp 1,Local data bus 8,
MAS12669-SFT271910,Bus identification of sub-bus users-Roof electronics control module,Local data bus 3,
MAS12669-SFT271947,Bus identification of sub-bus users-Humidity sensor: interior,Local data bus,
MAS12669-SFT271948,Bus identification of sub-bus users-Rear Driver Side Door Control Module,Local data bus 12,
MAS12669-SFT271949,Bus identification of sub-bus users-Rear Passenger Door Control Module,Local data bus 12,
MAS12669-SFT271950,Bus identification of sub-bus users-Rear lid opener control module,Local data bus 8,
MAS12669-SFT271966,Bus identification of sub-bus users-Left head area heater,Local data bus 4,
MAS12669-SFT271967,Bus identification of sub-bus users-Right head area heater,Local data bus 4,
MAS12669-SFT272009,Bus identification of sub-bus users-Steering Column Switch,Local data bus 6,
MAS12669-SFT272014,Bus identification of sub-bus users-Control head for driving and comfort functions,Local data bus 11,
MAS12669-SFT272057,Bus identification of sub-bus users-Valve block 1 in front seat driver side,Local data bus 4,
MAS12669-SFT272061,Bus identification of sub-bus users-Valve block 1 in front seat passenger side,Local data bus 4,
MAS12669-SFT272065,Bus identification of sub-bus users-Blower 1 for left front backrest,Local data bus 4,
MAS12669-SFT272067,Bus identification of sub-bus users-Blower 1 for left front seat cushion,Local data bus 4,
MAS12669-SFT272069,Bus identification of sub-bus users-Blower 1 for right front backrest,Local data bus 4,
MAS12669-SFT272071,Bus identification of sub-bus users-Blower 1 for right front seat cushion,Local data bus 4,
MAS12669-SFT272107,Bus identification of sub-bus users-Antenna for short-range communication,Data bus subCAN 1,
MAS12669-SFT272121,Bus identification of sub-bus users-Control unit 2 for driving and convenience functions,Local data bus 11,
MAS12669-SFT272139,Bus identification of sub-bus users-Antenna 2 for short-range communication,Data bus subCAN 1,
MAS12669-SFT272142,Bus identification of sub-bus users-left tail lamp 2,Local data bus 8,
MAS12669-SFT272143,Bus identification of sub-bus users-Right rear tail lamp 1,Local data bus 8,
MAS12669-SFT272144,Bus identification of sub-bus users-Right rear tail lamp 2,Local data bus 8,
MAS12669-SFT272221,Bus identification of sub-bus users-Radio receiver for remote start,Local data bus 6,
MAS12669-SFT272238,Bus identification of sub-bus users-Wiper motor control unit 2,Local data bus,
MAS12669-SFT272272,Bus identification of sub-bus users-Virtual pedal door opening: rear driver side,Local data bus 4,
MAS12669-SFT272286,Bus identification of sub-bus users-Virtual pedal door opening: rear passenger side,Local data bus 4,
MAS13141,Test voltage,0.00, V
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 02 0E 00,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,3,
MAS18919-MAS17454,Engine hood contacts-Engine hood contact 2,not active,
MAS18919-MAS18918,Engine hood contacts-Engine hood contact 1,not active,
MAS25022,Anti-play: electronic child safety lock: counter status,not active,
MAS26259-ENG370528,Charging socket flap contact switch-Charging_flap_switch,closed,
ENG277599-IDE01651,ASIL_relevante_RDIDs-Status of adaptation,Adaptations have been changed,
ENG277599-IDE05319,ASIL_relevante_RDIDs-Adapted values/adaptation,5008,
ENG277599-MAS18508,ASIL_relevante_RDIDs-Number of nodes,7,
ENG277599-ENG352898,ASIL_relevante_RDIDs-RDID_2,2674,
ENG277599-ENG354790,ASIL_relevante_RDIDs-RDID_3,4579,
ENG277599-ENG356716,ASIL_relevante_RDIDs-RDID_4,4581,
ENG277599-ENG353343,ASIL_relevante_RDIDs-RDID_5,4157,
ENG277599-ENG354949,ASIL_relevante_RDIDs-RDID_6,4609,
ENG277599-ENG356274,ASIL_relevante_RDIDs-Status_3,Adaptations have been changed,
ENG277599-ENG352650,ASIL_relevante_RDIDs-Status_RDID_2,Adaptations have been changed,
ENG277599-ENG354936,ASIL_relevante_RDIDs-Status_RDID_4,Adaptations have been changed,
ENG277599-ENG355882,ASIL_relevante_RDIDs-Status_RDID_5,Adaptations have been changed,
ENG277599-ENG352419,ASIL_relevante_RDIDs-Status_RDID_6,Adaptations have been changed,
ENG117285-ENG115840,Cycle_Protection_Counter-general_cycle_protection_counter,2,
ENG117285-ENG124947,Cycle_Protection_Counter-last_wake_up,Pin A44 Klemme 15,
ENG281289-MAS06423,Dataset_download__rdids_changed_by_adaption-Data set ID,Write only channel,
ENG281289-ENG354946,Dataset_download__rdids_changed_by_adaption-dataset_id_10,Write only channel,
ENG281289-ENG355903,Dataset_download__rdids_changed_by_adaption-dataset_id_2,Write only channel,
ENG281289-ENG355486,Dataset_download__rdids_changed_by_adaption-dataset_id_3,Write only channel,
ENG281289-ENG355877,Dataset_download__rdids_changed_by_adaption-dataset_id_4,Write only channel,
ENG281289-ENG354005,Dataset_download__rdids_changed_by_adaption-dataset_id_5,Write only channel,
ENG281289-ENG354629,Dataset_download__rdids_changed_by_adaption-dataset_id_6,Write only channel,
ENG281289-ENG354338,Dataset_download__rdids_changed_by_adaption-dataset_id_7,Write only channel,
ENG281289-ENG351859,Dataset_download__rdids_changed_by_adaption-dataset_id_8,Write only channel,
ENG281289-ENG356970,Dataset_download__rdids_changed_by_adaption-dataset_id_9,Write only channel,
ENG116908-ENG115775,Ecu_Intern_Meas._Values_2-Hours_of_operation_front_window_wiper,0.8335, H
ENG116908-ENG115776,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_front_window_wiper,1400,
ENG116908-ENG115777,Ecu_Intern_Meas._Values_2-Number of_the_wisp_cycles_rear_window_wiper,0,
ENG116813,Entwicklermesswerte_CONTI,|KurzSchlussZaehler|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,02,
ENG179902-IDE06260,Function_On_Demand_Freischalt_ID_Status_Dev-ID number,10 02 0E 00,
ENG179902-MAS17839,Function_On_Demand_Freischalt_ID_Status_Dev-Number of functions which can be activated,3,
ENG179902-MAS17983,Function_On_Demand_Freischalt_ID_Status_Dev-Last state,not_active,
ENG179902,Function_On_Demand_Freischalt_ID_Status_Dev,|Authentication,Functions,Configuration,Preconditions met,Individualization characteristic,Cancellation,Release code for a SWaP function|Condition met,Not available,not OK,Condition met,valid,No,available.|Condition not met,Not available,not OK,Condition met,invalid,Yes,Not available|Condition met,Not available,not OK,Condition not met,invalid,Yes,Not available|Condition met,available.,OK,Condition not met,invalid,Yes,Not available|Condition not met,Not available,not OK,Condition not met,invalid,Yes,Not available|Condition met,Not available,not OK,Condition met,valid,Yes,available.|Condition not met,Not available,not OK,Condition met,invalid,Yes,Not available|Condition met,Not available,not OK,Condition not met,invalid,Yes,Not available|Condition met,Not available,not OK,Condition not met,invalid,Yes,Not available|Condition not met,Not available,not OK,Condition not met,invalid,Yes,Not available|Condition met,Not available,not OK,Condition met,valid,No,available.|,
ENG406183-ENG406311,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_AAG,01,
ENG406183-ENG406312,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_ACC,00,
ENG406183-ENG406313,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Airbag,00,
ENG406183-ENG406314,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_ASG,00,
ENG406183-ENG406315,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_BMCE,00,
ENG406183-ENG406316,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_DCDC,00,
ENG406183-ENG406317,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_EBKV,00,
ENG406183-ENG406318,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_ESC,00,
ENG406183-ENG406319,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Gateway,00,
ENG406183-ENG406320,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_HUD,00,
ENG406183-ENG406321,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_IID_FID,00,
ENG406183-ENG406322,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_iSMLS,00,
ENG406183-ENG406323,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_KFG,00,
ENG406183-ENG406324,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_LE1,00,
ENG406183-ENG406325,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_LE2,00,
ENG406183-ENG406326,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_LED_LM_L,01,
ENG406183-ENG406327,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_LED_LM_R,01,
ENG406183-ENG406328,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Lenkung,01,
ENG406183-ENG406329,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_MFK,00,
ENG406183-ENG406330,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_MFL,00,
ENG406183-ENG406331,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_OCC_OCDC,00,
ENG406183-ENG406332,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_PDC,00,
ENG406183-ENG406333,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_SAM,07,
ENG406183-ENG406334,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Sitz_FS,01,
ENG406183-ENG406335,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Sitz_HBFS,01,
ENG406183-ENG406336,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_Sitz_HFS,01,
ENG406183-ENG406337,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_SitzBFS,01,
ENG406183-ENG406338,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_STSG_HBFS,00,
ENG406183-ENG406339,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_STSG_HFS,00,
ENG406183-ENG406340,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_TsgBFS,00,
ENG406183-ENG406341,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_TsgFS,00,
ENG406183-ENG406342,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_TsgHBFS,00,
ENG406183-ENG406343,Kampagnen_ergebnisse_G1_ECU_Data_Summary-ORUGuard1_G1_Summary_TsgHFS,00,
ENG310456-IDE10283,key_fob-Key identification: transponder ID,4D D5 87 B1,
ENG310456-ENG331600,key_fob-key_fob_battery_level,2.77, V
ENG310456-ENG331607,key_fob-key_fob_button,no_UHF_message,
ENG310456-ENG331605,key_fob-key_fob_error_state,no_UHF_message,
ENG310456-ENG331606,key_fob-key_fob_number,Key_fob_2,
ENG310456-ENG331603,key_fob-LF_range_limitation,Unknown (12),
ENG310456-ENG331601,key_fob-number_of_adapted_key_fobs,2,
ENG310456-ENG331602,key_fob-rolling_code_synchronisation,no_UHF_message,
ENG116909-ENG107391,LIN activity-LIN 1,Communication,
ENG116909-ENG256023,LIN activity-LIN 10,Communication,
ENG116909-ENG256024,LIN activity-LIN 11,Communication,
ENG116909-ENG256025,LIN activity-LIN 12,Communication,
ENG116909-ENG256026,LIN activity-LIN 13,not coded/not installed,
ENG116909-ENG256027,LIN activity-LIN 14,not coded/not installed,
ENG116909-ENG107392,LIN activity-LIN 2,not coded/not installed,
ENG116909-ENG114948,LIN activity-LIN 3,Communication,
ENG116909-ENG114949,LIN activity-LIN 4,Communication,
ENG116909-ENG114950,LIN activity-LIN 5,Communication,
ENG116909-ENG114951,LIN activity-LIN 6,Bus sleep mode,
ENG116909-ENG256030,LIN activity-LIN 7,not coded/not installed,
ENG116909-ENG256031,LIN activity-LIN 8,not coded/not installed,
ENG116909-ENG256032,LIN activity-LIN 9,Communication,
ENG122922-ENG121684,misc_wiper_values_1-wiper_counter_block,0,
ENG122922-ENG121680,misc_wiper_values_1-wiper_counter_cycles,1400,
ENG122922-ENG121681,misc_wiper_values_1-wiper_counter_operating_h,47.6762, H
ENG122922-ENG121682,misc_wiper_values_1-wiper_errors,00000000 00000000 ,
ENG122922-ENG121683,misc_wiper_values_1-wiper_speed_real,40, /min
ENG122924-ENG115787,misc_wiper_values_2-wiper_angle,655.17, °
ENG122924-ENG115788,misc_wiper_values_2-wiper_angle_corr_OWL,0.00, °
ENG122924-ENG115789,misc_wiper_values_2-wiper_angle_corr_UWL,655.17, °
ENG122924-ENG115790,misc_wiper_values_2-wiper_power_supply_Ubat,15.05, V
ENG116793,Monitor 1,FF FF FF FF FF FF FF FF,
ENG116802,Monitor 10,FF FF FF FF FF FF FF FF,
ENG116794,Monitor 2,FF FF FF FF FF FF FF FF,
ENG116795,Monitor 3,FF FF FF FF FF FF FF FF,
ENG116796,Monitor 4,FF FF FF FF FF FF FF FF,
ENG116797,Monitor 5,FF FF FF FF FF FF FF FF,
ENG116798,Monitor 6,FF FF FF FF FF FF FF FF,
ENG116799,Monitor 7,FF FF FF FF FF FF FF FF,
ENG116800,Monitor 8,FF FF FF FF FF FF FF FF,
ENG116801,Monitor 9,FF FF FF FF FF FF FF FF,
ENG116792,Power up history,|Funktionsanforderung|1|1|1|1|1|0|1|1|1|1|,
ENG254813,Set_value_for_headlight_range_controls_regulating_unit,Initialization,
ENG122923-ENG115672,shadow_error_table-wiper_error_1_code,51,
ENG122923-ENG115673,shadow_error_table-wiper_error_1_count,17,
ENG122923-ENG115677,shadow_error_table-wiper_error_1_data_ec4,255,
ENG122923-ENG115678,shadow_error_table-wiper_error_1_data_ec5,0,
ENG122923-ENG115676,shadow_error_table-wiper_error_1_power_supply,12.8, V
ENG122923-ENG115675,shadow_error_table-wiper_error_1_temp,15, °C
ENG122923-ENG115674,shadow_error_table-wiper_error_1_timestamp,46.4814, min
ENG122923-ENG256664,shadow_error_table-wiper_error_10_code,0,
ENG122923-ENG256665,shadow_error_table-wiper_error_10_count,0,
ENG122923-ENG256666,shadow_error_table-wiper_error_10_data_ec4,0,
ENG122923-ENG256667,shadow_error_table-wiper_error_10_data_ec5,0,
ENG122923-ENG256668,shadow_error_table-wiper_error_10_power_supply,0.0, V
ENG122923-ENG256669,shadow_error_table-wiper_error_10_temp,0, °C
ENG122923-ENG256671,shadow_error_table-wiper_error_10_timestamp,0.0000, min
ENG122923-ENG115679,shadow_error_table-wiper_error_2_code,34,
ENG122923-ENG115680,shadow_error_table-wiper_error_2_count,1,
ENG122923-ENG115684,shadow_error_table-wiper_error_2_data_ec4,64,
ENG122923-ENG115685,shadow_error_table-wiper_error_2_data_ec5,12,
ENG122923-ENG115683,shadow_error_table-wiper_error_2_power_supply,13.7, V
ENG122923-ENG115682,shadow_error_table-wiper_error_2_temp,16, °C
ENG122923-ENG115681,shadow_error_table-wiper_error_2_timestamp,9.3296, min
ENG122923-ENG115686,shadow_error_table-wiper_error_3_code,39,
ENG122923-ENG115687,shadow_error_table-wiper_error_3_count,1,
ENG122923-ENG115691,shadow_error_table-wiper_error_3_data_ec4,6,
ENG122923-ENG115692,shadow_error_table-wiper_error_3_data_ec5,9,
ENG122923-ENG115690,shadow_error_table-wiper_error_3_power_supply,14.6, V
ENG122923-ENG115689,shadow_error_table-wiper_error_3_temp,20, °C
ENG122923-ENG115688,shadow_error_table-wiper_error_3_timestamp,6.9972, min
ENG122923-ENG115693,shadow_error_table-wiper_error_4_code,38,
ENG122923-ENG115694,shadow_error_table-wiper_error_4_count,1,
ENG122923-ENG115698,shadow_error_table-wiper_error_4_data_ec4,6,
ENG122923-ENG115699,shadow_error_table-wiper_error_4_data_ec5,1,
ENG122923-ENG115697,shadow_error_table-wiper_error_4_power_supply,14.6, V
ENG122923-ENG115695,shadow_error_table-wiper_error_4_temp,21, °C
ENG122923-ENG115696,shadow_error_table-wiper_error_4_timestamp,6.9972, min
ENG122923-ENG115700,shadow_error_table-wiper_error_5_code,25,
ENG122923-ENG115701,shadow_error_table-wiper_error_5_count,1,
ENG122923-ENG115705,shadow_error_table-wiper_error_5_data_ec4,7,
ENG122923-ENG115706,shadow_error_table-wiper_error_5_data_ec5,0,
ENG122923-ENG115704,shadow_error_table-wiper_error_5_power_supply,12.2, V
ENG122923-ENG115703,shadow_error_table-wiper_error_5_temp,15, °C
ENG122923-ENG115702,shadow_error_table-wiper_error_5_timestamp,0.6664, min
ENG122923-ENG256676,shadow_error_table-wiper_error_6_code,47,
ENG122923-ENG256677,shadow_error_table-wiper_error_6_count,1,
ENG122923-ENG256678,shadow_error_table-wiper_error_6_data_ec4,1,
ENG122923-ENG256679,shadow_error_table-wiper_error_6_data_ec5,0,
ENG122923-ENG256680,shadow_error_table-wiper_error_6_power_supply,12.6, V
ENG122923-ENG256681,shadow_error_table-wiper_error_6_temp,18, °C
ENG122923-ENG256683,shadow_error_table-wiper_error_6_timestamp,0.0000, min
ENG122923-ENG256684,shadow_error_table-wiper_error_7_code,31,
ENG122923-ENG256685,shadow_error_table-wiper_error_7_count,1,
ENG122923-ENG256686,shadow_error_table-wiper_error_7_data_ec4,64,
ENG122923-ENG256687,shadow_error_table-wiper_error_7_data_ec5,255,
ENG122923-ENG256688,shadow_error_table-wiper_error_7_power_supply,12.6, V
ENG122923-ENG256689,shadow_error_table-wiper_error_7_temp,11, °C
ENG122923-ENG256691,shadow_error_table-wiper_error_7_timestamp,0.0000, min
ENG122923-ENG256692,shadow_error_table-wiper_error_8_code,0,
ENG122923-ENG256693,shadow_error_table-wiper_error_8_count,0,
ENG122923-ENG256694,shadow_error_table-wiper_error_8_data_ec4,0,
ENG122923-ENG256695,shadow_error_table-wiper_error_8_data_ec5,0,
ENG122923-ENG256696,shadow_error_table-wiper_error_8_power_supply,0.0, V
ENG122923-ENG256697,shadow_error_table-wiper_error_8_temp,0, °C
ENG122923-ENG256699,shadow_error_table-wiper_error_8_timestamp,0.0000, min
ENG122923-ENG256700,shadow_error_table-wiper_error_9_code,0,
ENG122923-ENG256701,shadow_error_table-wiper_error_9_count,0,
ENG122923-ENG256702,shadow_error_table-wiper_error_9_data_ec4,0,
ENG122923-ENG256703,shadow_error_table-wiper_error_9_data_ec5,0,
ENG122923-ENG256704,shadow_error_table-wiper_error_9_power_supply,0.0, V
ENG122923-ENG256705,shadow_error_table-wiper_error_9_temp,0, °C
ENG122923-ENG256707,shadow_error_table-wiper_error_9_timestamp,0.0000, min
ENG250298-IDE00104,Specific_ambient_conditions-DTC,00 00 00,
ENG250298-IDE07836,Specific_ambient_conditions-Log data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG406204-ENG406303,Sperrzustand_ORU_Guard_1_G1_Fixation_State-ORUGuard1_G1_FixationState,Idle,
ENG406205-ENG406306,Status_Metadaten_ORU_Guard_1_G1_MetaDataState-ORUGuard1_G1_Metadata_State,Initial value,
ENG254825,steuergeraetinterne_Messwert,00 01 00 01 03 20 15 01 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 04 00 00 00 00 00 00 00 00 00 00 00 40 00 0A 00 00 00 00 04 00 00 00 00 12 01 00 00 01 00 00 00 E5 C0 00 00 40 11 00 30 38 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0D 00 00 00 02 04 00 00 00 02 E2 0F 05 7F E2 11 1C E7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 00 02 4C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 02 3F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG116790-MAS00711,Supply voltage history-Odometer reading,24, km
ENG116790-ENG115814,Supply voltage history-highest voltage ever measured,15.3, V
ENG116790-ENG115815,Supply voltage history-hoechste im letzten Fahrzyklus gemessen Batteriespannung,14.9, V
ENG116790-ENG115816,Supply voltage history-voltage measurement: intern,5.0, V
ENG122921-ENG121628,values_motorloads-mod_temp_fast,14, °C
ENG122921-ENG121627,values_motorloads-mod_temp_slow,19, °C
ENG122921-ENG121629,values_motorloads-temp_pcb,14, °C
ENG122921-ENG121631,values_motorloads-wiper_energymodel_load,0,
ENG122921-ENG121632,values_motorloads-wiper_energymodel_status,0,
ENG122921-ENG121633,values_motorloads-wiper_power_supply_PWM,0, %
ENG122921-ENG121630,values_motorloads-wiper_thermomodel_status,0,
ENG117315-ENG163906,Window_Regulator_Driver_Side_Rear_VW_Workshop_System_Name-System_short_sign,J326 ,
ENG117316-ENG163906,Window_Regulator_Passenger_Side_Rear_VW_Workshop_System_Name-System_short_sign,J327 ,
ENG254854-ENG161480,Wischer_Flash_Historie-Betriebsstundenzaehler_1,0.000000, s
ENG254854-ENG161481,Wischer_Flash_Historie-Betriebsstundenzaehler_2,0.000000, s
ENG254854-ENG161482,Wischer_Flash_Historie-Betriebsstundenzaehler_3,0.000000, s
ENG254854-ENG161483,Wischer_Flash_Historie-Betriebsstundenzaehler_4,0.000000, s
ENG254854-ENG161484,Wischer_Flash_Historie-Betriebsstundenzaehler_5,0.000000, s
ENG254854-ENG162659,Wischer_Flash_Historie-geflashte_SW_Version_2,0,
ENG254854-ENG162660,Wischer_Flash_Historie-geflashte_SW_Version_3,0,
ENG254854-ENG162661,Wischer_Flash_Historie-geflashte_SW_Version_4,0,
ENG254854-ENG162662,Wischer_Flash_Historie-geflashte_SW_Version_5,0,
ENG254854-ENG162663,Wischer_Flash_Historie-geflashte_SW_Version1,0,
ENG254854-ENG163410,Wischer_Flash_Historie-Programmierdatum_1_Jahr,0,
ENG254854-ENG163411,Wischer_Flash_Historie-Programmierdatum_1_Monat,0,
ENG254854-ENG163412,Wischer_Flash_Historie-Programmierdatum_1_Tag,0,
ENG254854-ENG163413,Wischer_Flash_Historie-Programmierdatum_2_Jahr,0,
ENG254854-ENG163414,Wischer_Flash_Historie-Programmierdatum_2_Monat,0,
ENG254854-ENG163415,Wischer_Flash_Historie-Programmierdatum_2_Tag,0,
ENG254854-ENG163416,Wischer_Flash_Historie-Programmierdatum_3_Jahr,0,
ENG254854-ENG163417,Wischer_Flash_Historie-Programmierdatum_3_Monat,0,
ENG254854-ENG163418,Wischer_Flash_Historie-Programmierdatum_3_Tag,0,
ENG254854-ENG163419,Wischer_Flash_Historie-Programmierdatum_4_Jahr,0,
ENG254854-ENG163420,Wischer_Flash_Historie-Programmierdatum_4_Monat,0,
ENG254854-ENG163421,Wischer_Flash_Historie-Programmierdatum_4_Tag,0,
ENG254854-ENG163422,Wischer_Flash_Historie-Programmierdatum_5_Jahr,0,
ENG254854-ENG163423,Wischer_Flash_Historie-Programmierdatum_5_Monat,0,
ENG254854-ENG163424,Wischer_Flash_Historie-Programmierdatum_5_Tag,0,
ENG254854-ENG164205,Wischer_Flash_Historie-Tester_Seriennummer_1,00 00 00 00 00 00,
ENG254854-ENG164206,Wischer_Flash_Historie-Tester_Seriennummer_2,00 00 00 00 00 00,
ENG254854-ENG164207,Wischer_Flash_Historie-Tester_Seriennummer_3,00 00 00 00 00 00,
ENG254854-ENG164208,Wischer_Flash_Historie-Tester_Seriennummer_4,00 00 00 00 00 00,
ENG254854-ENG164209,Wischer_Flash_Historie-Tester_Seriennummer_5,00 00 00 00 00 00,
ENG254854-ENG164431,Wischer_Flash_Historie-Wischzyklenzaehler_1,0,
ENG254854-ENG164432,Wischer_Flash_Historie-Wischzyklenzaehler_2,0,
ENG254854-ENG164433,Wischer_Flash_Historie-Wischzyklenzaehler_3,0,
ENG254854-ENG164434,Wischer_Flash_Historie-Wischzyklenzaehler_4,0,
ENG254854-ENG164435,Wischer_Flash_Historie-Wischzyklenzaehler_5,0,
ENG133751-ENG124960,Wischermesswerte 1-aktuelle Schwelle (kalt oder warm),0,
ENG133751-ENG161419,Wischermesswerte 1-Anzahl Wischzyklen(aktueller Wert),1411,
ENG133751-ENG98439,Wischermesswerte 1-Battery voltage,15.0472, V
ENG133751-ENG124957,Wischermesswerte 1-Energiemodell Daten 1 gerechneter Wert,0,
ENG133751-ENG124958,Wischermesswerte 1-Energiemodell Daten 2 gerechneter Wert,0,
ENG133751-ENG124959,Wischermesswerte 1-Energiemodell Daten 3 gerechneter Wert,0,
ENG133751-ENG98786,Wischermesswerte 1-Engine angle,6553.3, °
ENG133751-ENG124964,Wischermesswerte 1-Motor PWM,0.000, %
ENG133751-ENG115795,Wischermesswerte 1-Operating Hours,171628.193, s
ENG133751-ENG115650,Wischermesswerte 1-PCB-Temperatur,67889.005, °C
ENG133751-ENG124961,Wischermesswerte 1-Schwellwert 'kalt',1347443310,
ENG133751-ENG124962,Wischermesswerte 1-Schwellwert 'warm',1687603450,
ENG133751-ENG147706,Wischermesswerte 1-Schwellwert zum loeschen,200,
ENG133751-ENG99062,Wischermesswerte 1-Wipe speed,0.00, /min
ENG133752-ENG124978,Wischermesswerte 2-aktuelle obere Wendelage,0.0, °
ENG133752-ENG124973,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Beifahrerseite,0.6210, °
ENG133752-ENG124972,Wischermesswerte 2-aktueller Wischwinkel des Wischerarmes Fahrerseite,0.5260, °
ENG133752-ENG255292,Wischermesswerte 2-aktueller_Motor_kurbelwinkel,6553.3, °
ENG133752-ENG124984,Wischermesswerte 2-Anstehende Wischmodus,51,
ENG133752-ENG124981,Wischermesswerte 2-Arbeitswinkel der Motorabtriebswelle bei Fehlereintritt,0.0, °
ENG133752-ENG147708,Wischermesswerte 2-Blockzaehler (Ueberlast),0,
ENG133752-ENG147709,Wischermesswerte 2-Fehlerzustaende (Errorstate),0,
ENG133752-ENG124982,Wischermesswerte 2-Funktion bei Fehlereintritt 1,0,
ENG133752-ENG124983,Wischermesswerte 2-Funktion bei Fehlereintritt 2,0,
ENG133752-ENG124976,Wischermesswerte 2-Ist-Wischgeschwindigkeit,0, /min
ENG133752-ENG124985,Wischermesswerte 2-Master-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG121977,Wischermesswerte 2-No. of wisher cycles,0,
ENG133752-ENG98396,Wischermesswerte 2-Operating time,167695.130, s
ENG133752-ENG124970,Wischermesswerte 2-OWL Obere Wendelage,156.9, °
ENG133752-ENG124986,Wischermesswerte 2-RLS-Botschaft,00 00 00 00 00 00 00 00,
ENG133752-ENG124975,Wischermesswerte 2-Soll-Wischgeschwindigkeit,0, /min
ENG133752-ENG99020,Wischermesswerte 2-Supply voltage,12.7968, V
ENG133752-ENG98969,Wischermesswerte 2-Temperature,15.038, °C
ENG133752-ENG124971,Wischermesswerte 2-UWL Untere Wendelage,18.3, °
ENG133743-ENG125002,Wischermesswerte 3-Chip number,00 00 00 00 00 00 00 00,
ENG133743-ENG255531,Wischermesswerte 3-Chip number Infineon,AD 85 E3 3F 7F D5 55 AE D5 76 DC A6,
ENG133743-ENG125000,Wischermesswerte 3-EOL number,30,
ENG133743-ENG125001,Wischermesswerte 3-Error state,0,
ENG133743-ENG124999,Wischermesswerte 3-ICT (NG) measurement value,0,
ENG133743-ENG124998,Wischermesswerte 3-ICT (OK) measurement value,0,
ENG133743-ENG98897,Wischermesswerte 3-Serial number,39 30 39 34 35 33 46 30 33 30 32 34 32 30 34 30 31 35 39 34,
ENG254856-ENG255353,WWS Historie-Anzahl Wischzyklen max MCU Temperatur,619,
ENG254856-ENG255354,WWS Historie-Anzahl Wischzyklen max. LIN Temperatur,4,
ENG254856-ENG255356,WWS Historie-Anzahl Wischzyklen max. UBatt,114,
ENG254856-ENG263779,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_0,13,
ENG254856-ENG263780,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_1,1161,
ENG254856-ENG263781,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_2,62,
ENG254856-ENG263782,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_3,36,
ENG254856-ENG263783,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_4,52,
ENG254856-ENG263784,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_5,24,
ENG254856-ENG263785,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_6,25,
ENG254856-ENG263786,WWS Historie-Anzahl_Wischzyklen_RS_Stufe_7,38,
ENG254856-ENG255393,WWS Historie-Betriebsstunden max MCU Temperatur,1199.061853, s
ENG254856-ENG255394,WWS Historie-Betriebsstunden max. LIN Temperatur,325.504176, s
ENG254856-ENG255396,WWS Historie-Betriebsstunden max. UBatt,736.810067, s
ENG254856-ENG289707,WWS Historie-extern_Temp,0, °C
ENG254856-ENG255812,WWS Historie-Kl_15_Zyklenzaehler,301,
ENG254856-ENG255813,WWS Historie-Kl_X_Zyklenzaehler,5,
ENG254856-ENG289722,WWS Historie-LIN_Signal_max_Exterior_Temp,-111, °C
ENG254856-ENG289704,WWS Historie-max_Intern_Temp,99, °C
ENG254856-ENG256046,WWS Historie-max_power_supply,15.4, V
ENG254856-ENG256320,WWS Historie-Sleep_Counter,460,
ENG254856-ENG256640,WWS Historie-Wakeup_Counter,458,
ENG406211-ENG406296,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_DiagAddress,00 00,
ENG406211-ENG406297,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_HwPartNo,00 00 00 00 00 00 00 00 00 00 00,
ENG406211-ENG406298,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_HwVerNo,00 00 00,
ENG406211-ENG406299,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_IVDP,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG406211-ENG406300,Zielsteuergeraete_Informationen_G1_ECU_Data-ORUGuard1_G1_ECUData_SwVerNo,00 00 00 00,
ENG406212-ENG406304,Zustand_ORU_Guard_1_G1_State-ORUGuard1_G1_Guard_State,ready,
Elapsed Time: 00:50
Jef
HQ
blockmap-10-1EE-919-300-B_WVGAWVEB7SH010695-20241230-1131.CSV
;SW:1EE-919-300-B   HW:1EE-919-300 ---  Park/Steer Assist
;Component:RPA12K        H01 0630, Coding:0230026041
;EV_EPHBO3CVW4130000,001014,EV_EPHBO3CVW4130000_VWE4.rod
;Monday,30,December,2024,11:31:34:18177
;VCDS Version: Beta 24.12.0 (x64)  Data version: 20241120 DS361.3
;VCID: 3334C5377BB11882BE0-8066-R
Group,Description,Actual
IDE00018,Voltage terminal 15,14.5, V
IDE00957-MAS01632,Resulting distance of front sensors-Status,82, cm
IDE00958-MAS01632,Resulting distance of rear sensors-Status,38, cm
IDE00973,Outside temperature,12.50, °
IDE00974,Outside air temperature internally calculated,12.00, °
IDE01123-MAS01632,Distance of left rear park assist sensor-Status,188, cm
IDE01124-MAS01632,Distance of left rear center park assist sensors-Status,infinite,
IDE01125-MAS01632,Distance of right rear center park assist sensors-Status,127, cm
IDE01126-MAS01632,Distance of right rear park assist sensor-Status,infinite,
IDE01127-MAS01632,Distance sensor for left front park assist-Status,infinite,
IDE01128-MAS01632,Distance sensor for left front center park assist-Status,infinite,
IDE01129-MAS01632,Distance sensor for right front center park assist-Status,infinite,
IDE01130-MAS01632,Distance of right front park assist sensors-Status,infinite,
IDE01131-MAS01632,Oscillating time of left rear park assist sensors-Status,0.512, ms
IDE01132-MAS01632,Oscillating time of left rear center park assist sensors-Status,0.480, ms
IDE01133-MAS01632,Oscillating time of right rear center park assist sensors-Status,Malfunction,
IDE01134-MAS01632,Oscillating time of right rear park assist sensors-Status,0.512, ms
IDE01135-MAS01632,Decay time for left front park assist sensor-Status,0.480, ms
IDE01136-MAS01632,Decay time for left front center park assist sensor-Status,0.480, ms
IDE01137-MAS01632,Decay time for right front center park assist sensors-Status,0.480, ms
IDE01138-MAS01632,Decay time for right front park assist sensors-Status,Malfunction,
IDE01165,Park assist activation tone,OFF,
IDE01166,Supply voltage for park assist sensor,14.5, V
IDE01167,Convertible offset for volume level 1,1,
IDE01169,Audio lowering request,No,
IDE01175-MAS01632,Distance of side left rear parking aid sensors-Status,38, cm
IDE01176-MAS01632,Distance of side right rear parking aid sensors-Status,64, cm
IDE01177-MAS01632,Oscillating time of side left rear parking aid sensors-Status,0.560, ms
IDE01178-MAS01632,Oscillating time of side right rear parking aid sensors-Status,0.592, ms
IDE01185-MAS01632,Distance sensor for left front parking aid-Status,infinite,
IDE01186-MAS01632,Distance sensor for right front parking aid-Status,82, cm
IDE01187-MAS01632,Decay time for side left front parking aid sensor-Status,0.512, ms
IDE01188-MAS01632,Decay time for right side front parking aid sensor-Status,0.592, ms
IDE01588,Driving direction,not detected,
IDE03684,Vehicle stopped,Yes,
IDE07543,Vehicle speed,0.00, km/h
IDE11152-MAS12261,Wheel circumferences-Right front wheel circumference,896, mm
IDE11152-MAS12262,Wheel circumferences-Left front wheel circumference,1997, mm
IDE11152-MAS12263,Wheel circumferences-Right rear wheel circumference,0, mm
IDE11152-MAS12264,Wheel circumferences-Left rear wheel circumference,115, mm
IDE12038,Brake requirements (ring buffer),|Year,Month,Day,Hours,Minutes,Seconds,Brake pressure,Brake electronics fault,Vehicle speed,Accelerator pedal position,Object horizontal position,Object vertical position|2000,0,0,0,0,0,0,Initialization,-20.0,0,-5.0,-5.0|2000,0,0,0,0,0,0,Initialization,-20.0,0,-5.0,-5.0|2000,0,0,0,0,0,0,Initialization,-20.0,0,-5.0,-5.0|2000,0,0,0,0,0,0,Initialization,-20.0,0,-5.0,-5.0|2000,0,0,0,0,0,0,Initialization,-20.0,0,-5.0,-5.0|, m
IDE13546,Remote controlled parking: ID of the connected device,0,
IDE13574,remote-controlled parking: X coordinate of request,0,
IDE13575,remote-controlled parking: Y coordinate of request,0,
IDE13576,remote controlled parking: status of the authentication,0,
IDE13577,remote control parking: inverse drive request,0,
IDE13579,remote control parking: driver request,0,
IDE13580,remote control parking: status of the stored devices,0,
IDE17906,Park Assist with remote control: touch screen diagnostics status,0,
IDE17907,Park Assist with remote control: function status,0,
IDE17908,Smartphone connection components: main version,0,
IDE17909,Smartphone connection components: ancillary version,0,
IDE17910,Data record: main version,0,
IDE17911,Data record: ancillary version,0,
IDE17912,Cause of malfunction at smartphone connection,0,
ENG377871-IDE18659,IPA_RPA_abort_ring_buffer-Intelligent parking assistant: reason for cancellation,|Year,Month,Day,Hours,Minutes,Seconds,Odometer reading,Delay management: system status,Malfunction type,Vehicle speed,Object horizontal position,Object vertical position,Cancellation reason,Malfunction source,Intelligent parking assistant: function status,Maneuvering parking steering assistance: function status|2000,0,0,0,0,0,0,Initialization,Message missing,-20.0,-5.0,-5.0,Steering intervention by the driver,Airbag_01,Not available,Maneuvering parking steering assistance: inactive|,
Elapsed Time: 00:04
blockmap-13-1EA-907-567-B_WVGAWVEB7SH010695-20241230-1131.CSV
;SW:1EA-907-567-B   HW:1EA-907-819 ---  Auto Dist. Reg
;Component:ARS512VW13    H05 0232, Coding:06230AE24071C04412574000008040052F4020000000000000000000000000
;EV_FRONTRADARCONTIVW310,004013,EV_FRONTRADARCONTIVW310_004_VWE3.rod
;Monday,30,December,2024,11:31:49:18177
;VCID: 3B24ED1753E1D0C2660-806E-R SFD
IDE00002,Transport mode,OFF,
IDE00019,Voltage terminal 30,14.8, V
IDE00102,Control Module temperature,31, °C
IDE00310,Outside temperature,12.5, °C
IDE00391,Adaptive distance regulation: status,ACC_StandBy,
IDE00924,Steering angle,2.300, °
IDE00925,Yaw rate,0.000, rad/s
IDE01268-MAS02506,Windshield wiper-Wiper active,not active,
IDE01794-ENG161032,ACC operating lever signal-ACC_main_switch,operated,
IDE01794-ENG255266,ACC operating lever signal-ACC_main_switch_status,On,
IDE01794-ENG98480,ACC operating lever signal-Cancel,Not operated,
IDE01794-ENG161043,ACC operating lever signal-Control_lever_coding,ACC,
IDE01794-ENG161044,ACC operating lever signal-Control_lever_error,No malfunction,
IDE01794-ENG255629,ACC operating lever signal-distance_toggle,Not operated,
IDE01794-ENG161132,ACC operating lever signal-part_control_lever,control_lever_8_positions,
IDE01794-ENG159615,ACC operating lever signal-Resume,Not operated,
IDE01794-ENG98911,ACC operating lever signal-Set,Not operated,
IDE01794-ENG109453,ACC operating lever signal-TIP_DOWN,Not operated,
IDE01794-ENG256530,ACC operating lever signal-tip_level_button,Not operated,
IDE01794-ENG109454,ACC operating lever signal-TIP_UP,Not operated,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,BA C8 E5 51,
IDE02068-MAS00106,Time stamp-Year,2024,
IDE02068-MAS00107,Time stamp-Month,12,
IDE02068-MAS00108,Time stamp-Day,30,
IDE02068-MAS00109,Time stamp-Hours,16,
IDE02068-MAS00110,Time stamp-Minutes,31,
IDE02068-MAS00111,Time stamp-Seconds,47,
IDE03660,Longitudinal acceleration,0.00, m/s²
IDE04805-IDE02955,Driving profile selection-System status,Not available,
IDE04805-MAS01447,Driving profile selection-Act.val.,0,
IDE04805-MAS01448,Driving profile selection-Target value,1,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,07,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS09609,Component protection properties-Status IKA start key,Unknown (128),
IDE08343,Immobilizer Challenge,DA 24 48 32,
IDE08936,Misalignment angle: horiz,0.475, °
IDE09906,Vertical deadjustment,0.623, °
IDE10902-IDE00102,Expanded ambient data 1-Control Module temperature,31, °C
IDE10902-IDE00310,Expanded ambient data 1-Outside temperature,12.5, °C
IDE10902-IDE00391,Expanded ambient data 1-Adaptive distance regulation: status,ACC_StandBy,
IDE10902-IDE03660,Expanded ambient data 1-Longitudinal acceleration,0.00, m/s²
IDE10902-MAS00370,Expanded ambient data 1-Vehicle speed,0.00, m/s
IDE10902-MAS02324,Expanded ambient data 1-Voltage at sensor,14.8, V
IDE10903-IDE00924,Expanded ambient data 2-Steering angle,2.300, °
IDE10903-IDE00925,Expanded ambient data 2-Yaw rate,0.000, rad/s
IDE10903-IDE01268,Expanded ambient data 2-Windshield wiper,not active,
IDE10903-IDE08936,Expanded ambient data 2-Misalignment angle: horiz,0.475, °
IDE10903-IDE09906,Expanded ambient data 2-Vertical deadjustment,0.623, °
IDE10903-MAS00106,Expanded ambient data 2-Year,2024,
IDE10903-MAS00107,Expanded ambient data 2-Month,12,
IDE10903-MAS00108,Expanded ambient data 2-Day,30,
IDE10903-MAS00109,Expanded ambient data 2-Hours,16,
IDE10903-MAS00110,Expanded ambient data 2-Minutes,31,
IDE10903-MAS00111,Expanded ambient data 2-Seconds,48,
IDE10903-MAS00711,Expanded ambient data 2-Odometer reading,464, km
IDE10903-MAS13429,Expanded ambient data 2-Horizontal correction angle: currently,0.000, °
IDE10903-MAS13430,Expanded ambient data 2-Vertical correction angle: currently,0.000, °
IDE10903-ENG255471,Expanded ambient data 2-Blindness_combined,0, %
IDE10903-ENG255476,Expanded ambient data 2-Blindness_indicator_1,0, %
IDE10903-ENG255477,Expanded ambient data 2-Blindness_indicator_2,0, %
IDE10903-ENG255478,Expanded ambient data 2-Blindness_indicator_3,0, %
IDE10903-ENG255479,Expanded ambient data 2-Blindness_indicator_4,0, %
IDE10903-ENG255480,Expanded ambient data 2-Blindness_indicator_5,0, %
IDE10903-ENG255481,Expanded ambient data 2-Blindness_indicator_6,0, %
IDE10903-ENG255628,Expanded ambient data 2-Distance_index,1.42, m
IDE10903-ENG256311,Expanded ambient data 2-Sensor_FRKL,0,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 71|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 07|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 FE|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 1B|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,13254,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 57 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|,
IDE12062,Counter for terminal 15 reset,505,
IDE12238,I network: discarded messages counter,0,
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,0, µs
IDE13845,Production mode status,not active,
IDE14997,Number of events: sensor blind,0,
IDE14998,Number of events: misalignment,0,
IDE15000-IDE08936,History data sensor calibration-Misalignment angle: horiz,0.000, °
IDE15000-IDE09906,History data sensor calibration-Vertical deadjustment,0.000, °
IDE15000-IDE14999,History data sensor calibration-Duration of calibration,2.40, s
IDE15000-IDE15022,History data sensor calibration-Result of calibration,OK,
IDE15000-MAS00106,History data sensor calibration-Year,2024,
IDE15000-MAS00107,History data sensor calibration-Month,10,
IDE15000-MAS00108,History data sensor calibration-Day,15,
IDE15000-MAS00109,History data sensor calibration-Hours,10,
IDE15000-MAS00110,History data sensor calibration-Minutes,33,
IDE15000-MAS00111,History data sensor calibration-Seconds,58,
IDE15000-MAS00711,History data sensor calibration-Odometer reading,2, km
IDE15000-MAS02356,History data sensor calibration-Type of calibration,static,
IDE15000-MAS13429,History data sensor calibration-Horizontal correction angle: currently,0.140, °
IDE15000-MAS13430,History data sensor calibration-Vertical correction angle: currently,0.620, °
IDE15001,History data sensor calibration 01,00 62 9E A8 7A 00 00 25 75 64 74 15 75 64 54 23 75 34 83 03 13 03 63 93 50 00 00 00 00 00 00 00 00 00 1C 00 7C 00 30,
IDE15002,History data sensor calibration 02,00 00 42 00 00 00 00 0F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE15003,History data sensor calibration 03,00 00 42 00 00 00 00 0F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE15004,History data sensor calibration 04,00 00 42 00 00 00 00 0F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE15005,History data sensor calibration 05,00 00 42 00 00 00 00 0F FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 00 00 00 00 00 00 00 00 00 00 00 00 00 01,
IDE15006,History data sensor 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15007,History data sensor 02,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15008,History data sensor 03,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15009,History data sensor 04,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15010,History data sensor 05,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15011,History data sensor 06,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15012,History data sensor 07,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15013,History data sensor 08,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15014,History data sensor 09,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15015,History data sensor 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15016,History data sensor 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15017,History data sensor 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15018,History data sensor 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15019,History data sensor 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE15020,History data sensor 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE17075-MAS06854,Functions that can be enabled: FoD slave enhanced status-Version,11,
IDE17075-ENG298547,Functions that can be enabled: FoD slave enhanced status-Extended_state_payload,00 01 00 D6 02 03 00 02 00 00 03 03 00 00 00 00 00 00 00 DD 00 00 00 00 03 00 00 00 0A 00 00 00 00 00 00 75 30 00 05 7E 40 00 00 03 E8 00 0A 02 0A 23 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE17075-ENG298612,Functions that can be enabled: FoD slave enhanced status-Payload_length,53,
MAS00370,Vehicle speed,0.00, m/s
MAS17268,Functions which can be activated: connection error counter,0,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 01 01 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,10,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS26502,Traffic sense,Unknown,
ENG282476-ENG282622,ACC_invalid_states-ErrorIdentCode,00 00 00 00,
ENG282476-ENG282616,ACC_invalid_states-LineNumber,00 00 00 00,
ENG282476-ENG282621,ACC_invalid_states-SourceFileID,00 00 00 00,
ENG282477-ENG104031,ACTLNumber-Number,03,
ENG282493-ENG282622,AWV_invalid_states-ErrorIdentCode,00 00 00 00,
ENG282493-ENG282616,AWV_invalid_states-LineNumber,00 00 00 00,
ENG282493-ENG282621,AWV_invalid_states-SourceFileID,00 00 00 00,
ENG282503,ECU_monitoring_states,00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,10,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG254718-ENG299129,Function_On_Demand_Unlock_ID_Status_Dev-FoD_function_state,|ID number,Authentication,Functions,Configuration,Preconditions met,Individualization characteristic,Cancellation,Release code for a SWaP function|10 01 01 00,valid,Not available,not OK,Condition met,valid,No,available.|10 01 02 00,valid,Not available,not OK,Condition met,valid,No,available.|10 01 03 00,valid,Not available,not OK,Condition met,valid,Yes,available.|10 01 04 00,valid,Not available,not OK,Condition met,valid,No,available.|10 01 05 00,valid,Not available,not OK,Condition met,valid,No,available.|10 01 06 00,valid,Not available,not OK,Condition met,valid,Yes,available.|10 01 07 00,valid,Not available,not OK,Condition met,valid,Yes,available.|10 01 08 00,valid,Not available,not OK,Condition met,valid,Yes,available.|10 01 09 00,valid,Not available,not OK,Condition met,valid,Yes,available.|10 01 0A 00,valid,Not available,not OK,Condition met,valid,Yes,available.|,
ENG139759-ENG98375,Supplier_sw_block_version-Application,02 20 05 10,
ENG139759-ENG140150,Supplier_sw_block_version-Bootloader,01 01 21 10,
ENG139832,Sw_version_supplier,002032005 240206,
Elapsed Time: 00:19
blockmap-15-3WA-959-655-AA_WVGAWVEB7SH010695-20241230-1132.CSV
;SW:3WA-959-655-AA   HW:3WA-959-655-AA ---  Airbags
;Component:Airbag VW50   006 0151, Coding:8CCC0C0000FCC0000000002000000000A15450008100A200830036F8102B0065
;EV_AirbaVW50TS6VW49X,001001,EV_AirbaVW50TS6VW49X_VWE3.rod
;Monday,30,December,2024,11:32:19:18177
;VCID: 147666AB1EFFFFBAC7A-8040-R SFD
IDE00821-MAS01632,Seat belt switch 2nd row driver's side-Status,not connected,
IDE00821-MAS04136,Seat belt switch 2nd row driver's side-Current,no measured value present,
IDE00821-MAS05030,Seat belt switch 2nd row driver's side-Resistance,388.0, Ohm
IDE00822-MAS01632,Safety belt switch 2nd row frt.passenger side-Status,not connected,
IDE00822-MAS04136,Safety belt switch 2nd row frt.passenger side-Current,no measured value present,
IDE00822-MAS05030,Safety belt switch 2nd row frt.passenger side-Resistance,384.0, Ohm
IDE00823-MAS01632,Seat belt switch 2nd row center-Status,not connected,
IDE00823-MAS04136,Seat belt switch 2nd row center-Current,no measured value present,
IDE00823-MAS05030,Seat belt switch 2nd row center-Resistance,384.0, Ohm
IDE00824-MAS01632,Seat belt switch 3rd row driver's side-Status,connected,
IDE00824-MAS04136,Seat belt switch 3rd row driver's side-Current,no measured value present,
IDE00824-MAS05030,Seat belt switch 3rd row driver's side-Resistance,820.0, Ohm
IDE00825-MAS01632,Passenger side 3rd row seat belt switch-Status,connected,
IDE00825-MAS04136,Passenger side 3rd row seat belt switch-Current,no measured value present,
IDE00825-MAS05030,Passenger side 3rd row seat belt switch-Resistance,820.0, Ohm
IDE00826-MAS01632,Seat belt switch 3rd row center-Status,not installed,
IDE00826-MAS04136,Seat belt switch 3rd row center-Current,no measured value present,
IDE00826-MAS05030,Seat belt switch 3rd row center-Resistance,no measured value present,
IDE00947-MAS01632,Driver side rear curtain airbag igniter-Status,no measured value present,
IDE00947-MAS05030,Driver side rear curtain airbag igniter-Resistance,no measured value present,
IDE00948-MAS01632,Frt.passenger side rear curtain airbag igniter-Status,no measured value present,
IDE00948-MAS05030,Frt.passenger side rear curtain airbag igniter-Resistance,no measured value present,
IDE00956,Occupation status: frt.passenger seat,Empty or child or child safety seat,
IDE01097-MAS01167,Front passenger airbag -disabled- indicator lamp-Actuation time,1 second,
IDE01097-MAS01168,Front passenger airbag -disabled- indicator lamp-Start parameter,On,
IDE01097-ENG102225,Front passenger airbag -disabled- indicator lamp-Input Output Control Parameter,Brief actuation,
IDE01357-MAS01632,Left pedestrian protection igniter-Status,no measured value present,
IDE01357-MAS05030,Left pedestrian protection igniter-Resistance,no measured value present,
IDE01358-MAS01632,Right pedestrian protection igniter-Status,no measured value present,
IDE01358-MAS05030,Right pedestrian protection igniter-Resistance,no measured value present,
IDE01359-MAS01632,Front pedestrian protection trigger-Status,no measured value present,
IDE01359-MAS05030,Front pedestrian protection trigger-Resistance,no measured value present,
IDE01552-MAS01167,Activation of active head restraint-Actuation time,1 second,
IDE01552-MAS01168,Activation of active head restraint-Start parameter,OFF,
IDE01552-ENG102225,Activation of active head restraint-Input Output Control Parameter,Brief actuation,
IDE01554-MAS01143,Workshop code for last rollover bar deployment-Device number,0,
IDE01554-MAS01144,Workshop code for last rollover bar deployment-Importer number,0,
IDE01554-MAS01145,Workshop code for last rollover bar deployment-Dealership number,0,
IDE01555,Number of frontal crashes,0,
IDE02255,Malfunction text output,Malfunction text 1,
IDE02255-MAS01167,Malfunction text output-Actuation time,1 second,
IDE02255-MAS01168,Malfunction text output-Start parameter,On,
IDE02255-ENG102225,Malfunction text output-Input Output Control Parameter,Brief actuation,
IDE02256-MAS01167,Seat belt tensioner: activation-Actuation time,1 second,
IDE02256-MAS01168,Seat belt tensioner: activation-Start parameter,On,
IDE02256-MAS01340,Seat belt tensioner: activation-Functions,Tighten seat-belt slack characteristic 1,
IDE02256-MAS04150,Seat belt tensioner: activation-Side,Left,
IDE02256-ENG102225,Seat belt tensioner: activation-Input Output Control Parameter,Brief actuation,
IDE02486,Data logger triggering,not initialized,
IDE02852-MAS01632,Battery Interrupt Igniter High-Voltage Battery-Status,correct,
IDE02852-MAS05030,Battery Interrupt Igniter High-Voltage Battery-Resistance,3.3, Ohm
IDE03800-MAS01632,Driver airbag release valve igniter-Status,no measured value present,
IDE03800-MAS05030,Driver airbag release valve igniter-Resistance,no measured value present,
IDE03801-MAS01632,Frt.pass. airbag release valve igniter-Status,not installed,
IDE03801-MAS05030,Frt.pass. airbag release valve igniter-Resistance,no measured value present,
IDE03870,Seat occupied recognition malfunction status,0,
IDE03870,Seat occupied recognition malfunction status,|,,|00,0,0|,
IDE04805-IDE02955,Driving profile selection-System status,Initialization,
IDE04805-MAS01448,Driving profile selection-Target value,0,
IDE04805-MAS05058,Driving profile selection-Compatibility,No,
IDE05726-MAS09976,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'off': frt. pass. side,no measured value present,
IDE05726-MAS09977,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'on': frt. pass. side,no measured value present,
IDE05726-MAS09978,Dimmer terminal 58xd-Dim. value indicator lamp for airbag 'text': frt. pass. side,no measured value present,
IDE06032-MAS01167,Vehicle conditioning-Actuation time,1 second,
IDE06032-MAS01168,Vehicle conditioning-Start parameter,On,
IDE06032-MAS01340,Vehicle conditioning-Functions,Close windows,
IDE06032-ENG102225,Vehicle conditioning-Input Output Control Parameter,Brief actuation,
IDE06034-MAS01632,Rollover protection trigger: driver side-Status,no measured value present,
IDE06034-MAS05030,Rollover protection trigger: driver side-Resistance,no measured value present,
IDE06035-MAS01632,Rollover protection trigger: front passenger side-Status,no measured value present,
IDE06035-MAS05030,Rollover protection trigger: front passenger side-Resistance,no measured value present,
IDE06959,Seat occupant detection: diagnosis signal,22.5, %
IDE06960,Seat occupant detection: msmt. signal,1.0, %
IDE06961,Seat occupant detection: ref. signal,0.5, %
IDE07190-MAS01632,Igniter for battery open circuit 2nd battery-Status,no measured value present,
IDE07190-MAS05030,Igniter for battery open circuit 2nd battery-Resistance,no measured value present,
IDE07192-MAS01632,Thorax airbag igniter-Status,no measured value present,
IDE07192-MAS05030,Thorax airbag igniter-Resistance,no measured value present,
IDE08436-MAS01632,Driver side seat belt tensioner igniter 3-Status,no measured value present,
IDE08436-MAS05030,Driver side seat belt tensioner igniter 3-Resistance,no measured value present,
IDE08437-MAS01632,Front passenger side third row seat belt tensioner igniter-Status,no measured value present,
IDE08437-MAS05030,Front passenger side third row seat belt tensioner igniter-Resistance,no measured value present,
IDE09598-MAS01167,Triggering crash shutoff: high voltage system (Bus signal)-Actuation time,1 second,
IDE09598-MAS01168,Triggering crash shutoff: high voltage system (Bus signal)-Start parameter,On,
IDE09598-MAS05705,Triggering crash shutoff: high voltage system (Bus signal)-Shutdown request,No switch-off,
IDE09598-ENG102225,Triggering crash shutoff: high voltage system (Bus signal)-Input Output Control Parameter,Brief actuation,
IDE09599-IDE09624,Accident severity management-Crash severity,No result,
IDE09599-IDE09625,Accident severity management-Collision pos. - front drvr. side,not active,
IDE09599-IDE09626,Accident severity management-Collision pos. - front pass. side,not active,
IDE09599-IDE09627,Accident severity management-Collision pos. - side drvr. side,not active,
IDE09599-IDE09628,Accident severity management-Collision pos. - side frt. pass. side,not active,
IDE09599-IDE09629,Accident severity management-Collision pos. - rear of drvr. side,not active,
IDE09599-IDE09630,Accident severity management-Collision pos. - rear of frt. pass. side,not active,
IDE09599-IDE09631,Accident severity management-Collision position - rollover crash,not active,
IDE09599-IDE09632,Accident severity management-Collision pos. - pedestr. protect.,not active,
IDE09599-MAS01167,Accident severity management-Actuation time,1 second,
IDE09599-MAS01168,Accident severity management-Start parameter,On,
IDE09599-ENG102225,Accident severity management-Input Output Control Parameter,Brief actuation,
IDE10300,OBD Driving Cycle detected,not active,
IDE11715-MAS01632,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Status,no measured value present,
IDE11715-MAS05030,Igniter 2 f. seat belt tensioner: 2nd row: front passenger side-Resistance,no measured value present,
IDE11716-MAS01632,Igniter 2 for seat belt tensioner: 2nd row: driver side-Status,no measured value present,
IDE11716-MAS05030,Igniter 2 for seat belt tensioner: 2nd row: driver side-Resistance,no measured value present,
IDE12056-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,not installed,
IDE12056-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12057-MAS01632,Igniter for interaction airbag 2nd row: driver side-Status,no measured value present,
IDE12057-MAS05030,Igniter for interaction airbag 2nd row: driver side-Resistance,no measured value present,
IDE12158-MAS01632,Front pedestrian protection trigger 2-Status,no measured value present,
IDE12158-MAS05030,Front pedestrian protection trigger 2-Resistance,no measured value present,
IDE12208-MAS01632,Igniter for deactivation of A/C system 1-Status,not installed,
IDE12208-MAS05030,Igniter for deactivation of A/C system 1-Resistance,no measured value present,
IDE12209-MAS01632,Igniter for deactivation of A/C system 2-Status,not installed,
IDE12209-MAS05030,Igniter for deactivation of A/C system 2-Resistance,no measured value present,
IDE12257-IDE00821,Extended belts witch diagnostic-Seat belt switch 2nd row driver's side,255,
IDE12257-IDE00822,Extended belts witch diagnostic-Safety belt switch 2nd row frt.passenger side,255,
IDE12257-IDE00823,Extended belts witch diagnostic-Seat belt switch 2nd row center,255,
IDE12257-IDE00824,Extended belts witch diagnostic-Seat belt switch 3rd row driver's side,255,
IDE12257-IDE00825,Extended belts witch diagnostic-Passenger side 3rd row seat belt switch,255,
IDE12257-IDE00826,Extended belts witch diagnostic-Seat belt switch 3rd row center,255,
IDE12257-IDE14842,Extended belts witch diagnostic-Center seat belt switch,255,
IDE12257-IDE14843,Extended belts witch diagnostic-Seat belt switch: 4th row driver side,255,
IDE12257-IDE14844,Extended belts witch diagnostic-Seat belt switch: 4th row passenger side,255,
IDE12257-IDE14845,Extended belts witch diagnostic-Seat belt switch: 4th row center,255,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,5,
IDE12257-MAS00025,Extended belts witch diagnostic-Driver seat belt switch,0,
IDE12257-MAS00026,Extended belts witch diagnostic-Front passenger side safety belt switch,255,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,15,
IDE12257-MAS00478,Extended belts witch diagnostic-Reserved,0,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,not installed,
IDE12257-MAS01632,Extended belts witch diagnostic-Status,connected,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,not active,
IDE12257-MAS09326,Extended belts witch diagnostic-Function,active,
IDE13284-MAS01632,Seat-occupied recognition: 3rd row driver side-Status,no measured value present,
IDE13284-MAS05030,Seat-occupied recognition: 3rd row driver side-Resistance,no measured value present,
IDE13586-MAS01632,Seat-occupied recognition: 3rd row front passenger side-Status,no measured value present,
IDE13586-MAS05030,Seat-occupied recognition: 3rd row front passenger side-Resistance,no measured value present,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVGAWVEB7SH010695,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,5,
IDE14239-MAS01632,Igniter for high-voltage battery 2 open circuit-Status,no measured value present,
IDE14239-MAS05030,Igniter for high-voltage battery 2 open circuit-Resistance,no measured value present,
IDE14240-MAS01632,Driver side seat occupancy detection-Status,assigned,
IDE14240-MAS05030,Driver side seat occupancy detection-Resistance,84.0, Ohm
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3D 5C A0 C2 C8 42 9A,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,3,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 06,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14662-IDE13284,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row driver side,255,
IDE14662-IDE13586,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,255,
IDE14662-IDE14240,Expanded diagnosis of seat occupancy detection-Driver side seat occupancy detection,0,
IDE14662-IDE14240,Expanded diagnosis of seat occupancy detection-Driver side seat occupancy detection,5,
IDE14662-IDE14846,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: center,255,
IDE14662-IDE14847,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row driver side,255,
IDE14662-IDE14848,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,255,
IDE14662-IDE14849,Expanded diagnosis of seat occupancy detection-Seat-occupied recognition: 4th row center,255,
IDE14662-MAS00038,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: driver side: rear,255,
IDE14662-MAS00039,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: passenger side: rear,255,
IDE14662-MAS00040,Expanded diagnosis of seat occupancy detection-Seat occupied recognition: center: rear,255,
IDE14662-MAS00231,Expanded diagnosis of seat occupancy detection-Seat occupied recognition passenger side,255,
IDE14662-MAS00478,Expanded diagnosis of seat occupancy detection-Reserved,15,
IDE14662-MAS00478,Expanded diagnosis of seat occupancy detection-Reserved,0,
IDE14662-MAS01632,Expanded diagnosis of seat occupancy detection-Status,not installed,
IDE14662-MAS01632,Expanded diagnosis of seat occupancy detection-Status,assigned,
IDE14662-MAS09326,Expanded diagnosis of seat occupancy detection-Function,not active,
IDE14662-MAS09326,Expanded diagnosis of seat occupancy detection-Function,active,
IDE14662-MAS18987,Expanded diagnosis of seat occupancy detection-Seat occupancy detection: 3rd row center,255,
IDE14740-IDE13284,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row driver side,Not assigned,
IDE14740-IDE13586,Wireless seat occupancy detection-Seat-occupied recognition: 3rd row front passenger side,Not assigned,
IDE14740-IDE14240,Wireless seat occupancy detection-Driver side seat occupancy detection,assigned,
IDE14740-IDE14846,Wireless seat occupancy detection-Seat occupancy detection: center,not installed,
IDE14740-IDE14847,Wireless seat occupancy detection-Seat-occupied recognition: 4th row driver side,not installed,
IDE14740-IDE14848,Wireless seat occupancy detection-Seat-occupied recognition: 4th row front passenger side,not installed,
IDE14740-IDE14849,Wireless seat occupancy detection-Seat-occupied recognition: 4th row center,not installed,
IDE14740-MAS00038,Wireless seat occupancy detection-Seat occupied recognition: driver side: rear,not installed,
IDE14740-MAS00039,Wireless seat occupancy detection-Seat occupied recognition: passenger side: rear,not installed,
IDE14740-MAS00040,Wireless seat occupancy detection-Seat occupied recognition: center: rear,not installed,
IDE14740-MAS00231,Wireless seat occupancy detection-Seat occupied recognition passenger side,not installed,
IDE14740-MAS18987,Wireless seat occupancy detection-Seat occupancy detection: 3rd row center,not installed,
IDE14741-IDE00821,Wireless belt buckle query-Seat belt switch 2nd row driver's side,not installed,
IDE14741-IDE00822,Wireless belt buckle query-Safety belt switch 2nd row frt.passenger side,not installed,
IDE14741-IDE00823,Wireless belt buckle query-Seat belt switch 2nd row center,not installed,
IDE14741-IDE00824,Wireless belt buckle query-Seat belt switch 3rd row driver's side,not connected,
IDE14741-IDE00825,Wireless belt buckle query-Passenger side 3rd row seat belt switch,not connected,
IDE14741-IDE00826,Wireless belt buckle query-Seat belt switch 3rd row center,not installed,
IDE14741-IDE14842,Wireless belt buckle query-Center seat belt switch,not installed,
IDE14741-IDE14843,Wireless belt buckle query-Seat belt switch: 4th row driver side,not installed,
IDE14741-IDE14844,Wireless belt buckle query-Seat belt switch: 4th row passenger side,not installed,
IDE14741-IDE14845,Wireless belt buckle query-Seat belt switch: 4th row center,not installed,
IDE14741-MAS00025,Wireless belt buckle query-Driver seat belt switch,connected,
IDE14741-MAS00026,Wireless belt buckle query-Front passenger side safety belt switch,not connected,
IDE14842-MAS01632,Center seat belt switch-Status,not installed,
IDE14842-MAS04136,Center seat belt switch-Current,no measured value present,
IDE14842-MAS05030,Center seat belt switch-Resistance,no measured value present,
IDE14843-MAS01632,Seat belt switch: 4th row driver side-Status,not installed,
IDE14843-MAS04136,Seat belt switch: 4th row driver side-Current,no measured value present,
IDE14843-MAS05030,Seat belt switch: 4th row driver side-Resistance,no measured value present,
IDE14844-MAS01632,Seat belt switch: 4th row passenger side-Status,not installed,
IDE14844-MAS04136,Seat belt switch: 4th row passenger side-Current,no measured value present,
IDE14844-MAS05030,Seat belt switch: 4th row passenger side-Resistance,no measured value present,
IDE14845-MAS01632,Seat belt switch: 4th row center-Status,not installed,
IDE14845-MAS04136,Seat belt switch: 4th row center-Current,no measured value present,
IDE14845-MAS05030,Seat belt switch: 4th row center-Resistance,no measured value present,
IDE14846-MAS01632,Seat occupancy detection: center-Status,not installed,
IDE14846-MAS05030,Seat occupancy detection: center-Resistance,no measured value present,
IDE14847-MAS01632,Seat-occupied recognition: 4th row driver side-Status,not installed,
IDE14847-MAS05030,Seat-occupied recognition: 4th row driver side-Resistance,no measured value present,
IDE14848-MAS01632,Seat-occupied recognition: 4th row front passenger side-Status,not installed,
IDE14848-MAS05030,Seat-occupied recognition: 4th row front passenger side-Resistance,no measured value present,
IDE14849-MAS01632,Seat-occupied recognition: 4th row center-Status,not installed,
IDE14849-MAS05030,Seat-occupied recognition: 4th row center-Resistance,no measured value present,
IDE15772-MAS14174,Wireless belt request/seat occupancy detection status-2nd Row Center,not configured,
IDE15772-MAS20984,Wireless belt request/seat occupancy detection status-1st Row Driver Side,not configured,
IDE15772-MAS20985,Wireless belt request/seat occupancy detection status-1st Row Passenger Side,not configured,
IDE15772-MAS20986,Wireless belt request/seat occupancy detection status-1st Row Center,not configured,
IDE15772-MAS20987,Wireless belt request/seat occupancy detection status-3rd Row Center,not configured,
IDE15772-MAS20988,Wireless belt request/seat occupancy detection status-4th Row Center,not configured,
IDE15772-MAS20989,Wireless belt request/seat occupancy detection status-4th Row Passenger Side,not configured,
IDE15772-MAS20990,Wireless belt request/seat occupancy detection status-3rd Row Passenger Side,correct,
IDE15772-MAS20991,Wireless belt request/seat occupancy detection status-2nd Row Passenger Side,not configured,
IDE15772-MAS20992,Wireless belt request/seat occupancy detection status-2nd Row Driver Side,not configured,
IDE15772-MAS20993,Wireless belt request/seat occupancy detection status-3rd Row Driver Side,correct,
IDE15772-MAS20994,Wireless belt request/seat occupancy detection status-4th Row Driver Side,not configured,
IDE15776-MAS01632,Deactivation igniter: DC/DC converter-Status,no measured value present,
IDE15776-MAS05030,Deactivation igniter: DC/DC converter-Resistance,no measured value present,
IDE16063-MAS01632,Igniter for high-voltage battery 3 open circuit-Status,no measured value present,
IDE16063-MAS05030,Igniter for high-voltage battery 3 open circuit-Resistance,no measured value present,
IDE16064-MAS01632,Driver Head Curtain Airbag Igniter 2-Status,correct,
IDE16064-MAS05030,Driver Head Curtain Airbag Igniter 2-Resistance,2.6, Ohm
IDE16065-MAS01632,Front Passenger Head Curtain Airbag Igniter 2-Status,correct,
IDE16065-MAS05030,Front Passenger Head Curtain Airbag Igniter 2-Resistance,2.5, Ohm
IDE16304-IDE02241,Inertial sensors-Lateral acceleration sensor 1,-0.1, m/s²
IDE16304-IDE02245,Inertial sensors-Lateral acceleration sensor 2,-163.8, m/s²
IDE16304-IDE02538,Inertial sensors-Longitude Acceleration Sensor,-0.1, m/s²
IDE16304-IDE02546,Inertial sensors-Roll rate sensor,-0.4, °/s
IDE16304-IDE02549,Inertial sensors-Pitch rate sensor,-327.7, °/s
IDE16304-IDE02552,Inertial sensors-Yaw rate sensor,-0.0, °/s
IDE16304-IDE02555,Inertial sensors-Yaw rate sensor 2,-327.7, °/s
IDE16304-IDE16337,Inertial sensors-Longitudinal Acceleration Sensor 2,-163.8, m/s²
IDE16304-MAS04460,Inertial sensors-Validity,OK,
IDE16304-MAS04460,Inertial sensors-Validity,Not installed due to specific system,
IDE16304-MAS22296,Inertial sensors-Vertical Motion Sensor,9.7, m/s²
IDE16304-MAS22298,Inertial sensors-Vertical Motion Sensor 2,-163.8, m/s²
IDE17275-MAS01632,Igniter for deactivation of A/C system 3-Status,not installed,
IDE17275-MAS05030,Igniter for deactivation of A/C system 3-Resistance,no measured value present,
MAS00001-MAS01632,Driver airbag igniter-Status,correct,
MAS00001-MAS05030,Driver airbag igniter-Resistance,3.0, Ohm
MAS00002-MAS01632,Driver's Airbag Igniter 2-Status,no measured value present,
MAS00002-MAS05030,Driver's Airbag Igniter 2-Resistance,no measured value present,
MAS00003-MAS01632,Front passenger airbag igniter-Status,correct,
MAS00003-MAS05030,Front passenger airbag igniter-Resistance,2.2, Ohm
MAS00004-MAS01632,Front passenger airbag igniter 2-Status,correct,
MAS00004-MAS05030,Front passenger airbag igniter 2-Resistance,2.2, Ohm
MAS00005-MAS01632,Driver thorax airbag igniter-Status,correct,
MAS00005-MAS05030,Driver thorax airbag igniter-Resistance,2.5, Ohm
MAS00006-MAS01632,Front passenger side airbag igniter-Status,correct,
MAS00006-MAS05030,Front passenger side airbag igniter-Resistance,2.4, Ohm
MAS00007-MAS01632,Driver side rear thorax airbag igniter-Status,no measured value present,
MAS00007-MAS05030,Driver side rear thorax airbag igniter-Resistance,no measured value present,
MAS00008-MAS01632,Passenger side rear thorax airbag igniter-Status,no measured value present,
MAS00008-MAS05030,Passenger side rear thorax airbag igniter-Resistance,no measured value present,
MAS00009-MAS01632,Driver head curtain airbag igniter-Status,correct,
MAS00009-MAS05030,Driver head curtain airbag igniter-Resistance,2.4, Ohm
MAS00010-MAS01632,Front passenger head curtain airbag igniter-Status,correct,
MAS00010-MAS05030,Front passenger head curtain airbag igniter-Resistance,2.4, Ohm
MAS00011-MAS01632,Driver knee airbag igniter-Status,no measured value present,
MAS00011-MAS05030,Driver knee airbag igniter-Resistance,no measured value present,
MAS00012-MAS01632,Front passenger knee airbag igniter-Status,not installed,
MAS00012-MAS05030,Front passenger knee airbag igniter-Resistance,no measured value present,
MAS00013-MAS01632,Driver side seat belt tension igniter-Status,correct,
MAS00013-MAS05030,Driver side seat belt tension igniter-Resistance,2.4, Ohm
MAS00014-MAS01632,Front passenger side seat belt tension igniter-Status,correct,
MAS00014-MAS05030,Front passenger side seat belt tension igniter-Resistance,2.3, Ohm
MAS00015-MAS01632,Driver's Safety Belt Tensioner Igniter 2-Status,correct,
MAS00015-MAS05030,Driver's Safety Belt Tensioner Igniter 2-Resistance,2.4, Ohm
MAS00016-MAS01632,Front passenger seat belt tensioner igniter 2-Status,correct,
MAS00016-MAS05030,Front passenger seat belt tensioner igniter 2-Resistance,2.4, Ohm
MAS00017-MAS01632,Driver's Belt Force Limiter-Status,correct,
MAS00017-MAS05030,Driver's Belt Force Limiter-Resistance,2.4, Ohm
MAS00018-MAS01632,Front passenger side belt force limiter igniter-Status,correct,
MAS00018-MAS05030,Front passenger side belt force limiter igniter-Resistance,2.4, Ohm
MAS00019-MAS01632,Driver side rear safety belt tension igniter-Status,correct,
MAS00019-MAS05030,Driver side rear safety belt tension igniter-Resistance,2.6, Ohm
MAS00020-MAS01632,Passenger side rear seat belt tensioner igniter-Status,correct,
MAS00020-MAS05030,Passenger side rear seat belt tensioner igniter-Resistance,2.7, Ohm
MAS00021-MAS01632,Center rear seat belt tensioner igniter-Status,no measured value present,
MAS00021-MAS05030,Center rear seat belt tensioner igniter-Resistance,no measured value present,
MAS00022-MAS01632,Battery Interrupt Igniter-Status,no measured value present,
MAS00022-MAS05030,Battery Interrupt Igniter-Resistance,no measured value present,
MAS00023-MAS01632,Driver side active head restraint igniter-Status,no measured value present,
MAS00023-MAS05030,Driver side active head restraint igniter-Resistance,no measured value present,
MAS00024-MAS01632,Igniter for active head restraint on frt. passenger side-Status,no measured value present,
MAS00024-MAS05030,Igniter for active head restraint on frt. passenger side-Resistance,no measured value present,
MAS00025-MAS01632,Driver seat belt switch-Status,connected,
MAS00025-MAS04136,Driver seat belt switch-Current,no measured value present,
MAS00025-MAS05030,Driver seat belt switch-Resistance,96.0, Ohm
MAS00026-MAS01632,Front passenger side safety belt switch-Status,not connected,
MAS00026-MAS04136,Front passenger side safety belt switch-Current,no measured value present,
MAS00026-MAS05030,Front passenger side safety belt switch-Resistance,396.0, Ohm
MAS00031,Airbag deactivation status,OFF,
MAS00032-MAS01632,Key switch terminal 1-Status,not installed,
MAS00032-MAS05030,Key switch terminal 1-Resistance,no measured value present,
MAS00033-MAS01632,Key switch terminal 2-Status,not installed,
MAS00033-MAS05030,Key switch terminal 2-Resistance,no measured value present,
MAS00035-MAS01632,Seat position sensor: driver side-Status,Rear,
MAS00035-MAS04136,Seat position sensor: driver side-Current,5.5, mA
MAS00036-MAS01632,Seat position sensor: front passenger side-Status,Rear,
MAS00036-MAS04136,Seat position sensor: front passenger side-Current,5.4, mA
MAS00037,Calibration status,0,
MAS00038-MAS01632,Seat occupied recognition: driver side: rear-Status,no measured value present,
MAS00038-MAS05030,Seat occupied recognition: driver side: rear-Resistance,no measured value present,
MAS00039-MAS01632,Seat occupied recognition: passenger side: rear-Status,no measured value present,
MAS00039-MAS05030,Seat occupied recognition: passenger side: rear-Resistance,no measured value present,
MAS00040-MAS01632,Seat occupied recognition: center: rear-Status,no measured value present,
MAS00040-MAS05030,Seat occupied recognition: center: rear-Resistance,no measured value present,
MAS00083-IDE05251,Deploying crash signal-Crash direction,No crash direction,
MAS00083-IDE05258,Deploying crash signal-Crash intensity,Stage 1,
MAS00083-MAS01167,Deploying crash signal-Actuation time,1 second,
MAS00083-MAS01168,Deploying crash signal-Start parameter,On,
MAS00083-ENG102225,Deploying crash signal-Input Output Control Parameter,Brief actuation,
MAS00231-MAS01632,Seat occupied recognition passenger side-Status,not installed,
MAS00231-MAS05030,Seat occupied recognition passenger side-Resistance,no measured value present,
MAS01634-IDE00020,Supply voltage-Terminal 15 status,On,
MAS01634-IDE00773,Supply voltage-Terminal 15 status via CAN,On,
MAS01634-IDE02537,Supply voltage-Terminal 30 status,correct,
MAS01634-MAS06489,Supply voltage-Terminal 15 signal,14.6, V
MAS01634-MAS06982,Supply voltage-Terminal 15 status signal,On,
MAS01634-MAS15175,Supply voltage-Terminal 30,14.8, V
MAS18987-MAS01632,Seat occupancy detection: 3rd row center-Status,not installed,
MAS18987-MAS05030,Seat occupancy detection: 3rd row center-Resistance,no measured value present,
Elapsed Time: 00:20
blockmap-16-1EE-953-507-CH_WVGAWVEB7SH010695-20241230-1132.CSV
;SW:1EE-953-507-CH   HW:1EE-953-507-CH ---  Steering wheel
;Component:GSMMEB        005 0067, Coding:
;EV_SMLSKLOGEN2,009005,EV_SMLSKLOGEN2.rod
;Monday,30,December,2024,11:32:57:18177
;VCID: 035455F76B9168026E0-8056-R SFD
IDE00020,Terminal 15 status,On,
IDE02693-IDE02335,Turn signals and parking lights-Signal light switch position,Not operated,
IDE02694-MAS01288,Horn operation-Horn,Not operated,
IDE02695-IDE01268,Front wiping: front washing-Windshield wiper,Intermittent operation,
IDE02695-MAS02338,Front wiping: front washing-Windshield wiper: intermittent stage,Stage 2,
IDE02695-MAS02339,Front wiping: front washing-Windshield washer system,Not operated,
IDE02696-IDE02711,Rear wiping: rear washing-Rear wiper,Not operated,
IDE02696-MAS02341,Rear wiping: rear washing-Rear window washer system,Not operated,
IDE02743,High Beam,Not operated,
IDE02744-MAS01447,Steering wheel heating-Act.val.,0, %
IDE02744-MAS01448,Steering wheel heating-Target value,0, %
IDE02744-MAS01632,Steering wheel heating-Status,OFF,
IDE02744-MAS04121,Steering wheel heating-Voltage,0.0, V
IDE02744-MAS04136,Steering wheel heating-Current,0.00, A
IDE03393,Selector lever position,Basic setting X,
IDE05724,Dimmer terminal 58xt,100, %
IDE09492-ENG274503,Temperatures-Internal ECU Temperature,30, °C
IDE10342-MAS00468,Standard - ambient data 1: status-Unlearning counter,10,
IDE10342-MAS00711,Standard - ambient data 1: status-Odometer reading,464, km
IDE10342-MAS10409,Standard - ambient data 1: status-Time stamp,00 63 3D 08 37,
IDE11401,Selec. range display: spec. val.,Not operated,
IDE11411-IDE15366,Button for park. lock-Selector lever P button status,not coded/not installed,
IDE13824,Monitoring network diagnosis valid,active,
MAS20396,SFD protection procedure,SFD access protection,
Elapsed Time: 00:02
blockmap-17-10A-920-320-D_WVGAWVEB7SH010695-20241230-1119.CSV
;SW:10A-920-320-D   HW:10A-920-320-D ---  Instruments
;Component:FAHRERDISPLAY 031 0650, Coding:267001
;EV_DashBoardLGMEB,002032,EV_DashBoardLGMEB_002_VWE3.rod
;Monday,30,December,2024,11:19:32:18177
;VCID: 16721CA30803EDAAB9E-8042-R SFD
IDE07159-MAS01155,Control module switch-off: counter-Control module,00,
IDE07159-MAS05583,Control module switch-off: counter-Data bus,00,
IDE14129-IDE04290,Segment test status-Color code,White,
IDE14129-MAS01167,Segment test status-Actuation time,OFF,
IDE14129-ENG261531,Segment test status-IO Reached Status,Output diagnostic test not active,
IDE14130-MAS01167,Test image in center display status-Actuation time,OFF,
IDE14130-MAS01168,Test image in center display status-Start parameter,not defined,
IDE14130-ENG261531,Test image in center display status-IO Reached Status,Output diagnostic test not active,
IDE14132-MAS01167,Indicator lamp status-Actuation time,OFF,
IDE14132-MAS01168,Indicator lamp status-Start parameter,OFF,
IDE14132-ENG261531,Indicator lamp status-IO Reached Status,Output diagnostic test not active,
IDE15133-IDE04798,LED activation-Left turn signal,OFF,
IDE15133-IDE04799,LED activation-Right turn signal,OFF,
IDE15133-MAS00170,LED activation-OBD,OFF,
IDE15133-MAS00988,LED activation-Reverse gear,OFF,
IDE15133-MAS01167,LED activation-Actuation time,OFF,
IDE15133-MAS01712,LED activation-Neutral,OFF,
IDE15133-MAS01736,LED activation-Driving,OFF,
IDE15133-MAS03834,LED activation-Emergency signal flashing,OFF,
IDE15133-MAS12723,LED activation-Arrow symbol,OFF,
IDE15133-MAS18688,LED activation-Parking,OFF,
IDE15133-MAS20558,LED activation-Jump symbol,OFF,
IDE15133-MAS20559,LED activation-Slash,OFF,
IDE15133-UNK00014,LED activation-B,OFF,
IDE15133-ENG261531,LED activation-IO Reached Status,Output diagnostic test not active,
MAS18157-MAS20207,SFD activated status-SFD roll,No activation active,
ENG105830-ENG261526,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_functional_lighting_for_gear_selection_red,1000,
ENG105830-ENG261527,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_functional_lighting_for_gear_selection_white,1000,
ENG105830-ENG261528,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_functional_lighting_for_gear_selection_yellow,1000,
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,1000,
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,1000,
ENG105830-ENG261529,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_search_lighting_for_gear_selection_white,1000,
ENG105830-ENG261530,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_internal characteristic_phototransistor,254,
Elapsed Time: 00:01
blockmap-19-1EE-937-012-A_WVGAWVEB7SH010695-20241230-1119.CSV
;SW:1EE-937-012-A   HW:1EE-937-012 ---  CAN Gateway
;Component:ICAS1 Host-SG 031 0254, Coding:
;EV_GatewICAS1MEBUNECE,001004,EV_GatewICAS1MEBUNECE_VNE4.rod
;Monday,30,December,2024,11:19:49:18177
;VCID: 323AC03384AB118AB56-8066 SFD
IDE00019,Voltage terminal 30,14.9, V
IDE00056,History data 1,00 00 00 00 00 00 00 00 00 00 00,
IDE00056,History data 1,80 14 34 0C 0C 18 01 01 00 00 00,
IDE00056,History data 1,13 14 30 18 0C 18 01 00 00 8B 0A 00 00,
IDE00056,History data 1,80 13 23 0C 0C 18 01 00 00 00 00,
IDE00056,History data 1,00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00057,History data 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00057,History data 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00059,History data 4,00 00 00 01 01 00 00 FE FF 00 00 FF 00 00 00 00 00 00 00 00 00 0F 46 00 00 00 00 00 00 00 00 00 00 00,
IDE00059,History data 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00059,History data 4,00 13 29 0B 0A 18 01 3A 4A 43 42 34 34 30 39 32 38 53 31 4F 32 01 4B 07 00 00 00 00 00 00 00 00 00 00,
IDE00060,History data 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00061,History data 6,35 10 11 1E 0C 18 00 00 00 00 14 57 57 32 32 7C 00 00 94 01 00 00,
IDE00061,History data 6,34 0D 32 1E 0C 18 00 00 00 00 10 59 59 32 32 72 00 00 94 00 00 00,
IDE00061,History data 6,34 14 0C 1D 0C 18 00 03 00 00 15 5A 5B 36 36 7E 00 00 94 01 00 02,
IDE00061,History data 6,34 0D 32 1E 0C 18 00 00 00 00 14 59 59 32 32 72 00 00 94 01 00 00,
IDE00061,History data 6,34 14 09 1D 0C 18 00 00 00 00 10 5A 5A 36 36 7F 00 00 94 00 00 00,
IDE00061,History data 6,34 14 0C 1D 0C 18 00 05 00 00 10 5A 5A 36 36 7E 00 00 94 00 00 00,
IDE00061,History data 6,35 10 12 1E 0C 18 00 03 00 00 30 57 58 32 32 7C 00 00 94 00 00 00,
IDE00061,History data 6,34 14 09 1D 0C 18 00 05 00 00 15 5A 5A 36 36 7E 00 00 94 01 00 02,
IDE00061,History data 6,35 10 11 1E 0C 18 00 00 00 00 10 57 57 32 32 7C 00 00 94 00 00 00,
IDE00061,History data 6,35 0D 32 1E 0C 18 01 03 01 00 75 59 59 32 32 72 00 00 94 01 00 00,
IDE00062,History data 7,33 12 00 1C 0C 18 00 00 BD 00 00 61 1F 00 00 35 00 00 00 BA 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,35 0D 38 1E 0C 18 00 00 91 00 00 57 19 00 00 32 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,34 12 1B 1C 0C 18 00 00 80 00 00 5F 1C 00 00 37 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,34 14 1C 1C 0C 18 00 00 11 06 00 5A 1A 00 00 36 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,34 14 0E 1D 0C 18 00 00 3C 0A 00 59 19 00 00 32 00 00 01 04 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,35 10 12 1E 0C 18 00 00 91 00 00 57 19 00 00 32 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,30 10 25 1C 0C 18 00 00 6B 00 00 60 1E 00 00 34 00 00 02 53 01 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,32 11 39 1C 0C 18 00 00 BA 00 00 61 1F 00 00 35 00 00 00 03 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,34 14 0B 1D 0C 18 00 00 14 06 00 5A 1A 00 00 36 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00062,History data 7,31 10 26 1C 0C 18 00 00 6B 00 00 60 1E 00 00 34 00 00 02 84 01 00 00 00 00 08 00 00 00 00 00 00 00 00,
IDE00063,History data 8,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00063,History data 8,00 00 00 00 00 00 00 00 00 00 00 00 00 28 00 00 00 00 00 00,
IDE00064,History data 9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00065,History data 10,34 14 0B 1D 0C 18 5D 00 00 00 7D 00 00 00 00 00 00 00 00 00,
IDE00065,History data 10,30 10 25 1C 0C 18 5D 00 00 00 6B 00 00 00 00 00 00 00 00 00,
IDE00065,History data 10,34 14 0E 1D 0C 18 5D 00 00 00 78 00 00 00 02 00 01 00 00 00,
IDE00068,History data 13,69 10 33 0A 0C 18 02 00 01 00 00 00 00 01 00 00 00,
IDE00068,History data 13,67 10 15 0A 0C 18 02 00 01 00 00 00 00 01 00 00 00,
IDE00068,History data 13,66 10 13 0A 0C 18 02 00 01 00 00 00 00 01 00 00 00,
IDE00068,History data 13,6A 10 35 0A 0C 18 03 00 01 00 00 00 00 01 00 00 00,
IDE00068,History data 13,68 10 27 0A 0C 18 02 00 01 00 00 00 00 01 00 00 00,
IDE00071,History data 16,00 00 00 00 00 00 8C 00,
IDE00071,History data 16,00 00 00 00 00 00 02 00,
IDE00071,History data 16,73 01 15 00 10 00 10 00 00 00,
IDE00071,History data 16,0D 01 03 00 00 00 00 00 00 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00 1D 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00 00 00 00 00,
IDE00071,History data 16,00 00 00 00 00 00 17 01,
IDE00071,History data 16,D0 01 00 00 00 00 00,
IDE00071,History data 16,AE 0A C1 03 15 01 0B 00 00 00,
IDE00071,History data 16,1B 01 7F 00 23 00 00 00,
IDE00071,History data 16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE00301,Mileage,464, km
IDE00316-MAS00106,Time-Year,2024,
IDE00316-MAS00107,Time-Month,12,
IDE00316-MAS00108,Time-Day,30,
IDE00316-MAS00109,Time-Hours,11,
IDE00316-MAS00110,Time-Minutes,19,
IDE00316-MAS00111,Time-Seconds,52,
IDE00356,Cruise Control System (CCS): switch position,OFF,
IDE00356-IDE15905,Cruise Control System (CCS): switch position-Travel Assist,Not operated,
IDE00356-MAS00128,Cruise Control System (CCS): switch position-Distance Regulation,Not operated,
IDE00356-MAS00323,Cruise Control System (CCS): switch position-Tap delay,Not operated,
IDE00356-MAS00324,Cruise Control System (CCS): switch position-Tap acceleration,Not operated,
IDE00356-MAS00325,Cruise Control System (CCS): switch position-Set,Not operated,
IDE00356-MAS00326,Cruise Control System (CCS): switch position-Resume,Not operated,
IDE00356-MAS02321,Cruise Control System (CCS): switch position-Cancel,Not operated,
IDE00356-MAS02343,Cruise Control System (CCS): switch position-Station coding,0,
IDE00356-MAS03758,Cruise Control System (CCS): switch position-Not assigned,Not operated,
IDE00356-MAS04522,Cruise Control System (CCS): switch position-Tap deceleration stage 2,Not operated,
IDE00356-MAS05138,Cruise Control System (CCS): switch position-Operating part,none,
IDE00356-MAS05812,Cruise Control System (CCS): switch position-Limit button,not installed,
IDE00356-MAS06029,Cruise Control System (CCS): switch position-MFL message counter,0,
IDE00356-MAS06879,Cruise Control System (CCS): switch position-Checksum,0,
IDE00634,Vehicle electrical system current,21, A
IDE00767-ENG279518,No. of unscheduled ECU resets-Number of Destructive Resets,0,
IDE00767-ENG279519,No. of unscheduled ECU resets-Number of External Watchdog Resets,0,
IDE00767-ENG279520,No. of unscheduled ECU resets-Number of Functional Resets,0,
IDE00767-ENG279521,No. of unscheduled ECU resets-Number of RL78 Resets,0,
IDE01803,History data 17,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE01803,History data 17,01 13 2A 0B 0A 18 A0 21 51 3D 0B 36 03 A6 0B 2D B2 CF 00 00,
IDE01803,History data 17,00 00 00 00 00 00 00 00 00 28 00 00 00 B8 0B 00 00 00 00 00,
IDE01803,History data 17,00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00,
IDE01807-IDE07142,History data 21-Time since terminal 15 off,1.3, H
IDE01807-MAS00106,History data 21-Year,2024,
IDE01807-MAS00107,History data 21-Month,12,
IDE01807-MAS00108,History data 21-Day,28,
IDE01807-MAS00109,History data 21-Hours,17, H
IDE01807-MAS00110,History data 21-Minutes,57, min
IDE01807-MAS14375,History data 21-Cycle counter,315,
IDE01807-MAS14376,History data 21-ECU 1,00 76,
IDE01807-MAS14377,History data 21-Alert maintenance time for ECU 1,1.3, H
IDE01807-MAS14378,History data 21-Repetition counter for ECU 1,0,
IDE01807-MAS14379,History data 21-ECU 2,00 7C,
IDE01807-MAS14380,History data 21-Alert maintenance time for ECU 2,1.3, H
IDE01807-MAS14381,History data 21-Repetition counter for ECU 2,0,
IDE01807-MAS14382,History data 21-ECU 3,00 00,
IDE01807-MAS14383,History data 21-Alert maintenance time for ECU 3,0.0, H
IDE01807-MAS14384,History data 21-Repetition counter for ECU 3,0,
IDE01807-MAS14385,History data 21-ECU 4,00 00,
IDE01807-MAS14386,History data 21-Alert maintenance time for ECU 4,0.0, H
IDE01807-MAS14387,History data 21-Repetition counter for ECU 4,0,
IDE01807-MAS14388,History data 21-ECU 5,00 00,
IDE01807-MAS14389,History data 21-Alert maintenance time for ECU 5,0.0, H
IDE01807-MAS14390,History data 21-Repetition counter for ECU 5,0,
IDE01807-MAS28454,History data 21-Data bus to ECU 1,Powertrain data bus,
IDE01807-MAS28455,History data 21-Data bus to ECU 2,Powertrain data bus,
IDE01807-MAS28456,History data 21-Data bus to ECU 3,Unknown,
IDE01807-MAS28457,History data 21-Data bus to ECU 4,Unknown,
IDE01807-MAS28458,History data 21-Data bus to ECU 5,Unknown,
IDE01808-MAS03173,History data 22-Powertrain data bus,0.1, H
IDE01808-MAS03174,History data 22-Comfort data bus,0.0, H
IDE01808-MAS03176,History data 22-Display and control head databus,0.0, H
IDE01808-MAS03178,History data 22-Suspension data bus,0.0, H
IDE01808-MAS03179,History data 22-Local data bus 2,0.0, H
IDE01808-MAS03180,History data 22-Local data bus,0.0, H
IDE01808-MAS05686,History data 22-Data bus diagnostics,0.0, H
IDE01808-MAS05972,History data 22-Local data bus 3,0.0, H
IDE01808-MAS06525,History data 22-Local data bus 4,0.0, H
IDE01808-MAS06526,History data 22-Local data bus 5,0.0, H
IDE01808-MAS06527,History data 22-Local data bus 6,0.0, H
IDE01808-MAS12183,History data 22-Comfort CAN bus 2,0.0, H
IDE01808-MAS12186,History data 22-AFS/From light data bus,0.0, H
IDE01808-MAS14373,History data 22-All BUS systems,0.1, H
IDE01808-MAS14771,History data 22-Local data bus 7,0.0, H
IDE01808-MAS16909,History data 22-Data bus driver assistance systems,0.0, H
IDE01808-MAS16912,History data 22-VLAN_FAS,0.0, H
IDE01808-MAS16913,History data 22-VLAN_Infotainment,0.0, H
IDE01808-MAS16915,History data 22-VLAN_Komfort,0.0, H
IDE01808-MAS16916,History data 22-VLAN_Powertrain,0.0, H
IDE01808-MAS16917,History data 22-VLAN_Diagnose,0.0, H
IDE01808-MAS17153,History data 22-Data bus connect,0.0, H
IDE01808-MAS18934,History data 22-VLAN Connect,0.1, H
IDE01808-MAS20472,History data 22-VLAN Connect 2,0.0, H
IDE01808-MAS20475,History data 22-Data bus multifunction steering wheel,0.0, H
IDE01808-MAS20476,History data 22-Data bus electrification,0.1, H
IDE01808-MAS20957,History data 22-VLAN_charging,0.0, H
IDE01808-MAS21728,History data 22-VLAN_light,0.0, H
IDE01808-MAS22817,History data 22-Data bus driver assistance systems 2,0.0, H
IDE01808-MAS28451,History data 22-Virtual remote control vehicle key data bus,0.0, H
IDE01809-IDE07142,History data 23-Time since terminal 15 off,14.2, H
IDE01809-MAS00106,History data 23-Year,2024,
IDE01809-MAS00107,History data 23-Month,12,
IDE01809-MAS00108,History data 23-Day,15,
IDE01809-MAS00109,History data 23-Hours,16, H
IDE01809-MAS00110,History data 23-Minutes,55, min
IDE01809-MAS14375,History data 23-Cycle counter,228,
IDE01809-MAS14395,History data 23-Bus with maximum number of post alarms,Comfort data bus,
IDE01809-MAS14396,History data 23-Post alerts in current cycle,87,
IDE01809-MAS14397,History data 23-Rousing ECU 1,00 8C,
IDE01809-MAS14398,History data 23-Number of post alerts for control module 1,55,
IDE01809-MAS14399,History data 23-CarWakeUp bit 1,0,
IDE01809-MAS14400,History data 23-Rousing ECU 2,00 00,
IDE01809-MAS14401,History data 23-Number of post alerts for control module 2,0,
IDE01809-MAS14402,History data 23-CarWakeUp bit 2,0,
IDE01809-MAS14403,History data 23-Rousing ECU 3,00 00,
IDE01809-MAS14404,History data 23-Number of post alerts for control module 3,0,
IDE01809-MAS14405,History data 23-CarWakeUp bit 3,0,
IDE01809-MAS14406,History data 23-Rousing ECU 4,00 00,
IDE01809-MAS14407,History data 23-Number of post alerts for control module 4,0,
IDE01809-MAS14408,History data 23-CarWakeUp bit 4,0,
IDE01809-MAS14409,History data 23-Rousing ECU 5,00 00,
IDE01809-MAS14410,History data 23-Number of post alerts for control module 5,0,
IDE01809-MAS14411,History data 23-CarWakeUp bit 5,0,
IDE01809-MAS28454,History data 23-Data bus to ECU 1,Powertrain data bus,
IDE01809-MAS28455,History data 23-Data bus to ECU 2,Unknown,
IDE01809-MAS28456,History data 23-Data bus to ECU 3,Unknown,
IDE01809-MAS28457,History data 23-Data bus to ECU 4,Unknown,
IDE01809-MAS28458,History data 23-Data bus to ECU 5,Unknown,
IDE01810-IDE07142,History data 24-Time since terminal 15 off,0.0, H
IDE01810-MAS00106,History data 24-Year,2000,
IDE01810-MAS00107,History data 24-Month,1,
IDE01810-MAS00108,History data 24-Day,1,
IDE01810-MAS00109,History data 24-Hours,0, H
IDE01810-MAS00110,History data 24-Minutes,0, min
IDE01810-MAS14375,History data 24-Cycle counter,0,
IDE01810-MAS14392,History data 24-CarWakeUp Bit,0,
IDE01810-MAS14393,History data 24-ID of the alerting message,00 00 00 00,
IDE01810-MAS14394,History data 24-Bus of the alerting message,Unknown,
IDE01810-MAS14412,History data 24-Bus with maximum number of alerts,Unknown,
IDE01810-MAS14413,History data 24-Alert events in current cycle,0,
IDE01810-MAS20473,History data 24-Alerting message counter,0,
IDE01812-MAS01468,History data 26-Terminal 15,320,
IDE01812-MAS03173,History data 26-Powertrain data bus,1,
IDE01812-MAS03174,History data 26-Comfort data bus,76,
IDE01812-MAS03176,History data 26-Display and control head databus,8,
IDE01812-MAS03178,History data 26-Suspension data bus,11,
IDE01812-MAS03180,History data 26-Local data bus,0,
IDE01812-MAS05686,History data 26-Data bus diagnostics,0,
IDE01812-MAS12183,History data 26-Comfort CAN bus 2,0,
IDE01812-MAS12186,History data 26-AFS/From light data bus,241,
IDE01812-MAS14374,History data 26-Totals,763,
IDE01812-MAS16909,History data 26-Data bus driver assistance systems,5,
IDE01812-MAS16917,History data 26-VLAN_Diagnose,0,
IDE01812-MAS17153,History data 26-Data bus connect,203,
IDE01812-MAS20475,History data 26-Data bus multifunction steering wheel,170,
IDE01812-MAS20476,History data 26-Data bus electrification,6,
IDE01812-MAS22817,History data 26-Data bus driver assistance systems 2,6,
IDE01812-MAS28451,History data 26-Virtual remote control vehicle key data bus,0,
IDE01813-MAS03173,History data 27-Powertrain data bus,355,
IDE01813-MAS03174,History data 27-Comfort data bus,1769,
IDE01813-MAS03176,History data 27-Display and control head databus,18,
IDE01813-MAS03178,History data 27-Suspension data bus,221,
IDE01813-MAS12183,History data 27-Comfort CAN bus 2,527,
IDE01813-MAS12186,History data 27-AFS/From light data bus,3,
IDE01813-MAS14374,History data 27-Totals,4318,
IDE01813-MAS16909,History data 27-Data bus driver assistance systems,12,
IDE01813-MAS16912,History data 27-VLAN_FAS,0,
IDE01813-MAS16913,History data 27-VLAN_Infotainment,333,
IDE01813-MAS16915,History data 27-VLAN_Komfort,0,
IDE01813-MAS16916,History data 27-VLAN_Powertrain,0,
IDE01813-MAS17153,History data 27-Data bus connect,394,
IDE01813-MAS18934,History data 27-VLAN Connect,204,
IDE01813-MAS20472,History data 27-VLAN Connect 2,0,
IDE01813-MAS20475,History data 27-Data bus multifunction steering wheel,55,
IDE01813-MAS20476,History data 27-Data bus electrification,424,
IDE01813-MAS20957,History data 27-VLAN_charging,0,
IDE01813-MAS21728,History data 27-VLAN_light,0,
IDE01813-MAS22817,History data 27-Data bus driver assistance systems 2,3,
IDE01813-MAS28451,History data 27-Virtual remote control vehicle key data bus,0,
IDE01814-MAS03173,History data 28-Powertrain data bus,0,
IDE01814-MAS03174,History data 28-Comfort data bus,1520,
IDE01814-MAS03176,History data 28-Display and control head databus,0,
IDE01814-MAS03178,History data 28-Suspension data bus,96,
IDE01814-MAS12183,History data 28-Comfort CAN bus 2,295,
IDE01814-MAS12186,History data 28-AFS/From light data bus,0,
IDE01814-MAS14374,History data 28-Totals,1919,
IDE01814-MAS16909,History data 28-Data bus driver assistance systems,0,
IDE01814-MAS16912,History data 28-VLAN_FAS,0,
IDE01814-MAS16913,History data 28-VLAN_Infotainment,0,
IDE01814-MAS16915,History data 28-VLAN_Komfort,0,
IDE01814-MAS16916,History data 28-VLAN_Powertrain,0,
IDE01814-MAS17153,History data 28-Data bus connect,0,
IDE01814-MAS18934,History data 28-VLAN Connect,0,
IDE01814-MAS20472,History data 28-VLAN Connect 2,0,
IDE01814-MAS20475,History data 28-Data bus multifunction steering wheel,0,
IDE01814-MAS20476,History data 28-Data bus electrification,0,
IDE01814-MAS20957,History data 28-VLAN_charging,0,
IDE01814-MAS21728,History data 28-VLAN_light,0,
IDE01814-MAS22817,History data 28-Data bus driver assistance systems 2,0,
IDE01814-MAS28451,History data 28-Virtual remote control vehicle key data bus,0,
IDE01816-IDE07142,History data 30-Time since terminal 15 off,14.2, H
IDE01816-MAS00106,History data 30-Year,2024,
IDE01816-MAS00107,History data 30-Month,12,
IDE01816-MAS00108,History data 30-Day,15,
IDE01816-MAS00109,History data 30-Hours,16, H
IDE01816-MAS00110,History data 30-Minutes,55, min
IDE01816-MAS14375,History data 30-Cycle counter,228,
IDE01816-MAS28463,History data 30-Data bus 1,Powertrain data bus,
IDE01816-MAS28464,History data 30-Data bus 2,Data bus electrification,
IDE01816-MAS28465,History data 30-Data bus 3,VLAN Connect,
IDE01816-MAS28467,History data 30-Data bus 4,VLAN_Infotainment,
IDE01816-MAS28470,History data 30-Data bus 5,Unknown,
IDE01816-MAS28474,History data 30-Active time for data bus 1,14.2, H
IDE01816-MAS28475,History data 30-Active time for data bus 2,1.2, H
IDE01816-MAS28476,History data 30-Active time for data bus 3,0.1, H
IDE01816-MAS28477,History data 30-Active time for data bus 4,0.1, H
IDE01816-MAS28478,History data 30-Active time for data bus 5,0.0, H
IDE01817-IDE07142,History data 31-Time since terminal 15 off,1.3, H
IDE01817-MAS00106,History data 31-Year,2024,
IDE01817-MAS00107,History data 31-Month,12,
IDE01817-MAS00108,History data 31-Day,28,
IDE01817-MAS00109,History data 31-Hours,17, H
IDE01817-MAS00110,History data 31-Minutes,57, min
IDE01817-MAS14375,History data 31-Cycle counter,315,
IDE01817-MAS14376,History data 31-ECU 1,00 76,
IDE01817-MAS14377,History data 31-Alert maintenance time for ECU 1,1.3, H
IDE01817-MAS14378,History data 31-Repetition counter for ECU 1,0,
IDE01817-MAS14379,History data 31-ECU 2,00 7C,
IDE01817-MAS14380,History data 31-Alert maintenance time for ECU 2,1.3, H
IDE01817-MAS14381,History data 31-Repetition counter for ECU 2,0,
IDE01817-MAS14382,History data 31-ECU 3,00 00,
IDE01817-MAS14383,History data 31-Alert maintenance time for ECU 3,0.0, H
IDE01817-MAS14384,History data 31-Repetition counter for ECU 3,0,
IDE01817-MAS14385,History data 31-ECU 4,00 00,
IDE01817-MAS14386,History data 31-Alert maintenance time for ECU 4,0.0, H
IDE01817-MAS14387,History data 31-Repetition counter for ECU 4,0,
IDE01817-MAS14388,History data 31-ECU 5,00 00,
IDE01817-MAS14389,History data 31-Alert maintenance time for ECU 5,0.0, H
IDE01817-MAS14390,History data 31-Repetition counter for ECU 5,0,
IDE01817-MAS28454,History data 31-Data bus to ECU 1,Powertrain data bus,
IDE01817-MAS28455,History data 31-Data bus to ECU 2,Powertrain data bus,
IDE01817-MAS28456,History data 31-Data bus to ECU 3,Unknown,
IDE01817-MAS28457,History data 31-Data bus to ECU 4,Unknown,
IDE01817-MAS28458,History data 31-Data bus to ECU 5,Unknown,
IDE01818-IDE07142,History data 32-Time since terminal 15 off,14.2, H
IDE01818-MAS00106,History data 32-Year,2024,
IDE01818-MAS00107,History data 32-Month,12,
IDE01818-MAS00108,History data 32-Day,15,
IDE01818-MAS00109,History data 32-Hours,16, H
IDE01818-MAS00110,History data 32-Minutes,55, min
IDE01818-MAS14375,History data 32-Cycle counter,228,
IDE01818-MAS14391,History data 32-Alerting ECU,00 8C,
IDE01818-MAS14392,History data 32-CarWakeUp Bit,0,
IDE01818-MAS20474,History data 32-Cluster,00 00 03,
IDE01819-IDE07142,History data 33-Time since terminal 15 off,0.0, H
IDE01819-MAS00106,History data 33-Year,2000,
IDE01819-MAS00107,History data 33-Month,1,
IDE01819-MAS00108,History data 33-Day,1,
IDE01819-MAS00109,History data 33-Hours,0, H
IDE01819-MAS00110,History data 33-Minutes,0, min
IDE01819-MAS14375,History data 33-Cycle counter,0,
IDE01819-MAS14393,History data 33-ID of the alerting message,00 00 00 00,
IDE01819-MAS14394,History data 33-Bus of the alerting message,Unknown,
IDE01819-MAS20474,History data 33-Cluster,00 00 00,
IDE01820-IDE07142,History data 34-Time since terminal 15 off,2.4, H
IDE01820-MAS00106,History data 34-Year,2024,
IDE01820-MAS00107,History data 34-Month,12,
IDE01820-MAS00108,History data 34-Day,30,
IDE01820-MAS00109,History data 34-Hours,16, H
IDE01820-MAS00110,History data 34-Minutes,18, min
IDE01820-MAS14375,History data 34-Cycle counter,319,
IDE01820-MAS14393,History data 34-ID of the alerting message,1B 00 00 4A,
IDE01823-IDE07142,History data 37-Time since terminal 15 off,0.0, H
IDE01823-MAS00106,History data 37-Year,2000,
IDE01823-MAS00107,History data 37-Month,1,
IDE01823-MAS00108,History data 37-Day,1,
IDE01823-MAS00109,History data 37-Hours,0, H
IDE01823-MAS00110,History data 37-Minutes,0, min
IDE01823-MAS01632,History data 37-Status,activated,
IDE01823-MAS14375,History data 37-Cycle counter,320,
IDE01823-MAS14429,History data 37-Time in current cycle,0.0, H
IDE01848,Energy balance of last driving cycle,0.3, Ah
IDE01848-IDE01849,Energy balance of last driving cycle-Previous journey duration,0.0, H
IDE01995-ENG103538,Control module protocol information-ECUs DiagProt,|ISO-TP,TP 2.0,TP 1.6,K Line,Ethernet|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|No,No,No,No,No|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|Yes,No,No,No,Yes|No,No,No,No,No|,
IDE03527-MAS05102,CAN signals-Driver information: emergency shutdown,not active,
IDE03527-MAS10895,CAN signals-Driver information key position copy workshop,not active,
IDE04329-ENG118721,Status of all SWaP functions-SWaP_function_state array,|ID number,Release code for a SWaP function,Cancellation,Individualization characteristic,Preconditions met,Configuration,Functions,Authentication|10 13 14 00,available.,No,valid,Condition met,OK,available.,Condition met|10 13 17 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 18 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 19 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 1A 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 1B 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 1C 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 1D 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 01 00,available.,No,valid,Condition met,OK,available.,Condition met|10 13 03 00,available.,No,valid,Condition met,OK,available.,Condition met|10 13 05 00,available.,No,valid,Condition met,OK,available.,Condition met|10 13 07 00,available.,No,valid,Condition met,OK,available.,Condition met|10 13 13 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 22 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 1E 00,available.,No,valid,Condition met,OK,available.,Condition met|10 13 21 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 13 23 00,available.,No,valid,Condition met,OK,available.,Condition met|10 13 20 00,available.,No,valid,Condition met,OK,available.,Condition met|10 13 1F 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 02 0E 00,available.,No,valid,Condition met,OK,available.,Condition met|10 02 0F 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 02 03 00,available.,No,valid,Condition met,OK,available.,Condition met|00 06 01 00,available.,No,valid,Condition met,OK,available.,Condition met|00 04 01 00,available.,No,valid,Condition met,OK,available.,Condition met|00 07 17 00,available.,No,valid,Condition met,OK,available.,Condition met|00 07 18 00,available.,No,valid,Condition met,OK,available.,Condition met|00 07 1C 00,available.,No,valid,Condition met,OK,available.,Condition met|00 07 1B 00,available.,No,valid,Condition met,OK,available.,Condition met|10 05 03 00,available.,No,valid,Condition met,OK,available.,Condition met|10 05 01 00,available.,No,valid,Condition met,OK,available.,Condition met|10 05 02 00,available.,No,valid,Condition met,OK,available.,Condition met|10 05 05 00,available.,No,valid,Condition met,OK,available.,Condition met|10 0E 0F 00,available.,No,valid,Condition met,OK,available.,Condition met|10 01 01 00,available.,No,valid,Condition met,OK,available.,Condition met|10 01 02 00,available.,No,valid,Condition met,OK,available.,Condition met|10 01 04 00,available.,No,valid,Condition met,OK,available.,Condition met|10 01 05 00,available.,No,valid,Condition met,OK,available.,Condition met|00 07 1A 00,available.,No,valid,Condition met,OK,Not available,Condition met|10 13 16 00,available.,No,valid,Condition met,OK,available.,Condition met|10 07 17 00,available.,No,valid,Condition met,OK,available.,Condition met|10 0E 06 00,available.,No,valid,Condition met,OK,available.,Condition met|10 01 03 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 01 06 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 01 07 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 01 08 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 01 09 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 01 0A 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 0E 10 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 0E 0D 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|10 0E 08 00,Not available,No,invalid,Condition not met,OK,available.,Condition not met|,
IDE04332-ENG117770,Release code for a SWaP function-fsc,Not available,
IDE04343-ENG299091,Bus identification-ECU_databus_identification,|bus_number,bus_type|0,Bus master|0,Bus master|3,CAN|3,CAN|19,CAN|3,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|19,CAN|0,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,CAN|0,Bus master|0,Bus master|2,VLAN|0,Bus master|0,Bus master|0,Bus master|18,CAN|0,Bus master|8,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|8,CAN|18,CAN|1,CAN|1,CAN|6,Unknown (13)|6,Unknown (13)|6,Unknown (13)|0,Bus master|0,VLAN|0,Bus master|3,CAN|0,Bus master|0,Bus master|1,CAN|1,CAN|0,Bus master|0,Bus master|6,Unknown (13)|0,Bus master|20,CAN|6,Unknown (13)|20,CAN|1,CAN|0,Bus master|6,Unknown (13)|1,CAN|1,CAN|1,CAN|1,CAN|25,CAN|16,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,VLAN|0,Bus master|19,CAN|0,Bus master|0,Bus master|0,Bus master|18,CAN|0,VLAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|9,CAN|0,Bus master|0,Bus master|2,VLAN|0,Bus master|25,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|16,CAN|1,VLAN|0,Bus master|0,Bus master|3,CAN|19,CAN|0,Bus master|0,Bus master|0,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|20,CAN|0,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|9,CAN|9,CAN|1,CAN|0,Bus master|0,Bus master|1,CAN|1,CAN|6,Unknown (13)|0,Bus master|0,Bus master|0,CAN|0,Bus master|18,CAN|6,Unknown (13)|0,Bus master|0,Bus master|0,VLAN|0,Bus master|0,Bus master|0,Bus master|9,CAN|9,CAN|9,CAN|9,CAN|0,Bus master|9,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|8,CAN|8,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|9,VLAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,CAN|20,CAN|18,CAN|0,Bus master|0,Bus master|0,Bus master|1,VLAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|25,CAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,VLAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|1,VLAN|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|0,Bus master|18,CAN|18,CAN|18,CAN|18,CAN|18,CAN|1,VLAN|2,VLAN|1,VLAN|19,CAN|25,CAN|25,CAN|1,CAN|0,Bus master|8,CAN|0,Bus master|,
IDE04806-ENG137100,Driving profile selection button-Driving_Profile_Selection_Button_1,Not operated,
IDE04806-ENG137101,Driving profile selection button-Driving_Profile_Selection_Button_2,Not operated,
IDE04806-ENG137102,Driving profile selection button-Driving_Profile_Selection_Button_3,Not operated,
IDE04806-ENG137103,Driving profile selection button-Driving_Profile_Selection_Button_4,Not operated,
IDE04806-ENG137104,Driving profile selection button-Driving_Profile_Selection_Button_5,Not operated,
IDE04806-ENG137105,Driving profile selection button-Driving_Profile_Selection_Button_6,Not operated,
IDE04806-ENG137106,Driving profile selection button-Driving_Profile_Selection_Button_7,Not operated,
IDE04806-ENG137107,Driving profile selection button-Driving_Profile_Selection_Button_8,Not operated,
IDE05740-MAS05376,Driving profile selection: system status-Coordinator status,active,
IDE05740-ENG256034,Driving profile selection: system status-link_state,not engaged,
IDE05740-ENG256107,Driving profile selection: system status-operation_state,engaged,
IDE05740-ENG255187,Driving profile selection: system status-profile_state,engaged,
IDE05814,Individualization characteristic,DA 19 F5 79 97,
IDE06011-ENG118665,Selected driving profile-driving_profile,Comfort,
IDE06011-ENG256033,Selected driving profile-link_profile,link_profile_1,
IDE06011-ENG157286,Selected driving profile-Operation_mode,Unknown (0),
IDE06165-MAS06193,Driving profile selection statistics-Profile 1,184877056, min
IDE06165-MAS06194,Driving profile selection statistics-Profile 2,0, min
IDE06165-MAS06195,Driving profile selection statistics-Profile 3,117440512, min
IDE06165-MAS06196,Driving profile selection statistics-Profile 4,0, min
IDE06165-MAS06197,Driving profile selection statistics-Profile 5,0, min
IDE06165-MAS06198,Driving profile selection statistics-Profile 6,0, min
IDE06165-MAS06199,Driving profile selection statistics-Profile 7,0, min
IDE06165-MAS06200,Driving profile selection statistics-Profile 8,0, min
IDE06165-MAS08875,Driving profile selection statistics-Profile 9,0, min
IDE06165-MAS08876,Driving profile selection statistics-Profile 10,0, min
IDE06165-MAS08877,Driving profile selection statistics-Profile 11,0, min
IDE06165-MAS08878,Driving profile selection statistics-Profile 12,0, min
IDE06592-MAS18012,Status: special functions-Vehicle locking and unlocking via mobile online service,lock,
IDE06592-MAS18013,Status: special functions-Deactivation of extended start authentication,OFF,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,07,
IDE07145-MAS06776,Component protection properties-Komponent protection role,KS Master,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,80,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 6,
IDE07184-MAS06023,MFL button for freely assignable function-Parameter actuation of Joker FPA button,Not operated,
IDE07184-MAS06024,MFL button for freely assignable function-Parameter programming of Joker FPA button,not active,
IDE07628-IDE07629,Status power receptacle-Function release power receptacle,Enabled,
IDE07628-IDE07630,Status power receptacle-Pre-warning power receptacle,not active,
IDE07628-MAS01581,Status power receptacle-Power consumption,0, W
IDE07628-MAS06331,Status power receptacle-Enabling self-contained operation,locked,
IDE07628-MAS06332,Status power receptacle-Status function readiness,Enabled,
IDE07628-MAS06333,Status power receptacle-Status function,OFF,
IDE07628-MAS06334,Status power receptacle-Status overtemperature,in correct range,
IDE07628-MAS06341,Status power receptacle-After-run for power receptacle,not active,
IDE07636-MAS03001,Status hybrid DC/DC converter-Mode,2,
IDE07636-MAS04063,Status hybrid DC/DC converter-Malfunction in D/C-D/C converter,0,
IDE07636-MAS06335,Status hybrid DC/DC converter-Voltage low voltage side DCDC - converter,15.1, V
IDE07636-MAS06336,Status hybrid DC/DC converter-Current current DCDC - converter,28, A
IDE08162-MAS06256,TSG driver side: signals for central locking-Status door lock,locked,
IDE08162-MAS06266,TSG driver side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08162-MAS06431,TSG driver side: signals for central locking-Door contact switch,closed,
IDE08162-MAS06432,TSG driver side: signals for central locking-Button for interior lock,Not operated,
IDE08162-MAS06433,TSG driver side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08163-MAS06256,TSG frt.pass.side: signals for central locking-Status door lock,locked,
IDE08163-MAS06266,TSG frt.pass.side: signals for central locking-Open contact switch in locking cylinder,Not operated,
IDE08163-MAS06431,TSG frt.pass.side: signals for central locking-Door contact switch,closed,
IDE08163-MAS06432,TSG frt.pass.side: signals for central locking-Button for interior lock,Not operated,
IDE08163-MAS06433,TSG frt.pass.side: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08164-MAS06256,TSG driver side rear: signals for central locking-Status door lock,unlocked,
IDE08164-MAS06431,TSG driver side rear: signals for central locking-Door contact switch,closed,
IDE08164-MAS06432,TSG driver side rear: signals for central locking-Button for interior lock,Not operated,
IDE08164-MAS06433,TSG driver side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08165-MAS06256,TSG frt.pass. side rear: signals for central locking-Status door lock,unlocked,
IDE08165-MAS06431,TSG frt.pass. side rear: signals for central locking-Door contact switch,closed,
IDE08165-MAS06432,TSG frt.pass. side rear: signals for central locking-Button for interior lock,Not operated,
IDE08165-MAS06433,TSG frt.pass. side rear: signals for central locking-Door lock: safe status,Door lock: not safe,
IDE08235-MAS00084,Status of immobilizer participant-Terminal 15 on,Yes,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,1C,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,F8,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,F8,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08235-MAS10135,Status of immobilizer participant-Terminal 15 on via login,No,
IDE08235-MAS10136,Status of immobilizer participant-Key in position terminal 15,Yes,
IDE08235-MAS10137,Status of immobilizer participant-Key in position S,Yes,
IDE08235-MAS10138,Status of immobilizer participant-Key locked,No,
IDE08235-MAS10139,Status of immobilizer participant-Key adapted,No,
IDE08235-MAS10140,Status of immobilizer participant-Key authorized,No,
IDE08235-MAS10141,Status of immobilizer participant-Immobilizer status bit 0,0,
IDE08235-MAS10142,Status of immobilizer participant-Immobilizer status bit 1,0,
IDE08235-MAS10143,Status of immobilizer participant-Debug mode,not active,
IDE08235-MAS10144,Status of immobilizer participant-Immobilizer status bit 3,0,
IDE08235-MAS10145,Status of immobilizer participant-Immobilizer status bit 4,0,
IDE08235-MAS10146,Status of immobilizer participant-Immobilizer status bit 5,0,
IDE08235-MAS10147,Status of immobilizer participant-Immobilizer status bit 6,0,
IDE08235-MAS10148,Status of immobilizer participant-Immobilizer status bit 7,0,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,0, min
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,0, min
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,0, min
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,0, min
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,0, min
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,0, min
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 00 02,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,06,
IDE08238,Transponder ID current Key,00 00 00 00,
IDE08239,Transponder ID Key 1,4D D5 87 B1,
IDE08240,Transponder ID Key 2,9C D5 87 B1,
IDE08251-IDE80258,Configuration immobilizer-Immobilizer status,00 00,
IDE08251-MAS01159,Configuration immobilizer-Version number,00,
IDE08251-MAS01483,Configuration immobilizer-Software version,00 00 00,
IDE08251-MAS06847,Configuration immobilizer-Snapshot,00 00 00 00 00 00 00 00,
IDE08251-MAS06848,Configuration immobilizer-Power class 2,00,
IDE08251-MAS06849,Configuration immobilizer-Supported power classes,00,
IDE08251-MAS11095,Configuration immobilizer-Cause,00 00 00,
IDE08252-MAS06854,Test sum of adapted transponder-Version,81,
IDE08252-MAS06855,Test sum of adapted transponder-Test sum,13 89 F3 FB,
IDE08343,Immobilizer Challenge,87 A8 C1 BB,
IDE09058-IDE01845,Energy management: consumer releases-Reduce internal fan request,no request,
IDE09058-IDE06233,Energy management: consumer releases-Auxiliary heater: controlled,0, W
IDE09058-IDE06234,Energy management: consumer releases-Auxiliary heater: in stages,not enabled,
IDE09058-IDE80251,Energy management: consumer releases-Head area heater,Enabling stage 3,
IDE09058-MAS01490,Energy management: consumer releases-Energy management,not active,
IDE09058-MAS01535,Energy management: consumer releases-Rear window defogger,Enabled,
IDE09058-MAS01564,Energy management: consumer releases-Front windshield heater,1240, W
IDE09058-MAS05213,Energy management: consumer releases-Mirror heater,Enabled,
IDE09058-MAS05214,Energy management: consumer releases-Steering wheel heating,Enabled,
IDE09058-MAS05795,Energy management: consumer releases-Rear seat heater,Enabling stage 3,
IDE09058-MAS06552,Energy management: consumer releases-Front seat heating,Enabling stage 3,
IDE09058-MAS06553,Energy management: consumer releases-Display consumer switch-off,not active,
IDE09058-MAS14071,Energy management: consumer releases-Seat ventilation: rear,Enabling stage 3,
IDE09058-MAS20117,Energy management: consumer releases-Front seat ventilation,Enabling stage 3,
IDE09058-MAS21177,Energy management: consumer releases-Shut-off status,not active,
IDE09074-MAS01078,Vehicle properties-Vehicle model,Electric vehicle,
IDE09074-MAS08256,Vehicle properties-Max energy content,86450, Wh
IDE09074-MAS08262,Vehicle properties-Vehicle type recognition,performed without error,
IDE09075-MAS08266,Calculation: basic average values-Average consumption:BMS electrical (prognosis limit),21.2, kWh/100 km
IDE09075-MAS08267,Calculation: basic average values-Range average consumption: combustion engine,0.0, l/100km
IDE09075-MAS08268,Calculation: basic average values-Range average consumption: electrical,18.1, kWh/100 km
IDE09075-MAS08269,Calculation: basic average values-Calculated average speed: electrical trip,52.5, km/h
IDE09075-MAS08271,Calculation: basic average values-Calculated power: component A/C,0, W
IDE09075-MAS08272,Calculation: basic average values-Calculated power: low voltage basic consumer,100, W
IDE09075-MAS09165,Calculation: basic average values-medium forecast error performance air-conditioning interior,0, W
IDE09075-MAS10152,Calculation: basic average values-Range average consumption CNG,0.0, l/100km
IDE09075-MAS10153,Calculation: basic average values-Range average consumption LPG,0.0, kWh/100 km
IDE09076-MAS08273,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining the range: combustion engine,0, km
IDE09076-MAS08274,Calculated filtered remaining ranges (internal)-Calculated and filtered electrical remaining range,267, km
IDE09076-MAS08275,Calculated filtered remaining ranges (internal)-Average current load profile provided by battery,51, A
IDE09076-MAS10154,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: CNG,0, km
IDE09076-MAS10155,Calculated filtered remaining ranges (internal)-Calculated and filtered remaining range: LPG,0, km
IDE09077-MAS08276,Calculated filtered remaining ranges (CAN)-Total remaining range,267, km
IDE09077-MAS08277,Calculated filtered remaining ranges (CAN)-Filtered remaining range: combustion engine,0, km
IDE09077-MAS08278,Calculated filtered remaining ranges (CAN)-Filtered remaining range: electric motor,267, km
IDE09077-MAS10156,Calculated filtered remaining ranges (CAN)-Filtered remaining range CNG,0, km
IDE09077-MAS10157,Calculated filtered remaining ranges (CAN)-Filtered remaining range LPG,0, km
IDE09078-MAS08279,Calculated remaining ranges (display values)-Total remaining range: displayed value,166,
IDE09078-MAS08280,Calculated remaining ranges (display values)-Remaining range: displayed value: primary drive,166,
IDE09078-MAS08281,Calculated remaining ranges (display values)-Remaining range: displayed value: secondary drive,0,
IDE09078-MAS08282,Calculated remaining ranges (display values)-Remaining range display value units,miles,
IDE09079-MAS10158,Calculated street class consumptions-Average fuel consumption on street class 0,0.0, l/100km
IDE09079-MAS10159,Calculated street class consumptions-Average fuel consumption on street class 1,0.0, l/100km
IDE09079-MAS10160,Calculated street class consumptions-Average fuel consumption on street class 2,0.0, l/100km
IDE09079-MAS10161,Calculated street class consumptions-Average fuel consumption on street class 3,0.0, l/100km
IDE09079-MAS10162,Calculated street class consumptions-Average fuel consumption on street class 4,0.0, l/100km
IDE09079-MAS10163,Calculated street class consumptions-Average fuel consumption on street class 5,0.0, l/100km
IDE09079-MAS10164,Calculated street class consumptions-Average fuel consumption on street class 6,0.0, l/100km
IDE09079-MAS10165,Calculated street class consumptions-Electrical average consumption on Street Class 0,19.3, kWh/100 km
IDE09079-MAS10166,Calculated street class consumptions-Electrical average consumption on Street Class 1,17.1, kWh/100 km
IDE09079-MAS10167,Calculated street class consumptions-Electrical average consumption on Street Class 2,15.9, kWh/100 km
IDE09079-MAS10168,Calculated street class consumptions-Electrical average consumption on Street Class 3,16.5, kWh/100 km
IDE09079-MAS10169,Calculated street class consumptions-Electrical average consumption on Street Class 4,18.0, kWh/100 km
IDE09079-MAS10170,Calculated street class consumptions-Electrical average consumption on Street Class 5,19.3, kWh/100 km
IDE09079-MAS10171,Calculated street class consumptions-Electrical average consumption on Street Class 6,0.0, kWh/100 km
IDE09080-MAS08264,Energy storage unit-Tank contents: conventional fuel including RWB-internal deduct,0.0, l
IDE09080-MAS08265,Energy storage unit-Energy content of HV battery: RWB-internal deduction,52000, Wh
IDE09080-MAS10150,Energy storage unit-CNG tank volume incl. RWB inter. deduct. value,0.0, kg
IDE09080-MAS10151,Energy storage unit-LPG tank volume incl. RWB inter. deduct. value,0.0, l
IDE10300,OBD Driving Cycle detected,active,
IDE10739-IDE04447,Status: driving profile selection for oper. mode selection-Function status,engaged,
IDE10739-IDE06260,Status: driving profile selection for oper. mode selection-ID number,9,
IDE10739-MAS01156,Status: driving profile selection for oper. mode selection-Communication status,OK,
IDE10739-MAS01447,Status: driving profile selection for oper. mode selection-Act.val.,0,
IDE10779-IDE15221,Ethernet signal quality-Number of signal quality measured values,12,
IDE10779-MAS01159,Ethernet signal quality-Version number,00,
IDE10779,Ethernet signal quality,|Ethernet interface,|2,good: link available|3,good: link available|4,good: link available|5,no link|6,no link|7,no link|8,no link|10,no link|11,good: link available|12,good: link available|13,no link|16,no link|,
IDE10780,Ethernet counter connection interruptions,12,
IDE10780-MAS01159,Ethernet counter connection interruptions-Version number,00,
IDE10780,Ethernet counter connection interruptions,|Ethernet interface,|2,0|3,0|4,0|5,0|6,0|7,0|8,0|10,0|11,0|12,0|13,0|16,0|,
IDE10781-MAS01159,Ethernet counter checksum malfunction-Version number,00,
IDE10781-MAS11933,Ethernet counter checksum malfunction-Counter CRC error,12,
IDE10781,Ethernet counter checksum malfunction,|Ethernet interface,|2,0|3,0|4,0|5,0|6,0|7,0|8,0|10,0|11,0|12,0|13,0|16,0|,
IDE11127-IDE04332,Error-causing FS ID with status-Release code for a SWaP function,Not available,
IDE11127-IDE05814,Error-causing FS ID with status-Individualization characteristic,invalid,
IDE11127-IDE06260,Error-causing FS ID with status-ID number,00 00 00 00,
IDE11127-MAS01340,Error-causing FS ID with status-Functions,Not available,
IDE11127-MAS01903,Error-causing FS ID with status-Configuration,not OK,
IDE11127-MAS02934,Error-causing FS ID with status-Preconditions met,Condition not met,
IDE11127-MAS05616,Error-causing FS ID with status-Cancellation,Yes,
IDE11127-MAS05617,Error-causing FS ID with status-Authentication,Condition not met,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 0B 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 6B|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0F|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 17|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 47|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 45|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0D|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 63|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 59|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 13|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 58|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 6E|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 6F|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 37|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 FE|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 82|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 50|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 6A|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 08|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 42|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0E|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 77|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 7F|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0A|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 55|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 67|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 3B|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 10|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 1A|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0C|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 04 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 45|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 70|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 78|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 9C|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 2F|FF 14 00 00 00 00 00 00 00 00 00 00 00 05 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 16|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 11|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 1B|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 19|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|4|11|3|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,26434,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 10 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|02 7D FA 00 10 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2305|44 20 63 0B 99 4E,FD 53 7C B8 03 83 08 10 00 00 00 00 00 04 00 10,2064|02 7D FA 00 10 01,FD 53 7C B8 03 83 08 10 00 00 00 00 00 08 00 10,2064|44 20 63 0B 99 4E,FD 53 7C B8 03 83 00 02 00 00 00 00 00 04 00 10,2|02 7D FA 00 10 01,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,2|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,2|74 90 50 00 00 00,FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F,2|02 7D FA 00 57 00,FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57,2|44 3C 88 6B 00 D6,FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69,2|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 01 07,2|44 20 63 0B 99 4E,FD 53 7C B8 03 83 00 03 00 00 00 00 00 04 00 10,3|02 7D FA 01 08 00,FE 80 00 00 00 00 00 00 00 7D FA FF FE 01 08 00,3|02 7D FA 00 73 00,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,3|02 7D FA 01 06 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,3|02 7D FA 01 08 00,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 08,3|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,3|02 7D FA 00 10 01,FD 53 7C B8 03 83 00 03 00 00 00 00 00 08 00 10,3|02 7D FA 01 06 00,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 06,3|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 01 07,3|02 7D FA 00 10 01,FE 80 00 00 00 00 00 00 00 7D FA FF FE 00 10 01,3|02 7D FA 01 06 00,FE 80 00 00 00 00 00 00 00 7D FA FF FE 01 06 00,3|02 7D FA 01 07 00,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 01 07,4|44 20 63 0B 99 4E,FD 53 7C B8 03 83 00 04 00 00 00 00 00 04 00 10,4|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,4|02 7D FA 01 07 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,4|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 08,4|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 FC 10,4|30 0E B8 DA 35 44,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,4|02 7D FA 00 10 01,FD 53 7C B8 03 83 00 04 00 00 00 00 00 08 00 10,4|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 06,4|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F,4|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57,4|02 7D FA 01 07 00,FE 80 00 00 00 00 00 00 00 7D FA FF FE 01 07 00,4|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,11|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 08,11|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,11|02 7D FA 00 10 01,FD 53 7C B8 03 83 00 0B 00 00 00 00 00 08 00 10,11|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 06,11|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 0B 00 00 00 00 00 00 FC 10,11|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57,11|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 01 07,11|,
IDE11989-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 2-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE11990-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 3-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE11991-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 4-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE11993-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 6-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE11994-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 7-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE11995-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 8-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE12084-IDE02185,Component protection participant status-IKA key,not stored,
IDE12084-IDE10163,Component protection participant status-Authorization status,valid authentication,
IDE12084-MAS06772,Component protection participant status-Component protection generation,internal,
IDE12084-MAS13795,Component protection participant status-Node address,00 00,
IDE12084-MAS16977,Component protection participant status-Shut-off of the start authentication,not locked,
IDE12084-MAS16978,Component protection participant status-Start authentication,switched on,
IDE12084-MAS18011,Component protection participant status-Query message,Not sent,
IDE12084-ENG157306,Component protection participant status-Status_of_component_protection_slaves,|Node address,IKA key,Query message,Variant,Authorization status,Prioritisation|00 57,stored,Sent,KS Slave,valid authentication,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|15 20,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,not stored,Sent,Component protection participant of the extended Start authentication,not authenticated,prioritized|13 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 6F,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|73 20,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,stored,Sent,KS Slave,invalid authentication,prioritized|17 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 8A,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,not stored,Not sent,KS Slave,valid authentication,Not prioritized|0E 20,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,stored,Sent,Component protection participant of the extended Start authentication,not authenticated,prioritized|13 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 14,not stored,Not sent,KS Slave,incompletely authenticated,Not prioritized|00 00,stored,Not sent,KS Slave,not authenticated,Not prioritized|08 13,not stored,Not sent,KS Slave,not authenticated,Not prioritized|00 00,stored,Not sent,Component protection participant of the extended Start authentication,incompletely authenticated,prioritized|20 00,not stored,Not sent,KS Slave,not authenticated,Not prioritized|,
IDE12231-MAS14856,IP network: VLANs of Ethernet switch ports branch 2-VLAN,|VLAN|2|,
IDE12232-MAS14856,IP network: VLANs of Ethernet switch ports branch 3-VLAN,|VLAN|2|,
IDE12233-MAS14856,IP network: VLANs of Ethernet switch ports branch 4-VLAN,|VLAN|2|,
IDE12235-MAS14856,IP network: VLANs of Ethernet switch ports branch 6-VLAN,|VLAN|3|,
IDE12236-MAS14856,IP network: VLANs of Ethernet switch ports branch 7-VLAN,|VLAN|2|,
IDE12237-MAS14856,IP network: VLANs of Ethernet switch ports branch 8-VLAN,Write only channel,
IDE12238,I network: discarded messages counter,17671,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 C9,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 01 01 6A,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 01 01 6B,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 01 01 6C,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 01 01 6D,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 03 AA,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 39,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 6F,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 14,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 06,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 08,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,Test not yet carried out|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67,Test not yet carried out|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 01 07,Test not yet carried out|FD 53 7C B8 03 83 00 0B 00 00 00 00 00 00 00 BA,Test not yet carried out|,
IDE12262-MAS14182,Virtual radio key: status-Master key coded,No,
IDE12262-MAS14183,Virtual radio key: status-Virtual radio key active,No,
IDE12262-MAS14184,Virtual radio key: status-Number of secure elements in the ticket table,31,
IDE12264-MAS14185,Virtual radio key: ticket table-Ticket 1,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14186,Virtual radio key: ticket table-Ticket 2,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14187,Virtual radio key: ticket table-Ticket 3,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14188,Virtual radio key: ticket table-Ticket 4,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14189,Virtual radio key: ticket table-Ticket 5,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14190,Virtual radio key: ticket table-Ticket 6,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14191,Virtual radio key: ticket table-Ticket 7,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14192,Virtual radio key: ticket table-Ticket 8,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14193,Virtual radio key: ticket table-Ticket 9,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14194,Virtual radio key: ticket table-Ticket 10,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14195,Virtual radio key: ticket table-Ticket 11,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14196,Virtual radio key: ticket table-Ticket 12,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14197,Virtual radio key: ticket table-Ticket 13,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14198,Virtual radio key: ticket table-Ticket 14,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14199,Virtual radio key: ticket table-Ticket 15,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12264-MAS14200,Virtual radio key: ticket table-Ticket 16,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE12609-MAS02832,Steering wheel touch recognition: status-Malfunction status,No malfunction detected,
IDE12609-MAS14836,Steering wheel touch recognition: status-Touch intensity sensor 1,35,
IDE12609-MAS14837,Steering wheel touch recognition: status-Touch intensity sensor 2,43,
IDE12609-MAS14838,Steering wheel touch recognition: status-Touch intensity sensor 3,50,
IDE12609-MAS14839,Steering wheel touch recognition: status-Touch status,not touching,
IDE12633,IP Network maximum correction of the synchronized clock,0, µs
IDE12806-ENG299124,Diagnostic capability of the bus interface-Diag_paths,|Diag_path Bit 0,Diag_path Bit 1,Diag_path Bit 2,Diag_path Bit 3,Diag_path Bit 4,Diag_path Bit 5,Diag_path Bit 6,Diag_path Bit 7|Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable|Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable|Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable,Control module/bus interface diagnostics capable,Control module/bus interface not diagnostics capable|,
IDE12807-ENG299127,Participant authenticity-Ecu_authentications,|Ecu_authentication Bit 0,Ecu_authentication Bit 1,Ecu_authentication Bit 2,Ecu_authentication Bit 3,Ecu_authentication Bit 4,Ecu_authentication Bit 5,Ecu_authentication Bit 6,Ecu_authentication Bit 7|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic,Control module/bus interface authentic|,
IDE12844-ENG299092,Installation list of the 10 bit node addresses-Node_addresses,|Node address,ECM name,ECU ID|00 10,Data Bus OBD Interface,25|00 00,Unknown (0),255|00 12,Power steering,37|00 13,Brake electronics,3|00 14,Instrument cluster,3|00 15,Airbag,21|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 1B,Head-Up-Display,40|00 1C,Structure-borne sound actuator,130|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 23,Rear lid electronics,109|00 00,Unknown (0),255|00 00,Unknown (0),255|01 26,Application server 1 System 4 IoT,33097|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|01 2A,Access/start authorization 2,33100|00 00,Unknown (0),255|00 2C,Special Function,48|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 31,Steering column lock,32|00 32,Interface for access/start system,43|00 33,Automatic door: rear driver side,106|00 34,Automatic door: rear passenger side,106|01 35,Burglary protection control module 6: vehicle interior 2,31|01 36,Burglary protection control module 7: vehicle interior 3,33111|01 37,Burglary protection control module 8: vehicle interior 4,33112|00 00,Unknown (0),255|00 39,Multifunction interior camera,141|00 00,Unknown (0),255|00 3B,Brake Boost,35|00 00,Unknown (0),255|00 00,Unknown (0),255|00 3E,Rear drivers side door electronics,184|00 3F,Rear passenger side door electronics,187|00 00,Unknown (0),255|00 00,Unknown (0),255|01 01,Burglary Protection Control Module FL,33052|00 00,Unknown (0),255|00 44,High-voltage battery charger,195|01 02,Burglary Protection Control Module FR,33054|00 46,Climate Control Module,8|00 47,Trailer Function,8|00 00,Unknown (0),255|01 04,Burglary Protection Control Module RR,33056|00 4A,Driver's door electronics,66|00 4B,Passenger's door electronics,66|00 4C,Seat adjustment: driver side,54|00 4D,Seat adjustment: passenger's side,6|00 4E,Lane change assistance,6|00 4F,Front sensor for drivers assistant systems,60|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 57,Distance Regulation,19|00 00,Unknown (0),255|01 0C,Light line display 1,255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 0E,Electronic central electric,9|00 4F,Front sensor for drivers assistant systems,60|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 64,Actuator For Exterior Noise,166|00 00,Unknown (0),255|00 00,Unknown (0),255|00 67,Emergency call module and communication unit,117|00 00,Unknown (0),255|00 69,Rear view camera system,108|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 57,Distance Regulation,19|00 6F,Sound System,46|00 00,Unknown (0),255|00 00,Unknown (0),255|00 72,Wheel Damping Electronics,20|00 73,Information electronics 1,20|00 00,Unknown (0),255|00 00,Unknown (0),255|00 76,Engine Electronics,1|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 7B,Hybrid Battery Management,140|00 7C,Electric drive,81|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 82,Left light control,41|00 83,Right light control,41|00 84,Sunroof control module,57|00 00,Unknown (0),255|00 00,Unknown (0),255|00 87,Seat adjustment: rear driver's side,72|00 88,Seat adjustment: rear passenger side,72|01 03,Burglary Protection Control Module RL,33055|00 00,Unknown (0),255|00 00,Unknown (0),255|00 8C,Sound enhancement 2,70|00 00,Unknown (0),255|00 67,Emergency call module and communication unit,117|01 05,Burglary Protection Control Module interior,33057|00 00,Unknown (0),255|00 00,Unknown (0),255|00 69,Rear view camera system,108|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 96,Light Control Left 2,80|00 97,Light Control Right 2,214|00 98,Projection module in left matrix headlamp,215|00 99,Projection module in right matrix headlamp,216|00 00,Unknown (0),255|00 9B,Central control for digital matrix light,63|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 A5,charging device 1 for mobile end device,222|00 0C,Steering column electronics systems,22|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 BA,Antenna module,33029|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 B8,Electric drive 2,206|00 B9,Voltage converter 12V,206|00 BA,Antenna module,33029|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 14,Instrument cluster,3|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 C9,Rear surroundings camera,67|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 C9,Rear surroundings camera,67|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 73,Information electronics 1,20|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|00 00,Unknown (0),255|01 01,Burglary Protection Control Module FL,33052|01 02,Burglary Protection Control Module FR,33054|01 03,Burglary Protection Control Module RL,33055|01 04,Burglary Protection Control Module RR,33056|01 05,Burglary Protection Control Module interior,33057|01 06,Application server 1 system 1 adaptive,33058|01 07,Application server 1 system 2 Java,33059|01 08,Application server 3 system 1 infotainment,33060|01 09,Display unit Driver display,126|00 0A,Parking aid,118|00 0B,Tire Pressure Monitoring System (TPMS),101|00 0C,Steering column electronics systems,22|00 00,Unknown (0),255|00 0E,Electronic central electric,9|00 00,Unknown (0),255|,
IDE12939-MAS02643,Public key for SWaP function (3072)-Key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
IDE13345-MAS16268,Current Secure Element-Secure Element,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13345-MAS16269,Current Secure Element-Secure Element is contained in ticket table,No,
IDE13345-MAS16270,Current Secure Element-Secure element is authenticated,No,
IDE13551,EgoMaster tire circumference estimation utility,80, %
IDE13552,EgoMaster system status,AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB,
IDE13679-MAS06117,Power generator status-Specified voltage,15.125, V
IDE13679-MAS09777,Power generator status-Target current,0, A
IDE13679-MAS14362,Power generator status-Voltage limit boost mode,12.4,
IDE13751-IDE00773,Output signals: control of terminal-Terminal 15 status via CAN,active,
IDE13751-IDE06027,Output signals: control of terminal-Terminal S status via CAN,active,
IDE13751-MAS07386,Output signals: control of terminal-Terminal 50 on CAN,not active,
IDE13752-IDE09059,Electrical Steering Column Lock-Request terminal release,not active,
IDE13752-MAS06711,Electrical Steering Column Lock-Terminal release,not active,
IDE13752-MAS17234,Electrical Steering Column Lock-Steering column lock locked,not active,
IDE13754-IDE04447,Diagnosis filter: status-Function status,Function active: SFD protected,
IDE13754-MAS16866,Diagnosis filter: status-Odometer,0, km
IDE13754-MAS16867,Diagnosis filter: status-Reason for deactivation,Not deactivated,
IDE13754-MAS16875,Diagnosis filter: status-Filter status,Filter active,
IDE13755-IDE00056,Diagnosis filter: history data-History data 1,00000464*2024-12-30-16:17:45*0*,
IDE13755-IDE00057,Diagnosis filter: history data-History data 2,00000464*2024-12-30-16:02:48*0*,
IDE13755-IDE00058,Diagnosis filter: history data-History data 3,00000464*2024-12-30-13:49:56*0*,
IDE13755-IDE00059,Diagnosis filter: history data-History data 4,00000464*2024-12-29-20:07:21*0*,
IDE13755-IDE00060,Diagnosis filter: history data-History data 5,00000464*2024-12-29-18:11:46*0*,
IDE13756,Diagnosis filter: activation,active,
IDE13782-MAS00106,History data of the last 25 charges-Year,2000,
IDE13782-MAS00106,History data of the last 25 charges-Year,2024,
IDE13782-MAS00107,History data of the last 25 charges-Month,0,
IDE13782-MAS00107,History data of the last 25 charges-Month,12,
IDE13782-MAS00108,History data of the last 25 charges-Day,28,
IDE13782-MAS00108,History data of the last 25 charges-Day,0,
IDE13782-MAS00108,History data of the last 25 charges-Day,18,
IDE13782-MAS00108,History data of the last 25 charges-Day,10,
IDE13782-MAS00108,History data of the last 25 charges-Day,14,
IDE13782-MAS00108,History data of the last 25 charges-Day,13,
IDE13782-MAS00108,History data of the last 25 charges-Day,20,
IDE13782-MAS00109,History data of the last 25 charges-Hours,0,
IDE13782-MAS00109,History data of the last 25 charges-Hours,12,
IDE13782-MAS00109,History data of the last 25 charges-Hours,15,
IDE13782-MAS00109,History data of the last 25 charges-Hours,16,
IDE13782-MAS00109,History data of the last 25 charges-Hours,17,
IDE13782-MAS00109,History data of the last 25 charges-Hours,13,
IDE13782-MAS00109,History data of the last 25 charges-Hours,8,
IDE13782-MAS00109,History data of the last 25 charges-Hours,10,
IDE13782-MAS00109,History data of the last 25 charges-Hours,21,
IDE13782-MAS00109,History data of the last 25 charges-Hours,9,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,41,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,0,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,23,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,59,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,18,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,36,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,53,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,19,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,50,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,8,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,43,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,49,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,42,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,51,
IDE13782-MAS00110,History data of the last 25 charges-Minutes,47,
IDE13782-MAS00478,History data of the last 25 charges-Reserved,00000000 ,
IDE13782-MAS08747,History data of the last 25 charges-Charging plug connected,00000001 ,
IDE13782-MAS08747,History data of the last 25 charges-Charging plug connected,00000000 ,
IDE13782-ENG279300,History data of the last 25 charges-AC 1Phase,00000001 ,
IDE13782-ENG279300,History data of the last 25 charges-AC 1Phase,00000000 ,
IDE13782-ENG279301,History data of the last 25 charges-AC 2Phase,00000000 ,
IDE13782-ENG279302,History data of the last 25 charges-AC 3Phase,00000000 ,
IDE13782-ENG250730,History data of the last 25 charges-AWC,00000000 ,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,0,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,125,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,96,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,106,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,161,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,135,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,131,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,97,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,159,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,113,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,143,
IDE13782-ENG255392,History data of the last 25 charges-Berechneter Energiebedarf,107,
IDE13782-ENG279316,History data of the last 25 charges-Charging start or Error,00000000 ,
IDE13782-ENG279316,History data of the last 25 charges-Charging start or Error,00000001 ,
IDE13782-ENG123224,History data of the last 25 charges-DC,00000000 ,
IDE13782-ENG279324,History data of the last 25 charges-Derating AC Notladen,not active,
IDE13782-ENG279325,History data of the last 25 charges-Derating AC Temp Abschaltung,not active,
IDE13782-ENG279326,History data of the last 25 charges-Derating DC begrenzt,not active,
IDE13782-ENG279327,History data of the last 25 charges-Derating DC reduziert,not active,
IDE13782-ENG279328,History data of the last 25 charges-Derating DC Temp Abschaltung,not active,
IDE13782-ENG279329,History data of the last 25 charges-Derating Fehler Temp AC,not active,
IDE13782-ENG279330,History data of the last 25 charges-Derating Fehler Temp DC,not active,
IDE13782-ENG279336,History data of the last 25 charges-DTC Fehler Crash Detektiert,not active,
IDE13782-ENG279337,History data of the last 25 charges-DTC Fehler FuSi Absch,not active,
IDE13782-ENG279338,History data of the last 25 charges-DTC Fehler Fzg Verrollsicher,not active,
IDE13782-ENG279339,History data of the last 25 charges-DTC Fehler Keine CP Komm,not active,
IDE13782-ENG279340,History data of the last 25 charges-DTC Fehler Ladebereit HV Koord,not active,
IDE13782-ENG279341,History data of the last 25 charges-DTC Fehler Ladebereit Ls,not active,
IDE13782-ENG279342,History data of the last 25 charges-DTC Fehler Ladebereit OCC,not active,
IDE13782-ENG279343,History data of the last 25 charges-DTC Fehler Lv Nicht Stby,not active,
IDE13782-ENG279344,History data of the last 25 charges-DTC Fehler Not Abschaltung,not active,
IDE13782-ENG279345,History data of the last 25 charges-DTC Fehler Remote Update On,not active,
IDE13782-ENG279346,History data of the last 25 charges-DTC Fehler Stecker Nicht Verr,not active,
IDE13782-ENG279409,History data of the last 25 charges-Event Entry HVL HDS 600by RAW,18 C5 33 5C 03 D8 82 E8 32 08 00 0F 28 60 0F F0 BB 80 00 0B 00 00 00 00 18 C5 43 B4 03 D9 72 E8 32 0B 00 0F 28 40 0F F0 BB 80 00 00 00 00 00 00 18 C5 44 84 00 89 73 28 32 08 00 0F 1A A0 0F F0 BB 80 00 03 00 00 00 00 18 C5 46 B4 00 89 93 28 32 0B 00 0F 1A 80 0F F0 BB 80 00 00 00 00 00 00 18 C5 46 F4 01 05 93 B8 32 09 00 0F 18 40 0F F0 BB 80 00 03 00 00 00 00 18 C6 C2 AC 00 CD 0A 98 32 08 00 0F 20 C0 0F F0 BB 80 00 0B 00 00 00 00 18 C7 22 9C 01 A0 8A 48 32 09 00 0F 27 C0 0F F0 BB 80 00 0B 00 00 00 00 18 C7 31 28 00 00 D1 A0 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00 18 C7 31 34 01 04 D2 58 32 09 00 0F 23 C0 0F F0 BB 80 00 03 00 00 00 00 18 C7 37 18 00 01 22 40 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00 18 C7 37 24 03 01 24 58 32 08 00 0F 1F 40 0F F0 BB 80 00 03 00 00 00 00 18 C7 56 9C 0D 55 A4 28 32 09 00 0F 18 20 0F F0 BB 80 00 0B 00 00 00 00 18 C9 3D 7C 02 99 74 A8 32 08 00 0F 1A C0 0F F0 BB 80 00 0B 00 00 00 00 18 CA 2A 4C 02 89 5C 48 32 09 00 0F 1C 40 0F F0 BB 80 00 0B 00 00 00 00 18 CE 27 3C 02 E8 FC 08 32 09 00 0F 21 E0 0F F0 BB 80 00 0B 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13782-ENG255755,History data of the last 25 charges-Grund für Ladeende,Ladeabbruch durch Fehler nicht zuordenbar,
IDE13782-ENG255755,History data of the last 25 charges-Grund für Ladeende,Ladeabbruch durch erweitertes Laden,
IDE13782-ENG255755,History data of the last 25 charges-Grund für Ladeende,Ladeende durch Kunde an der LS,
IDE13782-ENG255756,History data of the last 25 charges-Grundladeplan Abweichung,00,
IDE13782-ENG255801,History data of the last 25 charges-Indikator geäernderter Ziel_SOC,00000000 ,
IDE13782-ENG255801,History data of the last 25 charges-Indikator geäernderter Ziel_SOC,00000001 ,
IDE13782-ENG279486,History data of the last 25 charges-Indikator_01,00000000 ,
IDE13782-ENG279487,History data of the last 25 charges-Indikator_02,00000000 ,
IDE13782-ENG279488,History data of the last 25 charges-Indikator_03,00000000 ,
IDE13782-ENG279489,History data of the last 25 charges-Indikator_04,00000000 ,
IDE13782-ENG279490,History data of the last 25 charges-Indikator_05,00000000 ,
IDE13782-ENG279491,History data of the last 25 charges-Indikator_06,00000000 ,
IDE13782-ENG279492,History data of the last 25 charges-Indikator_07,00000000 ,
IDE13782-ENG279493,History data of the last 25 charges-Indikator_08,00000000 ,
IDE13782-ENG279494,History data of the last 25 charges-Indikator_09,00000000 ,
IDE13782-ENG279495,History data of the last 25 charges-Indikator_10,00000000 ,
IDE13782-ENG279496,History data of the last 25 charges-Indikator_11,00000000 ,
IDE13782-ENG279497,History data of the last 25 charges-Indikator_12,00000000 ,
IDE13782-ENG279498,History data of the last 25 charges-Indikator_13,00000000 ,
IDE13782-ENG279499,History data of the last 25 charges-Indikator_14,00000000 ,
IDE13782-ENG279500,History data of the last 25 charges-Indikator_15,00000000 ,
IDE13782-ENG279501,History data of the last 25 charges-Indikator_16,00000001 ,
IDE13782-ENG279502,History data of the last 25 charges-Indikator_17,00000000 ,
IDE13782-ENG279503,History data of the last 25 charges-Indikator_18,00000000 ,
IDE13782-ENG279504,History data of the last 25 charges-Indikator_19,00000000 ,
IDE13782-ENG279505,History data of the last 25 charges-Indikator_20,00000000 ,
IDE13782-ENG279506,History data of the last 25 charges-Indikator_21,00000000 ,
IDE13782-ENG279507,History data of the last 25 charges-Indikator_22,00000000 ,
IDE13782-ENG279508,History data of the last 25 charges-Indikator_23,00000000 ,
IDE13782-ENG279509,History data of the last 25 charges-Indikator_24,00000000 ,
IDE13782-ENG279510,History data of the last 25 charges-Indikator_25,00000000 ,
IDE13782-ENG279513,History data of the last 25 charges-Kein Derating,not active,
IDE13782-ENG279513,History data of the last 25 charges-Kein Derating,active,
IDE13782-ENG255832,History data of the last 25 charges-Ladeanlauf Zustaende,0,
IDE13782-ENG255832,History data of the last 25 charges-Ladeanlauf Zustaende,48,
IDE13782-ENG255832,History data of the last 25 charges-Ladeanlauf Zustaende,176,
IDE13782-ENG255833,History data of the last 25 charges-Ladedauer zu Ladebeginn,3000, min
IDE13782-ENG255833,History data of the last 25 charges-Ladedauer zu Ladebeginn,0, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,0, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,246, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,34, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,162, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,51, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,65, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,853, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,166, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,192, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,186, min
IDE13782-ENG255834,History data of the last 25 charges-Ladedauer_HVL_HDS,104, min
IDE13782-ENG255835,History data of the last 25 charges-Ladedosen Temperatur max,255,
IDE13782-ENG255835,History data of the last 25 charges-Ladedosen Temperatur max,0,
IDE13782-ENG255836,History data of the last 25 charges-Ladestrategie,15,
IDE13782-ENG255836,History data of the last 25 charges-Ladestrategie,0,
IDE13782-ENG279526,History data of the last 25 charges-Reserve 1,not active,
IDE13782-ENG279268,History data of the last 25 charges-Reserve 2,not active,
IDE13782-ENG160434,History data of the last 25 charges-soc_end,66, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,0, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,26, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,69, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,46, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,64, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,74, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,68, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,50, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,59, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,37, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,36, %
IDE13782-ENG160434,History data of the last 25 charges-soc_end,41, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,46, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,16, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,26, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,50, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,17, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,0, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,31, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,33, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,36, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,52, %
IDE13782-ENG160433,History data of the last 25 charges-soc_start,43, %
IDE13782-ENG256324,History data of the last 25 charges-SOC_Ziel,100, %
IDE13782-ENG256324,History data of the last 25 charges-SOC_Ziel,0, %
IDE13782-ENG256395,History data of the last 25 charges-Status Grundladen,Sofortladen Standby,
IDE13782-ENG279538,History data of the last 25 charges-stream,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C7 56 9C 0D 55 A4 28 32 09 00 0F 18 20 0F F0 BB 80 00 0B 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C5 44 84 00 89 73 28 32 08 00 0F 1A A0 0F F0 BB 80 00 03 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C9 3D 7C 02 99 74 A8 32 08 00 0F 1A C0 0F F0 BB 80 00 0B 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C7 37 24 03 01 24 58 32 08 00 0F 1F 40 0F F0 BB 80 00 03 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C5 33 5C 03 D8 82 E8 32 08 00 0F 28 60 0F F0 BB 80 00 0B 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 CE 27 3C 02 E8 FC 08 32 09 00 0F 21 E0 0F F0 BB 80 00 0B 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C5 43 B4 03 D9 72 E8 32 0B 00 0F 28 40 0F F0 BB 80 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C5 46 F4 01 05 93 B8 32 09 00 0F 18 40 0F F0 BB 80 00 03 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C7 31 28 00 00 D1 A0 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C7 37 18 00 01 22 40 00 00 00 0F 00 00 0F F0 00 00 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 CA 2A 4C 02 89 5C 48 32 09 00 0F 1C 40 0F F0 BB 80 00 0B 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C5 46 B4 00 89 93 28 32 0B 00 0F 1A 80 0F F0 BB 80 00 00 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C7 22 9C 01 A0 8A 48 32 09 00 0F 27 C0 0F F0 BB 80 00 0B 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C6 C2 AC 00 CD 0A 98 32 08 00 0F 20 C0 0F F0 BB 80 00 0B 00 00 00 00,
IDE13782-ENG279538,History data of the last 25 charges-stream,18 C7 31 34 01 04 D2 58 32 09 00 0F 23 C0 0F F0 BB 80 00 03 00 00 00 00,
IDE13782-ENG256532,History data of the last 25 charges-Tracking DTC (10),not active,
IDE13782-ENG256533,History data of the last 25 charges-Tracking DTC (11),not active,
IDE13782-ENG256534,History data of the last 25 charges-Tracking DTC (12),not active,
IDE13782-ENG256535,History data of the last 25 charges-Tracking DTC (13),not active,
IDE13782-ENG256546,History data of the last 25 charges-Tracking DTC (9),not active,
IDE13782-ENG256721,History data of the last 25 charges-Zaehler_Bit,stored,
IDE13782-ENG256721,History data of the last 25 charges-Zaehler_Bit,Up-to-date,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVGAWVEB7SH010695,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,55,
IDE13845,Production mode status,not active,
IDE13873-MAS01159,Ethernet status electrical error-Version number,01,
IDE13873-MAS20288,Ethernet status electrical error-Number of status electrical error,3,
IDE13873,Ethernet status electrical error,|Ethernet interface,|2,No malfunction|3,No malfunction|4,No malfunction|0,No malfunction|6,Open circuit|7,Open circuit|0,No malfunction|10,Open circuit|11,No malfunction|12,No malfunction|0,No malfunction|0,No malfunction|,
IDE13956-IDE01715,Key position replication: input signals-Status terminal S,On,
IDE13956-IDE80258,Key position replication: input signals-Immobilizer status,Electronic steering locking device installed,
IDE13956-MAS01493,Key position replication: input signals-Engine running,not active,
IDE13956-MAS03679,Key position replication: input signals-Terminal 15 status,On,
IDE13956-MAS05104,Key position replication: input signals-Driver request: start engine,active,
IDE13956-MAS06711,Key position replication: input signals-Terminal release,not active,
IDE13956-MAS07719,Key position replication: input signals-Terminal 50 status,OFF,
IDE13956-MAS08136,Key position replication: input signals-Enabling Steering Column Lock,Condition not met,
IDE13956,Key position replication: input signals,0, s
IDE13956-ENG255532,Key position replication: input signals-clampcoordinator_approval,OFF,
IDE13956-ENG281503,Key position replication: input signals-clampcoordinator_diagnostic_approval,OFF,
IDE13956-ENG255625,Key position replication: input signals-diag_trigger_clampcoordinator_intern,OFF,
IDE13956-ENG281580,Key position replication: input signals-Number_Of_Start_Requests_In_Terminal15_Cycle,1,
IDE13956-ENG129033,Key position replication: input signals-s_anf_klemmenfreigabe_wfs,not requested,
IDE13956-ENG126972,Key position replication: input signals-s_klemmenfreigabe_wfs,No enabling,
IDE13956-ENG281606,Key position replication: input signals-Terminal15_deactivation_via_Timeout,not active,
IDE13956-ENG129036,Key position replication: input signals-To_block_terminal_upshift,not active,
IDE13956-ENG256549,Key position replication: input signals-trigger_clampcoordinator_intern_for_ignition_off,OFF,
IDE13956-ENG256550,Key position replication: input signals-trigger_clampkoordinator_intern_for_ignition_on,OFF,
IDE13956-ENG129038,Key position replication: input signals-Valid_time_control_section_diagnostics,0, s
IDE14151-MAS13098,Route-based range calculation-Power drawn by thermal management,0, W
IDE14151-MAS14375,Route-based range calculation-Cycle counter,6,
IDE14151-MAS17899,Route-based range calculation-Route-based range calculation status,not active,
IDE14151-MAS17900,Route-based range calculation-Classified consumption,17.5, kWh/100 km
IDE14151-MAS17901,Route-based range calculation-Classified consumption 2,8.8, kWh/100 km
IDE14151-MAS17902,Route-based range calculation-Classified consumption 3,15.1, kWh/100 km
IDE14151-MAS17903,Route-based range calculation-Classified consumption 4,15.2, kWh/100 km
IDE14151-MAS17904,Route-based range calculation-Classified consumption 5,17.2, kWh/100 km
IDE14151-MAS17905,Route-based range calculation-Classified consumption 6,17.2, kWh/100 km
IDE14151-MAS17906,Route-based range calculation-Classified consumption 7,20.3, kWh/100 km
IDE14151-MAS17907,Route-based range calculation-Classified consumption 8,21.2, kWh/100 km
IDE14151-MAS17908,Route-based range calculation-Classified consumption 9,21.2, kWh/100 km
IDE14151-MAS17909,Route-based range calculation-Classified consumption 10,21.2, kWh/100 km
IDE14151-MAS17910,Route-based range calculation-Calculated consumption,20.9, kWh/100 km
IDE14151-MAS17911,Route-based range calculation-Calculated consumption 2,18.4, kWh/100 km
IDE14151-MAS17912,Route-based range calculation-Calculated consumption 3,13.3, kWh/100 km
IDE14151-MAS17913,Route-based range calculation-Calculated consumption 4,14.0, kWh/100 km
IDE14151-MAS17914,Route-based range calculation-Calculated consumption 5,12.6, kWh/100 km
IDE14151-MAS17915,Route-based range calculation-Calculated consumption 6,16.4, kWh/100 km
IDE14151-MAS17916,Route-based range calculation-Calculated consumption 7,18.8, kWh/100 km
IDE14151-MAS17917,Route-based range calculation-Calculated consumption 8,18.8, kWh/100 km
IDE14151-MAS17918,Route-based range calculation-Calculated consumption 9,18.8, kWh/100 km
IDE14151-MAS17919,Route-based range calculation-Calculated consumption 10,20.0, kWh/100 km
IDE14151-MAS17921,Route-based range calculation-Comfort consumers power consumption,0, W
IDE14151-MAS17922,Route-based range calculation-Route-based range raw value with comfort consumers,0,
IDE14151-MAS17923,Route-based range calculation-Route-based range raw value without comfort consumers,0,
IDE14151-MAS17924,Route-based range calculation-Residual energy content without comfort consumers,0.00,
IDE14151-MAS17925,Route-based range calculation-Residual energy content with comfort consumers,0.00,
IDE14151-MAS17926,Route-based range calculation-Type of route,OFF,
IDE14151-MAS17927,Route-based range calculation-Range reference,65533,
IDE14151-MAS17928,Route-based range calculation-Maximum range,65533,
IDE14151-MAS17929,Route-based range calculation-Total coverage,2046,
IDE14151-MAS17930,Route-based range calculation-Range from destination,2046,
IDE14151-MAS17931,Route-based range calculation-Route-based range,2046,
IDE14151-MAS17932,Route-based range calculation-Recalculation status,not performed,
IDE14169-IDE08660,Autonomous recharging-Recharging the NV battery,8,
IDE14169-MAS02832,Autonomous recharging-Malfunction status,Malfunction,
IDE14169-MAS07409,Autonomous recharging-Status automatic recharging of low-voltage battery,possible,
IDE14169-ENG334094,Autonomous recharging-Comfort_limits,Not reached,
IDE14169-ENG334226,Autonomous recharging-HV_off_timer_status,Enabled,
IDE14169-ENG334227,Autonomous recharging-HV_power_supply_status,No malfunction,
IDE14169-ENG98676,Autonomous recharging-Init,not active,
IDE14169-ENG334254,Autonomous recharging-Limits_of_hv_battery,Not reached,
IDE14219,Component protection challenge,0B 88 D0 2C,
IDE14221-MAS06854,FAZIT identification component protection checksum-Version,81,
IDE14221-MAS06855,FAZIT identification component protection checksum-Test sum,D2 1C FE 15,
IDE14236-MAS00106,Authentic time: last confirmed time-Year,2024,
IDE14236-MAS00107,Authentic time: last confirmed time-Month,12,
IDE14236-MAS00108,Authentic time: last confirmed time-Day,30,
IDE14236-MAS00109,Authentic time: last confirmed time-Hours,16,
IDE14236-MAS00110,Authentic time: last confirmed time-Minutes,18,
IDE14236-MAS00111,Authentic time: last confirmed time-Seconds,44,
IDE14237-MAS00106,Authentic time: actual time-Year,2024,
IDE14237-MAS00107,Authentic time: actual time-Month,12,
IDE14237-MAS00108,Authentic time: actual time-Day,30,
IDE14237-MAS00109,Authentic time: actual time-Hours,16,
IDE14237-MAS00110,Authentic time: actual time-Minutes,21,
IDE14237-MAS00111,Authentic time: actual time-Seconds,18,
IDE14262-MAS12984,12V lead battery test pulse: high-voltage energy management-Reason for rejection,7,
IDE14262-MAS21182,12V lead battery test pulse: high-voltage energy management-Bad counter,232,
IDE14262-MAS22196,12V lead battery test pulse: high-voltage energy management-Test pulse prompt: low-voltage EM to high-voltage EM,no request,
IDE14262-MAS22197,12V lead battery test pulse: high-voltage energy management-Test pulse activation: high-voltage EM to low-voltage EM,No enabling,
IDE14265,Battery display: source of initiation,0,
IDE14268-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 10-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE14269-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 11-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE14271-MAS14856,IP network: VLANs of Ethernet switch ports branch 10-VLAN,|VLAN|11|,
IDE14272-MAS14856,IP network: VLANs of Ethernet switch ports branch 11-VLAN,|VLAN|4|,
IDE14334,Authentic time: number of maximum deviation exceeded,0,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,2,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 4B,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC time server,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3D 5C A0 C2 C8 28 88,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,41,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 44,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE14665-MAS03834,Control unit for driving and comfort functions: status-Emergency signal flashing,Not operated,
IDE14665-MAS18691,Control unit for driving and comfort functions: status-Emergency signal flashing: function lighting,OFF,
IDE14771,EgoMaster: input data,,
IDE14959,Tailgate opening: reason for non-availability,Terminal 15 active,
IDE14993-IDE00007,Software composition list identification data-VW/Audi part number,000000000  ,
IDE14993-IDE00013,Software composition list identification data-System designation,Comp Prot    ,
IDE14993-MAS03962,Software composition list identification data-Primary version number,0003,
IDE14993-MAS03963,Software composition list identification data-Secondary version number,0007,
IDE14993-MAS15135,Software composition list identification data-Supplier ID,00 01,
IDE14993-MAS19447,Software composition list identification data-Versioning,01,
IDE14993-MAS20341,Software composition list identification data-Number of software composition,00 33,
IDE14993-MAS21065,Software composition list identification data-Software Composition ID,00 00 00 00 00 00 00 14,
IDE14993-MAS21066,Software composition list identification data-Patch version number,0001,
IDE15047-MAS00106,UTC time (universal time)-Year,2024,
IDE15047-MAS00107,UTC time (universal time)-Month,12,
IDE15047-MAS00108,UTC time (universal time)-Day,30,
IDE15047-MAS00109,UTC time (universal time)-Hours,16,
IDE15047-MAS00110,UTC time (universal time)-Minutes,21,
IDE15047-MAS00111,UTC time (universal time)-Seconds,27,
IDE15048-ENG255825,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_CAN,unrestricted,
IDE15048-ENG255826,Output signals: terminal coordinator-KST_Immobiliser_Level_Request_SR,unrestricted,
IDE15048-ENG255827,Output signals: terminal coordinator-KST_Request_Clamp_15,CL_15_HW_AND_CAN,
IDE15048-ENG255828,Output signals: terminal coordinator-KST_Specialstate_Request_CAN,Initialization,
IDE15048-ENG255829,Output signals: terminal coordinator-KST_Specialstate_Request_SR,Initialization,
IDE15048-ENG255830,Output signals: terminal coordinator-KST_Specialstate_Status_CAN,active,
IDE15048-ENG255831,Output signals: terminal coordinator-KST_Specialstate_Status_SR,active,
IDE15049-IDE09065,Input signals: terminal coordinator-Status: remote start,Initialization,
IDE15049-MAS20292,Input signals: terminal coordinator-Key position reproduction: status,active,
IDE15049-MAS20294,Input signals: terminal coordinator-Key position reproduction: terminal query,Terminal 15: discrete and CAN,
IDE15049-MAS20297,Input signals: terminal coordinator-Key position replication: immobilizer request,unrestricted,
IDE15049-MAS20298,Input signals: terminal coordinator-Terminal 15 via diagnostic: query status,Initialization,
IDE15049-ENG263759,Input signals: terminal coordinator-AAA_Request_Clamp_15,none,
IDE15049-ENG263760,Input signals: terminal coordinator-AAA_Request_Immobiliser_Level,none,
IDE15049-ENG263761,Input signals: terminal coordinator-AAA_Request_Status,Initialization,
IDE15049-ENG263762,Input signals: terminal coordinator-MWS_Request_Clamp_15,none,
IDE15049-ENG263763,Input signals: terminal coordinator-MWS_Request_Immobiliser_Level,none,
IDE15049-ENG263764,Input signals: terminal coordinator-MWS_Request_Status,Initialization,
IDE15049-ENG263765,Input signals: terminal coordinator-PHP_Request_Clamp_15,none,
IDE15049-ENG263766,Input signals: terminal coordinator-PHP_Request_Immobiliser_Level,none,
IDE15049-ENG263767,Input signals: terminal coordinator-PHP_Request_Status,Initialization,
IDE15049-ENG263768,Input signals: terminal coordinator-RPA_Request_Clamp_15,none,
IDE15049-ENG263769,Input signals: terminal coordinator-RPA_Request_Immobiliser_Level,none,
IDE15049-ENG263770,Input signals: terminal coordinator-RPA_Request_Status,Initialization,
IDE15049-ENG263771,Input signals: terminal coordinator-RST_Request_Clamp_15,none,
IDE15049-ENG263772,Input signals: terminal coordinator-RST_Request_Immobiliser_Level,none,
IDE15049-ENG263773,Input signals: terminal coordinator-RWK_Request_Clamp_15,none,
IDE15049-ENG263774,Input signals: terminal coordinator-RWK_Request_Immobiliser_Level,none,
IDE15049-ENG263775,Input signals: terminal coordinator-RWK_Request_Status,Initialization,
IDE15049-ENG281498,Input signals: terminal coordinator-SPN_ORU_Request_Status,Initialization,
IDE15049-ENG263776,Input signals: terminal coordinator-ZAS_Request_Clamp_15,Terminal 15: discrete and CAN,
IDE15049-ENG263777,Input signals: terminal coordinator-ZAS_Request_Immobiliser_Level,unrestricted,
IDE15049-ENG263778,Input signals: terminal coordinator-ZAS_Request_Status,active,
IDE15333-MAS12519,EgoMaster: display speed calculation-Pre-run,0.00, %
IDE15333-MAS21326,EgoMaster: display speed calculation-Tire size data set,2282, mm
IDE15333-MAS21751,EgoMaster: display speed calculation-Data set for tire circumference: status,0,
IDE15333-MAS21752,EgoMaster: display speed calculation-Display speed,0, km/h
IDE15333-MAS21753,EgoMaster: display speed calculation-Display speed: status,1,
IDE15333-MAS21754,EgoMaster: display speed calculation-Front left wheel speed: status,0,
IDE15333-MAS21755,EgoMaster: display speed calculation-Right front wheel speed: status,0,
IDE15333-MAS21756,EgoMaster: display speed calculation-Rear left wheel speed: status,0,
IDE15333-MAS21757,EgoMaster: display speed calculation-Right rear wheel speed: status,0,
IDE15333-MAS21758,EgoMaster: display speed calculation-Tire circumference: ESP data,2282, mm
IDE15333-MAS21759,EgoMaster: display speed calculation-ESP data for tire circumference: status,0,
IDE15406-MAS03001,Tire circumference estimator-Mode,0,
IDE15406-MAS20916,Tire circumference estimator-Speed range 4: factor,1.00,
IDE15406-MAS20917,Tire circumference estimator-Speed range 3: status,0, %
IDE15406-MAS20918,Tire circumference estimator-Speed range 2: factor,1.00,
IDE15406-MAS20919,Tire circumference estimator-Speed range 1: factor,1.00,
IDE15406-MAS20921,Tire circumference estimator-Speed range 3: factor,1.00,
IDE15406-MAS20922,Tire circumference estimator-Speed range 5: factor,1.00,
IDE15406-MAS20923,Tire circumference estimator-Speed range 6: factor,1.00,
IDE15406-MAS20924,Tire circumference estimator-Speed range 0: factor,1.00,
IDE15406-MAS20925,Tire circumference estimator-Speed range 7: factor,1.00,
IDE15406-MAS20926,Tire circumference estimator-Speed range 7: status,0, %
IDE15406-MAS20927,Tire circumference estimator-Speed range 1: lower limit,34, km/h
IDE15406-MAS20928,Tire circumference estimator-Speed range 5: lower limit,129, km/h
IDE15406-MAS20929,Tire circumference estimator-Speed range 3: lower limit,90, km/h
IDE15406-MAS20930,Tire circumference estimator-Speed range 2: lower limit,60, km/h
IDE15406-MAS20931,Tire circumference estimator-Speed range 4: lower limit,110, km/h
IDE15406-MAS20932,Tire circumference estimator-Speed range 7: lower limit,200, km/h
IDE15406-MAS20933,Tire circumference estimator-Speed range 0: lower limit,0, km/h
IDE15406-MAS20934,Tire circumference estimator-Speed range 6: status,0, %
IDE15406-MAS20935,Tire circumference estimator-Speed range 6: lower limit,159, km/h
IDE15406-MAS20936,Tire circumference estimator-Speed range 5: status,0, %
IDE15406-MAS20937,Tire circumference estimator-Speed range 4: status,0, %
IDE15406-MAS20938,Tire circumference estimator-Speed synchronization: status,1,
IDE15406-MAS20939,Tire circumference estimator-Speed range 2: status,0, %
IDE15406-MAS20940,Tire circumference estimator-Speed range 1: status,0, %
IDE15406-MAS20948,Tire circumference estimator-Speed range 0: status,0, %
IDE15406-MAS20970,Tire circumference estimator-Terminal cycle estimator: status,0,
IDE15406-MAS20971,Tire circumference estimator-Tolerance adjustment: status,0,
IDE15406-MAS21746,Tire circumference estimator-Geometric precision status,0,
IDE15406-MAS21747,Tire circumference estimator-Satellite number: status,0,
IDE15406-MAS21748,Tire circumference estimator-GPS Position: Status,0,
IDE15406-MAS21749,Tire circumference estimator-Navigation speed: status,0,
IDE15406-MAS21750,Tire circumference estimator-Navigation speed,0, km/h
IDE15471,High-voltage charging manager: status of charging plan monitoring,not active,
IDE15472,High-voltage charging manager: energy deviation from charging plan,0.00, kWh
IDE15482-MAS14856,IP network: VLANs of Ethernet switch ports branch 12-VLAN,|VLAN|3|,
IDE15483-MAS14856,IP network: VLANs of Ethernet switch ports branch 13-VLAN,Write only channel,
IDE15484-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 12-MAC address,|MAC address|02 7D FA 00 10 02|,
IDE15485-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 13-MAC address,|MAC address|02 7D FA 00 10 03|,
IDE15499-MAS13088,High-voltage charging manager: active charging profile-Preconditioning of the interior,not activated,
IDE15499-MAS20823,High-voltage charging manager: active charging profile-Target SoC,1, %
IDE15499-MAS20824,High-voltage charging manager: active charging profile-Minimum SoC,Initialization,
IDE15499-MAS20825,High-voltage charging manager: active charging profile-Charging current reduction,Initialization,
IDE15499-MAS20826,High-voltage charging manager: active charging profile-Domestic current usage,not activated,
IDE15502-MAS03084,High-voltage charging manager: target current presetting-Phase 1,0.00, A
IDE15502-MAS03085,High-voltage charging manager: target current presetting-Phase 2,0.00, A
IDE15502-MAS03086,High-voltage charging manager: target current presetting-Phase 3,0.00, A
IDE15503,High-voltage charging manager: use of target current presetting,not activated,
IDE15504,High-voltage charging manager: target performance of expanded charging function,6.1965e+006, W
IDE15505,High-voltage charging manager: charging strategy of expanded charging function,Unknown (12),
IDE15506,High-voltage charging manager: status of extended charging functions,not active,
IDE15513-ENG279311,High-voltage charging manager: plug type and plug status-Byte to EOP,01 02 01 00 06 0F 00 0B 00 00,
IDE15521,High-voltage charging manager: charging process visualization,OFF,
IDE15522-MAS21677,DC charging: charging station statistics for charge process-DC charging: total energy turnover supply,0.00, kWh
IDE15522-MAS21678,DC charging: charging station statistics for charge process-DC charging: total charging time,0, min
IDE15523-MAS21679,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery maximum cell temperature,0, °C
IDE15523-MAS21680,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery minimum cell temperature,0, °C
IDE15523-MAS21681,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery maximum cell voltage,0.00, V
IDE15523-MAS21682,DC charging: vehicle statistics for charge process-DC charging: high-voltage battery minimum cell voltage,0.00, V
IDE15524-MAS07479,DC charging: maximum output of charging station-Max. charge voltage DC charge station,0.00, V
IDE15524-MAS21408,DC charging: maximum output of charging station-DC charging: maximum current charging station,-400, A
IDE15524-MAS21409,DC charging: maximum output of charging station-DC charging: minimum charging station voltage,0.00, V
IDE15524-MAS21410,DC charging: maximum output of charging station-DC charging: minimum current charging station,-400, A
IDE15525-ENG279311,DC charging: request parameters for high-voltage battery-Byte to EOP,00 00 0F A0 02,
IDE15526-IDE08969,DC charging: high-voltage battery charging parameters-HV battery: available capacity,0.00, kWh
IDE15526-MAS09113,DC charging: high-voltage battery charging parameters-Maximum temperature,0, °C
IDE15526-MAS21681,DC charging: high-voltage battery charging parameters-DC charging: high-voltage battery maximum cell voltage,0.00, V
IDE15527,DC charging: high-voltage battery status,normal,
IDE15527,DC charging: high-voltage battery status,0, °C
IDE15527,DC charging: high-voltage battery status,tbd,
IDE15528-IDE06954,DC charging: charging station status-Actual HV charge current,-400, A
IDE15528-IDE13628,DC charging: charging station status-HV charging voltage: current value,0.00, V
IDE15528-IDE15530,DC charging: charging station status-DC charging: charging station readiness,Pause,
IDE15528-MAS21678,DC charging: charging station status-DC charging: total charging time,0, min
IDE15529,DC charging: charging status of high-voltage battery,-400, A
IDE15529,DC charging: charging status of high-voltage battery,0.00, V
IDE15529,DC charging: charging status of high-voltage battery,0, min
IDE15530,DC charging: charging station readiness,Not ready,
IDE15531-MAS21360,Activation of tailgate locking-Charge socket A: loading hatch request status,Initialization,
IDE15531-MAS21361,Activation of tailgate locking-Charge socket B: loading hatch request status,Initialization,
IDE15532-MAS21358,Activation of charger plug lock-Charge socket A: charging connector requirement status,no request,
IDE15532-MAS21359,Activation of charger plug lock-Charge socket B: charging connector request status,no request,
IDE15533,DC charging: controlled by charging station,Not permitted,
IDE15533,DC charging: controlled by charging station,normal_operating_status,
IDE15533,DC charging: controlled by charging station,no request,
IDE15533,DC charging: controlled by charging station,not locked,
IDE15533,DC charging: controlled by charging station,active,
IDE15536,DC charging: vehicle charging readiness,tbd,
IDE15537-ENG279311,DC charging: charging station detection-Byte to EOP,00 00 00 00 00,
IDE15538-ENG279311,DC charging: parameters for vehicle charging components-Byte to EOP,00 00 00 00,
IDE15539-ENG279311,DC charging: charging station protocol version-Byte to EOP,00 00 00,
IDE15540,DC charging: maximum vehicle charging voltage,0.00, V
IDE15541,DC charging: control module internal charging process control,Standby,
IDE15541,DC charging: control module internal charging process control,no request,
IDE15541,DC charging: control module internal charging process control,0.00, A
IDE15542,DC charging: charging process control across control modules,no request,
IDE15542,DC charging: charging process control across control modules,not detected,
IDE15542,DC charging: charging process control across control modules,Send_cyclic_message_fast_cycle,
IDE15542,DC charging: charging process control across control modules,Norm_from_Year_2011,
IDE15543,DC charging: charging station status (Chademo),Standby,
IDE15543,DC charging: charging station status (Chademo),tbd,
IDE15545,DC charging: vehicle status,Selector lever in position P,
IDE15545,DC charging: vehicle status,not operational,
IDE15545,DC charging: vehicle status,Open,
IDE15550,DC charging: vehicle control,no request,
IDE15550,DC charging: vehicle control,tbd,
IDE15550,DC charging: vehicle control,not requested,
IDE15550,DC charging: vehicle control,0, A
IDE15550,DC charging: vehicle control,Standby,
IDE15551-ENG279311,Power line communication: charging station status-Byte to EOP,00 00 00 00 00 3E 00 0E FF FE 03 03 03 03 FE 03 FE 03 FE 00 03 FE 03 FE 03 FE,
IDE15552,Power line communication: vehicle status,no warning,
IDE15552,Power line communication: vehicle status,No malfunction,
IDE15552,Power line communication: vehicle status,not operational,
IDE15552,Power line communication: vehicle status,no request,
IDE15552,Power line communication: vehicle status,No_connection,
IDE15553,Power line communication: transfer and authentication,Do_not_use_transport_layer_security,
IDE15553,Power line communication: transfer and authentication,Contract not active,
IDE15554,Power line communication: process and manipulated variables,0.00, A
IDE15554,Power line communication: process and manipulated variables,1000.00, V
IDE15554,Power line communication: process and manipulated variables,no request,
IDE15555,Power line communication boundary conditions,0.00, A
IDE15555,Power line communication boundary conditions,1000.00, V
IDE15555,Power line communication boundary conditions,Initialization,
IDE15555,Power line communication boundary conditions,1.50, A
IDE15555,Power line communication boundary conditions,400.00, A
IDE15555,Power line communication boundary conditions,500.00, A
IDE15555,Power line communication boundary conditions,447.00, V
IDE15556,Power line communication: communication and process control,no request,
IDE15556,Power line communication: communication and process control,not specified,
IDE15557,Charger input: maximum charging current permitted per phase,0.00, A
IDE15558,Charger output: maximum charging capacity: and maximum charge current,138400, W
IDE15558,Charger output: maximum charging capacity: and maximum charge current,342.60, A
IDE15559-ENG279311,Actual voltage: current: and charging status of high-voltage battery-Byte to EOP,06 3D 3F 53 04 D8,
IDE15561,Calculated charge time remaining,0, min
IDE15562,Status of charge time calculation,Initialization,
IDE15563,Calculated charging speed,0, km
IDE15563,Calculated charging speed,kilometers_per_minute,
IDE15564,Calculated total charging time for one charge process,0.00, min
IDE15566,Deviation from actual calculated charging time,Unknown (0),
IDE15567,Calculated charge time based on temperature,0.00, min
IDE15568,Average total charging time over multiple values,0.00, min
IDE15570,DC charging: charge process control,no request,
IDE15571-ENG279311,Charge process status information-Byte to EOP,02 00 00 0F A0,
IDE15572,AC charging: adjacent phase voltage on charger rectifier,not detected,
IDE15574,Activation of charger rectifier,447, V
IDE15574,Activation of charger rectifier,0.00, A
IDE15574,Activation of charger rectifier,Standby,
IDE15575,Requested charging type and charge initiation,No enabling,
IDE15575,Requested charging type and charge initiation,not requested,
IDE15576,Charging subsystem status information,0, %
IDE15576,Charging subsystem status information,0, min
IDE15576,Charging subsystem status information,Standby,
IDE15576,Charging subsystem status information,no request,
IDE15576,Charging subsystem status information,60.50, %
IDE15577,Charging initiated by high-voltage coordinator,Ready_for_charging,
IDE15579,High-voltage charging manager: hold management status information,No malfunction,
IDE15579,High-voltage charging manager: hold management status information,Parking,
IDE15580,High-voltage charging management: accidental rolling preventing request,Leave standstill,
IDE15580,High-voltage charging management: accidental rolling preventing request,no request,
IDE15581,Control pilot activation,Open,
IDE15581,Control pilot activation,Close,
IDE15582-ENG279311,Charging readiness control: status information-Byte to EOP,00 01 01 07 00 FF 00,
IDE15583,Charging mode detected by control pilot evaluation,Unknown,
IDE15584-ENG279311,Control pilot signal evaluation-Byte to EOP,01 08,
IDE15585-MAS02949,Control Pilot charging socket A: input variables-Frequency,not detected,
IDE15585-MAS02952,Control Pilot charging socket A: input variables-Control voltage,0.00, V
IDE15585-MAS03873,Control Pilot charging socket A: input variables-Duty cycle,0.00, %
IDE15586-MAS02949,Control Pilot charging socket B: input variables-Frequency,880, Hz
IDE15586-MAS02952,Control Pilot charging socket B: input variables-Control voltage,Initialization,
IDE15586-MAS03873,Control Pilot charging socket B: input variables-Duty cycle,Initialization,
IDE15587,Status of charging plug lock,unlocked,
IDE15587,Status of charging plug lock,not completed,
IDE15587,Status of charging plug lock,activated,
IDE15588-MAS21352,Connector lock: operating status: door key cylinder-Central Locking System: lock triggered by door lock,Not operated,
IDE15588-MAS21353,Connector lock: operating status: door key cylinder-Central Locking System: unlock request triggered by door lock,Not operated,
IDE15589-MAS21441,Connector lock: operating status: radio key signal-Central Locking System: unlock triggered by remote key,Not operated,
IDE15589-MAS21442,Connector lock: operating status: radio key signal-Central Locking System: lock triggered by remote key,Not operated,
IDE15750,Visible status in charging plan processing,not active,
IDE15752,Charging requirement for expanded charging functions of basic charging,Unknown (4),
IDE15989-ENG279311,High voltage charging manager: next charging start-Byte to EOP,0C 11 E8 07 0C 1E,
IDE16497-MAS27312,12V vehicle electrical system activation-12-V vehicle electrical system information,0,
IDE16497-MAS27313,12V vehicle electrical system activation-12-V Li-Ion cooling information,0,
IDE16497-MAS27314,12V vehicle electrical system activation-12-V consumer information,0,
IDE16936-IDE01834,Low-voltage energy management: key figures of the lead battery-Battery voltage,15.03, V
IDE16936-IDE01836,Low-voltage energy management: key figures of the lead battery-Battery current,5, A
IDE16936-IDE12072,Low-voltage energy management: key figures of the lead battery-Warning displays,no warning,
IDE16936-IDE17292,Low-voltage energy management: key figures of the lead battery-Charge indicator,42.840,
IDE16936-MAS04059,Low-voltage energy management: key figures of the lead battery-Battery temperature,11, °C
IDE16936-MAS05030,Low-voltage energy management: key figures of the lead battery-Resistance,4.4,
IDE16936-MAS23197,Low-voltage energy management: key figures of the lead battery-Reason for warning display,0,
IDE16936-MAS23866,Low-voltage energy management: key figures of the lead battery-Limit resistance,8.6,
IDE16936-MAS23867,Low-voltage energy management: key figures of the lead battery-Escalation counter for battery alerts,0,
IDE16936-MAS26492,Low-voltage energy management: key figures of the lead battery-Duration of vehicle electrical system warning,0, H
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,E8,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,02,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,0, min
MAS00077-MAS06797,Immobilizer-Status configuration,17 00,
MAS00077-MAS10131,Immobilizer-Status Download 3,invalid,
MAS00077-ENG299121,Immobilizer-Configuration_status_(interpreted),|Configuration Kessy coded,Configuration E vehicle,Configuration SHE,Mobile key configuration|Yes,Yes,Yes,Yes|No,No,No,No|,
MAS00464-MAS00106,Standard - ambient data 1-Year,2000,
MAS00464-MAS00107,Standard - ambient data 1-Month,13,
MAS00464-MAS00108,Standard - ambient data 1-Day,28,
MAS00464-MAS00109,Standard - ambient data 1-Hours,0,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,15,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,48,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,0,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,464, km
MAS00769-IDE02717,Multifunction steering wheel control module-Tiptronic upshift,Not operated,
MAS00769-IDE02718,Multifunction steering wheel control module-Tiptronic downshift,Not operated,
MAS00769-IDE07668,Multifunction steering wheel control module-MFL Variant code,0,
MAS00769-MAS01065,Multifunction steering wheel control module-Brand,VW,
MAS00769-MAS01288,Multifunction steering wheel control module-Horn,Not operated,
MAS00769-MAS02317,Multifunction steering wheel control module-Button code 1,Not operated,
MAS00769-MAS02318,Multifunction steering wheel control module-Button code 2,Not operated,
MAS00769-MAS02319,Multifunction steering wheel control module-Event code 1,No result,
MAS00769-MAS02320,Multifunction steering wheel control module-Event code 2,No result,
MAS00769-MAS06029,Multifunction steering wheel control module-MFL message counter,0,
MAS00769-MAS06030,Multifunction steering wheel control module-MFL Toggle Bit,0,
MAS00769-MAS06034,Multifunction steering wheel control module-MFL Local active,not active,
MAS00769-MAS06035,Multifunction steering wheel control module-MFL M button,Not operated,
MAS12666-ENG299104,SubSystemNodeAddress of sub bus participant-SubSystem Node Addresses,|SubSystem Node Address,Subsystem designation|00 37,Battery Monitoring Control Module|00 69,Inverter for electrical outlet|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 31,Multifunction steering wheel control module|00 00,Unknown (0)|01 3E,Steering Wheel Touch Recognition Control Module|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 25,left tail lamp 1|01 0E,left tail lamp 2|01 0F,Right rear tail lamp 1|01 10,Right rear tail lamp 2|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 16,Anti-theft alarm system sensor|00 18,Alarm horn|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|01 90,Virtual pedal door opening: rear driver side|01 9E,Virtual pedal door opening: rear passenger side|00 4E,Rear lid opener control module|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 EB,Antenna for short-range communication|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 31,Multifunction steering wheel control module|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|00 00,Unknown (0)|,
MAS12668-ENG299105,Actual installation of sub-bus users-SubSystems present,|SubSystem present Bit 0,SubSystem present Bit 1,SubSystem present Bit 2,SubSystem present Bit 3,SubSystem present Bit 4,SubSystem present Bit 5,SubSystem present Bit 6,SubSystem present Bit 7|can be reached,can be reached,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,can be reached,not attainable,not attainable,not attainable,not attainable,not attainable|can be reached,can be reached,can be reached,can be reached,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|can be reached,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable,not attainable|,
MAS12669-ENG299103,Bus identification of sub-bus users-SubSystem Bus IDs,|Bus ID|81|81|0|0|0|0|0|0|82|0|82|0|0|0|0|0|83|83|83|83|0|0|0|0|84|84|0|0|0|0|0|0|0|0|0|0|0|0|0|0|86|86|86|0|0|0|0|0|35|0|0|0|0|0|0|0|41|0|0|0|0|0|0|0|,
MAS16427-MAS17003,Online data acquisition configuration-Locking time for change of condition,0.0, s
MAS16427-MAS19090,Online data acquisition configuration-Configuration version,00 00 00 00,
MAS16428-MAS00106,Online data acquisition and analysis-Year,2000,
MAS16428-MAS00107,Online data acquisition and analysis-Month,0,
MAS16428-MAS00108,Online data acquisition and analysis-Day,0,
MAS16428-MAS00109,Online data acquisition and analysis-Hours,0,
MAS16428-MAS00110,Online data acquisition and analysis-Minutes,0,
MAS16428-MAS00111,Online data acquisition and analysis-Seconds,0,
MAS16428-MAS16995,Online data acquisition and analysis-Downloads data set number,0,
MAS16428-MAS19089,Online data acquisition and analysis-Emergency Call Module recognition and communication unit or navigation,none,
MAS16744-IDE01836,12V battery-Battery current,4.989, A
MAS16744-IDE01837,12V battery-Temperature of battery sensor,11, °C
MAS16744-IDE01838,12V battery-Battery temperature,10, °C
MAS16744-IDE01839,12V battery-Battery charge level,89, %
MAS16744-IDE01841,12V battery-Battery internal resistance,4.2, mOhm
MAS16744-IDE01842,12V battery-Usable battery charge,27, Ah
MAS16744-IDE01948,12V battery-Battery internal resistance not normed,4.4, mOhm
MAS16744-IDE04186,12V battery-Battery terminal recognition,connected,
MAS16744-IDE08347,12V battery-adapted battery capacity,58, Ah
MAS16744-MAS00362,12V battery-Battery voltage,15.036, V
MAS16744-MAS06086,12V battery-Total re-charge,188.5, Ah
MAS16744-MAS06087,12V battery-Entire energy throughput,179.0, Ah
MAS16744-MAS22232,12V battery-Battery aging: charge-related,96, %
MAS16744-MAS22233,12V battery-Battery aging: performance-related,96, %
MAS16745-IDE01839,Quiescent current management-Battery charge level,90, %
MAS16745-IDE01843,Quiescent current management-Battery voltage at rest,12.6, V
MAS16745-IDE01846,Quiescent current management-Static current shut-off stage,Deactivation stage 0,
MAS16745-IDE01852,Quiescent current management-Static current measurement: result,Measurement,
MAS16745-IDE01853,Quiescent current management-Static current measurement: status,Initialization,
MAS16745-IDE07907,Quiescent current management-Bus communication,active,
MAS16745-IDE09561,Quiescent current management-Static current last LIN sleep phase,-0.041, A
MAS17522-IDE04332,Unlockable functions: central activation status-Release code for a SWaP function,available.,
MAS17522-IDE05814,Unlockable functions: central activation status-Individualization characteristic,valid,
MAS17522-IDE06260,Unlockable functions: central activation status-ID number,10 13 14 00,
MAS17522-MAS01340,Unlockable functions: central activation status-Functions,available.,
MAS17522-MAS01903,Unlockable functions: central activation status-Configuration,OK,
MAS17522-MAS02934,Unlockable functions: central activation status-Preconditions met,Condition met,
MAS17522-MAS05616,Unlockable functions: central activation status-Cancellation,No,
MAS17522-MAS05617,Unlockable functions: central activation status-Authentication,Condition met,
MAS17522-MAS17839,Unlockable functions: central activation status-Number of functions which can be activated,50,
MAS17522-MAS17965,Unlockable functions: central activation status-Maximum at receiver control module per activation ID,8,
MAS17522-MAS17967,Unlockable functions: central activation status-Type of customization feature,03,
MAS17522-MAS18610,Unlockable functions: central activation status-Control module to be activated 1,00 19,
MAS17522-MAS18611,Unlockable functions: central activation status-Control module to be activated 2,00 00,
MAS17522-MAS18612,Unlockable functions: central activation status-Control module to be activated 3,00 00,
MAS17522-MAS18613,Unlockable functions: central activation status-Control module to be activated 4,00 00,
MAS17522-MAS18614,Unlockable functions: central activation status-Control module to be activated 5,00 00,
MAS17522-MAS18615,Unlockable functions: central activation status-Control module to be activated 6,00 00,
MAS17522-MAS18616,Unlockable functions: central activation status-Control module to be activated 7,00 00,
MAS17522-MAS18617,Unlockable functions: central activation status-Control module to be activated 8,00 00,
MAS17522-MAS18618,Unlockable functions: central activation status-Activation of SWaP function for control module 1,Not available,
MAS17522-MAS18619,Unlockable functions: central activation status-Activation of SWaP function for control module 2,Not available,
MAS17522-MAS18620,Unlockable functions: central activation status-Activation of SWaP function for control module 3,Not available,
MAS17522-MAS18621,Unlockable functions: central activation status-Activation of SWaP function for control module 4,Not available,
MAS17522-MAS18622,Unlockable functions: central activation status-Activation of SWaP function for control module 5,Not available,
MAS17522-MAS18623,Unlockable functions: central activation status-Activation of SWaP function for control module 6,Not available,
MAS17522-MAS18624,Unlockable functions: central activation status-Activation of SWaP function for control module 7,Not available,
MAS17522-MAS18625,Unlockable functions: central activation status-Activation of SWaP function for control module 8,Not available,
MAS17522-MAS18626,Unlockable functions: central activation status-Cancellation for control module 1,Yes,
MAS17522-MAS18627,Unlockable functions: central activation status-Cancellation for control module 2,Yes,
MAS17522-MAS18628,Unlockable functions: central activation status-Cancellation for control module 3,Yes,
MAS17522-MAS18629,Unlockable functions: central activation status-Cancellation for control module 4,Yes,
MAS17522-MAS18630,Unlockable functions: central activation status-Cancellation for control module 5,Yes,
MAS17522-MAS18631,Unlockable functions: central activation status-Cancellation for control module 6,Yes,
MAS17522-MAS18632,Unlockable functions: central activation status-Cancellation for control module 7,Yes,
MAS17522-MAS18633,Unlockable functions: central activation status-Cancellation for control module 8,Yes,
MAS17522-MAS18634,Unlockable functions: central activation status-Individualization feature for control module 1,invalid,
MAS17522-MAS18635,Unlockable functions: central activation status-Individualization feature for control module 2,invalid,
MAS17522-MAS18636,Unlockable functions: central activation status-Individualization feature for control module 3,invalid,
MAS17522-MAS18637,Unlockable functions: central activation status-Individualization feature for control module 4,invalid,
MAS17522-MAS18638,Unlockable functions: central activation status-Individualization feature for control module 5,invalid,
MAS17522-MAS18639,Unlockable functions: central activation status-Individualization feature for control module 6,invalid,
MAS17522-MAS18640,Unlockable functions: central activation status-Individualization feature for control module 7,invalid,
MAS17522-MAS18641,Unlockable functions: central activation status-Individualization feature for control module 8,invalid,
MAS17522-MAS18642,Unlockable functions: central activation status-Conditions met for control module 1,Condition not met,
MAS17522-MAS18643,Unlockable functions: central activation status-Conditions met for control module 2,Condition not met,
MAS17522-MAS18644,Unlockable functions: central activation status-Conditions met for control module 3,Condition not met,
MAS17522-MAS18645,Unlockable functions: central activation status-Conditions met for control module 4,Condition not met,
MAS17522-MAS18646,Unlockable functions: central activation status-Conditions met for control module 5,Condition not met,
MAS17522-MAS18647,Unlockable functions: central activation status-Conditions met for control module 6,Condition not met,
MAS17522-MAS18648,Unlockable functions: central activation status-Conditions met for control module 7,Condition not met,
MAS17522-MAS18649,Unlockable functions: central activation status-Conditions met for control module 8,Condition not met,
MAS17522-MAS18650,Unlockable functions: central activation status-Configuration for control module 1,OK,
MAS17522-MAS18651,Unlockable functions: central activation status-Configuration for control module 2,not OK,
MAS17522-MAS18652,Unlockable functions: central activation status-Configuration for control module 3,not OK,
MAS17522-MAS18653,Unlockable functions: central activation status-Configuration for control module 4,not OK,
MAS17522-MAS18654,Unlockable functions: central activation status-Configuration for control module 5,not OK,
MAS17522-MAS18655,Unlockable functions: central activation status-Configuration for control module 6,not OK,
MAS17522-MAS18656,Unlockable functions: central activation status-Configuration for control module 7,not OK,
MAS17522-MAS18657,Unlockable functions: central activation status-Configuration for control module 8,not OK,
MAS17522-MAS18658,Unlockable functions: central activation status-Functions in control module 1,available.,
MAS17522-MAS18659,Unlockable functions: central activation status-Functions in control module 2,Not available,
MAS17522-MAS18660,Unlockable functions: central activation status-Functions in control module 3,Not available,
MAS17522-MAS18661,Unlockable functions: central activation status-Functions in control module 4,Not available,
MAS17522-MAS18662,Unlockable functions: central activation status-Functions in control module 5,Not available,
MAS17522-MAS18663,Unlockable functions: central activation status-Functions in control module 6,Not available,
MAS17522-MAS18664,Unlockable functions: central activation status-Functions in control module 7,Not available,
MAS17522-MAS18665,Unlockable functions: central activation status-Functions in control module 8,Not available,
MAS17522-MAS18666,Unlockable functions: central activation status-Authentication for control module 1,Condition not met,
MAS17522-MAS18667,Unlockable functions: central activation status-Authentication for control module 2,Condition not met,
MAS17522-MAS18668,Unlockable functions: central activation status-Authentication for control module 3,Condition not met,
MAS17522-MAS18669,Unlockable functions: central activation status-Authentication for control module 4,Condition not met,
MAS17522-MAS18670,Unlockable functions: central activation status-Authentication for control module 5,Condition not met,
MAS17522-MAS18671,Unlockable functions: central activation status-Authentication for control module 6,Condition not met,
MAS17522-MAS18672,Unlockable functions: central activation status-Authentication for control module 7,Condition not met,
MAS17522-MAS18673,Unlockable functions: central activation status-Authentication for control module 8,Condition not met,
MAS17522,Unlockable functions: central activation status,DA 19 F5 79 97 00 00 00,
MAS17523-MAS17968,Unlockable functions: date of last activation-Date of last function activation,67 09 31 64,
MAS17523-MAS17969,Unlockable functions: date of last activation-Date of last key exchange,00 00 00 00,
MAS17523-MAS17970,Unlockable functions: date of last activation-Date of last reset,00 00 00 00,
MAS17524-MAS17977,Unlockable functions: version info-Supported activation version,Support from FSC version 0x12,
MAS17524-MAS17978,Unlockable functions: version info-Supported encryption procedure,RSA3072 Exp. 17,
MAS17524-MAS18453,Unlockable functions: version info-FoD metadata version,No version of FoD metadata is supported,
MAS17524-MAS18456,Unlockable functions: version info-KeyIdent (Key project identification),1702,
MAS17524-MAS18457,Unlockable functions: version info-Generation of function activation,Activation via FoD,
MAS17524-MAS18460,Unlockable functions: version info-FoD partner diagnostic address,81 24,
MAS17526-MAS17971,Unlockable functions: status of transfer-Transfer status,Valid transmission,
MAS17526-MAS17972,Unlockable functions: status of transfer-Number of slave control modules,8,
MAS17526-MAS17973,Unlockable functions: status of transfer-Transfer status in slave control module,Valid transmission,
MAS17526-MAS17974,Unlockable functions: status of transfer-Slave number,0,
MAS17526-MAS17975,Unlockable functions: status of transfer-Slave node address,118,
MAS17526-MAS17976,Unlockable functions: status of transfer-Slave diagnostic address,00 01,
MAS17833,Remaining period of test activation,4294967295, s
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS23345,Production mode: 12 V recharging status,not active,
MAS24928-IDE06956,Secure presence detection-Driver-side belt buckle status,plausible,
MAS24928-IDE06956,Secure presence detection-Driver-side belt buckle status,closed,
MAS24928-IDE13428,Secure presence detection-Accelerator pedal value,Not operated,
MAS24928-IDE13428,Secure presence detection-Accelerator pedal value,Measured value not available or parameter outside measur.range,
MAS24928-MAS00218,Secure presence detection-Driver door,plausible,
MAS24928-MAS00218,Secure presence detection-Driver door,closed,
MAS24928-MAS00370,Secure presence detection-Vehicle speed,plausible,
MAS24928-MAS00635,Secure presence detection-available.,available.,
MAS24928-MAS03554,Secure presence detection-Clutch pedal operation,Implausible,
MAS24928-MAS03554,Secure presence detection-Clutch pedal operation,Not operated,
MAS24928-MAS05192,Secure presence detection-Driver braking,plausible,
MAS24928-MAS05192,Secure presence detection-Driver braking,Braking,
MAS24928-MAS07200,Secure presence detection-Multi-function steering wheel,not around,
MAS24928-MAS07200,Secure presence detection-Multi-function steering wheel,Implausible,
MAS24928-MAS07652,Secure presence detection-Vehicle movement,Standstill,
MAS24928-MAS15366,Secure presence detection-Incorrect height values,plausible,
MAS24928-MAS15366,Secure presence detection-Incorrect height values,Not operated,
MAS24928-MAS17288,Secure presence detection-Driver seat occupant detection,plausible,
MAS24928-MAS17288,Secure presence detection-Driver seat occupant detection,assigned,
MAS24928-MAS22006,Secure presence detection-Start request recognition: status,Not operated,
MAS24928-MAS22963,Secure presence detection-Starter button actuated,Not operated,
MAS24928-MAS25016,Secure presence detection-Electronic parking brake: switch position,plausible,
MAS24928-MAS25017,Secure presence detection-Shift mechanism,Not operated,
MAS24928-MAS25017,Secure presence detection-Shift mechanism,plausible,
MAS24928-MAS25018,Secure presence detection-Driver request: switch position,Not operated,
MAS24928-MAS25020,Secure presence detection-Presence detection: status,Secure presence detection,
MAS24928-SFT33114,Secure presence detection-Multifunction interior camera,Implausible,
MAS24928-SFT33114,Secure presence detection-Multifunction interior camera,not detected,
MAS24971,Low-voltage energy management: energy charging balance,10010, Ah
MAS25221,Virtual remote control vehicle key: online configuration,|Config_profileid,Engine_start_and_driving_unlimited,Engine_start_and_driving_limited_power_speed_example_for_valet_parking,Remote_parking,Engine_start_without_driving_authorization,All_flaps_and_doors_open_close,Passenger_compartment_open_close,Load_room_open_close,Trunk_open_close,Frunk_open_close,Tank_and_loading_flap_or_charging_plug_unlock_lock,Glove_compartment_if_it_is_unlocked_locked_at_the_future_example_for_valet_parking,One_time_use_example_for_open_close_incar_deliviery_the_vehicle_must_reject_the_key_if_it_is_used_repeatedly|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|0,No,No,No,No,No,No,No,No,No,No,No,No|,
MAS25221-ENG353386,Virtual remote control vehicle key: online configuration-Config_owner_pairing_passwort_max_attempts,00,
MAS25221-ENG356831,Virtual remote control vehicle key: online configuration-Config_servicecard_activation_mode,simple,
MAS25221-ENG353252,Virtual remote control vehicle key: online configuration-Config_sharing_password_length,00,
MAS25221-ENG356838,Virtual remote control vehicle key: online configuration-Config_sharing_password_required,No,
MAS25221-ENG353410,Virtual remote control vehicle key: online configuration-Config_sharing_passwort_max_attempts,00,
MAS25221-ENG354762,Virtual remote control vehicle key: online configuration-Config_slotid_1,00 00 00 00,
MAS25221-ENG353562,Virtual remote control vehicle key: online configuration-Config_slotid_10,00 00 00 00,
MAS25221-ENG352068,Virtual remote control vehicle key: online configuration-Config_slotid_11,00 00 00 00,
MAS25221-ENG355132,Virtual remote control vehicle key: online configuration-Config_slotid_12,00 00 00 00,
MAS25221-ENG352767,Virtual remote control vehicle key: online configuration-Config_slotid_13,00 00 00 00,
MAS25221-ENG354931,Virtual remote control vehicle key: online configuration-Config_slotid_14,00 00 00 00,
MAS25221-ENG354420,Virtual remote control vehicle key: online configuration-Config_slotid_15,00 00 00 00,
MAS25221-ENG351951,Virtual remote control vehicle key: online configuration-Config_slotid_16,00 00 00 00,
MAS25221-ENG355037,Virtual remote control vehicle key: online configuration-Config_slotid_2,00 00 00 00,
MAS25221-ENG355160,Virtual remote control vehicle key: online configuration-Config_slotid_3,00 00 00 00,
MAS25221-ENG354052,Virtual remote control vehicle key: online configuration-Config_slotid_4,00 00 00 00,
MAS25221-ENG356953,Virtual remote control vehicle key: online configuration-Config_slotid_5,00 00 00 00,
MAS25221-ENG353832,Virtual remote control vehicle key: online configuration-Config_slotid_6,00 00 00 00,
MAS25221-ENG355202,Virtual remote control vehicle key: online configuration-Config_slotid_7,00 00 00 00,
MAS25221-ENG352864,Virtual remote control vehicle key: online configuration-Config_slotid_8,00 00 00 00,
MAS25221-ENG356858,Virtual remote control vehicle key: online configuration-Config_slotid_9,00 00 00 00,
MAS25222-ENG352542,Near-field service card: information-Current_overlying_servicecard_corresponds_to_the_trained_service_card,No,
MAS25222-ENG353668,Near-field service card: information-Electronic_type_label_of_the_trained_servicecard,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS25222-ENG353958,Near-field service card: information-Id_of_the_trained_servicecard,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS25222-ENG352639,Near-field service card: information-Nfc_servicecard_learned,No,
MAS26682,Distance of storage error,00,
MAS26683,Distance of calculation error,00,
MAS27660,12-V battery display: trip reason,0,
MAS27748-IDE02068,Distance data with electronic stabilization program information-Time stamp,00 00 42 00 A1,
MAS27748-MAS00106,Distance data with electronic stabilization program information-Year,2000, yr
MAS27748-MAS00107,Distance data with electronic stabilization program information-Month,1, Months
MAS27748-MAS00108,Distance data with electronic stabilization program information-Day,1, d
MAS27748-MAS00109,Distance data with electronic stabilization program information-Hours,0, H
MAS27748-MAS00110,Distance data with electronic stabilization program information-Minutes,2, min
MAS27748-MAS00111,Distance data with electronic stabilization program information-Seconds,33, s
MAS27748-MAS27735,Distance data with electronic stabilization program information-ESC distance pulses,464486, m
MAS27748-MAS27749,Distance data with electronic stabilization program information-Distance pulses: number of jumps,0,
MAS27748-MAS27750,Distance data with electronic stabilization program information-Distance pulses: largest positive jump,0, m
MAS27748-MAS27751,Distance data with electronic stabilization program information-Distance pulses: largest negative jump,0, m
MAS27748-MAS27752,Distance data with electronic stabilization program information-Distance pulses: total jumps,0, m
MAS27748-MAS27753,Distance data with electronic stabilization program information-Distance pulses: jump balance,0, m
MAS27748-MAS27754,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: number,2,
MAS27748-MAS27755,Distance data with electronic stabilization program information-Electronic stabilization program communication failures: total duration,242, s
MAS27748-MAS27756,Distance data with electronic stabilization program information-Longest electronic stabilization program communication failure,5, min
ENG186121,Authentic_time_current_counter_kl15_since_last_sync,0,
ENG250331-ENG250595,Condition_check_1-State_info_1,05,
ENG250331-ENG250481,Condition_check_1-State_info_2,01,
ENG250331-ENG250687,Condition_check_1-Transponder_Identification,00 00 00 00,
ENG250332-ENG250595,Condition_check_2-State_info_1,05,
ENG250332-ENG250481,Condition_check_2-State_info_2,01,
ENG250332-ENG250687,Condition_check_2-Transponder_Identification,00 00 00 00,
ENG254614-IDE09469,DNH_someip_data_bus_service_error_value_received-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254614-MAS05767,DNH_someip_data_bus_service_error_value_received-port,00 00,
ENG254614-MAS20533,DNH_someip_data_bus_service_error_value_received-Service Id,00 00,
ENG254614-MAS20961,DNH_someip_data_bus_service_error_value_received-Method ID,00 00,
ENG254614-MAS20968,DNH_someip_data_bus_service_error_value_received-Number of services,5,
ENG254615-IDE09469,DNH_someip_data_bus_service_implausible-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254615-MAS05767,DNH_someip_data_bus_service_implausible-port,00 00,
ENG254615-MAS20533,DNH_someip_data_bus_service_implausible-Service Id,00 00,
ENG254615-MAS20961,DNH_someip_data_bus_service_implausible-Method ID,00 00,
ENG254615-MAS20968,DNH_someip_data_bus_service_implausible-Number of services,31,
ENG254616-IDE09469,DNH_someip_data_bus_service_not_available-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254616-MAS05767,DNH_someip_data_bus_service_not_available-port,00 00,
ENG254616-MAS20533,DNH_someip_data_bus_service_not_available-Service Id,00 00,
ENG254616-MAS20968,DNH_someip_data_bus_service_not_available-Number of services,0,
ENG118786-ENG137129,Driv._Prof._Sel._Dr._Op.-Drehsteller_Ist_Modus,0,
ENG118786-ENG137130,Driv._Prof._Sel._Dr._Op.-Drehsteller_Modus,0,
ENG118786-ENG137133,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_HVEM,0,
ENG118786-ENG137135,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Mo_BZS,0,
ENG118786-ENG137134,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Step_Reduction,0,
ENG118786-ENG137132,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_Lock_Signal_Trailer,0,
ENG118786-ENG137131,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Modus,not detected,
ENG118786-ENG118748,Driv._Prof._Sel._Dr._Op.-Driving_Profile_Selection_New_Driverwish_Profile,not detected,
ENG118783-ENG118728,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Coordinator_Sub_State_Value,5,
ENG118783-ENG118729,Driv._Prof._Sel._Sys._Subst.-Driving_Profile_Selection_Startup_State,active,
ENG286564,Easy_open_HBFS_unavailable_reason,Terminal 15 active,
ENG286565,Easy_open_HFS_unavailable_reason,Terminal 15 active,
ENG157804-ENG255267,EgoMaster_output_signals_accelerations-AccX,0.00, m/s²
ENG157804-ENG255268,EgoMaster_output_signals_accelerations-AccXConf,1,
ENG157804-ENG255269,EgoMaster_output_signals_accelerations-AccXVarUEst,173442575.38,
ENG157804-ENG255270,EgoMaster_output_signals_accelerations-AccY,0.00, m/s²
ENG157804-ENG255271,EgoMaster_output_signals_accelerations-AccYConf,1,
ENG157804-ENG255272,EgoMaster_output_signals_accelerations-AccYVarUEst,113295003.29,
ENG157804-ENG255273,EgoMaster_output_signals_accelerations-AccZ,0.00, m/s²
ENG157804-ENG255274,EgoMaster_output_signals_accelerations-AccZConf,2,
ENG157805-ENG98850,EgoMaster_output_signals_angular_rates-Pitch rate,0.00, rad/s
ENG157805-ENG256174,EgoMaster_output_signals_angular_rates-PitchRate Conf,2,
ENG157805-ENG98869,EgoMaster_output_signals_angular_rates-Roll rate,0.00, rad/s
ENG157805-ENG256292,EgoMaster_output_signals_angular_rates-RollRate Conf,2,
ENG157805-ENG256717,EgoMaster_output_signals_angular_rates-YawRate,0.00, rad/s
ENG157805-ENG256718,EgoMaster_output_signals_angular_rates-YawRate Conf,0,
ENG157805-ENG256719,EgoMaster_output_signals_angular_rates-YawRate VarUEst,12612.70,
ENG157806-ENG255776,EgoMaster_output_signals_body_data-Height2 USK,0, mm
ENG157806-ENG255777,EgoMaster_output_signals_body_data-Height2 USK Conf,2,
ENG157806-ENG255778,EgoMaster_output_signals_body_data-Height2 USK Variance,0.00,
ENG157806-ENG256169,EgoMaster_output_signals_body_data-Pitch Angle2 Gravity,0.00, rad
ENG157806-ENG256170,EgoMaster_output_signals_body_data-Pitch Angle2 Gravity Conf,1,
ENG157806-ENG256171,EgoMaster_output_signals_body_data-Pitch Angle2 USK,0.00, rad
ENG157806-ENG256172,EgoMaster_output_signals_body_data-Pitch Angle2 USK Conf,2,
ENG157806-ENG256173,EgoMaster_output_signals_body_data-Pitch Angle2 USK Variance,0.00,
ENG157806-ENG256287,EgoMaster_output_signals_body_data-Roll Angle2 Gravity,0.00, rad
ENG157806-ENG256288,EgoMaster_output_signals_body_data-Roll Angle2 Gravity Conf,2,
ENG157806-ENG256289,EgoMaster_output_signals_body_data-Roll Angle2 USK,0.00, rad
ENG157806-ENG256290,EgoMaster_output_signals_body_data-Roll Angle2 USK Conf,2,
ENG157806-ENG256291,EgoMaster_output_signals_body_data-Roll Angle2 USK Variance,0.00,
ENG157808-ENG255561,EgoMaster_output_signals_curve_data-Curvature,-0.00,
ENG157808-ENG255562,EgoMaster_output_signals_curve_data-Curvature Conf,0,
ENG157808-ENG255563,EgoMaster_output_signals_curve_data-Curvature CorrHAL,0.00, rad
ENG157808-ENG255564,EgoMaster_output_signals_curve_data-Curvature YawRateUsed,No,
ENG157808-ENG255565,EgoMaster_output_signals_curve_data-CurvatureCorr HALConf,0,
ENG157808-ENG255566,EgoMaster_output_signals_curve_data-CurvatureYaw RateUsedConf,2,
ENG157808-ENG256316,EgoMaster_output_signals_curve_data-SideSlipAngle,0.00, rad
ENG157808-ENG256317,EgoMaster_output_signals_curve_data-SideSlipAngle Conf,2,
ENG157809-ENG101762,EgoMaster_output_signals_gnss-Altitude,253.00, m
ENG157809-ENG255296,EgoMaster_output_signals_gnss-Altitude Conf,0,
ENG157809-ENG159412,EgoMaster_output_signals_gnss-Heading,75.00, °
ENG157809-ENG255767,EgoMaster_output_signals_gnss-Heading Conf,0,
ENG157809-ENG159329,EgoMaster_output_signals_gnss-Latitude,35905746,
ENG157809-ENG255860,EgoMaster_output_signals_gnss-Latitude Conf,0,
ENG157809-ENG159328,EgoMaster_output_signals_gnss-Longitude,-84111274,
ENG157809-ENG256037,EgoMaster_output_signals_gnss-Longitude Conf,0,
ENG157810-ENG255546,EgoMaster_output_signals_misc-Control Intervention,0,
ENG157810-ENG255547,EgoMaster_output_signals_misc-Control Intervention Conf,0,
ENG157810-ENG255637,EgoMaster_output_signals_misc-Driving Direction P Range,0, %
ENG157810-ENG255638,EgoMaster_output_signals_misc-Driving Direction P Range Conf,0,
ENG157810-ENG256223,EgoMaster_output_signals_misc-Pose ASIL Qualifier,security_requirements_not_fulfilled,
ENG157810-ENG256224,EgoMaster_output_signals_misc-Pose ASIL Qualifier Conf,0,
ENG157810-ENG256389,EgoMaster_output_signals_misc-Stand Still P Range,100, %
ENG157810-ENG256390,EgoMaster_output_signals_misc-Stand Still P Range Conf,0,
ENG157811-ENG256229,EgoMaster_output_signals_pose_data-Position X,0, m
ENG157811-ENG256230,EgoMaster_output_signals_pose_data-Position XConf,0,
ENG157811-ENG256231,EgoMaster_output_signals_pose_data-Position XDelta Variance,0.00,
ENG157811-ENG256232,EgoMaster_output_signals_pose_data-Position Xmm,0, mm
ENG157811-ENG256233,EgoMaster_output_signals_pose_data-Position Y,0, m
ENG157811-ENG256234,EgoMaster_output_signals_pose_data-Position YConf,0,
ENG157811-ENG256235,EgoMaster_output_signals_pose_data-Position YDelta Variance,0.00,
ENG157811-ENG256236,EgoMaster_output_signals_pose_data-Position Ymm,0, mm
ENG157811-ENG255167,EgoMaster_output_signals_pose_data-Yaw angle,0.00, rad
ENG157811-ENG256715,EgoMaster_output_signals_pose_data-Yaw Angle Conf,0,
ENG157811-ENG256716,EgoMaster_output_signals_pose_data-Yaw Angle Delta Variance,0.00,
ENG157812-ENG161844,EgoMaster_output_signals_reserved-DeDevMsgArray_01,0,
ENG157812-ENG161845,EgoMaster_output_signals_reserved-DeDevMsgArray_02,0,
ENG157812-ENG161846,EgoMaster_output_signals_reserved-DeDevMsgArray_03,0,
ENG157812-ENG161847,EgoMaster_output_signals_reserved-DeDevMsgArray_04,0,
ENG157812-ENG161848,EgoMaster_output_signals_reserved-DeDevMsgArray_05,0,
ENG157812-ENG161849,EgoMaster_output_signals_reserved-DeDevMsgArray_06,0,
ENG157812-ENG161850,EgoMaster_output_signals_reserved-DeDevMsgArray_07,0,
ENG157812-ENG161851,EgoMaster_output_signals_reserved-DeDevMsgArray_08,0,
ENG157812-ENG161852,EgoMaster_output_signals_reserved-DeDevMsgArray_09,0,
ENG157812-ENG161853,EgoMaster_output_signals_reserved-DeDevMsgArray_10,0,
ENG157812-ENG161854,EgoMaster_output_signals_reserved-DeDevMsgArray_11,0,
ENG157812-ENG161855,EgoMaster_output_signals_reserved-DeDevMsgArray_12,0,
ENG157813-ENG256406,EgoMaster_output_signals_steering_angles-SteeringAngle FL,-0.00, rad
ENG157813-ENG256407,EgoMaster_output_signals_steering_angles-SteeringAngle FLConf,0,
ENG157813-ENG256408,EgoMaster_output_signals_steering_angles-SteeringAngle FR,-0.00, rad
ENG157813-ENG256409,EgoMaster_output_signals_steering_angles-SteeringAngle FRConf,0,
ENG157813-ENG256410,EgoMaster_output_signals_steering_angles-SteeringAngle RL,0.00, rad
ENG157813-ENG256411,EgoMaster_output_signals_steering_angles-SteeringAngle RLConf,2,
ENG157813-ENG256412,EgoMaster_output_signals_steering_angles-SteeringAngle RR,0.00, rad
ENG157813-ENG256413,EgoMaster_output_signals_steering_angles-SteeringAngle RRConf,2,
ENG157814-ENG255626,EgoMaster_output_signals_velocities-Display Velocity,0.00, m/s
ENG157814-ENG255627,EgoMaster_output_signals_velocities-Display Velocity Conf,1,
ENG157814-ENG256552,EgoMaster_output_signals_velocities-UBound Residual Vel X,-192.00, m/s
ENG157814-ENG256553,EgoMaster_output_signals_velocities-UBound Residual Vel X Conf,0,
ENG157814-ENG256566,EgoMaster_output_signals_velocities-Velocity X,0.00, m/s
ENG157814-ENG256567,EgoMaster_output_signals_velocities-Velocity X Conf,0,
ENG157814-ENG256568,EgoMaster_output_signals_velocities-Velocity X Variance,0.00,
ENG157814-ENG256569,EgoMaster_output_signals_velocities-Velocity Y,0.00, m/s
ENG157814-ENG256570,EgoMaster_output_signals_velocities-Velocity Y Conf,0,
ENG157814-ENG256571,EgoMaster_output_signals_velocities-Velocity Y Variance,0.00,
ENG254620-ENG256642,EgoMaster_output_signals_wheel_data-WCFEEstimatorStatus,80, %
ENG254620-ENG256643,EgoMaster_output_signals_wheel_data-WCFEEstimatorStatus Conf,0,
ENG254620-ENG256644,EgoMaster_output_signals_wheel_data-WheelCircumference,2282, mm
ENG254620-ENG256645,EgoMaster_output_signals_wheel_data-WheelCircumference Conf,0,
ENG254620-ENG256646,EgoMaster_output_signals_wheel_data-WheelCorrFactor FL,1.01,
ENG254620-ENG256647,EgoMaster_output_signals_wheel_data-WheelCorrFactor FLConf,0,
ENG254620-ENG256648,EgoMaster_output_signals_wheel_data-WheelCorrFactor FR,1.01,
ENG254620-ENG256649,EgoMaster_output_signals_wheel_data-WheelCorrFactor FRConf,0,
ENG254620-ENG256650,EgoMaster_output_signals_wheel_data-WheelCorrFactor RL,1.02,
ENG254620-ENG256651,EgoMaster_output_signals_wheel_data-WheelCorrFactor RLConf,0,
ENG254620-ENG256652,EgoMaster_output_signals_wheel_data-WheelCorrFactor RR,1.02,
ENG254620-ENG256653,EgoMaster_output_signals_wheel_data-WheelCorrFactor RRConf,0,
ENG137077-ENG137157,EHR_pool_load-ehr_attribute_pool_load,0.0, %
ENG137077-ENG137156,EHR_pool_load-ehr_segment_pool_load,0.0, %
ENG137077-ENG255696,EHR_pool_load-ehr_speedlimit_pool_load,0.0, %
ENG279104,eMMc_temperature_sensor,22, °C
ENG254720-ENG255783,High_voltage_charging_information-High_voltage_charging_state,Standby_charging_precondition_not_fulfilled,
ENG254720-ENG255784,High_voltage_charging_information-High_voltage_type_of_charging_request,charging_not_requested,
ENG254720-ENG334265,High_voltage_charging_information-Maximum_by_drive_enabled_power,2500, W
ENG370317,History_of_zdc_writing_operations,|Parameter set part number,Parameter set version|56 30 33 39 33 35 34 34 36 44 4B,30 30 30 31|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|2D 2D 2D 2D 2D 2D 2D 2D 2D 2D 2D,2D 2D 2D 2D|,
ENG310450-ENG334072,HV-EM_Autonomous_bidi_charging-Bidi_actual_performance,25600, W
ENG310450-ENG334074,HV-EM_Autonomous_bidi_charging-Bidi_charge_mode,No_bidi_charge,
ENG310450-ENG334229,HV-EM_Autonomous_bidi_charging-Hvem_bidi_specification,0, W
ENG254725-ENG334194,HV-EM_consumer_contingent-Enabling_battery_heater,Release,
ENG254725-ENG255697,HV-EM_consumer_contingent-Enabling_climate_aggregates,Release,
ENG254725-ENG334243,HV-EM_consumer_contingent-Hvem_wake_up,active,
ENG254727-ENG354387,HV-EM_energy_specification-Energy_content_set_point_powertrain,51925, Wh
ENG254727-ENG152032,HV-EM_energy_specification-HV-EM_high_voltage_battery_energy_information,22950, Wh
ENG254728-ENG255786,HV-EM_high_voltage_activation-HV-EM_activation_requirement_by_NVEM,Requirement,
ENG254728-ENG370745,HV-EM_high_voltage_activation-Hvem_battery_conditioning_voko,not active,
ENG254728-ENG370746,HV-EM_high_voltage_activation-Hvem_independent_air_conditioning,not active,
ENG254728-ENG334233,HV-EM_high_voltage_activation-Hvem_ops_hv_presence,Requirement,
ENG254728-ENG152036,HV-EM_high_voltage_activation-HV-EM_recharging_requirement,no request,
ENG254728-ENG334241,HV-EM_high_voltage_activation-Hvem_request_by_hv_charging,not active,
ENG254728-ENG395988,HV-EM_high_voltage_activation-Hvem_request_independent_low_voltage,no request,
ENG254729-ENG255533,HV-EM_operation_data-climate_power,700, W
ENG254729-ENG255581,HV-EM_operation_data-dcdc_power,550, W
ENG254729-ENG125881,HV-EM_operation_data-HV-EM_operation_mode,HV-EM_active,
ENG254730-ENG353491,HV-EM_operation_limitation-Charge_state_hv_battery_display_soc,60.5, %
ENG254730-ENG263259,HV-EM_operation_limitation-HV-EM_approval_dcdc_converter,Release,
ENG254730-ENG152034,HV-EM_operation_limitation-HV-EM_NV_power_limitation,4550, W
ENG254730-ENG152035,HV-EM_operation_limitation-HV-EM_power_limitation,0, W
ENG310451-ENG334228,HV-EM_Power_contingent-Hvem_actual_performance_auxiliary_consumers,1250, W
ENG310451-ENG334236,HV-EM_Power_contingent-Hvem_power_specification_air_conditioner,2500, W
ENG310451-ENG334238,HV-EM_Power_contingent-Hvem_power_specification_battery_heater,0, W
ENG310452-ENG334231,HV-EM_Power_request-Hvem_minimum_power,0, W
ENG310452-ENG334234,HV-EM_Power_request-Hvem_power_intention,2550, W
ENG310452-ENG334293,HV-EM_Power_request-Power_demand_air_conditioner,2550, W
ENG310452-ENG334295,HV-EM_Power_request-Power_demand_battery_heater,0, W
ENG277522-MAS20968,IAA_PSO_Master_someip_data_bus_service_error_value_received-Number of services,1,
ENG277522,IAA_PSO_Master_someip_data_bus_service_error_value_received,|Service Id,Method ID,IPv6 address,port|00 00,00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,00 00|,
ENG277567-MAS20968,IAA_PSO_Master_someip_data_bus_service_implausible-Number of services,15,
ENG277567,IAA_PSO_Master_someip_data_bus_service_implausible,|Service Id,Method ID,IPv6 address,port|00 00,00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,00 00|,
ENG277550-MAS20968,IAA_PSO_Master_someip_data_bus_service_not_available-Number of services,56,
ENG277550,IAA_PSO_Master_someip_data_bus_service_not_available,|Service Id,IPv6 address,port|00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,00 00|,
ENG286616,Last_LIN_Message_BCM_VIP_HBFS,00 00 02 00 FE C8 FF FF,
ENG286617,Last_LIN_Message_BCM_VIP_HFS,00 00 3E 00 FE E8 FF FF,
ENG121906,Last_LIN_Message_Kessy,00 00 3E 00 FE E0 FF FF,
ENG121907,Last_LIN_Message_LIN,00 00 00 00 80 01 00 00,
ENG286618,Last_LIN_Message_VIP_HBFS,00 00 00 00 80 01 00 00,
ENG286619,Last_LIN_Message_VIP_HFS,00 00 00 00 80 01 00 00,
ENG347941,Legislated_obd-requirement_plausible,NO OBD,
ENG254782-IDE09469,MSP-OD_someip_data_bus_service_not_available-IPv6 address,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG254782-MAS05767,MSP-OD_someip_data_bus_service_not_available-port,00 00,
ENG254782-MAS20533,MSP-OD_someip_data_bus_service_not_available-Service Id,18 00,
ENG254782-MAS20968,MSP-OD_someip_data_bus_service_not_available-Number of services,142,
ENG310457-ENG334195,NVEM_12V_autonome_Funktionen-Energieinhalt_Primärseite,45900,
ENG310457-ENG334211,NVEM_12V_autonome_Funktionen-functional_requirement_NVEM,8,
ENG310457-ENG334297,NVEM_12V_autonome_Funktionen-Qe_auf_Basis_SOC,27, Ah
ENG310457-ENG334298,NVEM_12V_autonome_Funktionen-Qe_Batterie,32, Ah
ENG310457-ENG334299,NVEM_12V_autonome_Funktionen-QKomfort,33, Ah
ENG310457-ENG334442,NVEM_12V_autonome_Funktionen-Zaehler_Haeufigkeit_autonomes_Nachladen,0,
ENG310458-ENG334272,Nvem_12V_recognized_battery_data-Nvem_12V_recognized_battery_capacity,58, Ah
ENG310458-ENG334273,Nvem_12V_recognized_battery_data-Nvem_12V_recognized_battery_technology,1,
ENG310459-MAS06344,NVEM_crank_voltage_analysis-Minimum voltage at last engine start,14.65, V
ENG310459-MAS06345,NVEM_crank_voltage_analysis-Minimum voltage at last engine start recognized,not detected,
ENG310459-MAS06346,NVEM_crank_voltage_analysis-Voltage drop through engine start recognized,not detected,
ENG310459-MAS06347,NVEM_crank_voltage_analysis-Current voltage drop last start,12.65, V
ENG310459-MAS06348,NVEM_crank_voltage_analysis-Normed voltage drop,12.65, V
ENG310459-MAS11064,NVEM_crank_voltage_analysis-Current last engine start,1, A
ENG310459-MAS11065,NVEM_crank_voltage_analysis-Current delta last engine start,1, A
ENG310460,NVEM_Grund_falsch_codiert,0,
ENG310461-ENG255780,NVEM_idle_speed_increase-Heizleistungskontingent_Stufe,Stage 5,
ENG310462-IDE06339,NVEM_mode_operation-Hybrid readiness: status,not active,
ENG310462-MAS03679,NVEM_mode_operation-Terminal 15 status,active,
ENG310462-ENG278695,NVEM_mode_operation-Comfort_Ready_Status,active,
ENG310462-ENG157286,NVEM_mode_operation-Operation_mode,11,
ENG310462-ENG334324,NVEM_mode_operation-safety_drivestate,3,
ENG310463-MAS06117,NVEM_Sollvorgaben-Specified voltage,14.900, V
ENG310463-MAS09777,NVEM_Sollvorgaben-Target current,174.0, A
ENG310463-ENG334355,NVEM_Sollvorgaben-Sollleistung,4550, W
ENG310463-ENG334356,NVEM_Sollvorgaben-Sollleistung_grund,0,
ENG310463-ENG334357,NVEM_Sollvorgaben-Sollleistung_vorgabe,4550, W
ENG310463-ENG334358,NVEM_Sollvorgaben-Spannung_soll_grund,6,
ENG310463-ENG334370,NVEM_Sollvorgaben-Strom_soll_grund,0,
ENG310464-MAS00978,NVEM_VST_Zustand-Priority,0,
ENG310464-ENG334316,NVEM_VST_Zustand-Reason_consumer_cutoff,4098,
ENG310464-ENG334423,NVEM_VST_Zustand-Trigger_consumer_cutoff,0,
ENG279180,onBoard_temperature_sensor,20, °C
ENG297745-MAS11001,Power_network_state-Reason,15,
ENG121946-MAS06517,Rear_Lid_Opening_Sender_Counter-Rear spoiler counter,91,
ENG121946-MAS12705,Rear_Lid_Opening_Sender_Counter-Number of detected proximities,0,
ENG121946-MAS12706,Rear_Lid_Opening_Sender_Counter-Number of detected kick movements,15,
ENG121946-MAS12707,Rear_Lid_Opening_Sender_Counter-Number of transmitter activations,91,
ENG254841-ENG255534,User State Server-Comfort Ready Status,active,
ENG254841-ENG255633,User State Server-Driver Presence Status,driver_present_verified,
ENG254841-ENG255634,User State Server-Driver Presence_Qbit,gueltiger_Wert,
ENG254841-ENG255639,User State Server-DTC OccupantPresenceService Error,no error,
ENG254841-ENG255640,User State Server-DTC OccupantPresenceService Restriction,no restriction,
ENG254841-ENG255787,User State Server-HV_Anwesenheit,HV request,
ENG254841-ENG256105,User State Server-Occupant Presence Status,OccupantPresentVerified,
ENG254841-ENG256557,User State Server-USS CAN Nachlauf,NM Level 2,
ENG286726-MAS06517,Vip_sliding_door_driver_side_power_opening_control_unit_counter_values-Rear spoiler counter,0,
ENG286726-MAS12705,Vip_sliding_door_driver_side_power_opening_control_unit_counter_values-Number of detected proximities,25,
ENG286726-MAS12706,Vip_sliding_door_driver_side_power_opening_control_unit_counter_values-Number of detected kick movements,0,
ENG286726-MAS12707,Vip_sliding_door_driver_side_power_opening_control_unit_counter_values-Number of transmitter activations,0,
ENG286731-MAS06517,Vip_sliding_door_passenger_side_power_opening_control_unit_counter_values-Rear spoiler counter,0,
ENG286731-MAS12705,Vip_sliding_door_passenger_side_power_opening_control_unit_counter_values-Number of detected proximities,25,
ENG286731-MAS12706,Vip_sliding_door_passenger_side_power_opening_control_unit_counter_values-Number of detected kick movements,0,
ENG286731-MAS12707,Vip_sliding_door_passenger_side_power_opening_control_unit_counter_values-Number of transmitter activations,0,
Elapsed Time: 02:37
Jef
HQ
blockmap-23-1N3-909-059-AA_WVGAWVEB7SH010695-20241230-1133.CSV
;SW:1N3-909-059-AA   HW:1N3-909-059 ---  Brake Booster
;Component:EBB-ZF-Gen1   H47 0853, Coding:A0404080600028
;EV_BrakeBoostZFMEBUNECE,001034,EV_BrakeBoostZFMEBUNECE.rod
;Monday,30,December,2024,11:33:18:18177
;VCDS Version: Beta 24.12.0 (x64)  Data version: 20241120 DS361.3
;VCID: 74B6062B3E3F5FBA67A-8020-R SFD
Group,Description,Actual
IDE06422-ENG103176,IUMPR_1-General Denominator,12320,
IDE06422-ENG102823,IUMPR_1-Ignition Cycle Counter,12336,
IDE06422-ENG100120,IUMPR_1-Milage,2560, km
IDE06422-ENG102846,IUMPR_1-Number of IUMPR Records,0,
IDE06423-ENG101817,IUMPR_2-Denominator,12320,
IDE06423-ENG103772,IUMPR_2-DFCC Value,256,
IDE06423-ENG99150,IUMPR_2-Numerator,12336,
IDE06423-ENG101622,IUMPR_2-Record Number,0,
IDE06424-ENG101817,IUMPR_3-Denominator,12320,
IDE06424-ENG103772,IUMPR_3-DFCC Value,256,
IDE06424-ENG99150,IUMPR_3-Numerator,12336,
IDE06424-ENG101622,IUMPR_3-Record Number,0,
IDE08586-IDE02955,Status: electromechanical power brake-System status,ready,
IDE10300,OBD Driving Cycle detected,active,
IDE13138-MAS03034,Sluggishness test-Pressure,0.00, bar
IDE13138-MAS10346,Sluggishness test-Engine torque,0.00, Nm
IDE13138-MAS19863,Sluggishness test-Status of parking brake: electromechanical,0,
IDE13138-MAS19866,Sluggishness test-Travel pressure rod,0.000000, mm
IDE13845,Production mode status,not active,
IDE14696-MAS03458,Leakage test-Differential pressure,0.00, bar
IDE14696-MAS19863,Leakage test-Status of parking brake: electromechanical,0,
IDE14696-MAS19864,Leakage test-Brake pressure 1,0, bar
IDE14696-MAS19865,Leakage test-Brake pressure 2,0, bar
Elapsed Time: 00:03
blockmap-2B-3WA-905-861_WVGAWVEB7SH010695-20241230-1133.CSV
;SW:3WA-905-861   HW:3WA-905-861 ---  Steer. Col. Lock
;Component:ELV-MQB_UNECE H05 0063, Coding:8880000000000000
;EV_ELVMarqUNECE,003006,EV_ELVMarqUNECE.rod
;Monday,30,December,2024,11:33:31:18177
;VCID: 084E42DB52B74B5A3B2-805C-R SFD
IDE00019,Voltage terminal 30,15.1,
IDE00021,Engine RPM,128.00, /min
IDE00021-MAS00058,Engine RPM-Implausible,No,
IDE00021-MAS00103,Engine RPM-invalid,No,
IDE00021-MAS02239,Engine RPM-outdated,No,
IDE00021-MAS02246,Engine RPM-Timeout,No,
IDE00075-MAS00058,Vehicle speed-Implausible,No,
IDE00075-MAS00103,Vehicle speed-invalid,No,
IDE00075-MAS02246,Vehicle speed-Timeout,No,
IDE00096-MAS02239,Selector lever position-outdated,No,
IDE00096-MAS02246,Selector lever position-Timeout,No,
IDE00096,Selector lever position,not OK.,
IDE00660-MAS02246,Drive readiness-Timeout,No,
IDE00660,Drive readiness,not active,
IDE01766-MAS03714,Distance impulses-Left front wheel,0,
IDE01766-MAS03715,Distance impulses-Right front wheel,0,
IDE01766-MAS03716,Distance impulses-Left rear wheel,0,
IDE01766-MAS03717,Distance impulses-Right rear wheel,0,
IDE01766-MAS11907,Distance impulses-Left front wheel signal state timeout,No,
IDE01766-MAS11908,Distance impulses-Right front wheel signal state timeout,No,
IDE01766-MAS11909,Distance impulses-Left rear wheel signal state timeout,No,
IDE01766-MAS11910,Distance impulses-Right rear wheel signal state timeout,No,
IDE01766-MAS11911,Distance impulses-Left front wheel invalid signal state,No,
IDE01766-MAS11912,Distance impulses-Right front wheel invalid signal state,No,
IDE01766-MAS11913,Distance impulses-Left rear wheel invalid signal state,No,
IDE01766-MAS11914,Distance impulses-Right rear wheel invalid signal state,No,
IDE02569-MAS02242,Terminal S: line status-Electronic central electric actual value,On,
IDE02569-MAS02246,Terminal S: line status-Timeout,No,
IDE02570-MAS02242,Terminal 15: line status-Electronic central electric actual value,On,
IDE02570-MAS02246,Terminal 15: line status-Timeout,No,
IDE02573,End switch for steering column: unlocked: status,operated,
IDE02574,End switch for steering column: locked: status,Not operated,
IDE02575,Unlocking motor: activation status,not activated,
IDE02576,Locking motor: activation status,not activated,
IDE02577,Steering column twisting: status,not twisted,
IDE02579-MAS02246,Park selector lever position-Timeout,No,
IDE02579,Park selector lever position,locked,
IDE02580,Number of unlocks,209,
IDE02588,Terminal signals and start release,not enabled,
IDE02589-MAS02246,Rotary latch status-Timeout,No,
IDE02589,Rotary latch status,closed,
IDE02590-MAS02246,External vehicle locking: SPECIFIED condition-Timeout,No,
IDE02590-MAS02257,External vehicle locking: SPECIFIED condition-SPECIFIED condition of fuse per remote/key,Vehicle not secured,
IDE02590,External vehicle locking: SPECIFIED condition,unlocked,
IDE02759-MAS02345,Steering column lock current condition/learn mode-Current condition,Immobilizer download obtained,
IDE02759-MAS02349,Steering column lock current condition/learn mode-Learn mode,Adapted,
IDE03527-IDE03411,CAN signals-Red warning lamp,not active,
IDE03527-MAS04444,CAN signals-Wake-up,not active,
IDE03527-MAS05099,CAN signals-Driver information: steering column lock defective,not active,
IDE03527-MAS05100,CAN signals-Driver information: steering column lock: workshop,not active,
IDE03527-MAS05101,CAN signals-Driver information: move steering,not active,
IDE06746-IDE00020,Locking requirements-Terminal 15 status,Condition not met,
IDE06746-IDE00021,Locking requirements-Engine RPM,Condition not met,
IDE06746-IDE00075,Locking requirements-Vehicle speed,Condition met,
IDE06746-IDE00660,Locking requirements-Drive readiness,Condition not met,
IDE06746-IDE01715,Locking requirements-Status terminal S,Condition not met,
IDE06746-IDE01766,Locking requirements-Distance impulses,Condition met,
IDE06746-IDE02052,Locking requirements-Malfunction message in instrument panel,Condition met,
IDE06746-IDE02579,Locking requirements-Park selector lever position,Condition not met,
IDE06746-MAS02349,Locking requirements-Learn mode,Adapted,
IDE06746-MAS08251,Locking requirements-Vehicle speed signals: communication status,Condition met,
IDE06746-MAS08252,Locking requirements-Terminal status signal: communication status,Condition met,
IDE06746-MAS08441,Locking requirements-Test of locking requirements,not active,
IDE06746-MAS08791,Locking requirements-Vehicle speed signals: cyclical reception,Condition met,
IDE06746-MAS08792,Locking requirements-Signals for distance pulses: cyclical reception,Condition met,
IDE06746-MAS08794,Locking requirements-Terminal status signal: cyclical reception,Condition met,
IDE06746-MAS11697,Locking requirements-Signals for distance pulses: communication status,Condition met,
IDE09059-MAS02246,Request terminal release-Timeout,No,
IDE09059,Request terminal release,No,
IDE09064,Status: unlock trigger,No,
IDE09065-MAS02246,Status: remote start-Timeout,No,
IDE09065,Status: remote start,not active,
IDE09066-MAS02246,ID sensor exiting vehicle-Timeout,No,
IDE09066,ID sensor exiting vehicle,No,
ENG111213-ENG128873,Activated_Fault_Reactions-Locking disabled,No,
ENG128821-ENG111184,Errorcounter lifetime-AD-Converter corrupt,0,
ENG128821-ENG128856,Errorcounter lifetime-AD-Converter corrupt unlocking cycle,No,
ENG128821-ENG128851,Errorcounter lifetime-Areacheck highside,0,
ENG128821-ENG128852,Errorcounter lifetime-Areacheck highside unlocking cycle,No,
ENG128821-ENG128853,Errorcounter lifetime-Areacheck lowside,0,
ENG128821-ENG128854,Errorcounter lifetime-Areacheck lowside unlocking cycle,No,
ENG128821-ENG111176,Errorcounter lifetime-CoCo RAM-Check,0,
ENG128821-ENG128846,Errorcounter lifetime-CoCo RAM-Check unlocking cycle,No,
ENG128821-ENG111177,Errorcounter lifetime-CoCo ROM-Check,0,
ENG128821-ENG128847,Errorcounter lifetime-CoCo ROM-Check unlocking cycle,No,
ENG128821-ENG111194,Errorcounter lifetime-CPU-Test CoCo,0,
ENG128821-ENG128848,Errorcounter lifetime-CPU-Test CoCo unlocking cycle,No,
ENG128821-ENG111192,Errorcounter lifetime-CPU-Test HaCo,0,
ENG128821-ENG128844,Errorcounter lifetime-CPU-Test HaCo unlocking cycle,No,
ENG128821-ENG111187,Errorcounter lifetime-Enable CoCo incorrect active locking,0,
ENG128821-ENG128858,Errorcounter lifetime-Enable CoCo incorrect active locking unlocking cycle,No,
ENG128821-ENG111181,Errorcounter lifetime-Endposition switches implausible,0,
ENG128821-ENG128855,Errorcounter lifetime-Endposition switches implausible unlocking cycle,No,
ENG128821-ENG128872,Errorcounter lifetime-Endposition_Button_Unlocked_Change_To_Not_Activated_While_Driving,0,
ENG128821-ENG128870,Errorcounter lifetime-Endposition_Locked_Not_Reached,0,
ENG128821-ENG128871,Errorcounter lifetime-Endposition_Locked_Not_Reached unlocking cycle,No,
ENG128821-ENG162685,Errorcounter lifetime-HaCo CAN-Cell-Check,0,
ENG128821-ENG162686,Errorcounter lifetime-HaCo CAN-Cell-Check unlocking cycle,No,
ENG128821-ENG111185,Errorcounter lifetime-HaCo CoCo communication disturbed,0,
ENG128821-ENG128857,Errorcounter lifetime-HaCo CoCo communication disturbed unlocking cycle,No,
ENG128821-ENG352066,Errorcounter lifetime-HaCo ECC Flash Check,0,
ENG128821-ENG352780,Errorcounter lifetime-HaCo ECC Flash-Check unlocking cycle,No,
ENG128821-ENG356279,Errorcounter lifetime-HaCo ECC SRAM Check,0,
ENG128821-ENG355067,Errorcounter lifetime-HaCo ECC SRAM-Check unlocking cycle,No,
ENG128821-ENG111175,Errorcounter lifetime-HaCo EEPROM-Check,0,
ENG128821-ENG128845,Errorcounter lifetime-HaCo EEPROM-Check unlocking cycle,No,
ENG128821-ENG111173,Errorcounter lifetime-HaCo RAM-Check,0,
ENG128821-ENG128842,Errorcounter lifetime-HaCo RAM-Check unlocking cycle,No,
ENG128821-ENG111174,Errorcounter lifetime-HaCo ROM-Check,0,
ENG128821-ENG128843,Errorcounter lifetime-HaCo ROM-Check unlocking cycle,No,
ENG128821-ENG353074,Errorcounter lifetime-Hardfault HaCo Check,0,
ENG128821-ENG352312,Errorcounter lifetime-Hardfault HaCo unlocking cycle,No,
ENG128821-ENG128868,Errorcounter lifetime-Invalid eeprom data immobilizer,0,
ENG128821-ENG128869,Errorcounter lifetime-Invalid eeprom data immobilizer unlocking cycle,No,
ENG128821-ENG357002,Errorcounter lifetime-Memory Management HaCo Check,0,
ENG128821-ENG355666,Errorcounter lifetime-Memory Management HaCo unlocking cycle,No,
ENG128821-ENG111189,Errorcounter lifetime-No CoCo enable locking,0,
ENG128821-ENG128859,Errorcounter lifetime-No CoCo enable locking unlocking cycle,No,
ENG128821-ENG111195,Errorcounter lifetime-Program sequence CoCo,0,
ENG128821-ENG128863,Errorcounter lifetime-Program sequence CoCo unlocking cycle,No,
ENG128821-ENG111193,Errorcounter lifetime-Program sequence HaCo,0,
ENG128821-ENG128862,Errorcounter lifetime-Program sequence HaCo unlocking cycle,No,
ENG128821-ENG111190,Errorcounter lifetime-Reset HaCo CoCo failed,0,
ENG128821-ENG128860,Errorcounter lifetime-Reset HaCo CoCo failed unlocking cycle,No,
ENG128821-ENG111191,Errorcounter lifetime-Reset SBC HaCo failed,0,
ENG128821-ENG128861,Errorcounter lifetime-Reset SBC HaCo failed unlocking cycle,No,
ENG128821-ENG119956,Errorcounter lifetime-Return address,00 00 00 00,
ENG128821-ENG128866,Errorcounter lifetime-SDA-Error CoCo,0,
ENG128821-ENG128867,Errorcounter lifetime-SDA-Error CoCo unlocking cycle,No,
ENG128821-ENG128864,Errorcounter lifetime-SDA-Error HaCo,0,
ENG128821-ENG128865,Errorcounter lifetime-SDA-Error HaCo unlocking cycle,No,
ENG128821-ENG111179,Errorcounter lifetime-Shortcut motor driver highside,0,
ENG128821-ENG128849,Errorcounter lifetime-Shortcut motor driver highside unlocking cycle,No,
ENG128821-ENG111180,Errorcounter lifetime-Shortcut motor driver lowside,0,
ENG128821-ENG128850,Errorcounter lifetime-Shortcut motor driver lowside unlocking cycle,No,
ENG128821-ENG353840,Errorcounter lifetime-Usage Fault HaCo Check,0,
ENG128821-ENG354256,Errorcounter lifetime-Usage Fault HaCo unlocking cycle,No,
ENG128820,Free_Releases_Numbers,256,
ENG128822-MAS02538,functional_check-End of assembly line OK,Confirmed,
ENG128822-ENG128823,functional_check-functional_check_manufacturer,Confirmed,
ENG128822-ENG128824,functional_check-functional_check_steering_column_supplier,Not confirmed,
Elapsed Time: 00:05
blockmap-36-1N3-959-760-H_WVGAWVEB7SH010695-20241230-1133.CSV
;SW:1N3-959-760-H   HW:1N3-959-760-H ---  Seat Mem. Drvr
;Component:MEM-FS        011 0571, Coding:0118BA4000013A008803010121010000000000000000000000000000215000
;EV_SCMDriveSideCONTIAU736,006013,EV_SCMDriveSideCONTIAU736_VW42.rod
;Monday,30,December,2024,11:33:44:18177
;VCID: 3E22E40340F3C5EA41E-806A-R
IDE00019-MAS00043,Voltage terminal 30-Terminal 30 power supply,14.90, V
IDE00102,Control Module temperature,32,
IDE00787,Cause for cancellation,none,
IDE01277-IDE09268,Counter of compressor activations-Switch on occurrences of compressor,0, counts
IDE01277-MAS06166,Counter of compressor activations-Current operation time,0, s
IDE01457,Energy management deactivation stage,Deactivation stage 0,
IDE05738-MAS12801,Subssystem diagnosis classes-DK0 systems supported,DK0 systems not supported,
IDE05738-MAS12803,Subssystem diagnosis classes-DK1 systems supported,DK1 systems not supported,
IDE05738-MAS12805,Subssystem diagnosis classes-DK2/DK2F systems supported,DK2/DK2F systems not supported,
IDE05738-MAS12807,Subssystem diagnosis classes-DK3 or DK4 high/low systems supported,DK3 or DK4 high/low systems not supported,
IDE06510-MAS01390,Adjustment for backrest angle-Block 1,34045,
IDE06510-MAS01391,Adjustment for backrest angle-Block 2,32462,
IDE06510-MAS02282,Adjustment for backrest angle-Position,32722,
IDE06510-MAS02955,Adjustment for backrest angle-Engine temperature,25, °C
IDE06510-MAS03129,Adjustment for backrest angle-Reset counter,48,
IDE06510-MAS04160,Adjustment for backrest angle-Load change,49,
IDE06510-MAS04337,Adjustment for backrest angle-Engine current,0, A
IDE06510-MAS05370,Adjustment for backrest angle-Direction of movement,Not operated,
IDE06510-MAS05563,Adjustment for backrest angle-Norming,standardized,
IDE06510-MAS05719,Adjustment for backrest angle-Maximum travel,1583,
IDE06510-MAS12838,Adjustment for backrest angle-Standardization flag,standardized,
IDE06511-MAS01390,Seat height adjustment-Block 1,33270,
IDE06511-MAS01391,Seat height adjustment-Block 2,32769,
IDE06511-MAS02282,Seat height adjustment-Position,33211,
IDE06511-MAS02955,Seat height adjustment-Engine temperature,25, °C
IDE06511-MAS03129,Seat height adjustment-Reset counter,6,
IDE06511-MAS04160,Seat height adjustment-Load change,46,
IDE06511-MAS04337,Seat height adjustment-Engine current,0, A
IDE06511-MAS05370,Seat height adjustment-Direction of movement,Not operated,
IDE06511-MAS05563,Seat height adjustment-Norming,standardized,
IDE06511-MAS05719,Seat height adjustment-Maximum travel,501,
IDE06511-MAS12838,Seat height adjustment-Standardization flag,standardized,
IDE06512-MAS01390,Adjustment for seat forward/back position-Block 1,33089,
IDE06512-MAS01391,Adjustment for seat forward/back position-Block 2,32537,
IDE06512-MAS02282,Adjustment for seat forward/back position-Position,32999,
IDE06512-MAS02955,Adjustment for seat forward/back position-Engine temperature,25, °C
IDE06512-MAS03129,Adjustment for seat forward/back position-Reset counter,22,
IDE06512-MAS04160,Adjustment for seat forward/back position-Load change,587,
IDE06512-MAS04337,Adjustment for seat forward/back position-Engine current,0, A
IDE06512-MAS05370,Adjustment for seat forward/back position-Direction of movement,Not operated,
IDE06512-MAS05563,Adjustment for seat forward/back position-Norming,standardized,
IDE06512-MAS05719,Adjustment for seat forward/back position-Maximum travel,552,
IDE06512-MAS12838,Adjustment for seat forward/back position-Standardization flag,standardized,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not active,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not active,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not active,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not active,
IDE06614-MAS01601,Memory seat adjustment control head-storing,not active,
IDE06683-MAS01390,Seat inclination adjustment-Block 1,33031,
IDE06683-MAS01391,Seat inclination adjustment-Block 2,32770,
IDE06683-MAS02282,Seat inclination adjustment-Position,32905,
IDE06683-MAS02955,Seat inclination adjustment-Engine temperature,25, °C
IDE06683-MAS03129,Seat inclination adjustment-Reset counter,17,
IDE06683-MAS04160,Seat inclination adjustment-Load change,38,
IDE06683-MAS04337,Seat inclination adjustment-Engine current,0, A
IDE06683-MAS05370,Seat inclination adjustment-Direction of movement,Not operated,
IDE06683-MAS05563,Seat inclination adjustment-Norming,standardized,
IDE06683-MAS05719,Seat inclination adjustment-Maximum travel,261,
IDE06683-MAS12838,Seat inclination adjustment-Standardization flag,standardized,
IDE06684-MAS01390,Lumbar support height adjustment-Block 1,0,
IDE06684-MAS01391,Lumbar support height adjustment-Block 2,0,
IDE06684-MAS02282,Lumbar support height adjustment-Position,0,
IDE06684-MAS02955,Lumbar support height adjustment-Engine temperature,0, °C
IDE06684-MAS03129,Lumbar support height adjustment-Reset counter,0,
IDE06684-MAS04160,Lumbar support height adjustment-Load change,0,
IDE06684-MAS04337,Lumbar support height adjustment-Engine current,0, A
IDE06684-MAS05370,Lumbar support height adjustment-Direction of movement,Not operated,
IDE06684-MAS05563,Lumbar support height adjustment-Norming,not normed,
IDE06684-MAS05719,Lumbar support height adjustment-Maximum travel,0,
IDE06684-MAS12838,Lumbar support height adjustment-Standardization flag,never normed,
IDE06685-MAS01390,Lumbar support longitudinal position adjustment-Block 1,0,
IDE06685-MAS01391,Lumbar support longitudinal position adjustment-Block 2,0,
IDE06685-MAS02282,Lumbar support longitudinal position adjustment-Position,0,
IDE06685-MAS02955,Lumbar support longitudinal position adjustment-Engine temperature,0, °C
IDE06685-MAS03129,Lumbar support longitudinal position adjustment-Reset counter,0,
IDE06685-MAS04160,Lumbar support longitudinal position adjustment-Load change,0,
IDE06685-MAS04337,Lumbar support longitudinal position adjustment-Engine current,0, A
IDE06685-MAS05370,Lumbar support longitudinal position adjustment-Direction of movement,Not operated,
IDE06685-MAS05563,Lumbar support longitudinal position adjustment-Norming,not normed,
IDE06685-MAS05719,Lumbar support longitudinal position adjustment-Maximum travel,0,
IDE06685-MAS12838,Lumbar support longitudinal position adjustment-Standardization flag,never normed,
IDE06871-IDE06510,Seat adjustment control head-Adjustment for backrest angle,Not operated,
IDE06871-IDE06511,Seat adjustment control head-Seat height adjustment,Not operated,
IDE06871-IDE06512,Seat adjustment control head-Adjustment for seat forward/back position,Not operated,
IDE06871-IDE06683,Seat adjustment control head-Seat inclination adjustment,Not operated,
IDE06871-IDE06684,Seat adjustment control head-Lumbar support height adjustment,Not operated,
IDE06871-IDE06685,Seat adjustment control head-Lumbar support longitudinal position adjustment,Not operated,
IDE06871-IDE08989,Seat adjustment control head-Seat depth adjustment,Not operated,
IDE06871-IDE08990,Seat adjustment control head-Backrest top adjustment,Not operated,
IDE06871-IDE08991,Seat adjustment control head-Belt height adjustment,Not operated,
IDE06871-IDE11024,Seat adjustment control head-Headrest height adjustment,Not operated,
IDE06871-IDE11025,Seat adjustment control head-Headrest length adjustment,Not operated,
IDE07159,Control module switch-off: counter,0,
IDE07347-IDE06510,Memory setting 1 for seat adjustment-Adjustment for backrest angle,0,
IDE07347-IDE06511,Memory setting 1 for seat adjustment-Seat height adjustment,0,
IDE07347-IDE06512,Memory setting 1 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07347-IDE06683,Memory setting 1 for seat adjustment-Seat inclination adjustment,0,
IDE07347-IDE06684,Memory setting 1 for seat adjustment-Lumbar support height adjustment,0,
IDE07347-IDE06685,Memory setting 1 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07347-IDE08989,Memory setting 1 for seat adjustment-Seat depth adjustment,0,
IDE07347-IDE08990,Memory setting 1 for seat adjustment-Backrest top adjustment,0,
IDE07347-IDE08991,Memory setting 1 for seat adjustment-Belt height adjustment,0,
IDE07347-IDE11024,Memory setting 1 for seat adjustment-Headrest height adjustment,0,
IDE07348-IDE06510,Memory setting 2 for seat adjustment-Adjustment for backrest angle,0,
IDE07348-IDE06511,Memory setting 2 for seat adjustment-Seat height adjustment,0,
IDE07348-IDE06512,Memory setting 2 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07348-IDE06683,Memory setting 2 for seat adjustment-Seat inclination adjustment,0,
IDE07348-IDE06684,Memory setting 2 for seat adjustment-Lumbar support height adjustment,0,
IDE07348-IDE06685,Memory setting 2 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07348-IDE08989,Memory setting 2 for seat adjustment-Seat depth adjustment,0,
IDE07348-IDE08990,Memory setting 2 for seat adjustment-Backrest top adjustment,0,
IDE07348-IDE08991,Memory setting 2 for seat adjustment-Belt height adjustment,0,
IDE07348-IDE11024,Memory setting 2 for seat adjustment-Headrest height adjustment,0,
IDE07349-IDE06510,Memory setting 3 for seat adjustment-Adjustment for backrest angle,0,
IDE07349-IDE06511,Memory setting 3 for seat adjustment-Seat height adjustment,0,
IDE07349-IDE06512,Memory setting 3 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07349-IDE06683,Memory setting 3 for seat adjustment-Seat inclination adjustment,0,
IDE07349-IDE06684,Memory setting 3 for seat adjustment-Lumbar support height adjustment,0,
IDE07349-IDE06685,Memory setting 3 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07349-IDE08989,Memory setting 3 for seat adjustment-Seat depth adjustment,0,
IDE07349-IDE08990,Memory setting 3 for seat adjustment-Backrest top adjustment,0,
IDE07349-IDE08991,Memory setting 3 for seat adjustment-Belt height adjustment,0,
IDE07349-IDE11024,Memory setting 3 for seat adjustment-Headrest height adjustment,0,
IDE07350-IDE06510,Memory setting 4 for seat adjustment-Adjustment for backrest angle,0,
IDE07350-IDE06511,Memory setting 4 for seat adjustment-Seat height adjustment,0,
IDE07350-IDE06512,Memory setting 4 for seat adjustment-Adjustment for seat forward/back position,0,
IDE07350-IDE06683,Memory setting 4 for seat adjustment-Seat inclination adjustment,0,
IDE07350-IDE06684,Memory setting 4 for seat adjustment-Lumbar support height adjustment,0,
IDE07350-IDE06685,Memory setting 4 for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07350-IDE08989,Memory setting 4 for seat adjustment-Seat depth adjustment,0,
IDE07350-IDE08990,Memory setting 4 for seat adjustment-Backrest top adjustment,0,
IDE07350-IDE08991,Memory setting 4 for seat adjustment-Belt height adjustment,0,
IDE07350-IDE11024,Memory setting 4 for seat adjustment-Headrest height adjustment,0,
IDE07351-IDE06510,Memory setting 1: remote master key for seat adjustment-Adjustment for backrest angle,32723,
IDE07351-IDE06511,Memory setting 1: remote master key for seat adjustment-Seat height adjustment,33210,
IDE07351-IDE06512,Memory setting 1: remote master key for seat adjustment-Adjustment for seat forward/back position,32929,
IDE07351-IDE06683,Memory setting 1: remote master key for seat adjustment-Seat inclination adjustment,32904,
IDE07351-IDE06684,Memory setting 1: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07351-IDE06685,Memory setting 1: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07351-IDE08989,Memory setting 1: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07351-IDE08990,Memory setting 1: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07351-IDE08991,Memory setting 1: remote master key for seat adjustment-Belt height adjustment,0,
IDE07351-IDE11024,Memory setting 1: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07352-IDE06510,Memory setting 2: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07352-IDE06511,Memory setting 2: remote master key for seat adjustment-Seat height adjustment,0,
IDE07352-IDE06512,Memory setting 2: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07352-IDE06683,Memory setting 2: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07352-IDE06684,Memory setting 2: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07352-IDE06685,Memory setting 2: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07352-IDE08989,Memory setting 2: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07352-IDE08990,Memory setting 2: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07352-IDE08991,Memory setting 2: remote master key for seat adjustment-Belt height adjustment,0,
IDE07352-IDE11024,Memory setting 2: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07353-IDE06510,Memory setting 3: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07353-IDE06511,Memory setting 3: remote master key for seat adjustment-Seat height adjustment,0,
IDE07353-IDE06512,Memory setting 3: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07353-IDE06683,Memory setting 3: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07353-IDE06684,Memory setting 3: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07353-IDE06685,Memory setting 3: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07353-IDE08989,Memory setting 3: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07353-IDE08990,Memory setting 3: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07353-IDE08991,Memory setting 3: remote master key for seat adjustment-Belt height adjustment,0,
IDE07353-IDE11024,Memory setting 3: remote master key for seat adjustment-Headrest height adjustment,0,
IDE07354-IDE06510,Memory setting 4: remote master key for seat adjustment-Adjustment for backrest angle,0,
IDE07354-IDE06511,Memory setting 4: remote master key for seat adjustment-Seat height adjustment,0,
IDE07354-IDE06512,Memory setting 4: remote master key for seat adjustment-Adjustment for seat forward/back position,0,
IDE07354-IDE06683,Memory setting 4: remote master key for seat adjustment-Seat inclination adjustment,0,
IDE07354-IDE06684,Memory setting 4: remote master key for seat adjustment-Lumbar support height adjustment,0,
IDE07354-IDE06685,Memory setting 4: remote master key for seat adjustment-Lumbar support longitudinal position adjustment,0,
IDE07354-IDE08989,Memory setting 4: remote master key for seat adjustment-Seat depth adjustment,0,
IDE07354-IDE08990,Memory setting 4: remote master key for seat adjustment-Backrest top adjustment,0,
IDE07354-IDE08991,Memory setting 4: remote master key for seat adjustment-Belt height adjustment,0,
IDE07354-IDE11024,Memory setting 4: remote master key for seat adjustment-Headrest height adjustment,0,
IDE08989-MAS01390,Seat depth adjustment-Block 1,0,
IDE08989-MAS01391,Seat depth adjustment-Block 2,0,
IDE08989-MAS02282,Seat depth adjustment-Position,0,
IDE08989-MAS02955,Seat depth adjustment-Engine temperature,0, °C
IDE08989-MAS03129,Seat depth adjustment-Reset counter,0,
IDE08989-MAS04160,Seat depth adjustment-Load change,0,
IDE08989-MAS04337,Seat depth adjustment-Engine current,0, A
IDE08989-MAS05370,Seat depth adjustment-Direction of movement,Not operated,
IDE08989-MAS05563,Seat depth adjustment-Norming,not normed,
IDE08989-MAS05719,Seat depth adjustment-Maximum travel,0,
IDE08989-MAS12838,Seat depth adjustment-Standardization flag,never normed,
IDE08990-MAS01390,Backrest top adjustment-Block 1,0,
IDE08990-MAS01391,Backrest top adjustment-Block 2,0,
IDE08990-MAS02282,Backrest top adjustment-Position,0,
IDE08990-MAS02955,Backrest top adjustment-Engine temperature,0, °C
IDE08990-MAS03129,Backrest top adjustment-Reset counter,0,
IDE08990-MAS04160,Backrest top adjustment-Load change,0,
IDE08990-MAS04337,Backrest top adjustment-Engine current,0, A
IDE08990-MAS05370,Backrest top adjustment-Direction of movement,Not operated,
IDE08990-MAS05563,Backrest top adjustment-Norming,not normed,
IDE08990-MAS05719,Backrest top adjustment-Maximum travel,0,
IDE08990-MAS12838,Backrest top adjustment-Standardization flag,never normed,
IDE08991-MAS01390,Belt height adjustment-Block 1,0,
IDE08991-MAS01391,Belt height adjustment-Block 2,0,
IDE08991-MAS02282,Belt height adjustment-Position,0,
IDE08991-MAS02955,Belt height adjustment-Engine temperature,0, °C
IDE08991-MAS03129,Belt height adjustment-Reset counter,0,
IDE08991-MAS04160,Belt height adjustment-Load change,0,
IDE08991-MAS04337,Belt height adjustment-Engine current,0, A
IDE08991-MAS05370,Belt height adjustment-Direction of movement,Not operated,
IDE08991-MAS05563,Belt height adjustment-Norming,not normed,
IDE08991-MAS05719,Belt height adjustment-Maximum travel,0,
IDE08991-MAS12838,Belt height adjustment-Standardization flag,never normed,
IDE09081-MAS08291,Seat switch module-Plate: vertical actuation direction,Not operated,
IDE09081-MAS08292,Seat switch module-Plate: horizontal actuation direction,Not operated,
IDE09081-MAS08293,Seat switch module-Paddle,Not operated,
IDE09082,Massage button,Not operated,
IDE09083-MAS08294,Entry assistance button-Entry assistance button: actuation direction forward,Not operated,
IDE09083-MAS08295,Entry assistance button-Entry assistance button: actuation direction backward,Not operated,
IDE09084-MAS08296,Backrest lock switch-Switch state normally closed,operated,
IDE09084-MAS08297,Backrest lock switch-Switch state normally open,Not operated,
IDE09085,Backrest limit switch,Not operated,
IDE10995-IDE06510,Calibrating the motors: status-Adjustment for backrest angle,standardized,
IDE10995-IDE06511,Calibrating the motors: status-Seat height adjustment,standardized,
IDE10995-IDE06512,Calibrating the motors: status-Adjustment for seat forward/back position,standardized,
IDE10995-IDE06683,Calibrating the motors: status-Seat inclination adjustment,standardized,
IDE10995-IDE06684,Calibrating the motors: status-Lumbar support height adjustment,not normed,
IDE10995-IDE06685,Calibrating the motors: status-Lumbar support longitudinal position adjustment,not normed,
IDE10995-IDE08988,Calibrating the motors: status-Head restraint adjustment,not normed,
IDE10995-IDE08989,Calibrating the motors: status-Seat depth adjustment,not normed,
IDE10995-IDE08990,Calibrating the motors: status-Backrest top adjustment,not normed,
IDE10995-IDE08991,Calibrating the motors: status-Belt height adjustment,not normed,
IDE10995-IDE11957,Calibrating the motors: status-Display unit adjustment,not normed,
IDE10995-IDE11969,Calibrating the motors: status-Adjustment of foot rest,not normed,
IDE10995-IDE11986,Calibrating the motors: status-Adjustment 2 of visual display unit,not normed,
IDE10995-MAS11869,Calibrating the motors: status-Headrest adjustment: horizontal,not normed,
IDE10995-MAS11890,Calibrating the motors: status-Headrest adjustment: vertical,not normed,
IDE10996-MAS11891,Excessive force limit: status-Seat forward/back position adjustment: forwards,Adapted,
IDE10996-MAS11892,Excessive force limit: status-Seat forward/back position adjustment: backwards,Adapted,
IDE10996-MAS11895,Excessive force limit: status-Backrest inclination adjustment: forwards,Not adapted,
IDE10996-MAS11896,Excessive force limit: status-Backrest inclination adjustment: backwards,Not adapted,
IDE10996-MAS11959,Excessive force limit: status-Seat height adjustment higher,Not adapted,
IDE10996-MAS11960,Excessive force limit: status-Seat height adjustment lower,Not adapted,
IDE11024-MAS01390,Headrest height adjustment-Block 1,0,
IDE11024-MAS01391,Headrest height adjustment-Block 2,0,
IDE11024-MAS02282,Headrest height adjustment-Position,0,
IDE11024-MAS02955,Headrest height adjustment-Engine temperature,0, °C
IDE11024-MAS03129,Headrest height adjustment-Reset counter,0,
IDE11024-MAS04160,Headrest height adjustment-Load change,0,
IDE11024-MAS04337,Headrest height adjustment-Engine current,0, A
IDE11024-MAS05370,Headrest height adjustment-Direction of movement,Not operated,
IDE11024-MAS05563,Headrest height adjustment-Norming,not normed,
IDE11024-MAS05719,Headrest height adjustment-Maximum travel,0,
IDE11024-MAS12838,Headrest height adjustment-Standardization flag,never normed,
IDE11025-MAS01390,Headrest length adjustment-Block 1,0,
IDE11025-MAS01391,Headrest length adjustment-Block 2,0,
IDE11025-MAS02282,Headrest length adjustment-Position,0,
IDE11025-MAS02955,Headrest length adjustment-Engine temperature,0, °C
IDE11025-MAS03129,Headrest length adjustment-Reset counter,0,
IDE11025-MAS04160,Headrest length adjustment-Load change,0,
IDE11025-MAS04337,Headrest length adjustment-Engine current,0, A
IDE11025-MAS05370,Headrest length adjustment-Direction of movement,Not operated,
IDE11025-MAS05563,Headrest length adjustment-Norming,not normed,
IDE11025-MAS05719,Headrest length adjustment-Maximum travel,0,
IDE11025-MAS12838,Headrest length adjustment-Standardization flag,never normed,
IDE11957-MAS01390,Display unit adjustment-Block 1,0,
IDE11957-MAS01391,Display unit adjustment-Block 2,0,
IDE11957-MAS02282,Display unit adjustment-Position,0,
IDE11957-MAS02955,Display unit adjustment-Engine temperature,0, °C
IDE11957-MAS03129,Display unit adjustment-Reset counter,0,
IDE11957-MAS04160,Display unit adjustment-Load change,0,
IDE11957-MAS04337,Display unit adjustment-Engine current,0, A
IDE11957-MAS05370,Display unit adjustment-Direction of movement,Not operated,
IDE11957-MAS05563,Display unit adjustment-Norming,not normed,
IDE11957-MAS05719,Display unit adjustment-Maximum travel,0,
IDE11957-MAS12838,Display unit adjustment-Standardization flag,never normed,
IDE11969-MAS01390,Adjustment of foot rest-Block 1,0,
IDE11969-MAS01391,Adjustment of foot rest-Block 2,0,
IDE11969-MAS02282,Adjustment of foot rest-Position,0,
IDE11969-MAS02955,Adjustment of foot rest-Engine temperature,0, °C
IDE11969-MAS03129,Adjustment of foot rest-Reset counter,0,
IDE11969-MAS04160,Adjustment of foot rest-Load change,0,
IDE11969-MAS04337,Adjustment of foot rest-Engine current,0, A
IDE11969-MAS05370,Adjustment of foot rest-Direction of movement,Not operated,
IDE11969-MAS05563,Adjustment of foot rest-Norming,not normed,
IDE11969-MAS05719,Adjustment of foot rest-Maximum travel,0,
IDE11969-MAS12838,Adjustment of foot rest-Standardization flag,never normed,
IDE11986-MAS01390,Adjustment 2 of visual display unit-Block 1,0,
IDE11986-MAS01391,Adjustment 2 of visual display unit-Block 2,0,
IDE11986-MAS02282,Adjustment 2 of visual display unit-Position,0,
IDE11986-MAS02955,Adjustment 2 of visual display unit-Engine temperature,0, °C
IDE11986-MAS03129,Adjustment 2 of visual display unit-Reset counter,0,
IDE11986-MAS04160,Adjustment 2 of visual display unit-Load change,0,
IDE11986-MAS04337,Adjustment 2 of visual display unit-Engine current,0, A
IDE11986-MAS05370,Adjustment 2 of visual display unit-Direction of movement,Not operated,
IDE11986-MAS05563,Adjustment 2 of visual display unit-Norming,not normed,
IDE11986-MAS05719,Adjustment 2 of visual display unit-Maximum travel,0,
IDE11986-MAS12838,Adjustment 2 of visual display unit-Standardization flag,never normed,
IDE12083-MAS13890,Switch for lateral backrest support adjustment-Adjustment for lateral support backrest,Not operated,
IDE12083-MAS13891,Switch for lateral backrest support adjustment-Adjustment for lateral support seat cushion,Not operated,
MAS12838-IDE06510,Standardization flag-Adjustment for backrest angle,standardized,
MAS12838-IDE06511,Standardization flag-Seat height adjustment,standardized,
MAS12838-IDE06512,Standardization flag-Adjustment for seat forward/back position,standardized,
MAS12838-IDE06683,Standardization flag-Seat inclination adjustment,standardized,
MAS12838-IDE06684,Standardization flag-Lumbar support height adjustment,never normed,
MAS12838-IDE06685,Standardization flag-Lumbar support longitudinal position adjustment,never normed,
MAS12838-IDE08988,Standardization flag-Head restraint adjustment,never normed,
MAS12838-IDE08989,Standardization flag-Seat depth adjustment,never normed,
MAS12838-IDE08990,Standardization flag-Backrest top adjustment,never normed,
MAS12838-IDE08991,Standardization flag-Belt height adjustment,never normed,
MAS12838-IDE11957,Standardization flag-Display unit adjustment,never normed,
MAS12838-IDE11969,Standardization flag-Adjustment of foot rest,never normed,
MAS12838-IDE11986,Standardization flag-Adjustment 2 of visual display unit,never normed,
MAS12838-MAS11869,Standardization flag-Headrest adjustment: horizontal,never normed,
MAS12838-MAS11890,Standardization flag-Headrest adjustment: vertical,never normed,
ENG139951-IDE06510,Account_1-Adjustment for backrest angle,32723,
ENG139951-IDE06511,Account_1-Seat height adjustment,33210,
ENG139951-IDE06512,Account_1-Adjustment for seat forward/back position,32929,
ENG139951-IDE06683,Account_1-Seat inclination adjustment,32904,
ENG139951-IDE06684,Account_1-Lumbar support height adjustment,0,
ENG139951-IDE06685,Account_1-Lumbar support longitudinal position adjustment,0,
ENG139951-IDE08989,Account_1-Seat depth adjustment,0,
ENG139951-IDE08990,Account_1-Backrest top adjustment,0,
ENG139951-IDE08991,Account_1-Belt height adjustment,0,
ENG139951-IDE11024,Account_1-Headrest height adjustment,0,
ENG139952-IDE06510,Account_2-Adjustment for backrest angle,0,
ENG139952-IDE06511,Account_2-Seat height adjustment,0,
ENG139952-IDE06512,Account_2-Adjustment for seat forward/back position,0,
ENG139952-IDE06683,Account_2-Seat inclination adjustment,0,
ENG139952-IDE06684,Account_2-Lumbar support height adjustment,0,
ENG139952-IDE06685,Account_2-Lumbar support longitudinal position adjustment,0,
ENG139952-IDE08989,Account_2-Seat depth adjustment,0,
ENG139952-IDE08990,Account_2-Backrest top adjustment,0,
ENG139952-IDE08991,Account_2-Belt height adjustment,0,
ENG139952-IDE11024,Account_2-Headrest height adjustment,0,
ENG139953-IDE06510,Account_3-Adjustment for backrest angle,0,
ENG139953-IDE06511,Account_3-Seat height adjustment,0,
ENG139953-IDE06512,Account_3-Adjustment for seat forward/back position,0,
ENG139953-IDE06683,Account_3-Seat inclination adjustment,0,
ENG139953-IDE06684,Account_3-Lumbar support height adjustment,0,
ENG139953-IDE06685,Account_3-Lumbar support longitudinal position adjustment,0,
ENG139953-IDE08989,Account_3-Seat depth adjustment,0,
ENG139953-IDE08990,Account_3-Backrest top adjustment,0,
ENG139953-IDE08991,Account_3-Belt height adjustment,0,
ENG139953-IDE11024,Account_3-Headrest height adjustment,0,
ENG139954-IDE06510,Account_4-Adjustment for backrest angle,0,
ENG139954-IDE06511,Account_4-Seat height adjustment,0,
ENG139954-IDE06512,Account_4-Adjustment for seat forward/back position,0,
ENG139954-IDE06683,Account_4-Seat inclination adjustment,0,
ENG139954-IDE06684,Account_4-Lumbar support height adjustment,0,
ENG139954-IDE06685,Account_4-Lumbar support longitudinal position adjustment,0,
ENG139954-IDE08989,Account_4-Seat depth adjustment,0,
ENG139954-IDE08990,Account_4-Backrest top adjustment,0,
ENG139954-IDE08991,Account_4-Belt height adjustment,0,
ENG139954-IDE11024,Account_4-Headrest height adjustment,0,
ENG139955-IDE06510,Account_5-Adjustment for backrest angle,0,
ENG139955-IDE06511,Account_5-Seat height adjustment,0,
ENG139955-IDE06512,Account_5-Adjustment for seat forward/back position,0,
ENG139955-IDE06683,Account_5-Seat inclination adjustment,0,
ENG139955-IDE06684,Account_5-Lumbar support height adjustment,0,
ENG139955-IDE06685,Account_5-Lumbar support longitudinal position adjustment,0,
ENG139955-IDE08989,Account_5-Seat depth adjustment,0,
ENG139955-IDE08990,Account_5-Backrest top adjustment,0,
ENG139955-IDE08991,Account_5-Belt height adjustment,0,
ENG139955-IDE11024,Account_5-Headrest height adjustment,0,
ENG139956-IDE06510,Account_6-Adjustment for backrest angle,0,
ENG139956-IDE06511,Account_6-Seat height adjustment,0,
ENG139956-IDE06512,Account_6-Adjustment for seat forward/back position,0,
ENG139956-IDE06683,Account_6-Seat inclination adjustment,0,
ENG139956-IDE06684,Account_6-Lumbar support height adjustment,0,
ENG139956-IDE06685,Account_6-Lumbar support longitudinal position adjustment,0,
ENG139956-IDE08989,Account_6-Seat depth adjustment,0,
ENG139956-IDE08990,Account_6-Backrest top adjustment,0,
ENG139956-IDE08991,Account_6-Belt height adjustment,0,
ENG139956-IDE11024,Account_6-Headrest height adjustment,0,
ENG139957-IDE06510,Account_7-Adjustment for backrest angle,0,
ENG139957-IDE06511,Account_7-Seat height adjustment,0,
ENG139957-IDE06512,Account_7-Adjustment for seat forward/back position,0,
ENG139957-IDE06683,Account_7-Seat inclination adjustment,0,
ENG139957-IDE06684,Account_7-Lumbar support height adjustment,0,
ENG139957-IDE06685,Account_7-Lumbar support longitudinal position adjustment,0,
ENG139957-IDE08989,Account_7-Seat depth adjustment,0,
ENG139957-IDE08990,Account_7-Backrest top adjustment,0,
ENG139957-IDE08991,Account_7-Belt height adjustment,0,
ENG139957-IDE11024,Account_7-Headrest height adjustment,0,
ENG139950-IDE06510,BAP_Seat_Adjustment_Button_Status-Adjustment for backrest angle,Not operated,
ENG139950-IDE06511,BAP_Seat_Adjustment_Button_Status-Seat height adjustment,Not operated,
ENG139950-IDE06512,BAP_Seat_Adjustment_Button_Status-Adjustment for seat forward/back position,Not operated,
ENG139950-IDE06683,BAP_Seat_Adjustment_Button_Status-Seat inclination adjustment,Not operated,
ENG139950-IDE06684,BAP_Seat_Adjustment_Button_Status-Lumbar support height adjustment,Not operated,
ENG139950-IDE06685,BAP_Seat_Adjustment_Button_Status-Lumbar support longitudinal position adjustment,Not operated,
ENG139950-IDE08989,BAP_Seat_Adjustment_Button_Status-Seat depth adjustment,Not operated,
ENG139950-IDE08990,BAP_Seat_Adjustment_Button_Status-Backrest top adjustment,Not operated,
ENG139950-IDE08991,BAP_Seat_Adjustment_Button_Status-Belt height adjustment,Not operated,
ENG139950-IDE11024,BAP_Seat_Adjustment_Button_Status-Headrest height adjustment,Not operated,
ENG139950-IDE11025,BAP_Seat_Adjustment_Button_Status-Headrest length adjustment,Not operated,
ENG139950-IDE11957,BAP_Seat_Adjustment_Button_Status-Display unit adjustment,Not operated,
ENG139950-IDE11969,BAP_Seat_Adjustment_Button_Status-Adjustment of foot rest,Not operated,
ENG139950-IDE11986,BAP_Seat_Adjustment_Button_Status-Adjustment 2 of visual display unit,Not operated,
ENG139950-ENG140668,BAP_Seat_Adjustment_Button_Status-backrest_side_bolster,Not operated,
ENG139950-ENG140669,BAP_Seat_Adjustment_Button_Status-footmat,Not operated,
ENG139950-ENG140667,BAP_Seat_Adjustment_Button_Status-side_bolster,Not operated,
ENG136330-ENG136340,Cause of de-normalization-Axis_1,Normierroutine,
ENG136330-ENG136349,Cause of de-normalization-Axis_10,Achse decodiert,
ENG136330-ENG136341,Cause of de-normalization-Axis_2,Normierroutine,
ENG136330-ENG136342,Cause of de-normalization-Axis_3,Normierroutine,
ENG136330-ENG136343,Cause of de-normalization-Axis_4,Normierroutine,
ENG136330-ENG136344,Cause of de-normalization-Axis_5,Achse decodiert,
ENG136330-ENG136345,Cause of de-normalization-Axis_6,Achse decodiert,
ENG136330-ENG136346,Cause of de-normalization-Axis_7,Achse decodiert,
ENG136330-ENG136347,Cause of de-normalization-Axis_8,Achse decodiert,
ENG136330-ENG136348,Cause of de-normalization-Axis_9,Achse decodiert,
ENG136325-ENG101098,crash_precrash-Crash,not active,
ENG136325-ENG131963,crash_precrash-Precrash,not active,
ENG247801-ENG248126,info_developer-ax_da,80 E7 7F 19 81 41 00 07 7F D2 7E CE 84 FD 00 07 81 BB 80 01 81 F6 00 07 80 89 80 02 81 07 00 07 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A 80 00 00 00 FF FF 01 0A,
ENG247801-ENG248078,info_developer-gl_lo,31 4E 33 39 35 39 37 36 30 48 20 00 00 00 00 00 54 30 37 35 00 00 00 00 32 35 33 39 00 00 00 00 53 43 42 55 5A 5A 50 45 4F 50 4C 45 00 00 00 00 0D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG247947,info_developer-gl_pr,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 08 01 00 00 03 00 04 04 02 04 00 00,
ENG247801-ENG248107,info_developer-pne,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG247801-ENG248040,info_developer-so_deb,00 00 00 00 00 00 00 00 69 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG136350-ENG136426,key_memory_activated-mmi_key_memory_activated,active,
ENG157282-ENG161450,Maximum travel-Axis_1_current,552,
ENG157282-ENG161451,Maximum travel-Axis_1_last,0,
ENG157282-ENG161452,Maximum travel-Axis_10_current,65535,
ENG157282-ENG161453,Maximum travel-Axis_10_last,0,
ENG157282-ENG161454,Maximum travel-Axis_2_current,1583,
ENG157282-ENG161455,Maximum travel-Axis_2_last,0,
ENG157282-ENG161456,Maximum travel-Axis_3_current,501,
ENG157282-ENG161457,Maximum travel-Axis_3_last,0,
ENG157282-ENG161458,Maximum travel-Axis_4_current,261,
ENG157282-ENG161459,Maximum travel-Axis_4_last,0,
ENG157282-ENG161460,Maximum travel-Axis_5_current,65535,
ENG157282-ENG161461,Maximum travel-Axis_5_last,0,
ENG157282-ENG161462,Maximum travel-Axis_6_current,65535,
ENG157282-ENG161463,Maximum travel-Axis_6_last,0,
ENG157282-ENG161464,Maximum travel-Axis_7_current,65535,
ENG157282-ENG161465,Maximum travel-Axis_7_last,0,
ENG157282-ENG161466,Maximum travel-Axis_8_current,65535,
ENG157282-ENG161467,Maximum travel-Axis_8_last,0,
ENG157282-ENG161468,Maximum travel-Axis_9_current,65535,
ENG157282-ENG161469,Maximum travel-Axis_9_last,0,
ENG136323-IDE06842,Memory_ID_CAN_1-Status - Button 1,not active,
ENG136323-IDE06843,Memory_ID_CAN_1-Status - Button 2,not active,
ENG136323-IDE06844,Memory_ID_CAN_1-Status - Button 3,not active,
ENG136323-IDE06845,Memory_ID_CAN_1-Status - Button 4,not active,
ENG136323-ENG123088,Memory_ID_CAN_1-FFB_Close_Button,not active,
ENG136323-ENG123087,Memory_ID_CAN_1-FFB_Open_Button,not active,
ENG136323-ENG123089,Memory_ID_CAN_1-FT_lock,not active,
ENG136323-ENG123090,Memory_ID_CAN_1-FT_locked,not active,
ENG136324-MAS03679,Memory_ID_CAN_2-Terminal 15 status,active,
ENG136324-ENG123091,Memory_ID_CAN_2-DoorContact_more_than_10min_opened,not active,
ENG136324-ENG123092,Memory_ID_CAN_2-DoorContact_NotActive_Active,not active,
ENG136324-ENG140350,Memory_ID_CAN_2-FFB_HDF_Button,not active,
ENG136324-ENG136335,Memory_ID_CAN_2-Hardware_onoff,active,
ENG136324-ENG123093,Memory_ID_CAN_2-Memory_Adjustment,not active,
ENG136324-ENG123094,Memory_ID_CAN_2-MemoryButton_Pressed,not active,
ENG136324-ENG248058,Memory_ID_CAN_2-v_signal_less_v_threshold,active,
ENG158048-MAS03760,missing_pre_conditions-Wind deflector position,not active,
ENG158048-ENG161471,missing_pre_conditions-backrest_locked,active,
ENG158048-ENG161472,missing_pre_conditions-backrest_unlocked,active,
ENG158048-ENG161506,missing_pre_conditions-button_pressed,not active,
ENG158048-ENG161716,missing_pre_conditions-coded_axes_not_normalized,not active,
ENG158048-ENG163288,missing_pre_conditions-other_adjustment_already_active,not active,
ENG158048-ENG98864,missing_pre_conditions-Reserved,0,
ENG158048-ENG310748,missing_pre_conditions-reserviert_01,0,
ENG158048-ENG163523,missing_pre_conditions-reset_problem,not active,
ENG158048-ENG163733,missing_pre_conditions-speed_above_5kmh,not active,
ENG158048-ENG159469,missing_pre_conditions-Voltage_supply,not active,
ENG158102-ENG161674,personalization_last_function-cause_of_termination,0,
ENG158102,personalization_last_function,none,
ENG158102-ENG99298,personalization_last_function-State,none,
ENG136328-ENG136337,pwm_generator-pwm_generator_group_1_overload,not active,
ENG136328-ENG136338,pwm_generator-pwm_generator_group_2_overload,not active,
ENG136326-ENG99389,Resets-Resetcounter,18,
ENG136329-ENG136339,sbc-sbc_overload,not active,
ENG136351-ENG136438,Seat_Actual_Positions-Current_Position_fsv,32768,
ENG136351-ENG136434,Seat_Actual_Positions-Current_Position_ghv,32768,
ENG136351-ENG136441,Seat_Actual_Positions-Current_Position_kks,32768,
ENG136351-ENG136437,Seat_Actual_Positions-Current_Position_ksv_x,32768,
ENG136351-ENG136431,Seat_Actual_Positions-Current_Position_ksv_z,32768,
ENG136351-ENG136436,Seat_Actual_Positions-Current_Position_ldh,32768,
ENG136351-ENG136435,Seat_Actual_Positions-Current_Position_ldw,32768,
ENG136351-ENG136433,Seat_Actual_Positions-Current_Position_lkv,32768,
ENG136351-ENG136428,Seat_Actual_Positions-Current_Position_lnv,32722,
ENG136351-ENG136439,Seat_Actual_Positions-Current_Position_rse1,32768,
ENG136351-ENG136440,Seat_Actual_Positions-Current_Position_rse2,32768,
ENG136351-ENG136429,Seat_Actual_Positions-Current_Position_shv,33211,
ENG136351-ENG136427,Seat_Actual_Positions-Current_Position_slv,32999,
ENG136351-ENG136430,Seat_Actual_Positions-Current_Position_snv,32905,
ENG136351-ENG136432,Seat_Actual_Positions-Current_Position_stv,32768,
ENG123054-ENG136421,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_1,not active,
ENG123054-ENG136422,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_2,not active,
ENG123054-ENG136423,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_3,not active,
ENG123054-ENG136424,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_4,not active,
ENG123054-ENG136425,Seat_Adjustment_Memory_Info_CAN-Mem_Taster_SET,not active,
ENG123054-ENG123084,Seat_Adjustment_Memory_Info_CAN-MMB_glob_Stop,not active,
ENG123054-ENG123077,Seat_Adjustment_Memory_Info_CAN-MMB_storage_0,not active,
ENG123054-ENG123078,Seat_Adjustment_Memory_Info_CAN-MMB_storage_1,not active,
ENG123054-ENG123079,Seat_Adjustment_Memory_Info_CAN-MMB_storage_2,not active,
ENG123054-ENG123080,Seat_Adjustment_Memory_Info_CAN-MMB_storage_3,not active,
ENG123054-ENG123083,Seat_Adjustment_Memory_Info_CAN-MMB_store,not active,
ENG123054-ENG123082,Seat_Adjustment_Memory_Info_CAN-MMB_tast,not active,
ENG123054-ENG123081,Seat_Adjustment_Memory_Info_CAN-MMB_tipp,not active,
ENG123055-ENG123086,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Active_Remote_Control_Key,Key 1,
ENG123055-ENG123085,Seat_Adjustment_Remote_Control_Locking_Info_CAN-Remote_Control_Key_Signal,No_signal,
ENG123053-ENG136417,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Head_Movement,not active,
ENG123053-ENG136412,Seat_Adjustment_State_Info_CAN-FSM_Backrest_Inclination_Movement,not active,
ENG123053-ENG136418,Seat_Adjustment_State_Info_CAN-FSM_Belt_Height_Movement,not active,
ENG123053-ENG136415,Seat_Adjustment_State_Info_CAN-FSM_Headrest_Movement,not active,
ENG123053-ENG123076,Seat_Adjustment_State_Info_CAN-FSM_KD_Error,not active,
ENG123053-ENG136420,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Height_Movement,not active,
ENG123053-ENG136419,Seat_Adjustment_State_Info_CAN-FSM_Lumbar_Longitudial_Movement,not active,
ENG123053-ENG136416,Seat_Adjustment_State_Info_CAN-FSM_Seat_Depth_Movement,not active,
ENG123053-ENG136413,Seat_Adjustment_State_Info_CAN-FSM_Seat_Height_Movement,not active,
ENG123053-ENG136414,Seat_Adjustment_State_Info_CAN-FSM_Seat_Inclination_Movement,not active,
ENG123053-ENG136411,Seat_Adjustment_State_Info_CAN-FSM_Seat_Longitudial_Movement,not active,
ENG123053-ENG123075,Seat_Adjustment_State_Info_CAN-FSM_SeatMovement,not active,
ENG158188-IDE06510,Seat_Position_Memory_Remote_Control_5-Adjustment for backrest angle,0,
ENG158188-IDE06511,Seat_Position_Memory_Remote_Control_5-Seat height adjustment,0,
ENG158188-IDE06512,Seat_Position_Memory_Remote_Control_5-Adjustment for seat forward/back position,0,
ENG158188-IDE06683,Seat_Position_Memory_Remote_Control_5-Seat inclination adjustment,0,
ENG158188-IDE06684,Seat_Position_Memory_Remote_Control_5-Lumbar support height adjustment,0,
ENG158188-IDE06685,Seat_Position_Memory_Remote_Control_5-Lumbar support longitudinal position adjustment,0,
ENG158188-IDE08989,Seat_Position_Memory_Remote_Control_5-Seat depth adjustment,0,
ENG158188-IDE08990,Seat_Position_Memory_Remote_Control_5-Backrest top adjustment,0,
ENG158188-IDE08991,Seat_Position_Memory_Remote_Control_5-Belt height adjustment,0,
ENG158188-IDE11024,Seat_Position_Memory_Remote_Control_5-Headrest height adjustment,0,
ENG158189-IDE06510,Seat_Position_Memory_Remote_Control_6-Adjustment for backrest angle,0,
ENG158189-IDE06511,Seat_Position_Memory_Remote_Control_6-Seat height adjustment,0,
ENG158189-IDE06512,Seat_Position_Memory_Remote_Control_6-Adjustment for seat forward/back position,0,
ENG158189-IDE06683,Seat_Position_Memory_Remote_Control_6-Seat inclination adjustment,0,
ENG158189-IDE06684,Seat_Position_Memory_Remote_Control_6-Lumbar support height adjustment,0,
ENG158189-IDE06685,Seat_Position_Memory_Remote_Control_6-Lumbar support longitudinal position adjustment,0,
ENG158189-IDE08989,Seat_Position_Memory_Remote_Control_6-Seat depth adjustment,0,
ENG158189-IDE08990,Seat_Position_Memory_Remote_Control_6-Backrest top adjustment,0,
ENG158189-IDE08991,Seat_Position_Memory_Remote_Control_6-Belt height adjustment,0,
ENG158189-IDE11024,Seat_Position_Memory_Remote_Control_6-Headrest height adjustment,0,
ENG158190-IDE06510,Seat_Position_Memory_Remote_Control_7-Adjustment for backrest angle,0,
ENG158190-IDE06511,Seat_Position_Memory_Remote_Control_7-Seat height adjustment,0,
ENG158190-IDE06512,Seat_Position_Memory_Remote_Control_7-Adjustment for seat forward/back position,0,
ENG158190-IDE06683,Seat_Position_Memory_Remote_Control_7-Seat inclination adjustment,0,
ENG158190-IDE06684,Seat_Position_Memory_Remote_Control_7-Lumbar support height adjustment,0,
ENG158190-IDE06685,Seat_Position_Memory_Remote_Control_7-Lumbar support longitudinal position adjustment,0,
ENG158190-IDE08989,Seat_Position_Memory_Remote_Control_7-Seat depth adjustment,0,
ENG158190-IDE08990,Seat_Position_Memory_Remote_Control_7-Backrest top adjustment,0,
ENG158190-IDE08991,Seat_Position_Memory_Remote_Control_7-Belt height adjustment,0,
ENG158190-IDE11024,Seat_Position_Memory_Remote_Control_7-Headrest height adjustment,0,
ENG136327-ENG116986,Source_Last_Reset-Low_Voltage,active,
ENG136327-ENG123073,Source_Last_Reset-Low_Voltage_At_Run_Up,not active,
ENG136327-ENG123072,Source_Last_Reset-Power_On_Reset,not active,
ENG136327-ENG123071,Source_Last_Reset-Software_Reset_by_diagnosis,not active,
ENG136327-ENG110107,Source_Last_Reset-Watchdog_reset,not active,
ENG136327-ENG123074,Source_Last_Reset-Watchdog_Reset_At_Run_Up,not active,
Elapsed Time: 00:22
Jef
HQ
blockmap-3C-2Q0-907-686-H_WVGAWVEB7SH010695-20241230-1134.CSV
;SW:2Q0-907-686-H   HW:2Q0-907-686-H ---  Lane Change
;Component:HRE_Master    H26 0320, Coding:5A954750
;EV_HREHellaGen3MstrUNECE,001001,EV_HREHellaGen3MstrUNECE_VW27.rod
;Monday,30,December,2024,11:34:31:18177
;VCID: 3FDC990747F9CCE24A8-806A-R
IDE00018,Voltage terminal 15,14.40, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,32.0, °C
IDE00925,Yaw rate,0.01, °/s
IDE01441,Back-up lamp,OFF,
IDE01766-MAS01853,Distance impulses-Left front,0,
IDE01766-MAS01854,Distance impulses-Right front,0,
IDE01766-MAS01855,Distance impulses-Left rear,0,
IDE01766-MAS01856,Distance impulses-Right rear,0,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,DF 19 4E 5E,
IDE02049,Trailer detected,not detected,
IDE02057-MAS10062,Dynamic calibration: status-Auto. calibration: distance travelled,174.00, km
IDE02057-MAS10063,Dynamic calibration: status-Auto. calibration: percent. progress Master,100, %
IDE02057-MAS10064,Dynamic calibration: status-Auto. calibration: percent. progress Slave,100, %
IDE02057,Dynamic calibration: status,OFF,
IDE02219-MAS02471,Steering wheel angle: sign-Sign,Negative,
IDE02219,Steering wheel angle: sign,0.00, °
IDE02486,Data logger triggering,not initialized,
IDE03619,System condition,On,
IDE05064,lane change assist. 2: supply voltage,14.40, V
IDE05065,lane change assist. 2: temperature,32.0, °C
IDE05067-MAS03385,Functional status of lane change assist.-Lane change assistance,passive,
IDE05067-MAS08213,Functional status of lane change assist.-Blind spot detection,OFF,
IDE05067-MAS10332,Functional status of lane change assist.-Rear Cross Traffic Alert,passive,
IDE05067-MAS15693,Functional status of lane change assist.-Exit warning,active,
IDE05070,Curve radius,-14146.0, m
IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,128,
IDE05077-MAS02475,Rain/light recognition sensor via data bus-Brightness infrared,Unknown (128),
IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,1021,
IDE05077-MAS02477,Rain/light recognition sensor via data bus-Front brightness,numerical value: no text,
IDE05077,Rain/light recognition sensor via data bus,installed,
IDE05078-MAS04108,Distance of object 1-Distance in X-direction,25.25, m
IDE05078-MAS04109,Distance of object 1-Distance in Y-direction,15.88, m
IDE05079-MAS02465,Relative speed of object 1-Speed in y-direction,8.03, m/s
IDE05079-MAS02469,Relative speed of object 1-Speed in x-direction,90.25, m/s
IDE05080-MAS04108,Distance of object 2-Distance in X-direction,25.25, m
IDE05080-MAS04109,Distance of object 2-Distance in Y-direction,15.88, m
IDE05081-MAS02465,Relative speed of object 2-Speed in y-direction,8.03, m/s
IDE05081-MAS02469,Relative speed of object 2-Speed in x-direction,90.25, m/s
IDE05082-MAS04108,Distance of object 3-Distance in X-direction,25.25, m
IDE05082-MAS04109,Distance of object 3-Distance in Y-direction,15.88, m
IDE05083-MAS02465,Relative speed of object 3-Speed in y-direction,8.03, m/s
IDE05083-MAS02469,Relative speed of object 3-Speed in x-direction,90.25, m/s
IDE05084,Closest object left lane,0,
IDE05084,Closest object left lane,No object recognized,
IDE05085,Closest object right lane,No object recognized,
IDE05085,Closest object right lane,0,
IDE05086,Closest object lane used,No object recognized,
IDE05086,Closest object lane used,0,
IDE05087,Dynamic angle offset lane change assist. 1,-1.20, °
IDE05088,Dynamic angle offset lane change assist. 2,1.00, °
IDE05090,Measured receiving power lane change assist. 1,0, %
IDE05091,Measured receiving power lane change assist. 2,0, %
IDE05092,Measured angle lane change assist. 1,-20.48, °
IDE05093,Measured angle lane change assist. 2,-20.48, °
IDE05094,Static angle offset lane change assist. 1,10.24, °
IDE05095,Static angle offset lane change assist. 2,10.24, °
IDE06199-MAS01167,Indicator light for lane change assist. in instrument cluster-Actuation time,no control,
IDE06199-ENG170421,Indicator light for lane change assist. in instrument cluster-IoReached Status,Output diagnostic test not active,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS09610,Component protection properties-Status GFA Key,invalid,
IDE07145-MAS09611,Component protection properties-Status Master ECU Key,not stored,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,Up to download version 01,
IDE10102,Right warning light flashing cycle,OFF,
IDE10103,Left warning light flashing cycle,OFF,
IDE10104,Left warning light status,OFF,
IDE10106,Right warning light status,OFF,
IDE10107,Dimming value of left warning light: warning algorithm,0, %
IDE10108,Status of left warning light: warning algorithm,---,
IDE10109,Dimming value of right warning light: warning algorithm,0, %
IDE10110,Status of right warning light: warning algorithm,---,
IDE10229-IDE10101,Warning light for blind spot assistant in left exterior mirror-Dimming value of left warning light,0, %
IDE10229-MAS01167,Warning light for blind spot assistant in left exterior mirror-Actuation time,no control,
IDE10229-ENG170421,Warning light for blind spot assistant in left exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10230-IDE10105,Warning light for blind spot assistant in right exterior mirror-Dimming value of right warning light,0, %
IDE10230-MAS01167,Warning light for blind spot assistant in right exterior mirror-Actuation time,no control,
IDE10230-ENG170421,Warning light for blind spot assistant in right exterior mirror-IoReached Status,Output diagnostic test not active,
IDE10235-IDE10233,Status night design-Night design,not activated,
IDE10235-IDE10234,Status night design-Day design,activated,
IDE10235,Status night design,OFF,
IDE10236-MAS10041,Lane keeping warning system-Distance to lane,0.11, m
IDE10236-MAS10042,Lane keeping warning system-Time to lane crossing,3.0, s
IDE10236-MAS10043,Lane keeping warning system-Vehicle side,Left,
IDE11133-MAS01167,Output of parking assistant warning-Actuation time,no control,
IDE11133-ENG170421,Output of parking assistant warning-IoReached Status,Output diagnostic test not active,
IDE13096,Rear cross traffic assistant: left warning level,cannot be assessed,
IDE13107,Rear cross traffic assistant: right warning level,cannot be assessed,
IDE13626-MAS01167,Output of exit assistant warning-Actuation time,no control,
IDE13626-ENG170421,Output of exit assistant warning-IoReached Status,Output diagnostic test not active,
IDE13845,Production mode status,not active,
IDE80001,Analysis 1,No display,
IDE80002,Analysis 2,keine_Anzeige,
IDE80003,Analysis 3,No display,
IDE80004,Analysis 4,keine_Anzeige,
MAS00370,Vehicle speed,0.00, km/h
MAS05108-MAS10050,ESP-Delay regulation,Feedback: delay regulation not available,
MAS05108-MAS10059,ESP-Blind spot warning: message,consistent,
MAS05108-MAS10669,ESP-Delay regulation: brake jolt,Not available,
MAS08785-IDE02679,Parking aid-Tone sensor,available.,
MAS08785-IDE03619,Parking aid-System condition,active,
MAS10065-MAS04108,Distance of object 4-Distance in X-direction,25.25, m
MAS10065-MAS04109,Distance of object 4-Distance in Y-direction,15.88, m
MAS10066-MAS04108,Distance of object 5-Distance in X-direction,25.25, m
MAS10066-MAS04109,Distance of object 5-Distance in Y-direction,15.88, m
MAS10067-MAS02465,Relative speed of object 4-Speed in y-direction,8.03, m/s
MAS10067-MAS02469,Relative speed of object 4-Speed in x-direction,90.25, m/s
MAS10068-MAS02465,Relative speed of object 5-Speed in y-direction,8.03, m/s
MAS10068-MAS02469,Relative speed of object 5-Speed in x-direction,90.25, m/s
MAS18838,Auto-calibration: adaptive angle correction characteristic curve (slave),0, %
MAS18839,Auto-calibration: adaptive angle correction characteristic curve,0, %
MAS18840-MAS04108,Distance of object 6-Distance in X-direction,25.25, m
MAS18840-MAS04109,Distance of object 6-Distance in Y-direction,15.88, m
MAS18841-MAS02465,Relative speed of object 6-Speed in y-direction,8.03, m/s
MAS18841-MAS02469,Relative speed of object 6-Speed in x-direction,90.25, m/s
ENG347801-MAS13892,CAN_Autodetect_Platform_Version-Platform,Unknown,
ENG347982,OffsetCorrectionState_S0,100,
ENG347983,OffsetCorrectionState_S1,100,
Elapsed Time: 00:09
blockmap-42-1EA-959-593-F_WVGAWVEB7SH010695-20241230-1134.CSV
;SW:1EA-959-593-F   HW:1EA-959-593-F ---  Door Elect, Driver
;Component:TSG FS        009 0563, Coding:0035DB20D200028044000020
;EV_DCU3DriveSideMAXHCONT,001004,EV_DCU3DriveSideMAXHCONT_VWE3.rod
;Monday,30,December,2024,11:34:49:18177
;VCDS Version: Beta 24.12.0 (x64)  Data version: 20241120 DS361.3
;VCID: 45D08BEF25259632004-8010-R
Group,Description,Actual
IDE02262,synchronous mirror adjustment,active,
IDE02267-IDE05835,Supply voltage for door control module: front: driver side-Supply voltage for central locking,14.90, V
IDE04215-MAS02428,Mirror adjustment switch-Switch positions,Neutral,
IDE04216-MAS01458,Mirror heater-Operating condition,not active,
IDE04216-MAS02965,Mirror heater-Performance percentage,0, %
IDE04216-MAS04247,Mirror heater-Button,Not operated,
IDE04217,Fuel filler door release button,not installed,
IDE04218,Turn signal in exterior rear-view mirror,not active,
IDE04219-IDE02266,Window regulator control unit: driver side-Passenger side rear power window button,Not operated,
IDE04219-IDE04220,Window regulator control unit: driver side-Driver power window button,Not operated,
IDE04219-IDE06621,Window regulator control unit: driver side-Driver side rear power window button,Not operated,
IDE04219-IDE06872,Window regulator control unit: driver side-Front passenger power window button,Not operated,
IDE04220,Driver power window button,Not operated,
IDE04411,Child safety button,not installed,
IDE04539-MAS01634,Mirror memory-Supply voltage,active,
IDE04539-MAS02228,Mirror memory-X coordinate,34, %
IDE04539-MAS02229,Mirror memory-Y coordinate,54, %
IDE04539-MAS02476,Mirror memory-installed,installed,
IDE04540,Mirror adjustment (X/Y direction),Position center,
IDE04580,Dimming of inside door handle lighting,Not available,
IDE04581,Dimming for interior ambient lighting,0, %
IDE04586,Mirror fold-in activation,not active,
IDE05071-MAS02594,Lane change assistance button-Indicator light in switch,not installed,
IDE05071-MAS07693,Lane change assistance button-Button Status,not installed,
IDE05720-IDE02589,Front driver side door status-Rotary latch status,closed,
IDE05720-IDE04213,Front driver side door status-Central locking button,Not operated,
IDE05725,Dimmer terminal 58xs,0, %
IDE05726,Dimmer terminal 58xd,100, %
IDE05825-MAS02594,DWA Interior monitoring/vehicle inclination sensor button-Indicator light in switch,not coded/not installed,
IDE05825-MAS04247,DWA Interior monitoring/vehicle inclination sensor button-Button,not coded/not installed,
IDE06206-MAS01453,Front window regulator status: driver side-Blocking detection,active,
IDE06206-MAS02097,Front window regulator status: driver side-Window position,0.00, %
IDE06206-MAS02098,Front window regulator status: driver side-Window regulator standardized,Yes,
IDE06206-MAS04642,Front window regulator status: driver side-Before upper stop,active,
IDE06206-MAS05370,Front window regulator status: driver side-Direction of movement,Position top,
IDE06469,Ambient illumination for speaker,Not available,
IDE06614-IDE06842,Memory seat adjustment control head-Status - Button 1,not installed,
IDE06614-IDE06843,Memory seat adjustment control head-Status - Button 2,not installed,
IDE06614-IDE06844,Memory seat adjustment control head-Status - Button 3,not installed,
IDE06614-IDE06845,Memory seat adjustment control head-Status - Button 4,not installed,
IDE06937-MAS02545,Front window regulator reversing position: driver side-Last,127.50, %
IDE06937-MAS02546,Front window regulator reversing position: driver side-Second to last,127.50, %
IDE06937-MAS02547,Front window regulator reversing position: driver side-Third to last,127.50, %
IDE06937-MAS02548,Front window regulator reversing position: driver side-Fourth to last,127.50, %
IDE06937-MAS05380,Front window regulator reversing position: driver side-fifth to last,127.50, %
IDE07405-MAS02447,Enable driver front window regulator relay-Release,Yes,
IDE07409-MAS02955,Excessive temper. disconnect: front window regulator: driv.side-Engine temperature,22, °C
IDE07543,Vehicle speed,0.00, km/h
IDE08061,Child safety lock button 2,Not operated,
IDE08697-MAS07302,Number of driving cycles without opening door-Max. number of driving cycles without opening door,0,
IDE09335,Mirror fold-in: current consumption,0.00, A
IDE09798,Play protection: mirror fold-in,not active,
IDE10158,Window lift: switch-over from front to rear,not installed,
IDE10164-MAS01632,Automatically dimming exterior mirrors-Status,not installed,
IDE10164-MAS03691,Automatically dimming exterior mirrors-Dimming,255, %
IDE13865-MAS02099,Exterior door handle actuator-Switch for inside door handle,not installed,
IDE13865-MAS02100,Exterior door handle actuator-Switch for outside door handle,not installed,
IDE13865-MAS09598,Exterior door handle actuator-Request on CAN,Not available,
IDE13865-MAS11741,Exterior door handle actuator-CAN Status,Initialization,
IDE13865-MAS17088,Exterior door handle actuator-Contact: exterior door handle retracted,not installed,
IDE13865-MAS17089,Exterior door handle actuator-Contact: exterior door handle extended,not installed,
IDE13865-MAS17090,Exterior door handle actuator-Actuator activation status,not installed,
IDE15336,Light output 1 pin D8 target brightness on front driver side,Not available,
IDE15338,Light output 3 pin C1/B3 target brightness on front driver side,0, %
IDE15339,Light output 4 pin D16 target brightness on front driver side,0, %
IDE15636,Light output 2 pin D3 target brightness on front driver side,Not available,
MAS01872,Rear lid remote control lock switch,Not operated,
MAS02099,Switch for inside door handle,Not operated,
MAS02100,Switch for outside door handle,Not operated,
MAS02101,Child safety lock,active,
MAS06010,Ambient light,Not available,
Elapsed Time: 00:08
blockmap-44-1N3-907-144-Q_WVGAWVEB7SH010695-20241230-1135.CSV
;SW:1N3-907-144-Q   HW:1N3-907-144-L ---  Steering Assist
;Component:BASGEN1MQB37  131 7341, Coding:00000000000002010000020101000100000001000101
;EV_SteerAssisBASGEN1MQB37,017078,EV_SteerAssisBASGEN1MQB37_017_VW27.rod
;Monday,30,December,2024,11:35:06:18177
;VCID: 3C26EE0B56EFD7FA6FA-8068-R SFD
IDE00019,Voltage terminal 30,14.95, V
IDE00021,Engine RPM,65535, /min
IDE00323-IDE01022,Security Access: Number of invalid keys-Counter: incorrect inputs of key-code,45,
IDE00323-MAS01155,Security Access: Number of invalid keys-Control module,Unknown (45),
IDE00323-MAS02913,Security Access: Number of invalid keys-Remaining running time,11565,
IDE02202,End stage temperature,14, °C
IDE02955,System status,Driving mode,
IDE03214,Engine stop using start-stop function,Unknown (255),
IDE03682-IDE04457,motor position sensor-Electric motor speed,-18000.0, /min
IDE03682-MAS02961,motor position sensor-Engine angle,2, °
IDE03726-IDE02955,Parallel Parking Assistance-System status,not active,
IDE03726-IDE05159,Parallel Parking Assistance-Steering angle: target value,1.93715e-005, °
IDE03726-IDE05160,Parallel Parking Assistance-Steering angle: target-actual deviation,5273.6, °
IDE03726-MAS03095,Parallel Parking Assistance-Function status,not active,
IDE03735,Steering torque,0.0, Nm
IDE04118-IDE05157,Straight line running correction-Long term learning condition,Condition not met,
IDE04118-IDE05158,Straight line running correction-Short term learning condition,Condition not met,
IDE04118-MAS02998,Straight line running correction-Angle value offset,1.1, °
IDE04118-MAS03095,Straight line running correction-Function status,active,
IDE04118-MAS03528,Straight line running correction-Long term adaptation value,1.1, °
IDE04118-MAS03529,Straight line running correction-Short term adaptation value,0.0, °
IDE04119-MAS03095,Active default-Function status,active,
IDE04119-MAS03738,Active default-Restoring force: setpoint,0, N
IDE04183,Steering assistance: target engine torque,0.0, Nm
IDE04184,Steering assistance: engine output,100, %
IDE04448,Steering angle sensor: angle,-3.39999, °
IDE04454,Steering angle sensor: angle speed,-2, °/s
IDE04458,Steering angle sensor: mechanical steering stroke,180.2, mm
IDE04459,Steering angle sensor: offset index mark mechanical middle,235, mm
IDE04460,Steering angle sensor: offset straight line running,-4.3, °
IDE04510-MAS03732,Steering angle sensor: slope detection index-Steering angle speed negative dropping slope on curve,not detected,
IDE04510-MAS03733,Steering angle sensor: slope detection index-Steering angle speed negative rising slope on curve,not detected,
IDE04510-MAS03734,Steering angle sensor: slope detection index-Steering angle speed positive dropping slope on curve,not detected,
IDE04510-MAS03735,Steering angle sensor: slope detection index-Steering angle speed positive rising slope on curve,not detected,
IDE04510-MAS03736,Steering angle sensor: slope detection index-Index mark,not detected,
IDE04765-IDE02955,Counter steer support-System status,Function is not active,
IDE04765-MAS02974,Counter steer support-Target force,0, N
IDE04765-MAS03739,Counter steer support-Steering torque request: brake electronics,6533.5, Nm
IDE04765-MAS14021,Counter steer support-Steering recommendation: correcting torque offset,0.0, Nm
IDE04805-IDE02955,Driving profile selection-System status,01,
IDE04805-IDE06011,Driving profile selection-Selected driving profile,02,
IDE04805-IDE06419,Driving profile selection-Driving profile switchover,will be performed.,
IDE04805-MAS01447,Driving profile selection-Act.val.,automatic,
IDE04805-MAS01448,Driving profile selection-Target value,automatic,
IDE04805-MAS03095,Driving profile selection-Function status,01,
IDE04805-MAS05058,Driving profile selection-Compatibility,01,
IDE05155,Power steering current consumption,0.0, A
IDE05162-IDE03723,Software end stop-End stops for steering,Adapted,
IDE05162-MAS03095,Software end stop-Function status,active,
IDE05162-MAS11513,Software end stop-End stop left,89.93, mm
IDE05162-MAS11514,Software end stop-End stop right,-90.29, mm
IDE05162-MAS12179,Software end stop-Validation of end stops: left and right,Condition met,
IDE05162-MAS12180,Software end stop-Validation of end stops: steering stroke,Condition met,
IDE05162-MAS12181,Software end stop-Validation of end stops: center,Condition not met,
IDE05713-IDE01864,Network diagnosis-Status of current bus communication,active,
IDE05713-MAS04460,Network diagnosis-Validity,No,
IDE05713-MAS06528,Network diagnosis-Release status,No,
IDE05993-ENG120753,Steering wheel angle load-0_to_50_degrees,4294967295,
IDE05993-ENG120755,Steering wheel angle load-100_to_150_degrees,4294967295,
IDE05993-ENG120751,Steering wheel angle load--100_to_-50_degrees,4294967295,
IDE05993-ENG120750,Steering wheel angle load--150_to_-100_degrees,4294967295,
IDE05993-ENG120756,Steering wheel angle load-150_to_200_degrees,4294967295,
IDE05993-ENG120749,Steering wheel angle load--200_to_-150_degrees,4294967295,
IDE05993-ENG120757,Steering wheel angle load-200_to_250_degrees,4294967295,
IDE05993-ENG120748,Steering wheel angle load--250_to_-200_degrees,4294967295,
IDE05993-ENG120758,Steering wheel angle load-250_to_300_degrees,4294967295,
IDE05993-ENG120747,Steering wheel angle load--300_to_-250_degrees,4294967295,
IDE05993-ENG120759,Steering wheel angle load-300_to_350_degrees,4294967295,
IDE05993-ENG120746,Steering wheel angle load--350_to_-300_degrees,4294967295,
IDE05993-ENG120760,Steering wheel angle load-350_to_400_degrees,4294967295,
IDE05993-ENG120745,Steering wheel angle load--400_to_-350_degrees,4294967295,
IDE05993-ENG120761,Steering wheel angle load-400_to_450_degrees,4294967295,
IDE05993-ENG120744,Steering wheel angle load--450_to_-400_degrees,4294967295,
IDE05993-ENG120762,Steering wheel angle load-450_to_500_degrees,4294967295,
IDE05993-ENG120752,Steering wheel angle load--50_to_0_degrees,4294967295,
IDE05993-ENG120754,Steering wheel angle load-50_to_100_degrees,4294967295,
IDE05993-ENG120743,Steering wheel angle load--500_to_-450_degrees,4294967295,
IDE05993-ENG120763,Steering wheel angle load-500_to_550_degrees,4294967295,
IDE05993-ENG120742,Steering wheel angle load--550_to_500_degrees,4294967295,
IDE05993-ENG120764,Steering wheel angle load-above_550_degrees,4294967295,
IDE05993-ENG120741,Steering wheel angle load-below_-550_degrees,4294967295,
IDE05994-ENG120729,Engine specified torque load-0_to_1_kilo_newton,4294967295,
IDE05994-ENG120728,Engine specified torque load--1_to_0_kilo_newton,4294967295,
IDE05994-ENG120730,Engine specified torque load-1_to_2_kilo_newton,4294967295,
IDE05994-ENG139218,Engine specified torque load-10_to_11_kilo_newton,4294967295,
IDE05994-ENG120719,Engine specified torque load--10_to_-9_kilo_newton,4294967295,
IDE05994-ENG139219,Engine specified torque load--11_to_-10_kilo_newton,4294967295,
IDE05994-ENG120727,Engine specified torque load--2_to_-1_kilo_newton,4294967295,
IDE05994-ENG120731,Engine specified torque load-2_to_3_kilo_newton,4294967295,
IDE05994-ENG120726,Engine specified torque load--3_to_-2_kilo_newton,4294967295,
IDE05994-ENG120732,Engine specified torque load-3_to_4_kilo_newton,4294967295,
IDE05994-ENG120725,Engine specified torque load--4_to_-3_kilo_newton,4294967295,
IDE05994-ENG120733,Engine specified torque load-4_to_5_kilo_newton,4294967295,
IDE05994-ENG120724,Engine specified torque load--5_to_-4_kilo_newton,4294967295,
IDE05994-ENG120734,Engine specified torque load-5_to_6_kilo_newton,4294967295,
IDE05994-ENG120723,Engine specified torque load--6_to_-5_kilo_newton,4294967295,
IDE05994-ENG120735,Engine specified torque load-6_to_7_kilo_newton,4294967295,
IDE05994-ENG120722,Engine specified torque load--7_to_-6_kilo_newton,4294967295,
IDE05994-ENG120736,Engine specified torque load-7_to_8_kilo_newton,4294967295,
IDE05994-ENG120721,Engine specified torque load--8_to_-7_kilo_newton,4294967295,
IDE05994-ENG120737,Engine specified torque load-8_to_9_kilo_newton,4294967295,
IDE05994-ENG120738,Engine specified torque load-9_to_10_kilo_newton,4294967295,
IDE05994-ENG120720,Engine specified torque load--9_to_-8_kilo_newton,4294967295,
IDE05994-ENG161314,Engine specified torque load-above_11_kilo_newton,4294967295,
IDE05994-ENG161479,Engine specified torque load-below_-11_kilo_newton,4294967295,
IDE05995-ENG120703,ECU temperature load-0_to_10_degrees_celsius,4294967295,
IDE05995-ENG120702,ECU temperature load--10_to_0_degrees_celsius,4294967295,
IDE05995-ENG120704,ECU temperature load-10_to_20_degrees_celsius,4294967295,
IDE05995-ENG120713,ECU temperature load-100_to_110_degrees_celsius,4294967295,
IDE05995-ENG120714,ECU temperature load-110_to_120_degrees_celsius,4294967295,
IDE05995-ENG120701,ECU temperature load--20_to_-10_degrees_celsius,4294967295,
IDE05995-ENG120705,ECU temperature load-20_to_30_degrees_celsius,4294967295,
IDE05995-ENG120700,ECU temperature load--30_to_-20_degrees_celsius,4294967295,
IDE05995-ENG120706,ECU temperature load-30_to_40_degrees_celsius,4294967295,
IDE05995-ENG120699,ECU temperature load--40_to_-30_degrees_celsius,4294967295,
IDE05995-ENG120707,ECU temperature load-40_to_50_degrees_celsius,4294967295,
IDE05995-ENG120708,ECU temperature load-50_to_60_degrees_celsius,4294967295,
IDE05995-ENG120709,ECU temperature load-60_to_70_degrees_celsius,4294967295,
IDE05995-ENG120710,ECU temperature load-70_to_80_degrees_celsius,4294967295,
IDE05995-ENG120711,ECU temperature load-80_to_90_degrees_celsius,4294967295,
IDE05995-ENG120712,ECU temperature load-90_to_100_degrees_celsius,4294967295,
IDE05995-ENG120715,ECU temperature load-above_120_degrees_celsius,4294967295,
IDE05995-ENG120698,ECU temperature load-below_-40_degrees_celsius,4294967295,
IDE05996-ENG120766,Steering wheel angle speed load-360_to_600_degrees_per_second,4294967295,
IDE05996-ENG120765,Steering wheel angle speed load-50_to_360_degrees_per_second,4294967295,
IDE05996-ENG120767,Steering wheel angle speed load-600_to_800_degrees_per_second,4294967295,
IDE05996-ENG120768,Steering wheel angle speed load-above_800_degrees_per_second,4294967295,
IDE06678-MAS03000,Pull compensation-Adaptation value,-1200, N
IDE06678-MAS03095,Pull compensation-Function status,not active,
IDE07543,Vehicle speed,0, km/h
IDE10300,OBD Driving Cycle detected,not active,
IDE11591-IDE11629,Result of basic setting of steering angle-Status of the active routine,Finish routine: routine OK,
IDE11591-MAS05584,Result of basic setting of steering angle-Result,Preconditions met,
IDE11591-MAS14036,Result of basic setting of steering angle-Number of iterations,2,
IDE11591-MAS14037,Result of basic setting of steering angle-RESTRICTION,no restriction,
IDE11591-MAS14038,Result of basic setting of steering angle-Type of restriction,Precondition,
IDE11602-IDE11629,Result of steering angle sensor: initialization-Status of the active routine,Finish routine: routine OK,
IDE11602-MAS05584,Result of steering angle sensor: initialization-Result,Preconditions met,
IDE11602-MAS14036,Result of steering angle sensor: initialization-Number of iterations,2,
IDE11602-MAS14037,Result of steering angle sensor: initialization-RESTRICTION,no restriction,
IDE11602-MAS14038,Result of steering angle sensor: initialization-Type of restriction,Precondition,
IDE11603-IDE11629,Result of steering angle sensor: move to mechanical center-Status of the active routine,Finish routine: routine OK,
IDE11603-MAS05584,Result of steering angle sensor: move to mechanical center-Result,Preconditions met,
IDE11603-MAS14036,Result of steering angle sensor: move to mechanical center-Number of iterations,2,
IDE11603-MAS14037,Result of steering angle sensor: move to mechanical center-RESTRICTION,no restriction,
IDE11603-MAS14038,Result of steering angle sensor: move to mechanical center-Type of restriction,Precondition,
IDE11604-IDE11629,Result of steer.angle sens.: zero calibr.steer.wheel balance-Status of the active routine,Finish routine: routine OK,
IDE11604-MAS05584,Result of steer.angle sens.: zero calibr.steer.wheel balance-Result,Pre-conditions not fulfilled,
IDE11604-MAS14036,Result of steer.angle sens.: zero calibr.steer.wheel balance-Number of iterations,2,
IDE11604-MAS14037,Result of steer.angle sens.: zero calibr.steer.wheel balance-RESTRICTION,Canceled by user,
IDE11604-MAS14038,Result of steer.angle sens.: zero calibr.steer.wheel balance-Type of restriction,Precondition,
IDE11605-IDE11629,Result of resetting of all adaptation values-Status of the active routine,Finish routine: routine OK,
IDE11605-MAS05584,Result of resetting of all adaptation values-Result,Preconditions met,
IDE11605-MAS14036,Result of resetting of all adaptation values-Number of iterations,2,
IDE11605-MAS14037,Result of resetting of all adaptation values-RESTRICTION,no restriction,
IDE11605-MAS14038,Result of resetting of all adaptation values-Type of restriction,Precondition,
IDE11606-IDE11629,Result of resetting of all adjustments-Status of the active routine,Finish routine: routine OK,
IDE11606-MAS05584,Result of resetting of all adjustments-Result,Preconditions met,
IDE11606-MAS14036,Result of resetting of all adjustments-Number of iterations,2,
IDE11606-MAS14037,Result of resetting of all adjustments-RESTRICTION,no restriction,
IDE11606-MAS14038,Result of resetting of all adjustments-Type of restriction,Precondition,
IDE11607-IDE11629,Result of resetting all software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11607-MAS05584,Result of resetting all software end-stops-Result,Preconditions met,
IDE11607-MAS14036,Result of resetting all software end-stops-Number of iterations,2,
IDE11607-MAS14037,Result of resetting all software end-stops-RESTRICTION,no restriction,
IDE11607-MAS14038,Result of resetting all software end-stops-Type of restriction,Precondition,
IDE11608-IDE11629,Result of resetting to factory setting-Status of the active routine,Finish routine: routine OK,
IDE11608-MAS05584,Result of resetting to factory setting-Result,Preconditions met,
IDE11608-MAS14036,Result of resetting to factory setting-Number of iterations,2,
IDE11608-MAS14037,Result of resetting to factory setting-RESTRICTION,no restriction,
IDE11608-MAS14038,Result of resetting to factory setting-Type of restriction,Precondition,
IDE11609-IDE11629,Result of steering angle sensor: software end-stops-Status of the active routine,Finish routine: routine OK,
IDE11609-MAS05584,Result of steering angle sensor: software end-stops-Result,Pre-conditions not fulfilled,
IDE11609-MAS14036,Result of steering angle sensor: software end-stops-Number of iterations,5,
IDE11609-MAS14037,Result of steering angle sensor: software end-stops-RESTRICTION,Steering angle speed negative dropping slope on curve,
IDE11609-MAS14038,Result of steering angle sensor: software end-stops-Type of restriction,Precondition,
IDE11863,Support power reduction,100.0, %
IDE11865-IDE00021,Reason for engagement steering support-Engine RPM,not met,
IDE11865-IDE00075,Reason for engagement steering support-Vehicle speed,not met,
IDE11865-MAS01737,Reason for engagement steering support-Diagnosis,not met,
IDE11865-MAS08112,Reason for engagement steering support-Drive readiness,not met,
MAS01172-MAS01156,Development messages-Communication status,Stop,
MAS01172-MAS03095,Development messages-Function status,not active,
MAS01891-IDE02955,Lane assist-System status,not active,
MAS01891-MAS03095,Lane assist-Function status,not active,
MAS01891-MAS03368,Lane assist-Steering wheel vibration,not active,
MAS01891-MAS05054,Lane assist-Steering torque request: lane retention assistant,6543.5, Nm
MAS01891-MAS12816,Lane assist-Lane assistant: direct access power,0, N
MAS01891-MAS12817,Lane assist-Lane assistant: steering wheel vibration force,0, N
MAS01891-MAS12818,Lane assist-Lane assistant: overlay torque,0.0, Nm
MAS02126-IDE05744,Steering angle sensor: status-Steering angle sensor: initialization,initialized,
MAS02126-MAS01632,Steering angle sensor: status-Status,active,
MAS02126-MAS02247,Steering angle sensor: status-CAN message,invalid,
MAS02126-MAS10118,Steering angle sensor: status-Steering angle sensor: status of calibration,calibrated,
MAS08112,Drive readiness,active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
ENG157548-MAS00976,Angle_estimator-Counter,0,
ENG157548-ENG163894,Angle_estimator-Symmetry_angle_a,1.52588e-005, °
ENG157548-ENG163895,Angle_estimator-Symmetry_angle_b,1.10002, °
ENG157548-ENG163896,Angle_estimator-Symmetry_angle_offset,1.10002, °
ENG157548-ENG163897,Angle_estimator-Symmetry_calculated_angle,-1024, °
ENG157548-ENG163898,Angle_estimator-Symmetry_learning_status,Not adapted,
ENG157712,Current_gradient_limiting,12.0, %
ENG157713,Current_limiting,0.0, %
Elapsed Time: 00:07
blockmap-51-0ET-907-121-G_WVGAWVEB7SH010695-20241230-1135.CSV
;SW:0ET-907-121-G   HW:0ET-907-121-G ---  Electric Drive
;Component:MEB INV6.0    H10 7260, Coding:
;EV_DMCM21000110ET907121G,001001,EV_DMCM21000110ET907121G.rod
;Monday,30,December,2024,11:35:26:18177
;VCID: 44D696EB2E1FAF3A17A-8010-R SFD
IDE00019,Voltage terminal 30,14.779, V
IDE00024,ATF temperature,9.70, °C
IDE00601,Monitoring status since erasing DTC memory,,
IDE00619,RPM of electric machine,0, /min
IDE00628,Specified value of intermediate circuit voltage,0.00, V
IDE00635,Intermediate circuit current,0.00, A
IDE00637,DC link voltage,399.16, V
IDE00643,Minimum torque of electric machine,-0.25, Nm
IDE00644,Maximum torque of electric machine,-0.19, Nm
IDE00645,Specified torque of electric machine,0.00, Nm
IDE00651,Specified RPM of electric machine,0, /min
IDE00773,Terminal 15 status via CAN,1,
IDE00938,Calculated actual torque of electric machine,-0.25, Nm
IDE05246,Power electronics heat sink temperature,10.94, °C
IDE05249,Regulation due to excessive temperature,0,
IDE05250,Drive control condition,wait on command,
IDE05419,Intermediate circuit current maximum limit,800.00, A
IDE05420,Intermediate circuit current minimum threshold,-333.00, A
IDE05421,Torque: current value,-0.19, Nm
IDE06502,Offset angle adaptation: status,Precise,
IDE06552,Time since terminal 15 ON,644, s
IDE06553,Electrical drive control module: operating status,Unknown (2048),
IDE06805,Status of voltage freedom,2,
IDE09095,CAN signal battery management sys: traction network voltage,0.00, V
IDE09096,CAN signal battery management system high voltage protection: status,closed,
IDE09097,E-machine electrical rotor frequency,0.0, Hz
IDE09098,E-machine electrical power,0, W
IDE09099,E-machine mechanical power,0, W
IDE09100,E-machine free-run status,Enabled,
IDE09102,E-machine effective current,0.63, A
IDE09103,E-machine stator temperature,10.72, °C
IDE09104,E-machine stator temperature characteristic,0,
IDE09109,Power electronics voltage terminal 30: channel 1,14.779, V
IDE09111,Power electronics gate driver status,Free run,
IDE09113,Power Electronics IGBT-Module Temperature Phase U,10.91, °C
IDE09114,Power Electronics IGBT-Module Temperature Phase V,10.84, °C
IDE09115,Power Electronics IGBT-Module Temperature Phase W,10.97, °C
IDE09118,Magnetic flow calibration: status,0,
IDE09119,Position offset calibration: diagnostic status,NotTested__E,
IDE09126,Vehicle switch-off time,846, s
IDE09210,Phase current phase U unrestricted,0.69, A
IDE09211,Phase current phase V unrestricted,2.31, A
IDE09212,Phase current phase W unrestricted,1.75, A
IDE10300,OBD Driving Cycle detected,active,
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVGAWVEB7SH010695,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,4,
IDE14017,Operating mode: actual value,operational,
IDE14181,Transmission sump temperature,9.70, °C
IDE14182,Film capacitor temperature of the DC/DC converter,11.69, °C
IDE14382,Rotor temperature calculated,9.34, °C
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,0,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 00,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3D 5C A0 C2 C8 49 AA,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,2,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 0B,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS18384,Secure Onboard Communication: Freshness Values information-SOC time of last successful verification,FF FF FF FF FF FF FF FF,
IDE14496-MAS18385,Secure Onboard Communication: Freshness Values information-Current value of message counter,255,
IDE14496-MAS18386,Secure Onboard Communication: Freshness Values information-Bitfield with used counter values,11111111 11111111 ,
IDE14497-MAS17099,Secure Onboard Communication: missing key-Number of missing keys,0,
IDE14497-MAS17100,Secure Onboard Communication: missing key-Missing key,00 00,
IDE14497-MAS18387,Secure Onboard Communication: missing key-Missing key status,valid,
IDE16766,Type of discharge,No discharge,
IDE16768,Position offset angle: status,Precise,
IDE16930,High voltage in the intermediate circuit,0.00, V
IDE16931,Gate driver of power electronics: status,short circuit to Ground (GND),
IDE16993,Type of discharge: target mode,No discharge,
IDE18185,Offset angle of rotor positions,122.119, DegreElect
IDE80256,Rotor pos. sensor: sine offset,0.00, V
IDE80257,Rotor pos. sensor: cosine offset,0.00, V
MAS06254,Supply voltage Terminal 30 - 2,14.785, V
MAS07826,Request emergency discharge HV intermittent circuit condenser,no discharge request,
MAS13360,Discharge current HV intermediate circuit power electronics,0.00, A
MAS13363,Redundant intermediate circuit voltage power electronics,399.31, V
MAS13431,Low-voltage fuse: current,0.301, A
MAS13802,Rotor position sensor 2: cosine amplitude,0.00, V
MAS13803,Rotor position sensor 2: sine amplitude,0.00, V
MAS13804,Rotor position sensor 2: exciter amplitude,0.45004,
MAS20914,E-machine torque limitation,1,
MAS28035,Power electronics: requested level 2 target mode,8,
MAS28036,Power electronics: phase current difference fault status,0,
MAS28046,Power electronics: synchronized traction network,399.31, V
MAS28302,Power electronics: filtered phase current effective value,0.81, A
MAS28638,Power electronics temperature busbar: calculated value,13.19, °C
ENG286535,AC_phase_current_level_2_filtered_amplitude,0.44, A
ENG286536,AC_phase_current_level_2_filtered_amplitude_quality,OK,
ENG286544,Buck_boost_converter_input_current_filtered,0.301, A
ENG286545,Calibrated_level_2_rotor_offset_angle,122.997, DegreElect
ENG286546,CAN_network_management_status,1,
ENG286547,Check_sum_error_counter_motor_56_frame,0,
ENG390337,Cntr Ary Knk Out Rec 10ms pp rbe Bsw Adpr Cust 10ms rbe Bsw Adpr Cust,0,
ENG286548,Communication_status_motor_56_frame,rbe_CmnGlbMon_StCom_Norm_e,
ENG286548-ENG286905,Communication_status_motor_56_frame-Test_Program_Rbe Cdd Mon Fct Com Enum rbe Cmn Glb Mon St Com UBYTE,2,
ENG105721,Current_DC_Link_power,0, W
ENG286553,DC_link_filtered_voltage_with_sensor_tolerance,401.44, V
ENG286554,DC_link_voltage_1_V2,399.47, V
ENG286555,DC_Link_voltage_lower threshold_value,260.00, V
ENG286556,DC_Link_voltage_upper_threshold_value,442.00, V
ENG105799,Desired_torque,0.00, Nm
ENG286558,Diodes_overall_average_power_loss_value,0.0, W
ENG286559,Diodes_temperature_modelled_value,10.95, °C
ENG286561,Drive_motor_speed_difference_ASR_MSR_speed_limits,-860, /min
ENG286566,Emergency_discharge_request_quality_fault_status,OK,
ENG286580,Excitation_flux_filtered_value,0.051701, Wb
ENG286581,External_watchdog_error_counter,0,
ENG106482,Failure_emergency_shut_off,0,
ENG106483,Failure_free_wheeling,0,
ENG157343,Failure_inverter_limited_prfmnc,0,
ENG106485,Failure_inverter_shut_off,0,
ENG157344,Field_weakening_active,0,
ENG286586,Gate_driver_high_side_supply_status,step-up-operation,
ENG286587,Gate_driver_low_side_supply_status,not active,
ENG286588,Gate_driver_lowside_supply_desired_status,not active,
ENG286592,HV_flyback_converter_input_current,0.0071, A
ENG286593,HV_MCU_desired_operation_mode,rbe_CddHvMcu_StMod_NormMod_e,
ENG286593-ENG145775,HV_MCU_desired_operation_mode-Test_Program_Rbe Cdd Hv Mcu Enum rbe Cdd Hv Mcu St Mod UBYTE,0,
ENG286594,HV_MCU_operation_mode,Normal mode,
ENG286595,HV_MCU_reference_voltage_external_value,4.105, V
ENG286596,IGBT_phase_UVW_maximum_temperature_selection,0.00, °C
ENG286597,IGBT_temperature_modelled_value,10.97, °C
ENG286601,Intermediate_circuit_lowside_voltage_filtered_value,18.373, V
ENG144277,Internal_supply_voltage_15_inverter_IGBT,16.697, V
ENG274516,Inverter_current_in_d-direction_actual_value,-0.38, A
ENG274518,Inverter_current_in_q-direction_actual_value,-0.31, A
ENG286608,Inverter_gate_driver_safe_state_status,0,
ENG331380,Inverter_pwm_ratio_acquisition_error_state,0,
ENG286609,Irreversible_amplitude_difference_error,0,
ENG286610,Irreversible_amplitude_range_check_error,0,
ENG286611,Irreversible_normal_mode_check_error,0,
ENG286612,Irreversible_permanent_range_check_error,0,
ENG286613,Irreversible_phase_current_check_error,0,
ENG286614,Irreversible_plug_mode_check_error,0,
ENG286620,Last_received_query_from_external_watchdog,505290270,
ENG286621,Last_sent_answer_to_external_watchdog,2790697305,
ENG157388,Load_moment_auxiliary,0.00, Nm
ENG107585,Maximal_torque_hybrid_controller,1023.50, Nm
ENG107589,Maximum_power_limit,230016, W
ENG107590,Maximum_torque_derating_reason,Unknown (512),
ENG286628,MCU_error_counter,0,
ENG107623,Minimal_torque_hybrid_controller,-1023.00, Nm
ENG107625,Minimum_power_limit,-153536, W
ENG107626,Minimum_torque_derating_reason,Unknown (512),
ENG286629,Monitoring_desired_operating_mode_received_signal_quality,OK,
ENG286630,Monitoring_desired_torque_received_signal_quality,OK,
ENG286631,Monitoring_motor_maximum_mechanical_torque_signal_quallity,OK,
ENG286632,Monitoring_motor_maximum_speed_signal_quallity,OK,
ENG286633,Monitoring_motor_minimum_mechanical_torque_signal_quallity,OK,
ENG286634,Monitoring_motor_minimum_speed_signal_quallity,OK,
ENG286635,Monitoring_reinitialisation_end_to_end_communication_status,0,
ENG286636,Monitoring_state_shutoff_path_first_debug_word,0,
ENG286638-ENG188621,MPU_address_of_program_that_caused_trap-Bits 0-7,0,
ENG286639-ENG188621,MPU_bus_master_ID_which_caused_trap-Bits 0-7,0,
ENG286640-ENG188621,MPU_core_ID_stopped_by_trap-Bits 0-7,0,
ENG286641-ENG188621,MPU_error_type-Bits 0-7,0,
ENG286642-ENG188621,MPU_memory_address_to_trap-Bits 0-7,0,
ENG286643,Offset_angle_calibration_status,not tested,
ENG144276,Periodic_time_gate_driver,0.00010000, s
ENG286648,Powermodule_phase_1_temperature_characteristic_curve_status,1,
ENG286649,Powermodule_phase_2_temperature_characteristic_curve_status,1,
ENG286650,Powermodule_phase_3_temperature_characteristic_curve_status,1,
ENG286651,PWM_frequency,10000, Hz
ENG286659,Resolver_cosine_signal_filtered_amplitude,0.44501,
ENG286660,Resolver_cosine_signal_filtered_offset_derivation,0.00394,
ENG286661,Resolver_minimum_maximum_relative_amplitude_difference_to_average_amplitude_value,0.00269,
ENG286664,Resolver_sine_cosine_relative_amplitude_difference,0.00269,
ENG286665,Resolver_sine_cosine_relative_amplitude_difference_corrected_value,0.01999,
ENG286666,Resolver_sine_cosine_relative_amplitude_difference_estimated_value,0.00000,
ENG286667,Resolver_sine_signal_filtered_amplitude,0.44864,
ENG286668,Resolver_sine_signal_filtered_offset_derivation,0.00092,
ENG286669,Resolver_voltage_cosine_signal,-2.50, V
ENG286670,Resolver_voltage_sine_signal,0.88, V
ENG286682,Shut_off_path_test_permission_status,idle_mode,
ENG286684,SPI_communication_error_counter,0,
ENG390526,St Bit Fie Knk Out Tmr Rec 10ms pp rbe Bsw Adpr Cust 10ms rbe Bsw Adpr Cust,16255,
ENG390527,St Test Mod Knk Out Rec 10ms pp rbe Bsw Adpr Cust 10ms rbe Bsw Adpr Cust,0,
ENG286690,Status_communication_failure_motor_frame_56,0,
ENG286691,Status_CPLD_Hardware_faults,3438346239,
ENG286694,Status_end_to_end_motor_56_frame,No timeout/checksum/alive counter errors,
ENG286704,Status_value_check_motor_56_frame,0,
ENG286705,Sum_of_filtered_phase_currents,4.00, A
ENG286707,Switch_power_loss_modelled,0.0, W
ENG286709,Torque_calculated_from_power,0.00, Nm
ENG286711,Torque_electric_drive_motor_minimum_available_value,-560.44, Nm
ENG286712,Torque_filtered_desired_value,0.00, Nm
ENG286713,Torque_internal_desired_comparison_value,0.00, Nm
ENG286714,Torque_level_2_estimated_filtered_value,0.00, Nm
ENG286715,Torque_limited_damping_value,0.00, Nm
ENG286717,Torque_maximum_desired_negative_value,0.00, Nm
ENG286718,Torque_maximum_desired_positive_value,0.00, Nm
ENG286719,Torque_maximum_value,560.44, Nm
ENG286720,Traction_line_voltage_incremental_change_value,0.06, V
ENG286722,Vehicle_downtime_valid_state_V2,Unknown (256),
ENG286723,Vehicle_velocity_signal_quality,OK,
ENG286734,Voltage_regulator_input_voltage_filtered_value,14.275, V
Elapsed Time: 00:16
blockmap-52-1EA-959-592-F_WVGAWVEB7SH010695-20241230-1136.CSV
;SW:1EA-959-592-F   HW:1EA-959-592-F ---  Door Elect, Pass.
;Component:TSG BFS       009 0563, Coding:00355320DE00028040800020
;EV_DCU3PasseSideMAXHCONT,001004,EV_DCU3PasseSideMAXHCONT_VWE3.rod
;Monday,30,December,2024,11:36:01:18177
IDE02268-IDE00773,Supply voltage for door control module: front: frt.pass. side-Terminal 15 status via CAN,active,
IDE02268-IDE01715,Supply voltage for door control module: front: frt.pass. side-Status terminal S,active,
IDE02268-IDE05835,Supply voltage for door control module: front: frt.pass. side-Supply voltage for central locking,15.00, V
IDE04216-MAS04247,Mirror heater-Button,not installed,
IDE04539-MAS02228,Mirror memory-X coordinate,23, %
IDE04539-MAS02229,Mirror memory-Y coordinate,59, %
IDE04540,Mirror adjustment (X/Y direction),not installed,
IDE05727-IDE04213,Front passenger side door status-Central locking button,Not operated,
IDE05727-IDE04214,Front passenger side door status-Key switch in door lock,not installed,
IDE06207-MAS01453,Front window regulator status: frt.pass. side-Blocking detection,not active,
IDE06207-MAS02039,Front window regulator status: frt.pass. side-Force limitation,not active,
IDE06207-MAS02097,Front window regulator status: frt.pass. side-Window position,0.00, %
IDE06207-MAS02098,Front window regulator status: frt.pass. side-Window regulator standardized,Yes,
IDE06207-MAS03548,Front window regulator status: frt.pass. side-Motor current,0, A
IDE06207-MAS04642,Front window regulator status: frt.pass. side-Before upper stop,active,
IDE06207-MAS05370,Front window regulator status: frt.pass. side-Direction of movement,Position top,
IDE06872,Front passenger power window button,Not operated,
IDE06934,Front window regulator relay: frt.pass. side,Open,
IDE06938-MAS02545,Front window regulator reversing position: frt. pass. side-Last,127.50, %
IDE06938-MAS02546,Front window regulator reversing position: frt. pass. side-Second to last,127.50, %
IDE06938-MAS02547,Front window regulator reversing position: frt. pass. side-Third to last,127.50, %
IDE06938-MAS02548,Front window regulator reversing position: frt. pass. side-Fourth to last,127.50, %
IDE06938-MAS05380,Front window regulator reversing position: frt. pass. side-fifth to last,127.50, %
IDE07223,Window regulator child lock: frt.pass. side,Not available,
IDE07406-IDE03114,Enable front passenger window regulator relay-Comfort function,No,
IDE07406-MAS02447,Enable front passenger window regulator relay-Release,Yes,
IDE07410-MAS01632,Excess.temp. disconnect: front window regulator: frt.pass. side-Status,not active,
IDE07410-MAS02955,Excess.temp. disconnect: front window regulator: frt.pass. side-Engine temperature,22, °C
IDE07414,Comfort function for front window regulator: frt.pass. side,not active,
IDE15340,Light output 1 pin D8 target brightness on front passenger side,Not available,
IDE15341,Light output 2 pin D3 target brightness on front passenger side,Not available,
IDE15342,Light output 3 pin C1/B3 target brightness on front passenger side,0, %
IDE15343,Light output 4 pin D16 target brightness on front passenger side,0, %
Elapsed Time: 00:06
blockmap-5F-10C-035-842-A_WVGAWVEB7SH010695-20241230-1136.CSV
;SW:10C-035-842-A   HW:10C-035-842 ---  Information Electr.
;Component:IC3GSF--US    H09 3626, Coding:64101030000000000000000000000000000000000000000000
;EV_MUICASSAFEPart,002001,EV_MUICASSAFEPart_002_VNE4.rod
;Monday,30,December,2024,11:36:17:18177
;VCID: 1B640D97F321B0C2860-804E-R SFD
IDE00019,Voltage terminal 30,15.00, V
IDE00021,Engine RPM,0.00, /min
IDE00767,No. of unscheduled ECU resets,0,
IDE04312-MAS00109,System run time-Hours,0, H
IDE04312-MAS00110,System run time-Minutes,18, min
IDE05713-MAS01632,Network diagnosis-Status,Enabled,
IDE07589-IDE07590,Update programming: status-Currently processed module,0,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,0,
IDE07589-MAS01632,Update programming: status-Status,not active,
IDE07589-MAS10948,Update programming: status-control,Diagnosis,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 70|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 8F|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 B4|FF 14 00 00 00 00 00 00 00 00 00 00 00 02 00 06|FF 14 00 00 00 00 00 00 00 00 00 00 00 04 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 05 00 00|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|3|,
IDE11756,IP network: counter messages with inadmissible VLANs,65535,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,0,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,0,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|02 7D FA 00 73 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|00 00 00 00 00 00,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01,0|02 7D FA 00 10 00,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 10,3|02 7D FA 00 73 00,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,3|02 7D FA 00 73 00,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,3|02 7D FA 01 06 00,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 06,3|02 7D FA 01 08 00,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 08,3|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 FC 10,3|44 20 63 0B 99 4E,FD 53 7C B8 03 83 00 03 00 00 00 00 00 04 00 10,3|02 7D FA 00 10 01,FD 53 7C B8 03 83 00 03 00 00 00 00 00 08 00 10,3|00 00 00 00 00 00,FE 80 00 01 00 00 00 00 00 00 00 00 00 00 00 01,0|02 7D FA 00 73 00,FE 80 00 21 00 00 00 00 00 7D FA FF FE 00 73 00,0|00 00 00 00 00 02,FE 80 00 22 00 00 00 00 02 00 00 FF FE 00 00 02,0|02 7D FA 00 73 00,FE 80 00 23 00 00 00 00 00 7D FA FF FE 00 73 00,3|00 00 00 00 00 00,FE 80 00 25 00 00 00 00 00 00 00 00 00 00 00 01,0|,
IDE12238,I network: discarded messages counter,0,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Test not yet carried out|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|,
IDE12633,IP Network maximum correction of the synchronized clock,-14335, µs
IDE12980-ENG297751,Inspection: distance driven since the last inspection-FIX_Read_mileage_since_last_mileage_based_service_event,400, km
IDE12981-ENG303026,Inspection: time since the last inspection-FIX_Read_time_since_last_time_based_service_event,20, d
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,28,
IDE15495-MAS00976,Filtered data package due to firewall control at layer 3 and up-Counter,00 00 00 00 00 00 00 00,
IDE15495-MAS05767,Filtered data package due to firewall control at layer 3 and up-port,1,
IDE15496-MAS00976,Filtered data package due to firewall control up to layer 3-Counter,00 00 00 00 00 00 00 00,
IDE15496-MAS05767,Filtered data package due to firewall control up to layer 3-port,1,
MAS00778-IDE03619,Multimedia System 1-System condition,On,
MAS00778-IDE05228,Multimedia System 1-Operating hour counter,34, H
MAS00778-MAS00110,Multimedia System 1-Minutes,34, min
MAS00778-MAS01634,Multimedia System 1-Supply voltage,14.90, V
MAS00778-MAS02200,Multimedia System 1-Highest measured temperature,58, °C
MAS00778-MAS02201,Multimedia System 1-Temperature,42, °C
MAS00778-MAS03691,Multimedia System 1-Dimming,100, %
MAS26570-ENG334268,Distance of safety error-mileage_error_security_AR2_value,00 00,
MAS27747-MAS00106,Distance data with onboard supply control unit and electronic stabilization program information-Year,2019, yr
MAS27747-MAS00107,Distance data with onboard supply control unit and electronic stabilization program information-Month,1, Months
MAS27747-MAS00108,Distance data with onboard supply control unit and electronic stabilization program information-Day,1, d
MAS27747-MAS00109,Distance data with onboard supply control unit and electronic stabilization program information-Hours,0, H
MAS27747-MAS00110,Distance data with onboard supply control unit and electronic stabilization program information-Minutes,0, min
MAS27747-MAS00111,Distance data with onboard supply control unit and electronic stabilization program information-Seconds,8, s
MAS27747-MAS27735,Distance data with onboard supply control unit and electronic stabilization program information-ESC distance pulses,00 00 00 00 01 0B 19 E0,
MAS27747-MAS27749,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: number of jumps,11,
MAS27747-MAS27750,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: largest positive jump,16107296,
MAS27747-MAS27751,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: largest negative jump,0,
MAS27747-MAS27752,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: total jumps,00 00 00 00 06 F3 AE 80,
MAS27747-MAS27753,Distance data with onboard supply control unit and electronic stabilization program information-Distance pulses: jump balance,0,
MAS27747-MAS27754,Distance data with onboard supply control unit and electronic stabilization program information-Electronic stabilization program communication failures: number,2,
MAS27747-MAS27755,Distance data with onboard supply control unit and electronic stabilization program information-Electronic stabilization program communication failures: total duration,34, s
MAS27747-MAS27756,Distance data with onboard supply control unit and electronic stabilization program information-Longest electronic stabilization program communication failure,1, min
MAS27747-MAS27757,Distance data with onboard supply control unit and electronic stabilization program information-Longest onboard supply control unit communication failure,1, min
MAS27747-MAS27758,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit communication failures: total duration,35, s
MAS27747-MAS27759,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: number of jumps,14,
MAS27747-MAS27760,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: jump balance,464479, m
MAS27747-MAS27761,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: total jumps,4217897, m
MAS27747-MAS27762,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: largest negative jump,0, m
MAS27747-MAS27763,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit distance: largest positive jump,464479, m
MAS27747-MAS27764,Distance data with onboard supply control unit and electronic stabilization program information-Onboard supply control unit communication failures: number,2,
MAS27747-MAS27765,Distance data with onboard supply control unit and electronic stabilization program information-Total distance: status,464, km
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,dont care,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,dont care,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,dont care,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,dont care,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,dont care,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,dont care,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,dont care,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,dont care,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,dont care,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,dont care,
ENG274022-ENG256370,Display_speed_instrument_cluster-speed_warning_tire_isActive,false,
ENG274022-ENG256371,Display_speed_instrument_cluster-speed_warning_tire_threshold,30, km/h
ENG274022-ENG256372,Display_speed_instrument_cluster-speed_warning_user_isActive,false,
ENG274022-ENG256373,Display_speed_instrument_cluster-speed_warning_user_threshold,30, km/h
ENG274022-ENG256374,Display_speed_instrument_cluster-speed_warning_user2_isActive,false,
ENG274022-ENG256375,Display_speed_instrument_cluster-speed_warning_user2_threshold,30, km/h
ENG254819-ENG98988,startup_timer-Timer,1114, s
ENG254835-ENG258372,Unit_master-consumption_electric,Miles per kWh,
ENG254835-ENG274108,Unit_master-consumption_gas,mpg equivalent (US),
ENG254835-ENG274107,Unit_master-consumption_petrol_or_diesel,Miles per gallon (US),
ENG254835-ENG171158,Unit_master-Date,mm_dd_yy,
ENG254835-ENG144693,Unit_master-Distance,miles,
ENG254835-ENG180343,Unit_master-Pressure,psi,
ENG254835-ENG98926,Unit_master-Speed,Miles per hour,
ENG254835-ENG98971,Unit_master-Temperature,Degrees Fahrenheit,
ENG254835-ENG98987,Unit_master-Time,12h AM_PM,
ENG254835-ENG253460,Unit_master-Towing_capacity_mass,Pounds (lbs),
ENG254835-ENG274074,Unit_master-Volume,gallons (US),
Elapsed Time: 00:12
blockmap-6C-1EA-980-556-L_WVGAWVEB7SH010695-20241230-1136.CSV
;SW:1EA-980-556-L   HW:5WA-980-556-C ---  Back-up Cam.
;Component:RV eCompact   H52 0574, Coding:0603460027140000
;EV_CamSysRVCeCFicosUNECE,003008,EV_CamSysRVCeCFicosUNECE.rod
;Monday,30,December,2024,11:36:59:18177
IDE00019,Voltage terminal 30,14.70, V
IDE00303-MAS00222,Status: doors/lids 1-Rear lid,closed,
IDE00303-MAS01374,Status: doors/lids 1-Trailer,Measuring value not available,
IDE00924-IDE08941,Steering angle-Rack position,163.78,
IDE00924-MAS02471,Steering angle-Sign,Negative,
IDE00924-MAS02983,Steering angle-Steering wheel angle,2.3,
IDE00924,Steering angle,0.1125,
IDE00924-MAS10998,Steering angle-Rear-wheel drive: steering angle,81.89,
IDE00924-MAS10999,Steering angle-Rear-wheel drive: sign,Positive,
IDE00924-MAS11000,Steering angle-Rack: sign,Positive,
IDE06449-MAS05746,Camera system calibration-Rearview camera calibration status,Calibration ended,
IDE06449-MAS05748,Camera system calibration-Rearview camera calibration progress,0, %
IDE06449-MAS05750,Camera system calibration-Rearview camera calibration repeat attempts,0,
IDE06449-MAS05753,Camera system calibration-Cause of rearview camera calibration error,calibrated,
IDE06449-MAS05803,Camera system calibration-Rearview camera calibration resumption,No resumption,
IDE07402-MAS10858,External activation-Rear camera,not active,
IDE10589-MAS10858,Temperature of the camera-Rear camera,37, °C
IDE10740-IDE03619,System state area view-System condition,active,
IDE10780-MAS11932,Ethernet counter connection interruptions-Counter open circuit,0,
IDE10781-MAS11933,Ethernet counter checksum malfunction-Counter CRC error,0,
IDE11010-MAS00106,Rear camera: calibration time-Year,2024, yr
IDE11010-MAS00107,Rear camera: calibration time-Month,0, Months
IDE11010-MAS00108,Rear camera: calibration time-Day,15, d
IDE11010-MAS00109,Rear camera: calibration time-Hours,10, H
IDE11010-MAS00110,Rear camera: calibration time-Minutes,17, min
IDE11010-MAS00111,Rear camera: calibration time-Seconds,0, s
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address||IPv6 Multicast address|FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00|||IPv6 Multicast address|05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00||,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,65535,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|44 3C 88 6B 00 D6|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|00 00 00 00 00 00|,
IDE12238,I network: discarded messages counter,65535,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69,Test not yet carried out|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,Communication not possible|,
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,-1e+007,
IDE13845,Production mode status,No function restriction,
MAS02356-MAS10858,Type of calibration-Rear camera,TopView: calibration with calibration panel,
Elapsed Time: 00:04
blockmap-6D-4KE-959-107-B_WVGAWVEB7SH010695-20241230-1137.CSV
;SW:4KE-959-107-B   HW:4KE-959-107-B ---  Trunk Elect.
;Component:HDSG-Modul    H08 0342, Coding:6208
;EV_DeckLidCONTIAU536,001006,EV_DeckLidCONTIAU536_001_VWE3.rod
;Monday,30,December,2024,11:37:10:18177
;VCDS Version: Beta 24.12.0 (x64)  Data version: 20241120 DS361.3
;VCID: 45D08BEF25259632004-8010-R
Group,Description,Actual
IDE00019,Voltage terminal 30,14.86, V
IDE00542,Excessive temperature protection,not active,
IDE02019-MAS08993,Position programmable opening stop-Upper end pos.: relative,99, %
IDE02019-MAS08994,Position programmable opening stop-Upper end pos.: absolute,4740,
IDE02049,Trailer detected,Not available,
IDE02093-MAS09014,Status of rear lid lock-pre-latch,closed,
IDE02093-MAS09015,Status of rear lid lock-Main latch,closed,
IDE02093-MAS09016,Status of rear lid lock-Rear lid lock,closed,
IDE02094-MAS09057,Status of closing assist-Limit switch for pull-shut assist.,operated,
IDE02095-MAS01947,Status of pinch protection-Clamping strip 1,Not operated,
IDE02095-MAS01948,Status of pinch protection-Clamping strip 2,Not operated,
IDE02095-MAS01949,Status of pinch protection-Clamping strip 3,Not operated,
IDE02095-MAS01950,Status of pinch protection-Clamping strip 4,Not operated,
IDE03427-MAS08995,Upper end stop: maximum value-Max. upper end position,4785,
IDE03615-MAS02672,Variant-Start-stop,1,
IDE03906-MAS01947,Pinch protection voltage supply status-Clamping strip 1,OFF,
IDE03906-MAS01948,Pinch protection voltage supply status-Clamping strip 2,OFF,
IDE03906-MAS01949,Pinch protection voltage supply status-Clamping strip 3,OFF,
IDE03906-MAS01950,Pinch protection voltage supply status-Clamping strip 4,On,
IDE05229-MAS09002,Reason for cancellation of rear lid procedure-Last reason,END,
IDE05229-MAS09003,Reason for cancellation of rear lid procedure-second last reasons,END,
IDE05229-MAS09004,Reason for cancellation of rear lid procedure-third last reason,END,
IDE05229-MAS09005,Reason for cancellation of rear lid procedure-fourth last reason,END,
IDE05229-MAS09006,Reason for cancellation of rear lid procedure-fifth last reason,END,
IDE09491-IDE03434,Lock-in area-Detection area lower,300,
IDE09491-IDE03435,Lock-in area-Detection area upper,80,
IDE09492-MAS06165,Temperatures-Processor,-3276.00, °C
IDE09492-MAS08858,Temperatures-Outside air temperature on CAN,Initialization,
IDE09492-MAS08996,Temperatures-Internal temp. on CAN,19.50, °C
IDE09492-MAS08997,Temperatures-Output stage for tailgate motor,24.00, °C
IDE09492-MAS08998,Temperatures-Tailgate motor left,12.00, °C
IDE09492-MAS08999,Temperatures-Tailgate motor right,12.00, °C
IDE09492-MAS09001,Temperatures-Closing Assist Motor,Not available,
IDE09492-MAS09051,Temperatures-Output stage for tailgate motor: calculated,120.00, °C
IDE09492-MAS09053,Temperatures-Output stage for closing assist: calculated,Not available,
IDE09492-MAS11205,Temperatures-Luggage compartment cover motor,70.00, °C
IDE09492-MAS11206,Temperatures-Output stage for luggage comp. cover: calc.,120.00, °C
IDE09493,Status of basic tailgate setting,Basic setting ended,
IDE09494-MAS09002,Cancellation reason of basic tailgate setting-Last reason,Unknown (0),
IDE09494-MAS09003,Cancellation reason of basic tailgate setting-second last reasons,Unknown (0),
IDE09494-MAS09004,Cancellation reason of basic tailgate setting-third last reason,Unknown (0),
IDE09494-MAS09005,Cancellation reason of basic tailgate setting-fourth last reason,Unknown (0),
IDE09494-MAS09006,Cancellation reason of basic tailgate setting-fifth last reason,Unknown (0),
IDE09495,Status of tailgate initialization,initialized,
IDE09496-MAS09002,Reason for loss of tailgate initialization-Last reason,Reset,
IDE09496-MAS09003,Reason for loss of tailgate initialization-second last reasons,Supply voltage error,
IDE09496-MAS09004,Reason for loss of tailgate initialization-third last reason,Reset,
IDE09496-MAS09005,Reason for loss of tailgate initialization-fourth last reason,Supply voltage error,
IDE09496-MAS09006,Reason for loss of tailgate initialization-fifth last reason,Reset,
IDE09498-MAS01871,Status of control points-Rear lid lock button in luggage compartment,Not operated,
IDE09498-MAS01872,Status of control points-Rear lid remote control lock switch,Not operated,
IDE09498-MAS06265,Status of control points-Release button in rear lid handle,Not operated,
IDE09498-MAS06446,Status of control points-Remote radio control: button for luggage compartment unlocking,Not operated,
IDE09498-MAS09010,Status of control points-Sensor for rear lid opening,Not operated,
IDE09498-MAS09072,Status of control points-Locking mechanism button in the rear lid,Malfunction,
IDE09498-MAS13753,Status of control points-Button 2 for rear lid remote release,Malfunction,
IDE09498-MAS27006,Status of control points-Actuations for the rear lid opener in the virtual remote control vehicle key,Not operated,
IDE09499-IDE01991,Motors for tailgate: activation-Motor 1 for tailgate: status,OFF,
IDE09499-IDE02012,Motors for tailgate: activation-Motor 2 for tailgate: status,OFF,
IDE09499-MAS09001,Motors for tailgate: activation-Closing Assist Motor,OFF,
IDE09499-MAS11205,Motors for tailgate: activation-Luggage compartment cover motor,not installed,
IDE09500-MAS09012,Motors for tailgate: RPM-Rear lid motor 1,0.00, Hz
IDE09500-MAS09013,Motors for tailgate: RPM-Rear lid motor 2,0.00, Hz
IDE09500-MAS11205,Motors for tailgate: RPM-Luggage compartment cover motor,0.00, Hz
IDE09501-MAS09001,Motors for tailgate: elec. current-Closing Assist Motor,0.00, A
IDE09501-MAS09012,Motors for tailgate: elec. current-Rear lid motor 1,0.00, A
IDE09501-MAS09013,Motors for tailgate: elec. current-Rear lid motor 2,0.00, A
IDE09501-MAS11205,Motors for tailgate: elec. current-Luggage compartment cover motor,0.00, A
IDE09502-IDE02097,Tailgate angle sensor: absolute value-Position Sensor 1,0,
IDE09502-IDE02098,Tailgate angle sensor: absolute value-Position sensor 2,0,
IDE09502-IDE10697,Tailgate angle sensor: absolute value-Luggage compartment cover: position,0,
IDE09503-IDE02017,Tailgate angle sensor: relative value-Rear lid position: relative,0, %
IDE09503-MAS11205,Tailgate angle sensor: relative value-Luggage compartment cover motor,0, %
IDE09504,Status of clutch test,not active,
IDE09505-IDE02078,Tailgate actuation counter-Activations of rear lid closing button,58,
IDE09505-IDE02079,Tailgate actuation counter-Activations of rear lid unlocking button,53,
IDE09505-IDE02080,Tailgate actuation counter-Activations of rear lid remote unlocking switch,3,
IDE09505-IDE02081,Tailgate actuation counter-Activation of remote key button rid lid opening,10,
IDE09505-IDE02082,Tailgate actuation counter-Opening cycle counter,58,
IDE09505-IDE02083,Tailgate actuation counter-Closing cycle counter,44,
IDE09505-IDE02084,Tailgate actuation counter-Counter obstruction detected,5,
IDE09505-IDE02085,Tailgate actuation counter-Counter of selectable opening stop adapted,0,
IDE09505-IDE02087,Tailgate actuation counter-Counter for function limitation due to insufficient voltage,0,
IDE09505-IDE02088,Tailgate actuation counter-Counter for function limitation due to excessive voltage,0,
IDE09505-IDE02090,Tailgate actuation counter-Counter for function limitation due to excessive temperature,0,
IDE09505-IDE02174,Tailgate actuation counter-Counter of flap opening angle basic settings,2,
IDE09505-IDE03774,Tailgate actuation counter-Counter for closing operations canceled by lock-up,0,
IDE09505-MAS08873,Tailgate actuation counter-Resets to hardware watchdog,0,
IDE09505-MAS08874,Tailgate actuation counter-Resets due to software watchdog,1,
IDE09505-MAS09017,Tailgate actuation counter-Counter tailgate lock: implausible,0,
IDE09505-MAS09018,Tailgate actuation counter-Counter pull-shut asst. implausible,0,
IDE09505-MAS09019,Tailgate actuation counter-Play protection counter active,0,
IDE09505-MAS09058,Tailgate actuation counter-Counter Hall sensor in motor 1 for tailgate implausible,0,
IDE09505-MAS09059,Tailgate actuation counter-Counter Hall sensor in motor 2 for tailgate implausible,0,
IDE09505-MAS09060,Tailgate actuation counter-Wake-up events button for closing rear lid in lugg.compartment,2,
IDE09505-MAS09061,Tailgate actuation counter-Wake-up events Hall sensor in motor for tailgate,0,
IDE09505-MAS09062,Tailgate actuation counter-Wake-up events in data bus,438,
IDE09505-MAS09076,Tailgate actuation counter-Activating tailgate button for locking,0,
IDE09505-MAS09077,Tailgate actuation counter-Activating sensor for tailgate opening,0,
IDE09505-MAS09078,Tailgate actuation counter-Wake-up events button for unlocking tailgate,0,
IDE09505-MAS09482,Tailgate actuation counter-Current limitation active,0,
IDE09505-MAS10783,Tailgate actuation counter-Closing assist.counter: aborted by operating unit,1,
IDE09505-MAS11977,Tailgate actuation counter-Emergency running counter after terminal 30 reset,24,
IDE09505-MAS11978,Tailgate actuation counter-Play protection counter for closing aid active,0,
IDE09505-MAS12517,Tailgate actuation counter-Reset via timeout monitoring watchdog,0,
IDE09505-MAS12518,Tailgate actuation counter-Reset via network management monitoring watchdog,0,
IDE09505-MAS13753,Tailgate actuation counter-Button 2 for rear lid remote release,0,
IDE09505-MAS27006,Tailgate actuation counter-Actuations for the rear lid opener in the virtual remote control vehicle key,0,
IDE09506,Rear lid anti-play protection,not active,
IDE09519-MAS09054,Status of hall sensor in motor for tailgate-Motor 1 for tailgate: Hall sensor voltage supply,On,
IDE09519-MAS09055,Status of hall sensor in motor for tailgate-Motor 2 for tailgate: Hall sensor voltage supply,On,
IDE09519-MAS09066,Status of hall sensor in motor for tailgate-Motor 1: Sensor 1,00000001 ,
IDE09519-MAS09067,Status of hall sensor in motor for tailgate-Motor 1: Sensor 2,00000001 ,
IDE09519-MAS09068,Status of hall sensor in motor for tailgate-Motor 2: Sensor 1,00000001 ,
IDE09519-MAS09069,Status of hall sensor in motor for tailgate-Motor 2: Sensor 2,00000001 ,
IDE09519-MAS11207,Status of hall sensor in motor for tailgate-Motor for luggage comp. cover: sensor 1,00000000 ,
IDE09519-MAS11209,Status of hall sensor in motor for tailgate-Motor for luggage compartment cover: Hall sensor voltage supply,OFF,
IDE10697-MAS01471,Luggage compartment cover: position-lower stop,0,
IDE10697-MAS01472,Luggage compartment cover: position-upper stop,-8960,
IDE10697-MAS02282,Luggage compartment cover: position-Position,53,
IDE10698-IDE03774,Luggage compartment cover: counter-Counter for closing operations canceled by lock-up,0,
IDE10698-MAS09020,Luggage compartment cover: counter-Down adjustment,0,
IDE10698-MAS09021,Luggage compartment cover: counter-Up adjustment,0,
IDE10698-MAS09023,Luggage compartment cover: counter-Total number of adjustments,0,
IDE10698-MAS09024,Luggage compartment cover: counter-Shutdowns by excess force limiter,0,
IDE10698-MAS09025,Luggage compartment cover: counter-Blocking bottom mechan. stop,0,
IDE10698-MAS09026,Luggage compartment cover: counter-Blocking upper mechan. stop,0,
IDE10698-MAS09027,Luggage compartment cover: counter-Re-initializationn in bottom mechan. stop,0,
IDE10698-MAS09028,Luggage compartment cover: counter-Re-initialization in upper mechan. stop,0,
IDE10698-MAS09029,Luggage compartment cover: counter-Number of re-initializations,0,
IDE10699-MAS00342,Status of luggage compartment cover initialization-Initialization,not initialized,
IDE10700-MAS09002,Reason for loss of luggage compartment cover initialization-Last reason,Not yet initialized,
IDE10700-MAS09003,Reason for loss of luggage compartment cover initialization-second last reasons,Not yet initialized,
IDE10700-MAS09004,Reason for loss of luggage compartment cover initialization-third last reason,Not yet initialized,
IDE10700-MAS09005,Reason for loss of luggage compartment cover initialization-fourth last reason,Not yet initialized,
IDE10700-MAS09006,Reason for loss of luggage compartment cover initialization-fifth last reason,Not yet initialized,
IDE10804,Easing of rear lid,not active,
IDE11033,Motor for luggage compart. cover: excess. temp: protection,active,
IDE11036,Pull-shut asst.: play protec.,not active,
IDE11868,Indicator lamp for delayed closing,not installed,
IDE13157,Partial network operation counter not available,0,
MAS00972,Decoration variant,2,
Elapsed Time: 00:06
Jef
HQ
blockmap-75-14A-035-285-A_WVGAWVEB7SH010695-20241230-1137.CSV
;SW:14A-035-285-A   HW:14A-035-285 ---  Telematics
;Component:OCU4MEB_UNECE H11 0554, Coding:06020700010000000000010013000000101112111012000010
;EV_OCUGen4UNECE,001050,EV_OCUGen4UNECE_VWE3.rod
;Monday,30,December,2024,11:37:28:18177
;VCID: 1E620483E033A5EA61E-804A-R SFD
IDE00019,Voltage terminal 30,14.6, V
IDE00020,Terminal 15 status,On,
IDE00102,Control Module temperature,32, °C
IDE00608,Fuel type,Battery / electric,
IDE00672,Roadside Assistance Button,Not available,
IDE00673,Information Service Button -E450-,Not available,
IDE01215-ENG391557,Dimmer terminal 58d-dimmimg terminal 58d mux1,100.44, %
IDE01216,Dimmer terminal 58s,100, %
IDE01588,Driving direction,256, °
IDE01588-MAS01632,Driving direction-Status,available.,
IDE01625,Muting of radio/radio navigation system via control wire,not active,
IDE01630-MAS01167,Key illumination in telephone operating unit-Actuation time,0 s,
IDE01630-ENG170421,Key illumination in telephone operating unit-IoReached Status,Output diagnostic test not active,
IDE01631-MAS01167,Output of variable test tones via radio/radio navigation system-Actuation time,0 s,
IDE01631-ENG170421,Output of variable test tones via radio/radio navigation system-IoReached Status,Output diagnostic test not active,
IDE01712-IDE06673,GPS Position-Initialization status,initialized,
IDE01712-MAS01779,GPS Position-Length,84°6'40.5"W,
IDE01712-MAS01780,GPS Position-Width,35°54'20.7"N,
IDE01712-MAS02230,GPS Position-Height,284, m
IDE01713-MAS01632,Status GPS reception-Status,GPS data is being received: position completely determined,
IDE01713-MAS01785,Status GPS reception-Number of visible satellites,12,
IDE01713-MAS01786,Status GPS reception-Number of tracked satellites,12,
IDE01718,Crash signal,No crash recognized,
IDE01770-MAS01632,Status of GPS antenna-Status,OK,
IDE01770-MAS01808,Status of GPS antenna-Antenna current,25, mA
IDE01971,Lowest recorded control module temperature,-4, °C
IDE01972,Highest recorded control module temperature,44, °C
IDE02067-IDE00690,Antenna for telephone status-Connection to antenna,electrically OK,
IDE02067-MAS01808,Antenna for telephone status-Antenna current,38, µA
IDE02067-MAS03991,Antenna for telephone status-Reception level antenna 1,100, %
IDE02326-ENG117459,GPS signal strength-ID_GPS_satellite_no_1,3,
IDE02326-ENG117461,GPS signal strength-ID_GPS_satellite_no_2,4,
IDE02326-ENG117463,GPS signal strength-ID_GPS_satellite_no_3,8,
IDE02326-ENG117465,GPS signal strength-ID_GPS_satellite_no_4,9,
IDE02326-ENG117460,GPS signal strength-S/N_GPS_satellite_no_1,50, dBµV
IDE02326-ENG117462,GPS signal strength-S/N_GPS_satellite_no_2,47, dBµV
IDE02326-ENG117464,GPS signal strength-S/N_GPS_satellite_no_3,41, dBµV
IDE02326-ENG117466,GPS signal strength-S/N_GPS_satellite_no_4,48, dBµV
IDE03477-MAS00106,GPS time-Year,2024,
IDE03477-MAS00107,GPS time-Month,12,
IDE03477-MAS00108,GPS time-Day,30,
IDE03477-MAS00109,GPS time-Hours,16,
IDE03477-MAS00110,GPS time-Minutes,37,
IDE03477-MAS00111,GPS time-Seconds,27,
IDE03477-MAS01632,GPS time-Status,valid,
IDE04293,Operating state for emer call module,registerstate_not_searching,
IDE04750-MAS03876,SIM card-active SIM card,internal,
IDE04750-MAS03878,SIM card-SIM IMSI,311480935766104,
IDE04750-MAS04226,SIM card-Telephone number,15224597952    ,
IDE04750-MAS08401,SIM card-SIM intern,operational,
IDE04750-MAS08402,SIM card-SIM extern,Unknown,
IDE04750-MAS11003,SIM card-ICCID,89148000010410767420,
IDE04750-MAS11004,SIM card-UICCID,89033023312150000000036984684877,
IDE04790,Call for help button,Not operated,
IDE05430,Telephone serial number,353804420342824,
IDE07589-IDE07590,Update programming: status-Currently processed module,27,
IDE07589-IDE07591,Update programming: status-Number of modules to be programmed,28,
IDE07589-MAS00106,Update programming: status-Year,2024,
IDE07589-MAS00107,Update programming: status-Month,3,
IDE07589-MAS00108,Update programming: status-Day,20,
IDE07589-MAS00109,Update programming: status-Hours,9,
IDE07589-MAS00110,Update programming: status-Minutes,29,
IDE07589-MAS00111,Update programming: status-Seconds,45,
IDE07911-MAS01167,Microphone signal via audio output-Actuation time,0 s,
IDE07911-ENG170421,Microphone signal via audio output-IoReached Status,Output diagnostic test not active,
IDE08235-MAS06798,Status of immobilizer participant-Key / terminal status,04,
IDE08235-MAS06799,Status of immobilizer participant-Immobiliser status,00,
IDE08235-MAS06800,Status of immobilizer participant-Status MSG 1,00,
IDE08235-MAS06801,Status of immobilizer participant-Status MSG 2,00,
IDE08235-MAS06802,Status of immobilizer participant-Status MSG 3,00,
IDE08235-MAS06803,Status of immobilizer participant-Status MSG 4,00,
IDE08235-MAS06804,Status of immobilizer participant-Status TCM,00,
IDE08235-MAS06805,Status of immobilizer participant-Status ESCL,00,
IDE08235-MAS06806,Status of immobilizer participant-Status OCU,00,
IDE08235-MAS06807,Status of immobilizer participant-Status VTS,00,
IDE08236-MAS06808,Status locking periods immobilizer-Lock time download,00,
IDE08236-MAS06809,Status locking periods immobilizer-Reset lock time passwords,00,
IDE08236-MAS06810,Status locking periods immobilizer-Lock time login terminal 15 on,00,
IDE08236-MAS06811,Status locking periods immobilizer-Lock time login learn keys,00,
IDE08236-MAS06812,Status locking periods immobilizer-Lock time login leave learn keys,00,
IDE08236-MAS06813,Status locking periods immobilizer-Lock time login special functions,00,
IDE08237-MAS06814,Status Secure Hardware Extension-SHE counter,00 00 01 01,
IDE08237-MAS06815,Status Secure Hardware Extension-SHE key number,6, s
IDE08251-MAS06847,Configuration immobilizer-Snapshot,53 00 00 00 00 00 00 00 05 E8 00 00 00 00 00 10 03 00 3C,
IDE08343,Immobilizer Challenge,FE B2 E8 3B,
IDE09293-IDE00690,Status of antenna 2 for phone-Connection to antenna,electrically OK,
IDE09293-MAS01808,Status of antenna 2 for phone-Antenna current,38, µA
IDE09293-MAS03991,Status of antenna 2 for phone-Reception level antenna 1,100, %
IDE10300,OBD Driving Cycle detected,not active,
IDE10780,Ethernet counter connection interruptions,2,
IDE10781,Ethernet counter checksum malfunction,00,
IDE11282-IDE00704,Battery for emergency call module-State of Charge (SOC),88,
IDE11282-MAS00362,Battery for emergency call module-Battery voltage,7887,
IDE11282-MAS02201,Battery for emergency call module-Temperature,17, °C
IDE11282-MAS02476,Battery for emergency call module-installed,installed,
IDE11282-MAS02476,Battery for emergency call module-installed,was not charged,
IDE11282-MAS08415,Battery for emergency call module-Battery status,Battery OK,
IDE11307-IDE01839,eCall battery status-Battery charge level,88, %
IDE11307-MAS08415,eCall battery status-Battery status,normal,
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 67|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 01 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 05 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 04 00 00|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 03|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 16|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 0D|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 00|FF 02 00 00 00 00 00 00 00 00 00 01 FF 00 00 67|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|4|,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|30 0E B8 DA 35 44|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|02 7D FA 01 07 00,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 01 07,4|44 20 63 0B 99 4E,FD 53 7C B8 03 83 00 04 00 00 00 00 00 04 00 10,4|02 7D FA 00 10 02,FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 FC 10,4|,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 08,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 73,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 00 14,Test not yet carried out|FD 53 7C B8 03 83 00 03 00 00 00 00 00 00 01 06,Test not yet carried out|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 01 07,Test not yet carried out|FD 53 7C B8 03 83 00 04 00 00 00 00 00 00 00 10,Test not yet carried out|FD 53 7C B8 03 83 00 0B 00 00 00 00 00 00 00 BA,Test not yet carried out|,
IDE12625,IP network: current link deceleration: branch 1,5872, µs
IDE12633,IP Network maximum correction of the synchronized clock,-7715, ns
IDE12732,Button for ERA/Glonass test,Not available,
IDE13159-MAS01167,Loudspeaker test for emergency call module-Actuation time,0 s,
IDE13159-ENG170421,Loudspeaker test for emergency call module-IoReached Status,Output diagnostic test not active,
IDE13593-MAS07135,Emergency call SIM profile-Activation status,not activated,
IDE13593-MAS07967,Emergency call SIM profile-profile,Not available,
IDE13593-MAS11003,Emergency call SIM profile-ICCID,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,21,
IDE13845-ENG255234,Production mode status-Status_productionmode,No_function_controlled,
IDE13957-MAS00106,Mobile Online Service: connection status-Year,2000, yr
IDE13957-MAS00107,Mobile Online Service: connection status-Month,1, Months
IDE13957-MAS00108,Mobile Online Service: connection status-Day,1, d
IDE13957-MAS00109,Mobile Online Service: connection status-Hours,0, H
IDE13957-MAS00110,Mobile Online Service: connection status-Minutes,1, min
IDE13957-MAS00111,Mobile Online Service: connection status-Seconds,18, s
IDE13957-MAS00976,Mobile Online Service: connection status-Counter,0,
IDE13957-MAS07131,Mobile Online Service: connection status-ID steps,0,
IDE13957-MAS07132,Mobile Online Service: connection status-Code status,30,
IDE13957-MAS16770,Mobile Online Service: connection status-Year (UTC: universal time coordinated),2024, yr
IDE13957-MAS16772,Mobile Online Service: connection status-Month (UTC: universal time coordinated),12, Months
IDE13957-MAS16773,Mobile Online Service: connection status-Day (UTC: universal time coordinated),10, d
IDE13957-MAS16774,Mobile Online Service: connection status-Hour (UTC: universal time coordinated),17, H
IDE13957-MAS16775,Mobile Online Service: connection status-Minute (UTC: universal time coordinated),39, min
IDE13957-MAS16776,Mobile Online Service: connection status-Seconds (UTC: universal time coordinated),53, s
IDE13957-ENG151979,Mobile Online Service: connection status-Server_HTTP_Status_Code_Textual,Data connection established,
IDE13958-MAS00106,Mobile Online Service: service status-Year,2255, yr
IDE13958-MAS00107,Mobile Online Service: service status-Month,255, Months
IDE13958-MAS00108,Mobile Online Service: service status-Day,255, d
IDE13958-MAS00109,Mobile Online Service: service status-Hours,255, H
IDE13958-MAS00110,Mobile Online Service: service status-Minutes,255, min
IDE13958-MAS00111,Mobile Online Service: service status-Seconds,255, s
IDE13958-MAS07134,Mobile Online Service: service status-ID services,cc_breakdown_v2,
IDE13958-MAS07135,Mobile Online Service: service status-Activation status,Not available,
IDE13958-MAS07136,Mobile Online Service: service status-Exp. year,2000, yr
IDE13958-MAS07137,Mobile Online Service: service status-Exp. month,1, Months
IDE13958-MAS07138,Mobile Online Service: service status-Exp. day,1, d
IDE13958-MAS16770,Mobile Online Service: service status-Year (UTC: universal time coordinated),2255, yr
IDE13958-MAS16772,Mobile Online Service: service status-Month (UTC: universal time coordinated),255, Months
IDE13958-MAS16773,Mobile Online Service: service status-Day (UTC: universal time coordinated),255, d
IDE13958-MAS16774,Mobile Online Service: service status-Hour (UTC: universal time coordinated),255, H
IDE13958-MAS16775,Mobile Online Service: service status-Minute (UTC: universal time coordinated),255, min
IDE13958-MAS16776,Mobile Online Service: service status-Seconds (UTC: universal time coordinated),255, s
IDE13958-ENG246084,Mobile Online Service: service status-status_last_fail,65535,
IDE13958-ENG246255,Mobile Online Service: service status-status_last_ok,65535,
IDE13958-ENG246120,Mobile Online Service: service status-status_second_last_fail,65535,
IDE13958-ENG246279,Mobile Online Service: service status-status_second_last_ok,65535,
IDE14344-MAS18506,Automotive audio bus (A2B): status-Node name,Microphone module in roof,
IDE14344-MAS18507,Automotive audio bus (A2B): status-Node number,0,
IDE14344-MAS18509,Automotive audio bus (A2B): status-Node status,electrically OK,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3D 5C A0 C2 C8 4E D1,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,12,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 03,
IDE14878,IP network: counter - rejected ethernet frames: layer 2,65535,
IDE14879,IP network: counter - rejected IPv6 packets: layer 3,0,
IDE14880,IP network: counter - rejected UDP/TCP packets: layer 4,0,
MAS00077-MAS02345,Immobilizer-Current condition,02,
MAS00077-MAS06790,Immobilizer-Identity counter,01,
MAS00077-MAS06791,Immobilizer-Mark detection,03,
MAS00077-MAS06792,Immobilizer-P class,E8,
MAS00077-MAS06793,Immobilizer-Number of adapted keys,00,
MAS00077-MAS06794,Immobilizer-Number of keys to be adapted via service download,00,
MAS00077-MAS06795,Immobilizer-Number of keys to be adapted adapt service keys,00,
MAS00077-MAS06796,Immobilizer-Remaining time to switch on terminal 15,00,
MAS00077-MAS06797,Immobilizer-Status configuration,04,
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,30,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,37,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,42,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,10,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,464, km
MAS01490-IDE08800,Energy management-Battery capacity - current value,100, %
MAS01490-IDE16437,Energy management-Filling,00 00,
MAS01490-MAS08405,Energy management-Wake up cycles counter,283,
MAS01490-MAS27080,Energy management-High-voltage battery accepted,not transmitted,
MAS01490-ENG319453,Energy management-energy_release_12V_or_HV,12V battery,
MAS03615-MAS01167,Connection setup-Actuation time,0 s,
MAS03615-ENG170421,Connection setup-IoReached Status,Output diagnostic test not active,
MAS04394-IDE03580,Connection status-Country recognition for mobile network,311,
MAS04394-IDE07699,Connection status-Mobile network operator,480,
MAS04394-MAS03991,Connection status-Reception level antenna 1,100, %
MAS04394-MAS04460,Connection status-Validity,invalid,
MAS04394-MAS08406,Connection status-Network type,LTE,
MAS04394-MAS08407,Connection status-Data connection,active,
MAS04394-ENG123307,Connection status-Radio_Cell_Number,118528790,
MAS04394-ENG123308,Connection status-TCP_Connection_State,active,
MAS08178-IDE05253,Crash information-Front crash,No,
MAS08178-IDE05254,Crash information-Side crash on driver side,No,
MAS08178-IDE05255,Crash information-Side crash on frt.pass.side,No,
MAS08178-IDE05256,Crash information-Rear crash,No,
MAS08178-IDE05257,Crash information-Rollover crash,No,
MAS08178-MAS08636,Crash information-Automatic emergency call activated:Accident sensor,No,
MAS08200,Emergency call speaker status,electrically OK,
MAS10430,Indicator light for emerg. call,Emergency call function available,
MAS13076-MAS12732,Error valid: error path traversed-Dataset download,full working order,
MAS13076,Error valid: error path traversed,Active diagnosis,
MAS16678-MAS01167,Test mode for emergency call-Actuation time,0 s,
MAS16678-ENG170421,Test mode for emergency call-IoReached Status,Output diagnostic test not active,
MAS18157-MAS18158,SFD activated status-Role of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18161,SFD activated status-Status of vehicle diagnostic to be protected,SFD individualization feature set,
MAS18157-MAS18164,SFD activated status-Duration of vehicle diagnostic to be protected,No activation active,
MAS18157-MAS18165,SFD activated status-Type of vehicle diagnostic to be protected,No activation active,
MAS18799-MAS01167,Radio / radio navigation system muting test-Actuation time,0 s,
MAS18799-ENG170421,Radio / radio navigation system muting test-IoReached Status,Output diagnostic test not active,
MAS18800,Version of audio dataset used,U140,
MAS20396,SFD protection procedure,SFD access protection and SFD end-to-end protection,
MAS21340-ENG391363,PWM signal: duty cycle-pwm_duty_cycle_factor_terminal_xtxs,100, %
MAS24962,Partition synchronization,Synchronized,
ENG123206,Antenna_Switch,LTE antenna 1,
ENG186123-ENG187319,Authentic_time_last_client_response-Counter_kl15_since_last_sync,0,
ENG186123-ENG187669,Authentic_time_last_client_response-Current_time_used,2024-12-30T16:37:40Z,
ENG186123-ENG186739,Authentic_time_last_client_response-Last_valid_timestamp_from_Backend,2024-12-30T16:18:44Z,
ENG254564-ENG255490,Backup_Battery_SoH-BUB_ci,79.550,
ENG254564-ENG256057,Backup_Battery_SoH-mcharge_time,0, s
ENG254564-ENG256085,Backup_Battery_SoH-mSoH,100,
ENG254564-ENG256302,Backup_Battery_SoH-rSoH,99,
ENG123205,Incoming_call_line_state,Idle,
ENG117422,IP_Address,100.119.111.245,
ENG123203-ENG123321,Network_Statistics-CRC_Errors,11569,
ENG123203-ENG123320,Network_Statistics-DNS_Resolution,12852,
ENG123203-ENG123324,Network_Statistics-DNS_Resolution_Error,No malfunction,
ENG123203-ENG124655,Network_Statistics-Duration_Of_Voice_Calls,4278211072, min
ENG123203-ENG123319,Network_Statistics-Established_TCP_Connections,12848,
ENG123203-ENG123326,Network_Statistics-HTTP_Transmission_Error,Malfunction,
ENG123203-ENG123317,Network_Statistics-Interrupted_TCP_Connections,14900,
ENG123203-ENG123323,Network_Statistics-Network_Timeout_Error,Malfunction,
ENG123203-ENG123315,Network_Statistics-Number_Of_Events,12852,
ENG123203-ENG123330,Network_Statistics-Number_Of_Failed_DNS_Requests,12598,
ENG123203-ENG123332,Network_Statistics-Number_Of_Failed_HTTP_Requests,14138,
ENG123203-ENG123331,Network_Statistics-Number_Of_Failed_PDP_Connections,14899,
ENG123203-ENG123333,Network_Statistics-Number_Of_Failed_Secure_Connections,13360,
ENG123203-ENG123328,Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections,11571,
ENG123203-ENG123314,Network_Statistics-Number_Of_Jobs,12590,
ENG123203-ENG123329,Network_Statistics-Number_Of_Network_Timeouts,12372,
ENG123203-ENG123316,Network_Statistics-Number_Of_Packet_Data_Connection_Failures,13624,
ENG123203-ENG123311,Network_Statistics-Number_Of_Voice_Calls,12592,
ENG123203-ENG123325,Network_Statistics-PDP_Connection_Error,No malfunction,
ENG123203-ENG123318,Network_Statistics-Rejected_TCP_Connections,13402,
ENG123203-ENG123334,Network_Statistics-Round_Trip_Time,23040, ms
ENG123203-ENG123327,Network_Statistics-Secure_Connection_Error,Malfunction,
ENG123203-ENG123313,Network_Statistics-Service_Data_Volume,959328561, B
ENG123203-ENG123335,Network_Statistics-SMS_Counter,255,
ENG123203-ENG123312,Network_Statistics-Total_Data_Volume,808333617, B
ENG123203-ENG123322,Network_Statistics-Transport_Protocol_Connection_Error,No malfunction,
ENG245690,OCU_Internal_Status_Field,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG123204,Outgoing_call_line_state,Idle,
ENG247809,Position_Confidence,37, m
ENG377979-ENG391842,Pwm_duty_cycle_factor_terminal_58d-pwm_duty_cycle_value_Green,100, %
ENG377979-ENG391106,Pwm_duty_cycle_factor_terminal_58d-pwm_duty_cycle_value_Red,0, %
ENG247812-ENG159329,Second_Last_Position-Latitude, 35°54'20.3"N,
ENG247812-ENG159328,Second_Last_Position-Longitude, 84° 6'40.3"W ,
ENG247822-ENG159329,Third_Last_Position-Latitude, 35°54'21.0"N,
ENG247822-ENG159328,Third_Last_Position-Longitude, 84° 6'38.4"W ,
Elapsed Time: 00:22
blockmap-8C-0Z1-915-184-AE_WVGAWVEB7SH010695-20241230-1138.CSV
;SW:0Z1-915-184-AE   HW:0Z1-915-184-D ---  HV Battery
;Component:J840 K8C  BMC 010 1141, Coding:
;EV_BMCeVWBSMEB,003018,EV_BMCeVWBSMEB_003_VWE3.rod
;Monday,30,December,2024,11:38:13:18177
;VCID: 7DA0230F0D751EF2184-8028-R
IDE00010,Serial number,00000004092402040428,
IDE00019,Voltage terminal 30,14.312, V
IDE00021,Engine RPM,0, /min
IDE00056,History data 1,12,
IDE00056,History data 1,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 6F 4C|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 07 D6 4B|00 0A AB 19|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 87|00 22 23 D6|00 04 3C B0|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 03 96|00 15 41 51|00 00 EB D7|00 00 09 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 0E F5 1F|00 00 39 B0|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 04 F1 A0|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00056,History data 1,0,
IDE00057,History data 2,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 02|00 00 00 05|00 00 00 0A|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 07 E1|00 00 0B 29|00 00 93 28|00 00 73 14|00 00 12 C8|00 00 00 00|00 00 00 00|00 00 00 00|00 00 04 24|00 00 06 B6|00 00 45 59|00 00 24 A5|00 00 0A F2|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00057,History data 2,0,
IDE00058,History data 3,8,
IDE00058,History data 3,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 26|00 00 00 2D|00 00 00 3F|00 00 00 27|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 6F 3B|00 00 9A 92|00 00 B4 54|00 03 64 E5|00 00 6B E4|00 00 3D C9|00 00 00 8A|00 00 00 00|00 00 3C 3F|00 00 24 C8|00 00 43 A5|00 01 3F 69|00 00 23 76|00 00 11 FE|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00058,History data 3,0,
IDE00059,History data 4,8,
IDE00059,History data 4,64,
IDE00059,History data 4,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 53 53|00 00 0E 0D|00 02 E6 7F|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 34 CB|00 01 8D D6|00 02 4C DA|00 00 00 03|00 00 00 00|00 00 0A CD|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00060,History data 5,||00 00 00 00|00 00 C1 0B|00 00 98 D7|00 00 BA 6A|00 00 09 88|00 00 00 00|,
IDE00060,History data 5,0,
IDE00061,History data 6,2,
IDE00061,History data 6,10,
IDE00061,History data 6,||00 00 05 4A|00 00 00 0F|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 03 53|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00061,History data 6,0,
IDE00062,History data 7,6,
IDE00062,History data 7,21,
IDE00062,History data 7,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 03|00 00|00 00|00 00|00 01|00 04|00 01|00 00|00 02|00 00|00 00|00 00|00 00|00 00|,
IDE00063,History data 8,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 01|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00063,History data 8,0,
IDE00064,History data 9,||00 01 D6 64|00 02 5B 48|00 02 25 D8|00 02 58 78|00 02 58 78|00 02 58 78|00 02 43 60|00 02 43 60|00 02 12 DC|00 02 12 DC|00 02 1E 58|00 02 3F 28|00 01 E2 94|00 02 1F FC|00 01 98 84|00 02 57 10|00 01 82 04|00 01 78 2C|00 01 A3 10|00 00 FD 20|00 01 BC 60|00 01 19 7C|00 01 42 F8|00 01 9B 18|00 01 88 58|00 02 02 38|00 01 B8 DC|00 01 B9 CC|00 01 CD 7C|00 02 1F 48|00 01 DF 4C|00 01 C3 A4|00 02 1D 68|00 02 51 70|00 01 E1 68|00 02 2F EC|00 01 43 E8|00 01 E2 94|00 01 E4 74|00 02 34 D8|00 01 E6 90|00 02 46 E4|00 01 E0 78|00 02 41 F8|00 01 BE 40|00 01 D3 D0|00 02 10 48|00 01 CA E8|00 01 AE 14|00 01 E6 CC|00 01 8B 64|00 01 E6 CC|00 01 E4 74|00 01 9E 60|00 01 EE 4C|00 02 1B C4|00 01 E6 CC|00 02 51 34|00 01 F8 24|00 02 26 50|00 02 51 34|00 02 23 F8|00 02 4B 58|00 02 4C 48|00 01 26 D8|00 01 B0 E4|00 01 3F 74|00 00 00 00|00 00 00 00|00 00 00 00|00 00 A5 3C|00 01 C1 88|00 01 54 14|00 01 CB 60|00 01 F2 FC|00 01 F6 08|00 01 FD 4C|00 01 B0 30|00 01 A3 10|00 01 A4 B4|00 02 01 84|00 01 48 20|00 01 9B 54|00 01 CE 6C|00 01 D8 BC|00 01 FE 78|00 01 CE A8|00 01 9A 64|00 02 2D D0|00 01 C6 EC|00 01 CE 30|00 02 5B FC|00 01 6D 64|00 02 2F B0|00 01 E6 90|00 02 29 5C|00 01 EE 4C|00 02 5B FC|00 02 1D 68|00 02 33 E8|00 02 41 F8|00 02 47 98|00 01 EA 50|00 02 0D 78|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00064,History data 9,0,
IDE00065,History data 10,||00 04 C2 6A|00 00 00 06|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE00065,History data 10,0,
IDE00066,History data 11,16,
IDE00066,History data 11,8,
IDE00066,History data 11,2,
IDE00066,History data 11,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00067,History data 12,8,
IDE00067,History data 12,2,
IDE00067,History data 12,16,
IDE00067,History data 12,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00068,History data 13,8,
IDE00068,History data 13,||00 00 01 6C|00 00 00 01|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 01|,
IDE00069,History data 14,108,
IDE00069,History data 14,5D C0,
IDE00069,History data 14,||2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|2E E0|00 00|00 00|00 00|00 00|,
IDE00070,History data 15,||00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|00 00|,
IDE00070,History data 15,0,
IDE00071,History data 16,7B,
IDE00071,History data 16,63,
IDE00071,History data 16,00 00,
IDE00071,History data 16,1,
IDE00071,History data 16,00 5E,
IDE00071,History data 16,00 DE,
IDE00961-MAS05695,Malfunction Indicator Lamp-Start request,not active,
IDE01021,Current of H-V / hybrid battery,11, °C
IDE01021,Current of H-V / hybrid battery,-4.390, A
IDE01028-MAS01422,Coolant temperature of H-V / hybrid battery-Intake,10.500, °C
IDE01028-MAS01423,Coolant temperature of H-V / hybrid battery-Exhaust,11.000, °C
IDE01036-MAS01375,High voltage / Hybrid Battery history data 1-Counter for amp hour charge,593.445, Ah
IDE01036-MAS01376,High voltage / Hybrid Battery history data 1-Counter for amp hour discharge,-518.268, Ah
IDE01036-MAS01377,High voltage / Hybrid Battery history data 1-Counter for kilowatt hour charge,231.707, kWh
IDE01036-MAS01378,High voltage / Hybrid Battery history data 1-Counter for kilowatt hour discharge,-196.129, kWh
IDE01718,Crash signal,not active,
IDE01803,History data 17,6,
IDE01803,History data 17,||00 B3|00 00|00 00|00 03|00 00|00 00|,
IDE01804,History data 18,||00 01 A3 46|00 00 A2 44|00 07 D8 92|00 02 F3 5F|00 07 54 AD|00 02 DB B0|00 00 0A D1|00 00 04 42|00 00 00 02|00 00 00 00|,
IDE01804,History data 18,0,
IDE01805,History data 19,7,
IDE01805,History data 19,||00 0A 61 C2|00 09 DF 8D|00 00 36 2B|00 00 31 C2|00 00 00 04|00 00 17 27|00 00 03 1D|,
IDE01806,History data 20,||00 97 40 37|00 90 26 DD|00 02 D6 09|00 02 E2 CA|00 00 00 66|00 01 26 53|00 00 39 CE|,
IDE01806,History data 20,0,
IDE01807,History data 21,00 00,
IDE01807,History data 21,00,
IDE01807,History data 21,FF,
IDE01808,History data 22,FF,
IDE01808,History data 22,C8,
IDE01809,History data 23,00,
IDE01809,History data 23,00 00,
IDE01809,History data 23,00 00 00 00,
IDE01810,History data 24,00 00,
IDE01810,History data 24,00,
IDE01810,History data 24,00 00 00 00,
IDE01811,History data 25,64,
IDE01811,History data 25,8,
IDE01811,History data 25,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 5E|00 00 00 01|00 00 00 01|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 21|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE01812,History data 26,8,
IDE01812,History data 26,64,
IDE01812,History data 26,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 01|00 00 00 00|00 00 00 00|00 00 00 03|00 00 00 00|00 00 0A CD|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE01813,History data 27,8,
IDE01813,History data 27,||00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 0A D1|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|00 00 00 00|,
IDE01813,History data 27,0,
IDE01814,History data 28,04,
IDE01814,History data 28,00 00 00 00,
IDE01814,History data 28,14,
IDE01814,History data 28,66,
IDE01814,History data 28,00,
IDE01814,History data 28,00 4F 1A 00,
IDE01814,History data 28,00 4F 11 B6,
IDE01814,History data 28,6A,
IDE01814,History data 28,05,
IDE01814,History data 28,00 00 00 12,
IDE01814,History data 28,50,
IDE01814,History data 28,69,
IDE01814,History data 28,62,
IDE01814,History data 28,65,
IDE01814,History data 28,73,
IDE01814,History data 28,6B,
IDE01814,History data 28,60,
IDE01814,History data 28,67,
IDE01814,History data 28,68,
IDE01814,History data 28,6C,
IDE01814,History data 28,64,
IDE01814,History data 28,6D,
IDE01814,History data 28,61,
IDE01814,History data 28,00 00 00 14,
IDE01814,History data 28,00 00 30 95,
IDE01814,History data 28,00 00 00 23,
IDE01838,Battery temperature,9.500, °C
IDE01839,Battery charge level,61.600, %
IDE01985-MAS06855,FAZIT identification test sum-Test sum,35 BE D0 A3,
IDE03410-MAS05695,Yellow warning lamp-Start request,not active,
IDE03411-MAS05695,Red warning lamp-Start request,not active,
IDE05416,H-V battery insulation measurement test voltage,500, V
IDE05417,Serial number of H-V / hybrid battery,288 VWHT49Q02ZQ,
IDE05545,Battery disconnect relay actuation,closed,
IDE05963,ASSY part number,1EB915914DJ ,
IDE06346,H-V battery voltage,399.000, V
IDE06404,Pilot line,not active,
IDE06673,Initialization status,not active,
IDE06805,Status of voltage freedom,High voltage power off not recognized,
IDE06948,High-volt. battery mode: spec. value,Driving mode,
IDE06973,Power reduction status,not active,
IDE07045-MAS01420,Dynamic limit for charge current-Limit for charge current,343.200, A
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,03,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,05,
IDE07145-MAS06785,Component protection properties-GFA key,Not Used,
IDE07145-MAS06789,Component protection properties-KSB Config Status 2,00,
IDE07227-IDE01024,Voltage in H-V system-Voltage of hybrid battery after protection,399.000, V
IDE08215,Current 2 of H-V / hybrid battery,-9.420, A
IDE08217-MAS01234,maximum voltage for battery cells-Index 1,3,
IDE08217-MAS02985,maximum voltage for battery cells-Value,3.838, V
IDE08218-MAS01234,minimum voltage for battery cells-Index 1,68,
IDE08218-MAS02985,minimum voltage for battery cells-Value,3.831, V
IDE08228,Positive voltage of high volt battery after load protection,0.000, V
IDE08230-MAS01421,Dynamic limit for discharge current-Limit for discharge current,900.000, A
IDE08343,Immobilizer Challenge,CF A9 4C 4B,
IDE09588-ENG106773,In use monitor performance ratio 1-General_Denominator,0,
IDE09588-ENG106916,In use monitor performance ratio 1-Ignition_Cycle_Counter,209,
IDE09588-ENG100120,In use monitor performance ratio 1-Milage,450, km
IDE09588-ENG128699,In use monitor performance ratio 1-Number_of_IUMPR_Records,5,
IDE09589-ENG128703,In use monitor performance ratio 2-Denominator_to_DFCC_ID2_2,0,
IDE09589-ENG128701,In use monitor performance ratio 2-DFCC_Value_to_Record_ID2_1,42039,
IDE09589-ENG128702,In use monitor performance ratio 2-Numerator_to_DFCC_ID2_2,209,
IDE09589-ENG128700,In use monitor performance ratio 2-Recordnumber_uneven,1,
IDE09590-ENG128707,In use monitor performance ratio 3-Denominator_to_DFCC_ID3_2,0,
IDE09590-ENG128705,In use monitor performance ratio 3-DFCC_value_of_record_ID_3_2,42050,
IDE09590-ENG128706,In use monitor performance ratio 3-Numerator_to_DFCC_ID3_2,209,
IDE09590-ENG128704,In use monitor performance ratio 3-Recordnumber_even,2,
IDE11799,Minimum discharge voltage,260, V
IDE11801,Maximum charging voltage,442, V
IDE14477,Traction battery: China serial number,ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ,
IDE15098-MAS00106,Time stamp of last DTC memory entry deletion trigger-Year,2000,
IDE15098-MAS00107,Time stamp of last DTC memory entry deletion trigger-Month,0,
IDE15098-MAS00108,Time stamp of last DTC memory entry deletion trigger-Day,0,
IDE16765-MAS22458,Counter for falling below the insulation thresholds-Counter for positive terminal threshold 1,0,
IDE16765-MAS22474,Counter for falling below the insulation thresholds-Counter for negative terminal threshold 1,0,
IDE16765-MAS22475,Counter for falling below the insulation thresholds-Counter for negative terminal threshold 2,0,
IDE16765-MAS22476,Counter for falling below the insulation thresholds-Counter for positive terminal threshold 2,0,
IDE20040,High-voltage battery usable percentage of certified energy capacity,100.000, %
IDE80252,History data 0,HDM070706****,
IDE80253,Voltage terminal 30C,14.028, V
MAS00464-MAS00110,Standard - ambient data 1-Minutes,38,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,53,
MAS01302,Protection of posit. terminal of high voltage / hybrid battery,closed,
MAS01303,Protection of neg. terminal of high voltage / hybrid battery,closed,
MAS01481,Temperature in control module,19, °C
MAS01634,Supply voltage,15.000, V
MAS02194,Temperature 1,13, °C
MAS02195,Temperature 2,15, °C
MAS02199-MAS01966,Lowest measured temperature-Temperature sensor,6,
MAS02199-MAS02985,Lowest measured temperature-Value,9.625, °C
MAS02200-MAS01966,Highest measured temperature-Temperature sensor,15,
MAS02200-MAS02985,Highest measured temperature-Value,10.500, °C
MAS04266,Temperature sensor 1,9.875, °C
MAS04267,Temperature sensor 2,9.875, °C
MAS04268,Temperature sensor 3,9.875, °C
MAS04269,Temperature sensor 4,10.250, °C
MAS04270,Temperature sensor 5,9.875, °C
MAS04271,Temperature sensor 6,9.625, °C
MAS04272,Temperature sensor 7,10.000, °C
MAS04273,Temperature sensor 8,10.250, °C
MAS04291,Positive voltage of high volt battery after protection,398.938, V
MAS04293-MAS01632,Entire HV system positive terminal insulation resistance-Status,valid,
MAS04293,Entire HV system positive terminal insulation resistance,4300, kOhm
MAS04294-MAS01632,HV battery positive terminal insulation resistance-Status,invalid,
MAS04294,HV battery positive terminal insulation resistance,10000, kOhm
MAS04295-MAS01632,Entire HV system minus terminal insulation resistance-Status,valid,
MAS04295,Entire HV system minus terminal insulation resistance,4300, kOhm
MAS04296-MAS01632,HV battery minus terminal insulation resistance-Status,invalid,
MAS04296,HV battery minus terminal insulation resistance,10000, kOhm
MAS04649,Cell 1,3.837, V
MAS04650,Cell 2,3.838, V
MAS04651,Cell 3,3.838, V
MAS04652,Cell 4,3.838, V
MAS04653,Cell 5,3.838, V
MAS04654,Cell 6,3.838, V
MAS04655,Cell 7,3.838, V
MAS04656,Cell 8,3.837, V
MAS04657,Cell 9,3.837, V
MAS04658,Cell 10,3.836, V
MAS04659,Cell 11,3.835, V
MAS04660,Cell 12,3.836, V
MAS04661,Cell 13,3.837, V
MAS04662,Cell 14,3.836, V
MAS04663,Cell 15,3.837, V
MAS04664,Cell 16,3.836, V
MAS04665,Cell 17,3.838, V
MAS04666,Cell 18,3.838, V
MAS04667,Cell 19,3.838, V
MAS04668,Cell 20,3.837, V
MAS04669,Cell 21,3.837, V
MAS04670,Cell 22,3.837, V
MAS04671,Cell 23,3.838, V
MAS04672,Cell 24,3.838, V
MAS04673,Cell 25,3.837, V
MAS04674,Cell 26,3.837, V
MAS04675,Cell 27,3.837, V
MAS04676,Cell 28,3.837, V
MAS04677,Cell 29,3.838, V
MAS04678,Cell 30,3.837, V
MAS04679,Cell 31,3.837, V
MAS04680,Cell 32,3.837, V
MAS04681,Cell 33,3.836, V
MAS04682,Cell 34,3.835, V
MAS04683,Cell 35,3.839, V
MAS04684,Cell 36,3.837, V
MAS04685,Cell 37,3.836, V
MAS04686,Cell 38,3.836, V
MAS04687,Cell 39,3.837, V
MAS04688,Cell 41,3.839, V
MAS04689,Cell 42,3.836, V
MAS04690,Cell 43,3.837, V
MAS04691,Cell 44,3.836, V
MAS04692,Cell 45,3.837, V
MAS04693,Cell 46,3.837, V
MAS04694,Cell 47,3.837, V
MAS04695,Cell 48,3.837, V
MAS04696,Cell 49,3.838, V
MAS04697,Cell 50,3.837, V
MAS04698,Cell 51,3.836, V
MAS04699,Cell 52,3.837, V
MAS04700,Cell 53,3.837, V
MAS04701,Cell 54,3.837, V
MAS04702,Cell 55,3.837, V
MAS04703,Cell 56,3.837, V
MAS04704,Cell 57,3.837, V
MAS04705,Cell 58,3.837, V
MAS04706,Cell 59,3.837, V
MAS04707,Cell 60,3.837, V
MAS04708,Cell 61,3.837, V
MAS04709,Cell 62,3.837, V
MAS04710,Cell 63,3.837, V
MAS04711,Cell 64,3.837, V
MAS04712,Cell 65,3.838, V
MAS04713,Cell 66,3.838, V
MAS04714,Cell 67,3.839, V
MAS04715,Cell 68,3.831, V
MAS04716,Cell 69,3.836, V
MAS04717,Cell 70,3.834, V
MAS04718,Cell 71,3.838, V
MAS04719,Cell 72,3.839, V
MAS04720,Cell 40,3.837, V
MAS04721-MAS01234,Minimum charge level-Index 1,68,
MAS04721-MAS02985,Minimum charge level-Value,61.280, %
MAS04722-MAS01234,Maximum charge level-Index 1,21,
MAS04722-MAS02985,Maximum charge level-Value,61.920, %
MAS06746,Temperature sensor 9,9.875, °C
MAS06747,Temperature sensor 10,9.875, °C
MAS06748,Temperature sensor 11,10.125, °C
MAS06749,Temperature sensor 12,10.375, °C
MAS06750,Temperature sensor 13,10.000, °C
MAS06751,Temperature sensor 14,9.875, °C
MAS06752,Temperature sensor 15,10.500, °C
MAS06753,Temperature sensor 16,10.375, °C
MAS06754,Positive voltage of high volt battery before protection,398.969, V
MAS06761,Sum of voltage of all battery cells,399.098, V
MAS07429,Status loader positive terminal,Open,
MAS07430,Status loader negative terminal,Open,
MAS07735,Cell 73,3.837, V
MAS07736,Cell 74,3.837, V
MAS07737,Cell 75,3.838, V
MAS07738,Cell 76,3.837, V
MAS07739,Cell 77,3.837, V
MAS07740,Cell 78,3.837, V
MAS07741,Cell 79,3.837, V
MAS07742,Cell 80,3.837, V
MAS07743,Cell 81,3.837, V
MAS07744,Cell 82,3.838, V
MAS07745,Cell 83,3.837, V
MAS07746,Cell 84,3.837, V
MAS07747,Cell 85,3.837, V
MAS07748,Cell 86,3.837, V
MAS07749,Cell 87,3.838, V
MAS07750,Cell 88,3.837, V
MAS07751,Cell 89,3.836, V
MAS07752,Cell 90,3.837, V
MAS07753,Cell 91,3.837, V
MAS07754,Cell 92,3.836, V
MAS07755,Cell 93,3.837, V
MAS07756,Cell 94,3.837, V
MAS07757,Cell 95,3.837, V
MAS07758,Cell 96,3.837, V
MAS07759,Cell 97,3.837, V
MAS07760,Cell 98,3.836, V
MAS07761,Cell 99,3.838, V
MAS07762,Cell 100,3.837, V
MAS07763,Cell 101,3.836, V
MAS07764,Cell 102,3.838, V
MAS07765,Cell 103,3.837, V
MAS07766,Cell 104,3.837, V
MAS07767,Cell 105,Initialization,
MAS07768,Cell 106,Initialization,
MAS07769,Cell 107,Initialization,
MAS07770,Cell 108,Initialization,
MAS07773,Temperature sensor 17,9.875, °C
MAS07774,Temperature sensor 18,9.875, °C
MAS07775,Temperature sensor 19,10.250, °C
MAS07776,Temperature sensor 20,10.500, °C
MAS07777,Temperature sensor 21,9.875, °C
MAS07778,Temperature sensor 22,9.875, °C
MAS07779,Temperature sensor 23,10.250, °C
MAS07780,Temperature sensor 24,10.500, °C
MAS07781,Temperature sensor 25,9.875, °C
MAS07782,Temperature sensor 26,10.125, °C
MAS07792,Expanded battery limits,not active,
MAS07804,Pump for HV battery coolant: specified speed value,0, %
MAS07815,Cooling status BMS,Klima_off,
MAS07823,Current: PTC heater HV batt.,0.000, A
MAS07826,Request emergency discharge HV intermittent circuit condenser,not active,
MAS07827,Mode HV battery actual value,Driving mode,
MAS09283,HV interlock detector voltage,0.816, V
MAS09284,HV interlock source voltage,0.829, V
MAS09285,HV interlock detector current,10.984, mA
MAS09286,HV interlock source current,11.102, mA
MAS24224,Developer messages,07,
MAS24224,Developer messages,00,
MAS24224,Developer messages,01,
MAS24224,Developer messages,CC,
MAS24224,Developer messages,DD,
MAS24224,Developer messages,06,
MAS24224,Developer messages,BB,
MAS24224,Developer messages,AA,
MAS24224,Developer messages,0A,
MAS24224,Developer messages,13,
MAS24224,Developer messages,02,
MAS28019,High-voltage battery self-discharge status,||62|FA|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|00|20|,
Elapsed Time: 01:02
blockmap-A5-1EA-980-653-E_WVGAWVEB7SH010695-20241230-1139.CSV
;SW:1EA-980-653-E   HW:1EA-980-653-A ---  Frt Sens. Drv. Assist
;Component:MEB MFK 4.1   H08 5556, Coding:010A302E1F4500F83724301C4000000000000000000000000000000000000000
;EV_MFK41ValeoMEB,001080,EV_MFK41ValeoMEB_VWE3.rod
;Monday,30,December,2024,11:39:42:18177
;VCDS Version: Beta 24.12.0 (x64)  Data version: 20241120 DS361.3
;VCID: 3B24ED1753E1D0C2660-806E-R SFD
Group,Description,Actual
IDE00019,Voltage terminal 30,15.00, V
IDE00030-ENG261886,Status of actuator test-State_of_output_control,not active,
IDE00767,No. of unscheduled ECU resets,19,
IDE00973,Outside temperature,13.00, °C
IDE01968,Dynamic calibration: yaw angle offset,0.1570, °
IDE01969,Dynamic calibration: pitch angle offset,-0.2360, °
IDE01970,Dynamic calibration: roll angle offset,-0.0030, °
IDE01971,Lowest recorded control module temperature,-1, °C
IDE01972,Highest recorded control module temperature,75, °C
IDE01974-MAS01167,Steering wheel vibration-Actuation time,Unknown (0),
IDE01974-MAS08863,Steering wheel vibration-Status of actuator test,Output diagnostic test not active,
IDE01985-MAS06854,FAZIT identification test sum-Version,129,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,318732018,
IDE02007-MAS01167,Yellow indicator light for directional stabilization assistance-Actuation time,Unknown (0),
IDE02007-MAS08863,Yellow indicator light for directional stabilization assistance-Status of actuator test,Output diagnostic test not active,
IDE02008-MAS01167,Green indicator light for directional stabilization assistance-Actuation time,Unknown (0),
IDE02008-MAS08863,Green indicator light for directional stabilization assistance-Status of actuator test,Output diagnostic test not active,
IDE02009-MAS01167,Directional stabilization assistance display-Actuation time,Unknown (0),
IDE02009-MAS08863,Directional stabilization assistance display-Status of actuator test,Output diagnostic test not active,
IDE02057,Dynamic calibration: status,Passive values stored,
IDE02608-MAS01167,Window defogger for front sensor system-Actuation time,0 s,
IDE02608-MAS08863,Window defogger for front sensor system-Status of actuator test,Output diagnostic test not active,
IDE03222-MAS02534,Blindness detection-Clear view,Yes,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS17450,Blindness detection-Blindness: space detection,No,
IDE03222-MAS17452,Blindness detection-Windshield heater blindness request,No,
IDE03222-MAS17453,Blindness detection-Clear view currently detected,Yes,
IDE03354-MAS01632,Dynamic calibration: details-Status,No calibration relevant malfunction,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,129, km
IDE04227,Directional stab. asst w/ pwr steering asst: steering status,Lane assist deactivated in steering,
IDE04229,Directional stab. asst w/ pwr steering asst: steering torque,-0.0000, Nm
IDE04904-MAS01167,Traffic sign display in instrument cluster-Actuation time,Unknown (0),
IDE04904-MAS08863,Traffic sign display in instrument cluster-Status of actuator test,Output diagnostic test not active,
IDE07145-MAS06772,Component protection properties-Component protection generation,2,
IDE07145-MAS06773,Component protection properties-KS Standard software main version nummer,3,
IDE07145-MAS06774,Component protection properties-KS Standard software secondary version number,8,
IDE07145-MAS06775,Component protection properties-KS Standard software correct number,1,
IDE07145-MAS07187,Component protection properties-KS Data version,1,
IDE07145-MAS18014,Component protection properties-Supported SHE download versions,NOT-DEFINED,
IDE07214,Dynamic calibration: camera height offset,-39, mm
IDE07543,Vehicle speed,0.000, km/h
IDE09492-MAS11790,Temperatures-Control Module temperature,53, °C
IDE09492-MAS17447,Temperatures-Temperature of the EyeQ chip,57, °C
IDE09492-MAS17448,Temperatures-Temperature of the memory in the EyeQ chip,54, °C
IDE09492-MAS17449,Temperatures-High temperature shutdown,OFF,
IDE10220,Initial online calibration active,not active,
IDE10300,OBD Driving Cycle detected,active,
IDE10403,Current initial calibration: status,Initial static calibration EOL OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,0.00000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,0.00000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,0.00000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,0.00000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,0.0000, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,0.00000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,0.0000, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,0.00000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,0.0000, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,0.00000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1200, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,0.00000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS00106,Last initial calibrations: details-Year,24,
IDE10406-MAS00107,Last initial calibrations: details-Month,10,
IDE10406-MAS00108,Last initial calibrations: details-Day,15,
IDE10406-MAS00109,Last initial calibrations: details-Hours,10,
IDE10406-MAS00110,Last initial calibrations: details-Minutes,34,
IDE10406-MAS00111,Last initial calibrations: details-Seconds,9,
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,24,
IDE10664-MAS00107,Current initial calibration: details-Month,10,
IDE10664-MAS00108,Current initial calibration: details-Day,15,
IDE10664-MAS00109,Current initial calibration: details-Hours,10,
IDE10664-MAS00110,Current initial calibration: details-Minutes,34,
IDE10664-MAS00111,Current initial calibration: details-Seconds,9,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,2,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WVGAWVEB7SH010695,
IDE10664,Current initial calibration: details,00111111 ,
IDE10664,Current initial calibration: details,00110011 ,
IDE10779,Ethernet signal quality,good: link available,
IDE10780,Ethernet counter connection interruptions,0,
IDE10781,Ethernet counter checksum malfunction,0,
IDE10924-MAS02479,Initial calibration: result-Yaw angle,0.6390, °
IDE10924-MAS05286,Initial calibration: result-Roll angle,0.0200, °
IDE10924-MAS05287,Initial calibration: result-Pitch angle,-0.8380, °
IDE10924-MAS10678,Initial calibration: result-Camera height,1282, mm
IDE11752-IDE09469,IP network: IPv6-addresses-IPv6 address,|IPv6 address|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 4F|,
IDE11753-MAS14855,IP network: IPv6-multicast-addresses-IPv6 Multicast address,|IPv6 Multicast address|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 5B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 02|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 0B|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 18|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 61|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 09|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 21|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 19|FF 02 00 00 00 00 00 00 00 00 00 00 00 00 00 01|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 05|FF 14 00 00 00 00 00 00 00 00 00 00 00 00 00 2E|FF 14 00 00 00 00 00 00 00 00 00 00 00 01 00 FE|,
IDE11755-MAS14856,IP network: VLANs-VLAN,|VLAN|2|,
IDE11756,IP network: counter messages with inadmissible VLANs,0,
IDE11757,IP network: counter messages with inadmissible IPv6-addresses,6460,
IDE11759,IP network: counter messages with inadmissible TCP ports,0,
IDE11760,IP network: counter messages with inadmissible UDP ports,6,
IDE11761-IDE09467,IP network: MAC addresses-MAC address,|MAC address|74 90 50 00 00 00|,
IDE11869,IP network: NDP cache,|MAC address,IPv6 address,VLAN|44 20 63 0B 99 4E,FD 53 7C B8 03 83 00 02 00 00 00 00 00 04 00 10,2|,
IDE11988-IDE09467,IP network: MAC addresses of Ethernet switch ports branch 1-MAC address,|MAC address|74 90 50 00 00 00|,
IDE12230-ENG277505,IP network: VLANs of Ethernet switch ports branch 1-Ip_vlans_list,|VLAN|2|0|0|0|0|0|0|0|0|0|,
IDE12238,I network: discarded messages counter,6468,
IDE12239,IP network: test feedback value of communications relationships,|IPv6 address,Result|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 10,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 57,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 69,Test not yet carried out|FD 53 7C B8 03 83 00 02 00 00 00 00 00 00 00 C9,Test not yet carried out|,
IDE12625,IP network: current link deceleration: branch 1,0, µs
IDE12633,IP Network maximum correction of the synchronized clock,9794764, µs
IDE13845,Production mode status,not active,
IDE13994-MAS17458,Intrinsic calibration: result-Main point x,646.89, px
IDE13994-MAS17463,Intrinsic calibration: result-Main point y,542.21,
IDE13994-MAS17464,Intrinsic calibration: result-Focal length x,1459.76, px
IDE13994-MAS17465,Intrinsic calibration: result-Focal length y,1459.76, px
IDE13994-MAS17466,Intrinsic calibration: result-Distortion in k1,-0.0004688910,
IDE13994-MAS17467,Intrinsic calibration: result-Distortion in k2,-0.0003636790,
IDE13994-MAS17468,Intrinsic calibration: result-Distortion in k3,-0.0006388480,
IDE13994-MAS17469,Intrinsic calibration: result-Distortion in t1,-0.0000000000,
IDE13994-MAS17470,Intrinsic calibration: result-Distortion in t2,-0.0000000000,
IDE13994-MAS17471,Intrinsic calibration: result-Gamma,1.0000,
IDE13994-MAS17472,Intrinsic calibration: result-Incline,0.00, px
IDE13995-MAS08824,Calibration target position: stored values-Target 1: calibration mark 1: x-coordinate,2400.0000, mm
IDE13995-MAS08825,Calibration target position: stored values-Target 1: calibration mark 1: y-coordinate,642.5000, mm
IDE13995-MAS08826,Calibration target position: stored values-Target 1: calibration mark 1: z-coordinate,1456.0000, mm
IDE13995-MAS08827,Calibration target position: stored values-Target 1: calibration mark 2: x-coordinate,2400.0000, mm
IDE13995-MAS08828,Calibration target position: stored values-Target 1: calibration mark 2: y-coordinate,-642.5000, mm
IDE13995-MAS08829,Calibration target position: stored values-Target 1: calibration mark 2: z-coordinate,1456.0000, mm
IDE13995-MAS08830,Calibration target position: stored values-Target 1: calibration mark 3: x-coordinate,2400.0000, mm
IDE13995-MAS08831,Calibration target position: stored values-Target 1: calibration mark 3: y-coordinate,642.5000, mm
IDE13995-MAS08832,Calibration target position: stored values-Target 1: calibration mark 3: z-coordinate,944.0000, mm
IDE13995-MAS08833,Calibration target position: stored values-Target 1: calibration mark 4: x-coordinate,2400.0000, mm
IDE13995-MAS08834,Calibration target position: stored values-Target 1: calibration mark 4: y-coordinate,-642.5000, mm
IDE13995-MAS08835,Calibration target position: stored values-Target 1: calibration mark 4: z-coordinate,944.0000, mm
IDE13996-IDE05717,Axle offset: stored values-Front axle transverse position,1.20, mm
IDE13996-IDE05718,Axle offset: stored values-Rear axle transverse position,-0.90, mm
IDE13997-IDE02001,Body height to wheel house edge: stored values-Body height left front wheel house edge,804.000, mm
IDE13997-IDE02002,Body height to wheel house edge: stored values-Body height right front wheel house edge,803.000, mm
IDE13997-IDE02003,Body height to wheel house edge: stored values-Body height left rear wheel house edge,807.000, mm
IDE13997-IDE02004,Body height to wheel house edge: stored values-Body height right rear wheel house edge,808.000, mm
IDE13998,Distance to calibration field: stored values,1500.000, mm
IDE14000,Windshield defogger camera: activation status,OFF,
IDE17075-ENG298547,Functions that can be enabled: FoD slave enhanced status-Extended_state_payload,00 01 00 D6 02 03 00 02 00 00 03 03 00 00 00 00 00 00 00 4C 00 00 00 00 03 00 00 00 0A 00 00 00 00 00 00 75 30 00 05 7E 40 00 00 03 E8 00 0A 06 14 22 00 00 00,
IDE17075-ENG298612,Functions that can be enabled: FoD slave enhanced status-Payload_length,53,
IDE17075-ENG99027,Functions that can be enabled: FoD slave enhanced status-Version,11,
MAS01634-MAS09193,Supply voltage-PLA,15.0, V
MAS01634-MAS17440,Supply voltage-Supply voltage 1V0,1.0, V
MAS01634-MAS17441,Supply voltage-Supply voltage 1V1,1.1, V
MAS01634-MAS17442,Supply voltage-Supply voltage 1V2,0.0, V
MAS01634-MAS17443,Supply voltage-Supply voltage 1V25,1.2, V
MAS01634-MAS17444,Supply voltage-Supply voltage 1V8,1.8, V
MAS01634-MAS17445,Supply voltage-Supply voltage 3V3,3.2, V
MAS01634-MAS17446,Supply voltage-Supply voltage 5V0,5.0, V
MAS11502-MAS10691,Self-glare recognition-Self-glare quality,0, %
MAS11502-MAS11503,Self-glare recognition-Self-glare status,active,
MAS11502-MAS15965,Self-glare recognition-Glare detected,No,
MAS17268,Functions which can be activated: connection error counter,0,
MAS17473,Functional state and lane boundary information,2,
MAS17521-IDE04332,Unlockable functions: activation status-Release code for a SWaP function,available.,
MAS17521-IDE05814,Unlockable functions: activation status-Individualization characteristic,invalid,
MAS17521-IDE06260,Unlockable functions: activation status-ID number,10 0E 0F 00,
MAS17521-MAS01340,Unlockable functions: activation status-Functions,available.,
MAS17521-MAS01903,Unlockable functions: activation status-Configuration,OK,
MAS17521-MAS02934,Unlockable functions: activation status-Preconditions met,Condition not met,
MAS17521-MAS05616,Unlockable functions: activation status-Cancellation,No,
MAS17521-MAS05617,Unlockable functions: activation status-Authentication,Condition met,
MAS17521-MAS17839,Unlockable functions: activation status-Number of functions which can be activated,5,
MAS17521-MAS17983,Unlockable functions: activation status-Last state,not active,
MAS22239-ENG299116,Trained parking: prevention reasons (ring memory)-TPA_storing_prevention_ring_buffer,|Year,Month,Day,Hours,Minutes,Seconds,Trained parking spaces: number,last cause of reset,Recorded distance: until reset,Speed|2024,12,27,18,49,19,0,Road_surface_incline_too_high,0.00,0.00|2024,12,28,16,26,40,0,Road_surface_incline_too_high,0.00,0.00|2024,12,28,20,28,33,0,Road_surface_incline_too_high,0.00,0.00|2024,12,29,20,8,21,0,Road_surface_incline_too_high,0.00,0.00|2024,12,29,20,8,40,0,Road_surface_incline_too_high,0.00,0.00|2024,12,29,20,9,26,0,Road_surface_incline_too_high,0.00,0.00|2024,12,29,20,12,20,0,Road_surface_incline_too_high,0.00,0.00|2024,12,29,20,14,29,0,Road_surface_incline_too_high,0.00,0.00|2024,12,29,20,14,47,0,Road_surface_incline_too_high,0.00,0.00|2024,12,30,16,18,1,0,Road_surface_incline_too_high,0.00,0.00|, km/h
MAS22249,Recorded distance: actual,0.00, m
MAS22250-MAS22346,Trained parking: card memory-Memory block 1 and 2,        ,
MAS22250-MAS22347,Trained parking: card memory-Memory block 5 and 6,        ,
MAS22250-MAS22348,Trained parking: card memory-Memory block 7 and 8,        ,
MAS22250-MAS22352,Trained parking: card memory-Memory block 3 and 4,        ,
MAS22250-MAS22354,Trained parking: card memory-Memory block 9 and 10,        ,
MAS22261,Trained parking: cause of error,no_error_detected,
ENG347809,Current_ELKS_Failure_State,ELKS_no_Failure,
ENG297739-MAS06855,Dataset_Patch-Test sum,15 C8 23 22,
ENG297739-MAS24941,Dataset_Patch-Internal dataset applied,not_applied,
ENG179581-ENG181012,FoD_slave_operating_state-FoD_slave_state,2,
ENG254718-MAS17839,Function_On_Demand_Unlock_ID_Status_Dev-Number of functions which can be activated,5,
ENG254718-MAS17983,Function_On_Demand_Unlock_ID_Status_Dev-Last state,not active,
ENG254718-ENG247044,Function_On_Demand_Unlock_ID_Status_Dev-Function_On_Demand_Freischalt_ID_Status,|ID number,Authentication,Functions,Configuration,Preconditions met,Individualization characteristic,Cancellation,Release code for a SWaP function|10 0E 0F 00,Condition met,Not available,not OK,Condition met,valid,No,available.|10 0E 10 00,Condition met,Not available,not OK,Condition not met,valid,Yes,available.|10 0E 0D 00,Condition met,Not available,not OK,Condition not met,valid,Yes,available.|10 0E 08 00,Condition met,Not available,not OK,Condition met,valid,Yes,available.|10 0E 06 00,Condition met,Not available,not OK,Condition met,valid,No,available.|,
ENG370384-MAS00106,Programming_precondition_history-Year,0,
ENG370384-MAS00107,Programming_precondition_history-Month,0,
ENG370384-MAS00108,Programming_precondition_history-Day,0,
ENG370384-MAS00109,Programming_precondition_history-Hours,0,
ENG370384-MAS00110,Programming_precondition_history-Minutes,0,
ENG370384-MAS00111,Programming_precondition_history-Seconds,0,
ENG370384-ENG103063,Programming_precondition_history-Mileage,0,
ENG370384-ENG370522,Programming_precondition_history-Programming_precondition,unused,
ENG370384-ENG144705,Programming_precondition_history-Supply_voltage,0,
ENG370384-ENG119265,Programming_precondition_history-Velocity,Value,
ENG261867,Status_connection_to_mfk,inactive,
Elapsed Time: 00:54
blockmap-BE-1N3-959-244-B_WVGAWVEB7SH010695-20241230-1140.CSV
;SW:1N3-959-244-B   HW:1N3-959-244-B ---  Slid. Door Rear Left
;Component:Slidingdoor_d H04 0028, Coding:D600
;EV_SlideDoorDriveHufIDBuz,002110,EV_SlideDoorDriveHufIDBuz_002.rod
;Monday,30,December,2024,11:40:52:18177
;VCID: 3530FB2F75C506B2904-8060-R
IDE00019,Voltage terminal 30,14.80, V
IDE00029-IDE11960,Status of input signals 1-Fuel filler door positioner,Not operated,
IDE00029-MAS02032,Status of input signals 1-Front button for automatic sliding door,Not operated,
IDE00029-MAS02033,Status of input signals 1-Rear button for automatic sliding door,Not operated,
IDE00029-MAS02036,Status of input signals 1-Pinch protection sensor,Not operated,
IDE00029-MAS02103,Status of input signals 1-Signal from door lock: catch,operated,
IDE00029-MAS04194,Status of input signals 1-Driver side,Yes,
IDE00029-MAS04195,Status of input signals 1-Front passenger side,No,
IDE00029-ENG264512,Status of input signals 1-Deactivation_switch,Not operated,
IDE00056-ENG264528,History data 1-Fourth_revers_position,0,
IDE00056-ENG264529,History data 1-Fourth_revers_reason,0,
IDE00056-ENG264553,History data 1-Last_revers_position,683,
IDE00056-ENG264554,History data 1-Last_revers_reason,19,
IDE00056-ENG264654,History data 1-Second_revers_position,0,
IDE00056-ENG264655,History data 1-Second_revers_reason,0,
IDE00056-ENG264683,History data 1-Third_revers_position,0,
IDE00056-ENG264684,History data 1-Third_revers_reason,0,
IDE00057-IDE00056,History data 2-History data 1,1,
IDE00057-ENG264527,History data 2-Fourth_operator_unit,2,
IDE00057-ENG264653,History data 2-Second_operator_unit,1,
IDE00057-ENG264682,History data 2-Third_operator_unit,2,
IDE00058-ENG264530,History data 3-Fourth_stop_position,1040,
IDE00058-ENG264531,History data 3-Fourth_stop_reason,2,
IDE00058-ENG264555,History data 3-Last_stop_position,65533,
IDE00058-ENG264556,History data 3-Last_stop_reason,3,
IDE00058-ENG264656,History data 3-Second_stop_position,1040,
IDE00058-ENG264657,History data 3-Second_stop_reason,2,
IDE00058-ENG264685,History data 3-Third_stop_position,65534,
IDE00058-ENG264686,History data 3-Third_stop_reason,3,
IDE00320-MAS02111,Consistency of EEPROM data-Data consistency,Valid EEPROM Data,
IDE00320-MAS04299,Consistency of EEPROM data-Error during last data record download,No malfunction,
IDE00320-MAS04434,Consistency of EEPROM data-Data record modification,Data record not changed,
IDE00320-MAS06349,Consistency of EEPROM data-Dataset download possible,Not parameterizable,
IDE00330,Transverse slope,0, °
IDE00331,Longitudinal slope,0, °
IDE00609,Communication status of data bus 1,active,
IDE00767,No. of unscheduled ECU resets,10,
IDE02270-IDE00002,CAN input signal(s) status-Transport mode,not active,
IDE02270-IDE00020,CAN input signal(s) status-Terminal 15 status,On,
IDE02270-IDE01211,CAN input signal(s) status-Static current measuring mode,not active,
IDE02270-IDE01715,CAN input signal(s) status-Status terminal S,On,
IDE02270-IDE01716,CAN input signal(s) status-Terminal 50 status,OFF,
IDE02270-IDE01718,CAN input signal(s) status-Crash signal,No crash recognized,
IDE02270-IDE05713,CAN input signal(s) status-Network diagnosis,active,
IDE02270-IDE07856,CAN input signal(s) status-Terminal status,OFF,
IDE02270-IDE11279,CAN input signal(s) status-eCall operating state,not active,
IDE02270-MAS00215,CAN input signal(s) status-Fuel filler lid,Open,
IDE02270-MAS02034,CAN input signal(s) status-Installed on left side,Yes,
IDE02270-MAS02035,CAN input signal(s) status-Installed on right side,No,
IDE02270-MAS02097,CAN input signal(s) status-Window position,0.00, %
IDE02270-MAS02098,CAN input signal(s) status-Window regulator standardized,Yes,
IDE02270-MAS02099,CAN input signal(s) status-Switch for inside door handle,Not operated,
IDE02270-MAS02100,CAN input signal(s) status-Switch for outside door handle,Not operated,
IDE02270-MAS02101,CAN input signal(s) status-Child safety lock,operated,
IDE02270-MAS02102,CAN input signal(s) status-Signal from door lock: detent,Not operated,
IDE02270-MAS02103,CAN input signal(s) status-Signal from door lock: catch,Not operated,
IDE02270-MAS02104,CAN input signal(s) status-Door lock: safe,not active,
IDE02270-MAS02105,CAN input signal(s) status-Signal from door lock: engaged,not active,
IDE02270-MAS02106,CAN input signal(s) status-Request through vehicle key with remote control,Not operated,
IDE02270-MAS02108,CAN input signal(s) status-Signal vehicle speed (alt bit),not active,
IDE02270-MAS06524,CAN input signal(s) status-Status of closing assist,not active,
IDE02270-MAS07983,CAN input signal(s) status-Virtual pedal,Not operated,
IDE02270-MAS08781,CAN input signal(s) status-Connection state of charging plug,no plug detected,
IDE02270-MAS10510,CAN input signal(s) status-Kessy,not active,
IDE02270-MAS19085,CAN input signal(s) status-Tailgate position,closed,
IDE02270-MAS21240,CAN input signal(s) status-Network diagnostic approval: central activation,Network diagnostic approval: supported,
IDE02271-IDE18030,CAN output signal(s) status-Charging socket flap collision protection,Initialization,
IDE02271-MAS00478,CAN output signal(s) status-Reserved,-1,
IDE02271-MAS00542,CAN output signal(s) status-Indicator lamp for safety belt warning,Not operated,
IDE02271-MAS02036,CAN output signal(s) status-Pinch protection sensor,Not operated,
IDE02271-MAS02037,CAN output signal(s) status-Automatic sliding door moving: opening,not active,
IDE02271-MAS02038,CAN output signal(s) status-Automatic sliding door moving: closing,not active,
IDE02271-MAS02039,CAN output signal(s) status-Force limitation,Not operated,
IDE02271-MAS02502,CAN output signal(s) status-Customer service,No malfunction,
IDE02271-ENG264504,CAN output signal(s) status-Co_clamping_protection_seal_defect_IO,No malfunction,
IDE02272-MAS00976,Play protection: motor for automatic sliding door-Counter,0,
IDE02272-MAS02040,Play protection: motor for automatic sliding door-Anti-play protection,not active,
IDE02272-MAS02041,Play protection: motor for automatic sliding door-Activation limitation,180,
IDE02272-MAS02042,Play protection: motor for automatic sliding door-Deactivation limitation,120,
IDE02275-MAS01424,Position of automatic sliding door-max.value,04 55,
IDE02275-MAS01447,Position of automatic sliding door-Act.val.,00 00,
IDE02276,Number of driving cycles for automatic sliding door,144,
IDE02278-MAS02043,Status of output signals-Automatic sliding door acoustic,not active,
IDE02278-MAS02044,Status of output signals-Activation: motor for automatic sliding door,not activated,
IDE02278-MAS02045,Status of output signals-Motor activation for enabling ratchet release,not activated,
IDE02278-MAS02047,Status of output signals-Sliding door indicator lamp,not active,
IDE02278-MAS02048,Status of output signals-Sliding door indicator lamp 2,not active,
IDE02278-MAS09001,Status of output signals-Closing Assist Motor,not activated,
IDE02278-MAS21245,Status of output signals-Sliding door indicator lamp 3,not active,
IDE02278-MAS25771,Status of output signals-Activation of the automatic sliding door arrester,not activated,
IDE02486,Data logger triggering,not initialized,
IDE02578-MAS00976,Play protection status-Counter,0, °
IDE02578-MAS02040,Play protection status-Anti-play protection,not activated,
IDE02578-MAS02041,Play protection status-Activation limitation,200, °
IDE02578-MAS02042,Play protection status-Deactivation limitation,5,
IDE02856-MAS02283,Basic setting of opening width-Condition,calibrated,
IDE02856-MAS02402,Basic setting of opening width-Standardization value,1109,
IDE02856-MAS12981,Basic setting of opening width-Number of requested tests,2,
IDE02857-MAS02036,Activation current-Pinch protection sensor,6.90, V
IDE02857-MAS02044,Activation current-Activation: motor for automatic sliding door,0.00, A
IDE02857-MAS02045,Activation current-Motor activation for enabling ratchet release,0.00, A
IDE02857-MAS25778,Activation current-Door arrester: current consumption,0.00, A
IDE05999,Basic setting: position,00 00 00 02 45 88 03 FF FE 02 04 10 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06001,Basic setting: maximum value during opening,00 00 00 02 45 88 03 FF FE 02 04 10 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06002,Basic setting: current value during opening,00 00 00 02 45 88 03 FF FE 02 04 10 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06003,Basic setting: maximum value during closing,00 00 00 02 45 88 03 FF FE 02 04 10 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06004,Basic setting: current value during closing,00 00 00 02 45 88 03 FF FE 02 04 10 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE07543,Vehicle speed,0.00, km/h
IDE11036-MAS00976,Pull-shut asst.: play protec.-Counter,0, °
IDE11036-MAS02040,Pull-shut asst.: play protec.-Anti-play protection,not active,
IDE11036-MAS02041,Pull-shut asst.: play protec.-Activation limitation,63, °
IDE11036-MAS02042,Pull-shut asst.: play protec.-Deactivation limitation,42,
MAS00398-IDE00019,Read ambient data-Voltage terminal 30,14.8, V
MAS00398-IDE00330,Read ambient data-Transverse slope,0, °
MAS00398-IDE00331,Read ambient data-Longitudinal slope,0, °
MAS00398-IDE02272,Read ambient data-Play protection: motor for automatic sliding door,not active,
MAS00398-IDE02273,Read ambient data-Play protection: motor for enabling ratchet release,not active,
MAS00398-IDE02578,Read ambient data-Play protection status,not activated,
MAS00398-IDE10155,Read ambient data-Status door arrester,Open,
MAS00398-IDE17018,Read ambient data-Measured value container,No crash recognized,
MAS00398-MAS01424,Read ambient data-max.value,1109,
MAS00398-MAS01447,Read ambient data-Act.val.,0,
MAS00398-MAS02032,Read ambient data-Front button for automatic sliding door,Not operated,
MAS00398-MAS02033,Read ambient data-Rear button for automatic sliding door,Not operated,
MAS00398-MAS02036,Read ambient data-Pinch protection sensor,Not operated,
MAS00398-MAS02043,Read ambient data-Automatic sliding door acoustic,not active,
MAS00398-MAS02044,Read ambient data-Activation: motor for automatic sliding door,not active,
MAS00398-MAS02045,Read ambient data-Motor activation for enabling ratchet release,0.0, A
MAS00398-MAS02047,Read ambient data-Sliding door indicator lamp,not active,
MAS00398-MAS02048,Read ambient data-Sliding door indicator lamp 2,not active,
MAS00398-MAS02103,Read ambient data-Signal from door lock: catch,operated,
MAS00398-MAS02405,Read ambient data-Pre-engagement contact for rotary latch,Not operated,
MAS00398-MAS03403,Read ambient data-Parameter 3,closed,
MAS00398-MAS03548,Read ambient data-Motor current,0.0, A
MAS00398-MAS04194,Read ambient data-Driver side,Yes,
MAS00398-MAS04195,Read ambient data-Front passenger side,No,
MAS00398-MAS09001,Read ambient data-Closing Assist Motor,not active,
MAS00398-MAS21245,Read ambient data-Sliding door indicator lamp 3,not active,
MAS00398-MAS21251,Read ambient data-Pinch protection strip signal,6963,
MAS00398-MAS21252,Read ambient data-Sliding door position,Sliding door in main notch,
MAS00398-MAS25771,Read ambient data-Activation of the automatic sliding door arrester,not activated,
MAS00398-MAS25778,Read ambient data-Door arrester: current consumption,0.0, A
MAS00464-MAS00106,Standard - ambient data 1-Year,2024,
MAS00464-MAS00107,Standard - ambient data 1-Month,12,
MAS00464-MAS00108,Standard - ambient data 1-Day,30,
MAS00464-MAS00109,Standard - ambient data 1-Hours,16,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,40,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,55,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,10,
MAS00464-MAS00478,Standard - ambient data 1-Reserved,-1,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,464, km
MAS04894-IDE00002,Operating mode-Transport mode,not active,
MAS04894-IDE01211,Operating mode-Static current measuring mode,not active,
MAS04894-IDE06000,Operating mode-Customer service mode,not active,
MAS04894-MAS01790,Operating mode-Crash recognized,not active,
MAS04894-MAS02034,Operating mode-Installed on left side,active,
MAS04894-MAS02035,Operating mode-Installed on right side,not active,
MAS04894-MAS09595,Operating mode-Production mode,not active,
MAS04894-MAS25777,Operating mode-Control module status: door arrester,activated,
MAS21249,Sliding door opening: reason for obstruction,0, °
MAS21250,Sliding door close: reason for obstruction,0, °
Elapsed Time: 00:07
blockmap-BF-1N3-959-244-B_WVGAWVEB7SH010695-20241230-1141.CSV
;SW:1N3-959-244-B   HW:1N3-959-244-B ---  Slid. Door Rear Right
;Component:Slidingdoor_p H04 0028, Coding:D600
;EV_SlideDoorPasseHufIDBuz,002110,EV_SlideDoorPasseHufIDBuz_002.rod
;Monday,30,December,2024,11:41:06:18177
IDE00029-MAS04194,Status of input signals 1-Driver side,No,
IDE00029-MAS04195,Status of input signals 1-Front passenger side,Yes,
IDE00056-ENG264528,History data 1-Fourth_revers_position,681,
IDE00056-ENG264529,History data 1-Fourth_revers_reason,19,
IDE00056-ENG264553,History data 1-Last_revers_position,723,
IDE00056-ENG264554,History data 1-Last_revers_reason,25,
IDE00056-ENG264654,History data 1-Second_revers_position,706,
IDE00056-ENG264655,History data 1-Second_revers_reason,19,
IDE00056-ENG264683,History data 1-Third_revers_position,765,
IDE00056-ENG264684,History data 1-Third_revers_reason,19,
IDE00057-IDE00056,History data 2-History data 1,2,
IDE00057-ENG264682,History data 2-Third_operator_unit,5,
IDE00058-ENG264530,History data 3-Fourth_stop_position,1050,
IDE00058-ENG264656,History data 3-Second_stop_position,1050,
IDE00058-ENG264685,History data 3-Third_stop_position,65532,
IDE02270-IDE05713,CAN input signal(s) status-Network diagnosis,not active,
IDE02270-IDE11279,CAN input signal(s) status-eCall operating state,active,
IDE02270-MAS00215,CAN input signal(s) status-Fuel filler lid,closed,
IDE02270-MAS06524,CAN input signal(s) status-Status of closing assist,active,
IDE02271-IDE18030,CAN output signal(s) status-Charging socket flap collision protection,safe,
IDE02275-MAS01424,Position of automatic sliding door-max.value,04 5F,
IDE02276,Number of driving cycles for automatic sliding door,104,
IDE02278-MAS02043,Status of output signals-Automatic sliding door acoustic,active,
IDE02278-MAS02047,Status of output signals-Sliding door indicator lamp,active,
IDE02278-MAS02048,Status of output signals-Sliding door indicator lamp 2,active,
IDE02278-MAS21245,Status of output signals-Sliding door indicator lamp 3,active,
IDE02856-MAS02402,Basic setting of opening width-Standardization value,1119,
IDE05999,Basic setting: position,00 00 00 02 45 88 03 FF FC 02 04 1A 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06001,Basic setting: maximum value during opening,00 00 00 02 45 88 03 FF FC 02 04 1A 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06002,Basic setting: current value during opening,00 00 00 02 45 88 03 FF FC 02 04 1A 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06003,Basic setting: maximum value during closing,00 00 00 02 45 88 03 FF FC 02 04 1A 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE06004,Basic setting: current value during closing,00 00 00 02 45 88 03 FF FC 02 04 1A 00 00 00 00 00 00 00 00 49 44 42 75 7A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
MAS00398-MAS01424,Read ambient data-max.value,1119,
MAS00398-MAS04194,Read ambient data-Driver side,No,
MAS00398-MAS04195,Read ambient data-Front passenger side,Yes,
MAS00398-MAS21251,Read ambient data-Pinch protection strip signal,6977,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,41,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,9,
MAS04894-MAS02034,Operating mode-Installed on left side,not active,
MAS04894-MAS02035,Operating mode-Installed on right side,active,
Elapsed Time: 00:07
blockmap-C0-1T3-035-335-A_WVGAWVEB7SH010695-20241230-1141.CSV
;SW:1T3-035-335-A   HW:1EA-035-335 ---  Act. for Ext. Noise
;Component:E_SOUND_SG    H06 0006, Coding:
;EV_ESounHarmaMEBUNECE,001006,EV_ESounHarmaMEBUNECE_VWE3.rod
;Monday,30,December,2024,11:41:20:18177
;VCID: 2C06DE4BA68F477AFFA-8078-R
IDE00019,Voltage terminal 30,15.6, V
IDE00102-ENG127110,Control Module temperature-ecu_internal_temperature,19.0, °C
IDE00916-MAS09310,Speaker status-Channel 1,OK,
IDE12026-MAS01447,Status of charisma participant-Act.val.,0,
IDE12026-MAS01448,Status of charisma participant-Target value,0,
IDE12026-MAS01632,Status of charisma participant-Status,0,
Elapsed Time: 00:00
blockmap-C6-1EK-915-692-J_WVGAWVEB7SH010695-20241230-1141.CSV
;SW:1EK-915-692-J   HW:1EK-915-692-H ---  Batt. Chrg.
;Component:OCDC Gen4+    H03 2207, Coding:308010
;EV_OCDCXPHASERB8MEBB,002001,EV_OCDCXPHASERB8MEBB_002_VWE3.rod
;Monday,30,December,2024,11:41:27:18177
;VCID: 4BC4BDD703416042D60-801E-R SFD
IDE00008,Software version,2207,
IDE00019,Voltage terminal 30,0.000, V
IDE00025,Coolant temperature,215, °C
IDE00085,Normed load value,100.0, %
IDE00086,Accelerator pedal position,14.5, %
IDE00601-MAS00317,Monitoring status since erasing DTC memory-Malfunction Indicator Lamp,OFF,
IDE00601-MAS00329,Monitoring status since erasing DTC memory-Monitoring of fuel system,not activated,
IDE00601-MAS00330,Monitoring status since erasing DTC memory-Overall system monitoring,activated,
IDE00601-MAS00332,Monitoring status since erasing DTC memory-Fuel system test,Unknown (2),
IDE00601-MAS00333,Monitoring status since erasing DTC memory-Overall system test,completed successfully,
IDE00601-MAS00503,Monitoring status since erasing DTC memory-Number of emission-relevant DTC memory entries,0,
IDE00601-MAS04092,Monitoring status since erasing DTC memory-Monitoring of compression ignition,Not supported,
IDE00601-MAS04097,Monitoring status since erasing DTC memory-Intermittent monitoring,not activated,
IDE00601-MAS04098,Monitoring status since erasing DTC memory-Status not contin. monitoring since erasing event memory,not activated,
IDE00601-ENG151554,Monitoring status since erasing DTC memory-Completion status of all supported non-continuous monitors since DTCs cleared,00,
IDE00602-MAS04092,Monitoring status in current driving cycle-Monitoring of compression ignition,Not supported,
IDE00602-MAS04139,Monitoring status in current driving cycle-Activation status of intermittent monitoring,not activated,
IDE00602-MAS04140,Monitoring status in current driving cycle-Implementation status of intermittent monitoring,not activated,
IDE00602-ENG151471,Monitoring status in current driving cycle-Completion status of all supported non-continuous monitors this monitoring cycle,Yes,
IDE00602-ENG151579,Monitoring status in current driving cycle-Comprehensive component monitoring completed,completed successfully,
IDE00602-ENG151519,Monitoring status in current driving cycle-Comprehensive component monitoring enabled,activated,
IDE00602-ENG151568,Monitoring status in current driving cycle-Fuel system monitoring completed,Unknown (2),
IDE00602-ENG151497,Monitoring status in current driving cycle-Fuel system monitoring enabled,not activated,
IDE07543,Vehicle speed,0, km/h
IDE08423-MAS02949,Control signal for power outlet A for battery charging-Frequency,1133, Hz
IDE08423-MAS02952,Control signal for power outlet A for battery charging-Control voltage,0.0, V
IDE08423-MAS03873,Control signal for power outlet A for battery charging-Duty cycle,0.00, %
IDE13835-MAS17093,VKMS: relevant VIN number for last data supply-Status of vehicle identification number,valid,
IDE13835-MAS17094,VKMS: relevant VIN number for last data supply-Vehicle identification number output,WVGAWVEB7SH010695,
IDE13836-MAS17095,VKMS: adaption counter-Adaptation counter status,valid,
IDE13836-MAS17096,VKMS: adaption counter-Adaptation counter output,00 01,
IDE13837-MAS17097,VKMS: overview missing keys-Key status,valid,
IDE13837-MAS17099,VKMS: overview missing keys-Number of missing keys,0,
IDE13837-MAS17100,VKMS: overview missing keys-Missing key,00 00,
IDE13842-MAS17101,VKMS: retrieval of information list of the stored VKMS keys-VKMS key status,valid,
IDE13842-MAS17103,VKMS: retrieval of information list of the stored VKMS keys-VKMS type ID,00 15,
IDE13842-MAS17104,VKMS: retrieval of information list of the stored VKMS keys-VKMS type adaptation counter,00 01,
IDE13842-MAS18318,VKMS: retrieval of information list of the stored VKMS keys-Number of VKMS keys,6,
IDE14492-MAS18388,Secure Onboard Communication: verification failed-Failed verification status,valid,
IDE14492-MAS18389,Secure Onboard Communication: verification failed-Number of failed verifications,1,
IDE14492-MAS18390,Secure Onboard Communication: verification failed-Verification failed,00 09,
IDE14493-MAS18360,Secure Onboard Communication: signatures failed-failed signature creation,00 00,
IDE14493-MAS18391,Secure Onboard Communication: signatures failed-Failed signature creation status,valid,
IDE14493-MAS18392,Secure Onboard Communication: signatures failed-Number of failed signature creations,0,
IDE14494-MAS18361,Secure Onboard Communication: general information-Status of general information,valid,
IDE14494-MAS18362,Secure Onboard Communication: general information-ECU function,SOC participant,
IDE14494-MAS18367,Secure Onboard Communication: general information-Main function call period,5,
IDE14495-MAS18369,Secure Onboard Communication: information about internal time-Internal SOC time status,valid,
IDE14495-MAS18370,Secure Onboard Communication: information about internal time-Validity of internal SOC time,Valid SOC time,
IDE14495-MAS18374,Secure Onboard Communication: information about internal time-Internal time,00 3D 5C A0 C2 C8 57 B9,
IDE14495-MAS18375,Secure Onboard Communication: information about internal time-Jitter test status,Jitter not exceeded,
IDE14496-MAS18378,Secure Onboard Communication: Freshness Values information-Freshness status,valid,
IDE14496-MAS18379,Secure Onboard Communication: Freshness Values information-Number of Freshness IDs,18,
IDE14496-MAS18380,Secure Onboard Communication: Freshness Values information-SOC PDU ID to which this freshness information is assigned,00 09,
IDE14496-MAS18381,Secure Onboard Communication: Freshness Values information-Freshness Value query status,Freshness Value was not queried,
IDE14496-MAS1
