Date components were changed
Robyouth
C?ID=546125
Hi, I’ve changed 3 out of the six injectors on my v6 Audi q7, is it possible to find out, if the others have been changed, before I owned the car, using VCDS?
You can check whether the IMA codes printed on those injectors match what's in the respective Adaptation channels in the ECU, but beyond that, I don't know of any way, and even if they match, that doesn't mean they haven't been changed.
Robyouth
C?ID=546125
Do you mean it’ll show up those that haven’t been coded in? I’ve coded the three I changed. I’m just looking at the bolts and injector tops and some look quite clean, others don’t. I’ve had the car 3 years and changed 3, definitely thinking about changing the rest, unless they’ve been changed before. I thought it might tell you the date when they were coded
Dr Sheldon
Windsor UK
C?ID=334979
You will not get a definitive answer to that question without consulting previous owners.
If 3 went then the other 3 will go - that you can be sure of !
Robyouth
C?ID=546125
Thanks, I’ll change the other 3 asap I think. I went into limp mode towing our caravan on the M5 not great, to say the least
Robyouth
C?ID=546125
They have a QR code on them, I’ve not scanned that, I’ll try, good idea
Dr Sheldon
Windsor UK
C?ID=334979
don't they have a date of manufacturing written on it?
Means nothing !! Could have been remanufactured / refurbished 4 times since birth
iichel
Netherlands, Operation Market Garden
C?ID=284912
if the date is after for far before the birth of the car, i'm pretty sure it's not the original ones.
