2007 audi a4... multiple codes appeared at the same time.
ahidley
Pennsylvania, USA
C?ID=549110
I'm in desperate need for help with this issue. I had no codes other than the sirius radio code which is caused by me not having a subscription, so disregard that one.
I started the car on a day when it was 15 F degrees and I got all the codes listed below in the log.
in addition to the codes the speedometer stopped working as well as the cruise control. The odometer does light up and display but it does not add miles as i drive.
Now a little history. About 2 years ago I put in a new clutch and when i did that I flushed the entire brake system and clutch hydraulics and replaced it with DOT 3. I remember reading somewhere about differant brake fluids and one kind was a little thinner and that would work best with ABS . If i remember correctly it was 4.1?? Im not sure. So My question is could DOT 3 cause ABS issues when its cold outside? I have never had any brake issues in the last 2 years of owning this car and the ABS worked last week before these MIL lights appeared, it happened to be snowing and the ABS worked fine.
Now I also have a red light on the dash saying BRAKE. I know that the front brakes had about 1/4 inch of pad left a month ago. Could brakes needing replacement trigger the ABS issues?
Now there is a 001281 vehicle speed sensor code also. I cant find a speed sensor. There are 4, one in each wheel for the ABS. But what drives the speedometer? a fifth one or one of the ABS speed sensors.
I find it very odd that all these codes happened at the same time. So where is the common point to look at first?
I forgot to mention that I also have a headlight range control light flashing on the dash. The car has adaptive HIDs. It appears that the left rear abs speed sensor also controls the adaptive headlights?
Does anyone know I'd my car uses a G22 vehicle speed sensor?
Friday,27,December,2024,00:30:09:15949
VIN: WAUDH78EX7A103186   License Plate:
Mileage: 294070km-182726mi   Repair Order:
          67 69 75 76 77
VIN: WAUDH78EX7A103186   Mileage: 294070km-182726miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 8E1 910 559 F    HW: 8E0 907 559 J
   Component: 3.2l V6 FSI         0080
   Revision: --H19---    Serial number:
   Coding: 01040109180F0120
   Shop #: WSC 40636 444 999999
   VCID: 313F07F99D2ABE52E05-8064
   VINID: 9D1954607215A074410030481879395D91
049441 - No Communication with ABS Brake Control Module
               U0121 - 009 -
                    Fault Frequency: 20
                    Mileage: 293994 km
                    Mass Air / Rev.: 0.0 mg/str
                    Temperature: 15.0 C
                        Engine Off
                    Voltage: 12.04 V
001281 - Vehicle Speed Sensor
               P0501 - 008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Mileage: 294074 km
                    RPM: 1344 /min
                    Mass Air / Rev.: 196.2 mg/str
                    Temperature: -4.5 C
                        Idle
                    Load: 26.7 %
                    Speed: 8.0 km/h
Readiness: 0000 0100
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6D87DB8944821AB284D-50D0
01312 - Powertrain Data Bus
            79-00 - Please Check Fault Codes
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 01023
   Shop #: WSC 65536
   VCID: 3D272BC954624A3274D-4AA4
   Part No SW: 8E0 035 593 F    HW: 8E0 035 593 F
   Component: SDAR SIRIUS         0120
   Serial number: AUZ4Z7F1040029
   VCID: 2C01168DBA28D3BAD33-5160
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H12 3840
   Revision: 91H12384    Serial number: 0036N0G0CZZ1
   Coding: 0032607
   Shop #: WSC 06325 000 00000
   VCID: 3C2126CD4A68433A433-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 002 0070
   Subsystem 2 - Serial number: 3B9PA
   Subsystem 3 - Serial number: 0001.01.000000200000000000  63
   Subsystem 4 - Serial number: 000000  6332DRB403D98AAC5  63
   Subsystem 5 - Serial number: 98AAC5  6342DRB403DBD2A6%  63
   Subsystem 6 - Serial number: BD2A6%  6352ARB401B2E46FZ  63
   Subsystem 7 - Serial number: 2E46FZ  6362ARB401B15180A  63
   Subsystem 8 - Serial number: 15180A  63729RB401AD4AB4-  63
   Subsystem 9 - Serial number: D4AB4-  63829RB401AD4AB7/
   Subsystem 10 - Serial number: D4AB7/
   Part No: 8E0 953 549 Q
   Component: Lenks ulenmodul     0701
   Coding: 04041
   Shop #: WSC 06325
   VCID: 41DF5739289A2ED2105-4AA4
Address 17: Instruments        Labels: 8E0-920-9xx-8EC.clb
   Part No SW: 8E0 920 951 G    HW: 8E0 920 951 G
   Component: KOMBI+WFS 4     H14 0120
   Revision: 0120        Serial number: 00000000000000
   Coding: 0023261
   Shop #: WSC 06436 444 84396
   VCID: 2E051C858C04A1AAFD7-5118
Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.clb
   Coding: 0023261
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71BFC7F9588AFE52A05-4B3C
   Part No: 8E0 959 433 CG
   Component: Komfortger t T7B    4035
   Coding: 11788
   Shop #: WSC 06335
   VCID: 78A9FADD3BC0AF1A67B-4AA4
   Subsystem 1 - Part No: 8E1959801G
   Component: T rsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: T rsteuer.BF BRM 0706
   Component: T rsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: T rsteuer.HR BRM 0606
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000019
   VCID: 290FEF99B5FAC692285-807C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH03 0010
                    Fault Status: 11100100
                    Fault Frequency: 12
   Part No SW: 8E0 035 195 AC    HW: 8E0 035 195 AC
   Component: R Symphony2+    H03 0070
   Revision: 00H03000    Serial number: AUZ1Z4F2837782
   Coding: 0650102
   VCID: 6889AA9D6E503F9AF7B-5160
   Part No SW: 8P0 862 335 J    HW: 8P0 862 335 J
   Component: FSE_255x BT     H26 0290
   Revision: 00000000    Serial number: 00000005010357
   Coding: 0001677
   VCID: 3D272BC951624A3274D-50D0
End----(Elapsed Time: 05:03, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
Your ABS module is completely MIA. Check relevant fuses.
ahidley
Pennsylvania, USA
C?ID=549110
Well I checked all relevant fuses and all were OK. But I couldn't find a designated fuse for the ABS module.
After hours of searching online, I've found several other people with the same issue and one pointed to a service bulletin speaking of cold solder joints failing right after an ABS activation. That makes sense since I did activate it a week ago.
So I've ordered a used one with the same part number and revision.
Do I need to code this new ABS module? If so how and is there a rosstech video?
Will my vcds hex v2 program( code) it ?
Thanks...
dareckim11
Glasgow Scotland
C?ID=404683
It would be a good idea to check the voltage at the ABS pump plug. Before replacing it.
Here you will find the schematics erWin. Buy for 1 hour and download all.
Yes. I will code the ABS pump.If you have done any auto scans before,
you will find them in the C:/Ross-Tech/VCDS/Scans.
The ABS pump coding will be there.
Dr Sheldon
Windsor UK
C?ID=334979
Use what Audi recommend - easy !!
No !!
You have no need to know this !! However all 4 wheel speed sensors are wired to ABS, Speedo gets the info from ABS Over the CAN Network.
No - not quite true.
You need to Fix This First !!
U0121 - 009 -
Worry about the Speed sensor fault after that.
ahidley
Pennsylvania, USA
C?ID=549110
I'd like Thank everyone for their input. A used replacement abs module has been ordered. I would have gone to the local junkyard to get one but yesterday it was 0F degrees here . Today it's 32F so I could have gone today buy one is already ordered and I know it's the correct part number and Revision vs me searching the junkyard aimlessly..
I also have a Bently manual, Haynes, and https://charm.li/.
Hopefully it'll be a little warmer when the part arrives because I hate working outside when it's 0F . But it needs to get fixed as it's my daily driver.
I'll report back if I have issues and with a status report when it's fixed.
Again thanks for the responses..
Ahidley
Ziddywerks
Northern NJ USA
C?ID=208579
My money is on abs module taking a shit, they are known for failing a rebuild is your best option.
ahidley
Pennsylvania, USA
C?ID=549110
UPDATE: ok I got a used ABS control module and installed it today. I have the same errors as originally posted.
Whats my next step?
Many questions.
1- There is also a code for vehicle speed sensor. But for the life of me i cannot figure out which one it is?
2-address 08 What is HVAC ? Heating ventilation and air conditioning?
3-Code under 08 HVAC . If this is the heating and air conditioning, how could it be related to the ABS? Note: the heating and air seems to work fine.
4- Could I possibly get a description of what the can bus is and where its located? I have never understood that...
signed,
Seriously confused Ahidley
          67 69 75 76 77
               U0121 - 009 -
                    Fault Frequency: 20
                    Mileage: 293994 km
                    Temperature: 15.0 C
                        Engine Off
                    Voltage: 12.04 V
                    Mileage: 294074 km
                    RPM: 1344 /min
                    Temperature: -4.5 C
                        Idle
                    Load: 26.7 %
                    Speed: 8.0 km/h
   Coding: 00000
   Coding: 01023
   Shop #: WSC 65536
   Coding: 0032607
   Coding: 04041
   Shop #: WSC 06325
   Coding: 0023261
   Coding: 0023261
   Coding: 00002
   Coding: 11788
   Shop #: WSC 06335
   Coding: 0000019
                    Fault Frequency: 12
   Coding: 0650102
   Coding: 0001677
Dr Sheldon
Windsor UK
C?ID=334979
Whats my next step?
What you should have done before guessing at the fix !!
Get a wiring Diagram and check the Powers and Grounds at the ABS Pump using a 21w Bulb, Volt Meter and Back Probe. Testing to be done with the ABS Module plug Connected
ahidley
Pennsylvania, USA
C?ID=549110
That's easier said than done. I have the wiring diagrams. My issue is the location of the connector at the abs module and the routing of the cable. I can't just pull the abs module out alittle to gain access because the brake lines are attached. Access is restricted. Note the car has a v6 3.2.
Why would the abs connector need to be connected to do this test?
Is there a relay used to power the abs module?
Dr Sheldon
Windsor UK
C?ID=334979
Every thing I do is Non Intrusive - It makes sense in my head - Just the way I was taught and it works for me !!
Ok you do the test with it unplugged - What we got ?
Also make sure have continuity on the CAN lines from ABS to Engine !
Controller Area Network (CAN) bus is a communication system that allows modules to communicate with each other.
There are several variations however the one concerning you is the Powertrain Bus. It is the network that the Engine, ABS, Airbag, Instruments, Immobiliser are on (amongst others)
It is a 2 wire system and those wires are always twisted together (to manage interference) If one wire is down the whole lot is down !! It will not work on one wire alone !!
If your car has a Gateway - Then that is a gateway where all the different CAN Networks meet and exchange information (Loosely Speaking)
A B7 A4 does not have a Gateway. Powertrain CAN is brought directly to pins 6 and 14 of the OBD-II socket. So it ends up being a mixed bag. Some modules do diagnostic communications directly on the powertrain CAN while others are still on the K-Lines on pins 6 and 14.
Dr Sheldon
Windsor UK
C?ID=334979
I had my doubts !
Op for sure has a CAN issue as several Modules are not seeing ABS
A quick glance at the WD suggests that K Line only exists at DLC Pin 7 and Dash Panel - That is all i could see.
Nah, it goes to a number of other modules in a B7 A4. In fact, depending on how the car is equipped, it can have two K-lines, K1 on pin 7 and K2 on pin 15.
Dr Sheldon
Windsor UK
C?ID=334979
Bosch refer to Pin 7 as K Line and Pin 15 as L line - From what I can see both K & L are very similar (for diagnostic purposes) in all but name.
Yes, but the L-line is a very old and deprecated concept. It was used in the late 80s and early 90s as a dedicated, uni-directional "wake up" line for ECUs. Starting about 2001, Audi had so many control modules in some models that they were exceeding some electrical specification and moved some modules to a second K-Line on Pin 15. Since as you mentioned, they are very similar, doing this was backwards compatible with how the L-line was previously used.
ahidley
Pennsylvania, USA
C?ID=549110
Hello UWE And Dr Sheldon, After looking through many pages of the Bently manual, in the wiring diagrams there is K-line lo and K-line hi. Perhaps that's how it's designated?
ahidley
Pennsylvania, USA
C?ID=549110
Update, So as posted above, I installed the used abs module with the same results as the original abs module, aka, it doesn't show up under address 03 or anywhere in the vcds scan. But there are plenty of codes looking for it. So off to the Bently wire diagrams I go. As I'm searching through the maze of wiring diagrams, abs info, part locations(fuses, grounds, connectors, etc) I saw a warning paragraph. It said that if brake fluid was spilled on the abs connector to blow it off with an air compressor. Well it's pretty impossible to remove the 6 lines, 2 with the master cylinder on top of them, without spilling brake fluid. So I figured I'd blow out the connector. Now understand that this connector has a plastic cover to align the plns so that they don't get bent and due to that you can't see the connectors inside the plug due to the plastic blocking the view. So I blow it out and write powder comes out, a lot of it. Now I know the guy that had owned this car before I bought it and he was always taking it to the car wash and spraying it with the high pressure hose. He also washed the engine almost weekly. So I'm sure that's where the corrosion came from. So I sprayed the connector male and female with walmarts version of wd40, then air again, put it together and magically the vcds detected it. I deleted all codes except the new steering angle code and coded the replacement abs module with the correct code and then was able to use a link in ross-tech to I believe zero the steering angle error. That link had step by step directions. That code went away. I drove the car and all MILs are gone and the speedo, odometer, and cruise work now.
I do thank you and others for the assistance. I'm grateful..
Talk to you next week when the next check engine light comes on!!
Ahidley
