ABS long coding error after ecu swap
Ruben Andujar
Dominican Republic
C?ID=603468
Sunday,22,December,2024,10:11:37:12167
VIN: WAUZZZ8V2EA066582   License Plate:
Mileage: 64026km-39783mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 47 52 55 5F A9 BB
          BC
VIN: WAUZZZ8V2EA066582   Mileage: 64026km-39783miles
Address 01: Engine (J623-CJXE)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---    CVN: BCFA87FB
   Coding: 0A1D00322406010B3000
   Shop #: WSC 127111 775 822162
   ASAM Dataset: EV_ECM20TFS0208V0906259A 001006
   ROD: EV_ECM20TFS0208V0906259A.rod
   VCID: 3E22E1E9C0F54D8A6D7-806A
   VINID: 9D196AAAA22609544018614808D70E2D6E
Readiness: 1010 0001
   Part No SW: 0D9 300 011 N    HW: 02E 927 770 AN
   Component: DQ250-6A MQB  H52 4033
   Revision: 05652104    Serial number: TFK01308020145 CVN: 0000D815
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 201E3F915A411B7A7FB-8074
10906 - Cooling Oil Valve
          P179D 00 [00000010] - Electrical Malfunction
   Revision: 00000000    Serial number: 625030000007F3
   Coding: 32F16BA254260A72017C070841C5694CD62A5080E08296B6004150388505
   Shop #: WSC 51460 006 104857
   ROD: EV_Brake1UDSContiMK100IPB_033_VW48.rod
   VCID: 7BA428FD936798A20A9-802E
0297 - Steering angle sensor
          B1168 16 [00001000] - Voltage Too Low
                    Reset counter: 109
                    Mileage: 64026 km
                    Date: 2024.12.21
                    Time: 00:01:16
8308 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 69
                    Mileage: 64026 km
                    Date: 2024.12.21
                    Time: 00:01:16
          C1146 02 [00001001] - Signal Failure
                    Reset counter: 69
                    Mileage: 64026 km
                    Date: 2024.12.21
                    Time: 00:01:26
   Revision: 00021000    Serial number: 0194354570 Dataset Number: 8V0909577C  0009
   Coding: 030C1C
   Shop #: WSC 12345 123 61029
   VCID: 3A2AEDF9DCDD61AA51F-806E
   Part No SW: 8V0 820 043     HW: 8V0 820 043
   Component: AC Automat    H13 0032
   Revision: 20024000    Serial number: 00000000149492
   Coding: 03000014110000010000000000001500
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 6FBC0CADD71FF402B61-803A
   Humidity sensor: exterior:
   Serial number: 39C8C6C6000000000001
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011325400752 Dataset Number: 8V0909514C  0063
   Coding: 04111C42C0C106FD03844004B31C07A0081C000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77AC34CDAF4FBCC26E1-8022
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 130825  041 0580
   Serial number:         130903192051
   Coding: 0A47F7
   Serial number: 21702255
   Coding: 06006C
   Subsystem 3 - Part No SW: 8V0 941 531 G    HW: 8V0 941 531 G
   Serial number: 04 07 2013  00001525
   Serial number: 000000000ZY1321112RB
   Serial number: 00000000000027718282
   Sunroof control module:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000JBMYE00000
   Coding: 101F00
   Part No SW: 5Q0 919 298 B    HW: 5Q0 919 298
   Component: PARKHILFE PLA H11 0033
   Revision: --------    Serial number: 61131310200203 Dataset Number: 8V0909526C  0034
   Coding: 0030061011
   ASAM Dataset: EV_EPHVA2CAU3700000 003015
   ROD: EV_EPHVA2CAU3700000_003_AU37.rod
13637426 - Databus
                    Reset counter: 109
                    Mileage: 64026 km
                    Date: 2024.12.21
                    Time: 00:01:16
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    011 0361
   Serial number: 003M2R0339C  Dataset Number: 8V0909602C  0007
   Coding: 98CCC000000000005C540000004800000065
   VCID: 4BC4B83D8347E822FA9-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 209 13
   Serial number: 35767000000E365CDD08
   Subsystem 2 - Part No SW: -----------    HW: 480 000 209 13
   Serial number: 358670000008865CDD08
   Subsystem 3 - Part No SW: -----------    HW: 480 400 909 13
   Serial number: 3516502B51118713402N
   Subsystem 4 - Part No SW: -----------    HW: 480 400 909 13
   Serial number: 3526502B7111871323F/
   Subsystem 5 - Part No SW: -----------    HW: 480 400 908 13
   Serial number: 35565029B1088B032283
   Part No SW: 8V0 953 521 M    HW: 5Q0 953 549
   Revision: --------    Serial number: 10091304220434 Dataset Number: ----------
   Coding: 8418
   ROD: EV_SMLSKLOMQB_009.rod
   VCID: 44D69301AE19275A3B3-8010
   Part No SW: 8V0 920 870 N    HW: 8V0 920 870 N
   Component: KOMBI         H03 2212
   Coding: 078D081A2B9000080501BE00000000
   Shop #: WSC 38956 123 104857
   VCID: 46D289099825154A257-8012
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0000951645 Dataset Number: 8V0909515C  0044
   Coding: 0101000820085A005B0002281C0B00000001000000000000000000000000
   GVL: 01543C1000000600400C10000000C80000000000000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3B24E8FDD3E758A24A9-806E
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 14 08 2013  E0226207
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000187657002
   Coding: 0900000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73B400DDBB37D0E2529-8026
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        012 0006
   Serial number: 05091302090394 Dataset Number: 8V0909872D  0025
   Coding: 005D1E205C00040000001002
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 3FDC9CEDC7FF4482661-806A
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Dataset Number: 8V1909852A  0004
   Coding: 8300
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 3334C0DDFBB790E2929-8066
   Part No SW: 8V0 035 465 A    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0370
   Serial number: AUZ8ZAD0900EFFM Dataset Number: 8V0909510B  0014
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   VCID: 3632F9C9E8C585CAB57-8062
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       012 0006
   Serial number: 08091303111125 Dataset Number: 8V0909873D  0024
   Coding: 005D16205E00040000001002
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   Part No SW: 7P6 907 357 B    HW: 7P6 907 357 B
   Component: AFS-ECU       H01 0040
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865E  0029
   Coding: 012A00002B200200
   ASAM Dataset: EV_HeadlRegulLEDAFSMQB 001001
   ROD: EV_HeadlRegulLEDAFSMQB.rod
   Subsystem 1 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H06 7510
   Coding: E00100
   Subsystem 2 - Part No SW: 7PP 941 472 E    HW: 7PP 941 472 E  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H06 7510
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7000
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7000
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
   Component: MU-S--ER      040 0420
   Serial number: A3E01009131681 Dataset Number: 8V1909545B  0032
   Coding: 017303000000000021220002001A00002F0002640100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3436C3C1FEB997DA8B3-8060
   Multimedia System 1:
   Subsystem 1 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H48 0013
   Serial number: AUZ8Z9DG602GYX
   Subsystem 2 - Part No SW: 8V0 919 614 C    HW: 8V0 919 614 C
   Component: ControlUnit_B  H33 0037
   Serial number: C1000004071300010172
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0008
   Serial number: 130702201131
   VCID: 7DA026E58D73969234D-8028
   Part No SW: 5Q0 959 395 A    HW: 5Q0 959 395
   Component: TSG HFS       010 0006
   Serial number: 28081306070356 Dataset Number: 8V0909897B  0012
   Coding: 004D16204000040000001002
   ROD: EV_DCURearDriveMAXKLO.rod
   Component: TSG HBFS      010 0006
   Serial number: 28081303110353 Dataset Number: 8V0909896B  0012
   ROD: EV_DCURearPasseMAXKLO.rod
End----------(Elapsed Time: 01:52, VBatt start/end: 13.7V/13.5V)-----------
Ruben Andujar
Dominican Republic
C?ID=603468
I try to disable ASS in address 01 long coding but not allowed, throws an error "incorrect coding sequence" or something like that.
Ruben Andujar
Dominican Republic
C?ID=603468
@Ruben Andujar,
Would You post new, fresh Auto Scan, please.
yes, sure.
Thursday,26,December,2024,17:03:50:12167
Mileage: 64069km-39810mi   Repair Order:
          BC
VIN: WAUZZZ8V2EA066582   Mileage: 64069km-39810miles
Readiness: 0010 0001
   Coding: 32F16BA254260A72017C070841C5694CD62A5080E08296F6004150388505
   Coding: 030C1C
   Coding: 0A47F7
   Coding: 06006C
   Coding: 101F00
   Coding: 0030061011
   Coding: 8418
   Generator:
   Coding: 8300
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Fault Frequency: 66
                    Reset counter: 115
                    Mileage: 64058 km
                    Date: 2024.12.24
                    Time: 17:27:14
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 13.50 V
                    Temperature: 79.0 ∞C
                    KFC: 4B
                    KFA: 00 04
                    Freeze frame conditions: 21
                    uAdSensI_U5VFiltered_xdu16: 5.09775 V
                    uioUdNotFilt_xdu16: 13.64 V
                    uAdSensI_SwitchedKl30_xdu16: 13.63 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Coding: E00100
   Coding: E00100
   Coding: E00100
   Coding: E00100
End----------(Elapsed Time: 01:50, VBatt start/end: 12.4V/12.3V)-----------
Thursday,26,December,2024,17:04:53:12167
Gateway Installation List:  5Q0 907 530 M
