Resolved Audi C7 ABS Coding Rejected : Out of Range
Resolved
boostboy
hello i am having issues entering abs coding. It says coding rejected out of range. Ive read through all threads regarding this and tried adding 00 at the end and tried changing WSC number but it still will not accept. The coding was calculated based on PR codes and should be absolutely correct however it will not take. Only my original coding gets accepted. Any ideas?
ABS module is original. I have deleted sport diff (no dtc codes left) and swapped to zf8 transmission from C7 A6 Car is 2013 Audi S6
heres the coding I am trying to enter for ABS 65A74F01A6EDF2805B00 I have tried several other codings and they are all rejected. Only coding that accepts is my original coding.
Wednesday,18,December,2024,13:27:57:50406
VIN: WAUF2BFC0DN045902   License Plate: PARKSTUCKS6
Mileage: 169362km-105236mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 28 34 36 3B 3C 42 44 46
          47 52 53 55 56 5F 62 6C 72 85 8B 8E 8F 90 A9 BA
VIN: WAUF2BFC0DN045902   Mileage: 169362km-105236miles
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 560 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / X62 0008
   Revision: NCX62---    CVN: E0042D3D
   Coding: 1A2A003265460A0E1000
   Shop #: WSC 04919 123 12345
   ASAM Dataset: EV_ECM40TFS0114G0906560B 001008
   ROD: EV_ECM40TFS0114G0906560B.rod
   VCID: 270BFB33AF615A523E1-8072
   VINID: 9D1956092593014780105240087A381B9C
17875 - Exhaust Pressure Control Valve
          P0475 00 [00100111] - Electrical Malfunction
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:55
                    Engine RPM: 740.00 /min
                    Normed load value: 5.5 %
                    Coolant temperature: 92 °C
                    Intake air temperature: 36 °C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 13.970 V
                    Engine status: COENG_RUNNING
17876 - Exhaust Pressure Control Valve 2
          P049F 00 [00100111] - Malfunction
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:55
12352 - Coolant Pump for Intercooler
          P023A 00 [00100111] - Open Circuit
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:55
                    Normed load value: 7.1 %
                    Voltage terminal 30: 14.017 V
4715 - No Communication with Instrument Cluster
          U0155 00 [00100111] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:59
                    Engine RPM: 652.00 /min
                    Normed load value: 5.1 %
                    Voltage terminal 30: 14.065 V
                    selected gear-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 0
Readiness: 1110 1100
   Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
   Component: 0BK 40TFSIRdW H16 1006
   Revision: --H16---    CVN: 000FD926
   VCID: 71BFD56B512554E2A05-8024
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 65B64F01A66DF2805B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 3829284F72DFC5AAA7B-806C
0081 - Function Restricted due to Missing Message(s)
          U1111 00 [00001001] - -
          [ComScl_PDU_QSP_02_Timeout]
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 01
                    Uz: B9
   Part No SW: 4H0 907 064 DR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0510
   Coding: 0D882007000000000000
   VCID: 7CA1F45F06E7298A033-8028
   Serial number: 2312000163209015
03175 - Invalid Data Set
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:51
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 04081200040002
   Coding: 688120B84D
   Shop #: WSC 63577 004 1048576
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 629DAA2784C3FF7A29F-8036
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001396961
   Coding: 0600A00116349FE28F0080C7A0002908CF98D208A2080321800008402000
   VCID: 6FBBD31347914212B61-803A
   Component: WWS57X 120717  H36 0080
   Serial number:         120725135243
   Coding: 0045F7
   Serial number: 20481298
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 03 08 2012  00000464
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2FZL02
   Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103816000001672000
   Coding: 020300
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 2A088046000000000001
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061221400866
   Coding: A8C90A
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 77ABEB733F410AD26E1-8022
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H17 0400
   Serial number: 00000000000000 Dataset Number: 4G0909863C  0034
   Coding: 7601010102
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2809F80FA27F552A37B-807C
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [00001001] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:21:03
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.331 V
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D8002A1VP Dataset Number: 4G0909602E  0007
   Coding: 303234373131303030344A55304C34473053
   VCID: 33331F636BB926F2929-8066
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H15 0045
   Serial number: 6940000Y120000HD2S0U
   Serial number: 3575HRB405N1G0QMDP1$
   Serial number: 3585HRB404P1G1DOB17B
   Serial number: 3515JRB40511D2AS5PKD
   Serial number: 3525JRB40611D2ASNGQU
   Serial number: 3554VRB40551DKASL9F2
   Serial number: 3564VRB404R1DKAS60F0
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372LH5000OT
   Coding: 00043C
   VCID: 3829284F725FC5AAA7B-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 29 05 2012  B0185116
   Part No SW: 4G0 920 981 M    HW: 4G0 920 981 M
   Component: TBenUsaAccNv  H76 0515
   Revision: 28460207    Serial number: 658090812596024
   Coding: 03CF09051F41CF05020200
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 3537217B65CD38C2BCD-8060
9459739 - Fuel Level Sensor 2
          B1058 1B [00001001] - Resistance Too High
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AA
   Component: J533--Gateway H11 0035
   Revision: --------    Serial number: 00000000637233 Dataset Number: 4G0909515C  0062
   Coding: 00E1034800
   GVL: FDAFE84CFEE2600D5100
   ASAM Dataset: EV_GatewPkoUDS 001016
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790034026
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0076
   Serial number: 06081200040425
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 372B2B737FC1CAD2AE1-8062
0116 - Temperature Sensor for Rear Right Seat
          B1114 15 [00001001] - Open or Short to Plus
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
0124 - Rear Right Seat Heater
          B1118 15 [00001001] - Open or Short to Plus
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Dataset Number: 4G0909553F  0034
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_003_AU64.rod
   VCID: 2E050E17809B0B1AFD7-807A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000036152047
   Coding: 00581B0000002001000001010101102030303232203232
   Shop #: WSC 02311 785 00200
   VCID: 77ABEB733FC10AD26E1-8022
   Component: SARA 6D red   H02 0053
   Revision: --------    Serial number: EJ1BPA7E003TW- Dataset Number: 4G0909573C  0006
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0040
   Revision: 00H01000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 3039106F962F1DEAEFB-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H01 0040
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F13.08.1200H010003CF20039ÿ
   Subsystem 4 - Serial number: F20039ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0506
   Coding: 011F17005E00628002000013
   VCID: 45D751BB35ADA8422CD-8010
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0006779330 Dataset Number: 4G0909852H  0027
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1A6794A32FFA99F-8066
   Revision: 00002001    Serial number: 0181693737
   Coding: 01060E3A00FA418583B00880020503050000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000100672
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO17565053
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00001757762
03615 - Rear Right Reading Light
                    Fault Status: 01101100
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:55
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000003177
   Coding: 030000
   VCID: 1C61D4DFE6A7898AA33-8048
   Component: TSG BF        H03 0506
   Coding: 011F17005E00628002000002
   VCID: 46D556B708ABA35A257-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000438637 Dataset Number: 4G0909522B  0002
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B030703B3897E32DA9-807E
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 120814-0004-004
   Coding: 12216F33701AA400
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
530180 - Local Data Bus
          U10BA 00 [10001001] - No Communication
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:56
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156H$0C7621276
   Coding: 020007010000000001
   VCID: 211FE52BC1C5A462705-8074
   Part No SW: 4G0 035 746 B    HW: 4G0 035 746 B
   Component: H-BNT-NA      H49 0549
   Revision: --------    Serial number: 194H50C7508396
   Coding: 060200000203F9EF75128F1E00000003100001000000000000
   VCID: 2615F637A8EB435A057-8072
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LH3000KN
   Subsystem 3 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
02259 - Information Display and Control Head (Front) (J685)
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:57
                    Voltage: 14.30 V
03787 - Rotation Mechanism for Display Module Front
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
                    Voltage: 14.40 V
   Component: TSG HL        H03 0506
   Coding: 010F17004000628002000002
   VCID: 49CF5D8B19B54C22C85-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J27G4HO
   Coding: 1080004
   VCID: 2615F637A4EB435A057-8072
   Component: TSG HR        H03 0506
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Revision: --------    Serial number: 262130025421000 Dataset Number: 4G0909547C  0028
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F637A86B435A057-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Coding: 7601010102
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000050808127
   Coding: 04819A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0161 - Video Cable for Image Processing
          C1107 02 [00001001] - Signal Failure
          [No_camera_found_on_startup]
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:21:02
                    Outside temperature: 18.5 °C
                    Voltage terminal 15: 14.4 V
                    Control Module temperature: 23.0 °C
   Dataset Number: 4G0909614B  0005
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F156B91A514E2E05-8064
   Dataset Number: 4G0909615B  0005
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 120717201452
   VCID: 2C01041FB687790AD33-8078
0005 - Incorrect Vehicle Type
          U10D9 00 [00001001] - -
          [Keine Funktion durch Falschverbau im Fahrzeug--> keine Funktion]
                    Reset counter: 78
                    Mileage: 169362 km
                    Date: 2024.12.18
                    Time: 13:20:53
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804000593204 Dataset Number: 4G0909578A  0009
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X_AU57.rod
   VCID: 6695B63768EB835AC57-8032
End----------(Elapsed Time: 02:44, VBatt start/end: 14.4V/14.5V)-----------
Address 02: DTCs cleared
Address 0xA9,4G0 907 159 B,UDS Basic Settings,IDE00498-Resetting of all adaptation values
Address 0xA9,4G0 907 159 B,UDS Selective Output Tests,IDE03772-Structure-borne sound actuator
Address 09,4H0 907 063 CG,recoded (Long Coding),from,0600A00116349FE28F0080C7A0002908CF98D208A2080321800008402000,to,0600A00116349FE28F008087A0002908CF98D208A2080321800008402000,(63577/004/104857),
Address 19,4G0 907 468 AC,recoded (Installation List),from,FDAFE84CFEE2600D5100,to,FDAFE84CFEE2600D4100,,
Address 19: DTCs cleared
Address 19,4G0 907 468 AC,recoded (Installation List),from,FDAFE84CFEE2600D4100,to,FDAFE84CFEE2600D5100,,
What transmission did this car come with originally?
Have you considered the possibility that the ABS module has application-specific software in it?
boostboy
It originally had DL501. and honestly no, this is all new to me but with this in mind I grabbed A6 coding from same SW version online and it accepted it. So it is probably not understanding the codes. My function restricted code is gone but now i have an "incorrectly coded" error probably because there is a 4.0t engine in here not 3.0t. My guess is that i need to figure out how to tell it there is rs7 or s6 engine in here but in A6/A7 SW language(or I should say PR codes?). IF that is even possible of course
Monday,23,December,2024,16:40:21:50406
Workshop Code: 210 01369 040505
VIN: WAUF2BFC0DN045902   License Plate: ABSINCORRECTLYCODED
                Address 03: ABS Brakes       Labels: 4G0-907-379-V1.clb
Control Module Part Number: 4G0 907 379 J    HW: 4G0 907 379 J
  Component and/or Version: ESP PREMIUM   H09 0361
           Software Coding: 44A70F0122E5F0809B00
            Work Shop Code: WSC 01369 210 40505
              ASAM Dataset: EV_ESPPremiAU57X 004028 (AU57)
0790 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
          [VarECULuFeVariantCodingIncorrect]
                    Reset counter: 106
                    Mileage: 169524 km
                    Date: 2024.12.23
                    Time: 16:35:37
                    VzRef: 00
                    Bit Info 1: 80
                    Bit Info 2: 0F
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 71
                    Uz: 94
boostboy
The more i think about it i think I should try changing the first 2 values i believe those are for engine type. my original coding is 65A74F01A6EDF2805B0000 so Im guessing 65 is S6 CEUC engine. I dont know what Rs7 CRDB engine would be for this SW version, I will try to dig and try different values. But i think 44 signifies 3.0t engine so I will play around with it and see if anything takes and gets rid of that error.
Mwell
EU
C?ID=439106
According to VCP PR Coder for 4G0907379H J K and L:
65B64F01A66DF2805B00 original
65A74F01A6E5F2805B00 with DL501->ZF8 swap (PR G1D->G1G) as well as sport diff removed (PR GH2->GH1), rejected
65B74F01A6EDF2805B00 zf8 swap only, rejected
65A64F01A665F2805B00 sport diff removal only, not tested yet but probably rejected too
In more detail:
For both (DL501->ZF8 as well as sport differential removal):
byte 01: B6 -> A7 (10110110 -> 10100111: bit 3 disable, bit 7 enable)
byte 05: 6D -> E5 (01101101 -> 11100101 bit 0 enable, bit 4 disable)
For DL501->ZF8 only:
byte 01: B6 -> B7 (10110110 -> 10110111: bit 7 enable)
byte 05: 6D -> ED (01101101 -> 11101101: bit 0 enable)
For sport diff removal only:
byte 01: B6 -> A6 (10110110 -> 10100110: bit 3 disable)
byte 05: 6D -> 65 (01101101 -> 01100101: bit 4 disable)
Would be great if one day VCDS had such capability (calculating new coding with PR codes) for A6 4G ABS modules.
You should have enough autoscans by now to reverse-engineer the coding.
These codings are not working for some reason so there's error with VCP PR Coder for this ABS module.
Mwell
EU
C?ID=439106
I guess the out of range check is calculated for each group of two bytes ?
65A7 4F01 A6ED F280 5B00 Notice the 3rd group of 2 bytes A6ED is out of range and rejected by the module.
65A7 4F01 A6E5 F280 5B00 The correct coding has A6E5 which is still in the allowed range (edit: this one is rejected too, still out of range)
At least the out of range check is not calculated or each byte because e.g. the following RS6 coding 64 BF 99 01 26 FD 99 80 CB 00 is accepted, even though FD > ED.
AINils
Germany (AIB)
C?ID=56975
Transmission coding is in Byte 1 > Bit 0 - 2 and mirrored in Byte 5 > Bit 5-7
boostboy
Thank you for the help,that makes sense. I did get some rs6 coding to work but then there was errors for the sport diff.
It accepted this rs6 coding 64BF990126FD9980CB00 and this a6 coding 44A70F0122E5F0804B00 but then there was faults for air suspension and engine type.
I tried all of the suggested codes as well and it still gets the coding rejected error. Man these ABS modules are finicky and complex.
Mwell
EU
C?ID=439106
As ZF8 & DL501 cars got the same bits here (101), that means there's no ABS coding difference between those 2 gearboxes. Maybe it's different for manual vs auto transmission only.
So OP should try coding 65A64F01A665F2805B00 (sport diff disabled), I compared a few codings from cars with and without sport diff and this one should definitely work.
NEtech
Denmark
C?ID=56995
If I compare my Autoscans, I get this:
65A74F01A6E5F2805B00 [PR-G1G] 8 speed 4WD
65A64F01A665F2805B00 [PR-G1D] 7 speed 4WD
Mwell
EU
C?ID=439106
Is one of them or both of them real, working codings (i.e. not just calculated)?
NEtech
Denmark
C?ID=56995
Calculated, like your I guess.
Mwell
EU
C?ID=439106
Yeah the problem is, they don't work even though vcp pr coder suggests them. But its ok if the abs module doesn't care which gearbox is installed and we only code the sport diff removal.
boostboy
I am finally home now and was able to enter the coding.
Big thanks to Mwell and everyone else that helped. This code from Mwell worked for me 65A64F01A665F2805B00. Now there are no more ABS codes at all.
