2011 Jetta TDI ASR or ESP Button Retrofit
Billyska
Canada
C?ID=603240
Hi, Guys i installed the button for traction Control, followed al steps and tested it in VCDS and the button is activating but cant get traction control to turn on and off. only the old manual way with Hazards and 5 times gas pedal press. ( So Stupid!!) Anyhow further in the instructions it says maybe you need to code the ABS module. but i thought this was for post 14+ models... My Abs Module Long Coding only has 18 Bytes and the instructions show 19 Bytes, To change an option in byte 17 and one in byte 19? Any ideas, has some one successfully done this? Below is a scan of everything. And also I'm unsure why my long coding starts with B when all the instructions start with 1A.. i would like to get this working being it so annoying doing it the manual way. and I've doubled checked all wiring... Positive, negative, one to headlights switch illumination and the 4th wire straight to pin 9 starting from the Big Brown Wire or pin 8 starting from the small brown wire. Double and tripled checked. don't get it.... Also under faults anyone know about the radio one? i swapped radios and added bluetooth.. i know about the satelite antenna because dont have one but what about Tuner Not Enabled/Activate. my radio is working fine on all signals.
Saturday,21,December,2024,20:41:23:22097
VCDS Version: 24.7.1.0  HEX-V2 CB: 0.4643.5
VIN: 3VWDL7AJ8BM077513   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 44 56 77
VIN: 3VWDL7AJ8BM077513   Mileage: 234230km-145543miles
   Part No SW: 03L 997 030 P    HW: 03L 906 019 DA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 01920 003 1048576
   VCID: 3B24E8E89F60C5C24A9-806E
   VINID: 0E69D470745A2127401C71410CADB75194
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351112    Serial number: 00001012201002
   Shop #: WSC 00066 000 00000
   VCID: 176C1458C388C1A28E1-8042
   Revision: 00H31001
   Coding: B14B400C492900018D1002E5921C0042210000
   Shop #: WSC 00066 123 12345
   VCID: 7BA428E8D3E005C20A9-802E
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 Q    HW: 5C0 820 047 Q
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000256126
   VCID: 2E02D1BC5C12206AFD7-807A
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0257
   Revision: B2066001    Serial number: 03311043110261
   Coding: 73994F3808230F0000382000240884C40082502E60000000300000000000
   VCID: 2F3CCCB857182962F61-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3463
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3463
   Coding: 820000
   Subsystem 3 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Serial number: 40000000000000068058
   Coding: E30000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3463
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3463
   Coding: 800000
00901 - Back-Up Lamps
                    Fault Frequency: 11
                    Reset counter: 218
                    Mileage: 234167 km
                    Date: 2019.05.14.
                    Time: 09:50:14
03444 - Ignition Starter Switch
                    Reset counter: 2
                    Mileage: 234219 km
                    Date: 2019.05.14.
                    Time: 00:24:40
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTD09J77H   Dataset Number: 160003v____ 0086
   Coding: 00003935
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3436C3D4BEBE0ABA8B3-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1100002ZK40U
   Coding: 303243
   Serial number: 3572MSME222B5659ZZZZ
   Serial number: 3582MSME1F045659ZZZ$
   Serial number: 3516KSME3815120EZZZN
   Serial number: 3526KSME4246130EZZZO
   Component: F.Sens.Fahr  H01 ----
   Serial number: 3556LSME71081909ZZZT
   Component: F.Sens.Beif  H01 ----
   Serial number: 3566LSME26051909ZZZR
   Part No SW: 5C6 920 850 C    HW: 5C6 920 850 C
   Component: KOMBI         H07 0406
   Coding: 370800
   Shop #: WSC 00066 123 00149
   VCID: 290822A0697C4752285-807C
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0257
   Revision: B2066001
   Coding: 102200
   VCID: 70BE0FC48AA6769AAFB-8024
   Component: IMMO          H07 0406
   VCID: 6A8A1DACACFA8C4AE1F-803E
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3436C3D4B23E0ABA8B3-8060
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H15 0043
   Revision: -----27S    Serial number: VWZ4Z7K1176165
   Coding: 2500040000
   VCID: 61987A80514CCF12305-8034
02633 - Antenna for Satellite Tuner
                    Reset counter: 215
                    Mileage: 234167 km
                    Date: 2019.05.14.
                    Time: 09:50:13
                    Reset counter: 216
                    Mileage: 234167 km
                    Date: 2019.05.14.
                    Time: 09:50:13
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661007459 Dataset Number: 5K0035730E  0001
   Coding: 0A10040000010110
   Shop #: WSC 62613 666 28888
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270C24987F6871223E1-8072
End----------(Elapsed Time: 01:13, VBatt start/end: 14.2V/14.2V)-----------
Billyska
Canada
C?ID=603240
anyone?
First post 9:18 PM on a Saturday evening.
Bump at 9:43 AM on the Sunday morning?
Patience, Grasshopper! ;)
Go here:
Grab the .ZIP file linked in the first post. Look at the file named "1K0-907-379-60EC1-BJ.LBL". There's lots of good info in there. :)
Billyska
Canada
C?ID=603240
thanks!!
Billyska
Canada
C?ID=603240
Go here:
i went through and read everything but im a bit confused as to how to get the new long coding for mine... sorry new to this but how do i get mine from 18 bytes to 19 bytes for my specific car, so that i can enable the esp function after
