if I run an autoscan on two different cars, and they have different engine ECUs (just an example), but VCDS indicates the same label file... is it correct to assume that in the coding, the same byte/bit will perform the same function on both modules? even if coding lenght is different between modules?
such as:
Address 01: Engine (J623-DFYA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 012 Q HW: 05E 907 309 G
Component: R4 1.5l TFS H20 1319
Revision: 89H20000 CVN: 36C612D2
Coding: 0125003223641D0870086000000000000000000000000000
Shop #: WSC 46837 004 1048576
ASAM Dataset: EV_ECM15TFS01105E906012Q 002005
ROD: EV_ECM15TFS01105E906012Q.rod
VCID: 2D07F5A7FD9090E2C4D-8078
VINID: 9A38EAAAA6DCA9D8801411C4102565D3A2
Address 01: Engine (J623-CZCA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 HB HW: 04E 907 309 BH
Component: R4 1.4l TFS H25 4418
Revision: R7H25--- CVN: 80019C30
Coding: 0119003A23441D082000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ECM14TFS01104E906027HB 001006
ROD: EV_ECM14TFS01104E906027HB.rod
VCID: 6B833BBF03045ED29A9-803E
VINID: 9E69EAAAA465A989C00840880C790064AA
such as:
