Hello!
I have a Skoda Octavia 3 from 2017 with 1.6 diesel, the motor is CXXB with an Automatic transmission with a bunch of faults after an broken alternator and was replaced with a NEW one at a mechanic garage. The symptoms are for example : When i drive the car after a while ESC Stability Control Error pops on the screen and unlocks the door locking system and on infotainment screen i see The ParkPilot is currently not available (All the Parking Sensors i tested and they are ok )
I changed and correctly coded with VCDS a new battery with an AGM Bosch because the battery was 2 years old and i thought it might solve the problem but i had the same faults. Took the car at mechanic garage and he told me is the ABS module (pomp) wich he replaced and after that was the same faults. He erased the faults in VCDS and faults came back again.
And then he said we need to take the car and go to the Skoda dealership to check the new alternator to see if is working good or not. Can someone help me please ! Thank you
Here is the VCDS scan
Wednesday,11,December,2024,09:38:44:31287
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: TMBBG7NE9H0144790 License Plate:
Mileage: 256951km-159661mi Repair Order: 11 DEC SCAN
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE9H0144790 Mileage: 256951km-159661miles
Address 01: Engine (J623-CXXB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 CR HW: 04L 907 445 B
Component: R4 1.6l TDI H06 5813
Revision: 22004001
Coding: 01254012442519090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI03004L906056CR 004012
ROD: EV_ECM16TDI03004L906056AJ_004.rod
VCID: 7F5CDA1E177ADF82261-802A
VINID: 91D4925C77952580011041C900E22366DE
25126 - Implausible Data Received from ESP Control Module
U0416 00 [00100111] - -
Date: 2024.12.10
Time: 16:19:07
Engine RPM: 756.25 /min
Normed load value: 38.8 %
Coolant temperature: 23 °C
Intake air temperature: 13 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 13.468 V
CAN status - engine control module: 0
Cruise Control System (CCS): status: main switch off
Readiness: N/A
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 041 D HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1004
Revision: 00005026 Serial number: CU501612037144 CVN: 5B1CA0AB
Shop #: WSC 73430 031 00063
ROD: EV_TCMDQ200021.rod
VCID: 3632FF3A78C0DECAB57-8062
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AQ HW: 5Q0 614 517 AF
Component: ESC H62 0400
Revision: 00000000 Serial number: 63416000003416
Coding: 1A078A9114240970407E060940C3245851289002600224720041F070C002430000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036_SK37.rod
VCID: 005E59E26A84A07A5FB-8054
8252 - Databus
U1121 00 [10001000] - Missing Message
[FCAN: Motor_11 message is not received]
Fault Frequency: 11
Reset counter: 250
Mileage: 256951 km
Date: 2024.12.10
Time: 16:19:07
8254 - Databus
[FCAN: Motor_12 message is not received]
Fault Frequency: 11
Reset counter: 250
Mileage: 256951 km
Date: 2024.12.10
Time: 16:19:07
8258 - Databus
[FCAN: Motor_20 message is not received]
Fault Frequency: 11
Reset counter: 250
Mileage: 256951 km
Date: 2024.12.10
Time: 16:19:07
8264 - Databus
[FCAN: Tsk_06 message is not received]
Fault Frequency: 11
Reset counter: 250
Mileage: 256951 km
Date: 2024.12.10
Time: 16:19:07
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5E0 820 047 M HW: 5E0 820 047 M
Component: AC Manuell H05 1203
Revision: 00001K07
Coding: 01110104002110001000000000401000
ASAM Dataset: EV_ACManueBHBVW37X 003129
VCID: 2C06DD52B68C941AD33-8078
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 CJ HW: 5Q0 937 084 AL
Component: BCM MQBAB M H24 0175
Serial number: 01061633400231 Dataset Number: V03935247KE 0001
Coding: 0F0018424247005B47E04000000407080000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_015.rod
VCID: 025A53EA6488B26A49F-8056
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 161025 041 0570
Serial number: 161107165727
Coding: 065DDD
528405 - Databus
Reset counter: 250
Mileage: 256951 km
Date: 2024.12.11
Time: 09:32:56
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Voltage: 11.7 V
Outside temperature: 4.5 °C
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39231633705050 Dataset Number: 5E0039t____ 0001
Coding: 0001050011
VCID: 3C26ED1246EC049A433-8068
13637426 - Databus
Fault Frequency: 9
Reset counter: 210
Mileage: 256951 km
Date: 2024.12.10
Time: 16:19:07
Part No SW: 3Q0 959 655 AK HW: 3Q0 959 655 AK
Component: Airbag VW21 004 0306
Revision: -------- Serial number: 003R6PR1AX8B Dataset Number: V03935243CC 0001
Coding: 98CCC000000000005C5400CC008800000065
ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
VCID: 074C42FE4FAA97421E1-8052
Subsystem 1 - Part No SW: ----------- HW: 454 001 411 16
Serial number: 3570000000073859902F
Subsystem 2 - Part No SW: ----------- HW: 454 001 411 16
Serial number: 35800000000316599028
Subsystem 3 - Part No SW: ----------- HW: 454 802 311 16
Serial number: 35100F00C5D0D000000O
Subsystem 4 - Part No SW: ----------- HW: 454 802 411 16
Serial number: 3520000D1A50D0000009
Subsystem 5 - Part No SW: ----------- HW: 454 803 011 16
Serial number: 3550097C84D0D000000-
Part No SW: 5Q0 953 521 T HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20161205500714
Coding: 1410
ROD: EV_SMLSVALEOMQB.rod
VCID: 43D496EE3B127B62029-8016
Part No SW: 5E0 920 781 C HW: 5E0 920 781 C
Component: KOMBI 202 9630
Coding: 27A402082180000801082A001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009007
ROD: EV_DashBoardJCIMQBAB_009_SK37.rod
VCID: 280E2142A274B83A37B-807C
16776993 - Databus
[ESP_21 keine Kommunikation]
Fault Frequency: 11
Reset counter: 250
Mileage: 256951 km
Date: 2024.12.10
Time: 16:19:07
Part No SW: 3Q0 907 530 B HW: 3Q0 907 530 B
Component: GW MQB Mid 417 4286
Revision: -------- Serial number: 0005674562 Dataset Number: V03935242BZ 0001
Coding: 030100045F087300EB0000481C0F00010001050000000000000000000000
GVL: 01543C0000000000400C00000000C80000000000000000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 2E02D75A8090E60AFD7-807A
Generator:
Component: E221__MFL-PR6 H05 0130
Serial number: 00000000030023210624
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001611297850
Part No SW: 5Q4 959 393 E HW: 5Q4 959 393 B
Component: TSG FS 010 0032
Serial number: 0000229454040 Dataset Number: V03935252QV 0001
Coding: 001001208001040000001100
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 45D088F6352645522CD-8010
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012360609
Coding: 1D0200
Component: EPS_MQB_ZFLS 129 1072
Dataset Number: V03935242GR 0001
Coding: 0107
ROD: EV_SteerAssisMQB_013.rod
Part No SW: 5Q4 959 392 E HW: 5Q4 959 392 B
Component: TSG BFS 010 0032
Serial number: 0000230267823 Dataset Number: V03935252QY 0001
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 44D695F23E1C7C5A3B3-8010
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000012481091
Coding: 050200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 840 B HW: 5Q0 035 840 B
Component: MU-S--ER H30 0361
Serial number: SKZAZ2T5071821 Dataset Number: V03935256PC 0001
Coding: 03731100FF00000051110001000800002F0300C60120010002
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CTSAT_VW26.rod
Subsystem 1 - Part No SW: 5E0 919 605 H HW: 5E0 919 605 H
Component: ABT_Std-2 H43 1031
Serial number: SKZ8Z9SLG01YZ9
B201A 00 [00001001] - -
Reset counter: 210
Mileage: 256951 km
Date: 2024.12.10
Time: 16:13:49
Voltage terminal 30: 11.6 V
Status_Software_Version_Management-module_name: D
6146 - Display Module 1 for Multimedia System
B1297 F1 [00001001] - Electrical Malfunction in Backlight
Reset counter: 210
Mileage: 256951 km
Date: 2024.12.10
Time: 16:13:49
6147 - Display Module 1 for Multimedia System
B1297 F0 [00001001] - Short Circuit in Backlight
Reset counter: 210
Mileage: 256951 km
Date: 2024.12.10
Time: 16:13:49
7179 - Function Restricted due to Missing Message(s)
U1111 00 [00001001] - -
[Rear-view camera (0x0B) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 210
Mileage: 256951 km
Date: 2024.12.10
Time: 16:13:52
BAP-BAP_Function_ID: 02
