GOOD EVENING I HAVE A PROBLEM LANE ASSIST IS NOT AVAILABLE
THANKS FOR YOUR HELP
Thursday,19,December,2024,11:44:50:33174
VCDS Version: 24.7.1.0 (x64) HEX-NET CB: 0.4643.4
VIN: WVGZZZ5NZMW088422 License Plate: 4964-T-1
Mileage: 91127km-56623mi Repair Order: VW TIGUAN
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 18 19 42 44 4B 52 5F 69 6C 6D
75 82 A5 CA D6 D7
VIN: WVGZZZ5NZMW088422 Mileage: 91127km-56623miles
82-Head Up Display -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DTSB) Labels:. 05L-907-309-V1.clb
Part No SW: 05L 906 022 M HW: 05L 907 309 B
Component: R4 2.0l TDI H30 0901
Revision: E3H30--- CVN: 3313D33F914A6D2022E7CED8914A6D2043FB2DAA
Coding: 0125003A03741D0830000000000000000000000000000000
ASAM Dataset: EV_ECM20TDI01105L906022M 006004
ROD: EV_ECM20TDI01105L906022CK_VW37.rod
VCID: 312ACFC460A8CC1E74-8064
VINID: 9E65EAAAA15EA9D9C020810208629A5256
Readiness: 0 0 0 1 1
Part No SW: 0GC 300 045 D HW: 0GC 927 711 H
Component: GSG DQ381 H06 2802
Revision: 00H06V13 CVN: F2E4FF8E
ASAM Dataset: EV_TCMDQ381061 001001
ROD: EV_TCMDQ381061.rod
VCID: 2A18D8A84D7EBFC6B5-807E
No subsystems:
Part No SW: 5Q0 614 517 GB HW: 5Q0 614 517 BP
Component: ESC H35 0114
Revision: 00000000 Serial number: 61241000001957
Coding: 0AEE6A9AA0280B74477B060262C549505605D0E2604692713862F078D2024A0B00002E64121A03102F35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049015
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 77BE31DCCE4CD22EFA-8022
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0577272157 Dataset Number: V03935330XS 0001
Coding: 132C0C0723
ROD: EV_KessyHellaMQBAB.rod
VCID: 45C28B14C42070BEB8-8010
Part No SW: 3G8 907 044 C HW: 3G8 907 044 C
Component: Climatronic H10 0215
Coding: 36020114204115011105100C8050D436
ASAM Dataset: EV_AirCondiBHTCMQB3rTranc 002001
ROD: EV_AirCondiBHTCMQB3rTranc_002_VW37.rod
VCID: 2D12D3B47C90A8FE50-8078
Air quality sensor:
Subsystem 1 - Part No SW: 5Q0 907 659 E HW: 5Q0 907 659 E
Component: G238 _AQS H32 0120
Serial number: 127857000
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Part No SW: 5Q0 937 084 DQ HW: 5Q0 937 084 DQ
Component: BCM MQBAB H H42 0411
Serial number: 01102114100543 Dataset Number: V03935345KX 0001
ASAM Dataset: EV_BCMMQB 021001
ROD: EV_BCMBOSCH_021_VW37.rod
VCID: 0A587828ADBEDFC695-805E
Subsystem 1 - Part No SW: 5NB 955 119 B HW: 5NB 955 119 A Labels: 1KX-955-119.CLB
Component: 326 LL 210422 034 0373
Serial number: 00000002104200300531
Subsystem 2 - Part No SW: 81D 955 555 A HW: 81D 955 555
Component: G397_RLFSS H06 0004
Serial number: 40296246X81D955555A0
Coding: 0000DE
Serial number: 000000000ZY211200S6R
Subsystem 4 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000001773912
Steering Column Switch:
Subsystem 5 - Part No SW: 5Q1 953 521 KR HW: 5Q1 953 569 K
Component: Lenks.Modul H24 0190
Serial number: 0100250520210C104081
Part No SW: 3Q0 919 298 F HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0055
Serial number: 000805219448042 Dataset Number: V03935342GV 0001
Coding: 0231263A51
ASAM Dataset: EV_EPHBO2CVW3260000 010019
ROD: EV_EPHBO2CVW3260000_VW37.rod
VCID: 40CC9A00DB0255968B-8014
Part No SW: 2Q0 907 572 T HW: 2Q0 907 572 B
Component: ACCCONTIMQB H04 0383
Dataset Number: V03935348SV 0001
Coding: 32057F4B58FF8728749F812481408700000000000000000004
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
1140 - Databus
[FAULT_TIMEOUT_VZE_01]
Reset counter: 25
Mileage: 91127 km
Date: 2024.12.19
Time: 11:23:55
Voltage terminal 15: 12.1 V
Control Module temperature: 70 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_Off_MainSwitch_Off
1141 - Databus
[FAULT_TIMEOUT_VZE_02]
Reset counter: 25
Mileage: 91127 km
Date: 2024.12.19
Time: 11:23:55
1118 - Databus
[FAULT_TIMEOUT_VZE_03]
Reset counter: 25
Mileage: 91127 km
Date: 2024.12.19
Time: 11:23:55
Part No SW: 5Q0 959 655 CG HW: 5Q0 959 655 CG
Component: AirbagVW21 008 0421
Serial number: 003J9R7EULNO Dataset Number: V03935329RR 0001
Coding: 98CCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002166
VCID: 075E411CBEACA2AE8A-8052
Left seat belt tensioner:
Component: BeltPretRevFL 106 1040
Serial number: 5NB857705D0140V00949
Coding: 80000D
Right seat belt tensioner:
Component: BeltPretRevFR 106 1040
Serial number: 5NB857706D0138V01812
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 001 805 21
Serial number: 35700000000C9679955Y
Subsystem 4 - Part No SW: ----------- HW: 480 001 805 21
Serial number: 3580000000078679955T
Subsystem 5 - Part No SW: ----------- HW: 480 401 905 21
Component: SideSensor_Dr 005 6149
Serial number: 351000198C37E5C5A14E
Subsystem 6 - Part No SW: ----------- HW: 480 401 905 21
Component: SideSensor_Pr 005 6149
Serial number: 352000198C37E5C41156
Subsystem 7 - Part No SW: ----------- HW: 480 401 705 21
Component: FrontSensor_D 005 6149
Serial number: 35500019CC450E0823B8
Part No SW: 3G0 920 320 B HW: 3G0 920 320 B
Component: KOMBI 502 5176
Coding: 04A420086F840008018862431001000880600D06
ASAM Dataset: EV_DashBoardVDDMQBA0 001045
ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
VCID: 1C740E70172A517637-8048
16777012 - Function Restricted due to Interrupted Communications
U1110 00 [00001001] - -
[BAP_VZA_0x21 keine Kommunikation]
Reset counter: 25
Mileage: 91127 km
Date: 2024.12.19
Time: 11:23:57
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 5WA 963 272 A HW: 5WA 963 272 A
Component: STH-VW37x 006 0010
Serial number: 000000000000119
Coding: 250B155A5C25162CE46D18
ASAM Dataset: EV_AuxilHeateWOSVW38X 001009
ROD: EV_AuxilHeateWOSVW38X_001_VW27.rod
VCID: 4BD6BD2CE24486CE6E-801E
Auxiliary heating remote control:
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 442 4424
Revision: -------- Serial number: 0001636956 Dataset Number: V03935331QY 0001
Coding: 030100345F087300211002DE180F00010001070000000000000000000000
GVL: 01463C0808000400C08C80008006C80010000000000200000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 74A406D0DF3AB936DF-8020
Generator:
Component: 4-00-05-00-04
Subsystem 2 - Part No SW: 3G0 959 442 Q HW: 3G0 959 442 Q Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440071144212432
Coding: 2F2900
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Component: J367-BDMHella H11 9070
Serial number: 7913367505
Part No SW: 5Q0 959 593 K HW: 5Q0 959 593 F
Component: TSG FS003 0330
Serial number: YE007UEP33996 Dataset Number: V03935321AR 0001
Coding: 003D1A20D000048000001000
VCID: 49DA8724E83894DE5C-801C
Subsystem 1 - Part No SW: 5Q0 959 407 E HW: 5Q0 959 163 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0011
Serial number: 00000000000051607536
Coding: 210000
Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Serial number: 173009 00 Dataset Number: V03935345BQ 0001
Coding: 0101001100400010
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
VCID: 2B16DDAC4284A6CE4E-807E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 G HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0380
Serial number: 25052110801013 Dataset Number: V03935347QA 0001
Coding: 000000070900104A00002F10020000000000000000000000000000000000
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 393AF7E4B8D8045ECC-806C
Part No SW: 5Q0 959 592 K HW: 5Q0 959 592 F
Component: TSG BFS003 0330
Serial number: YE007UDS05989 Dataset Number: V03935319SR 0001
Coding: 003D1020DC00048000001000
VCID: 48DC8220F3326DD643-801C
Subsystem 1 - Part No SW: 5Q0 959 408 E HW: 5Q0 959 164 C Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0011
Serial number: 00000000000051680972
Coding: 290000
Address 5F: Information Electr. (J794) Labels:| 3G5-035-MIB-HGH3.clb
Part No SW: 3G5 035 816 D HW: 3G5 035 816 D
Component: MU-O-ND-EU H22 0278
Serial number: VWZAZ2Y0579412 Dataset Number: V03935343FK 0001
Coding: 23260000000020000000000000000000000000000000000000
ASAM Dataset: EV_MUOIMQB 001001
ROD: EV_MUOIMQB_001_VW27.rod
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H61 9216
Serial number: VWZ6ZJY1260311
Subsystem 2 - Part No: V03 959 809 CP
Component: EU 2021 4031
7201 - Function Restricted due to Interrupted Communications
[Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
Mileage: 91127 km
Date: 2024.12.19
Time: 11:23:58
BAP: 02
Voltage terminal 30: 12.1 V
Address 69: Trailer (J345) Labels:| 5H0-907-383.clb
Part No SW: 5H2 907 383 HW: 5H2 907 383
Component: Anhaenger H09 0040
Serial number: 000000000005774 Dataset Number: V03935308CU 0001
Coding: 0100000202001300
ASAM Dataset: EV_TrailFunctGener3Hella 001009
ROD: EV_TrailFunctGener3Hella_VW27.rod
VCID: 6D9213B4BC1068FE10-8038
Part No SW: 5Q0 907 556 D HW: 5Q0 907 556
Component: Areaview 2 H23 0609
Serial number: C854711JJ006222 Dataset Number: V03935344FX 0001
Coding: 01230600A30F200000204014
Shop #: WSC 23160 004 1048576
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB_006_VW37.rod
VCID: 3A38E8E8BDDE0F46C5-806E
Part No SW: 5WC 959 107 HW: 5WC 959 107
Component: HDSG-Modul H04 0430
Revision: -------- Serial number: A2-C767-1160-5 Dataset Number: V03935349YH
Coding: 0A88
ASAM Dataset: EV_DeckLidCONTIAU536 001001
ROD: EV_DeckLidCONTIAU536_VW37.rod
VCID: 0E507438D1D6F3E649-805A
Part No SW: 5WA 035 284 E HW: 5WA 035 284 B
Component: OCUGen3High H20 0139
Serial number: 0000000105VICL6 Dataset Number: V03935338PL 0001
Coding: 023760001968AC209005460161002607
ASAM Dataset: EV_OCUGen3High 003007
ROD: EV_OCUGen3High_003_VW27.rod
Address 82: Head Up Display (J898) Labels:| 3G0-919-608.clb
Part No SW: 5NA 919 608 C HW: 5NA 919 608 C
Component: HeadupDisplay 024 0440
Coding: 574040
ASAM Dataset: EV_HeadUpDisplContiVW481 001015
ROD: EV_HeadUpDisplContiVW481.rod
Reset counter: 25
Mileage: 91127 km
Date: 2024.12.19
Time: 11:37:01
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 2Q0-980-653.clb
Part No SW: 2Q0 980 653 B HW: 2Q0 980 653
Component: MQB MFK 3.0 H13 1202
Serial number: E57829508211370 Dataset Number: V03935342UX 0001
Coding: 00000888215AC020489E00001020002000018000000000000000000000000000
ASAM Dataset: EV_MFK3ValeoMQB 007042
VCID: 3424C6D09FBAF9361F-8060
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935351TV 0001
Coding: 608040732602
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75A23BD4D440A03EE8-8020
Part No SW: 992 941 572 CE HW: 992 941 572 C
Component: LED1L H08 9202
ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
VCID: 689C62A093F24DD663-803C
Component: LED1R H08 9202
End----(Elapsed Time: 01:36, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
