What is "TPMS II" on Mk5 Jetta Sportwagon?
GTIspirit
C?ID=245724
While following TDIclub: conversion to indirect TPMS to convert from direct to indirect TPMS after installing winter wheels without TPMS sensors on my 2009 Jetta Sportwagon, I noticed a "TPMS II" setting [4C].
How does it compare to this "TPMS" setting [65], which is unchecked according to the directions above?
Auto-scan for reference, though not sure if it's relevant to the question
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 52 56 62 72
VIN: 3VWPM71K39M266387   Mileage: 107700km-66921miles
65-Tire Pressure -- Status: Malfunction 1110
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 P    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H02---    Serial number: VWX7Z0H624D18R
   Coding: 0000075
   Shop #: WSC 03055 444 101074
   VCID: 3B5BDB767A9E83E648-806E
001169 - Secondary Air Injection System: Bank 1
               P0491 - 000 - Insufficient Flow
                    Fault Frequency: 8
                    Mileage: 91674 km
                    Time: 11:18:06
                    RPM: 1362 /min
                    Load: 43.1 %
                    Temperature: 15.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.224 V
009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
               P2432 - 000 - Short to Ground - MIL ON
                    Fault Status: 11100000
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 65.0°C
                    Temperature: 42.0°C
                    Voltage: 12.065 V
   Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
   Component: AQ 250 6F           1377
   Revision: 00H76000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 7DDF156E240A4DD636-8028
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 113B400D49280000880E02EC922000413400
   VCID: 74C9304AD7400C9E49-8020
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   VCID: 7CD9186A3F1044DE01-8028
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000001011611
   Coding: 148D8F2340041500070000001C000000000873075C000120000000000000
   VCID: 6FC33F267E662F46B4-803A
   Component: Wischer 040808 021  0501
   Coding: 00038805
   Shop #: WSC 00066
                    Fault Status: 00101100
                    Reset counter: 157
                    Mileage: 107041 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 14.30 V
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0364742
   Coding: 0000100
   VCID: 334BF35652CE4BA690-8066
02617 - Satellite Antenna (R170)
                    Fault Frequency: 14
                    Reset counter: 92
                    Mileage: 71397 km
                    Time: 21:34:38
            000 -  -
                    Reset counter: 118
                    Mileage: 67077 km
                    Time: 18:09:20
   Component: 78 AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6M066J5Z
   Coding: 0014136
   VCID: 6CF9282A4F70D45E91-8038
   Subsystem 1 - Part No: 1K0 959 339 H
   Component: BF-Gewichtsens. 007 0006
   Subsystem 2 - Serial number: 6332MSME29042F2FK
   Subsystem 3 - Serial number: 6342MSME29342C26C
   Subsystem 4 - Serial number: 6351HSME17192F0EG
   Subsystem 5 - Serial number: 6361HSME172529486
   Subsystem 6 - Serial number: 63727SME16373179/
   Subsystem 7 - Serial number: 63827SME161F6D7CM
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0010022
   VCID: 032B639642EE3B2640-8056
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H624D18R
   Coding: 0007203
   VCID: 3C59D86A7F9084DE41-8068
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0112
   Revision:   H07 01    Serial number: 160608F1001103
   Coding: ED807F06000302002002
   Shop #: WSC 03089 444 84152
   VCID: 69F7513E4082C176EA-803C
                    Reset counter: 134
                    Mileage: 107704 km
                    Time: 00:27:34
   Component: IMMO            3HL 1222
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000754988711
   Coding: 0001205
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2A75EE3285040A6E23-807E
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 139007885283083F0904058FB0880F0488FCA0
   VCID: 0429608A47E03C1E79-8050
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 00000505488720
   Coding: 0001204
   VCID: 70C13C5A635830BEAD-8024
   Part No SW: 1K0 035 180 L    HW: 1K0 035 180 L
   Component: Radio DE2       016 0020
   Revision: 00016000    Serial number: VWZ4Z7H2218562
   Coding: 0040401
   VCID: 2977113E800201762A-807C
00856 - Radio Antenna
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000003285233
   Coding: 0001168
   VCID: 76CD0A42013C1E8E77-8022
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000003341887
   Coding: 0001168
   VCID: 77D30746063667866C-8022
End-------------------------(Elapsed Time: 01:19)--------------------------
I suspect it's some kind of virtual module address used for compatibility reasons in some cars. I don't recall having seen anything that actually responds directly at this address..
