Hello everyone,
I think I have lost my ABS long coding for my mk7 Vw Golf auto TSI. I am new to euros and very stupidly swapped out the instrument clusters
This is how I lost it:
1. My original dash cluster had an error (error: instrument cluster failure, see workshop).
2. I purchased a used instrument cluster for the same year and model.
3. I (stupidly) swapped out my original cluster with the used one I bought.
4. The used one I bought came up with error codes, including stop start failure, airbag failure, handbrake failure, abs, dsc etc.
5. I freaked out and put my original cluster back in.
6. Now my original cluster has essentially the same error codes as the used one I bought AND the original instrument cluster error
7. My original cluster is in the car now, tried clearing codes but got nothing. Vin matches my car in the below report
Car works and drives, just abs is not working and the stop start feature. Airbags I’m not sure, hope I don’t have to find out!
I ran it thought vcds and have realised that the long coding is all 0. The trouble is that the dealers are All booked until February and can’t look at it!
It would be great if I can be guided on this. I very much appreciate any support.
______________________________
Thursday,19,December,2024,00:14:18:24367
VCDS Version: 24.7.1.0 (x64)
VIN: WVWZZZAUZDP036747 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZDP036747 Mileage: 157731km-98009miles
Address 01: Engine (J623-CMBA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 CN HW: 04E 907 309 A
Component: R4 1.4l TFS H08 9094
Revision: WAH08--- CVN: 4449043F
Coding: 01250032242405082000
Shop #: WSC 31159 005 1048576
ASAM Dataset: EV_ECM14TFS01104E906016CN 002008
ROD: EV_ECM14TFS01104E906016CN.rod
VCID: 70C120CDABFC3C163B-8024
VINID: 9E69EAAAA465A948000C61C41C2E1962AC
17158 - Databus
U1123 00 [00101111] - Received Error Message
Mileage: 157702 km
Engine RPM: 0.00 /min
Coolant temperature: 75 °C
Intake air temperature: 56 °C
Voltage terminal 30: 12.392 V
Mass flow through throttle valve: 0.0 kg/h
Mean injection time: 0.000 ms
Engine operating condition: Idle
5250 - Function Restriction due to Faults in Other Modules
U1113 00 [00101111] - -
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:10
Coolant temperature: 88 °C
Intake air temperature: 54 °C
Voltage terminal 30: 12.415 V
U0428 00 [00101111] - -
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:10
selected gear-Bits 0-7: 0
4716 - No Communications with Parking Brake Control Module
U0128 00 [00101111] - -
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:09
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 044 T HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5244
Revision: 00043014 Serial number: CU501301065643 CVN: 00004B24
Shop #: WSC 40952 002 1048576
ROD: EV_TCMDQ200021.rod
VCID: 49B7AD29E8E62DDE5C-801C
21221 - No Communications with Parking Brake Control Module
U0128 00 [00001011] - -
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:10
Engine RPM: 3.75 /min
Engine torque: -100 Nm
Vehicle speed: 96 km/h
Control Module temperature: 16 °C
CURRENT pressure: -9.5 bar
Clutch: primary stat: Driving
selected gear: GANG_5
Driving position: N
Accelerator pedal position: 0.4 %
DTC memory status: 8448
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 0000000000000000000000000000000000000000000000000000000000
Shop #: WSC 00028 028 00023
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
VCID: 7DDF09F9ECAE417EA0-8028
12 Faults Found:
0195 - Control module not coded
U1013 00 [10001001] - -
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:12
C1017 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:12
C1079 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:12
0279 - Brake Pressure Sensor 1
C107A 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:12
0295 - Steering angle sensor
B1168 54 [10001001] - Missing Calibration / Basic Setting
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:12
0398 - Control Module Incorrectly Coded
U1014 00 [10001001] - -
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:14
8269 - Databus
U1122 00 [00001000] - Implausible Message
Reset counter: 53
Mileage: 157716 km
Date: 2024.12.17
Time: 21:43:17
8278 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:12
8290 - Coding Not Possible
U10BC 00 [00001000] - -
Reset counter: 13
Mileage: 157731 km
Date: 2024.12.18
Time: 00:06:41
8306 - Databus
Reset counter: 13
Mileage: 157731 km
Date: 2024.12.18
Time: 00:06:41
8308 - Control Module Incorrectly Coded
Reset counter: 13
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:12
32848 - Control Module for Electric Parking Brake
C10E2 F1 [00001001] - Switches/Motors Detected
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:12
Part No SW: 5G0 907 044 Q HW: 5G0 907 044 Q
Component: Climatronic H02 0503
Revision: 00001K06 Dataset Number: 0000
Coding: 00120004200100011005000012101800
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_002_VW37.rod
VCID: 354FD1D9941E593E28-8060
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-BV1.clb
Part No SW: 5Q0 937 084 M HW: 5Q0 937 084 M
Component: BCM MQBAB B H14 0106
Serial number: 00011234000872 Dataset Number: 5G0063v____ 0001
Coding: 03001842C24102F30FA44000000403081000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_010.rod
VCID: 42A5BA05D5D0FE869D-8016
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 121120 042 0551
Serial number: 121210003448
Coding: 0E4DD5
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y13M01D08H08M23S28S1
Coding: 00A8DD
7 Faults Found:
B1263 01 [00001000] - Electrical Failure
Reset counter: 31
Mileage: 156913 km
Date: 2024.10.15
Time: 17:18:24
Terminal 15 status: OFF
Terminal 50 status: OFF
OFF: operated
Position lamps: Not operated
Low beam: Not operated
Stoerschutzzaehler: 0
Voltage: 12.3 V
Outside temperature: 19.0 °C
539925 - Databus
Reset counter: 47
Mileage: 185956 km
Date: 2024.07.18
Time: 00:02:14
Terminal 15 status: On
OFF: operated
Voltage: 12.3 V
Outside temperature: 27.5 °C
552213 - Databus
Reset counter: 47
Mileage: 185956 km
Date: 2024.07.18
Time: 00:02:13
OFF: operated
Voltage: 12.3 V
558869 - Databus
Reset counter: 47
Mileage: 185956 km
Date: 2024.07.18
Time: 00:02:13
OFF: operated
Voltage: 12.3 V
559637 - Databus
Reset counter: 47
Mileage: 185956 km
Date: 2024.07.18
Time: 00:02:13
OFF: operated
Voltage: 12.3 V
934149 - Rain/Light Recognition Sensor
B1366 76 [00001000] - Incorrect Mounting Position
Fault Frequency: 16
Reset counter: 48
Mileage: 156913 km
Date: 2024.10.15
Time: 17:14:47
OFF: operated
Voltage: 12.2 V
15360768 - Component Protection
U1101 00 [00001000] - Active
Reset counter: 47
Mileage: 185956 km
Date: 2024.07.18
Time: 00:00:32
OFF: operated
Voltage: 12.4 V
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231300712374Dataset Number: 5G0039v__A_ 0003
Coding: 0031151011
ASAM Dataset: EV_EPHVA18AU3700000 002016
VCID: 3A55C2E5BD00B646C5-806E
12658704 - Databus
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:20
13637426 - Databus
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:20
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R023LSI Dataset Number: 5G0003v____ 0066
Coding: 98CCC000000000005C00000000C800000065
Shop #: WSC 00028 028 00054
VCID: 40A1B00DDBDCEC968B-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 801 13
Serial number: 357670000000F1645C0S
Subsystem 2 - Part No SW: ----------- HW: 480 000 801 13
Serial number: 35867000000361645C0N
Subsystem 3 - Part No SW: ----------- HW: 480 401 101 13
Serial number: 3516502C10D46460E2B9
Subsystem 4 - Part No SW: ----------- HW: 480 401 101 13
Serial number: 3526502B50D3608432C4
Subsystem 5 - Part No SW: ----------- HW: 480 400 301 13
Serial number: 3556502B50D3771131A2
B13BC F2 [10001001] - No function
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:22
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AE HW: 5Q0 953 549 A
Revision: -------- Serial number: 15011304220093Dataset Number: ----------
Coding: 0500
Shop #: WSC 40195 333 37120
ROD: EV_SMLSKLOMQB_009.rod
VCID: 79D71DE9F8867D5E8C-802C
No ASAM data for: "EV_SMLSKLOMQB" (VW37)
Part No SW: 5G0 920 860 HW: 5G0 920 860
Component: KOMBI 235 0555
Coding: 27A401082380000801082A00040000
Shop #: WSC 13055 135 13560
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
VCID: 65EF4199643EE9BE58-8030
10485826 - Internal Control Module Memory Check Sum Error
B2000 41 [00001001] - General Checksum Failure
Mileage: 146352 km
Date: 2023.05.16
Time: 18:27:38
16776967 - Databus
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:26
16776973 - Databus
Reset counter: 12
Mileage: 157702 km
Date: 2024.12.17
Time: 19:10:26
Part No SW: 5Q0 907 530 E HW: 5Q0 907 530 E
Component: GW MQB Mid 121 1109
Revision: -------- Serial number: 0000232134Dataset Number: 5G0067v____ 1020
Coding: 030100342B086400EF0002481C0F00010001000000000000000000000000
GVL: 01543C0000000000400C00000000C80000000000000000000000000000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewLear_006.rod
VCID: 334BEFC19A6A470E06-8066
Generator:
Subsystem 2 - Part No SW: 5G0 959 442 J HW: 5G0 959 442 J Labels: 3C8-959-537.CLB
H13 0035
Serial number: 02120004914740070291
Coding: 280000
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 0448408801
131604 - No Communication with Instrument Cluster
U0155 00 [00001000] - -
Fault Frequency: 9
Reset counter: 47
Mileage: 156913 km
Date: 2024.10.15
Time: 06:26:01
Terminal 30 power supply: 12.4 V
Terminal 15: OFF
Part No SW: 5Q4 959 393 HW: 5Q4 959 393
Component: TSG FS 007 0006
Serial number: 0000048010805 Dataset Number: 5G0222v____ 0034
Coding: 003002208001020000001000
ROD: EV_DCUDriveSideEWMAXKLO.rod
VCID: 558F7159345E793EC8-8000
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000503925
Coding: 0D0000
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Dataset Number: 5G0074v____ 0120
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D5FC9F9AC2E817EE0-8068
15873 - Steering angle sensor
B1168 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 12
Motor status: 00
Supply voltage: 12.25 V
Temperature: 28.0 °C
KFC: 3E
KFA: 00 01
Freeze frame conditions: 4B
uAdSensI_U5VFiltered_xdu16: 5.05376 V
uioUdNotFilt_xdu16: 12.38 V
uAdSensI_SwitchedKl30_xdu16: 12.36 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 12
19204 - Databus
Mileage: 157702 km
Date: 2024.12.17
Time: 21:23:37
Motor status: 01
System status: Driving mode
Supply voltage: 12.00 V
KFC: 4B
KFA: 00 04
Freeze frame conditions: 21
uAdSensI_U5VFiltered_xdu16: 5.04887 V
uioUdNotFilt_xdu16: 12.20 V
uAdSensI_SwitchedKl30_xdu16: 12.21 V
Part No SW: 5Q4 959 592 HW: 5Q4 959 592
Component: TSG BFS 007 0006
Serial number: 0000048025619 Dataset Number: 5G0157v____ 0035
Coding: 003000208E01020000801000
ROD: EV_DCUPasseSideEWMAXKLO.rod
VCID: 012775099056259EC4-8054
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000493342
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 824 A HW: 5G0 035 824 A
Component: MU-S--ER 041 0421
Serial number: V1E00602154010 Dataset Number: 5G0CV1v____ 0001
Coding: 02730000FF00000011510001000900001F0100960100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 236B1F812A8AD78EF6-8076
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H44 0020
Serial number: VWZ8Z9M24012WL
End-------------------------(Elapsed Time: 03:12)--------------------------
