2015 Jetta TDI Manual Trans Rough Idle
Pherder01
California, USA
C?ID=586026
Good day,
I have a 2015 Jetta TDI that has been gone with my daughter for a couple years. It seems to have a rough idle. There are no engine codes and the RPM is 850.
Since its been gone for a couple years, it may be something I don't remember. It shakes the car during idle.
Is this normal for a manual transmission? What should I be looking for in VCDS?
Mileage is 182,000. Timing belt and water pump changed at 120,000 mi.
Thank you.
Pherder01
California, USA
C?ID=586026
Sunday,15,December,2024,21:45:04:00031
VIN: 3VW3A7AJ1FM274806   License Plate: 898
Mileage: 293770km-182540mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 2E 44 56 77
VIN: 3VW3A7AJ1FM274806   Mileage: 293770km-182540miles
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 016 AJ    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 8418
   Revision: 8AH20---    CVN: 0BA038E138D3FF82
   Coding: 01190012042410084000
   Shop #: WSC 22237 002 1048576
   ASAM Dataset: EV_ECM20TDI01104L906016AJ 001009
   ROD: EV_ECM20TDI01104L906016AJ_001.rod
   VCID: 71BFC38821291B72A05-8024
   VINID: 0E69C344745A0567421C420018794D2258
4113 - Camshaft Position Sensor (G40)
          P0341 00 [01100000] - Implausible Signal
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C492900FE851302E4921F0042A1100012
   Shop #: WSC 00066 000 00000
   VCID: 04519A5C0E1B1EDA7B3-8050
                    Reset counter: 213
                    Mileage: 293746 km
                    Date: 2019.04.24.
                    Time: 04:33:49
                    Count: 7
                    Count: 1
                    Count: 4096
                    Count: 128
                    Count: 33792
                    Count: 510
                    Fault Status: 00101100
                    Reset counter: 213
                    Mileage: 293746 km
                    Date: 2019.04.23.
                    Time: 03:55:55
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 4196
                    Count: 50944
                    Count: 256
                    Count: 1
                    Reset counter: 213
                    Mileage: 293746 km
                    Date: 2019.04.23.
                    Time: 03:55:55
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 16390
                    Count: 50944
                    Count: 256
                    Count: 1
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 CA    HW: 5C0 820 047 CA
   Component: J301  Klimaanlage   0207
   Revision: 2001001S    Serial number: 00000002495068
   Shop #: WSC 00066 790 00014
   VCID: 619FB3C8FD49ABF2305-8034
   Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
   Component: BCM PQ25 Max3 H78 0725
   Revision: B8078001    Serial number: 78003335141039
   Coding: 7B994B1808AB0B0000382080240884C50F86702E60000050B00010022844
   VCID: 3039068CEA23527AEFB-8064
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Serial number: 14102585141015053630
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Serial number: 14102584141022112620
   Coding: 820000
   Subsystem 3 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Component: E221__MFL-TAT  H04 0019
   Serial number: 3221407345600772AD1B
   Coding: 280000
   Subsystem 4 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Serial number: 14102587141028071818
   Coding: 800000
   Subsystem 5 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Serial number: 14202586141103215038
   Coding: 800000
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD03R0Y7   Dataset Number: 160003V____ 0313
   Coding: 00004B33
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72BDCC84242F206A59F-8026
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140001I9170K
   Coding: 303341
   Serial number: 3572MSME107A0C49ZZZ-
   Serial number: 3582MSME08442849ZZZX
   Serial number: 3516KSME65791032ZZZM
   Serial number: 3526KSME5B641032ZZZM
   Serial number: 3556LSME1B774E31ZZZ%
   Serial number: 3566LSME27425631ZZZP
          B10B3 00 [00001000] - Function Restriction due to Implausible Message(s)
                    Reset counter: 213
                    Mileage: 293746 km
                    Date: 2024.11.30.
                    Time: 03:56:13
   Part No SW: 5C6 920 954 A    HW: 5C6 920 954 A
   Component: KOMBI         H04 0807
   Coding: 270A01
   Shop #: WSC 00066 000 00120
   VCID: 2C0112FCC68B369AD33-8078
   Part No SW: 6N0 909 901     HW: 7H0 937 090 A
   Component: GW-K-CAN TP20 H78 0725
   Revision: B8078001
   Coding: 102200
   VCID: 70B9C68C2AA3127AAFB-8024
   Component: IMMO          H04 0807
   VCID: 6A8DD4E40CFFE8AAE1F-803E
Address 2E: Media Player 3
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 392F3BA835599332585-806C
                    Fault Status: 00101101
                    Reset counter: 213
                    Mileage: 293746 km
                    Date: 2019.04.23.
                    Time: 03:55:54
                    Voltage: 14.00 V
                        DU
                    Temperature: 22.0°C
                    RPM: 826 /min
   Part No SW: 1K0 035 164 J    HW: 1K0 035 164 J
   Component: LOW NAR SDARS H05 0006
   Revision: -----09S    Serial number: VWZ4Z6P3855543
   Coding: 01000400020006
   VCID: 290FEBE8C9F923B2285-807C
                    Reset counter: 173
                    Mileage: 293746 km
                    Date: 2019.04.23.
                    Time: 03:55:54
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666804589 Dataset Number: 5N0035729E  0001
   Coding: 0A10030080010110
   Shop #: WSC 01383 790 50316
   ROD: EV_UHVUMI.rod
   VCID: 323D0C84E4AF606A99F-8066
End----------(Elapsed Time: 01:39, VBatt start/end: 12.3V/12.3V)-----------
Pherder01
California, USA
C?ID=586026
I figured you were going to get me on that. Makes sense. It's kind of a pain in the neck to get to..
Thank you once again!
davisev5225
C?ID=263265
You say timing was done at 120k miles and you're now at 182k miles. Where did you source your timing parts? "Implausible signal" usually means the engine has jumped timing and needs to be re-timed. Since timing parts should be good for ~75k miles and you've not reached that yet, I wonder about the part quality (or lack thereof)?
Pherder01
California, USA
C?ID=586026
I think it is a cam position sensor. TBH, I’ve done timing belt/chain replacements in the past. These were on gas engines. I did have problems on this diesel because I failed to ensure the fuel pump was timed correctly. This was figured out and re-set. When the fuel pump was not timed correctly the “glow plug” indicator light was present. When I go to replace the cam position sensor I will inspect the belt again.
When I buy parts, I don’t mind spending the money for quality.
The timing belt was done before I had Vag-Com. Also it looks like
were limited numbers of CVCA engines released in the states. Please let me know if this is not correct.
The trigger for replacing the timing belt was a leaking water pump. This engine has the solenoid operated version.
Do I need to remove the camshaft gear to replace the cam position sensor?
davisev5225
C?ID=263265
Verify timing (all of it) before you load the parts cannon! You went on a tangent about the fuel pump timing, but that's not the error you're getting here, you're getting an error that the cam position doesn't make sense to the ECU as compared to other timing sensor data. Again, that usually means the timing has jumped a tooth, most likely on the cam gear. Your sensor is probably fine; if it wasn't, you'd get a different error about no communication or similar.
Pherder01
California, USA
C?ID=586026
Got the car back from my daughter this weekend. Rotated the crankshaft to the timing mark on the cover as well as the notch in the main pulley. Inserted an approximate 5.8 mm pin into the camshaft sprocket hole and into the pin on the cylinder head. Another pin was inserted into the fuel pump timing marks. This is a notch on the sprocket that aligns with a hole in the casting. All marks seem to be on. It doesn't seem possible to get the pins inserted unless the sprockets are in the correct place.
Any other thoughts about timing?
Dr Sheldon
Windsor UK
C?ID=334979
That fault may or may not cause the Engine to shake as you describe, plus the fact that is intermittent !!
Clear the fault and note how long it takes to come back please.
Is the belt tensioned and tight ? Weak Tensioner ? Any Bearing Noise ?
IF you take the belt off then bin it and replace it !!
davisev5225
C?ID=263265
Yep. :)
Now that you've physically verified the timing belt & components, it's time to focus on the electrical. Continuity test all the wires going to/from each of the timing sensors. Load test the power and ground wires in each connector. Remove each sensor and inspect them for metallic debris, sludge, etc. Inspect the holes/fittings where the sensors are inserted and verify there is no debris blocking the sensor from reading the encoder wheel (or equivalent) on each component.
You'll probably want to grab a wiring diagram <--- clickable link if you don't already have one.
Pherder01
California, USA
C?ID=586026
Yep. :)
I'm still trying to locate the Cam Position Sensor. I would think this would be in the manuals. As far as I can see it is not on the drive end of the cam. The only wiring going behind this cover is for the solenoid on the water pump. I've seen other videos that show the sensor at this end near the timing belt and there's nothing. The end near the gearbox doesn't seem to have anything there either.
Pherder01
California, USA
C?ID=586026
At192,000 mi. the shifting was very poor and a very shaky engine still. Went to change the clutch and found the dual mass flywheel was damaged. It was about an 1/8" from being concentric. An angle grinder was needed to remove a part of the flywheel to access the bolts. Flywheel replaced and vibration gone. Now, another problem on another thread. Clutch, pressure plate, flywheel alignment.
Continued here:
