VW Crafter Van 2020 No start
weldenie
Isle of Mull, Scotland
C?ID=597025
Hi if I try and start it on its own battery which is at 12.45 v it drops to 10.97 I ve just give it a sniff of easy start and it will fire on the easy start but no fuel being injected into the cylinder cam belts found could compression test but I think it’s electrical
   #22
Dr Sheldon
Windsor UK
C?ID=334979
removed the plug on injector number one and turned it over with a good volt meter connected to the injector plug only reading about .2 volts
Wrong way to do it !!
As soon as you unplug the Injector the ECU will detect that and cut supply / voltage from that injector.
   #23
Dr Sheldon
Windsor UK
C?ID=334979
Dropping to 10v is acceptable.
The fact that it will run on Easy Start is a good sign of Mechanical integrity !! Sort of !!
I would now be Scoping the Crank Sensor and Injectors !!
Graph the 3 I asked you for please - Especially RPM !!
  • Agree
weldenie
C?ID=597025
Hi I am struggling getting the graph to work /record I have managed to get the rpm off all 3 sensors
rpm
engine rpm 230
cam rpm 229
crankshaft rpm 232
still trying to work out injectors
   #26
weldenie
C?ID=597025
Hi, I am struggling to load any graphs or photos but I have managed to record:
IN_Injection_speed_injector(0) Peak: 235.8/min
IN_Injection_speed_injector(1). Peak:236.8/min
IN_Injection_speed_injector(2). Peak:236.5/min
IN_Injection_speed_injector(3). Peak:237.8/min
   #27
Dr Sheldon
Windsor UK
C?ID=334979
I can appreciate that you are trying !!
There is a good reason why I want to see Engine RPM, Rail Pressure (actual) & Battery Voltage on a Graph -That reason is to help you get your van started !!
However if you want my help then I would like you try harder, keep trying until you get it right. Please note that no one was born an Expert on VCDS - We all learnt except @Uwe :cool::cool:
Perhaps some one here can point you to a good Video that you can study.
   #28
Dr Sheldon
Windsor UK
C?ID=334979
Hi,
please find information asked for. Battery starting to go flat so has been put on charge. Please let me know if you need anything else.
Well &uck my old boots !!
You did a better job of that then I could do !!
That RPM is a little on the low side - I would like to see ~ 280rpm.
However if you were to squirt easy start before you crank it then that would raise the rpm well above that and mask any low rpm issue, if you have one, theoretically it would start and run.
Try that please, and yes I note that you have run it on easy start - Worth a shot but I do think your problem is elsewhere.
   #32
Dr Sheldon
Windsor UK
C?ID=334979
Crank Sensor was my other suspect but then we do have a healthy RPM reading !!
We are now left with
Address 01: Engine (J623-DAUA) Labels:. 04L-907-309-V2.clb
27277 - System Voltage
P0562 00 [00100011] - Too Low
Time for a wiring diagram from Erwin, a 21w bulb and a Voltmeter (if you do not have a scope). Test the Powers and Grounds at Engine ECU whilst cranking !!
   #36
weldenie
C?ID=597025
Update: Still no start! Had Engine control module sent away and tested and no issues found all working well. Back pinned wiring to the ecu and cannot find any low voltage and replaced the Alternator. Can the Body Control module prevent the engine from starting?
Please fine below the most recent scan with fault codes. Looking for any help as the van is stuck on an island.
Friday,24,January,2025,10:35:08:51221
VIN: WV1ZZZSYZM9003165   License Plate: T16AHS 24/1/2025 (02)
Mileage: 137676km-85547mi   Repair Order:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 52 5F 75 BB BC
VIN: WV1ZZZSYZM9003165   Mileage: 137676km-85547miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
   Part No SW: 04L 906 056 SK    HW: 04L 907 445 P
   Component: R4 2.0l TDI   H01 9973
   Revision: 23203001
   Coding: 001940346324050800000000000000000000000000000000
   Shop #: WSC 00000 000 00013
   ASAM Dataset: EV_ECM20TDI03004L906056SK 007007
   ROD: EV_ECM20TDI03004L906056SK_007.rod
   VCID: 084E407A52BFBA1A17B-805C
   VINID: 9E606AAAA8E9A9D240003046142A1B25D0
                    Mileage: 137173 km
                    Date: 2025.01.19
                    Time: 21:03:52
                    Engine RPM: 0.00 /min
                    Coolant temperature: 9  C
                    Intake air temperature: 15  C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 12.398 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 0.57 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0.000 bar
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 946 mbar
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 4
                    Index of next requested engine mode: 4
                    Index of engine target mode: 4
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 2N0-907-379-V1.clb
   Part No SW: 2N0 907 379 E    HW: 2N0 907 379 C
   Component: ESC_base      H02 0870
   Serial number: 08503636200709
   Coding: 25A82477483DB685A448246612486D063BF144B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 704031
   ROD: EV_Brake1ESP90iBOSCHVN54X_704.rod
   VCID: 382EF0BA62DF0A9AA7B-806C
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7C0 907 426 AD    HW: 7C0 907 426 AD
   Component: AC Manuell    H01 0401
   Coding: A03110000800000001000800500101000000000000000000000000000000
   Shop #: WSC 00000 000 00023
   ASAM Dataset: EV_AirCondiBHTCVN54X 003020
   ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
   VCID: 6B841FF6630971029A9-803E
   Part No SW: 5Q0 937 084 DN    HW: 5Q0 937 084 DN
   Component: BCM MQBAB M   H42 0411
   Serial number: 01102019300077 Dataset Number: V03935326XJ 0001
   ASAM Dataset: EV_BCMMQB 021001
   ROD: EV_BCMBOSCH_021_VN54.rod
   VCID: 074C43465FA1B5621E1-8052
   Subsystem 1 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY201851JY9
   Subsystem 2 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000858106
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 DM    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0100050520200C101665
262936 - Sensor for anti-theft alarm system
          B1330 29 [00001001] - Signal Implausible
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2025.01.19
                    Time: 21:03:50
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.5 V
                    Outside temperature: 10.0  C
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058320191 Dataset Number: V03935332DP 0001
   Coding: 8431051041
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_009_VN54.rod
   VCID: 53F4A716DB79C9C2B29-8006
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935298V  0001
   Coding: 2A00400200EF8448949C814D00308700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
   VCID: 43D497562B195942029-8016
   Part No SW: 3Q0 959 655 CL    HW: 3Q0 959 655 CL
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z1PCBUEXZ Dataset Number: V03935296YM 0001
   Coding: 800080000000000040000000008840000065
   ROD: EV_AirbaVW21TS6VW48X_VN54.rod
   VCID: 0A4A7A724CB3C80A01F-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 801 803 20
   Component: FrontSensor_D  305 0109
   Serial number: 3550064FA0E1B000000V
   Subsystem 2 - Part No SW: -----------    HW: 454 801 803 20
   Component: FrontSensor_P  305 0109
   Serial number: 3560060F40E1B000000M
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7C0 920 941 D    HW: 7C0 920 941 D
   Component: KOMBI         202 8400
   Coding: 27A411002080260001882A010400000800200000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   ROD: EV_DashBoardVDDMQBAB_VN54.rod
   VCID: 270C23C6BF6195623E1-8072
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4424
   Revision: --------    Serial number: 0000966468 Dataset Number: V03935319JA 0001
   Coding: 030100044F05730000000000000F00010001070000000000000000000000
   GVL: 01443C0000000000400C80008000480000000000000000000000000000000000
   ROD: EV_GatewNF_VN54.rod
   VCID: 74B6048A3E37AEFA4B3-8020
   Generator:
   Component: 4-01-03-04-00
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39200000925430070151
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 2N0 915 181     HW: 2N0 915 181
   Serial number: 758849020020071500C1
   Part No SW: 5Q4 959 393 K    HW: 5Q4 959 393 K
   Component: TSG FS        007 0485
   Serial number: 0000414364519  Dataset Number: V03935300JU 0001
   Coding: 00300B208001020100001000
   ROD: EV_DCU2DriveSideMAXHCONT_VN47.rod
   VCID: 4BC4BF7603499102FA9-801E
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 2N0 909 143 G    HW: 2N0 909 143 C
   Component: EPS_MQB_ZFLS  701 7031
   Dataset Number: V03935311EH 0001
   Coding: 0107
   ASAM Dataset: EV_SteerAssisMNB 002009
   ROD: EV_SteerAssisMNB_VN54.rod
   VCID: 3138CD9E81A5DBD2E05-8064
   Part No SW: 5Q4 959 392 K    HW: 5Q4 959 392 K
   Component: TSG BFS       007 0485
   Serial number: 0000415054181  Dataset Number: V03935300JV 0001
   ROD: EV_DCU2PasseSideMAXHCONT_VN47.rod
   VCID: 4ACABA720C33880AC1F-801E
   Part No SW: 7C0 035 869 A    HW: 7C0 035 869 A
   Component: MU-E-D-ER     720 0890
   Serial number: 02072000020159 Dataset Number: V03935327TG 0001
   Coding: 064500003C00000041110101008000001F0000C60000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VN54.rod
   VCID: 2A0ADAF2AC73A80A21F-807E
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000006NVNV1 Dataset Number: V03935329QV 0001
   Coding: 0654200019E818008005460160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW27.rod
   VCID: 01585D5E71858B52505-8054
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Multi Function Display (0x0F) - Funktionseinschr nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 137676 km
                    Date: 2025.01.19
                    Time: 21:03:53
                    Voltage terminal 30: 12.5 V
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 00:56, VBatt start/end: 12.3V/12.6V)-----------
   #37
VWT6
Finland
C?ID=295527
Could you please post engine's blockmap data.
[VCDS]
[Applications]
[Controller Channel Map]
- Controller Address = 01
- Login or security code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
The blockmap file is placed in folder C:\Ross-Tech\VCDS\Logs
Open the blockmap-01.....CSV file using e.g. Notepad - select all - copy
Paste into <CODE> wrapper => symbol </> in editor menu
