VW Crafter Van 2020 No start
weldenie
Isle of Mull, Scotland
C?ID=597025
Driving vehicle and just stopped. Fault codes found as follows:
27277 PO562 System voltage too low
25126 Implausible data received from ESP control module U0416
No other fault codes found. Engine cranking. No start.
Any help would be appreciated.
weldenie
C?ID=597025
Hi Petrol Dave,
After Charging the battery to full doing a rescan and deleting the DTC's attempting to start and then a full rescan. This is what was in the engine module.
Friday,13,December,2024,12:28:25:51221
VIN: WV1ZZZSYZM9003165   License Plate: T16AHS 2
                Address 01: Engine       Labels: 04L-907-309-V2.clb
Control Module Part Number: 04L 906 056 SK    HW: 04L 907 445 P
  Component and/or Version: R4 2.0l TDI   H01 9973
           Software Coding: 001940346324050800000000000000000000000000000000
            Work Shop Code: WSC 00000 000 00013
              ASAM Dataset: EV_ECM20TDI03004L906056SK 007007 (VN54)
                       ROD: EV_ECM20TDI03004L906056SK_007.rod
                      VCID: 084E407A52BFBA1A17B-805C
27277 - System Voltage
          P0562 00 [00100011] - Too Low
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:18:40
                    Engine RPM: 0.00 /min
                    Coolant temperature: 6  C
                    Intake air temperature: 6  C
                    Voltage terminal 30: 12.609 V
                    Air mass at air mass meter 1: 0.0 kg/h
                    Standardized air flow ratio: 1.000 counts
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 2.01 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Charge air pressure: specified value: 0.003 bar
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1019 mbar
                    Mean injection quantity: 0 mg/stroke
                    Index of current engine mode: 7
                    Index of next requested engine mode: 7
                    Index of engine target mode: 7
Readiness: N/A
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:18:40
                    Coolant temperature: 7  C
                    Intake air temperature: 8  C
                    Voltage terminal 30: 12.625 V
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1023 mbar
25126 - Implausible Data Received from ESP Control Module
          U0416 00 [00100011] - -
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:22:46
                    Voltage terminal 30: 12.179 V
                    Acceleration: 0.000 m/s
                    Average vehicle speed: 0.00 km/h
                    Cruise Control System (CCS): status: Initialization
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: No
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: N/A
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:18:40
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:22:46
Readiness: N/A
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:18:40
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:22:46
Readiness: N/A
NZDubNurd
New Zealand
C?ID=230482
Also, does it sound normal, cranking? Maybe post a link to a video if you aren't sure.
weldenie
C?ID=597025
Hi engine turns over fine ,tank fuel pump running ,fuel at filter and hp fuel pump running
fuel rail pressure is 49000 psi and 52000 no power/voltage at injectors
Dr Sheldon
Windsor UK
C?ID=334979
Where is the AUTOSCAN ???
How many times do you need to be asked ?? I'm sure it will be difficult to help you !!
weldenie
C?ID=597025
Clue !!
its not here !!
autoscan
Monday,16,December,2024,10:09:51:51221
VIN: WV1ZZZSYZM9003165   License Plate: TI6AHS FULL SCAN
Mileage: 137676km-85547mi   Repair Order:
Chassis Type: SY-VN54 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 42 44 52 5F 75 BB BC
VIN: WV1ZZZSYZM9003165   Mileage: 137676km-85547miles
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DAUA)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 SK    HW: 04L 907 445 P
   Component: R4 2.0l TDI   H01 9973
   Revision: 23203001
   Shop #: WSC 00000 000 00013
   VINID: 9E606AAAA8E9A9D240003046142A1B25D0
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:51:06
                    Coolant temperature: 10 °C
                    Intake air temperature: 0 °C
                    Voltage terminal 30: 12.023 V
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 1.60 %
                    Charge air pressure: specified value: 0.002 bar
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1015 mbar
                    Index of current engine mode: 4
                    Mileage: 137173 km
                    Voltage terminal 30: 11.906 V
                    Acceleration: 0.000 m/s²
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 2N0-907-379-V1.clb
   Part No SW: 2N0 907 379 E    HW: 2N0 907 379 C
   Component: ESC_base      H02 0870
   Serial number: 08503636200709
   Coding: 25A82477483DB685A448246612486D063BF144B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 704031
   ROD: EV_Brake1ESP90iBOSCHVN54X_704.rod
   VCID: 382EF0BA62DF0A9AA7B-806C
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [10001001] - -
          [Scl_LWI_Lenkradwinkel_Error]
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7C0 907 426 AD    HW: 7C0 907 426 AD
   Component: AC Manuell    H01 0401
   Coding: A03110000800000001000800500101000000000000000000000000000000
   Shop #: WSC 00000 000 00023
   ASAM Dataset: EV_AirCondiBHTCVN54X 003020
   ROD: EV_AirCondiBHTCVN54X_003_VN54.rod
   VCID: 6B841FF6630971029A9-803E
   Part No SW: 5Q0 937 084 DN    HW: 5Q0 937 084 DN
   Component: BCM MQBAB M   H42 0411
   Serial number: 01102019300077 Dataset Number: V03935326XJ 0001
   ASAM Dataset: EV_BCMMQB 021001
   ROD: EV_BCMBOSCH_021_VN54.rod
   VCID: 074C43465FA1B5621E1-8052
   Subsystem 1 - Part No SW: 5Q0 951 605 B    HW: 5Q0 951 605 B
   Component: Sirene, DWA  004 0007
   Serial number: 00000000000000858106
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 DM    HW: 5Q1 953 569 D
   Component: Lenks.Modul  H04 0180
   Serial number: 0100050520200C101665
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [00001001] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:41
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    Voltage: 12.6 V
                    Outside temperature: 6.0 °C
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058320191 Dataset Number: V03935332DP 0001
   Coding: 8431051041
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_009_VN54.rod
   VCID: 53F4A716DB79C9C2B29-8006
13637426 - Databus
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Dataset Number: V03935298V  0001
   Coding: 2A00400200EF8448949C814D00308700000000000000000004
   ROD: EV_ACCMRRCONTIVW376_003_VN54.rod
   VCID: 43D497562B195942029-8016
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Fault Frequency: 9
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
                    Voltage terminal 15: 12.6 V
                    Control Module temperature: 28 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.63 m/s²
                    Adaptive distance regulation: status: ACC_reversible_error
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Fault Frequency: 9
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
   Part No SW: 3Q0 959 655 CL    HW: 3Q0 959 655 CL
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z1PCBUEXZ Dataset Number: V03935296YM 0001
   Coding: 800080000000000040000000008840000065
   ROD: EV_AirbaVW21TS6VW48X_VN54.rod
   VCID: 0A4A7A724CB3C80A01F-805E
   Subsystem 1 - Part No SW: -----------    HW: 454 801 803 20
   Component: FrontSensor_D  305 0109
   Serial number: 3550064FA0E1B000000V
   Subsystem 2 - Part No SW: -----------    HW: 454 801 803 20
   Component: FrontSensor_P  305 0109
   Serial number: 3560060F40E1B000000M
Address 17: Instruments (J285)       Labels:| 7LA-920-XXX-V1.clb-SRI3
   Part No SW: 7C0 920 941 D    HW: 7C0 920 941 D
   Component: KOMBI         202 8400
   Coding: 27A411002080260001882A010400000800200000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   ROD: EV_DashBoardVDDMQBAB_VN54.rod
   VCID: 270C23C6BF6195623E1-8072
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4424
   Revision: --------    Serial number: 0000966468 Dataset Number: V03935319JA 0001
   Coding: 030100044F05730000000000000F00010001070000000000000000000000
   GVL: 01443C0000000000400C80008000480000000000000000000000000000000000
   ROD: EV_GatewNF_VN54.rod
   VCID: 74B6048A3E37AEFA4B3-8020
   Generator:
   Component: 4-00-05-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-MD9  H18 0052
   Serial number: 39200000925430070151
   Coding: 28FFFF
   Subsystem 3 - Part No SW: 2N0 915 181     HW: 2N0 915 181
   Serial number: 758849020020071500C1
197175 - Control unit for battery monitoring
          U1050 00 [00001000] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 67
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:39
                    Terminal 30 power supply: 12.4 V
                    Terminal 15: On
   Part No SW: 5Q4 959 393 K    HW: 5Q4 959 393 K
   Component: TSG FS        007 0485
   Serial number: 0000414364519  Dataset Number: V03935300JU 0001
   Coding: 00300B208001020100001000
   ROD: EV_DCU2DriveSideMAXHCONT_VN47.rod
   VCID: 4BC4BF7603499102FA9-801E
          B1487 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:43
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 2N0 909 143 G    HW: 2N0 909 143 C
   Component: EPS_MQB_ZFLS  701 7031
   Dataset Number: V03935311EH 0001
   Coding: 0107
   ASAM Dataset: EV_SteerAssisMNB 002009
   ROD: EV_SteerAssisMNB_VN54.rod
   VCID: 3138CD9E81A5DBD2E05-8064
16128 - Steering Angle Sensor
          B1168 F2 [00101111] - Not Initialized
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
                    Motor status: 00
                    Supply voltage: 12.50 V
                    Temperature: 19.0 °C
                    KFC: 3F
                    KFA: 00 02
                    Freeze frame conditions: 5F
   Part No SW: 5Q4 959 392 K    HW: 5Q4 959 392 K
   Component: TSG BFS       007 0485
   Serial number: 0000415054181  Dataset Number: V03935300JV 0001
   ROD: EV_DCU2PasseSideMAXHCONT_VN47.rod
   VCID: 4ACABA720C33880AC1F-801E
   Part No SW: 7C0 035 869 A    HW: 7C0 035 869 A
   Component: MU-E-D-ER     720 0890
   Serial number: 02072000020159 Dataset Number: V03935327TG 0001
   Coding: 064500003C00000041110101008000001F0000C60000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VN54.rod
   VCID: 2A0ADAF2AC73A80A21F-807E
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000006NVNV1 Dataset Number: V03935329QV 0001
   Coding: 0654200019E818008005460160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW27.rod
   VCID: 01585D5E71858B52505-8054
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
          [Multi Function Display (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:41
                    Voltage terminal 30: 12.6 V
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 00:52, VBatt start/end: 12.1V/12.2V)-----------
weldenie
C?ID=597025
You have faults in other modules so a complete Auto-Scan is essential.
   Revision: 23203001
                    Mileage: 137173 km
                    Date: 2024.12.10
                    Time: 00:51:06
                    Mileage: 137173 km
Readiness: N/A
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:41
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.6 V
   Coding: 8431051041
13637426 - Databus
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
2101 - Databus
                    Fault Frequency: 9
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
2055 - Databus
                    Fault Frequency: 9
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
   Generator:
   Coding: 28FFFF
                    Reset counter: 67
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:39
                    Terminal 15: On
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:43
   Coding: 0107
                    Reset counter: 27
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:38
                    Motor status: 00
                    KFC: 3F
                    KFA: 00 02
                    Mileage: 137676 km
                    Date: 2024.12.10
                    Time: 00:18:41
Dr Sheldon
Windsor UK
C?ID=334979
Lots of Battery / T30 Voltage errors there - All at 0 rpm !!
That makes me wonder what Voltage the battery is dropping to when Cranking??
How exactly have you measured Voltage at injectors ??
Can you graph with VCDS
Battery Voltage
Engine RPM
Fuel Rail Pressure
You could use a good set of Jump leads to another vehicle to see if it fires up.
Attach the Jump Leads. Leave the Donor Vehicle Running for 5 minutes - Then Crank and try !!
weldenie
C?ID=597025
Battery Voltage
Engine RPM
Fuel Rail Pressure
weldenie
C?ID=597025
Hi Thanks for reply , I've already tried the second battery supply , it didn't start ,voltage stayed at about 12.68 volts at cranking
I used ob11 reader for fuel pressure and removed the plug on injector number one and turned it over with a good volt meter connected to the injector plug only reading about .2 volts
never graphed any of the vcds but can try how do I do that ?
only bought the van 3 months ago so don't no much of its history , never missed a beat until it stopped a week ago with no warnings I was just traveling along and it just stopped almost as if you had stalled it on a hill start .
Dr Sheldon
Windsor UK
C?ID=334979
That is a worry !! Suggests no resistance from the Starter Motor ?? Which then suggests no resistance from the Engine !!
