2015 audi s3 so many codes that came up but not sure how to identify the actual code to look up
C?ID=255798
audi s3
2015
from the drivers seat i am seeing that the warning about presence not working right.
i know that the HVAC flap is having issues even after i fixed it myself. i believe i need to physically fix it to align up first for it work correctly.
O2 sensor issue is because i have a downpipe. so no real issue there.
now the other malfunctions i dont know what the actual code is to look up to know how to fix it. or the known fixes that are out there.
need help reading all these as well.
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
          55 5F 6C A5 A9 BB BC
VIN: WAUFFGFF4F1112359   Mileage: 155596km-96682miles
Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 259 E    HW: 06K 907 425 E
   Revision: --H13---    CVN: BEF084D4
   Coding: 0A1D00322466000E3004
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208V0906259E 001003
   ROD: EV_ECM20TFS0208V0906259E.rod
   VCID: 428B1CFFD54E5A869D-8016
   VINID: 9D19565975961160410420C5246E0356A0
18933 - Oxygen (Lambda) Sensor Signal B1 S2
          P2270 00 [11101101] - too Lean
                    Mileage: 155485 km
                    Date: 2024.12.09
                    Time: 08:00:56
                    Engine RPM: 2071.25 /min
                    Normed load value: 25.9 %
                    Vehicle speed: 86 km/h
                    Coolant temperature: 101  C
                    Intake air temperature: 17  C
                    Voltage terminal 30: 14.082 V
                    Engine: operating status: PL
                    STATE_LS_SAE[1]: CL
                    VLS_DOWN_SAE[1]: 0.940 V
                    Lambda probe heater: resistance: bank 1: probe 2: 328 Ohm
                    LAMB_DELTA_I_LAM_ADJ[1]: 0.00024
                    Lambda probe correction: duty cycle offset: bank 1: 0.00024
                    TEG_DYN_LS_DOWN[1]: 632.7250  C
Readiness: 0000 0001
   Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4932
   Revision: 06454104    Serial number: TFK02307210304 CVN: 0000D5C0
   Shop #: WSC 04940 001 00001
   ROD: EV_TCMDQ250021.rod
   VCID: 1F4DB58B067C576ED2-804A
   Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
   Component: ESC           H42 0711
   Revision: 00000000    Serial number: 60235000000540
   Coding: 31FF6B9254210A6E017A030541CC698CD62A5080C08296B6184150D88204
   Shop #: WSC 42927 001 104857
   ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
   VCID: 49990BD3E87889DE5C-801C
   Revision: 00021000    Serial number: 0358576375 Dataset Number: 8V0909577C  0009
   Coding: 030C0C
   VCID: 3A7B641FBD9E1246C5-806E
   Component: AC Automat    H13 0060
   Revision: 20027000    Serial number: 00000000561678
   Coding: 03000014010000000000000000001400
   VCID: 3365493B9AF4E30E06-8066
   Humidity sensor: exterior:
   Serial number: F188CE87000000000001
329989 - Motor for Defroster Flap
          B1090 54 [00001001] - Missing Calibration / Basic Setting
                    Reset counter: 242
                    Mileage: 155480 km
                    Date: 2024.12.08
                    Time: 18:56:20
                    Voltage terminal 30: 12.6 V
                    Inside temperature: 32.4  C
                    Outside temperature: 22.5  C
                    Defrost door - Specified value: 259
                    Defroster flap: actual value: 256
                    Defroster flap: actual value: 20.5 %
   Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
   Component: BCM MQBAB HNA H18 0137
   Serial number: 01011502600303 Dataset Number: 8V0909514L  0083
   Coding: 04151C46C04106FD45C04004510003A00800000000000000000000000000
   Shop #: WSC 12345 123 61029
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7AFBA41FFD1ED24685-802E
   Component: WWS371 150126  042 0585
   Serial number:         150130064653
   Coding: 0A47F7
   Serial number: 23684779
   Coding: 00006C
   Serial number: 04 12 2014  00000016
   Serial number: 00000000000061570698
   Sunroof control module:
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST0004HHUW00000
   Coding: 101F00
558100 - Databus
                    Reset counter: 30
                    Mileage: 155503 km
                    Date: 2024.12.09
                    Time: 16:35:31
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Position lamps: Not operated
                    Low beam: Not operated
                    last_wakeup: g ltiges Funktelegramm
                    Voltage: 14.1 V
                    Outside temperature: 18.0  C
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39391502709595 Dataset Number: 8V0909526D  0040
   Coding: 0070150011
   ROD: EV_EPHVA18AU3700000_VW26.rod
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 N    HW: 5Q0 907 567 N
   Component: ACC3          H10 0400
   Serial number: 29011503033504 Dataset Number: 8V0909863C  0015
   Coding: 01261701FE0309
   ASAM Dataset: EV_ACCBoschMQB 001024
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 468300EFF96666A6B1-8012
1043 - Automatic Distance Control
          B10E7 F0 [00101000] - Disconnected
                    Reset counter: 27
                    Mileage: 155480 km
                    Date: 2024.12.08
                    Time: 18:56:20
                    Control Module temperature: 32  C
                    Voltage terminal 15: 12.5 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s
1050 - Transmission in Limp Mode
          P305B 00 [00101000] - -
                    Reset counter: 27
                    Mileage: 155480 km
                    Date: 2024.12.08
                    Time: 18:56:20
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       280115002 Dataset Number: 8V0909554D  0013
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
   VCID: 438519FBCA54538E96-8016
   Serial number: 003GCR01BWV4 Dataset Number: 8V0909602F  0005
   VCID: 479D0DEBFE6C7FAE4A-8012
   Left seat belt tensioner:
   Serial number: 34178311B02021541509
   Coding: 333135
   Right seat belt tensioner:
   Serial number: 34178312B02021541326
   Coding: 333135
   Serial number: 6940000Y140001A5F508
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 002 901 15
   Serial number: 35700000000ABA3D721T
   Subsystem 5 - Part No SW: -----------    HW: 480 002 901 15
   Serial number: 35800000000BEA3D721Y
   Subsystem 6 - Part No SW: -----------    HW: 480 402 801 15
   Serial number: 3510002C9192BC713350
   Subsystem 7 - Part No SW: -----------    HW: 480 402 601 15
   Serial number: 35200029B19121A3828Y
   Subsystem 8 - Part No SW: -----------    HW: 480 403 110 14
   Serial number: 3550002A91860BA303F5
   Subsystem 9 - Part No SW: -----------    HW: 480 403 110 14
   Serial number: 3560002A91860BA1517%
9445929 - Seat occupied recognition control module
          B1022 29 [00001000] - Signal Implausible
                    Reset counter: 30
                    Mileage: 155503 km
                    Date: 2024.12.09
                    Time: 16:35:35
9577755 - Sensor Mat for Seat Occupied Detection
          B1225 1B [00001000] - Resistance Too High
                    Reset counter: 30
                    Mileage: 155503 km
                    Date: 2024.12.09
                    Time: 16:35:31
Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
   Part No SW: 8V0 953 521 ED    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 27011508490397
   Coding: E818
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 000FD6F79BC28896CB-8054
No ASAM data for: "EV_SMLSKLOMQB" (AU37)
   Part No SW: 8V0 920 970 S    HW: 8V0 920 970 S
   Component: KOMBI         H02 4292
   Coding: 03CD181B7F88CF050289FA041800000200000000
   VCID: 4C9732C7E70A9CF667-8018
   Revision: --------    Serial number: 31011510802262 Dataset Number: 8V0909515F  0060
   Coding: 0101000830085A005B00023C980B00000001010000000000000000000000
   GVL: 01D43C100000060040CC90000002CC0000000000000000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72EB8C3FA56EAA06CD-8026
   Generator:
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 17 01 2015  D0050847
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00019.11.14 Dataset Number: v1260x015G0 0000
   Coding: 0001
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
   Revision: 00000000    Serial number: 15000016664003
   Coding: 5D00000000000000
   VCID: 34674A279FFAE4361F-8060
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0355372304 Dataset Number: 8V0909535E  0033
   Coding: 030211
   ROD: EV_LaneChangAssis_VW52.rod
   VCID: 387F7E178392005633-806C
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0357648676
   Coding: 030211
   Serial number: 250115BAP05331 Dataset Number: 8V0909872F  0032
   Coding: 005D1F205C00048000000003
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Dataset Number: 8V0909852K  0022
   Coding: 9102
   VCID: 377D7D2B8E8C0F2E3A-8062
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN90108U+ Dataset Number: 8V0909510B  0017
   Coding: 01030300AAAA2AAA01
   ASAM Dataset: EV_AMPMst16C1ALPI 004024
   ROD: EV_AMPMst16C1ALPI_004_AU37.rod
   Serial number: 220115BAL11867 Dataset Number: 8V0909873F  0032
   Coding: 005D17205E00048000000003
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   VCID: 418913F3D048419E84-8014
   Component: AFS-ECU       H01 0091
   Revision: --------    Serial number: -------------- Dataset Number: 8V0909865L  0038
   Coding: 0122000123200400
   VCID: 3F8D150BA6BC376EF2-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
   Part No SW: 8V0 035 038 G    HW: 8V0 035 038 B
   Component: MU-H-LNS-US   H43 0394
   Serial number: A302B0FB009458 Dataset Number: 8V2909545F  0045
   Coding: 017301020000000021220002041A00102F000225010001047E
   ROD: EV_MUHig6C3HBAS_VW48.rod
   Subsystem 1 - Part No SW: V03 959 800 SS    HW: -----------
   Component: NAR 2015  --- 0035
   Multimedia System 1:
   Component: DU High  H49 0014
   Serial number: AUZ8Z9EY202HEF
   Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
   Component: ControlUnit_H  H81 0816
   Serial number: C1000029111400020188
   Compact disc data bank:
   Component: Gracenote  --- 3006
   Dataset Number: 8V0909460C  0017
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
   VCID: 306F46376BE2D8167B-8064
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000277395    Dataset Number: 8V0909466K  0039
   Coding: 0100000000010303000500010100000100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B75611BB2A42B4EDE-806E
   Part No SW: 8V0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0012
   Serial number: 150109200749
   VCID: 7DF1AF03EC30E57EA0-8028
   Part No SW: 5Q0 959 395 D    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0028
   Serial number: 140115CAD07887 Dataset Number: 8V0909897D  0018
   Coding: 004D17204000048000000002
   ROD: EV_DCURearDriveMAXKLO.rod
   Component: TSG HBFS      020 0028
   Serial number: 140115CAD07353 Dataset Number: 8V0909896D  0018
   ROD: EV_DCURearPasseMAXKLO.rod
Have you inspected the relevant wiring/connector(s)?
