alh injector
ivagp
C?ID=95551
just wanted to know has anyone seen compression blowing thru the injector. im going to run diesel purge just to see. with the pipe off and cranking u can see on every stroke a slight puff.
Keithuk
Stoke on Trent, England
C?ID=122432
The ALH TDI-PD engine suffers from leaking injector seals which causes diesel to dilute the engine oil.
Gone But Not Forgotten
If that is truly happening that injector is smoked............
ivagp
C?ID=95551
this is a 99.5 alh with 5 speed jetta. i have access to an auto pump and injectors, what is the pros and cons of doing this swap
smokey08
C?ID=120732
Pump from auto has bigger internals, injectors from auto has smaller nozzles. In theory the pump voltage calibration map inside the ecu would have to be changed to make it run nicely.
ivagp
C?ID=95551
also the clutch is fairly new. its the factory luk, i think its rated at 185 ft lbs of torque i don't really want to overpower the clutch. educate me on this which injectors would u put and why
