Steering wheel module Golf V 2008
diego.jover
Pirate
Walking the Plank
Portugal
Hello, I have a 2008 Golf and the steering wheel module was not working with the onboard commands and horn. I bought an used one with same codes but when I plug it onboard commands and horn works but steering assistance is not working. I understand that I need to copy the codes from the old module to the new one, right? Do you have any guide to do this?
Do I need to connect to VW server?
I don't have any VAG tool yet, I understand I can buy vcds and do it, right?
Thanks for your help!!
Are you using a RT VCDS product? (edit, I see you don't have a VAG hardware/software)
I do not believe so.
A couple options as I understand your question:
One, find someone with a Legitimate VCDS and get a complete Auto-Scan and post it here with you Thread.
Otherwise, post your VIN and someone here may be able to look up the data on your vehicle.
Or, purchase a VCDS Hex-V2 interface.
Portugal
Cardinais - Português!
Rua Alexandre Herculano 159
4400-007 Vila Nova de Gaia, Porto
Portugal
+351 22 492 08 77
diego.jover
Pirate
Walking the Plank
Portugal
Thanks!
My idea was to buy the VCDS if I can recode the module without connecting to VW server. I have the old module installed and the new one ready to install.
Is there any guide on how to do this?
Is there anyway to confirm that I don't need the VW server? I heard something about the VIN in the module..
Thanks!!
Dr Sheldon
Windsor UK
C?ID=334979
I sure you can code Steering Control Module with VCDS - It is not part on the Immo
  • Agree
cristo_844
Portugal
C?ID=412536
O modulo nao tem Vin!
Compra o VCDS de um distribuidor autorizado, de seguida posta um auto-scan que ajuda na instalação ira aparecer!
The module does not have Vin!
Buy the VCDS from an authorized distributor, then post a auto-scan that help with the installation will appear!
diego.jover
Pirate
Walking the Plank
Portugal
Here is the auto scan.
Help would be appreciated.
Thanks!!
Removed.  Data from a clone/pirate copy of VCDS is not acceptable in Ross-Tech's forum.
NEtech
Denmark
C?ID=56995
You are using a clone!
