Hello
I purchased an SQ8 as a stolen and recovered vehicle. The body control module has been replaced by Audi with two new keys. I still have a lot of fault codes and cannot open the doors or windows unles using the physical key in the drivers door which is the only one that then opens. The main problem I have is an active front sway bar that was damaged before I purchased the vehicle. I have repaired the wiring on the sway bar and want to check if the repair has been successful. The Audi techs tell me this problem may be the source of other issues, so this is where I should start. I would love some help confirming and interpreting the fault codes and making the car operational. Full scan below.
Tuesday,10,December,2024,14:07:14:38984
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4643.5
VIN: WAUZZZF19ND024845 License Plate:
Chassis Type: F1-AU58 (4KL)
Scan: 01 02 03 06 09 13 15 16 17 19 32 36 3C 42 44 46 52 5F 61 65
6D 74 75 81 82 A5 A9 BA BB C4 CA CB CF D4 D5 D6 D7 DB DC DE
VIN: WAUZZZF19ND024845 Mileage: 12355km-7677miles
74-Chassis Control -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
D4-Roll Control 1 -- Status: Malfunction 0010
D5-Roll Control 2 -- Status: Malfunction 0010
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
Address 01: Engine (------DCUE) Labels: Redir Fail!
Part No SW: 4M0 906 014 A HW: 0P2 907 309 A
Component: V8 4.0l TFS H31 0003
Revision: 72H31000 CVN: EE7628F2
Coding: 2A2A4012256E050B342C0000000000000000000000000000
Shop #: WSC 28379 006 1048576
ASAM Dataset: EV_ECM40TFS0114M0906014A 001005
ROD: EV_ECM40TFS0114M0906014A.rod
VCID: 26122E06486E89BA057-8072
VINID: 9D196AAAA58125E50008420414ED214D8A
Readiness: 1010 0001
Part No SW: 4M8 927 158 T HW: 0D6 927 156 J
Component: 0D6 40FSIRdW H06 0001
Revision: --H06--- CVN: D7178AAC
Coding: 100000
Shop #: WSC 31414 033 00001
ASAM Dataset: EV_TCMALX52011 002016
ROD: EV_TCMALX52011.rod
VCID: 4DC0B1AA0D589AE2E4D-8018
Address 03: ABS Brakes (J104) Labels: 4M0-907-379-V1.clb
Part No SW: 4M6 907 379 AF HW: 4M6 907 379
Component: ESP9 Premium H07 0857
Dataset Number: 4M8909504M 0005 CVN: 50A63DA5
Coding: 2CAA629630A40B9A93A64D955C8296E2E5BAC934460CD0C9B23A6947A75D93
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 01585D9A81808E82505-8054
0327 - Implausible Data Received from Suspension Control Module
U042B 00 [00101111] - -
[Signal_AFR_Fehlers_faulty(1.2:3]
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:09
75 00 80 00 C2 03 00 00 F0 60
Unlearning counter according OBD-OBD unlearning counter: 28
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M8 959 760 B HW: 4M6 959 760 B
Component: MEM-BFS 009 0064
Serial number: 00000467113454 Dataset Number: 4M8909866B 0015
Coding: 0138B2400001BE810043010101010000810000070700878700000000000000
ASAM Dataset: EV_SCMPasseSideCONTIAU736 006013
ROD: EV_SCMPasseSideCONTIAU736_VW38.rod
VCID: 3FDC9B62B7F43872661-806A
Valve block 1 in front seat passenger side:
Subsystem 1 - Part No SW: 4N0 907 182 HW: 4N0 907 182
Component: N477 VB1 BFSv H04 0011
Serial number: SJ8001190322402581DB
Coding: BF2F00
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 LE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0728
Dataset Number: 4M8909514L 0034
Coding: 07000143C13900DD070E57889FEF8C78130B33100426009701010A001B3316810A4509020010000000000100004109185802000044010104000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 018005
ROD: EV_BCM1BOSCHAU651_018.rod
VCID: 7CA62C6EE662E36A033-8028
Subsystem 1 - Part No SW: 4M8 955 119 C HW: 4M8 955 119 A
Component: J400FRWISCH 052 0997
Serial number: 904853F0402201100182
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 B HW: 81A 955 555
Component: G397_RLFSS H06 0004
Serial number: 43240617X81A955555B0
Coding: 02005D
Subsystem 3 - Part No SW: 4K2 941 501 A HW: 4K2 941 501 A
Component: E1 - LTM H09 0086
Serial number: 16S15.02.2200692491
Subsystem 4 - Part No SW: 8W0 857 511 F HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE108122123610338
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 AL HW: 4K0 947 135 AL
Component: Dachmodul H42 0416
Serial number: B02196928
Coding: 0D0104
Subsystem 6 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V512 LLR1SLvL H01 0012
Serial number: Q98BN08323463
Subsystem 7 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V514 LLR1SKvL H01 0012
Serial number: Q98BN06429090
Subsystem 8 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V516 LLR1SLvR H01 0012
Serial number: Q98BN090A2403
Subsystem 9 - Part No SW: 4N0 963 575 A HW: 4N0 963 575 A
Component: V518 LLR1SKvR H01 0012
Serial number: Q98BN08383354
67735 - Databus
[MxB not available]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:09
average_Voltage_terminals: 11.60 V
Outside air temperature sensor-Outside air temperature on CAN: 28.50 °C
interior_temperature: 30.50 °C
Vehicle speed: 0.00 km/h
67737 - Databus
[MXB_error-lamp_requested]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.10
Time: 14:04:51
average_Voltage_terminals: 11.30 V
Outside air temperature sensor-Outside air temperature on CAN: 25.50 °C
interior_temperature: 24.50 °C
262161 - Lamp 1 for Contour Lighting of Door; Rear Left
U117A 00 [00001001] - No Communications
[Left rear door contour illumination lamp 1: No communication]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:19
System run time-Terminal 15 on: 297 s
262181 - Lamp 1 for Ambient Lighting of Door; Rear Left
U1188 00 [00001001] - No Communications
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:19
System run time-Engine running time: 65535 s
System run time-Terminal 15 on: 65535 s
Address 13: Auto Dist. Reg (J428) Labels:* Redir Fail!
Part No SW: 4M0 907 561 P HW: 4K0 907 561
Component: LRR4R H12 0500
Dataset Number: 4M8909863M 0003
Coding: 3764E75478082C00000020A00000003E4A1246484401409E91
ASAM Dataset: EV_ACCBOSCHAU65X 002031
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 3D20E16ABDF82A6274D-8068
2342 - Databus
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:08
Control Module temperature: 51 °C
Voltage terminal 15: 11.5 V
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_reversible_error
Steering_angle-Data: 13.300 °
Yaw_rate-Data: 0.000 rad/s
adjustment_calculation: On
Misalignment angle: horiz: -0.695 °
Misalignment angle: horiz: fast algorithm: -0.868 °
Congestion pilot: status: OFF
Outside temperature: 28.50 °C
Sensor blindness: radar: no blindness detected
2345 - Databus
[FAULT_CAMERA_ERROR]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:08
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 AF HW: 4N0 959 655 AF
Component: AirbagVW31 H10 2844
Serial number: 0031MM00ZFV0 Dataset Number: 4M8909602BC 0002
Coding: AAFCF0C000C000009854003FF08D49A800C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001042
VCID: 005E589E8A8A878A5FB-8054
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2022080383100000
Coding: 03F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2022083330000000
Coding: 03F001
Subsystem 3 - Part No SW: ----------- HW: 480 000 303 22
Serial number: 35700000000827090A5D
Subsystem 4 - Part No SW: ----------- HW: 480 002 502 22
Serial number: 3580000000032905AD5K
Subsystem 5 - Part No SW: ----------- HW: 480 032 802 22
Component: SideSensor_Dr 002 0149
Serial number: 351003C00005A090F94X
Subsystem 6 - Part No SW: ----------- HW: 480 032 602 22
Component: SideSensor_Pr 002 0149
Serial number: 352003C006684AB0D849
Subsystem 7 - Part No SW: ----------- HW: 480 031 903 22
Component: FrontSensor_D 002 0149
Serial number: 355003C00BF3AA712F2I
Subsystem 8 - Part No SW: ----------- HW: 480 031 903 22
Component: FrontSensor_P 002 0149
Serial number: 356003C0051AA9C03EFM
Crash sensor for side airbag: B-pillar: driver side:
Subsystem 9 - Part No SW: ----------- HW: 480 032 802 22
Component: SideSens_B_Df 002 0149
Serial number: I0P003C006664DA0AD0/
Crash sensor for side airbag: B-pillar: passenger side:
Subsystem 10 - Part No SW: ----------- HW: 480 032 602 22
Component: SideSens_B_Pf 002 0149
Serial number: I0Q003C00669CCE02A9A
1065481 - Databus
[NWD: 0xTBD BV_SensorHeader error value BV2_NichtVerfuegbar]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
Part No SW: 4N0 907 129 NJ HW: 4N0 907 129 NJ
Component: Lenks.Modul H03 0009
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 06524E86A8AEA9BA657-8052
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4K0 920 790 F HW: 4K0 920 790 F
Component: FBenRDW------ H27 0115
Coding: 2D8D62EC7EA8000801A0E3609000100008003000
ASAM Dataset: EV_DashBoardAU65X 002027
ROD: EV_DashBoardAU65X_002_AU58.rod
VCID: 303EC85E7AAAD70AEFB-8064
Part No SW: 4KL 907 468 F HW: 4K1 907 468 C
Component: Gateway H08 0613
Serial number: F0745712141421 Dataset Number: 4K0909515L 0075
Coding: 03030001000886405407000000590132FC9A0040BC0000000900008E02000000
GVL: F1593C580840000002FC88008100C800110C0070000000000000000000006700
ASAM Dataset: EV_Gatew31xAU65x 003250
ROD: EV_Gatew31xAU65x_AU58.rod
VCID: 53F4A7D22B7CCC12B29-8006
Subsystem 1 - Part No SW: 4M8 951 523 J HW: 4M8 951 523 J
Component: J453 MFL H07 0004
Serial number: 20220323050350 30430
Subsystem 2 - Part No SW: 4K0 915 181 A HW: 4K0 915 181 A
Serial number: 75885203002203051713
Subsystem 3 - Part No SW: 4M8 419 508 A HW: 4M8 419 508 A
Component: J1158 KLR H13 0011
Serial number: 00000000000000253007
Coding: FFFFFF
131712 - Ride Level Control Module
U0132 00 [00001000] - No Communications
[Timeout_Node_0x80_DiagAdress_74_EFP]
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.08
Time: 10:28:25
131830 - Ethernet Module for Emergency Call
U1642 00 [00001000] - No Communication
[Timeout_Node_0xF6_conBox_DiagAdress_0075]
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.04
Time: 20:22:56
9502727 - Databus
[BMS_No_Component_Function]
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:08
48V activation restriction-Airbag control module: not active
48V activation restriction-Engine Electronics: not active
48V activation restriction-Roll stabilization: not active
48V activation restriction-48 V activation restriction due to open circuit: not active
48V activation restriction-48 V activation restriction due to deactivation: not active
48V activation restriction-Battery management 2: active
48V activation restriction-Voltage converter: not active
48V activation restriction-Auxiliary Air Heater Control Module/PTC: not active
48V activation restriction-Electrical compressor: not active
9502742 - Databus
[eAWS_No_Component_Function]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:08
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 A HW: 8W0 907 163
Component: QSP QCU Gen2 H08 0070
Revision: 5WK12701 Serial number: 605212211200807
Coding: 0500
ASAM Dataset: EV_TVDCQSP22 001008
ROD: EV_TVDCQSP22.rod
VCID: 3A2AEA76ACD61D5A51F-806E
Component: MEM-FS 009 0064
Serial number: 00000466697556 Dataset Number: 4M8909856B 0015
Coding: 01389A400001BE810083010101010000810000070700878700000000004000
Valve block 1 in front seat driver side:
Component: N475 VB1 FSv H04 0011
Serial number: SJ8001190322402582FE
Coding: BF2F00
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 AM HW: 4N0 907 566 A
Component: MRR_HR H24 0588
Dataset Number: 4M8909535E 0016
Coding: 4FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001022
ROD: EV_RearRadarS1DelphAU651.rod
2240525 - Databus
[databus error value received - TSG_FT_01 - ASW_HMI_defekt]
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:08
Control Module temperature: 58 °C
Voltage terminal 30: 11.40 V
Terminal 15 status: On
Voltage terminal 15: Measuring value not available
Part No SW: 4M1 959 793 J HW: 4M1 959 793 D
Component: TSG FS003 0430
Serial number: YE007VBD15292 Dataset Number: 4M8909872D 0028
Coding: 001DCA4252010482A009B432
VCID: 46D28E86E82E69BA257-8012
196645 - Local Data Bus
U10BA 00 [00001001] - No Communication
[Door electronics passenger side rear Function limitation due to missing message]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:12:34
196705 - Function Restricted due to Incorrect Signature
B201D 00 [00001000] - -
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.04
Time: 20:17:34
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Dataset Number: 4M8909852K 0001
Coding: B2130301000100
ROD: EV_EPSVWBSAU426_010.rod
VCID: 323AC25674A6E51A99F-8066
Part No SW: 8W1 907 064 DH HW: 8W1 907 064 H
Component: BCM2 MLBevo 044 0604
Dataset Number: 4M8909501J 0041
Coding: 013500000FB100406309A0066C00880203004000804F06502F0400200504823F001F06800D0F35
ASAM Dataset: EV_BCM2HellaAU736 020017
ROD: EV_BCM2HellaAU736_020.rod
Subsystem 1 - Part No SW: 5Q0 951 177 A HW: 5Q0 951 172 B
Component: Sensor, DWA 004 0403
Serial number: 000000000ZL22042X5SC
Subsystem 2 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000002331379
left tail lamp 1:
Subsystem 3 - Part No SW: 4M8 945 069 B HW: 4M8 945 069 B
Component: SHL_li1 H04 0004
Serial number: 069B2203280000072076
Subsystem 4 - Part No SW: 3G0 962 243 D HW: 3G0 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 39292341
left tail lamp 2:
Subsystem 5 - Part No SW: 4M8 945 217 F HW: 4M8 945 217 F
Component: SHL_li2 H04 0004
Serial number: 217F2203260000070982
Right rear tail lamp 1:
Subsystem 6 - Part No SW: 4M8 945 070 B HW: 4M8 945 070 B
Component: SHL_re1 H04 0004
Serial number: 070B2203280000072089
Right rear tail lamp 2:
Subsystem 7 - Part No SW: 4M8 945 218 F HW: 4M8 945 218 F
Component: SHL_re2 H04 0004
Serial number: 218F2203260000070982
65569 - Databus
[Passenger side rear door control module: TSG_HBFS_01: no signal/communication]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:12:34
Supply voltages-Terminal 30 power supply: 11.821 V
Supply voltages-Supply voltage Terminal 30 - 2: 11.821 V
Supply voltages-Supply voltage Terminal 30 - 3: 11.807 V
general_additional_freeze_frame-terminal_control_intern_status: 1B 01 5E 12 04 F8
131074 - Antenna for Access/Start Authorization; Left
B1474 13 [00001001] - Open Circuit
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:31:15
Supply voltages-Terminal 30 power supply: 12.024 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.011 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.011 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 42 10 04 80
antenna_freeze_frame: 00000100 00000000 00000000 00111000
131109 - Touch Sensor on Exterior Door Grip; Rear Left
B116D 13 [00001001] - Open Circuit
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.08
Time: 10:32:49
Supply voltages-Terminal 30 power supply: 11.903 V
Supply voltages-Supply voltage Terminal 30 - 2: 11.875 V
Supply voltages-Supply voltage Terminal 30 - 3: 11.903 V
general_additional_freeze_frame-terminal_control_intern_status: 91 04 0A 12 04 98
exterior_handle_sensor_freeze_frame: 00000000 00000000 00000000 00000001
Part No SW: 4M1 959 792 J HW: 4M1 959 792 D
Component: TSG BFS003 0430
Serial number: YE007VB504875 Dataset Number: 4M8909873D 0028
Coding: 001DCA025E010482A009B430
VCID: 45D0898AD52862A22CD-8010
B201D 00 [00001001] - -
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:17:33
1114113 - Local Data Bus
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:12:33
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 4M2 035 089 B HW: 4M2 035 089 A
Component: MU-TP-ND-RW 044 3611
Serial number: GRO-63313.04.22 Dataset Number: 4M8909545M 0009
Coding: 15363008804200000000000000000000000000000000000000
ASAM Dataset: EV_MUTI 001010
ROD: EV_MUTI_AU58.rod
VCID: 2E02D626609EC1FAFD7-807A
Multimedia System 1:
Subsystem 1 - Part No SW: 4M8 919 605 M HW: 4M8 919 605 M
Component: DU AU536 Top H41 0060
Serial number: INX00119122100151079
Subsystem 2 - Part No: V03 959 822 JP
Component: MIB3_RW_ 1263
Compact disc data bank:
Component: Gracenote2 4009
Multimedia System 5:
Subsystem 4 - Part No SW: 4N0 919 603 M HW: 4N0 919 603 M
Component: DU AU651 Bot H41 0060
Serial number: INX00121022200170386
Volume Control 1:
Subsystem 5 - Part No SW: 4N1 919 616 B HW: 4N1 919 616
Component: LSR-D5/C8 H33 0110
Serial number: 00007522000049235047
Media socket:
Subsystem 6 - Part No: 4N1 035 736
007 0007
Digital Sound System Control Module 2:
Subsystem 7 - Part No SW: 8Y0 035 465 A HW: 8Y0 035 465 A
Component: B_A_3_P_0_AU H11 0100
Serial number: HHA-07317.03.2234860
9463059 - Rear Left Bass Speaker
B1065 13 [00001001] - Open Circuit
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:10
Voltage terminal 30: 11.4 V
Address 61: Battery Regul. (J1120) Labels: None
Part No SW: 4M0 915 169 G HW: 4M0 915 169 G
Component: BMS_48V_SCAP H08 0115
Serial number: 220950003780111
ASAM Dataset: EV_SCAP0213061 001004
ROD: EV_SCAP0213061.rod
VCID: 372CF3429FC40032AE1-8062
53762 - HV Battery Discharge Current
P0CA7 00 [00001000] - Too High
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
High-volt. battery mode: spec. value: Standby-mode
Mode HV battery actual value: Hybrid battery mode: emergency shutdown
H-V battery voltage: 39.50 V
Voltage in H-V system-Voltage of hybrid battery after protection: 0.30 V
Current of H-V / hybrid battery: 0.10 A
Battery temperature: 27 °C
Battery charge level: 73 %
Voltage terminal 30: 11.70 V
Power reduction status: not active
Crash signal: not active
Protection of posit. terminal of high voltage / hybrid battery: Open
maximum voltage for battery cells-Index 1: 0
maximum voltage for battery cells-Value: 1.91 V
minimum voltage for battery cells-Index 1: 0
minimum voltage for battery cells-Value: 1.86 V
Maximum charge level-Index 1: 0
Maximum charge level-Value: 70 %
Minimum charge level-Index 1: 0
Minimum charge level-Value: 68 %
Dynamic limit for charge current-Limit for charge current: 0 A
Predictive limit for charge current-Limit for charge current: 0 A
Dynamic limit for discharge current-Limit for discharge current: 0 A
Predictive limit for discharge current-Limit for discharge current: 0 A
Maximum charging voltage: 54.00 V
Minimum discharge voltage: 0.00 V
Minimum dynamic charging voltage: 41.00 V
Minimum predictive charging voltage: 41.00 V
Minimum dynamic discharge voltage: 38.00 V
Minimum predictive discharge voltage: 38.00 V
Address 65: Tire Pressure (J502) Labels: 4M0-907-273.clb
Part No SW: 4M0 907 273 B HW: 4M0 907 273 B
Component: RDKHUFAU736 H06 0010
Serial number: 30000000134774 Dataset Number: 4MF909850A 0004
ROD: EV_RDKHUFAU736_AU38.rod
VCID: 2F3CCB226794C8F2F61-807A
Part No SW: 4M0 959 107 F HW: 4M0 959 107 A
Component: HDSG-Modul H13 0172
Revision: -------- Serial number: A2-C737-6252-5 Dataset Number: 4M8909541E 0008
Coding: 2830
VCID: 3632FE4698CEF93AB57-8062
Address 74: Chassis Control (J775) Labels:* 4N0-907-777.clb
Part No SW: 4M8 907 777 CA HW: 4M8 907 777 C
Component: Fahrwerk-SG H53 2135
Serial number: 1404220104 Dataset Number: 4M8909576N 0001
Coding: 36606850FA64
ASAM Dataset: EV_ChassContrContiAU651 002016
ROD: EV_ChassContrContiAU651_002.rod
VCID: 025A52968486959A49F-8056
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004132693611
Coding: 303030
3342343 - Level Control System
C1046 F6 [10001001] - Axle Load Determination Not Performed
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
Internal DTC: 106
10747906 - Function Limitation due to Malfunction in Roll Stabilization
C1297 00 [10001001] - -
[Function restriction due to functional error eAWS FA]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
Internal DTC: 292
196608 - Ride Height Not Learned
C1044 00 [10001001] - -
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
Internal DTC: 836
196609 - Basic Setting of Deflected Position not Performed
C10C5 00 [10001001] - -
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
Internal DTC: 837
Part No SW: 4K0 035 284 F HW: 4K0 035 284 B
Component: CB_H_AUS 042 0371
Serial number: A976D0N2502497 Dataset Number: 4K0909612L 0015
Coding: 01E0E0F9C04080F6E0
ASAM Dataset: EV_ConBoxHighAU49X 001004
ROD: EV_ConBoxHighAU49X_AU58.rod
VCID: 2B04DF32538CB4D2DA9-807E
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M8 713 041 D HW: 4N2 713 041 C
Component: GSM-LL H10 0084
Revision: 0L0D5012 Serial number: 21120379252238
ASAM Dataset: EV_GSMWaehlZFAU736 001018
ROD: EV_GSMWaehlZFAU736_VW53.rod
VCID: 2D00D12A6D98BAE2C4D-8078
Address 82: Head Up Display (J898) Labels:| 4Nx-919-617-V1.clb
Part No SW: 4M8 919 617 J HW: 4M8 919 617 J
Component: HeadupDisplay H20 6051
Coding: 4600E0
ASAM Dataset: EV_HeadUpDisplAU65X 001011
ROD: EV_HeadUpDisplAU65X_VW53.rod
VCID: 44D6948EDE125BAA3B3-8010
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4K4 907 117 H HW: 4K4 907 117
Component: zFAS Var C H09 0371
Dataset Number: 4M8909466AB 0046
Coding: 04C188000000000000FBD60000FCC40E1B9F5200000000D8000000000096D40100BBB8000000000000000080C00000000000000000000000F980800000000000000078D00080009000800080000000000080C00000E0
ASAM Dataset: EV_ZFASAU516 003008
ROD: EV_ZFASAU516_003.rod
VCID: 3436C44E8EB2EB2A8B3-8060
221201 - Front Camera for Driver-Assist Systems
C12B3 54 [00001001] - Missing Calibration / Basic Setting
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
Front camera: status of current initial calibration: not completed successfully
Front camera: details of current initial calibration-Year: 2000
Front camera: details of current initial calibration-Month: 0
Front camera: details of current initial calibration-Day: 0
Front camera: details of current initial calibration-Hours: 0
Front camera: details of current initial calibration-Minutes: 0
Front camera: details of current initial calibration-Seconds: 0
Front camera: details of current initial calibration-Odometer reading: 3 km
Front camera: details of current initial calibration-Status: Calibration not yet performed
Front camera: details of current initial calibration-Vehicle Identification Number (VIN): WAUZZZF19ND0
Front camera: details of current initial calibration-Focal length: 0
Front camera: details of current initial calibration-Calibration marks: line 1: 00111111
Front camera: details of current initial calibration-Calibration marks: line 2: 00111111
Front camera: details of current initial calibration-Calibration marks: line 3: 00111111
Front camera: details of current initial calibration-Calibration marks: line 4: 00111111
Front camera: details of current initial calibration-Calibration marks: line 5: 00111111
Front camera: details of current initial calibration-Main point of the camera: X coordinate: 640
Front camera: details of current initial calibration-Main point of the camera: Y coordinate: 480
Front camera: yaw angle (initial calibration)-Front_camera_yaw_angle_initial_calibration: -0.14 °
Front camera: pitch angle (initial calibration)-Front_camera_pitch_angle_initial_calibration: -0.00 °
Front camera: sway angle (initial calibration)-Front_camera_roll_angle_initial_calibration: -0.13 °
Front camera: camera height (initial calibration)-Front_camera_height_initial_calibration: 1558 mm
Front camera: calibration result (static calibration end of line)-Yaw angle: -0.14 °
Front camera: calibration result (static calibration end of line)-Pitch angle: -0.00 °
Front camera: calibration result (static calibration end of line)-Roll angle: -0.12 °
Front camera: calibration result (static calibration end of line)-Camera height: 1558 mm
Front camera: calibration results (end of line initial dynamic calibration)-Yaw angle: -8.85 °
Front camera: calibration results (end of line initial dynamic calibration)-Pitch angle: -5.67 °
Front camera: calibration results (end of line initial dynamic calibration)-Roll angle: -5.73 °
Front camera: calibration results (end of line initial dynamic calibration)-Camera height: 0 mm
Front camera: type of latest end of line calibration: static
Front camera: end of line calibration: adjustment: only static calibration
Initial online calibration status: not active
Initial online calibration: suitable single images: 0
EyeQ temperatures-CPU: -40 °C
EyeQ temperatures-VPM: -40 °C
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
65543 - Egress Warning
C12DD F0 [00001000] - Status Feedback for HMI Implausible
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:14
Profile master status exit warning-Mode: Malfunction
Profile master status exit warning-Nominal status: On
Profile master status exit warning-Actual status:: Malfunction
2117741 - Control unit for information electronics 1
U1054 00 [00001000] - No Communication
[ServiceConnectTimeout_ETH_Update]
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.08
Time: 10:04:41
Ethernet signal quality: good: link available
Part No SW: 4M8 907 159 B HW: 4K0 907 159
Component: SAS-GEN 2.5 H08 0001
Serial number: 220228290941
ROD: EV_SoundActuaGen2AU64X_003_VW27.rod
Address BA: Motor Mounts (J931) Labels: None
Part No SW: 4M0 907 145 E HW: 4M0 907 145 B
Component: AEMevo H11 0132
Dataset Number: 4M8909578D 0004
ASAM Dataset: EV_AEMZFAU736 006014
ROD: EV_AEMZFAU736_006.rod
Part No SW: 4M1 959 795 J HW: 4M1 959 795 D
Component: TSG HFS005 0430
Serial number: YE007VBK0269A Dataset Number: 4M8909897D 0028
Coding: 000DC80200010482A008B020
VCID: 48CE80BEE23A7FCAD7B-801C
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:17:33
Address C4: DC/DC Converter (A7) Labels: None
Part No SW: 4K0 959 682 HW: 4K0 959 682
Component: DCDC_GEN_2 H20 0307
Serial number: DC22102000138 Dataset Number: 4M8909475B 0005
ASAM Dataset: EV_DCDC48VFLEXAU581 004001
ROD: EV_DCDC48VFLEXAU581_004_VW38.rod
VCID: 76B23E46D84EB93A757-8022
Part No SW: 89A 907 594 BC HW: 89A 907 594
Component: SAD_STG_1 006 0031
Dataset Number: 4M8909469E 0014
Coding: 728040053632
ASAM Dataset: EV_SunRoofCONTIAU736 009012
VCID: 79A8357AE950D642185-802C
Address CB: Rear Axle Steering (J1019) Labels:* 4M0-909-145.clb
Part No SW: 4M0 909 145 AA HW: 4M0 909 145 E
Component: HAL_MLBevoH08 0698
Revision: -------- Serial number: CCC_098_B_1122_ Dataset Number: 4M8909904G 0002
Coding: 42248A00
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
VCID: 6FBC0B22A71488F2B61-803A
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H24 0588
Dataset Number: 4M8909468E 0016
Coding: 4FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001022
ROD: EV_RearRadarS2DelphAU651.rod
2240525 - Databus
Reset counter: 154
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:08
Voltage terminal 30: 11.50 V
Address D4: Roll Control 1 (----) Labels: None
Part No SW: 971 907 156 T HW: 971 907 156 L
Component: EAWSH17 0311
Serial number: 00120220227271 Dataset Number: 4M8909592D 0001
ASAM Dataset: EV_EAWSSchaeFront 008001
ROD: EV_EAWSSchaeFront_VW53.rod
VCID: 3138CD5A71A0DE02E05-8064
12681249 - Internal Fault
B200F F0 [10001001] - Unknown Error Elaboration
[GDU_OVERCURRENT]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
Spannung KL30: 11.6 V
Spannung KL40: 0.00 V
Micro Controller Temperatur: 38 °C
Endstufe-Temperatur: 34 °C
Aktor-Motor-Temperatur: 30 °C
Current: -2 A
Steller Position: 0 °
Steller Drehzahl: 0 rad/s
Transverse acceleration: 0.29 m/s²
Derating (Über-/Unterspannnung) niedere Bit (MSB): 00000101
Abstuetzkraft: -10 N
System status: Stoerung
Derating (Über-/Unterspannnung) höhere Bit (MSB): 00000000
Fahrzeuggeschwindigkeit Steller: 0.00 km/h
Fehlerpfad: 00
DTC: C1 80 21
Status HW-KL15: active
MVK_eAWS_Sollmodus: No enabling
Zeit Nach KL15-Wechsel: 51.0 s
Fahrprogram: Program 2
Batterieabriss: 00
Steller-Isttorsion: 1.9062500
Steller-Solltorsion: 0.0000000
StellerTorsion Init: 0.0000000
Externer Verdrehwinkel: 0.0937500
Externe Winkelgeschwindigkeit: 0.0000000
ElektroMotor Istmoment: 0.0000
EawsCrtlActiveStatus: active
LL-Statemachine (Commutation Task) State: State: Safe Mode
Address D5: Roll Control 2 (----) Labels: None
Serial number: 00120220306294 Dataset Number: 4M8909593D 0001
ASAM Dataset: EV_EAWSSchaeRear 008001
ROD: EV_EAWSSchaeRear_AU58.rod
12665857 - Internal Fault
B200F FE [00001001] - Unknown Error Elaboration
[Störungsmeldung eAWS_VA]
Reset counter: 114
Mileage: 12355 km
Date: 2024.12.04
Time: 20:11:07
Spannung KL30: 11.4 V
Micro Controller Temperatur: 35 °C
Endstufe-Temperatur: 29 °C
Aktor-Motor-Temperatur: 27 °C
Current: -2 A
Steller Position: 1 °
System status: Init
Fehlerpfad: 00
DTC: C1 44 01
Batterieabriss: 00
Steller-Isttorsion: 0.0000000
Externer Verdrehwinkel: 0.0000000
LL-Statemachine (Commutation Task) State: State: Temp Safe Mode
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0032
Dataset Number: 4M8909471E 0013
ROD: EV_LMSLeftHELLAAU58X.rod
VCID: 72BA0256B426A51A59F-8026
Dataset Number: 4M8909472E 0013
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 AM HW: 4N0 907 669 A
Component: MRR_VR H28 0588
Dataset Number: 4M8909482E 0014
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001022
ROD: EV_FrontCorneRadarS1AU651.rod
VCID: 0550498A95A8A2A26CD-8050
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H28 0588
Dataset Number: 4M8909483E 0015
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001022
ROD: EV_FrontCorneRadarS2AU651.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:| 4N0-035-502.clb
Part No SW: 4N0 035 502 B HW: 4N0 035 502 B
Component: WLC Front H14 0061
Coding: 400000
Shop #: WSC 31414 051 00001
VCID: 231437123B5C7C92629-8076
End----(Elapsed Time: 02:35, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
